[U-Boot] [PATCH v2 0/4] ARM: atmel: boards: enable SPL support
This patch series enable SPL support for following boards: - at91sam9m10g45ek - NAND flash boot support - SD card boot support - at91sam9n12ek - NAND flash boot support - SPI flash boot support - at91sam9x5ek - NAND flash boot support - SPI flash boot support
Changes in v2: - Remove the meaningless prefix "+S:" in configuration file.
Bo Shen (4): ARM: atmel: arm926ejs: fix clock configuration ARM: atmel: at91sam9m10g45ek: enable spl support ARM: atmel: at91sam9x5ek: enable spl support ARM: atmel: at91sam9n12ek: enable spl support
arch/arm/mach-at91/Kconfig | 3 + arch/arm/mach-at91/Makefile | 2 + arch/arm/mach-at91/arm926ejs/clock.c | 54 +++++++++-------- arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 48 +++++++++++++++ arch/arm/mach-at91/include/mach/at91_pmc.h | 6 +- arch/arm/mach-at91/include/mach/at91sam9x5.h | 10 ++++ arch/arm/mach-at91/mpddrc.c | 3 +- arch/arm/mach-at91/spl.c | 2 +- arch/arm/mach-at91/spl_at91.c | 11 +++- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 80 +++++++++++++++++++++++++ board/atmel/at91sam9n12ek/at91sam9n12ek.c | 73 ++++++++++++++++++++++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 74 +++++++++++++++++++++++ configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + include/configs/at91sam9m10g45ek.h | 58 ++++++++++++++++++ include/configs/at91sam9n12ek.h | 58 +++++++++++++++++- include/configs/at91sam9x5ek.h | 57 ++++++++++++++++++ 21 files changed, 513 insertions(+), 32 deletions(-) create mode 100644 arch/arm/mach-at91/arm926ejs/u-boot-spl.lds
Config MCKR according to the datasheet sequence, or else it will cause the MCKR configuration failed.
Remove timeout checking for clock configuration, if configure the clock failed, let the system hang while not run in wrong clock configuration.
Signed-off-by: Bo Shen voice.shen@atmel.com Tested-by: Heiko Schocher hs@denx.de ---
Changes in v2: None
arch/arm/mach-at91/arm926ejs/clock.c | 54 +++++++++++++++++++----------------- 1 file changed, 28 insertions(+), 26 deletions(-)
diff --git a/arch/arm/mach-at91/arm926ejs/clock.c b/arch/arm/mach-at91/arm926ejs/clock.c index f363982..8d6934e 100644 --- a/arch/arm/mach-at91/arm926ejs/clock.c +++ b/arch/arm/mach-at91/arm926ejs/clock.c @@ -195,50 +195,52 @@ int at91_clock_init(unsigned long main_clock) void at91_plla_init(u32 pllar) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - int timeout = AT91_PLL_LOCK_TIMEOUT;
writel(pllar, &pmc->pllar); - while (!(readl(&pmc->sr) & (AT91_PMC_LOCKA | AT91_PMC_MCKRDY))) { - timeout--; - if (timeout == 0) - break; - } + while (!(readl(&pmc->sr) & AT91_PMC_LOCKA)) + ; } void at91_pllb_init(u32 pllbr) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - int timeout = AT91_PLL_LOCK_TIMEOUT;
writel(pllbr, &pmc->pllbr); - while (!(readl(&pmc->sr) & (AT91_PMC_LOCKB | AT91_PMC_MCKRDY))) { - timeout--; - if (timeout == 0) - break; - } + while (!(readl(&pmc->sr) & AT91_PMC_LOCKB)) + ; }
void at91_mck_init(u32 mckr) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - int timeout = AT91_PLL_LOCK_TIMEOUT; u32 tmp;
tmp = readl(&pmc->mckr); - tmp &= ~(AT91_PMC_MCKR_PRES_MASK | - AT91_PMC_MCKR_MDIV_MASK | - AT91_PMC_MCKR_PLLADIV_MASK | - AT91_PMC_MCKR_CSS_MASK); - tmp |= mckr & (AT91_PMC_MCKR_PRES_MASK | - AT91_PMC_MCKR_MDIV_MASK | - AT91_PMC_MCKR_PLLADIV_MASK | - AT91_PMC_MCKR_CSS_MASK); + tmp &= ~AT91_PMC_MCKR_PRES_MASK; + tmp |= mckr & AT91_PMC_MCKR_PRES_MASK; writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ;
- while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) { - timeout--; - if (timeout == 0) - break; - } + tmp = readl(&pmc->mckr); + tmp &= ~AT91_PMC_MCKR_MDIV_MASK; + tmp |= mckr & AT91_PMC_MCKR_MDIV_MASK; + writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; + + tmp = readl(&pmc->mckr); + tmp &= ~AT91_PMC_MCKR_PLLADIV_MASK; + tmp |= mckr & AT91_PMC_MCKR_PLLADIV_MASK; + writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; + + tmp = readl(&pmc->mckr); + tmp &= ~AT91_PMC_MCKR_CSS_MASK; + tmp |= mckr & AT91_PMC_MCKR_CSS_MASK; + writel(tmp, &pmc->mckr); + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; }
void at91_periph_clk_enable(int id)
