[PATCH v2 1/2] ARM: dts: at91: sam9x60: add pioC node
Add node for pioC.
Signed-off-by: Mihai Sain mihai.sain@microchip.com --- changes in v2: - none
arch/arm/dts/sam9x60.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index e801331d80..be44519934 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -22,6 +22,7 @@ serial0 = &dbgu; gpio0 = &pioA; gpio1 = &pioB; + gpio2 = &pioC; gpio3 = &pioD; spi0 = &qspi; }; @@ -197,6 +198,14 @@ clocks = <&pmc PMC_TYPE_PERIPHERAL 3>; };
+ pioC: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + #gpio-cells = <2>; + gpio-controller; + clocks = <&pmc PMC_TYPE_PERIPHERAL 4>; + }; + pioD: gpio@fffffa00 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffffa00 0x200>;
Add clock command for CLK sub-system and gpio command for query and control gpio pins.
Signed-off-by: Mihai Sain mihai.sain@microchip.com --- Changes in v2: - fixed short commit, it's configs not DTS.
configs/sam9x60ek_mmc_defconfig | 2 ++ configs/sam9x60ek_nandflash_defconfig | 2 ++ configs/sam9x60ek_qspiflash_defconfig | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index fd6f89ad59..4270fa340e 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -25,7 +25,9 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLK=y CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index de8dc1dac8..507d596cbc 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -25,7 +25,9 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLK=y CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index d3dd9fc71c..437272897a 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -26,7 +26,9 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLK=y CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y
On 11/2/21 10:28 AM, Eugen Hristev wrote:
Add node for pioC.
changes in v2:
- none
Applied both to u-boot-at91/next
Eugen Hristev
Eugen.Hristev@microchip.com
