[U-Boot] [PATCH 1/2] power: axp152: Registers definitions in header
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/power/axp152.c | 11 ----------- include/axp152.h | 12 ++++++++++++ 2 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/drivers/power/axp152.c b/drivers/power/axp152.c index 27c2c4c..740a3b4 100644 --- a/drivers/power/axp152.c +++ b/drivers/power/axp152.c @@ -8,17 +8,6 @@ #include <i2c.h> #include <axp152.h>
-enum axp152_reg { - AXP152_CHIP_VERSION = 0x3, - AXP152_DCDC2_VOLTAGE = 0x23, - AXP152_DCDC3_VOLTAGE = 0x27, - AXP152_DCDC4_VOLTAGE = 0x2B, - AXP152_LDO2_VOLTAGE = 0x2A, - AXP152_SHUTDOWN = 0x32, -}; - -#define AXP152_POWEROFF (1 << 7) - static int axp152_write(enum axp152_reg reg, u8 val) { return i2c_write(0x30, reg, 1, &val, 1); diff --git a/include/axp152.h b/include/axp152.h index 3e5ccbd..9d205f8 100644 --- a/include/axp152.h +++ b/include/axp152.h @@ -3,6 +3,18 @@ * * SPDX-License-Identifier: GPL-2.0+ */ + +enum axp152_reg { + AXP152_CHIP_VERSION = 0x3, + AXP152_DCDC2_VOLTAGE = 0x23, + AXP152_DCDC3_VOLTAGE = 0x27, + AXP152_DCDC4_VOLTAGE = 0x2B, + AXP152_LDO2_VOLTAGE = 0x2A, + AXP152_SHUTDOWN = 0x32, +}; + +#define AXP152_POWEROFF (1 << 7) + int axp152_set_dcdc2(int mvolt); int axp152_set_dcdc3(int mvolt); int axp152_set_dcdc4(int mvolt);
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/power/axp209.c | 38 -------------------------------------- include/axp209.h | 38 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/drivers/power/axp209.c b/drivers/power/axp209.c index e1cbba9..ebb3822 100644 --- a/drivers/power/axp209.c +++ b/drivers/power/axp209.c @@ -10,44 +10,6 @@ #include <asm/arch/gpio.h> #include <axp209.h>
-enum axp209_reg { - AXP209_POWER_STATUS = 0x00, - AXP209_CHIP_VERSION = 0x03, - AXP209_DCDC2_VOLTAGE = 0x23, - AXP209_DCDC3_VOLTAGE = 0x27, - AXP209_LDO24_VOLTAGE = 0x28, - AXP209_LDO3_VOLTAGE = 0x29, - AXP209_IRQ_ENABLE1 = 0x40, - AXP209_IRQ_ENABLE2 = 0x41, - AXP209_IRQ_ENABLE3 = 0x42, - AXP209_IRQ_ENABLE4 = 0x43, - AXP209_IRQ_ENABLE5 = 0x44, - AXP209_IRQ_STATUS5 = 0x4c, - AXP209_SHUTDOWN = 0x32, - AXP209_GPIO0_CTRL = 0x90, - AXP209_GPIO1_CTRL = 0x92, - AXP209_GPIO2_CTRL = 0x93, - AXP209_GPIO_STATE = 0x94, - AXP209_GPIO3_CTRL = 0x95, -}; - -#define AXP209_POWER_STATUS_ON_BY_DC (1 << 0) -#define AXP209_POWER_STATUS_VBUS_USABLE (1 << 4) - -#define AXP209_IRQ5_PEK_UP (1 << 6) -#define AXP209_IRQ5_PEK_DOWN (1 << 5) - -#define AXP209_POWEROFF (1 << 7) - -#define AXP209_GPIO_OUTPUT_LOW 0x00 /* Drive pin low */ -#define AXP209_GPIO_OUTPUT_HIGH 0x01 /* Drive pin high */ -#define AXP209_GPIO_INPUT 0x02 /* Float pin */ - -/* GPIO3 is different from the others */ -#define AXP209_GPIO3_OUTPUT_LOW 0x00 /* Drive pin low, Output mode */ -#define AXP209_GPIO3_OUTPUT_HIGH 0x02 /* Float pin, Output mode */ -#define AXP209_GPIO3_INPUT 0x06 /* Float pin, Input mode */ - static int axp209_write(enum axp209_reg reg, u8 val) { return i2c_write(0x34, reg, 1, &val, 1); diff --git a/include/axp209.h b/include/axp209.h index 0436249..d36da41 100644 --- a/include/axp209.h +++ b/include/axp209.h @@ -4,6 +4,44 @@ * SPDX-License-Identifier: GPL-2.0+ */
+enum axp209_reg { + AXP209_POWER_STATUS = 0x00, + AXP209_CHIP_VERSION = 0x03, + AXP209_DCDC2_VOLTAGE = 0x23, + AXP209_DCDC3_VOLTAGE = 0x27, + AXP209_LDO24_VOLTAGE = 0x28, + AXP209_LDO3_VOLTAGE = 0x29, + AXP209_IRQ_ENABLE1 = 0x40, + AXP209_IRQ_ENABLE2 = 0x41, + AXP209_IRQ_ENABLE3 = 0x42, + AXP209_IRQ_ENABLE4 = 0x43, + AXP209_IRQ_ENABLE5 = 0x44, + AXP209_IRQ_STATUS5 = 0x4c, + AXP209_SHUTDOWN = 0x32, + AXP209_GPIO0_CTRL = 0x90, + AXP209_GPIO1_CTRL = 0x92, + AXP209_GPIO2_CTRL = 0x93, + AXP209_GPIO_STATE = 0x94, + AXP209_GPIO3_CTRL = 0x95, +}; + +#define AXP209_POWER_STATUS_ON_BY_DC (1 << 0) +#define AXP209_POWER_STATUS_VBUS_USABLE (1 << 4) + +#define AXP209_IRQ5_PEK_UP (1 << 6) +#define AXP209_IRQ5_PEK_DOWN (1 << 5) + +#define AXP209_POWEROFF (1 << 7) + +#define AXP209_GPIO_OUTPUT_LOW 0x00 /* Drive pin low */ +#define AXP209_GPIO_OUTPUT_HIGH 0x01 /* Drive pin high */ +#define AXP209_GPIO_INPUT 0x02 /* Float pin */ + +/* GPIO3 is different from the others */ +#define AXP209_GPIO3_OUTPUT_LOW 0x00 /* Drive pin low, Output mode */ +#define AXP209_GPIO3_OUTPUT_HIGH 0x02 /* Float pin, Output mode */ +#define AXP209_GPIO3_INPUT 0x06 /* Float pin, Input mode */ + #define AXP_GPIO
extern int axp209_set_dcdc2(int mvolt);
Thanks, I've also queued these 2 up in u-boot-sunxi/next.
Regards,
Hans
-enum axp152_reg {
+enum axp152_reg {
- int axp152_set_dcdc2(int mvolt); int axp152_set_dcdc3(int mvolt); int axp152_set_dcdc4(int mvolt);
Hans de Goede
Paul Kocialkowski
