[U-Boot] [PATCH V2 0/5] i.MX6 (DQ/DLS): consolidate mux and pad names
This patch set consolidates mux and pad declarations for the i.MX6 Dual/Quad and Dual-Lite/Solo processor variants.
Patch 1 replaces the mux/pad names with their equivalents from the Linux kernel (from linux-next). This Patch 2 removes a set of completely useless pad declarations Patch 3 adds a number of registers that are defined in the Linux kernel and in the DLS variant, but not in the DQ. Patch 4 removes pad declarations that aren't used and aren't defined in the Linux kernel tree Patch 5 cleans up the whitespace in mx6[q|dl]_pins.h so the IOMUX_PAD() columns line up.
Note to reviewers: Because the majority of the changes in this patch set are simple name changes, using the '--word-diff' git parameter makes review much easier:
~/u-boot$ git diff HEAD^^^ --word-diff
V2 adds support for the udoo board into patch 1.
Eric Nelson (5): i.MX6DQ/DLS: replace pad names with their Linux kernel equivalents i.MX6DQ/DLS: remove useless mux/pad declarations i.MX6DQ: Add Pinmux settings that are present in mainline and Dual-Lite/Solo i.MX6DQ/DLS: remove unused pad declarations i.MX6DQ/DLS: whitespace: Align IOMUX_PAD column in declarations
arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 2413 ++++++++++--------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 2390 +++++++++--------------- board/barco/titanium/titanium.c | 106 +- board/boundary/nitrogen6x/nitrogen6x.c | 170 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 40 +- board/freescale/mx6qarm2/mx6qarm2.c | 66 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 60 +- board/freescale/mx6sabresd/mx6sabresd.c | 90 +- board/udoo/udoo.c | 20 +- board/wandboard/wandboard.c | 54 +- 10 files changed, 2115 insertions(+), 3294 deletions(-)
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- V2 adds support for board/udoo/.
arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 1824 ++++++++++++------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 1698 +++++++++++------------ board/barco/titanium/titanium.c | 106 +- board/boundary/nitrogen6x/nitrogen6x.c | 170 +-- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 40 +- board/freescale/mx6qarm2/mx6qarm2.c | 66 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 60 +- board/freescale/mx6sabresd/mx6sabresd.c | 90 +- board/udoo/udoo.c | 20 +- board/wandboard/wandboard.c | 54 +- 10 files changed, 2064 insertions(+), 2064 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 7373407..94f49c0 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -10,399 +10,399 @@ #include <asm/imx-common/iomux-v3.h>
enum { - MX6_PAD_CSI0_DAT10__IPU1_CSI0_D_10 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUDMUX_AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0360, 0x004C, 2, 0x07F8, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_TXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_RXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), MX6_PAD_CSI0_DAT10__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x0360, 0x004C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__GPIO_5_28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0360, 0x004C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__SIMBA_TRACE_7 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__IPU1_CSI0_D_11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0800, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_RXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), + MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0364, 0x0050, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__GPIO_5_29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x0364, 0x0050, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__SIMBA_TRACE_8 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__IPU1_CSI0_D_12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__WEIM_WEIM_D_8 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__PCIE_CTRL_DIAG_STATUS_BUS_MUX_16 = IOMUX_PAD(0x0368, 0x0054, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), MX6_PAD_CSI0_DAT12__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x0368, 0x0054, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__GPIO_5_30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__SIMBA_TRACE_9 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__IPU1_CSI0_D_13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__WEIM_WEIM_D_9 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__PCIE_CTRL_DIAG_STATUS_BUS_MUX_17 = IOMUX_PAD(0x036C, 0x0058, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_TXD = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RXD = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), + MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x036C, 0x0058, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__GPIO_5_31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x036C, 0x0058, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__SIMBA_TRACE_10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__IPU1_CSI0_D_14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__WEIM_WEIM_D_10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__PCIE_CTRL_DIAG_STATUS_BUS_MUX_18 = IOMUX_PAD(0x0370, 0x005C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TXD = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_RXD = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), MX6_PAD_CSI0_DAT14__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0370, 0x005C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__GPIO_6_0 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0370, 0x005C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__SIMBA_TRACE_11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__IPU1_CSI0_D_15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__WEIM_WEIM_D_11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__PCIE_CTRL_DIAG_STATUS_BUS_MUX_19 = IOMUX_PAD(0x0374, 0x0060, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_TXD = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RXD = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), + MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0374, 0x0060, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__GPIO_6_1 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x0374, 0x0060, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__SIMBA_TRACE_12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__IPU1_CSI0_D_16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__WEIM_WEIM_D_12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__PCIE_CTRL_DIAG_STATUS_BUS_MUX_20 = IOMUX_PAD(0x0378, 0x0064, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_CTS = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_RTS = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), MX6_PAD_CSI0_DAT16__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x0378, 0x0064, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__GPIO_6_2 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0378, 0x0064, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__SIMBA_TRACE_13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__IPU1_CSI0_D_17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__WEIM_WEIM_D_13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__PCIE_CTRL_DIAG_STATUS_BUS_MUX_21 = IOMUX_PAD(0x037C, 0x0068, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_CTS = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_RTS = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), + MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x037C, 0x0068, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__GPIO_6_3 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x037C, 0x0068, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__SIMBA_TRACE_14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__IPU1_CSI0_D_18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__WEIM_WEIM_D_14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__PCIE_CTRL_DIAG_STATUS_BUS_MUX_22 = IOMUX_PAD(0x0380, 0x006C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_CTS = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_RTS = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), + MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), MX6_PAD_CSI0_DAT18__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0380, 0x006C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__GPIO_6_4 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__MMDC_MMDC_DEBUG_41 = IOMUX_PAD(0x0380, 0x006C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__SIMBA_TRACE_15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__IPU1_CSI0_D_19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__WEIM_WEIM_D_15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__PCIE_CTRL_DIAG_STATUS_BUS_MUX_23 = IOMUX_PAD(0x0384, 0x0070, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_CTS = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_RTS = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), + MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0384, 0x0070, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__GPIO_6_5 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__MMDC_MMDC_DEBUG_42 = IOMUX_PAD(0x0384, 0x0070, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__ANATOP_ANATOP_TESTO_9 = IOMUX_PAD(0x0384, 0x0070, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__IPU1_CSI0_D_4 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__WEIM_WEIM_D_2 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0388, 0x0074, 2, 0x07D8, 0, 0), - MX6_PAD_CSI0_DAT4__KPP_COL_5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), - MX6_PAD_CSI0_DAT4__AUDMUX_AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__GPIO_5_22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), + MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__MMDC_MMDC_DEBUG_43 = IOMUX_PAD(0x0388, 0x0074, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__SIMBA_TRACE_1 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__IPU1_CSI0_D_5 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__WEIM_WEIM_D_3 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x038C, 0x0078, 2, 0x07E0, 0, 0), - MX6_PAD_CSI0_DAT5__KPP_ROW_5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), - MX6_PAD_CSI0_DAT5__AUDMUX_AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__GPIO_5_23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), + MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__MMDC_MMDC_DEBUG_44 = IOMUX_PAD(0x038C, 0x0078, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__SIMBA_TRACE_2 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__IPU1_CSI0_D_6 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__WEIM_WEIM_D_4 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0390, 0x007C, 2, 0x07DC, 0, 0), - MX6_PAD_CSI0_DAT6__KPP_COL_6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), - MX6_PAD_CSI0_DAT6__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__GPIO_5_24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), + MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__MMDC_MMDC_DEBUG_45 = IOMUX_PAD(0x0390, 0x007C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__SIMBA_TRACE_3 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__IPU1_CSI0_D_7 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__WEIM_WEIM_D_5 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0394, 0x0080, 2, 0x07E4, 0, 0), - MX6_PAD_CSI0_DAT7__KPP_ROW_6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), - MX6_PAD_CSI0_DAT7__AUDMUX_AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__GPIO_5_25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), + MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__MMDC_MMDC_DEBUG_46 = IOMUX_PAD(0x0394, 0x0080, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__SIMBA_TRACE_4 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__IPU1_CSI0_D_8 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__WEIM_WEIM_D_6 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0398, 0x0084, 2, 0x07F4, 0, 0), - MX6_PAD_CSI0_DAT8__KPP_COL_7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), + MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0), - MX6_PAD_CSI0_DAT8__GPIO_5_26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__MMDC_MMDC_DEBUG_47 = IOMUX_PAD(0x0398, 0x0084, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__SIMBA_TRACE_5 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__IPU1_CSI0_D_9 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__WEIM_WEIM_D_7 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x039C, 0x0088, 2, 0x07FC, 0, 0), - MX6_PAD_CSI0_DAT9__KPP_ROW_7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), + MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0), - MX6_PAD_CSI0_DAT9__GPIO_5_27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__MMDC_MMDC_DEBUG_48 = IOMUX_PAD(0x039C, 0x0088, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__SIMBA_TRACE_6 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__WEIM_WEIM_D_0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__PCIE_CTRL_DIAG_STATUS_BUS_MUX_14 = IOMUX_PAD(0x03A0, 0x008C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__GPIO_5_20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__MMDC_MMDC_DEBUG_31 = IOMUX_PAD(0x03A0, 0x008C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__SIMBA_TRCLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_13 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__CCM_CLKO = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__GPIO_5_19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x03A4, 0x0090, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__SIMBA_TRCTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_12 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__GPIO_5_18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__MMDC_MMDC_DEBUG_29 = IOMUX_PAD(0x03A8, 0x0094, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__SIMBA_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__WEIM_WEIM_D_1 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__PCIE_CTRL_DIAG_STATUS_BUS_MUX_15 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__GPIO_5_21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__MMDC_MMDC_DEBUG_32 = IOMUX_PAD(0x03AC, 0x0098, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__SIMBA_TRACE_0 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_DISP_CLK__LCDIF_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__LCD_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__MIPI_CORE_DPHY_TEST_OUT_28 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__SDMA_DEBUG_CORE_STATE_0 = IOMUX_PAD(0x03B0, 0x009C, 4, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__GPIO_4_16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__MMDC_MMDC_DEBUG_0 = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__TPSMP_HDATA_DIR = IOMUX_PAD(0x03B0, 0x009C, 7, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__LCDIF_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__LCD_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN15__LCDIF_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUDMUX_AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__LCD_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__MIPI_CORE_DPHY_TEST_OUT_29 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__SDMA_DEBUG_CORE_STATE_1 = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__GPIO_4_17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__PL301_SIM_MX6DL_PER1_HSIZE_0 = IOMUX_PAD(0x03B4, 0x00A0, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__LCDIF_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN2__LCDIF_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), - MX6_PAD_DI0_PIN2__AUDMUX_AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__LCD_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN2__LCD_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), + MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__MIPI_CORE_DPHY_TEST_OUT_30 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__SDMA_DEBUG_CORE_STATE_2 = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__GPIO_4_18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__MMDC_MMDC_DEBUG_2 = IOMUX_PAD(0x03B8, 0x00A4, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__PL301_SIM_MX6DL_PER1_HADDR_9 = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__LCDIF_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN3__LCDIF_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__LCD_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN3__LCD_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__MIPI_CORE_DPHY_TEST_OUT_31 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__SDMA_DEBUG_CORE_STATE_3 = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__GPIO_4_19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__PL301_SIM_MX6DL_PER1_HADDR_10 = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__LCDIF_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN4 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__LCDIF_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), - MX6_PAD_DI0_PIN4__AUDMUX_AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__USDHC1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), + MX6_PAD_DI0_PIN3__LCD_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN4__LCD_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), + MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), MX6_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__PL301_SIM_MX6DL_PER1_HADDR_11 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__LCDIF_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT0__LCDIF_DAT_0 = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__LCD_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT0__LCD_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__USDHC1_USDHC_DEBUG_0 = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__SDMA_DEBUG_CORE_RUN = IOMUX_PAD(0x03C4, 0x00B0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__GPIO_4_21 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__PL301_SIM_MX6DL_PER1_HSIZE_1 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT1__LCDIF_DAT_1 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT1__LCD_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__USDHC1_USDHC_DEBUG_1 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__SDMA_DEBUG_EVENT_CHANNEL_SEL = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__GPIO_4_22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__MMDC_MMDC_DEBUG_6 = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__PL301_SIM_MX6DL_PER1_HADDR_12 = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__LCDIF_DAT_10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__LCD_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT10__USDHC1_USDHC_DEBUG_6 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__SDMA_DEBUG_EVENT_CHANNEL_3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__GPIO_4_31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__MMDC_MMDC_DEBUG_15 = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__PL301_SIM_MX6DL_PER1_HADDR_21 = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__LCDIF_DAT_11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT11__LCD_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__USDHC1_USDHC_DEBUG_7 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__SDMA_DEBUG_EVENT_CHANNEL_4 = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__GPIO_5_5 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__MMDC_MMDC_DEBUG_16 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__PL301_SIM_MX6DL_PER1_HADDR_22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__LCDIF_DAT_12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT12__LCD_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__SDMA_DEBUG_EVENT_CHANNEL_5 = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__GPIO_5_6 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__MMDC_MMDC_DEBUG_17 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__PL301_SIM_MX6DL_PER1_HADDR_23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__LCDIF_DAT_13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT13__LCD_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), MX6_PAD_DISP0_DAT13__SDMA_DEBUG_EVT_CHN_LINES_0 = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__GPIO_5_7 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__MMDC_MMDC_DEBUG_18 = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__PL301_SIM_MX6DL_PER1_HADDR_24 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__LCDIF_DAT_14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT14__LCD_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), MX6_PAD_DISP0_DAT14__SDMA_DEBUG_EVT_CHN_LINES_1 = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__GPIO_5_8 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__MMDC_MMDC_DEBUG_19 = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__PL301_SIM_MX6DL_PER1_HSIZE_2 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__LCDIF_DAT_15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT15__LCD_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x07E8, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0804, 0, 0), MX6_PAD_DISP0_DAT15__SDMA_DEBUG_EVT_CHN_LINES_2 = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__GPIO_5_9 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__MMDC_MMDC_DEBUG_20 = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__PL301_SIM_MX6DL_PER1_HADDR_25 = IOMUX_PAD(0x03E0, 0x00CC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__LCDIF_DAT_16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT16__LCD_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT16__AUDMUX_AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), - MX6_PAD_DISP0_DAT16__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), - MX6_PAD_DISP0_DAT16__GPIO_5_10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), + MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), + MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__MMDC_MMDC_DEBUG_21 = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__PL301_SIM_MX6DL_PER1_HADDR_26 = IOMUX_PAD(0x03E4, 0x00D0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__LCDIF_DAT_17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT17__LCD_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT17__AUDMUX_AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), - MX6_PAD_DISP0_DAT17__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), - MX6_PAD_DISP0_DAT17__GPIO_5_11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), + MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), + MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__MMDC_MMDC_DEBUG_22 = IOMUX_PAD(0x03E8, 0x00D4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__PL301_SIM_MX6DL_PER1_HADDR_27 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__LCDIF_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT18__LCD_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT18__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), - MX6_PAD_DISP0_DAT18__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), - MX6_PAD_DISP0_DAT18__GPIO_5_12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), + MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), + MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__MMDC_MMDC_DEBUG_23 = IOMUX_PAD(0x03EC, 0x00D8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__WEIM_WEIM_CS_2 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__LCDIF_DAT_19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT19__LCD_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT19__AUDMUX_AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), - MX6_PAD_DISP0_DAT19__AUDMUX_AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), - MX6_PAD_DISP0_DAT19__GPIO_5_13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), + MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), + MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__MMDC_MMDC_DEBUG_24 = IOMUX_PAD(0x03F0, 0x00DC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__WEIM_WEIM_CS_3 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT2__LCDIF_DAT_2 