[PATCH] ARM: zynq: Change SYS_MALLOC_LEN in zynq_cse_nand_defconfig
nand_scan_tail() function allocates memory dynamically for struct nand_buffers which needs ~21kbytes of memory. But the memory alloted with CONFIG_SYS_MALLOC_LEN is 4k which is insufficient. Increase CONFIG_SYS_MALLOC_LEN to 32Kbytes from which struct nand_buffers uses ~21kbytes & remaining memory is used for other.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
configs/zynq_cse_nand_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 2b58c461c390..80a427d905d3 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x100000 -CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_SYS_MALLOC_LEN=0x8000 CONFIG_ENV_SIZE=0x190 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y
po 20. 4. 2020 v 7:43 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 2b58c461c390..80a427d905d3 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x100000 -CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_SYS_MALLOC_LEN=0x8000 CONFIG_ENV_SIZE=0x190 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y -- 2.26.0
Applied. M
Michal Simek
Michal Simek
