Re: [U-Boot] [PATCH v9 8/9] doc: sifive-fu540: Update README for steps to create FW_PAYLOAD
From: Anup Patel [mailto:Anup.Patel@wdc.com] Sent: Tuesday, June 25, 2019 2:32 PM To: Rick Jian-Zhi Chen(陳建志); Bin Meng; Lukas Auer; Simon Glass Cc: Ramon Fried; Joe Hershberger; Palmer Dabbelt; Paul Walmsley; Troy Benjegerdes; Atish Patra; Alistair Francis; U-Boot Mailing List; Anup Patel Subject: [PATCH v9 8/9] doc: sifive-fu540: Update README for steps to create FW_PAYLOAD
Due changes in DT bindings, we now embed DTB from Linux-5.3 (or higher) in OpenSBI FW_PAYLOAD along with payload u-boot.bin. This patch updates SiFive FU540 README to reflect the changes in build and boot steps.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Alistair Francis Alistair.Francis@wdc.com
doc/README.sifive-fu540 | 356 ++++++++++++++++++---------------------- 1 file changed, 164 insertions(+), 192 deletions(-)
diff --git a/doc/README.sifive-fu540 b/doc/README.sifive-fu540 index fd9f2a8e46..33e03dc861 100644 --- a/doc/README.sifive-fu540 +++ b/doc/README.sifive-fu540 @@ -13,7 +13,8 @@ The support for following drivers are already enabled: 3. Cadence MACB ethernet driver for networking support.
TODO: -1. SPI driver is still missing. So MMC card can't be used in U-Boot as of now. +1. SPI host driver is still missing. +2. SPI MMC driver does not compile and needs a re-write using U-Boot DM. 2. U-Boot expects the serial console device entry to be present under /chosen DT node. Example: chosen { @@ -33,16 +34,21 @@ Building
Flashing
-The current U-Boot port is supported in S-mode only and loaded from DRAM. +The current U-Boot port is supported in S-mode only and loaded directly +into DRAM.
-A prior stage (M-mode) firmware/bootloader (e.g OpenSBI or BBL) is required to -load the u-boot.bin into memory and provide runtime services. The u-boot.bin -can be given as a payload to the prior stage (M-mode) firmware/bootloader. +A prior stage (M-mode) firmware/bootloader (e.g OpenSBI) is required to +boot the u-boot.bin in S-mode and provide M-mode runtime services.
-The description of steps required to build the firmware is beyond the scope of -this document. Please refer OpenSBI or BBL documenation. +Currently, the u-boot.bin is used as a payload of the OpenSBI +FW_PAYLOAD firmware. We need to compile OpenSBI with below command: +make PLATFORM=sifive/fu540 FW_PAYLOAD_PATH=<path to u-boot.bin> +FW_PAYLOAD_FDT_PATH=<path to hifive-unleashed-a00.dtb from Linux> +(Note: Prefer hifive-unleashed-a00.dtb from Linux-5.3 or higher) +(Note: Linux-5.2 is also fine but it does not have ethernet DT node)
+More detailed description of steps required to build FW_PAYLOAD +firmware is beyond the scope of this document. Please refer OpenSBI documenation. (Note: OpenSBI git repo is at https://github.com/riscv/opensbi.git) -(Note: BBL git repo is at https://github.com/riscv/riscv-pk.git)
Once the prior stage firmware/bootloader binary is generated, it should be copied to the first partition of the sdcard. @@ -55,20 +61,18 @@ Once you plugin the sdcard and power up, you should see the U-Boot prompt.