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__LCD_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__USDHC1_USDHC_DEBUG_2 = IOMUX_PAD(0x03F4, 0x00E0, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__SDMA_DEBUG_MODE = IOMUX_PAD(0x03F4, 0x00E0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__GPIO_4_23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__MMDC_MMDC_DEBUG_7 = IOMUX_PAD(0x03F4, 0x00E0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__PL301_SIM_MX6DL_PER1_HADDR_13 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__LCDIF_DAT_20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT20__LCD_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x07D8, 1, 0), - MX6_PAD_DISP0_DAT20__AUDMUX_AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), + MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), MX6_PAD_DISP0_DAT20__SDMA_DEBUG_EVT_CHN_LINES_7 = IOMUX_PAD(0x03F8, 0x00E4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__GPIO_5_14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__MMDC_MMDC_DEBUG_25 = IOMUX_PAD(0x03F8, 0x00E4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__PL301_SIM_MX6DL_PER1_HADDR_28 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__LCDIF_DAT_21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT21__LCD_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x07E0, 1, 0), - MX6_PAD_DISP0_DAT21__AUDMUX_AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), + MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), MX6_PAD_DISP0_DAT21__SDMA_DEBUG_BUS_DEVICE_0 = IOMUX_PAD(0x03FC, 0x00E8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__GPIO_5_15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__MMDC_MMDC_DEBUG_26 = IOMUX_PAD(0x03FC, 0x00E8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__PL301_SIM_MX6DL_PER1_HADDR_29 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__LCDIF_DAT_22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT22__LCD_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x00EC, 2, 0x07DC, 1, 0), - MX6_PAD_DISP0_DAT22__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), + MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), MX6_PAD_DISP0_DAT22__SDMA_DEBUG_BUS_DEVICE_1 = IOMUX_PAD(0x0400, 0x00EC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__GPIO_5_16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__MMDC_MMDC_DEBUG_27 = IOMUX_PAD(0x0400, 0x00EC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__PL301_SIM_MX6DL_PER1_HADDR_30 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__LCDIF_DAT_23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT23__LCD_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x07E4, 1, 0), - MX6_PAD_DISP0_DAT23__AUDMUX_AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), + MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), MX6_PAD_DISP0_DAT23__SDMA_DEBUG_BUS_DEVICE_2 = IOMUX_PAD(0x0404, 0x00F0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__GPIO_5_17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__MMDC_MMDC_DEBUG_28 = IOMUX_PAD(0x0404, 0x00F0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__PL301_SIM_MX6DL_PER1_HADDR_31 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT3__LCDIF_DAT_3 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT3__LCD_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0408, 0x00F4, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__USDHC1_USDHC_DEBUG_3 = IOMUX_PAD(0x0408, 0x00F4, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__SDMA_DEBUG_BUS_ERROR = IOMUX_PAD(0x0408, 0x00F4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__GPIO_4_24 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__MMDC_MMDC_DEBUG_8 = IOMUX_PAD(0x0408, 0x00F4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__PL301_SIM_MX6DL_PER1_HADDR_14 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT4__LCDIF_DAT_4 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT4__LCD_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__USDHC1_USDHC_DEBUG_4 = IOMUX_PAD(0x040C, 0x00F8, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x040C, 0x00F8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__GPIO_4_25 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x040C, 0x00F8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__PL301_SIM_MX6DL_PER1_HADDR_15 = IOMUX_PAD(0x040C, 0x00F8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT5__LCDIF_DAT_5 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT5__LCD_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__SDMA_DEBUG_MATCHED_DMBUS = IOMUX_PAD(0x0410, 0x00FC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__GPIO_4_26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__MMDC_MMDC_DEBUG_10 = IOMUX_PAD(0x0410, 0x00FC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__PL301_SIM_MX6DL_PER1_HADDR_16 = IOMUX_PAD(0x0410, 0x00FC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT6__LCDIF_DAT_6 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT6__LCD_DATA06 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x0414, 0x0100, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUDMUX_AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__SDMA_DEBUG_RTBUFFER_WRITE = IOMUX_PAD(0x0414, 0x0100, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__GPIO_4_27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__MMDC_MMDC_DEBUG_11 = IOMUX_PAD(0x0414, 0x0100, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__PL301_SIM_MX6DL_PER1_HADDR_17 = IOMUX_PAD(0x0414, 0x0100, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT7__LCDIF_DAT_7 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT7__LCD_DATA07 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x0418, 0x0104, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__USDHC1_USDHC_DEBUG_5 = IOMUX_PAD(0x0418, 0x0104, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__SDMA_DEBUG_EVENT_CHANNEL_0 = IOMUX_PAD(0x0418, 0x0104, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__GPIO_4_28 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__MMDC_MMDC_DEBUG_12 = IOMUX_PAD(0x0418, 0x0104, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__PL301_SIM_MX6DL_PER1_HADDR_18 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT8__LCDIF_DAT_8 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PWM1_PWMO = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_WDOG_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT8__LCD_DATA08 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__SDMA_DEBUG_EVENT_CHANNEL_1 = IOMUX_PAD(0x041C, 0x0108, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__GPIO_4_29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__MMDC_MMDC_DEBUG_13 = IOMUX_PAD(0x041C, 0x0108, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PL301_SIM_MX6DL_PER1_HADDR_19 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT9__LCDIF_DAT_9 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PWM2_PWMO = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_WDOG_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT9__LCD_DATA09 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__SDMA_DEBUG_EVENT_CHANNEL_2 = IOMUX_PAD(0x0420, 0x010C, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__GPIO_4_30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__MMDC_MMDC_DEBUG_14 = IOMUX_PAD(0x0420, 0x010C, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PL301_SIM_MX6DL_PER1_HADDR_20 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x0424, NO_MUX_I, 0, 0x0000, 0, 0), @@ -516,635 +516,635 @@ enum { MX6_PAD_DRAM_SDQS6__MMDC_DRAM_SDQS_6 = IOMUX_PAD(0x04D4, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS7__MMDC_DRAM_SDQS_7 = IOMUX_PAD(0x04D8, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x04DC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A16__WEIM_WEIM_A_16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x04E0, 0x0110, 1, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x04E0, 0x0110, 2, 0x08B8, 0, 0), MX6_PAD_EIM_A16__MIPI_CORE_DPHY_TEST_OUT_23 = IOMUX_PAD(0x04E0, 0x0110, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A16__GPIO_2_22 = IOMUX_PAD(0x04E0, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x04E0, 