[U-Boot] Adding new command using existing commands
I am trying to add one command in U-Boot using set of existing commands.
e.g. adding one command for fusing flash with a newly compiled file. new command - "fuse_uboot"
used commands: 1. ping (do_ping() call) 2. tftp (do_tftpb() call) 3. protect off (do_protect() call) 4. erase (do_flerase() call) 5. cp.b (do_cp_mem() call) 6. protect on (do_protect() call) 7. reset (do_reset)
I am copying a section of my code: addition in common/cmd_mem.c:
extern int ping_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void protect_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern int erase_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); static int do_mem_cp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
#if defined(FUSE_UBOOT_FILE) static int do_fuse_uboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int ret = 0, ret1 = 0, ret2 = 1; unsigned int f_size = 0;
char *ping_argv[] = {"ping", NULL, NULL, NULL}; char *tftp_argv[] = {"tftp", NULL, NULL, NULL}; char *protect_argv[] = {"protect", NULL, NULL, NULL}; char *erase_argv[] = {"erase", NULL, NULL, NULL}; char *cp_argv[] = {"cp.b", NULL, NULL, NULL};
printf("Fusing U-Boot\n");
ping_argv[1] = getenv("serverip"); ret = ping_extern(cmdtp, 0, 2, ping_argv); if (ret == 0) { tftp_argv[1] = "10000"; tftp_argv[2] = "uboot_new.bin"; ret1 = (do_tftpb(cmdtp, 0, 3, tftp_argv)); f_size = getenv("filesize"); if (ret1 == 0) { protect_argv[1] = "off"; protect_argv[2] = "1:0-10"; protect_extern(cmdtp, 0, 3, protect_argv);
erase_argv[1] = "1:0-10"; ret2 = erase_extern(cmdtp, 0, 2, erase_argv);
if (ret2 == 0) { cp_argv[1] = "10000"; cp_argv[2] = "fe000000"; cp_argv[3] = f_size; do_mem_cp(cmdtp, 0, 4, cp_argv);
protect_argv[1] = "on"; protect_argv[2] = "1:0-10"; protect_extern(cmdtp, 0, 3, protect_argv); do_reset(NULL, 0, 0, NULL); } else printf("Flash not erased : ERROR %d\n", ret2); } else printf("FILE NOT FOUND\n"); } else printf("PING FAILED : CHECK NETWORK PARAMETERS !!!\n");
return 0; }
U_BOOT_CMD( fuse_boot, 1, 0, do_fuse_uboot, "fuse uboot file from your TFTP server", "" ); #endif
addition in common/cmd_flash.c:
int erase_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int ret; ret = do_flerase(cmdtp, 0, 2, argv); return ret; }
void protect_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { do_protect(cmdtp, 0, 3, argv); }
addition in common/cmd_net.c:
int ping_extern(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int ret; ret = do_ping(cmdtp, 0, 2, argv); return ret; }
The problem I am facing: whenever I pass "1:0-10" as protect_argv[2], after calling protect_extern(), erase get only "1" as erase_argv[1]. Same goes with every values, if arguments are same for both the call second value gets corrupted.
please help me out !!!
Thanks in advance, Ajanta
Regards,
अजंता शर्मा रिसर्च इंजिनियर प्लॅटफॉर्म सॉफ्टवेर ग्रूप सी-डॉट, बेंगालुरू
Ajanta Sarma Research Engineer Platform Software Group C-DOT Bangalore Contact - 08025119895 Mobile - 9739778513
Disclaimer: ---------- This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If
Ajanta Sarma