Sample boot log from HiFive Unleashed board
-U-Boot 2019.01-00019-gc7953536-dirty (Jan 22 2019 - 11:05:40 -0800) +U-Boot 2019.07-rc4-00013-g1837f893b0 (Jun 20 2019 - 11:08:48 +0530)
CPU: rv64imafdc -Model: sifive,hifive-unleashed-a00 +Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB In: serial@10010000 Out: serial@10010000 Err: serial@10010000 -Net: -Warning: ethernet@10090000 (eth0) using random MAC address - b6:75:4d:48:50:94 -eth0: ethernet@10090000 +Net: eth0: ethernet@10090000 Hit any key to stop autoboot: 0 => version -U-Boot 2019.01-00019-gc7953536-dirty (Jan 22 2019 - 11:05:40 -0800) +U-Boot 2019.07-rc4-00013-g1837f893b0 (Jun 20 2019 - 11:08:48 +0530)
riscv64-linux-gcc.br_real (Buildroot 2018.11-rc2-00003-ga0787e9) 8.2.0 GNU ld (GNU Binutils) 2.31.1 @@ -79,30 +83,19 @@ Now you can configure your networking, tftp server and use tftp boot method to load uImage.
-=> setenv ethaddr 70:B3:D5:92:F0:C2 -=> setenv ipaddr 10.196.157.189 -=> setenv serverip 10.11.143.218 -=> setenv gatewayip 10.196.156.1 +=> setenv ipaddr 10.206.5.241 => setenv netmask 255.255.252.0 -=> bdinfo -boot_params = 0x0000000000000000 -DRAM bank = 0x0000000000000000 --> start = 0x0000000080000000 --> size = 0x0000000200000000 -relocaddr = 0x00000000fff90000 -reloc off = 0x000000007fd90000 -ethaddr = 70:B3:D5:92:F0:C2 -IP addr = 10.196.157.189 -baudrate = 115200 bps -=> tftpboot uImage +=> setenv serverip 10.206.4.143 +=> setenv gateway 10.206.4.1 +=> tftpboot ${kernel_addr_r} /sifive/fu540/uImage ethernet@10090000: PHY present at 0 ethernet@10090000: Starting autonegotiation... ethernet@10090000: Autonegotiation complete -ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x3800) +ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x7c00) Using ethernet@10090000 device -TFTP from server 10.11.143.218; our IP address is 10.196.157.189; sending through gateway 10.196.156.1 -Filename 'uImage'. -Load address: 0x80200000 +TFTP from server 10.206.4.143; our IP address is 10.206.5.241 Filename +'/sifive/fu540/uImage'. +Load address: 0x80600000 Loading: ############################################################# ####
############################################################# #### @@ -112,192 +105,171 @@ Loading: ############################################################# ####
1.5 MiB/s
+done +Bytes transferred = 9162364 (8bce7c hex) => tftpboot ${ramdisk_addr_r} +/sifive/fu540/uRamdisk +ethernet@10090000: PHY present at 0 +ethernet@10090000: Starting autonegotiation... +ethernet@10090000: Autonegotiation complete +ethernet@10090000: link up, 1000Mbps full-duplex (lpa: 0x7c00) Using +ethernet@10090000 device TFTP from server 10.206.4.143; our IP address +is 10.206.5.241 Filename '/sifive/fu540/uRamdisk'. +Load address: 0x82500000 +Loading: +############################################################ #####
2.5 MiB/s
448.2 KiB/s
done -Bytes transferred = 14939132 (e3f3fc hex) -=> bootm 0x80200000 - 0x82200000 -## Booting kernel from Legacy Image at 80200000 ... +Bytes transferred = 2398272 (249840 hex) => setenv bootargs +"root=/dev/ram rw console=ttySIF0 earlycon=sbi" +=> bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdtcontroladdr} ## +Booting kernel from Legacy Image at 80600000 ... Image Name: Linux Image Type: RISC-V Linux Kernel Image (uncompressed)
- Data Size: 14939068 Bytes = 14.2 MiB
- Data Size: 9162300 Bytes = 8.7 MiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK
-## Flattened Device Tree blob at 82200000
- Booting using the fdt blob at 0x82200000
+## Loading init Ramdisk from Legacy Image at 82500000 ...
