[PATCH v4 0/6] Add Cortina Access basic DM drivers
Cortina Access management has decided that we want to add formal upstream support of u-boot going forward for our line of SoCs and evaluation boards.
Our line of SoC’s all begin with the “CA” designation followed by 4 digits. i.e. CAxxxx. The CAxxxx series supports both ARM and MIPS ISA based custom cores.
All our drivers have cross platform support for both CPU ISAs. They will be placed in the normal drivers tree in u-boot.
In addition, our SoCs and development boards share common Cortina specific features which are not driver related. Those changes will be maintained in board/cortina/common. While specific development boards will be in board/cortina/board_name.
We would like to have a git-mailrc alias of "cortina" to allow us to better maintain and support our boards and common features found in the board/cortina subtree.
Changes in v4: - clean up presidio_asic.h per trini recommendations - use autogen savedefconfig instead of manual maintained file
Changes in v3: - Remove CA ARM and MIPS common subdirectories from board/cortina/common after further discussions with trini - clean up comment blocks - fix rmw of baud rate bitfield change - fixed dts closing bracket indentation - presidio.h: remove deadcode from presidio.h - presidio.h: remove CA_REG_READ/CA_REG_WRITE wrapper macros - presidio.h: remove CA77xx define replace use CA common Kconfig SoC selection instead - select SOC_CA7774 via board's Kconfig - select BIT64 via board's Kconfig instead of presidio.h
Changes in v2: - Modified filepath for CA ARM and MIPS per trini's recommendation - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove Authorship as it is already recorded within Git and is redundant - Replace printf() as debug() - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove authorship comment as it is already recorded within Git and is redundant - Use setbits_32() for read-modify-write operation. - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove authorship comment as it is already recorded within Git and is redundant - Merge serial_cortina.h reg defines into serial_cortina.c - Modify ca_serial_pending() and API to get resource.
Alex Nemirovsky (2): MAINTAINERS, git-mailrc: cortina: add Custodian for Cortina Access Inc. board: presidio-asic: Add basic G3 engr. development board support
Jason Li (4): gpio: do not include <asm/arch/gpio.h> for Cortina CAxxxx SoCs gpio: cortina_gpio: add DM_GPIO driver for CAxxxx SoCs watchdog: cortina_wdt: add support for HW WDT on CAxxxx SoCs serial: serial_cortina: add UART DM driver for CAxxxx SoCs
MAINTAINERS | 16 +++ arch/arm/Kconfig | 5 + arch/arm/dts/Makefile | 2 + arch/arm/dts/ca-presidio-engboard.dts | 69 +++++++++++ arch/arm/include/asm/gpio.h | 2 +- arch/arm/mach-cortina/Makefile | 5 + board/cortina/common/Kconfig | 6 + board/cortina/presidio-asic/Kconfig | 18 +++ board/cortina/presidio-asic/MAINTAINERS | 6 + board/cortina/presidio-asic/Makefile | 8 ++ board/cortina/presidio-asic/lowlevel_init.S | 87 ++++++++++++++ board/cortina/presidio-asic/presidio.c | 134 ++++++++++++++++++++++ configs/cortina_presidio-asic-base_defconfig | 29 +++++ doc/git-mailrc | 2 + drivers/gpio/Kconfig | 8 ++ drivers/gpio/Makefile | 1 + drivers/gpio/cortina_gpio.c | 111 ++++++++++++++++++ drivers/serial/Kconfig | 7 ++ drivers/serial/Makefile | 2 +- drivers/serial/serial_cortina.c | 164 +++++++++++++++++++++++++++ drivers/watchdog/Kconfig | 8 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/cortina_wdt.c | 138 ++++++++++++++++++++++ include/configs/presidio_asic.h | 75 ++++++++++++ 24 files changed, 902 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/ca-presidio-engboard.dts create mode 100644 arch/arm/mach-cortina/Makefile create mode 100644 board/cortina/common/Kconfig create mode 100644 board/cortina/presidio-asic/Kconfig create mode 100644 board/cortina/presidio-asic/MAINTAINERS create mode 100644 board/cortina/presidio-asic/Makefile create mode 100644 board/cortina/presidio-asic/lowlevel_init.S create mode 100644 board/cortina/presidio-asic/presidio.c create mode 100644 configs/cortina_presidio-asic-base_defconfig create mode 100644 drivers/gpio/cortina_gpio.c create mode 100644 drivers/serial/serial_cortina.c create mode 100644 drivers/watchdog/cortina_wdt.c create mode 100644 include/configs/presidio_asic.h
Assign Alex Nemirovsky as custodian for all Cortina Access (CA) for ARM and MIPS based SoCs.
