[U-Boot] [PATCH 1/2] dtoc: Move the output code into its own function
The code to generate the tables is quite long. Move the node-output code into its own function.
tools/dtoc/dtoc.py | 96 +++++++++++++++++++++++++++++------------------------- 1 file changed, 52 insertions(+), 44 deletions(-)
diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/dtoc.py index afc5171c2a..0a111eced6 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/dtoc.py @@ -301,6 +301,57 @@ class DtbPlatdata: self.Out(';\n') self.Out('};\n')
+ def OutputNode(self, node): + """Output the C code for a node + + Args: + node: node to output + """ + struct_name = self.GetCompatName(node) + var_name = Conv_name_to_c(node.name) + self.Buf('static struct %s%s %s%s = {\n' % + (STRUCT_PREFIX, struct_name, VAL_PREFIX, var_name)) + for pname, prop in node.props.items(): + if pname in PROP_IGNORE_LIST or pname[0] == '#': + continue + ptype = TYPE_NAMES[prop.type] + member_name = Conv_name_to_c(prop.name) + self.Buf('\t%s= ' % TabTo(3, '.' + member_name)) + + # Special handling for lists + if type(prop.value) == list: + self.Buf('{') + vals = [] + # For phandles, output a reference to the platform data + # of the target node. + if self.IsPhandle(prop): + # Process the list as pairs of (phandle, id) + it = iter(prop.value) + for phandle_cell, id_cell in zip(it, it): + phandle = fdt_util.fdt32_to_cpu(phandle_cell) + id = fdt_util.fdt32_to_cpu(id_cell) + target_node = self._phandle_node[phandle] + name = Conv_name_to_c(target_node.name) + vals.append('{&%s%s, %d}' % (VAL_PREFIX, name, id)) + else: + for val in prop.value: + vals.append(self.GetValue(prop.type, val)) + self.Buf(', '.join(vals)) + self.Buf('}') + else: + self.Buf(self.GetValue(prop.type, prop.value)) + self.Buf(',\n') + self.Buf('};\n') + + # Add a device declaration + self.Buf('U_BOOT_DEVICE(%s) = {\n' % var_name) + self.Buf('\t.name\t\t= "%s",\n' % struct_name) + self.Buf('\t.platdata\t= &%s%s,\n' % (VAL_PREFIX, var_name)) + self.Buf('\t.platdata_size\t= sizeof(%s%s),\n' % + (VAL_PREFIX, var_name)) + self.Buf('};\n') + self.Buf('\n') + def GenerateTables(self): """Generate device defintions for the platform data
@@ -314,50 +365,7 @@ class DtbPlatdata: self.Out('\n') node_txt_list = [] for node in self._valid_nodes: - struct_name = self.GetCompatName(node) - var_name = Conv_name_to_c(node.name) - self.Buf('static struct %s%s %s%s = {\n' % - (STRUCT_PREFIX, struct_name, VAL_PREFIX, var_name)) - for pname, prop in node.props.items(): - if pname in PROP_IGNORE_LIST or pname[0] == '#': - continue - ptype = TYPE_NAMES[prop.type] - member_name = Conv_name_to_c(prop.name) - self.Buf('\t%s= ' % TabTo(3, '.' + member_name)) - - # Special handling for lists - if type(prop.value) == list: - self.Buf('{') - vals = [] - # For phandles, output a reference to the platform data - # of the target node. - if self.IsPhandle(prop): - # Process the list as pairs of (phandle, id) - it = iter(prop.value) - for phandle_cell, id_cell in zip(it, it): - phandle = fdt_util.fdt32_to_cpu(phandle_cell) - id = fdt_util.fdt32_to_cpu(id_cell) - target_node = self._phandle_node[phandle] - name = Conv_name_to_c(target_node.name) - vals.append('{&%s%s, %d}' % (VAL_PREFIX, name, id)) - else: - for val in prop.value: - vals.append(self.GetValue(prop.type, val)) - self.Buf(', '.join(vals)) - self.Buf('}') - else: - self.Buf(self.GetValue(prop.type, prop.value)) - self.Buf(',\n') - self.Buf('};\n') - - # Add a device declaration - self.Buf('U_BOOT_DEVICE(%s) = {\n' % var_name) - self.Buf('\t.name\t\t= "%s",\n' % struct_name) - self.Buf('\t.platdata\t= &%s%s,\n' % (VAL_PREFIX, var_name)) - self.Buf('\t.platdata_size\t= sizeof(%s%s),\n' % - (VAL_PREFIX, var_name)) - self.Buf('};\n') - self.Buf('\n') + self.OutputNode(node)
# Output phandle target nodes first, since they may be referenced # by others
At present dtoc assumes that nodes which are phandles do not themselves reference other phandle nodes. Unfortunately this is not necessarilly true. As a result we can currently output C code which does not compile because a node declaration can be referenced before it is declared.
