[U-Boot] [PATCH] arm: dra7xx: Assign omap_vcores based on board type
Currently omap_vcores which holds pmic data is being assigned based on the SoC type. PMIC is not a part of SoC. It is logical to to assign omap_vcores based on board type. Hence over ride the vcores_init function and assign omap_vcores based on the board type.
Reported-by: Nishanth Menon nm@ti.com Signed-off-by: Keerthy j-keerthy@ti.com ---
Boot tested on both dra7-evm and dra72-evm.
arch/arm/cpu/armv7/omap5/hw_data.c | 78 -------------------------------- board/ti/dra7xx/evm.c | 91 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 91 insertions(+), 78 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index a517b13..65f43d6 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -364,82 +364,6 @@ struct vcores_data omap5430_volts_es2 = { .mm.abb_tx_done_mask = OMAP_ABB_MM_TXDONE_MASK, };
-struct vcores_data dra752_volts = { - .mpu.value = VDD_MPU_DRA7, - .mpu.efuse.reg = STD_FUSE_OPP_VMIN_MPU, - .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .mpu.addr = TPS659038_REG_ADDR_SMPS12, - .mpu.pmic = &tps659038, - .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, - - .eve.value = VDD_EVE_DRA7, - .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE, - .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .eve.addr = TPS659038_REG_ADDR_SMPS45, - .eve.pmic = &tps659038, - .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, - - .gpu.value = VDD_GPU_DRA7, - .gpu.efuse.reg = STD_FUSE_OPP_VMIN_GPU, - .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .gpu.addr = TPS659038_REG_ADDR_SMPS6, - .gpu.pmic = &tps659038, - .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, - - .core.value = VDD_CORE_DRA7, - .core.efuse.reg = STD_FUSE_OPP_VMIN_CORE, - .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .core.addr = TPS659038_REG_ADDR_SMPS7, - .core.pmic = &tps659038, - - .iva.value = VDD_IVA_DRA7, - .iva.efuse.reg = STD_FUSE_OPP_VMIN_IVA, - .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .iva.addr = TPS659038_REG_ADDR_SMPS8, - .iva.pmic = &tps659038, - .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, -}; - -struct vcores_data dra722_volts = { - .mpu.value = VDD_MPU_DRA7, - .mpu.efuse.reg = STD_FUSE_OPP_VMIN_MPU, - .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .mpu.addr = TPS65917_REG_ADDR_SMPS1, - .mpu.pmic = &tps659038, - .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, - - .core.value = VDD_CORE_DRA7, - .core.efuse.reg = STD_FUSE_OPP_VMIN_CORE, - .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .core.addr = TPS65917_REG_ADDR_SMPS2, - .core.pmic = &tps659038, - - /* - * The DSPEVE, GPU and IVA rails are usually grouped on DRA72x - * designs and powered by TPS65917 SMPS3, as on the J6Eco EVM. - */ - .gpu.value = VDD_GPU_DRA7, - .gpu.efuse.reg = STD_FUSE_OPP_VMIN_GPU, - .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .gpu.addr = TPS65917_REG_ADDR_SMPS3, - .gpu.pmic = &tps659038, - .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, - - .eve.value = VDD_EVE_DRA7, - .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE, - .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .eve.addr = TPS65917_REG_ADDR_SMPS3, - .eve.pmic = &tps659038, - .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, - - .iva.value = VDD_IVA_DRA7, - .iva.efuse.reg = STD_FUSE_OPP_VMIN_IVA, - .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, - .iva.addr = TPS65917_REG_ADDR_SMPS3, - .iva.pmic = &tps659038, - .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, -}; - /* * Enable essential clock domains, modules and * do some additional special settings needed @@ -804,7 +728,6 @@ void __weak hw_data_init(void) case DRA752_ES2_0: *prcm = &dra7xx_prcm; *dplls_data = &dra7xx_dplls; - *omap_vcores = &dra752_volts; *ctrl = &dra7xx_ctrl; break;
