[PATCH] rockchip: rk3399: expand space for decompressed kernel
fix following error by using same ENV_MEM_LAYOUT_SETTINGS with rk35xx:
U-Boot 2025.01-rc3-00001-g1527c7dcdb01 (Dec 02 2024 - 22:57:18 +0000) : Retrieving file: /boot/extlinux/../nixos/dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-Image Retrieving file: /boot/extlinux/../nixos/6fq8fmmab31yxdwcs7zw44p78fq9fy1s-initrd-linux-6.12.1-initrd append: init=/nix/store/yjbxgzf1vkwbw6ab738bf4kxazhyypa1-nixos-system-rock-5b-25.05.20241201.ac35b10/init console=ttyS2,1500000n8 console=ttyAMA0,115200n8 console=tty0 loglevel=7 Retrieving file: /boot/extlinux/../nixos/dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-dtbs/rockchip/rk3399-rock-4se.dtb Moving Image from 0x2080000 to 0x2200000, end=0x60d0000 ERROR: RD image overlaps OS image (OS=2200000..60d0000) Boot failed (err=-14)
$ ls -lh boot/nixos/ total 84M -r--r--r-- 1 root root 24M Jan 1 1970 6fq8fmmab31yxdwcs7zw44p78fq9fy1s-initrd-linux-6.12.1-initrd -r--r--r-- 1 root root 62M Jan 1 1970 dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-Image dr-xr-xr-x 36 root root 4.0K Jan 1 1970 dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-dtbs
similar problem was fixed for rk35xx by:
commit 69b73877f02c ("rockchip: rk35xx: expand space for decompressed kernel")
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- include/configs/rk3399_common.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index c5bcd7dc5e8a..76f40e7cd5f8 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -20,16 +20,16 @@ #endif
#define ENV_MEM_LAYOUT_SETTINGS \ - "scriptaddr=0x00500000\0" \ + "scriptaddr=0x00c00000\0" \ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \ - "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01e00000\0" \ - "fdtoverlay_addr_r=0x01f00000\0" \ - "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x06000000\0" \ - "kernel_comp_addr_r=0x08000000\0" \ - "kernel_comp_size=0x2000000\0" + "pxefile_addr_r=0x00e00000\0" \ + "kernel_addr_r=0x02000000\0" \ + "kernel_comp_addr_r=0x0a000000\0" \ + "fdt_addr_r=0x12000000\0" \ + "fdtoverlay_addr_r=0x12100000\0" \ + "ramdisk_addr_r=0x12180000\0" \ + "kernel_comp_size=0x8000000\0"
#define CFG_EXTRA_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
I'm thinking to do same (or similar) fix for RK3328 too.
that configuration should work with 512MB RAM device, right?
-- FUKAUMI Naoki Radxa Computer (Shenzhen) Co., Ltd.
- "scriptaddr=0x00c00000\0" \ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \
I noticed there is 256MB RK3328 device. I need to think about it.
U-Boot 2025.01-rc3-00001-g1527c7dcdb01 (Dec 02 2024 - 22:57:18 +0000) : Retrieving file: /boot/extlinux/../nixos/ dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-Image Retrieving file: /boot/extlinux/../ nixos/6fq8fmmab31yxdwcs7zw44p78fq9fy1s-initrd-linux-6.12.1-initrd append: init=/nix/store/yjbxgzf1vkwbw6ab738bf4kxazhyypa1-nixos-system- rock-5b-25.05.20241201.ac35b10/init console=ttyS2,1500000n8 console=ttyAMA0,115200n8 console=tty0 loglevel=7 Retrieving file: /boot/extlinux/../nixos/ dhqjsnprmzjxncil3m0g9l09a479crn3-linux-6.12.1-dtbs/rockchip/rk3399- rock-4se.dtb Moving Image from 0x2080000 to 0x2200000, end=0x60d0000 ERROR: RD image overlaps OS image (OS=2200000..60d0000) Boot failed (err=-14)
diff --git a/include/configs/rk3399_common.h b/include/configs/ rk3399_common.h index c5bcd7dc5e8a..76f40e7cd5f8 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -20,16 +20,16 @@ #endif #define ENV_MEM_LAYOUT_SETTINGS \ - "scriptaddr=0x00500000\0" \ + "scriptaddr=0x00c00000\0" \ "script_offset_f=0xffe000\0" \ "script_size_f=0x2000\0" \ - "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x01e00000\0" \ - "fdtoverlay_addr_r=0x01f00000\0" \ - "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x06000000\0" \ - "kernel_comp_addr_r=0x08000000\0" \ - "kernel_comp_size=0x2000000\0" + "pxefile_addr_r=0x00e00000\0" \ + "kernel_addr_r=0x02000000\0" \ + "kernel_comp_addr_r=0x0a000000\0" \ + "fdt_addr_r=0x12000000\0" \ + "fdtoverlay_addr_r=0x12100000\0" \ + "ramdisk_addr_r=0x12180000\0" \ + "kernel_comp_size=0x8000000\0" #define CFG_EXTRA_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
FUKAUMI Naoki
Kever Yang