Adjust the code to explicitly output all phandle nodes needed by node before the node itself is output.
This fixes building with the latest rk3399-firefly.dts from Linux, which has reordered the nodes.
tools/dtoc/dtoc.py | 55 ++++++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 41 insertions(+), 14 deletions(-)
diff --git a/tools/dtoc/dtoc.py b/tools/dtoc/dtoc.py index 0a111eced6..2e0b9c04e2 100755 --- a/tools/dtoc/dtoc.py +++ b/tools/dtoc/dtoc.py @@ -272,6 +272,33 @@ class DtbPlatdata: upto += 1 return structs
+ def ScanPhandles(self): + """Figure out what phandles each node uses + + We need to be careful when outputing nodes that use phandles since + they must come after the declaration of the phandles in the C file. + Otherwise we get a compiler error since the phandle struct is not yet + declared. + + This function adds to each node a list of phandle nodes that the node + depends on. This allows us to output things in the right order. + """ + for node in self._valid_nodes: + node.phandles = set() + for pname, prop in node.props.items(): + if pname in PROP_IGNORE_LIST or pname[0] == '#': + continue + if type(prop.value) == list: + if self.IsPhandle(prop): + # Process the list as pairs of (phandle, id) + it = iter(prop.value) + for phandle_cell, id_cell in zip(it, it): + phandle = fdt_util.fdt32_to_cpu(phandle_cell) + id = fdt_util.fdt32_to_cpu(id_cell) + target_node = self._phandle_node[phandle] + node.phandles.add(target_node) + + def GenerateStructs(self, structs): """Generate struct defintions for the platform data
@@ -352,6 +379,8 @@ class DtbPlatdata: self.Buf('};\n') self.Buf('\n')
+ self.Out(''.join(self.GetBuf())) + def GenerateTables(self): """Generate device defintions for the platform data
@@ -363,21 +392,18 @@ class DtbPlatdata: self.Out('#include <dm.h>\n') self.Out('#include <dt-structs.h>\n') self.Out('\n') - node_txt_list = [] - for node in self._valid_nodes: + nodes_to_output = list(self._valid_nodes) + + # Keep outputing nodes until there is none left + while nodes_to_output: + node = nodes_to_output[0] + # Output all the node's dependencies first + for req_node in node.phandles: + if req_node in nodes_to_output: + self.OutputNode(req_node) + nodes_to_output.remove(req_node) self.OutputNode(node) - - # Output phandle target nodes first, since they may be referenced - # by others - if 'phandle' in node.props: - self.Out(''.join(self.GetBuf())) - else: - node_txt_list.append(self.GetBuf()) - - # Output all the nodes which are not phandle targets themselves, but - # may reference them. This avoids the need for forward declarations. - for node_txt in node_txt_list: - self.Out(''.join(node_txt)) + nodes_to_output.remove(node)
if __name__ != "__main__": @@ -400,6 +426,7 @@ plat.ScanDtb() plat.ScanTree() plat.SetupOutput(options.output) structs = plat.ScanStructs() +plat.ScanPhandles()
for cmd in args[0].split(','): if cmd == 'struct':
Hi Simon,
- def ScanPhandles(self):
declared.
continue
node_txt_list = []
# by others
else:
Tested-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Hi Simon,
Applied to u-boot-rockchip/next, thanks!
Hi Simon,
- def OutputNode(self, node):
Args:
continue
self.Buf('{')
vals = []
else:
self.Buf('}')
else:
self.Buf(',\n')
self.Buf('};\n')
self.Buf('};\n')
self.Buf('\n')
continue
self.Buf('{')
vals = []
else:
self.Buf('}')
else:
self.Buf(',\n')
self.Buf('};\n')
self.Buf('};\n')
self.Buf('\n')
self.OutputNode(node) # Output phandle target nodes first, since they may be referenced # by others
Thanks, - Kever
Hi Simon,
Kever Yang
sjg@google.com