Currently Cortina Access CAxxxx family of SoCs support both ARM and MIPS ISA. Drivers have cross platform support for both architectures.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com
Changes in v4: None Changes in v3: - Remove CA ARM and MIPS common subdirectories from board/cortina/common after further discussions with trini
MAINTAINERS | 16 ++++++++++++++++ board/cortina/common/Kconfig | 6 ++++++ doc/git-mailrc | 2 ++ 3 files changed, 24 insertions(+) create mode 100644 board/cortina/common/Kconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 438fb22..2a5f41d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -173,6 +173,14 @@ F: doc/README.bcm7xxx F: drivers/mmc/bcmstb_sdhci.c F: drivers/spi/bcmstb_spi.c
+ARM CORTINA ACCESS CAxxxx +M: Alex Nemirovsky alex.nemirovsky@cortina-access.com +S: Supported +F: board/cortina/common/ +F: drivers/gpio/cortina_gpio.c +F: drivers/watchdog/cortina_wdt.c +F: drivers/serial/serial_cortina.c + ARM/CZ.NIC TURRIS MOX SUPPORT M: Marek Behun marek.behun@nic.cz S: Maintained @@ -647,6 +655,14 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-mips.git F: arch/mips/
+MIPS CORTINA ACCESS CAxxxx +M: Alex Nemirovsky alex.nemirovsky@cortina-access.com +S: Supported +F: board/cortina/common/ +F: drivers/gpio/cortina_gpio.c +F: drivers/watchdog/cortina_wdt.c +F: drivers/serial/serial_cortina.c + MIPS MSCC M: Gregory CLEMENT gregory.clement@bootlin.com M: Lars Povlsen lars.povlsen@microchip.com diff --git a/board/cortina/common/Kconfig b/board/cortina/common/Kconfig new file mode 100644 index 0000000..00c709e --- /dev/null +++ b/board/cortina/common/Kconfig @@ -0,0 +1,6 @@ +config CORTINA_PLATFORM + bool "Cortina-Access Platform" + default y + help + Select this option for Cortina-Access platforms + to enables selection of CAxxxx drivers diff --git a/doc/git-mailrc b/doc/git-mailrc index d29416a..33d1814 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -15,6 +15,7 @@ alias abrodkin Alexey Brodkin alexey.brodkin@synopsys.com alias afleming Andy Fleming afleming@gmail.com alias ag Anatolij Gustschin agust@denx.de alias agraf Alexander Graf agraf@csgraf.de +alias alexnemirovsky Alex Nemirovsky alex.nemirovsky@cortina-access.com alias alisonwang Alison Wang alison.wang@nxp.com alias angelo_ts Angelo Dureghello angelo@sysam.it alias bmeng Bin Meng bmeng.cn@gmail.com @@ -56,6 +57,7 @@ alias arc uboot, abrodkin
alias arm uboot, trini alias at91 uboot, abiessmann +alias cortina uboot, alexnemirovsky alias davinci ti alias imx uboot, sbabic alias kirkwood uboot, stroese
The Cortina CAxxxx GPIO driver maintains DM_GPIO support across different CPU ISA in the CAxxxx Soc Family; Not just ARM. Therefore, it is not desirable to split out and maintain separete gpio header file for each CPU architecture.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Jason Li jason.li@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com
Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/include/asm/gpio.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/gpio.h b/arch/arm/include/asm/gpio.h index 6ff5f42..10af1e1 100644 --- a/arch/arm/include/asm/gpio.h +++ b/arch/arm/include/asm/gpio.h @@ -3,7 +3,7 @@ !defined(CONFIG_ARCH_BCM63158) && !defined(CONFIG_ARCH_ROCKCHIP) && \ !defined(CONFIG_ARCH_LX2160A) && !defined(CONFIG_ARCH_LS1028A) && \ !defined(CONFIG_ARCH_LS2080A) && !defined(CONFIG_ARCH_LS1088A) && \ - !defined(CONFIG_ARCH_ASPEED) + !defined(CONFIG_ARCH_ASPEED) && !defined(CONFIG_CORTINA_PLATFORM) #include <asm/arch/gpio.h> #endif #include <asm-generic/gpio.h>
DM_GPIO based GPIO controller driver for CAxxxx SoCs. This driver support multiple CPU architectures and Cortina Access SoC platforms.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Jason Li jason.li@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com
Changes in v4: None Changes in v3: None Changes in v2: - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove Authorship as it is already recorded within Git and is redundant - Replace printf() as debug()
drivers/gpio/Kconfig | 8 ++++ drivers/gpio/Makefile | 1 + drivers/gpio/cortina_gpio.c | 111 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 120 insertions(+) create mode 100644 drivers/gpio/cortina_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 1de6f52..8a7aa5a 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -59,6 +59,14 @@ config BCM6345_GPIO help This driver supports the GPIO banks on BCM6345 SoCs.
+config CORTINA_GPIO + bool "Cortina-Access GPIO driver" + depends on DM_GPIO && CORTINA_PLATFORM + help + Enable support for the GPIO controller in Cortina CAxxxx SoCs. + This driver supports all CPU ISA variants supported by Cortina + Access CAxxxx SoCs. + config DWAPB_GPIO bool "DWAPB GPIO driver" depends on DM && DM_GPIO diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 449046b..ceae612 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -17,6 +17,7 @@ endif obj-$(CONFIG_AT91_GPIO) += at91_gpio.o obj-$(CONFIG_ATMEL_PIO4) += atmel_pio4.o obj-$(CONFIG_BCM6345_GPIO) += bcm6345_gpio.o +obj-$(CONFIG_CORTINA_GPIO) += cortina_gpio.o obj-$(CONFIG_INTEL_GPIO) += intel_gpio.o obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o obj-$(CONFIG_INTEL_BROADWELL_GPIO) += intel_broadwell_gpio.o diff --git a/drivers/gpio/cortina_gpio.c b/drivers/gpio/cortina_gpio.c new file mode 100644 index 0000000..e2374ce --- /dev/null +++ b/drivers/gpio/cortina_gpio.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Cortina-Access + * + * GPIO Driver for Cortina Access CAxxxx Line of SoCs + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/compat.h> +#include <linux/compiler.h> + +/* GPIO Register Map */ +#define CORTINA_GPIO_CFG 0x00 +#define CORTINA_GPIO_OUT 0x04 +#define CORTINA_GPIO_IN 0x08 +#define CORTINA_GPIO_LVL 0x0C +#define CORTINA_GPIO_EDGE 0x10 +#define CORTINA_GPIO_BOTHEDGE 0x14 +#define CORTINA_GPIO_IE 0x18 +#define CORTINA_GPIO_INT 0x1C +#define CORTINA_GPIO_STAT 0x20 + +struct cortina_gpio_bank { + void __iomem *base; +}; + +#ifdef CONFIG_DM_GPIO +static int ca_gpio_direction_input(struct udevice *dev, unsigned int offset) +{ + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + setbits_32(priv->base, BIT(offset)); + return 0; +} + +static int +ca_gpio_direction_output(struct udevice *dev, unsigned int offset, int value) +{ + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + clrbits_32(priv->base, BIT(offset)); + return 0; +} + +static int ca_gpio_get_value(struct udevice *dev, unsigned int offset) +{ + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + return readl(priv->base + CORTINA_GPIO_IN) & BIT(offset); +} + +static int ca_gpio_set_value(struct udevice *dev, unsigned int offset, + int value) +{ + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + setbits_32(priv->base + CORTINA_GPIO_OUT, BIT(offset)); + return 0; +} + +static int ca_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + if (readl(priv->base) & BIT(offset)) + return GPIOF_INPUT; + else + return GPIOF_OUTPUT; +} + +static const struct dm_gpio_ops gpio_cortina_ops = { + .direction_input = ca_gpio_direction_input, + .direction_output = ca_gpio_direction_output, + .get_value = ca_gpio_get_value, + .set_value = ca_gpio_set_value, + .get_function = ca_gpio_get_function, +}; + +static int ca_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct cortina_gpio_bank *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) + return -EINVAL; + + uc_priv->gpio_count = dev_read_u32_default(dev, "ngpios", 32); + uc_priv->bank_name = dev->name; + + debug("Done Cortina GPIO init\n"); + return 0; +} + +static const struct udevice_id ca_gpio_ids[] = { + {.compatible = "cortina,ca-gpio"}, + {} +}; + +U_BOOT_DRIVER(cortina_gpio) = { + .name = "cortina-gpio", + .id = UCLASS_GPIO, + .ops = &gpio_cortina_ops, + .probe = ca_gpio_probe, + .priv_auto_alloc_size = sizeof(struct cortina_gpio_bank), + .of_match = ca_gpio_ids, +}; +#endif /* CONFIG_DM_GPIO */
Add support for hardware watchdog timer on all Cortina Access CAxxxx family of SoCs.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Jason Li jason.li@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com
Changes in v4: None Changes in v3: None Changes in v2: - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove authorship comment as it is already recorded within Git and is redundant - Use setbits_32() for read-modify-write operation.
drivers/watchdog/Kconfig | 8 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/cortina_wdt.c | 138 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 147 insertions(+) create mode 100644 drivers/watchdog/cortina_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 8c16d69..2f7dedb 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -99,6 +99,14 @@ config WDT_CDNS Select this to enable Cadence watchdog timer, which can be found on some Xilinx Microzed Platform.
+config WDT_CORTINA + bool "Cortina Access CAxxxx watchdog timer support" + depends on WDT + help + Cortina Access CAxxxx watchdog timer support. + This driver support all CPU ISAs supported by Cortina + Access CAxxxx SoCs. + config WDT_MPC8xx bool "MPC8xx watchdog timer support" depends on WDT && MPC8xx diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 955caef..87f92a4 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_WDT_SANDBOX) += sandbox_wdt.o obj-$(CONFIG_WDT_ARMADA_37XX) += armada-37xx-wdt.o obj-$(CONFIG_WDT_ASPEED) += ast_wdt.o obj-$(CONFIG_WDT_BCM6345) += bcm6345_wdt.o +obj-$(CONFIG_WDT_CORTINA) += cortina_wdt.o obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o diff --git a/drivers/watchdog/cortina_wdt.c b/drivers/watchdog/cortina_wdt.c new file mode 100644 index 0000000..f6a0e70 --- /dev/null +++ b/drivers/watchdog/cortina_wdt.c @@ -0,0 +1,138 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Cortina-Access + * + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <wdt.h> +#include <linux/bitops.h> + +#define CA_WDT_CTRL 0x00 +#define CA_WDT_PS 0x04 +#define CA_WDT_DIV 0x08 +#define CA_WDT_LD 0x0C +#define CA_WDT_LOADE 0x10 +#define CA_WDT_CNT 0x14 +#define CA_WDT_IE 0x18 +#define CA_WDT_INT 0x1C +#define CA_WDT_STAT 0x20 + +/* CA_WDT_CTRL */ +#define CTL_WDT_EN BIT(0) +#define CTL_WDT_RSTEN BIT(1) +#define CTL_WDT_CLK_SEL BIT(2) +/* CA_WDT_LOADE */ +#define WDT_UPD BIT(0) +#define WDT_UPD_PS BIT(1) + +/* Global config */ +#define WDT_RESET_SUB BIT(4) +#define WDT_RESET_ALL_BLOCK BIT(6) +#define WDT_RESET_REMAP BIT(7) +#define WDT_EXT_RESET BIT(8) +#define WDT_RESET_DEFAULT (WDT_EXT_RESET | WDT_RESET_REMAP | \ + WDT_RESET_ALL_BLOCK | WDT_RESET_SUB) + +struct ca_wdt_priv { + void __iomem *base; + void __iomem *global_config; +}; + +static void cortina_wdt_set_timeout(struct udevice *dev, u64 timeout_ms) +{ + struct ca_wdt_priv *priv = dev_get_priv(dev); + + /* Prescale using millisecond unit */ + writel(CORTINA_PER_IO_FREQ / 1000, priv->base + CA_WDT_PS); + + /* Millisecond */ + writel(1, priv->base + CA_WDT_DIV); + + writel(timeout_ms, priv->base + CA_WDT_LD); + writel(WDT_UPD | WDT_UPD_PS, priv->base + CA_WDT_LOADE); +} + +static int cortina_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct ca_wdt_priv *priv = dev_get_priv(dev); + + cortina_wdt_set_timeout(dev, timeout); + + /* WDT Reset option */ + setbits_32(priv->global_config, WDT_RESET_DEFAULT); + + /* Enable WDT */ + setbits_32(priv->base, CTL_WDT_EN | CTL_WDT_RSTEN | CTL_WDT_CLK_SEL); + + return 0; +} + +static int cortina_wdt_stop(struct udevice *dev) +{ + struct ca_wdt_priv *priv = dev_get_priv(dev); + + /* Disable WDT */ + writel(0, priv->base); + + return 0; +} + +static int cortina_wdt_reset(struct udevice *dev) +{ + struct ca_wdt_priv *priv = dev_get_priv(dev); + + /* Reload WDT counter */ + writel(WDT_UPD, priv->base + CA_WDT_LOADE); + + return 0; +} + +static int cortina_wdt_expire_now(struct udevice *dev, ulong flags) +{ + /* Set 1ms timeout to reset system */ + cortina_wdt_set_timeout(dev, 1); + hang(); + + return 0; +} + +static int cortina_wdt_probe(struct udevice *dev) +{ + struct ca_wdt_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) + return -ENOENT; + + priv->global_config = dev_remap_addr_index(dev, 1); + if (!priv->global_config) + return -ENOENT; + + /* Stop WDT */ + cortina_wdt_stop(dev); + + return 0; +} + +static const struct wdt_ops cortina_wdt_ops = { + .start = cortina_wdt_start, + .reset = cortina_wdt_reset, + .stop = cortina_wdt_stop, + .expire_now = cortina_wdt_expire_now, +}; + +static const struct udevice_id cortina_wdt_ids[] = { + {.compatible = "cortina,ca-wdt"}, + {} +}; + +U_BOOT_DRIVER(cortina_wdt) = { + .name = "cortina_wdt", + .id = UCLASS_WDT, + .probe = cortina_wdt_probe, + .of_match = cortina_wdt_ids, + .ops = &cortina_wdt_ops, +};
Add serial UART driver support for all Cortina Access CAxxxx family of SoCs.
