[U-Boot] [PATCH][v4] crypto/fsl - Add progressive hashing support using hardware acceleration.
Currently only normal hashing is supported using hardware acceleration. Added support for progressive hashing using hardware.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com Signed-off-by: Gaurav Rana gaurav.rana@freescale.com CC: Simon Glass sjg@chromium.org --- Changes in v4: Add CONFIG_SHA256, CONFIG_SHA256, CONFIG_SHA_PROG_HW_ACCEL, CONFIG_SHA_HW_ACCEL to Kconfig. Modify README for these configs descriptions.
Changes in v3: Remove duplication of code and create function gen_hash_type. Modify MAX_SG to MAX_SG_32
Changes in v2: Merge to common functions for SHA1 and SHA256. Replace malloc and memset with calloc. Remove cast conversions for void* pointers. Replace hardcoded errors with Macros. Corrected comments.
Kconfig | 4 +- README | 23 +++++-- common/hash.c | 10 +++ drivers/crypto/fsl/fsl_hash.c | 138 +++++++++++++++++++++++++++++++++++++++++- drivers/crypto/fsl/fsl_hash.h | 34 +++++++++++ include/fsl_sec.h | 26 ++++++++ include/hw_sha.h | 41 ++++++++++++- lib/Kconfig | 38 ++++++++++++ 8 files changed, 307 insertions(+), 7 deletions(-) create mode 100644 drivers/crypto/fsl/fsl_hash.h
diff --git a/Kconfig b/Kconfig index fed488f..c4afb82 100644 --- a/Kconfig +++ b/Kconfig @@ -121,7 +121,9 @@ config FIT_SIGNATURE select RSA help This option enables signature verification of FIT uImages, - using a hash signed and verified using RSA. + using a hash signed and verified using RSA. If + CONFIG_SHA_PROG_HW_ACCEL is defined, i.e support for progressive + hashing is available using hardware, RSA library will be using it. See doc/uImage.FIT/signature.txt for more details.
config SYS_EXTRA_OPTIONS diff --git a/README b/README index cac7978..7a3f1e7 100644 --- a/README +++ b/README @@ -3149,8 +3149,21 @@ CBFS (Coreboot Filesystem) support Enable the hash verify command (hash -v). This adds to code size a little.
- CONFIG_SHA1 - support SHA1 hashing - CONFIG_SHA256 - support SHA256 hashing + CONFIG_SHA1 - This option enables support of hashing using SHA1 + algorithm. The hash is calculated in software. + CONFIG_SHA256 - This option enables support of hashing using + SHA256 algorithm. The hash is calculated in software. + CONFIG_SHA_HW_ACCEL - This option enables calculation of hash + using SHA1/SHA256 algorithm in hardware. The files using + hash_lookup_algo function would get pointer to structure having + hardware accelerated SHA support. The hash command would + automatically use hardware support if this option is enabled. + CONFIG_SHA_PROG_HW_ACCEL - This option enables SHA1 or SHA256 + progressive hashing using hardware acceleration. The + hash_progressive_lookup_algo function would return pointer to + structure having support for progressive hashing in hardware. + FIT_SIGNATURE which uses this function would automatically + use hardware support if this option is enabled.
Note: There is also a sha1sum command, which should perhaps be deprecated in favour of 'hash sha1'. @@ -3444,8 +3457,10 @@ FIT uImage format:
CONFIG_FIT_SIGNATURE This option enables signature verification of FIT uImages, - using a hash signed and verified using RSA. See - doc/uImage.FIT/signature.txt for more details. + using a hash signed and verified using RSA. If + CONFIG_SHA_PROG_HW_ACCEL is defined, i.e support for progressive + hashing is available using hardware, RSA library will be using it. + See doc/uImage.FIT/signature.txt for more details.