Dear Bo Shen,
Bo Shen voice.shen@atmel.com writes:
Changes in v2: None
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Supports boot up from NAND flash with software ECC eanbled. And supports boot up from SD/MMC card with FAT file system.
As the boot from SD/MMC card with FAT file system, the BSS segment is too big to fit into SRAM, so, use the lds to put it into SDRAM.
Signed-off-by: Bo Shen voice.shen@atmel.com ---
arch/arm/mach-at91/Kconfig | 1 + arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 48 +++++++++++++++ arch/arm/mach-at91/spl_at91.c | 6 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 80 +++++++++++++++++++++++++ configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + include/configs/at91sam9m10g45ek.h | 58 ++++++++++++++++++ 7 files changed, 194 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-at91/arm926ejs/u-boot-spl.lds
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 30945c1..25da926 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -66,6 +66,7 @@ config TARGET_STAMP9G20 config TARGET_AT91SAM9M10G45EK bool "Atmel AT91SAM9M10G45-EK board" select CPU_ARM926EJS + select SUPPORT_SPL
config TARGET_PM9G45 bool "Ronetix pm9g45 board" diff --git a/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds new file mode 100644 index 0000000..acadd1d --- /dev/null +++ b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2015 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, \ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + *(.vectors) + arch/arm/cpu/arm926ejs/start.o (.text*) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + + . = ALIGN(4); + __image_copy_end = .; + + .end : + { + *(.__end) + } >.sram + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end = .; + } >.sdram +} diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index 89f588b..af6fc0d 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -71,7 +71,11 @@ void __weak at91_spl_board_init(void) { }
-void spl_board_init(void) +void __weak spl_board_init(void) +{ +} + +void board_init_f(ulong dummy) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index b807ef9..4289179 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -8,6 +8,7 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/clk.h> #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> @@ -15,6 +16,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> +#include <linux/mtd/nand.h> #include <atmel_lcdc.h> #include <atmel_mci.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) @@ -71,6 +73,84 @@ void at91sam9m10g45ek_nand_hw_init(void) } #endif
+#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ + /* + * On the at91sam9m10g45ek board, the chip wm9711 stays in the + * test mode, so it needs do some action to exit test mode. + */ + at91_periph_clk_enable(ATMEL_ID_PIODE); + at91_set_gpio_output(AT91_PIN_PD7, 0); + at91_set_gpio_output(AT91_PIN_PD8, 0); + at91_set_pio_pullup(AT91_PIO_PORTD, 7, 1); + at91_set_pio_pullup(AT91_PIO_PORTD, 8, 1); + +#ifdef CONFIG_SYS_USE_MMC + at91_mci_hw_init(); +#elif CONFIG_SYS_USE_NANDFLASH + at91sam9m10g45ek_nand_hw_init(); +#endif +} + +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_14 | + ATMEL_MPDDRC_CR_DQMS_SHARED | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3); + + ddr2->rtr = 0x24b; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET |/* 6*7.5 = 45 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET |/* 2*7.5 = 15 ns */ + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | /* 2*7.5 = 15 ns */ + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | /* 8*7.5 = 60 ns */ + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | /* 2*7.5 = 15 ns */ + 1 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | /* 1*7.5= 7.5 ns*/ + 1 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | /* 1 clk cycle */ + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); /* 2 clk cycles */ + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | /* 2*7.5 = 15 ns */ + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 16 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 14 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (1 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 