Changes in v4: None Changes in v3: - clean up comment blocks - fix rmw of baud rate bitfield change
Changes in v2: - Rename driver in DT namespace for consistency between all CA drivers. - Remove blank line after SPDX identifier - Remove authorship comment as it is already recorded within Git and is redundant - Merge serial_cortina.h reg defines into serial_cortina.c - Modify ca_serial_pending() and API to get resource.
drivers/serial/Kconfig | 7 ++ drivers/serial/Makefile | 2 +- drivers/serial/serial_cortina.c | 164 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 172 insertions(+), 1 deletion(-) create mode 100644 drivers/serial/serial_cortina.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index ece7d87..9f76596 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -539,6 +539,13 @@ config BCM6345_SERIAL help Select this to enable UART on BCM6345 SoCs.
+config CORTINA_UART + bool "Cortina UART support" + depends on DM_SERIAL + help + Select this to enable UART support for Cortina-Access UART devices + found on CAxxxx SoCs. + config FSL_LINFLEXUART bool "Freescale Linflex UART support" depends on DM_SERIAL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 06ee306..c8f2db4 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -28,13 +28,13 @@ obj-$(CONFIG_PL010_SERIAL) += serial_pl01x.o obj-$(CONFIG_PL011_SERIAL) += serial_pl01x.o obj-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o endif - obj-$(CONFIG_ALTERA_UART) += altera_uart.o obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o obj-$(CONFIG_AR933X_UART) += serial_ar933x.o obj-$(CONFIG_ARM_DCC) += arm_dcc.o obj-$(CONFIG_ATMEL_USART) += atmel_usart.o obj-$(CONFIG_BCM6345_SERIAL) += serial_bcm6345.o +obj-$(CONFIG_CORTINA_UART) += serial_cortina.o obj-$(CONFIG_EFI_APP) += serial_efi.o obj-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o obj-$(CONFIG_MCFUART) += mcfuart.o diff --git a/drivers/serial/serial_cortina.c b/drivers/serial/serial_cortina.c new file mode 100644 index 0000000..4f227bf --- /dev/null +++ b/drivers/serial/serial_cortina.c @@ -0,0 +1,164 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Cortina-Access Ltd. + * Common UART Driver for Cortina Access CAxxxx line of SoCs + * + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <watchdog.h> +#include <asm/io.h> +#include <serial.h> +#include <linux/compiler.h> + +/* Register definitions */ +#define UCFG 0x00 /* UART config register */ +#define UFC 0x04 /* Flow Control */ +#define URX_SAMPLE 0x08 /* UART RX Sample register */ +#define URT_TUNE 0x0C /* Fine tune of UART clk */ +#define UTX_DATA 0x10 /* UART TX Character data */ +#define URX_DATA 0x14 /* UART RX Character data */ +#define UINFO 0x18 /* UART Info */ +#define UINT_EN0 0x1C /* UART Interrupt enable 0 */ +#define UINT_EN1 0x20 /* UART Interrupt enable 1 */ +#define UINT0 0x24 /* UART Interrupt 0 setting/clearing */ +#define UINT1 0x28 /* UART Interrupt 1 setting/clearing */ +#define UINT_STAT 0x2C /* UART Interrupt Status */ + +/* UART Control Register Bit Fields */ +#define UCFG_BAUD_COUNT_MASK 0xFFFFFF00 +#define UCFG_BAUD_COUNT(x) ((x << 8) & UCFG_BAUD_COUNT_MASK) +#define UCFG_EN BIT(7) +#define UCFG_RX_EN BIT(6) +#define UCFG_TX_EN BIT(5) +#define UCFG_PARITY_EN BIT(4) +#define UCFG_PARITY_SEL BIT(3) +#define UCFG_2STOP_BIT BIT(2) +#define UCFG_CNT1 BIT(1) +#define UCFG_CNT0 BIT(0) +#define UCFG_CHAR_5 0 +#define UCFG_CHAR_6 1 +#define UCFG_CHAR_7 2 +#define UCFG_CHAR_8 3 + +#define UINFO_TX_FIFO_EMPTY BIT(3) +#define UINFO_TX_FIFO_FULL BIT(2) +#define UINFO_RX_FIFO_EMPTY BIT(1) +#define UINFO_RX_FIFO_FULL BIT(0) + +#define UINT_RX_NON_EMPTY BIT(6) +#define UINT_TX_EMPTY BIT(5) +#define UINT_RX_UNDERRUN BIT(4) +#define UINT_RX_OVERRUN BIT(3) +#define UINT_RX_PARITY_ERR BIT(2) +#define UINT_RX_STOP_ERR BIT(1) +#define UINT_TX_OVERRUN BIT(0) +#define UINT_MASK_ALL 0x7F + +struct ca_uart_priv { + void __iomem *base; +}; + +int ca_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + unsigned int uart_ctrl, baud, sample; + + baud = CORTINA_UART_CLOCK / baudrate; + + uart_ctrl = readl(priv->base + UCFG); + uart_ctrl &= ~UCFG_BAUD_COUNT_MASK; + uart_ctrl |= UCFG_BAUD_COUNT(baud); + writel(uart_ctrl, priv->base + UCFG); + + sample = baud / 2; + sample = (sample < 7) ? 