[U-Boot-Users] [PATCH] Add sa1100 get_ticks
Greetings,
This fixes recent build failure for sa1100 targets:
Index: u-boot/cpu/sa1100/interrupts.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/cpu/sa1100/interrupts.c,v retrieving revision 1.2 diff -u -r1.2 interrupts.c --- u-boot/cpu/sa1100/interrupts.c 27 Jun 2003 21:32:36 -0000 1.2 +++ u-boot/cpu/sa1100/interrupts.c 10 Mar 2004 02:09:43 -0000 @@ -218,3 +218,24 @@ while (tmo >= get_timer_masked ()) /*NOP*/; } + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk (void) +{ + ulong tbclk; + + tbclk = CFG_HZ; + return tbclk; +}
I haven't specifically tested get_ticks or get_tbclk. But this fixes the build and my target (gcplus) works fine for those features that I have tested (bootp/tftp/bootm) with this patch applied.
-- Regards, George
Thanks, added.
George G. Davis