0 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddr ddr2; + unsigned long csa; + + ddr2_conf(&ddr2); + + /* enable DDR2 clock */ + writel(0x4, &pmc->scer); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&mat->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + csa &= ~AT91_MATRIX_EBI_VDDIOMSEL_3_3V; + writel(csa, &mat->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_CS6, &ddr2); +} +#endif + #ifdef CONFIG_CMD_USB static void at91sam9m10g45ek_usb_hw_init(void) { diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 6949d3a..f3e1ebe 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 30967e3..5e0b16e 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index db5d5ea..e4c49f4 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -203,4 +203,62 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000)
+/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x010000 +#define CONFIG_SPL_STACK 0x310000 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT + +#define CONFIG_SYS_MONITOR_LEN 0x80000 + +#ifdef CONFIG_SYS_USE_MMC + +#define CONFIG_SPL_BSS_START_ADDR 0x70000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00080000 +#define CONFIG_SYS_SPL_MALLOC_START 0x70080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000 + +#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x400 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT + +#elif CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63, } +#endif + +#define CONFIG_SPL_ATMEL_SIZE +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define CONFIG_SYS_AT91_PLLA 0x20c73f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define ATMEL_BASE_MPDDRC ATMEL_BASE_DDRSDRC0 #endif
Dear Bo Shen,
Changes in v2:
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash.
arch/arm/mach-at91/Kconfig | 1 + arch/arm/mach-at91/Makefile | 1 + arch/arm/mach-at91/include/mach/at91_pmc.h | 6 ++- arch/arm/mach-at91/include/mach/at91sam9x5.h | 10 ++++ arch/arm/mach-at91/mpddrc.c | 3 +- arch/arm/mach-at91/spl.c | 2 +- arch/arm/mach-at91/spl_at91.c | 5 ++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 74 ++++++++++++++++++++++++++++ configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + include/configs/at91sam9x5ek.h | 57 +++++++++++++++++++++ 11 files changed, 157 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 25da926..bdf87f9 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -83,6 +83,7 @@ config TARGET_AT91SAM9RLEK config TARGET_AT91SAM9X5EK bool "Atmel AT91SAM9X5-EK board" select CPU_ARM926EJS + select SUPPORT_SPL
config TARGET_SAMA5D3_XPLAINED bool "SAMA5D3 Xplained board" diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index e596ba6..ba83616 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -2,6 +2,7 @@ obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o ifneq ($(CONFIG_SPL_BUILD),) obj-$(CONFIG_AT91SAM9G20) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o spl_at91.o +obj-$(CONFIG_AT91SAM9X5) += mpddrc.o spl_at91.o obj-$(CONFIG_SAMA5D3) += mpddrc.o spl_atmel.o obj-$(CONFIG_SAMA5D4) += mpddrc.o spl_atmel.o obj-y += spl.o diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index 65691ab..c903260 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -97,7 +97,8 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_CSS_PLLB 0x00000003 #define AT91_PMC_MCKR_CSS_MASK 0x00000003
-#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ + defined(CONFIG_AT91SAM9X5) #define AT91_PMC_MCKR_PRES_1 0x00000000 #define AT91_PMC_MCKR_PRES_2 0x00000010 #define AT91_PMC_MCKR_PRES_4 0x00000020 @@ -126,7 +127,8 @@ typedef struct at91_pmc { #else #define AT91_PMC_MCKR_MDIV_1 0x00000000 #define AT91_PMC_MCKR_MDIV_2 0x00000100 -#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ + defined(CONFIG_AT91SAM9X5) #define AT91_PMC_MCKR_MDIV_3 0x00000300 #endif #define AT91_PMC_MCKR_MDIV_4 0x00000200 diff --git a/arch/arm/mach-at91/include/mach/at91sam9x5.h b/arch/arm/mach-at91/include/mach/at91sam9x5.h index 36a5cdf..d18c936 100644 --- a/arch/arm/mach-at91/include/mach/at91sam9x5.h +++ b/arch/arm/mach-at91/include/mach/at91sam9x5.h @@ -124,6 +124,16 @@ #define ATMEL_BASE_EHCI 0x00700000 /* USB Host controller (EHCI) */ #endif
