[U-Boot] [PATCH v2] sunxi_nand_spl: Be smarter about where to look for backup u-boot.bin
We know when u-boot is written to its own partition, in this case the layout always is:
eb 0 spl eb 1 spl-backup eb 2 u-boot eb 3 u-boot-backup
eb: erase-block
So if we cannot load u-boot from its primary offset we know exactly where to look for it.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- Changes in v2: -Add an eraseblock_size helper variable to make the calculation for finding the backup u-boot easier to understand --- drivers/mtd/nand/sunxi_nand_spl.c | 26 ++++++++++++++++++++------ 1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index 5985534..b0e07aa 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -356,18 +356,32 @@ static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest,
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dest) { +#if CONFIG_SYS_NAND_U_BOOT_OFFS == CONFIG_SPL_PAD_TO + /* + * u-boot-dtb.bin appended to SPL, use syndrome (like the BROM does) + * and try different erase block sizes to find the backup. + */ const uint32_t boot_offsets[] = { 0 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 1 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 2 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 4 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, }; - int i, syndrome; - - if (CONFIG_SYS_NAND_U_BOOT_OFFS == CONFIG_SPL_PAD_TO) - syndrome = 1; /* u-boot-dtb.bin appended to SPL */ - else - syndrome = 0; /* u-boot-dtb.bin on its own partition */ + const int syndrome = 1; +#else + /* + * u-boot-dtb.bin on its own partition, do not use syndrome, u-boot + * partition sits after 2 eraseblocks (spl, spl-backup), look for + * backup u-boot 1 erase block further. + */ + const uint32_t eraseblock_size = CONFIG_SYS_NAND_U_BOOT_OFFS / 2; + const uint32_t boot_offsets[] = { + CONFIG_SYS_NAND_U_BOOT_OFFS, + CONFIG_SYS_NAND_U_BOOT_OFFS + eraseblock_size, + }; + const int syndrome = 0; +#endif + int i;
if (offs == CONFIG_SYS_NAND_U_BOOT_OFFS) { for (i = 0; i < ARRAY_SIZE(boot_offsets); i++) {
eb: erase-block
Is it worth noting here (or perhaps in a code comment?) that the code currently assumes that the first four ebs are of uniform size?
does)
const uint32_t boot_offsets[] = { 0 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 1 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 2 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, 4 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, };*/
- int i, syndrome;
- else
- const int syndrome = 1;
+#else
-boot
for
- const uint32_t eraseblock_size = CONFIG_SYS_NAND_U_BOOT_OFFS /
2;
- const uint32_t boot_offsets[] = {
- const int syndrome = 0;
int i;
eb: erase-block
The eraseblock size is a property of the nand, given a certain nand chip, all eraseblocks on that chip always have the same size.
Regards,
Hans
does)
- int i, syndrome;
- else
+#else
-boot
for
2;
int i;
eb: erase-block
So they never have "boot erase zones" at either the start or end, which divide one of the erase zones into more fine-grained sizes?
e.g. it used to be the case with NOR that with, say, a 128KB device you would have zones of 3x32K, 1x16K, 2x8K or something like that rather than simply 4x32K.
They don't do this with NAND then?
Ian.
eb: erase-block
To the best of my knowledge no.
Regards,
Hans
eb: erase-block
Thanks.
In which case: Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