7 : sample; + writel(sample, priv->base + URX_SAMPLE); + + return 0; +} + +static int ca_serial_getc(struct udevice *dev) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + int ch; + + ch = readl(priv->base + URX_DATA) & 0xFF; + + return (int)ch; +} + +static int ca_serial_putc(struct udevice *dev, const char ch) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + unsigned int status; + + /* Retry if TX FIFO full */ + status = readl(priv->base + UINFO); + if (status & UINFO_TX_FIFO_FULL) + return -EAGAIN; + + writel(ch, priv->base + UTX_DATA); + + return 0; +} + +static int ca_serial_pending(struct udevice *dev, bool input) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + unsigned int status; + + status = readl(priv->base + UINFO); + + if (input) + return (status & UINFO_RX_FIFO_EMPTY) ? 0 : 1; + else + return (status & UINFO_TX_FIFO_FULL) ? 1 : 0; +} + +static int ca_serial_probe(struct udevice *dev) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + u32 uart_ctrl; + + /* Set data, parity and stop bits */ + uart_ctrl = UCFG_EN | UCFG_TX_EN | UCFG_RX_EN | UCFG_CHAR_8; + writel(uart_ctrl, priv->base + UCFG); + + return 0; +} + +static int ca_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct ca_uart_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) + return -ENOENT; + + return 0; +} + +static const struct dm_serial_ops ca_serial_ops = { + .putc = ca_serial_putc, + .pending = ca_serial_pending, + .getc = ca_serial_getc, + .setbrg = ca_serial_setbrg, +}; + +static const struct udevice_id ca_serial_ids[] = { + {.compatible = "cortina,ca-uart"}, + {} +}; + +U_BOOT_DRIVER(serial_cortina) = { + .name = "serial_cortina", + .id = UCLASS_SERIAL, + .of_match = ca_serial_ids, + .ofdata_to_platdata = ca_serial_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct ca_uart_priv), + .probe = ca_serial_probe, + .ops = &ca_serial_ops +};
Add basic Presidio G3 engineering board support
Changes in v3: - fixed dts closing bracket indentation - presidio.h: remove deadcode from presidio.h - presidio.h: remove CA_REG_READ/CA_REG_WRITE wrapper macros - presidio.h: remove CA77xx define replace use CA common Kconfig SoC selection instead - select SOC_CA7774 via board's Kconfig - select BIT64 via board's Kconfig instead of presidio.h
Changes in v2: None
arch/arm/Kconfig | 5 + arch/arm/dts/Makefile | 2 + arch/arm/dts/ca-presidio-engboard.dts | 69 ++++++++++++++ arch/arm/mach-cortina/Makefile | 5 + board/cortina/presidio-asic/Kconfig | 18 ++++ board/cortina/presidio-asic/MAINTAINERS | 6 ++ board/cortina/presidio-asic/Makefile | 8 ++ board/cortina/presidio-asic/lowlevel_init.S | 87 +++++++++++++++++ board/cortina/presidio-asic/presidio.c | 134 +++++++++++++++++++++++++++ configs/cortina_presidio-asic-base_defconfig | 29 ++++++ include/configs/presidio_asic.h | 75 +++++++++++++++ 11 files changed, 438 insertions(+) create mode 100644 arch/arm/dts/ca-presidio-engboard.dts create mode 100644 arch/arm/mach-cortina/Makefile create mode 100644 board/cortina/presidio-asic/Kconfig create mode 100644 board/cortina/presidio-asic/MAINTAINERS create mode 100644 board/cortina/presidio-asic/Makefile create mode 100644 board/cortina/presidio-asic/lowlevel_init.S create mode 100644 board/cortina/presidio-asic/presidio.c create mode 100644 configs/cortina_presidio-asic-base_defconfig create mode 100644 include/configs/presidio_asic.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 36c9c2f..6d95cde 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1638,6 +1638,10 @@ config TARGET_DURIAN Support for durian platform. It has 2GB Sdram, uart and pcie.