+/* + * External memory + */ +#define ATMEL_BASE_CS0 0x10000000 +#define ATMEL_BASE_CS1 0x20000000 +#define ATMEL_BASE_CS2 0x30000000 +#define ATMEL_BASE_CS3 0x40000000 +#define ATMEL_BASE_CS4 0x50000000 +#define ATMEL_BASE_CS5 0x60000000 + /* 9x5 series chip id definitions */ #define ARCH_ID_AT91SAM9X5 0x819a05a0 #define ARCH_ID_VERSION_MASK 0x1f diff --git a/arch/arm/mach-at91/mpddrc.c b/arch/arm/mach-at91/mpddrc.c index beec13d..24d5fcd 100644 --- a/arch/arm/mach-at91/mpddrc.c +++ b/arch/arm/mach-at91/mpddrc.c @@ -19,7 +19,8 @@ static inline void atmel_mpddr_op(int mode, u32 ram_address)
static int ddr2_decodtype_is_seq(u32 cr) { -#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) +#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ + defined(CONFIG_AT91SAM9X5) if (cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED) return 0; #endif diff --git a/arch/arm/mach-at91/spl.c b/arch/arm/mach-at91/spl.c index aaa5eec..27a405a 100644 --- a/arch/arm/mach-at91/spl.c +++ b/arch/arm/mach-at91/spl.c @@ -29,7 +29,7 @@ u32 spl_boot_device(void) return BOOT_DEVICE_MMC1; #elif CONFIG_SYS_USE_NANDFLASH return BOOT_DEVICE_NAND; -#elif CONFIG_SYS_USE_SERIALFLASH +#elif CONFIG_SYS_USE_SERIALFLASH || CONFIG_SYS_USE_SPIFLASH return BOOT_DEVICE_SPI; #endif return BOOT_DEVICE_NONE; diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index af6fc0d..e28e568 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -115,9 +115,14 @@ void board_init_f(ulong dummy) timer_init();
/* enable clocks for all PIOs */ +#ifdef CONFIG_AT91SAM9X5 + at91_periph_clk_enable(ATMEL_ID_PIOAB); + at91_periph_clk_enable(ATMEL_ID_PIOCD); +#else at91_periph_clk_enable(ATMEL_ID_PIOA); at91_periph_clk_enable(ATMEL_ID_PIOB); at91_periph_clk_enable(ATMEL_ID_PIOC); +#endif /* init console */ at91_seriald_hw_init(); preloader_console_init(); diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 17a2a40..114ac5c 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -293,3 +293,77 @@ int dram_init(void) CONFIG_SYS_SDRAM_SIZE); return 0; } + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ +#ifdef CONFIG_SYS_USE_MMC + at91_mci_hw_init(); +#elif CONFIG_SYS_USE_NANDFLASH + at91sam9x5ek_nand_hw_init(); +#elif CONFIG_SYS_USE_SPIFLASH + at91_spi0_hw_init(1 << 4); +#endif +} + +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED); + + ddr2->rtr = 0x411; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 19 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 18 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 3 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddr ddr2; + unsigned long csa; + + ddr2_conf(&ddr2); + + /* enable DDR2 clock */ + writel(0x4, &pmc->scer); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + csa &= ~AT91_MATRIX_EBI_DBPU_OFF; + csa |= AT91_MATRIX_EBI_DBPD_OFF; + csa |= AT91_MATRIX_EBI_EBI_IOSR_NORMAL; + writel(csa, &matrix->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_CS1, &ddr2); +} +#endif diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index c2ebb00..6eea1af 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 76f68a6..7ef1534 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6d8b71d..1a481b3 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -243,4 +243,61 @@ */ #define CONFIG_SYS_MALLOC_LEN (512 * 1024 + 0x1000)
+/* SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x6000 +#define CONFIG_SPL_STACK 0x308000 + +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SYS_MONITOR_LEN (512 << 10) + +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define CONFIG_SYS_AT91_PLLA 0x20c73f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define ATMEL_BASE_MPDDRC ATMEL_BASE_DDRSDRC + +#ifdef CONFIG_SYS_USE_MMC +#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x400 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT + +#elif CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0 +#define CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER + +#elif CONFIG_SYS_USE_SPIFLASH +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8400 + +#endif + #endif
Dear Bo Shen,
Changes in v2:
Hi Eugene, Hi Bo,
Sorry to hijack this thread, but I do have a few questions here.