0x0110, 5, 0x0000, 0, 0), MX6_PAD_EIM_A16__TPSMP_HDATA_6 = IOMUX_PAD(0x04E0, 0x0110, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A16__SRC_BT_CFG_16 = IOMUX_PAD(0x04E0, 0x0110, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A16__EPDC_SDDO_0 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A17__WEIM_WEIM_A_17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_DISP1_DAT_12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_CSI1_D_12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), + MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x04E0, 0x0110, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A16__EPDC_DATA00 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU1_CSI1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), MX6_PAD_EIM_A17__MIPI_CORE_DPHY_TEST_OUT_22 = IOMUX_PAD(0x04E4, 0x0114, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A17__GPIO_2_21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), MX6_PAD_EIM_A17__TPSMP_HDATA_5 = IOMUX_PAD(0x04E4, 0x0114, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A17__SRC_BT_CFG_17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A17__EPDC_PWRSTAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A18__WEIM_WEIM_A_18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_DISP1_DAT_13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_CSI1_D_13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), + MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A17__EPDC_PWR_STAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU1_CSI1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), MX6_PAD_EIM_A18__MIPI_CORE_DPHY_TEST_OUT_21 = IOMUX_PAD(0x04E8, 0x0118, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A18__GPIO_2_20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), MX6_PAD_EIM_A18__TPSMP_HDATA_4 = IOMUX_PAD(0x04E8, 0x0118, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A18__SRC_BT_CFG_18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A18__EPDC_PWRCTRL_0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A19__WEIM_WEIM_A_19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_DISP1_DAT_14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_CSI1_D_14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), + MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A18__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU1_CSI1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), MX6_PAD_EIM_A19__MIPI_CORE_DPHY_TEST_OUT_20 = IOMUX_PAD(0x04EC, 0x011C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A19__GPIO_2_19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), MX6_PAD_EIM_A19__TPSMP_HDATA_3 = IOMUX_PAD(0x04EC, 0x011C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A19__SRC_BT_CFG_19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A19__EPDC_PWRCTRL_1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A20__WEIM_WEIM_A_20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_DISP1_DAT_15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_CSI1_D_15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), + MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A19__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), MX6_PAD_EIM_A20__MIPI_CORE_DPHY_TEST_OUT_19 = IOMUX_PAD(0x04F0, 0x0120, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A20__GPIO_2_18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), MX6_PAD_EIM_A20__TPSMP_HDATA_2 = IOMUX_PAD(0x04F0, 0x0120, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A20__SRC_BT_CFG_20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A20__EPDC_PWRCTRL_2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A21__WEIM_WEIM_A_21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_DISP1_DAT_16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_CSI1_D_16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), + MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A20__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU1_CSI1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), MX6_PAD_EIM_A21__MIPI_CORE_DPHY_TEST_OUT_18 = IOMUX_PAD(0x04F4, 0x0124, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A21__GPIO_2_17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), MX6_PAD_EIM_A21__TPSMP_HDATA_1 = IOMUX_PAD(0x04F4, 0x0124, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A21__SRC_BT_CFG_21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), MX6_PAD_EIM_A21__EPDC_GDCLK = IOMUX_PAD(0x04F4, 0x0124, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A22__WEIM_WEIM_A_22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_DISP1_DAT_17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_CSI1_D_17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), - MX6_PAD_EIM_A22__GPIO_2_16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU1_CSI1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), + MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), MX6_PAD_EIM_A22__TPSMP_HDATA_0 = IOMUX_PAD(0x04F8, 0x0128, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A22__SRC_BT_CFG_22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), MX6_PAD_EIM_A22__EPDC_GDSP = IOMUX_PAD(0x04F8, 0x0128, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A23__WEIM_WEIM_A_23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_DISP1_DAT_18 = IOMUX_PAD(0x04FC, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_CSI1_D_18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), - MX6_PAD_EIM_A23__IPU1_SISG_3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A23__GPIO_6_6 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_CSI1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), + MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), MX6_PAD_EIM_A23__PL301_SIM_MX6DL_PER1_HPROT_3 = IOMUX_PAD(0x04FC, 0x012C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A23__SRC_BT_CFG_23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), MX6_PAD_EIM_A23__EPDC_GDOE = IOMUX_PAD(0x04FC, 0x012C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A24__WEIM_WEIM_A_24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_DISP1_DAT_19 = IOMUX_PAD(0x0500, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_CSI1_D_19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), - MX6_PAD_EIM_A24__IPU1_SISG_2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A24__GPIO_5_4 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_CSI1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), + MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), MX6_PAD_EIM_A24__PL301_SIM_MX6DL_PER1_HPROT_2 = IOMUX_PAD(0x0500, 0x0130, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A24__SRC_BT_CFG_24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), MX6_PAD_EIM_A24__EPDC_GDRL = IOMUX_PAD(0x0500, 0x0130, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A25__WEIM_WEIM_A_25 = IOMUX_PAD(0x0504, 0x0134, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x0504, 0x0134, 0, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x0504, 0x0134, 1, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x0504, 0x0134, 2, 0x0000, 0, 0), MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x0504, 0x0134, 3, 0x0000, 0, 0), MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x0504, 0x0134, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A25__GPIO_5_2 = IOMUX_PAD(0x0504, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x0504, 0x0134, 5, 0x0000, 0, 0), MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0504, 0x0134, 6, 0x085C, 0, 0), MX6_PAD_EIM_A25__PL301_SIM_MX6DL_PER1_HBURST_0 = IOMUX_PAD(0x0504, 0x0134, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A25__EPDC_SDDO_15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A25__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__WEIM_WEIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EPDC_DATA15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x0508, 0x0138, 1, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__GPIO_6_31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x0508, 0x0138, 6, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EPDC_SDCE_9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__WEIM_WEIM_CS_0 = IOMUX_PAD(0x050C, 0x013C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__IPU1_DI1_PIN5 = IOMUX_PAD(0x050C, 0x013C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EPDC_SDCE9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x050C, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x050C, 0x013C, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x050C, 0x013C, 2, 0x07F4, 2, 0), MX6_PAD_EIM_CS0__MIPI_CORE_DPHY_TEST_OUT_24 = IOMUX_PAD(0x050C, 0x013C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__GPIO_2_23 = IOMUX_PAD(0x050C, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x050C, 0x013C, 5, 0x0000, 0, 0), MX6_PAD_EIM_CS0__TPSMP_HDATA_7 = IOMUX_PAD(0x050C, 0x013C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__EPDC_SDDO_6 = IOMUX_PAD(0x050C, 0x013C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__WEIM_WEIM_CS_1 = IOMUX_PAD(0x0510, 0x0140, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__IPU1_DI1_PIN6 = IOMUX_PAD(0x0510, 0x0140, 1, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__EPDC_DATA06 = IOMUX_PAD(0x050C, 0x013C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0510, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0510, 0x0140, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0510, 0x0140, 2, 0x07FC, 2, 0), MX6_PAD_EIM_CS1__MIPI_CORE_DPHY_TEST_OUT_25 = IOMUX_PAD(0x0510, 0x0140, 4, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__GPIO_2_24 = IOMUX_PAD(0x0510, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0510, 0x0140, 5, 0x0000, 0, 0), MX6_PAD_EIM_CS1__TPSMP_HDATA_8 = IOMUX_PAD(0x0510, 0x0140, 6, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__EPDC_SDDO_8 = IOMUX_PAD(0x0510, 0x0140, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D16__WEIM_WEIM_D_16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__EPDC_DATA08 = IOMUX_PAD(0x0510, 0x0140, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x0514, 0x0144, 1, 0x07D8, 2, 0), - MX6_PAD_EIM_D16__IPU1_DI0_PIN5 = IOMUX_PAD(0x0514, 0x0144, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D16__IPU1_CSI1_D_18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), + MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x0514, 0x0144, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D16__IPU1_CSI1_DATA18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x0514, 0x0144, 4, 0x0864, 0, 0), - MX6_PAD_EIM_D16__GPIO_3_16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0), MX6_PAD_EIM_D16__TPSMP_HTRANS_0 = IOMUX_PAD(0x0514, 0x0144, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D16__EPDC_SDDO_10 = IOMUX_PAD(0x0514, 0x0144, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D17__WEIM_WEIM_D_17 = IOMUX_PAD(0x0518, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D16__EPDC_DATA10 = IOMUX_PAD(0x0514, 0x0144, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x0518, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x0518, 0x0148, 1, 0x07DC, 2, 0), - MX6_PAD_EIM_D17__IPU1_DI0_PIN6 = IOMUX_PAD(0x0518, 0x0148, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D17__IPU1_DI0_PIN06 = IOMUX_PAD(0x0518, 0x0148, 2, 0x0000, 0, 0), MX6_PAD_EIM_D17__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x0518, 0x0148, 3, 0x08B8, 1, 0), - MX6_PAD_EIM_D17__DCIC1_DCIC_OUT = IOMUX_PAD(0x0518, 0x0148, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D17__GPIO_3_17 = IOMUX_PAD(0x0518, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x0518, 0x0148, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x0518, 0x0148, 5, 0x0000, 0, 0), MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0), MX6_PAD_EIM_D17__PL301_SIM_MX6DL_PER1_HBURST_1 = IOMUX_PAD(0x0518, 0x0148, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D17__EPDC_VCOM_0 = IOMUX_PAD(0x0518, 0x0148, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D18__WEIM_WEIM_D_18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D17__EPDC_VCOM0 = IOMUX_PAD(0x0518, 0x0148, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x051C, 0x014C, 1, 0x07E0, 2, 0), - MX6_PAD_EIM_D18__IPU1_DI0_PIN7 = IOMUX_PAD(0x051C, 0x014C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D18__IPU1_CSI1_D_17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), + MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x051C, 0x014C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D18__IPU1_CSI1_DATA17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x051C, 0x014C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D18__GPIO_3_18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0), MX6_PAD_EIM_D18__PL301_SIM_MX6DL_PER1_HBURST_2 = IOMUX_PAD(0x051C, 0x014C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D18__EPDC_VCOM_1 = IOMUX_PAD(0x051C, 0x014C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D19__WEIM_WEIM_D_19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D18__EPDC_VCOM1 = IOMUX_PAD(0x051C, 0x014C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x0520, 0x0150, 1, 0x07E8, 1, 0), - MX6_PAD_EIM_D19__IPU1_DI0_PIN8 = IOMUX_PAD(0x0520, 0x0150, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D19__IPU1_CSI1_D_16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), - MX6_PAD_EIM_D19__UART1_CTS = IOMUX_PAD(0x0520, 0x0150, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D19__UART1_RTS = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), - MX6_PAD_EIM_D19__GPIO_3_19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPIT1_EPITO = IOMUX_PAD(0x0520, 0x0150, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x0520, 0x0150, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D19__IPU1_CSI1_DATA16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), + MX6_PAD_EIM_D19__UART1_CTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), + MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x0520, 0x0150, 6, 0x0000, 0, 0), MX6_PAD_EIM_D19__PL301_SIM_MX6DL_PER1_HRESP = IOMUX_PAD(0x0520, 0x0150, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPDC_SDDO_12 = IOMUX_PAD(0x0520, 0x0150, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D20__WEIM_WEIM_D_20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EPDC_DATA12 = IOMUX_PAD(0x0520, 0x0150, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x0524, 0x0154, 1, 0x0808, 0, 0), MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x0524, 0x0154, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D20__IPU1_CSI1_D_15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), - MX6_PAD_EIM_D20__UART1_CTS = IOMUX_PAD(0x0524, 0x0154, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D20__UART1_RTS = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), - MX6_PAD_EIM_D20__GPIO_3_20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EPIT2_EPITO = IOMUX_PAD(0x0524, 0x0154, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), + MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), + MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x0524, 0x0154, 6, 0x0000, 0, 0), MX6_PAD_EIM_D20__TPSMP_HTRANS_1 = IOMUX_PAD(0x0524, 0x0154, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D21__WEIM_WEIM_D_21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x0528, 0x0158, 1, 0x0000, 0, 0), MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x0528, 0x0158, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_CSI1_D_11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), - MX6_PAD_EIM_D21__USBOH3_USBOTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), - MX6_PAD_EIM_D21__GPIO_3_21 = IOMUX_PAD(0x0528, 0x0158, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D21__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), + MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), + MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x0528, 0x0158, 5, 0x0000, 0, 0), MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0), - MX6_PAD_EIM_D21__SPDIF_IN1 = IOMUX_PAD(0x0528, 0x0158, 7, 0x08F0, 0, 0), - MX6_PAD_EIM_D22__WEIM_WEIM_D_22 = IOMUX_PAD(0x052C, 0x015C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x0528, 0x0158, 7, 0x08F0, 0, 0), + MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x052C, 