[RFC PATCH] ubifs: Call ubifs_iput when ubifs_iget is used
The inode should be freed after a reference is get to avoid memory leak
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- fs/ubifs/ubifs.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 048730db7f..6acd6c3776 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -319,9 +319,7 @@ static int filldir(struct ubifs_info *c, const char *name, int namlen, } ctime_r((time_t *)&inode->i_mtime, filetime); printf("%9lld %24.24s ", inode->i_size, filetime); -#ifndef __UBOOT__ ubifs_iput(inode); -#endif
printf("%s\n", name);
@@ -557,6 +555,7 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename)
/* We have some sort of symlink recursion, bail out */ if (symlink_count++ > 8) { + ubifs_iput(inode); printf("Symlink recursion, aborting\n"); return 0; } @@ -568,6 +567,7 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename) * the leading slash */ next = name = link_name + 1; root_inum = 1; + ubifs_iput(inode); continue; } /* Relative to cur dir */ @@ -575,6 +575,7 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename) link_name, next == NULL ? "" : next); memcpy(symlinkpath, buf, sizeof(buf)); next = name = symlinkpath; + ubifs_iput(inode); continue; }
@@ -583,8 +584,10 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename) */
/* Found the node! */ - if (!next || *next == '\0') + if (!next || *next == '\0') { + ubifs_iput(inode); return inum; + }
root_inum = inum; name = next;
Hello Michael,
As discussed, that patch looks valid to me!
It would be good to have some testers...
Looking through the code, I think there is one more place:
$ git diff diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index d8d78a2d3d..a5d141055c 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -2322,6 +2322,7 @@ static int ubifs_fill_super(struct super_block *sb, void *data, int silent) } #else sb->s_root = NULL; + ubifs_iput(inode); #endif
mutex_unlock(&c->umount_mutex); $
What do you mean?
bye, Heiko
Hi Heiko
On Tue, Aug 6, 2024 at 6:29 AM Heiko Schocher hs@denx.de wrote:
Hello Michael,
#endifubifs_iput(inode);
Right, I think that people are reporting now those problem can try to give a quick try on it
Michael
What do you mean?
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-52 Fax: +49-8142-66989-80 Email: hs@denx.de
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Hello Michael,
Am Mon, Aug 05, 2024 at 07:31:40PM +0200 schrieb Michael Trimarchi:
Tested this on top of my recent ubifs series. No obvious problems found on U-Boot command line with various combinations of commands, no crashes, so …
Tested-by: Alexander Dahl ada@thorsis.com
Greets Alex
}ubifs_iput(inode); continue;
-- 2.43.0
Hi Alexander
On Wed, Aug 7, 2024 at 4:55 PM Alexander Dahl ada@thorsis.com wrote:
Hello Michael,
I think that we can resend including last heiko remark and let heiko to pick it from his own tree
Heiko I will add CoDevelopment if it's ok for you
Michael
Greets Alex
} root_inum = inum; name = next;
-- 2.43.0
On 07.08.24 16:57, Michael Nazzareno Trimarchi wrote:
Hi Alexander
Hello Michael,
Fine for me! Thanks!
bye, Heiko
Michael
Greets Alex
-- 2.43.0
Alexander Dahl
Heiko Schocher
Michael Trimarchi