I'm currently working on a mainline port for a custom board based on the CORE9G25 SoM [1] and would like to use U-Boot SPL instead of AT91Bootstrap. In this email, you "enable spl support" as stated in the commit subject, but CONFIG_SPL is not enabled for this board at any time. So only the code is present to e.g. init the DDR2 but its actually not executed. Or am I missing something here.
Could you please let me know, what the status of this SPL support for the AT91SAM9X5 is? Has this been tested without AT91Bootstrap lately?
Thanks, Stefan
[1] www.armdevs.com/CORE9G25.html
Changes in v2:
select SUPPORT_SPL
- defined(CONFIG_AT91SAM9X5) #define AT91_PMC_MCKR_PRES_1 0x00000000 #define AT91_PMC_MCKR_PRES_2 0x00000010 #define AT91_PMC_MCKR_PRES_4 0x00000020
- defined(CONFIG_AT91SAM9X5) #define AT91_PMC_MCKR_MDIV_3 0x00000300 #endif #define AT91_PMC_MCKR_MDIV_4 0x00000200
- External memory
- /* 9x5 series chip id definitions */ #define ARCH_ID_AT91SAM9X5 0x819a05a0 #define ARCH_ID_VERSION_MASK 0x1f
- defined(CONFIG_AT91SAM9X5) if (cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED) return 0; #endif
- at91_periph_clk_enable(ATMEL_ID_PIOAB);
- at91_periph_clk_enable(ATMEL_ID_PIOCD);
- at91_mci_hw_init();
- at91sam9x5ek_nand_hw_init();
- at91_spi0_hw_init(1 << 4);
+#endif +}
- ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM);
- ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 |
- ddr2->rtr = 0x411;
- ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET |
- ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET |
- ddr2->tpr2 = (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET |
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- struct atmel_mpddr ddr2;
- unsigned long csa;
- ddr2_conf(&ddr2);
- /* enable DDR2 clock */
- writel(0x4, &pmc->scer);
- /* Chip select 1 is for DDR2/SDRAM */
- csa = readl(&matrix->ebicsa);
- csa |= AT91_MATRIX_EBI_CS1A_SDRAMC;
- csa &= ~AT91_MATRIX_EBI_DBPU_OFF;
- csa |= AT91_MATRIX_EBI_DBPD_OFF;
- csa |= AT91_MATRIX_EBI_EBI_IOSR_NORMAL;
- writel(csa, &matrix->ebicsa);
- /* DDRAM2 Controller initialize */
- ddr2_init(ATMEL_BASE_CS1, &ddr2);
- #endif
Viele Grüße, Stefan
On 19.02.2019 15:27, Stefan Roese wrote:
Hi Eugene, Hi Bo,
I did not test myself the SPL for any 9x5 board. The DDR2 init code should be executed inside the SPL. Once you build your board with a CONFIG_SPL enabled, you should get the spl binary built, then you can add both SPL + U-boot proper on the boot media and have SPL boot (execute DDR init code and load U-boot proper). I would suggest to try on Sd-card first because it's easier (filesystem), but the commit says only SPI and NAND tested. You can also look at the U-boot version which first included this patch, some things may have changed since...
