[U-Boot] [PATCH] ppc: Conditionally compile bat_rw.c
Only a few PPC boards actually use the common BAT manipulation functions, so only compile it for them.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- arch/powerpc/lib/Makefile | 2 +- include/configs/Alaska8220.h | 1 + include/configs/MPC8610HPCD.h | 1 + include/configs/MPC8641HPCN.h | 1 + include/configs/Yukon8220.h | 1 + include/configs/sbc8641d.h | 1 + include/configs/xpedite517x.h | 1 + 7 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 2065b6d..cec7666 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -30,7 +30,7 @@ SOBJS-y += ppcstring.o SOBJS-y += ticks.o SOBJS-y += reloc.o
-COBJS-y += bat_rw.o +COBJS-$(CONFIG_BAT_RW) += bat_rw.o COBJS-y += board.o COBJS-y += bootm.o COBJS-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount.o diff --git a/include/configs/Alaska8220.h b/include/configs/Alaska8220.h index 576aa74..85b68be 100644 --- a/include/configs/Alaska8220.h +++ b/include/configs/Alaska8220.h @@ -31,6 +31,7 @@ #define CONFIG_MPC8220 1 #define CONFIG_ALASKA8220 1 /* ... on Alaska board */
+#define CONFIG_BAT_RW 1 /* Use common BAT rw code */ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* Input clock running at 30Mhz, read Hid1 for the CPU multiplier to diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 645d947..2b7b8b5 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -53,6 +53,7 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */
+#define CONFIG_BAT_RW 1 /* Use common BAT rw code */ #define CONFIG_HIGH_BATS 1 /* High BATs supported & enabled */ #define CONFIG_ALTIVEC 1
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 3b80d14..d92b12d 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -68,6 +68,7 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
+#define CONFIG_BAT_RW 1 /* Use common BAT rw code */ #define CONFIG_HIGH_BATS 1 /* High BATs supported and enabled */ #define CONFIG_SYS_NUM_ADDR_MAP 8 /* Number of addr map slots = 8 dbats */
diff --git a/include/configs/Yukon8220.h b/include/configs/Yukon8220.h index c439068..8ec6c84 100644 --- a/include/configs/Yukon8220.h +++ b/include/configs/Yukon8220.h @@ -31,6 +31,7 @@ #define CONFIG_MPC8220 1 #define CONFIG_YUKON8220 1 /* ... on Yukon board */
/* Input clock running at 30Mhz, read Hid1 for the CPU multiplier to diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index a7831c0..490d4f5 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -64,6 +64,7 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
#undef CONFIG_SPD_EEPROM /* Do not use SPD EEPROM for DDR setup*/ diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 43f1406..c7edfc7 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -37,6 +37,7 @@ #define CONFIG_SYS_FORM_3U_VPX 1 #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_pre_init */ +#define CONFIG_BAT_RW 1 /* Use common BAT rw code */ #define CONFIG_HIGH_BATS 1 /* High BATs supported and enabled */ #define CONFIG_ALTIVEC 1
Dear Peter Tyser,
Sorry, but this does not apply:
Applying: ppc: Conditionally compile bat_rw.c fatal: sha1 information is lacking or useless (include/configs/xpedite517x.h). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001 ppc: Conditionally compile bat_rw.c
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- Changes since v1: - Rebased on current top of tree
arch/powerpc/lib/Makefile | 2 +- include/configs/Alaska8220.h | 1 + include/configs/MPC8610HPCD.h | 1 + include/configs/MPC8641HPCN.h | 1 + include/configs/XPEDITE5170.h | 1 + include/configs/Yukon8220.h | 1 + include/configs/sbc8641d.h | 1 + 7 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/include/configs/XPEDITE5170.h b/include/configs/XPEDITE5170.h index 8770a8d..306baed 100644 --- a/include/configs/XPEDITE5170.h +++ b/include/configs/XPEDITE5170.h @@ -36,6 +36,7 @@ #define CONFIG_SYS_BOARD_NAME "XPedite5170" #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_pre_init */ +#define CONFIG_BAT_RW 1 /* Use common BAT rw code */ #define CONFIG_HIGH_BATS 1 /* High BATs supported and enabled */ #define CONFIG_ALTIVEC 1
Dear Peter Tyser,
Changes since v1:
Applied, thanks.
Peter Tyser