WARNING: When relying on signed FIT images with required signature check the legacy image format is default diff --git a/common/hash.c b/common/hash.c index d154d02..9e9f84b 100644 --- a/common/hash.c +++ b/common/hash.c @@ -127,11 +127,21 @@ static struct hash_algo hash_algo[] = { SHA1_SUM_LEN, hw_sha1, CHUNKSZ_SHA1, +#ifdef CONFIG_SHA_PROG_HW_ACCEL + hw_sha_init, + hw_sha_update, + hw_sha_finish, +#endif }, { "sha256", SHA256_SUM_LEN, hw_sha256, CHUNKSZ_SHA256, +#ifdef CONFIG_SHA_PROG_HW_ACCEL + hw_sha_init, + hw_sha_update, + hw_sha_finish, +#endif }, #endif #ifdef CONFIG_SHA1 diff --git a/drivers/crypto/fsl/fsl_hash.c b/drivers/crypto/fsl/fsl_hash.c index d77f257..c298404 100644 --- a/drivers/crypto/fsl/fsl_hash.c +++ b/drivers/crypto/fsl/fsl_hash.c @@ -10,6 +10,9 @@ #include "jobdesc.h" #include "desc.h" #include "jr.h" +#include "fsl_hash.h" +#include <hw_sha.h> +#include <asm-generic/errno.h>
#define CRYPTO_MAX_ALG_NAME 80 #define SHA1_DIGEST_SIZE 20 @@ -39,6 +42,122 @@ static struct caam_hash_template driver_hash[] = { }, };
+static enum caam_hash_algos get_hash_type(struct hash_algo *algo) +{ + if (!strcmp(algo->name, driver_hash[SHA1].name)) + return SHA1; + else + return SHA256; +} + +/* Create the context for progressive hashing using h/w acceleration. + * + * @ctxp: Pointer to the pointer of the context for hashing + * @caam_algo: Enum for SHA1 or SHA256 + * @return 0 if ok, -ENOMEM on error + */ +static int caam_hash_init(void **ctxp, enum caam_hash_algos caam_algo) +{ + *ctxp = calloc(1, sizeof(struct sha_ctx)); + if (*ctxp == NULL) { + debug("Cannot allocate memory for context\n"); + return -ENOMEM; + } + return 0; +} + +/* + * Update sg table for progressive hashing using h/w acceleration + * + * The context is freed by this function if an error occurs. + * We support at most 32 Scatter/Gather Entries. + * + * @hash_ctx: Pointer to the context for hashing + * @buf: Pointer to the buffer being hashed + * @size: Size of the buffer being hashed + * @is_last: 1 if this is the last update; 0 otherwise + * @caam_algo: Enum for SHA1 or SHA256 + * @return 0 if ok, -EINVAL on error + */ +static int caam_hash_update(void *hash_ctx, const void *buf, + unsigned int size, int is_last, + enum caam_hash_algos caam_algo) +{ + uint32_t final = 0; + dma_addr_t addr = virt_to_phys((void *)buf); + struct sha_ctx *ctx = hash_ctx; + + if (ctx->sg_num >= MAX_SG_32) { + free(ctx); + return -EINVAL; + } + +#ifdef CONFIG_PHYS_64BIT + ctx->sg_tbl[ctx->sg_num].addr_hi = addr >> 32; +#else + ctx->sg_tbl[ctx->sg_num].addr_hi = 0x0; +#endif + ctx->sg_tbl[ctx->sg_num].addr_lo = addr; + + sec_out32(&ctx->sg_tbl[ctx->sg_num].len_flag, + (size & SG_ENTRY_LENGTH_MASK)); + + ctx->sg_num++; + + if (is_last) { + final = sec_in32(&ctx->sg_tbl[ctx->sg_num - 1].len_flag) | + SG_ENTRY_FINAL_BIT; + sec_out32(&ctx->sg_tbl[ctx->sg_num - 1].len_flag, final); + } + + return 0; +} + +/* + * Perform progressive hashing on the given buffer and copy hash at + * destination buffer + * + * The context is freed after completion of hash operation. + * + * @hash_ctx: Pointer to the context for hashing + * @dest_buf: Pointer to the destination buffer where hash is to be copied + * @size: Size of the buffer being hashed + * @caam_algo: Enum for SHA1 or SHA256 + * @return 0 if ok, -EINVAL on error + */ +static int caam_hash_finish(void *hash_ctx, void *dest_buf, + int size, enum caam_hash_algos caam_algo) +{ + uint32_t len = 0; + struct sha_ctx *ctx = hash_ctx; + int i = 0, ret = 0; + + if (size < driver_hash[caam_algo].digestsize) { + free(ctx); + return -EINVAL; + } + + for (i = 0; i < ctx->sg_num; i++) + len += (sec_in32(&ctx->sg_tbl[i].len_flag) & + SG_ENTRY_LENGTH_MASK); + + inline_cnstr_jobdesc_hash(ctx->sha_desc, (uint8_t *)ctx->sg_tbl, len, + ctx->hash, + driver_hash[caam_algo].alg_type, + driver_hash[caam_algo].digestsize, + 1); + + ret = run_descriptor_jr(ctx->sha_desc); + + if (ret) + debug("Error %x\n", ret); + else + memcpy(dest_buf, ctx->hash, sizeof(ctx->hash)); + + free(ctx); + return ret; +} + int caam_hash(const unsigned char *pbuf, unsigned int buf_len, unsigned char *pout, enum caam_hash_algos algo) { @@ -48,7 +167,7 @@ int caam_hash(const unsigned char *pbuf, unsigned int buf_len, desc = malloc(sizeof(int) * MAX_CAAM_DESCSIZE); if (!desc) { debug("Not enough memory for descriptor allocation\n"); - return -1; + return -ENOMEM; }
inline_cnstr_jobdesc_hash(desc, pbuf, buf_len, pout, @@ -75,3 +194,20 @@ void hw_sha1(const unsigned char *pbuf, unsigned int buf_len, if (caam_hash(pbuf, buf_len, pout, SHA1)) printf("CAAM was not setup properly or it is faulty\n"); } + +int hw_sha_init(struct hash_algo *algo, void **ctxp) +{ + return caam_hash_init(ctxp, get_hash_type(algo)); +} + +int hw_sha_update(struct hash_algo *algo, void *ctx, const void *buf, + unsigned int size, int is_last) +{ + return caam_hash_update(ctx, buf, size, is_last, get_hash_type(algo)); +} + +int hw_sha_finish(struct hash_algo *algo, void *ctx, void *dest_buf, + int size) +{ + return caam_hash_finish(ctx, dest_buf, size, get_hash_type(algo)); +} diff --git a/drivers/crypto/fsl/fsl_hash.h b/drivers/crypto/fsl/fsl_hash.h new file mode 100644 index 0000000..f5be651 --- /dev/null +++ b/drivers/crypto/fsl/fsl_hash.h @@ -0,0 +1,34 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef _SHA_H +#define _SHA_H + +#include <fsl_sec.h> +#include <hash.h> +#include "jr.h" + +/* We support at most 32 Scatter/Gather Entries.*/ +#define MAX_SG_32 32 + +/* + * Hash context contains the following fields + * @sha_desc: Sha Descriptor + * @sg_num: number of entries in sg table + * @len: total length of buffer + * @sg_tbl: sg entry table + * @hash: index to the hash calculated + */ +struct sha_ctx { + uint32_t sha_desc[64]; + uint32_t sg_num; + uint32_t len; + struct sg_entry sg_tbl[MAX_SG_32]; + u8 hash[HASH_MAX_DIGEST_SIZE]; +}; + +#endif diff --git a/include/fsl_sec.h b/include/fsl_sec.h index aa850a3..b6e6f04 100644 --- a/include/fsl_sec.h +++ b/include/fsl_sec.h @@ -175,6 +175,32 @@ struct jr_regs { u32 jrcr; };
+/* + * Scatter Gather Entry - Specifies the the Scatter Gather Format + * related information + */ +struct sg_entry { +#ifdef CONFIG_SYS_FSL_SEC_LE + uint32_t addr_lo; /* Memory Address - lo */ + uint16_t addr_hi; /* Memory Address of start of buffer - hi */ + uint16_t reserved_zero; +#else + uint16_t reserved_zero; + uint16_t addr_hi; /* Memory Address of start of buffer - hi */ + uint32_t addr_lo; /* Memory Address - lo */ +#endif + + uint32_t len_flag; /* Length of the data in the frame */ +#define SG_ENTRY_LENGTH_MASK 0x3FFFFFFF +#define SG_ENTRY_EXTENSION_BIT 0x80000000 +#define SG_ENTRY_FINAL_BIT 0x40000000 + uint32_t bpid_offset; +#define SG_ENTRY_BPID_MASK 0x00FF0000 +#define SG_ENTRY_BPID_SHIFT 16 +#define SG_ENTRY_OFFSET_MASK 0x00001FFF +#define SG_ENTRY_OFFSET_SHIFT 0 +}; + int sec_init(void); #endif