+config TARGET_PRESIDIO_ASIC + bool "Support Cortina Presidio ASIC Platform" + select ARM64 + endchoice
config ARCH_SUPPORT_TFABOOT @@ -1782,6 +1786,7 @@ source "board/Marvell/gplugd/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" +source "board/cortina/presidio-asic/Kconfig" source "board/broadcom/bcm23550_w1d/Kconfig" source "board/broadcom/bcm28155_ap/Kconfig" source "board/broadcom/bcm963158/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0127a91..81db1e6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -849,6 +849,8 @@ dtb-$(CONFIG_TARGET_VEXPRESS_CA15_TC2) += vexpress-v2p-ca15_a7.dtb
dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb
+dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/ca-presidio-engboard.dts b/arch/arm/dts/ca-presidio-engboard.dts new file mode 100644 index 0000000..c03dacc --- /dev/null +++ b/arch/arm/dts/ca-presidio-engboard.dts @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020, Cortina Access Inc. + */ + +/dts-v1/; + +/ { + #address-cells = <2>; + #size-cells = <1>; + + mmc0: mmc@f4400000 { + compatible = "snps,dw-cortina"; + reg = <0x0 0xf4400000 0x1000>; + bus-width = <4>; + io_ds = <0x77>; + fifo-mode; + sd_dll_ctrl = <0xf43200e8>; + io_drv_ctrl = <0xf432004c>; + }; + + gpio0: gpio-controller@0xf4329280 { + compatible = "cortina,ca-gpio"; + reg = <0x0 0xf4329280 0x24>; + gpio-controller; + #gpio-cells = <2>; + status = "okay"; + }; + gpio1: gpio-controller@0xf43292a4 { + compatible = "cortina,ca-gpio"; + reg = <0x0 0xf43292a4 0x24>; + gpio-controller; + #gpio-cells = <2>; + status = "disabled"; + }; + + watchdog: watchdog@0xf432901c { + compatible = "cortina,ca-wdt"; + reg = <0x0 0xf432901c 0x34>, + <0x0 0xf4320020 0x04>; + status = "okay"; + }; + + uart0: serial@0xf4329148 { + u-boot,dm-pre-reloc; + compatible = "cortina,ca-uart"; + reg = <0x0 0xf4329148 0x30>; + status = "okay"; + }; + + i2c: i2c@f4329120 { + compatible = "cortina,ca-i2c"; + reg = <0x0 0xf4329120 0x28>; + clock-frequency = <400000>; + }; + + sflash: sflash-controller@f4324000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "cortina,ca-sflash"; + reg = <0x0 0xf4324000 0x50>; + reg-names = "sflash-regs"; + flash@0 { + compatible = "jedec,spi-nor"; + spi-rx-bus-width = <1>; + spi-max-frequency = <108000000>; + }; + }; +}; diff --git a/arch/arm/mach-cortina/Makefile b/arch/arm/mach-cortina/Makefile new file mode 100644 index 0000000..ffb8692 --- /dev/null +++ b/arch/arm/mach-cortina/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2020 Cortina Access Inc. +# +obj-y += lowlevel_init.o diff --git a/board/cortina/presidio-asic/Kconfig b/board/cortina/presidio-asic/Kconfig new file mode 100644 index 0000000..8e6f6cf --- /dev/null +++ b/board/cortina/presidio-asic/Kconfig @@ -0,0 +1,18 @@ +if TARGET_PRESIDIO_ASIC +config BIT64 + bool + default y + +select SOC_CA7774 + +config SYS_BOARD + default "presidio-asic" + +config SYS_VENDOR + default "cortina" + +config SYS_CONFIG_NAME + default "presidio_asic" + +source "board/cortina/common/Kconfig" +endif diff --git a/board/cortina/presidio-asic/MAINTAINERS b/board/cortina/presidio-asic/MAINTAINERS new file mode 100644 index 0000000..9db17bd --- /dev/null +++ b/board/cortina/presidio-asic/MAINTAINERS @@ -0,0 +1,6 @@ +Cortina Presidio ASIC G3 Engineering BOARD +M: Alex Nemirovsky alex.nemirovsky@cortina-access.com +S: Supported +F: board/cortina/presidio-asic/ +F: include/configs/presidio_asic.h +F: configs/cortina_presidio-asic*defconfig diff --git a/board/cortina/presidio-asic/Makefile b/board/cortina/presidio-asic/Makefile new file mode 100644 index 0000000..d167a15 --- /dev/null +++ b/board/cortina/presidio-asic/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2020 Cortina-Access.Inc. +# +# + +obj-y := presidio.o +obj-y += lowlevel_init.o diff --git a/board/cortina/presidio-asic/lowlevel_init.S b/board/cortina/presidio-asic/lowlevel_init.S new file mode 100644 index 0000000..4450a5d --- /dev/null +++ b/board/cortina/presidio-asic/lowlevel_init.S @@ -0,0 +1,87 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Cortina-Access + * + */ + + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> +#include <asm/macro.h> +#include <asm/armv8/mmu.h> + + .globl lowlevel_init +lowlevel_init: + mov x29, lr /* Save LR */ + +#if defined(CONFIG_SOC_CA7774) + /* Enable SMPEN in CPUECTLR */ + mrs x0, s3_1_c15_c2_1 + tst x0, #0x40 + b.ne skip_smp_setup + orr x0, x0, #0x40 + msr s3_1_c15_c2_1, x0 +skip_smp_setup: +#endif + +#if defined(CONFIG_SOC_CA8277B) + /* Enable CPU Timer */ + ldr x0, =CONFIG_SYS_TIMER_BASE + mov x1, #1 + str w1, [x0] +#endif + +#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) + branch_if_slave x0, 1f +#ifndef CONFIG_TARGET_VENUS + ldr x0, =GICD_BASE + bl gic_init_secure +#endif +1: +#if defined(CONFIG_GICV3) + ldr x0, =GICR_BASE + bl gic_init_secure_percpu +#elif defined(CONFIG_GICV2) + ldr x0, =GICD_BASE + ldr x1, =GICC_BASE + bl gic_init_secure_percpu +#endif +#endif + +#ifdef CONFIG_ARMV8_MULTIENTRY + branch_if_master x0, x1, 2f + + /* + * Slave should wait for master clearing spin table. + * This sync prevent salves observing incorrect + * value of spin table and jumping to wrong place. + */ +#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) +#ifdef CONFIG_GICV2 + ldr x0, =GICC_BASE +#endif + bl gic_wait_for_interrupt +#endif + + /* + * All slaves will enter EL2 and optionally EL1. + */ + adr x4, lowlevel_in_el2 + ldr x5, =ES_TO_AARCH64 + bl armv8_switch_to_el2 + +lowlevel_in_el2: +#ifdef CONFIG_ARMV8_SWITCH_TO_EL1 + adr x4, lowlevel_in_el1 + ldr x5, =ES_TO_AARCH64 + bl armv8_switch_to_el1 + +lowlevel_in_el1: +#endif + +#endif /* CONFIG_ARMV8_MULTIENTRY */ + +2: + mov lr, x29 /* Restore LR */ + ret diff --git a/board/cortina/presidio-asic/presidio.c b/board/cortina/presidio-asic/presidio.c new file mode 100644 index 0000000..b4fa01f --- /dev/null +++ b/board/cortina/presidio-asic/presidio.c @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 - Cortina Access Inc. + * + */ +#include <common.h> +#include <malloc.h> +#include <errno.h> +#include <netdev.