@@ -812,7 +735,6 @@ void __weak hw_data_init(void) case DRA722_ES2_0: *prcm = &dra7xx_prcm; *dplls_data = &dra72x_dplls; - *omap_vcores = &dra722_volts; *ctrl = &dra7xx_ctrl; break;
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 8c916a3..c5f7190 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -310,6 +310,82 @@ void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) } }
+struct vcores_data dra752_volts = { + .mpu.value = VDD_MPU_DRA7, + .mpu.efuse.reg = STD_FUSE_OPP_VMIN_MPU, + .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .mpu.addr = TPS659038_REG_ADDR_SMPS12, + .mpu.pmic = &tps659038, + .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, + + .eve.value = VDD_EVE_DRA7, + .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE, + .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .eve.addr = TPS659038_REG_ADDR_SMPS45, + .eve.pmic = &tps659038, + .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, + + .gpu.value = VDD_GPU_DRA7, + .gpu.efuse.reg = STD_FUSE_OPP_VMIN_GPU, + .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .gpu.addr = TPS659038_REG_ADDR_SMPS6, + .gpu.pmic = &tps659038, + .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, + + .core.value = VDD_CORE_DRA7, + .core.efuse.reg = STD_FUSE_OPP_VMIN_CORE, + .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .core.addr = TPS659038_REG_ADDR_SMPS7, + .core.pmic = &tps659038, + + .iva.value = VDD_IVA_DRA7, + .iva.efuse.reg = STD_FUSE_OPP_VMIN_IVA, + .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .iva.addr = TPS659038_REG_ADDR_SMPS8, + .iva.pmic = &tps659038, + .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, +}; + +struct vcores_data dra722_volts = { + .mpu.value = VDD_MPU_DRA7, + .mpu.efuse.reg = STD_FUSE_OPP_VMIN_MPU, + .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .mpu.addr = TPS65917_REG_ADDR_SMPS1, + .mpu.pmic = &tps659038, + .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, + + .core.value = VDD_CORE_DRA7, + .core.efuse.reg = STD_FUSE_OPP_VMIN_CORE, + .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .core.addr = TPS65917_REG_ADDR_SMPS2, + .core.pmic = &tps659038, + + /* + * The DSPEVE, GPU and IVA rails are usually grouped on DRA72x + * designs and powered by TPS65917 SMPS3, as on the J6Eco EVM. + */ + .gpu.value = VDD_GPU_DRA7, + .gpu.efuse.reg = STD_FUSE_OPP_VMIN_GPU, + .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .gpu.addr = TPS65917_REG_ADDR_SMPS3, + .gpu.pmic = &tps659038, + .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, + + .eve.value = VDD_EVE_DRA7, + .eve.efuse.reg = STD_FUSE_OPP_VMIN_DSPEVE, + .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .eve.addr = TPS65917_REG_ADDR_SMPS3, + .eve.pmic = &tps659038, + .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, + + .iva.value = VDD_IVA_DRA7, + .iva.efuse.reg = STD_FUSE_OPP_VMIN_IVA, + .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .iva.addr = TPS65917_REG_ADDR_SMPS3, + .iva.pmic = &tps659038, + .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, +}; + /** * @brief board_init * @@ -405,6 +481,21 @@ void do_board_detect(void) } #endif /* CONFIG_SPL_BUILD */
+void vcores_init(void) +{ + if (board_is_dra74x_evm()) { + *omap_vcores = &dra752_volts; + } else if (board_is_dra72x_evm()) { + *omap_vcores = &dra722_volts; + } else { + /* If EEPROM is not populated */ + if (is_dra72x()) + *omap_vcores = &dra722_volts; + else + *omap_vcores = &dra752_volts; + } +} + void set_muxconf_regs(void) { do_set_mux32((*ctrl)->control_padconf_core_base,
Hi Tom,
If there are no comments on this one. Can you please pull this patch?
- Enable essential clock domains, modules and
- do some additional special settings needed
- @brief board_init
- if (board_is_dra74x_evm()) {
- } else if (board_is_dra72x_evm()) {
- } else {
if (is_dra72x())
else
- void set_muxconf_regs(void) { do_set_mux32((*ctrl)->control_padconf_core_base,
Keerthy
Keerthy
