[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
Changes from last merge window.
The following changes since commit d7d000311285e4b8d11e089ca13ea456a01be3b8:
Merge branch 'master' of git://git.denx.de/u-boot-mips (2016-05-23 11:51:37 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to 0a71cd77290ca317ecf6f15984a91abbee741e09:
net: phy: dp83867: Add SGMII helper for configuration (2016-05-24 11:42:05 -0500)
---------------------------------------------------------------- Dan Murphy (7): drivers: net: cpsw: Add reading of DT phy-handle node net: zynq_gem: Add the passing of the phy-handle node net: phy: dp83867: Add device tree bindings and documentation net: phy: ti: Allow the driver to be more configurable net: phy: Move is_rgmii helper to phy.h net: phy: Add phy_interface_is_sgmii to phy.h net: phy: dp83867: Add SGMII helper for configuration
Kevin Smith (2): net: Remove unused mv88e61xx switch driver net: phy: Add PHY driver for mv88e61xx switches
Mugunthan V N (12): drivers: core: device: add support to check dt compatible for a device/machine ti_omap5_common: eth: do not define DM_ETH for spl drivers: net: cpsw: fix cpsw dp parse when num slaves as 1 ARM: omap5: add platform specific ethernet phy modes configurations drivers: net: cpsw: fix get mdio base and gmii_sel reg from DT drivers: net: cpsw: add support for reading mac address from efuse arm: dts: am4372: add syscon node to cpsw to read mac address arm: dts: dra7: add syscon node to cpsw to read mac address arm: dts: dra7: fix ethernet name with proper device address defconfig: am437x_gp_evm: enable eth driver model defconfig: am437x_sk_evm: enable eth driver model defconfig: dra74_evm: enable eth driver model
arch/arm/dts/am4372.dtsi | 1 + arch/arm/dts/dra7.dtsi | 3 +- arch/arm/include/asm/arch-omap5/cpu.h | 12 + configs/am437x_gp_evm_defconfig | 1 + configs/am437x_sk_evm_defconfig | 1 + configs/dra74_evm_defconfig | 1 + doc/device-tree-bindings/net/ti,dp83867.txt | 25 + drivers/core/device.c | 14 + drivers/net/Makefile | 2 +- drivers/net/cpsw-common.c | 121 +++ drivers/net/cpsw.c | 77 +- drivers/net/phy/mv88e61xx.c | 1322 ++++++++++++++++++--------- drivers/net/phy/mv88e61xx.h | 61 -- drivers/net/phy/phy.c | 3 + drivers/net/phy/ti.c | 88 +- drivers/net/zynq_gem.c | 15 +- include/configs/ti_omap5_common.h | 1 + include/cpsw.h | 2 + include/dm/device.h | 23 + include/dt-bindings/net/ti-dp83867.h | 35 + include/netdev.h | 58 -- include/phy.h | 23 + 22 files changed, 1300 insertions(+), 589 deletions(-) create mode 100644 doc/device-tree-bindings/net/ti,dp83867.txt create mode 100644 drivers/net/cpsw-common.c delete mode 100644 drivers/net/phy/mv88e61xx.h create mode 100644 include/dt-bindings/net/ti-dp83867.h
Thanks! -Joe
On Tue, May 24, 2016 at 11:50:33AM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