- Image Name: Linux RootFS
- Image Type: RISC-V Linux RAMDisk Image (uncompressed)
- Data Size: 2398208 Bytes = 2.3 MiB
- Load Address: 00000000
- Entry Point: 00000000
- Verifying Checksum ... OK
+## Flattened Device Tree blob at ff795730
- Booting using the fdt blob at 0xff795730 Loading Kernel Image ... OK
- Using Device Tree in place at 0000000082200000, end 0000000082205c69
- Using Device Tree in place at 00000000ff795730, end 00000000ff799dac
Starting kernel ...
[ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 -[ 0.000000] Linux version 5.0.0-rc1-00020-g4b51f736 (atish@jedi-01) (gcc version 7.2.0 (GCC)) #262 SMP Mon Jan 21 17:39:27 PST 2019 -[ 0.000000] initrd not found or empty - disabling initrd +[ 0.000000] Linux version 5.2.0-rc1-00003-gb9543e66e700 (anup@anup-lab-machine) (gcc version 8.2.0 (Buildroot 2018.11-rc2-00003-ga0787e9)) #1 SMP Thu Jun 20 11:41:26 IST 2019 +[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') +[ 0.000000] printk: bootconsole [sbi0] enabled +[ 0.000000] Initial ramdisk at: 0x(____ptrval____) (2398208 bytes) [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff] -[ 0.000000] Normal [mem 0x0000000100000000-0x000027ffffffffff] +[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080200000-0x000000027fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000027fffffff] -[ 0.000000] software IO TLB: mapped [mem 0xfbfff000-0xfffff000] (64MB) -[ 0.000000] CPU with hartid=0 has a non-okay status of "masked" -[ 0.000000] CPU with hartid=0 has a non-okay status of "masked" +[ 0.000000] software IO TLB: mapped [mem 0xfb795000-0xff795000] (64MB) +[ 0.000000] CPU with hartid=0 is not available +[ 0.000000] CPU with hartid=0 is not available [ 0.000000] elf_hwcap is 0x112d -[ 0.000000] percpu: Embedded 15 pages/cpu @(____ptrval____) s29720 r0 d31720 u61440 +[ 0.000000] percpu: Embedded 17 pages/cpu s29592 r8192 d31848 u69632 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975 -[ 0.000000] Kernel command line: earlyprintk +[ 0.000000] Kernel command line: root=/dev/ram rw console=ttySIF0 earlycon=sbi [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Sorting __ex_table... -[ 0.000000] Memory: 8178760K/8386560K available (3309K kernel code, 248K rwdata, 872K rodata, 9381K init, 763K bss, 207800K reserved, 0K cma-reserved) +[ 0.000000] Memory: 8182056K/8386560K available (5753K kernel code, 357K rwdata, 1804K rodata, 204K init, 808K bss, 204504K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Hierarchical RCU implementation. -[ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. -[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. +[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0 -[ 0.000000] plic: mapped 53 interrupts to 4 (out of 9) handlers. -[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1] +[ 0.000000] plic: mapped 53 interrupts with 4 handlers for 9 contexts. +[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [2] [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns -[ 0.000008] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns -[ 0.000221] Console: colour dummy device 80x25 -[ 0.000902] printk: console [tty0] enabled -[ 0.000963] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) -[ 0.001034] pid_max: default: 32768 minimum: 301 -[ 0.001541] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) -[ 0.001912] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) -[ 0.003542] rcu: Hierarchical SRCU implementation. -[ 0.004347] smp: Bringing up