[U-Boot] [PATCH] ARM: Remove unused CONFIG_DRIVER_SMC91111, CONFIG_DRIVER_LAN91C96
Remove unused CONFIG_DRIVER_SMC91111,CONFIG_DRIVER_LAN91C96, if required implement smc_set_mac_add() in board init.
Signed-off-by: Ashok Kumar Reddy ashokkourla2000@gmail.com --- arch/arm/lib/board.c | 17 ----------------- 1 file changed, 17 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 109a1ac..cb71b02 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -57,13 +57,6 @@ #include <miiphy.h> #endif
-#ifdef CONFIG_DRIVER_SMC91111 -#include "../drivers/net/smc91111.h" -#endif -#ifdef CONFIG_DRIVER_LAN91C96 -#include "../drivers/net/lan91c96.h" -#endif - DECLARE_GLOBAL_DATA_PTR;
ulong monitor_flash_len; @@ -593,16 +586,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* enable exceptions */ enable_interrupts();
- /* Perform network card initialisation if necessary */ -#if defined(CONFIG_DRIVER_SMC91111) || defined (CONFIG_DRIVER_LAN91C96) - /* XXX: this needs to be moved to board init */ - if (getenv("ethaddr")) { - uchar enetaddr[6]; - eth_getenv_enetaddr("ethaddr", enetaddr); - smc_set_mac_addr(enetaddr); - } -#endif /* CONFIG_DRIVER_SMC91111 || CONFIG_DRIVER_LAN91C96 */ - /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
Ashok Kumar Reddy