Let me know of your findings. I will let you know if I have the chance to test this myself.
Eugen
Thanks, Stefan
Hi Eugene,
Hi Eugene, Hi Bo,
On this board I only have NAND, so there is no option to first test some other boot device unfortunately.
Sure, I can and will check this. But I first wanted to check with you guys about the status, since you implemented and most likely also tested this stuff.
Okay. I'll try to test this stuff (even though I don't have JTAG on this board) and will get back to you with findings and most likely also some further questions.
Thanks, Stefan
Hi Eugene,
On 19.02.19 15:56, Stefan Roese wrote:
<snip>
So I did make some progress here but building and testing the SPL version by loading it to 0x30.0000 and starting it there via the "go" command. I'm not brave enough to flash it right now, since de-bricking might be tricky here, as I don't have JTAG. With the loaded version I'm able to fully load the main U-Boot image from NAND and run it from there to the prompt.
But then I looked at the latest AT91Bootstrap code and noticed the many changes in the lowlevel boot code (clocking, DDR2, etc). I'm a bit hesitant to port all this code to mainline U-Boot SPL here. One reason being that you at Microchip / Atmel will most likely continue to work on the AT91Bootstrap code and not on the potentially ported SPL code version. So what's you opinion here on this? Why do you not integrate all this code into U-Boot SPL and drop this bootstrap version completely? What is your suggestion for me on how to handle this? Stay with AT91Bootstrap or move to SPL?
Thanks, Stefan
On 21.02.2019 19:00, Stefan Roese wrote:
Hi Eugene,
<snip>
Hi Stefan,
Send me a patch and I can apply and test, but I cannot promise to have it very fast :) (or your git tree from where I can pull...) Have to make it for 9x5-ek board, as I do not have anything else at my disposal
At91boostrap is always recommended as we have the latest implementation and it's used by most of the people using at91 boards and more tested. We always try to keep SPL in sync , but it's only on best-effort at this moment I will review/take patches for SPL of course. There are people who use it so we try to have it working at all times.
Eugen
Thanks, Stefan
Hi Eugene,
Hi Eugene,
<snip>
Hi Stefan,
I might come back to your offer, thanks!
I see. The decision to completely move to SPL should have probably been made some years ago then (as other SoC vendors have done). Nothing to be done about this now.
Still, what I really like in this SPL approach vs the vendor pre U-Boot loader is, that all is encapsulated in one source code repository and one image usually is generated, simplifying the bootloader building and programming quite a bit.
Okay, good to know.
Thanks, Stefan
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash.
arch/arm/mach-at91/Kconfig | 1 + arch/arm/mach-at91/Makefile | 1 + arch/arm/mach-at91/include/mach/at91_pmc.h | 4 +- arch/arm/mach-at91/mpddrc.c | 2 +- arch/arm/mach-at91/spl_at91.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 73 ++++++++++++++++++++++++++++++ configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + include/configs/at91sam9n12ek.h | 58 +++++++++++++++++++++++- 9 files changed, 138 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index bdf87f9..30c4e17 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -75,6 +75,7 @@ config TARGET_PM9G45 config TARGET_AT91SAM9N12EK bool "Atmel AT91SAM9N12-EK board" select CPU_ARM926EJS + select SUPPORT_SPL
config TARGET_AT91SAM9RLEK bool "Atmel at91sam9rl reference board" diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index ba83616..0d3ee48 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -2,6 +2,7 @@ obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o ifneq ($(CONFIG_SPL_BUILD),) obj-$(CONFIG_AT91SAM9G20) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o spl_at91.o +obj-$(CONFIG_AT91SAM9N12) += mpddrc.o spl_at91.o obj-$(CONFIG_AT91SAM9X5) += mpddrc.o spl_at91.o obj-$(CONFIG_SAMA5D3) += mpddrc.o spl_atmel.o obj-$(CONFIG_SAMA5D4) += mpddrc.o spl_atmel.o diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index c903260..ebb7dec 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -98,7 +98,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_CSS_MASK 0x00000003
