[U-Boot] [PATCH 0/2] sama5d3xek: get GMAC working
I had a strange behaviour for my sama5d34ek board which could sometimes not get up GMAC in U-Boot. It turned out, that we missed to initialize the PHY correctly.
Bo, could you please verify correct behaviour on 100MiB devices like sama5d31ek?
Andreas Bießmann (2): macb: simplify gmac initialisation sama5d3xek: run PHY's config
board/atmel/sama5d3xek/sama5d3xek.c | 29 ++++++++++++++++++++--------- drivers/net/macb.c | 25 ++++++++----------------- 2 files changed, 28 insertions(+), 26 deletions(-)
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Bo Shen voice.shen@atmel.com ---
drivers/net/macb.c | 25 ++++++++----------------- 1 file changed, 8 insertions(+), 17 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 01a94a4..375c8a4 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -479,31 +479,22 @@ static int macb_phy_init(struct macb_device *macb) /* First check for GMAC */ if (macb_is_gem(macb)) { lpa = macb_mdio_read(macb, MII_STAT1000); - if (lpa & (1 << 11)) { - speed = 1000; - duplex = 1; - } else { - if (lpa & (1 << 10)) { - speed = 1000; - duplex = 1; - } else { - speed = 0; - } - }
- if (speed == 1000) { - printf("%s: link up, %dMbps %s-duplex (lpa: 0x%04x)\n", + if (lpa & (LPA_1000FULL | LPA_1000HALF)) { + duplex = ((lpa & LPA_1000FULL) ? 1 : 0); + + printf("%s: link up, 1000Mbps %s-duplex (lpa: 0x%04x)\n", netdev->name, - speed, duplex ? "full" : "half", lpa);
ncfgr = macb_readl(macb, NCFGR); - ncfgr &= ~(GEM_BIT(GBE) | MACB_BIT(SPD) | MACB_BIT(FD)); - if (speed) - ncfgr |= GEM_BIT(GBE); + ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD)); + ncfgr |= GEM_BIT(GBE); + if (duplex) ncfgr |= MACB_BIT(FD); + macb_writel(macb, NCFGR, ncfgr);
return 1;
Dear Andreas Devel,
Andreas Devel andreas.devel@googlemail.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com
board/atmel/sama5d3xek/sama5d3xek.c | 29 ++++++++++++++++++++--------- 1 file changed, 20 insertions(+), 9 deletions(-)
diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index f53754b..ca4f79d 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -17,6 +17,7 @@ #include <lcd.h> #include <atmel_lcdc.h> #include <atmel_mci.h> +#include <phy.h> #include <micrel.h> #include <net.h> #include <netdev.h> @@ -273,15 +274,25 @@ int dram_init(void)
int board_phy_config(struct phy_device *phydev) { - /* rx data delay */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x2222); - /* tx data delay */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x2222); - /* rx/tx clock delay */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf2f4); + /* board specific timings for GMAC */ + if (has_gmac()) { + /* rx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, + 0x2222); + /* tx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, + 0x2222); + /* rx/tx clock delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, + 0xf2f4); + } + + /* always run the PHY's config routine */ + if (phydev->drv->config) + return phydev->drv->config(phydev);
return 0; }
Dear Andreas Devel,
Hi Andreas,
Test OK on sama5d31ek board, you can add Tested-by tag for this patch series.
Tested-by: Bo Shen voice.shen@atmel.com
Thanks.
Best Regards, Bo Shen
Andreas Bießmann
Bo Shen