diff --git a/include/hw_sha.h b/include/hw_sha.h index 783350d..ab19a99 100644 --- a/include/hw_sha.h +++ b/include/hw_sha.h @@ -7,7 +7,7 @@ */ #ifndef __HW_SHA_H #define __HW_SHA_H - +#include <hash.h>
/** * Computes hash value of input pbuf using h/w acceleration @@ -34,4 +34,43 @@ void hw_sha256(const uchar * in_addr, uint buflen, */ void hw_sha1(const uchar * in_addr, uint buflen, uchar * out_addr, uint chunk_size); + +/* + * Create the context for sha progressive hashing using h/w acceleration + * + * @algo: Pointer to the hash_algo struct + * @ctxp: Pointer to the pointer of the context for hashing + * @return 0 if ok, -ve on error + */ +int hw_sha_init(struct hash_algo *algo, void **ctxp); + +/* + * Update buffer for sha progressive hashing using h/w acceleration + * + * The context is freed by this function if an error occurs. + * + * @algo: Pointer to the hash_algo struct + * @ctx: Pointer to the context for hashing + * @buf: Pointer to the buffer being hashed + * @size: Size of the buffer being hashed + * @is_last: 1 if this is the last update; 0 otherwise + * @return 0 if ok, -ve on error + */ +int hw_sha_update(struct hash_algo *algo, void *ctx, const void *buf, + unsigned int size, int is_last); + +/* + * Copy sha hash result at destination location + * + * The context is freed after completion of hash operation or after an error. + * + * @algo: Pointer to the hash_algo struct + * @ctx: Pointer to the context for hashing + * @dest_buf: Pointer to the destination buffer where hash is to be copied + * @size: Size of the buffer being hashed + * @return 0 if ok, -ve on error + */ +int hw_sha_finish(struct hash_algo *algo, void *ctx, void *dest_buf, + int size); + #endif diff --git a/lib/Kconfig b/lib/Kconfig index a1f30a2..36d4a49 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -29,4 +29,42 @@ config SYS_HZ
source lib/rsa/Kconfig
+menu "Hashing Support" + +config SHA1 + bool "Enable SHA1 support" + help + This option enables support of hashing using SHA1 algorithm. + The hash is calculated in software. + The SHA1 algorithm produces a 160bits (20-byte) hash value + termed as digets size. + +config SHA256 + bool "Enable SHA256 support" + help + This option enables support of hashing using SHA256 algorithm. + The hash is calculated in software. + The SHA256 algorithm produces a 256bits (32-byte) hash value + termed as digets size. + +config SHA_HW_ACCEL + bool "Enable hashing using hardware" + help + This option enables calculation of hash using SHA1/SHA256 algorithm + in hardware. The files using hash_lookup_algo function would get + pointer to structure having hardware accelerated SHA support. The + hash command would automatically use hardware support if this option + is enabled. + +config SHA_PROG_HW_ACCEL + bool "Enable Progressive hashing support using hardware" + depends on SHA_HW_ACCEL + help + This option enables SHA1 or SHA256 progressive hashing using hardware + acceleration. The hash_progressive_lookup_algo function would return + pointer to structure having support for progressive hashing in + hardware. FIT_SIGNATURE which uses this function would automatically + use hardware support if this option is enabled. +endmenu + endmenu
Gaurav Rana