#if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ - defined(CONFIG_AT91SAM9X5) + defined(CONFIG_AT91SAM9X5) || defined(CONFIG_AT91SAM9N12) #define AT91_PMC_MCKR_PRES_1 0x00000000 #define AT91_PMC_MCKR_PRES_2 0x00000010 #define AT91_PMC_MCKR_PRES_4 0x00000020 @@ -128,7 +128,7 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_MDIV_1 0x00000000 #define AT91_PMC_MCKR_MDIV_2 0x00000100 #if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ - defined(CONFIG_AT91SAM9X5) + defined(CONFIG_AT91SAM9X5) || defined(CONFIG_AT91SAM9N12) #define AT91_PMC_MCKR_MDIV_3 0x00000300 #endif #define AT91_PMC_MCKR_MDIV_4 0x00000200 diff --git a/arch/arm/mach-at91/mpddrc.c b/arch/arm/mach-at91/mpddrc.c index 24d5fcd..e2b6a49 100644 --- a/arch/arm/mach-at91/mpddrc.c +++ b/arch/arm/mach-at91/mpddrc.c @@ -20,7 +20,7 @@ static inline void atmel_mpddr_op(int mode, u32 ram_address) static int ddr2_decodtype_is_seq(u32 cr) { #if defined(CONFIG_SAMA5D3) || defined(CONFIG_SAMA5D4) || \ - defined(CONFIG_AT91SAM9X5) + defined(CONFIG_AT91SAM9X5) || defined(CONFIG_AT91SAM9N12) if (cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED) return 0; #endif diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index e28e568..a79a9dc 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -115,7 +115,7 @@ void board_init_f(ulong dummy) timer_init();
/* enable clocks for all PIOs */ -#ifdef CONFIG_AT91SAM9X5 +#if defined(CONFIG_AT91SAM9X5) || defined(CONFIG_AT91SAM9N12) at91_periph_clk_enable(ATMEL_ID_PIOAB); at91_periph_clk_enable(ATMEL_ID_PIOCD); #else diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 9adc992..4f46a03 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -257,3 +257,76 @@ int dram_init(void) CONFIG_SYS_SDRAM_SIZE); return 0; } + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ +#ifdef CONFIG_SYS_USE_MMC + at91_mci_hw_init(); +#elif CONFIG_SYS_USE_NANDFLASH + at91sam9n12ek_nand_hw_init(); +#elif CONFIG_SYS_USE_SPIFLASH + at91_spi0_hw_init(1 << 4); +#endif +} + +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED); + + ddr2->rtr = 0x411; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 19 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 18 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (2 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 3 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddr ddr2; + unsigned long csa; + + ddr2_conf(&ddr2); + + /* enable DDR2 clock */ + writel(0x4, &pmc->scer); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + csa &= ~AT91_MATRIX_EBI_DBPU_OFF; + csa |= AT91_MATRIX_EBI_DBPD_OFF; + csa |= AT91_MATRIX_EBI_EBI_IOSR_NORMAL; + writel(csa, &matrix->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_CS1, &ddr2); +} +#endif diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index f908246..11b42d4 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index d106b5a..5426bcd 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -1,3 +1,4 @@ +CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" CONFIG_ARM=y CONFIG_ARCH_AT91=y diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index f02fce9..aeec8b8 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -228,6 +228,62 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) -#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +/* SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x6000 +#define CONFIG_SPL_STACK 0x308000 + +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SYS_MONITOR_LEN (512 << 10) + +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define CONFIG_SYS_AT91_PLLA 0x20953f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define ATMEL_BASE_MPDDRC ATMEL_BASE_DDRSDRC + +#ifdef CONFIG_SYS_USE_MMC +#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x400 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT + +#elif CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x40000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0 +#define CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER + +#elif CONFIG_SYS_USE_SPIFLASH +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8400 + +#endif
#endif
Dear Bo Shen,
Changes in v2:
Andreas Bießmann
Bo Shen
Stefan Roese
