[U-Boot] [PATCH v2 2/3] Add video support to mx51evk board
Adds video support to mx51evk board, this board allows different displays. This patch enables the WVGA TFT LCD panel only, on Display interface 1. Remove comments from include/configs/mx51evk.h to use it.
Signed-off-by: Renato Frias renato.frias@freescale.com --- Changes for v2: - Removed trailing whitespaces from struct fb_videomode - Using PAD_CTL_* definitions - Updated commit message
board/freescale/mx51evk/mx51evk.c | 60 ++++++++++++++++++++++++++++++++++++- include/configs/mx51evk.h | 11 +++++++ 2 files changed, 70 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 2160d5a..3743121 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -34,9 +34,37 @@ #include <fsl_pmic.h> #include <mc13892.h>
+#ifdef CONFIG_LCD +#include <linux/fb.h> +#include <lcd.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
static u32 system_rev; +extern int mx51_fb_init(struct fb_videomode *mode, u32 ipu_di, u32 pix_fmt); + +#ifdef CONFIG_LCD +static struct fb_videomode claa_wvga = { + "CLAA07LC0ACW", + 57, /* Refresh */ + 800, /* xres */ + 480, /* yres */ + 37037, /* pixclock = 27Mhz */ + 40, /* left margin */ + 60, /* right margin */ + 10, /* upper margin */ + 10, /* lower margin */ + 20, /* hsync-len */ + 10, /* vsync-len */ + 0, /* sync */ + FB_VMODE_NONINTERLACED, /* vmode */ + 0, /* flag */ +}; + +static int wvga_ipu_di = 1; +static int wvga_bppix = 16; +#endif
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { @@ -148,6 +176,34 @@ static void setup_iomux_fec(void) mxc_iomux_set_pad(MX51_PIN_NANDF_D11, 0x2180); }
+#ifdef CONFIG_LCD +void setup_iomux_ipu(void) +{ + /* DISP2_DAT [0:15] are configured by default */ + mxc_request_iomux(MX51_PIN_DI1_D1_CS, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI1_D1_CS, + PAD_CTL_PKE_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_request_iomux(MUX_IN_GPIO3_IPP_IND_G_IN_4_SELECT_INPUT, + INPUT_CTL_PATH1); + + /* DISP2_DRDY pin */ + mxc_request_iomux(MX51_PIN_DI_GP4, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI_GP4, PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_KEEPER | PAD_CTL_DRV_LOW); +} + +void lcd_enable(void) +{ + int ret; + + ret = mx51_fb_init(&claa_wvga, wvga_ipu_di, wvga_bppix); + if (ret) { + puts("LCD cannot be configured\n"); + } + +} +#endif + #ifdef CONFIG_MXC_SPI static void setup_iomux_spi(void) { @@ -409,7 +465,9 @@ int board_init(void)
setup_iomux_uart(); setup_iomux_fec(); - +#ifdef CONFIG_LCD + setup_iomux_ipu(); +#endif return 0; }
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index f98438d..cd931ea 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -211,6 +211,17 @@ #define CONFIG_SYS_DDR_CLKSEL 0 #define CONFIG_SYS_CLKTL_CBCDR 0x59E35100
+/* + * Framebuffer and LCD + */ +/* +#define CONFIG_LCD +#define CONFIG_VIDEO_MX5 +#define LCD_BPP LCD_COLOR16 +#define CONFIG_CMD_BMP +#define CONFIG_BMP_16BPP +*/ + /*----------------------------------------------------------------------- * FLASH and environment organization */
Last line does not apply for the commit message. This is only a change from your V1 patch, because the mx51evk.h in mainline has no commented configuration.
Why do you set these variables as you need only in lcd_enable() ?
- Framebuffer and LCD
You say you removed the comment, but it seems you have not....
Best regards, Stefano Babic
Renato Frias
Stefano Babic
