[PATCH v2] imx8mp-evk: Add USB0 OTG support
Add USB0 OTG support.
Currently, the USB0 OTG nodes are not enabled in the Linux kernel devicetree.
For this reason, enable the USB0 OTG nodes inside imx8mp-evk-u-boot.dtsi for now.
Also select several useful options such as USB gadget and fastboot.
Tested by running "ums 0 mmc 2".
Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v1: - Selected CONFIG_PHY=y and CONFIG_PHY_IMX8MQ_USB=y. Previously the ums command was working only after booting via USB serial download mode. Now it also works after booting from SD card.
arch/arm/dts/imx8mp-evk-u-boot.dtsi | 14 +++++++++++++ configs/imx8mp_evk_defconfig | 31 +++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 6784ed2e7c92..43f13a9c22f7 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -111,6 +111,20 @@ bootph-pre-ram; };
+&usb3_phy0 { + status = "okay"; +}; + +&usb3_0 { + status = "okay"; +}; + +&usb_dwc3_0 { + pinctrl-names = "default"; + dr_mode = "peripheral"; + status = "okay"; +}; + &usdhc1 { bootph-pre-ram; }; diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index da1f5d1ad2e0..c129170bf83d 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -59,6 +59,9 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y @@ -74,6 +77,14 @@ CONFIG_ETHPRIME="eth1" CONFIG_SPL_DM=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x42800000 +CONFIG_FASTBOOT_BUF_SIZE=0x20000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y @@ -94,10 +105,15 @@ CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_SPL_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y CONFIG_POWER_PCA9450=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y @@ -109,4 +125,19 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_EHCI_HCD=y +# CONFIG_USB_EHCI_MX7 is not set +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_SDP_LOADADDR=0x0 CONFIG_IMX_WATCHDOG=y
Changes since v1:
+&usb3_phy0 {
- status = "okay";
Keep the list sorted, _0 goes before _phy0, doesn't it ?
+&usb3_0 {
- status = "okay";
+&usb_dwc3_0 {
- pinctrl-names = "default";
Is this ^ pinctrl-names without pinctrl-0 property needed ?
- dr_mode = "peripheral";
- status = "okay";
- &usdhc1 { bootph-pre-ram; };
With that fixed:
Fabio Estevam