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <configs/presidio_asic.h> +#include <linux/psci.h> +#include <asm/psci.h> +#include <cpu_func.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CA_PERIPH_BASE 0xE0000000UL +#define CA_PERIPH_SIZE 0x20000000UL +#define CA_GLOBAL_BASE 0xf4320000 +#define CA_GLOBAL_JTAG_ID 0xf4320000 +#define CA_GLOBAL_BLOCK_RESET 0xf4320004 +#define CA_GLOBAL_BLOCK_RESET_RESET_DMA BIT(16) +#define CA_DMA_SEC_SSP_BAUDRATE_CTRL 0xf7001b94 +#define CA_DMA_SEC_SSP_ID 0xf7001b80 + +int print_cpuinfo(void) +{ + printf("CPU: Cortina Presidio G3\n"); + return 0; +} + +static struct mm_region presidio_mem_map[] = { + { + .virt = DDR_BASE, + .phys = DDR_BASE, + .size = PHYS_SDRAM_1_SIZE, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_OUTER_SHARE + }, + { + .virt = CA_PERIPH_BASE, + .phys = CA_PERIPH_BASE, + .size = CA_PERIPH_SIZE, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, + { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = presidio_mem_map; + +static noinline int invoke_psci_fn_smc(u64 function_id, u64 arg0, u64 arg1, + u64 arg2) +{ + asm volatile("mov x0, %0\n" + "mov x1, %1\n" + "mov x2, %2\n" + "mov x3, %3\n" + "smc #0\n" + : "+r" (function_id) + : "r" (arg0), "r" (arg1), "r" (arg2) + ); + + return function_id; +} + +int board_early_init_r(void) +{ + dcache_disable(); + return 0; +} + +int board_init(void) +{ + unsigned int reg_data, jtag_id; + + /* Enable timer */ + writel(1, CONFIG_SYS_TIMER_BASE); + + /* Enable snoop in CCI400 slave port#4 */ + writel(3, 0xF5595000); + + jtag_id = readl(CA_GLOBAL_JTAG_ID); + + /* If this is HGU variant then do not use + * the Saturn daughter card ref. clk + */ + if (jtag_id == 0x1010D8F3) { + reg_data = readl(0xF3100064); + /* change multifunc. REF CLK pin to + * a simple GPIO pin + */ + reg_data |= (1 << 1); + writel(reg_data, 0xf3100064); + } + + return 0; +} + +int dram_init(void) +{ + unsigned int ddr_size; + + ddr_size = readl(0x111100c); + gd->ram_size = ddr_size * 0x100000; + return 0; +} + +void reset_cpu(ulong addr) +{ + invoke_psci_fn_smc(PSCI_0_2_FN_SYSTEM_RESET, 0, 0, 0); +} + +#ifdef CONFIG_LAST_STAGE_INIT +int last_stage_init(void) +{ + u32 val; + + val = readl(CA_GLOBAL_BLOCK_RESET); + val &= ~CA_GLOBAL_BLOCK_RESET_RESET_DMA; + writel(val, CA_GLOBAL_BLOCK_RESET); + + /* reduce output pclk ~3.7Hz to save power consumption */ + writel(0x000000FF, CA_DMA_SEC_SSP_BAUDRATE_CTRL); + + return 0; +} +#endif diff --git a/configs/cortina_presidio-asic-base_defconfig b/configs/cortina_presidio-asic-base_defconfig new file mode 100644 index 0000000..ec64bd2 --- /dev/null +++ b/configs/cortina_presidio-asic-base_defconfig @@ -0,0 +1,29 @@ +CONFIG_ARM=y +# CONFIG_SYS_ARCH_TIMER is not set +CONFIG_TARGET_PRESIDIO_ASIC=y +CONFIG_SYS_TEXT_BASE=0x04000000 +CONFIG_DM_GPIO=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_IDENT_STRING="Presidio-SoC" +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon=serial,0xf4329148 console=ttyS0,115200 root=/dev/ram0" +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SYS_PROMPT="G3#" +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_SMC=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_DEFAULT_DEVICE_TREE="ca-presidio-engboard" +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_CORTINA_GPIO=y +# CONFIG_MMC is not set +CONFIG_DM_SERIAL=y +CONFIG_CORTINA_UART=y +CONFIG_WDT=y +CONFIG_WDT_CORTINA=y diff --git a/include/configs/presidio_asic.h b/include/configs/presidio_asic.h new file mode 100644 index 0000000..023092e --- /dev/null +++ b/include/configs/presidio_asic.h @@ -0,0 +1,75 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Cortina Access Inc. + * + * Configuration for Cortina-Access Presidio board. + */ + +#ifndef __PRESIDIO_ASIC_H +#define __PRESIDIO_ASIC_H + +#define CONFIG_REMAKE_ELF + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SYS_INIT_SP_ADDR 0x00100000 +#define CONFIG_SYS_BOOTM_LEN 0x00c00000 + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 25000000 +#define CONFIG_SYS_TIMER_RATE COUNTER_FREQUENCY +#define CONFIG_SYS_TIMER_COUNTER 0xf4321008 + +/* note: arch/arm/cpu/armv8/start.S which references GICD_BASE/GICC_BASE + * does not yet support DT. Thus define it here. + */ +#define CONFIG_GICV2 +#define GICD_BASE 0xf7011000 +#define GICC_BASE 0xf7012000 + +#define CONFIG_SYS_MEMTEST_SCRATCH 0x00100000 +#define CONFIG_SYS_MEMTEST_START 0x05000000 +#define CONFIG_SYS_MEMTEST_END 0x0D000000 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (8 << 20)) + +#define CONFIG_SYS_TIMER_BASE 0xf4321000 + +/* Use external clock source */ +#define PRESIDIO_APB_CLK 125000000 +#define CORTINA_PER_IO_FREQ PRESIDIO_APB_CLK + +/* Cortina Serial Configuration */ +#define CORTINA_UART_CLOCK (PRESIDIO_APB_CLK) +#define CORTINA_SERIAL_PORTS {(void *)CONFIG_SYS_SERIAL0, \ + (void *)CONFIG_SYS_SERIAL1} + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_SERIAL0 PER_UART0_CFG +#define CONFIG_SYS_SERIAL1 PER_UART1_CFG + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (DDR_BASE + 0x10000000) +#define CONFIG_LAST_STAGE_INIT + +/* SDRAM Bank #1 */ +#define DDR_BASE 0x00000000 +#define PHYS_SDRAM_1 DDR_BASE +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2GB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* max command args */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_EXTRA_ENV_SETTINGS "silent=y\0" + +#endif /* __PRESIDIO_ASIC_H */
Hello Tom and Daniel,
This v4 of patch 6/6 in the series is the only one which yield feedback in the prior v3. All other are in “Reviewed-By” state. We hope that v4 sent out a week ago has addressed those issues.