secondary CPUs ... -[ 1.040259] CPU1: failed to come online -[ 2.080483] CPU2: failed to come online -[ 3.120699] CPU3: failed to come online -[ 3.120765] smp: Brought up 1 node, 1 CPU -[ 3.121923] devtmpfs: initialized -[ 3.124649] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns -[ 3.124727] futex hash table entries: 1024 (order: 4, 65536 bytes) -[ 3.125346] random: get_random_u32 called from bucket_table_alloc+0x72/0x172 with crng_init=0 -[ 3.125578] NET: Registered protocol family 16 -[ 3.126400] sifive-u54-prci 10000000.prci: Registered U54 core clocks -[ 3.126649] sifive-gemgxl-mgmt 100a0000.cadence-gemgxl-mgmt: Registered clock switch 'cadence-gemgxl-mgmt' -[ 3.135572] vgaarb: loaded -[ 3.135858] SCSI subsystem initialized -[ 3.136193] usbcore: registered new interface driver usbfs -[ 3.136266] usbcore: registered new interface driver hub -[ 3.136348] usbcore: registered new device driver usb -[ 3.136446] pps_core: LinuxPPS API ver. 1 registered -[ 3.136484] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it -[ 3.136575] PTP clock support registered -[ 3.137256] clocksource: Switched to clocksource riscv_clocksource -[ 3.142711] NET: Registered protocol family 2 -[ 3.143322] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes) -[ 3.143634] TCP established hash table entries: 65536 (order: 7, 524288 bytes) -[ 3.145799] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) -[ 3.149121] TCP: Hash tables configured (established 65536 bind 65536) -[ 3.149591] UDP hash table entries: 4096 (order: 5, 131072 bytes) -[ 3.150094] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes) -[ 3.150781] NET: Registered protocol family 1 -[ 3.230693] workingset: timestamp_bits=62 max_order=21 bucket_order=0 -[ 3.241224] io scheduler mq-deadline registered -[ 3.241269] io scheduler kyber registered -[ 3.242143] sifive_gpio 10060000.gpio: SiFive GPIO chip registered 16 GPIOs -[ 3.242357] pwm-sifivem 10020000.pwm: Unable to find controller clock -[ 3.242439] pwm-sifivem 10021000.pwm: Unable to find controller clock -[ 3.243228] xilinx-pcie 2000000000.pci: PCIe Link is DOWN -[ 3.243289] xilinx-pcie 2000000000.pci: host bridge /soc/pci@2000000000 ranges: -[ 3.243360] xilinx-pcie 2000000000.pci: No bus range found for /soc/pci@2000000000, using [bus 00-ff] -[ 3.243447] xilinx-pcie 2000000000.pci: MEM 0x40000000..0x5fffffff -> 0x40000000 -[ 3.243591] xilinx-pcie 2000000000.pci: PCI host bridge to bus 0000:00 -[ 3.243636] pci_bus 0000:00: root bus resource [bus 00-ff] -[ 3.243676] pci_bus 0000:00: root bus resource [mem 0x40000000-0x5fffffff] -[ 3.276547] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled -[ 3.277689] 10010000.serial: ttySIF0 at MMIO 0x10010000 (irq = 39, base_baud = 0) is a SiFive UART v0 -[ 3.786963] printk: console [ttySIF0] enabled -[ 3.791504] 10011000.serial: ttySIF1 at MMIO 0x10011000 (irq = 40, base_baud = 0) is a SiFive UART v0 -[ 3.801251] sifive_spi 10040000.spi: mapped; irq=41, cs=1 -[ 3.806362] m25p80 spi0.0: unrecognized JEDEC id bytes: 9d, 70, 19 -[ 3.812084] m25p80: probe of spi0.0 failed with error -2 -[ 3.817453] sifive_spi 10041000.spi: mapped; irq=42, cs=4 -[ 3.823027] sifive_spi 10050000.spi: mapped; irq=43, cs=1 -[ 3.828604] libphy: Fixed MDIO Bus: probed -[ 3.832623] macb: GEM doesn't support hardware ptp. -[ 3.837196] libphy: MACB_mii_bus: probed -[ 4.041156] Microsemi VSC8541 SyncE 10090000.ethernet-ffffffff:00: attached PHY driver [Microsemi VSC8541 SyncE] (mii_bus:phy_addr=10090000.ethernet-ffffffff:00, irq=POLL) -[ 