[U-Boot] [RFC PATCH] net: designware: drop compatible altr, socfpga-stmmac
The same compatible = "altr,socfpga-stmmac" appears in both drivers/net/designware.c and drivers/net/dwmac_socfgpa.c, creating ambiguity in which driver will be bound.
For Intel/Altera SoC devices, dwmac_socfpga.c is the correct driver. So drop the compatible string from designware.c.
Signed-off-by: Ralph Siemsen ralph.siemsen@linaro.org --- This compatible string also appears in: axs10x_mb.dtsi and hsdk.dts. Maintainers of those boards have been copied, kindly review.
drivers/net/designware.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index c4fe40b19a..145eeac45f 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -847,7 +847,6 @@ int designware_eth_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id designware_eth_ids[] = { { .compatible = "allwinner,sun7i-a20-gmac" }, - { .compatible = "altr,socfpga-stmmac" }, { .compatible = "amlogic,meson6-dwmac" }, { .compatible = "amlogic,meson-gx-dwmac" }, { .compatible = "amlogic,meson-gxbb-dwmac" },
Hi Ralph,
-----Original Message----- From: Ralph Siemsen ralph.siemsen@linaro.org Sent: Monday, August 19, 2019 9:43 PM To: u-boot@lists.denx.de; Joe Hershberger joe.hershberger@ni.com; Alexey Brodkin abrodkin@synopsys.com; Vlad Zakharov vzakhar@synopsys.com Cc: Ralph Siemsen ralph.siemsen@linaro.org Subject: [RFC PATCH] net: designware: drop compatible altr,socfpga-stmmac
Thanks for this clean-up.
Speaking about AXS10x board where we do have DW GMAC I cannot recall the reason I chose to use "altr,socfpga-stmmac" for the board here [1] 3 years ago.
But given we don't have any special quirks implemented whatever is the most generic DW GMAC compatible string is should be good for us.
Joe, could you please suggest if we need to use just "st,stm32-dwmac" or add our own compatible as the ASIC is not from ST obviously but an FPGA with Synopsys ARC SoC?
[1] https://gitlab.denx.de/u-boot/u-boot/commit/fb2dea60e8f355ae00d427db09112a90...
-Alexey
On Tue, Aug 20, 2019 at 3:07 AM Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
Hi Ralph,
I think we should only be using what Linux does, so I'm afraid I have to defer to what exists in the DTs there.
-Joe
-Alexey _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Joe,
-----Original Message----- From: Joe Hershberger joe.hershberger@ni.com Sent: Wednesday, September 4, 2019 1:10 AM To: Alexey Brodkin abrodkin@synopsys.com Cc: Ralph Siemsen ralph.siemsen@linaro.org; Joseph Hershberger joseph.hershberger@ni.com; u- boot@lists.denx.de; linux-snps-arc@lists.infradead.org; Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com Subject: Re: [U-Boot] [RFC PATCH] net: designware: drop compatible altr, socfpga-stmmac
Hi Ralph,
In the Linux kernel we use "snps,dwmac", see [1]. But maybe we need to switch to "snps,dwmac-3.70a" even as what we really have is 3.73a.
While in U-Boot we don't have either one, the most generic is "st,stm32-dwmac", see [2]. So maybe we want to add at least "snps,dwmac".
@Jose Abreu could you please confirm if "snps,dwmac-3.70a" is OK for GMAC IP v3.73a?
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch... [2] https://gitlab.denx.de/u-boot/u-boot/blob/master/drivers/net/designware.c#L8...
-Alexey
From: Alexey Brodkin abrodkin@synopsys.com Date: Sep/04/2019, 06:59:01 (UTC+00:00)
Hi Joe,
Hi Ralph,
Yes it should be okay.
-Alexey
--- Thanks, Jose Miguel Abreu
Ralph Siemsen ralph.siemsen@linaro.org schrieb am Mo., 19. Aug. 2019, 20:43:
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
-- 2.17.1
On Mon, Aug 19, 2019 at 1:43 PM Ralph Siemsen ralph.siemsen@linaro.org wrote:
Hi Ralph,
https://patchwork.ozlabs.org/patch/1149481/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
participants (5)
Alexey Brodkin
Joe Hershberger
Jose Abreu
Ralph Siemsen
Simon Goldschmidt