Let us know if there is anything else holding up the series acceptance.
BR -AN
On Jan 30, 2020, at 12:34 PM, Alex Nemirovsky Alex.Nemirovsky@cortina-access.com wrote:
Changes in v4:
Changes in v3:
Changes in v2: None
- bool "Support Cortina Presidio ASIC Platform"
- select ARM64
endchoice
targets += $(dtb-y)
- Copyright (C) 2020, Cortina Access Inc.
+/dts-v1/;
- #address-cells = <2>;
- #size-cells = <1>;
- mmc0: mmc@f4400000 {
bus-width = <4>;
io_ds = <0x77>;
fifo-mode;
- gpio0: gpio-controller@0xf4329280 {
gpio-controller;
#gpio-cells = <2>;
status = "okay";
- gpio1: gpio-controller@0xf43292a4 {
gpio-controller;
#gpio-cells = <2>;
- watchdog: watchdog@0xf432901c {
status = "okay";
- uart0: serial@0xf4329148 {
status = "okay";
- i2c: i2c@f4329120 {
- sflash: sflash-controller@f4324000 {
#size-cells = <1>;
flash@0 {
bool
default y
+select SOC_CA7774
+config SYS_BOARD
- default "presidio-asic"
+config SYS_VENDOR
- default "cortina"
- default "presidio_asic"
- Copyright (C) 2020 Cortina-Access
- .globl lowlevel_init
+lowlevel_init:
- mov x29, lr /* Save LR */
- /* Enable SMPEN in CPUECTLR */
- mrs x0, s3_1_c15_c2_1
- tst x0, #0x40
b.ne skip_smp_setup
- orr x0, x0, #0x40
- msr s3_1_c15_c2_1, x0
- /* Enable CPU Timer */
- ldr x0, =CONFIG_SYS_TIMER_BASE
- mov x1, #1
- str w1, [x0]
- branch_if_slave x0, 1f
- ldr x0, =GICD_BASE
- bl gic_init_secure
- ldr x0, =GICR_BASE
- bl gic_init_secure_percpu
- ldr x1, =GICC_BASE
+#endif +#endif
- branch_if_master x0, x1, 2f
- ldr x0, =GICC_BASE
- bl gic_wait_for_interrupt
- adr x4, lowlevel_in_el2
- ldr x5, =ES_TO_AARCH64
- bl armv8_switch_to_el2
- adr x4, lowlevel_in_el1
- bl armv8_switch_to_el1
+2:
- mov lr, x29 /* Restore LR */
- ret
- (C) Copyright 2020 - Cortina Access Inc.
- printf("CPU: Cortina Presidio G3\n");
- .virt = DDR_BASE,
- .phys = DDR_BASE,
- .size = PHYS_SDRAM_1_SIZE,
- .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) |
- .virt = CA_PERIPH_BASE,
- .phys = CA_PERIPH_BASE,
- .size = CA_PERIPH_SIZE,
- .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) |
PTE_BLOCK_NON_SHARE
- /* List terminator */
- 0,
u64 arg2)
- asm volatile("mov x0, %0\n"
"mov x1, %1\n"
"mov x2, %2\n"
"mov x3, %3\n"
"smc #0\n"
- return function_id;
- dcache_disable();
- unsigned int reg_data, jtag_id;
- /* Enable timer */
- writel(1, CONFIG_SYS_TIMER_BASE);
- /* Enable snoop in CCI400 slave port#4 */
- writel(3, 0xF5595000);
- jtag_id = readl(CA_GLOBAL_JTAG_ID);
- /* If this is HGU variant then do not use
- if (jtag_id == 0x1010D8F3) {
* a simple GPIO pin
- unsigned int ddr_size;
- ddr_size = readl(0x111100c);
- gd->ram_size = ddr_size * 0x100000;
- invoke_psci_fn_smc(PSCI_0_2_FN_SYSTEM_RESET, 0, 0, 0);
- u32 val;
- val = readl(CA_GLOBAL_BLOCK_RESET);
- val &= ~CA_GLOBAL_BLOCK_RESET_RESET_DMA;
- writel(val, CA_GLOBAL_BLOCK_RESET);
- /* reduce output pclk ~3.7Hz to save power consumption */
- writel(0x000000FF, CA_DMA_SEC_SSP_BAUDRATE_CTRL);
- Copyright (C) 2020 Cortina Access Inc.
- Configuration for Cortina-Access Presidio board.
- does not yet support DT. Thus define it here.
2.7.4
Alex Nemirovsky
Alex Nemirovsky