4.055779] macb 10090000.ethernet eth0: Cadence GEM rev 0x10070109 at 0x10090000 irq 12 (70:b3:d5:92:f0:c2) -[ 4.065780] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver -[ 4.072033] ehci-pci: EHCI PCI platform driver -[ 4.076521] usbcore: registered new interface driver usb-storage -[ 4.082843] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0) -[ 4.127465] mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff -[ 4.133645] usbcore: registered new interface driver usbhid -[ 4.138980] usbhid: USB HID core driver -[ 4.143017] NET: Registered protocol family 17 -[ 4.147885] pwm-sifivem 10020000.pwm: SiFive PWM chip registered 4 PWMs -[ 4.153945] pwm-sifivem 10021000.pwm: SiFive PWM chip registered 4 PWMs -[ 4.186407] Freeing unused kernel memory: 9380K -[ 4.190224] This architecture does not have kernel memory protection. -[ 4.196609] Run /init as init process -Starting logging: OK -Starting mdev... -[ 4.303785] mmc0: host does not support reading read-only switch, assuming write-enable -[ 4.311109] mmc0: new SDHC card on SPI -[ 4.317103] mmcblk0: mmc0:0000 SS08G 7.40 GiB -[ 4.386471] mmcblk0: p1 p2 -sort: /sys/devices/platform/Fixed: No such file or directory -modprobe: can't change directory to '/lib/modules': No such file or directory -Initializing random[ 4.759075] random: dd: uninitialized urandom read (512 bytes read)
- number generator... done.
-Starting network... -udhcpc (v1.24.2) started -Sending discover... -Sending discover... -[ 7.927510] macb 10090000.ethernet eth0: link up (1000/Full) -Sending discover... -Sending select for 10.196.157.190... -Lease of 10.196.157.190 obtained, lease time 499743 -deleting routers -adding dns 10.86.1.1 -adding dns 10.86.2.1 -/etc/init.d/S50dropbear -Starting dropbear sshd: [ 12.772393] random: dropbear: uninitialized urandom read (32 bytes read) -OK +[ 0.000007] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns +[ 0.008553] Console: colour dummy device 80x25 +[ 0.012990] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000) +[ 0.023103] pid_max: default: 32768 minimum: 301 +[ 0.028269] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes) +[ 0.035068] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes) +[ 0.042770] *** VALIDATE proc *** +[ 0.045610] *** VALIDATE cgroup1 *** +[ 0.049157] *** VALIDATE cgroup2 *** +[ 0.053743] rcu: Hierarchical SRCU implementation. +[ 0.058297] smp: Bringing up secondary CPUs ... +[ 0.064134] smp: Brought up 1 node, 4 CPUs +[ 0.069114] devtmpfs: initialized +[ 0.073281] random: get_random_u32 called from bucket_table_alloc.isra.10+0x4e/0x160 with crng_init=0 +[ 0.082157] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns +[ 0.091634] futex hash table entries: 1024 (order: 4, 65536 bytes) +[ 0.098480] NET: Registered protocol family 16 +[ 0.114101] vgaarb: loaded +[ 0.116397] SCSI subsystem initialized +[ 0.120358] usbcore: registered new interface driver usbfs +[ 0.125541] usbcore: registered new interface driver hub +[ 0.130936] usbcore: registered new device driver usb +[ 0.136618] clocksource: Switched to clocksource riscv_clocksource +[ 0.148108] NET: Registered protocol family 2 +[ 0.152358] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes) +[ 0.159928] TCP established hash table entries: 65536 (order: 7, 524288 bytes) +[ 0.169027] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) +[ 0.178360] TCP: Hash tables configured (established 65536 bind 65536) +[ 0.184653] UDP hash table entries: 