[PATCH v2] mx6sabreauto: Convert to DM_ETH
This fixes the following warning:
===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Signed-off-by: Pedro Jardim jardim.c.pedro@gmail.com --- Changes since v1: - Remove CONFIG_ETHPRIME=y - Remove CONFIG_FEC_MXC_PHYADDR=y board/freescale/mx6sabreauto/mx6sabreauto.c | 42 ------------- configs/mx6sabreauto_defconfig | 6 +++ include/configs/mx6sabreauto.h | 7 --- 3 files changed, 6 insertions(+), 49 deletions(-)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index 140f24459d..de19a562eb 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -22,7 +22,6 @@ #include <mmc.h> #include <fsl_esdhc_imx.h> #include <miiphy.h> -#include <netdev.h> #include <asm/arch/sys_proto.h> #include <i2c.h> #include <input.h> @@ -76,23 +75,6 @@ static iomux_v3_cfg_t const uart4_pads[] = { IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
-static iomux_v3_cfg_t const enet_pads[] = { - IOMUX_PADS(PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), -};
/* I2C2 PMIC, iPod, Tuner, Codec, Touch, HDMI EDID, MIPI CSI2 card */ static struct i2c_pads_info mx6q_i2c_pad_info1 = { @@ -259,10 +241,6 @@ static void setup_iomux_eimnor(void) } #endif
-static void setup_iomux_enet(void) -{ - SETUP_IOMUX_PADS(enet_pads); -}
static iomux_v3_cfg_t const usdhc3_pads[] = { IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), @@ -340,26 +318,6 @@ static void setup_gpmi_nand(void) } #endif
-static void setup_fec(void) -{ - if (is_mx6dqp()) { - /* - * select ENET MAC0 TX clock from PLL - */ - imx_iomux_set_gpr_register(5, 9, 1, 1); - enable_fec_anatop_clock(0, ENET_125MHZ); - } - - setup_iomux_enet(); -} - -int board_eth_init(bd_t *bis) -{ - setup_fec(); - - return cpu_eth_init(bis); -} - u32 get_board_rev(void) { int rev = nxp_board_rev(); diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index c53d079f88..69dfc1a3a1 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -96,3 +96,11 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y +CONFIG_FEC_MXC=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_RGMII=y diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index c07b03984a..68465b8e08 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -75,12 +75,5 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
-#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 1 - -#define CONFIG_PHY_ATHEROS
#endif /* __MX6SABREAUTO_CONFIG_H */
Reviewed-by: Fabio Estevam festevam@gmail.com
This fixes the following warning: ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ==================================================== Signed-off-by: Pedro Jardim jardim.c.pedro@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Pedro Jardim
sbabic@denx.de