4096 (order: 5, 131072 bytes) +[ 0.190819] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes) +[ 0.197618] NET: Registered protocol family 1 +[ 0.201892] RPC: Registered named UNIX socket transport module. +[ 0.207395] RPC: Registered udp transport module. +[ 0.212159] RPC: Registered tcp transport module. +[ 0.216940] RPC: Registered tcp NFSv4.1 backchannel transport module. +[ 0.223445] PCI: CLS 0 bytes, default 64 +[ 0.227726] Unpacking initramfs... +[ 0.260556] Freeing initrd memory: 2336K +[ 0.264652] workingset: timestamp_bits=62 max_order=21 bucket_order=0 +[ 0.278452] NFS: Registering the id_resolver key type +[ 0.282841] Key type id_resolver registered +[ 0.287067] Key type id_legacy registered +[ 0.291155] nfs4filelayout_init: NFSv4 File Layout Driver Registering... +[ 0.298299] NET: Registered protocol family 38 +[ 0.302470] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254) +[ 0.309906] io scheduler mq-deadline registered +[ 0.314501] io scheduler kyber registered +[ 0.354134] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled +[ 0.360725] 10010000.serial: ttySIF0 at MMIO 0x10010000 (irq = 4, base_baud = 0) is a SiFive UART v0 +[ 0.369191] printk: console [ttySIF0] enabled +[ 0.369191] printk: console [ttySIF0] enabled +[ 0.377938] printk: bootconsole [sbi0] disabled +[ 0.377938] printk: bootconsole [sbi0] disabled +[ 0.387298] 10011000.serial: ttySIF1 at MMIO 0x10011000 (irq = 1, base_baud = 0) is a SiFive UART v0 +[ 0.396411] [drm] radeon kernel modesetting enabled. +[ 0.409818] loop: module loaded +[ 0.412606] libphy: Fixed MDIO Bus: probed +[ 0.416870] macb 10090000.ethernet: Registered clk switch 'sifive-gemgxl-mgmt' +[ 0.423570] macb: GEM doesn't support hardware ptp. +[ 0.428469] libphy: MACB_mii_bus: probed +[ 1.053009] Microsemi VSC8541 SyncE 10090000.ethernet-ffffffff:00: attached PHY driver [Microsemi VSC8541 SyncE] (mii_bus:phy_addr=10090000.ethernet-ffffffff:00, irq=POLL) +[ 1.067548] macb 10090000.ethernet eth0: Cadence GEM rev 0x10070109 at 0x10090000 irq 7 (70:b3:d5:92:f2:f3) +[ 1.077330] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k +[ 1.083069] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. +[ 1.089061] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver +[ 1.095485] ehci-pci: EHCI PCI platform driver +[ 1.099947] ehci-platform: EHCI generic platform driver +[ 1.105196] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver +[ 1.111286] ohci-pci: OHCI PCI platform driver +[ 1.115742] ohci-platform: OHCI generic platform driver +[ 1.121142] usbcore: registered new interface driver uas +[ 1.126269] usbcore: registered new interface driver usb-storage +[ 1.132331] mousedev: PS/2 mouse device common for all mice +[ 1.137978] usbcore: registered new interface driver usbhid +[ 1.143325] usbhid: USB HID core driver +[ 1.148022] NET: Registered protocol family 10 +[ 1.152609] Segment Routing with IPv6 +[ 1.155571] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver +[ 1.161927] NET: Registered protocol family 17 +[ 1.165907] Key type dns_resolver registered +[ 1.171694] Freeing unused kernel memory: 204K +[ 1.175375] This architecture does not have kernel memory protection. +[ 1.181792] Run /init as init process
_ _
| ||_|
| | _ ____ _ _ _ _
| || | _ \| | | |\ \/ /
| || | | | | |_| |/ \
|_||_|_| |_|\____|\_/\_/
Busybox Rootfs
-Welcome to Buildroot -buildroot login: +Please press Enter to activate this console. +/ #
Applied to u-boot-riscv/master, thanks!
Rick
Rick Chen