0x015C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x052C, 0x015C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_DI0_PIN1 = IOMUX_PAD(0x052C, 0x015C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_CSI1_D_10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), - MX6_PAD_EIM_D22__USBOH3_USBOTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D22__GPIO_3_22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D22__SPDIF_OUT1 = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x052C, 0x015C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_CSI1_DATA10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), + MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), MX6_PAD_EIM_D22__PL301_SIM_MX6DL_PER1_HWRITE = IOMUX_PAD(0x052C, 0x015C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D22__EPDC_SDCE_6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D23__WEIM_WEIM_D_23 = IOMUX_PAD(0x0530, 0x0160, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D22__EPDC_SDCE6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x0530, 0x0160, 0, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x0530, 0x0160, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_CTS = IOMUX_PAD(0x0530, 0x0160, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_RTS = IOMUX_PAD(0x0530, 0x0160, 2, 0x0908, 0, 0), - MX6_PAD_EIM_D23__UART1_DCD = IOMUX_PAD(0x0530, 0x0160, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x0530, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x0530, 0x0160, 2, 0x0908, 0, 0), + MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x0530, 0x0160, 3, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x0530, 0x0160, 4, 0x08B0, 0, 0), - MX6_PAD_EIM_D23__GPIO_3_23 = IOMUX_PAD(0x0530, 0x0160, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN2 = IOMUX_PAD(0x0530, 0x0160, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D23__GPIO3_IO23 = IOMUX_PAD(0x0530, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI1_PIN02 = IOMUX_PAD(0x0530, 0x0160, 6, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x0530, 0x0160, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D23__EPDC_SDDO_11 = IOMUX_PAD(0x0530, 0x0160, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D24__WEIM_WEIM_D_24 = IOMUX_PAD(0x0534, 0x0164, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D23__EPDC_DATA11 = IOMUX_PAD(0x0530, 0x0160, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x0534, 0x0164, 0, 0x0000, 0, 0), MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x0534, 0x0164, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_TXD = IOMUX_PAD(0x0534, 0x0164, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_RXD = IOMUX_PAD(0x0534, 0x0164, 2, 0x090C, 0, 0), + MX6_PAD_EIM_D24__UART3_TX_DATA = IOMUX_PAD(0x0534, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D24__UART3_RX_DATA = IOMUX_PAD(0x0534, 0x0164, 2, 0x090C, 0, 0), MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x0534, 0x0164, 3, 0x07EC, 0, 0), MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x0534, 0x0164, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D24__GPIO_3_24 = IOMUX_PAD(0x0534, 0x0164, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), - MX6_PAD_EIM_D24__UART1_DTR = IOMUX_PAD(0x0534, 0x0164, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D24__EPDC_SDCE_7 = IOMUX_PAD(0x0534, 0x0164, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D25__WEIM_WEIM_D_25 = IOMUX_PAD(0x0538, 0x0168, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x0534, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), + MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x0534, 0x0164, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D24__EPDC_SDCE7 = IOMUX_PAD(0x0534, 0x0164, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x0538, 0x0168, 0, 0x0000, 0, 0), MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x0538, 0x0168, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_TXD = IOMUX_PAD(0x0538, 0x0168, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_RXD = IOMUX_PAD(0x0538, 0x0168, 2, 0x090C, 1, 0), + MX6_PAD_EIM_D25__UART3_TX_DATA = IOMUX_PAD(0x0538, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x0538, 0x0168, 2, 0x090C, 1, 0), MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x0538, 0x0168, 3, 0x07F0, 0, 0), MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x0538, 0x0168, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D25__GPIO_3_25 = IOMUX_PAD(0x0538, 0x0168, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUDMUX_AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), - MX6_PAD_EIM_D25__UART1_DSR = IOMUX_PAD(0x0538, 0x0168, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D25__EPDC_SDCE_8 = IOMUX_PAD(0x0538, 0x0168, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D26__WEIM_WEIM_D_26 = IOMUX_PAD(0x053C, 0x016C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x0538, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), + MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x0538, 0x0168, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D25__EPDC_SDCE8 = IOMUX_PAD(0x0538, 0x0168, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x053C, 0x016C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x053C, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_D_1 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI1_D_14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), - MX6_PAD_EIM_D26__UART2_TXD = IOMUX_PAD(0x053C, 0x016C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D26__UART2_RXD = IOMUX_PAD(0x053C, 0x016C, 4, 0x0904, 0, 0), - MX6_PAD_EIM_D26__GPIO_3_26 = IOMUX_PAD(0x053C, 0x016C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_SISG_2 = IOMUX_PAD(0x053C, 0x016C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DISP1_DAT_22 = IOMUX_PAD(0x053C, 0x016C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI1_DATA14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), + MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0904, 0, 0), + MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x053C, 0x016C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_SISG2 = IOMUX_PAD(0x053C, 0x016C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_DISP1_DATA22 = IOMUX_PAD(0x053C, 0x016C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D26__EPDC_SDOED = IOMUX_PAD(0x053C, 0x016C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D27__WEIM_WEIM_D_27 = IOMUX_PAD(0x0540, 0x0170, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x0540, 0x0170, 0, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x0540, 0x0170, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_D_0 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI1_D_13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), - MX6_PAD_EIM_D27__UART2_TXD = IOMUX_PAD(0x0540, 0x0170, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D27__UART2_RXD = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), - MX6_PAD_EIM_D27__GPIO_3_27 = IOMUX_PAD(0x0540, 0x0170, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_SISG_3 = IOMUX_PAD(0x0540, 0x0170, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DISP1_DAT_23 = IOMUX_PAD(0x0540, 0x0170, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI1_DATA13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), + MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), + MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x0540, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x0540, 0x0170, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_DISP1_DATA23 = IOMUX_PAD(0x0540, 0x0170, 7, 0x0000, 0, 0), MX6_PAD_EIM_D27__EPDC_SDOE = IOMUX_PAD(0x0540, 0x0170, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D28__WEIM_WEIM_D_28 = IOMUX_PAD(0x0544, 0x0174, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x0544, 0x0174, 0, 0x0000, 0, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x0544, 0x0174, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_CSI1_D_12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), - MX6_PAD_EIM_D28__UART2_CTS = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D28__UART2_RTS = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), - MX6_PAD_EIM_D28__GPIO_3_28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU1_CSI1_DATA12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), + MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), + MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x0544, 0x0174, 6, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x0544, 0x0174, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D28__EPDC_PWRCTRL_3 = IOMUX_PAD(0x0544, 0x0174, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D29__WEIM_WEIM_D_29 = IOMUX_PAD(0x0548, 0x0178, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D28__EPDC_PWR_CTRL3 = IOMUX_PAD(0x0544, 0x0174, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x0548, 0x0178, 0, 0x0000, 0, 0), MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x0548, 0x0178, 1, 0x0000, 0, 0), MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x0548, 0x0178, 2, 0x0808, 1, 0), - MX6_PAD_EIM_D29__UART2_CTS = IOMUX_PAD(0x0548, 0x0178, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D29__UART2_RTS = IOMUX_PAD(0x0548, 0x0178, 4, 0x0900, 1, 0), - MX6_PAD_EIM_D29__GPIO_3_29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D29__UART2_CTS_B = IOMUX_PAD(0x0548, 0x0178, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D29__UART2_RTS_B = IOMUX_PAD(0x0548, 0x0178, 4, 0x0900, 1, 0), + MX6_PAD_EIM_D29__GPIO3_IO29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), MX6_PAD_EIM_D29__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0548, 0x0178, 6, 0x08BC, 0, 0), MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x0548, 0x0178, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D29__EPDC_PWRWAKE = IOMUX_PAD(0x0548, 0x0178, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D30__WEIM_WEIM_D_30 = IOMUX_PAD(0x054C, 0x017C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DISP1_DAT_21 = IOMUX_PAD(0x054C, 0x017C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D29__EPDC_PWR_WAKE = IOMUX_PAD(0x0548, 0x0178, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x054C, 0x017C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x054C, 0x017C, 1, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x054C, 0x017C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_D_3 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_CTS = IOMUX_PAD(0x054C, 0x017C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_RTS = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), - MX6_PAD_EIM_D30__GPIO_3_30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USBOH3_USBH1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), + MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), + MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), MX6_PAD_EIM_D30__PL301_SIM_MX6DL_PER1_HPROT_0 = IOMUX_PAD(0x054C, 0x017C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D30__EPDC_SDOEZ = IOMUX_PAD(0x054C, 0x017C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D31__WEIM_WEIM_D_31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DISP1_DAT_20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x0550, 0x0180, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_D_2 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_CTS = IOMUX_PAD(0x0550, 0x0180, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_RTS = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), - MX6_PAD_EIM_D31__GPIO_3_31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USBOH3_USBH1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), + MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), MX6_PAD_EIM_D31__PL301_SIM_MX6DL_PER1_HPROT_1 = IOMUX_PAD(0x0550, 0x0180, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D31__EPDC_SDCLK = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D31__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__WEIM_WEIM_DA_A_0 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_DISP1_DAT_9 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_CSI1_D_9 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D31__EPDC_SDCLK_P = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D31__EIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_CSI1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA0__MIPI_CORE_DPHY_TEST_OUT_2 = IOMUX_PAD(0x0554, 0x0184, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__GPIO_3_0 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA0__TPSMP_HDATA_14 = IOMUX_PAD(0x0554, 0x0184, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__SRC_BT_CFG_0 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EPDC_SDCLKN = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__WEIM_WEIM_DA_A_1 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_DISP1_DAT_8 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_CSI1_D_8 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EPDC_SDCLK_N = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_CSI1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA1__MIPI_CORE_DPHY_TEST_OUT_3 = IOMUX_PAD(0x0558, 0x0188, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA1__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0558, 0x0188, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__GPIO_3_1 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA1__TPSMP_HDATA_15 = IOMUX_PAD(0x0558, 0x0188, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__SRC_BT_CFG_1 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA1__EPDC_SDLE = IOMUX_PAD(0x0558, 0x0188, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__WEIM_WEIM_DA_A_10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x055C, 0x018C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x055C, 0x018C, 2, 0x08B0, 1, 0), MX6_PAD_EIM_DA10__MIPI_CORE_DPHY_TEST_OUT_12 = IOMUX_PAD(0x055C, 0x018C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__GPIO_3_10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA10__TPSMP_HDATA_24 = IOMUX_PAD(0x055C, 0x018C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__SRC_BT_CFG_10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EPDC_SDDO_1 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__WEIM_WEIM_DA_A_11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_DI1_PIN2 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EPDC_DATA01 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_CSI1_HSYNC = IOMUX_PAD(0x0560, 0x0190, 2, 0x08B4, 0, 0), MX6_PAD_EIM_DA11__MIPI_CORE_DPHY_TEST_OUT_13 = IOMUX_PAD(0x0560, 0x0190, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA11__SDMA_DEBUG_EVT_CHN_LINES_6 = IOMUX_PAD(0x0560, 0x0190, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__GPIO_3_11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA11__TPSMP_HDATA_25 = IOMUX_PAD(0x0560, 0x0190, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SRC_BT_CFG_11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EPDC_SDDO_3 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__WEIM_WEIM_DA_A_12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_DI1_PIN3 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EPDC_DATA03 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0564, 0x0194, 2, 0x08BC, 1, 0), MX6_PAD_EIM_DA12__MIPI_CORE_DPHY_TEST_OUT_14 = IOMUX_PAD(0x0564, 0x0194, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA12__SDMA_DEBUG_EVT_CHN_LINES_3 = IOMUX_PAD(0x0564, 0x0194, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__GPIO_3_12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA12__TPSMP_HDATA_26 = IOMUX_PAD(0x0564, 0x0194, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SRC_BT_CFG_12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EPDC_SDDO_2 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__WEIM_WEIM_DA_A_13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EPDC_DATA02 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x0568, 0x0198, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA13__CCM_DI1_EXT_CLK = IOMUX_PAD(0x0568, 0x0198, 2, 0x07D0, 0, 0), MX6_PAD_EIM_DA13__MIPI_CORE_DPHY_TEST_OUT_15 = IOMUX_PAD(0x0568, 0x0198, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA13__SDMA_DEBUG_EVT_CHN_LINES_4 = IOMUX_PAD(0x0568, 0x0198, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__GPIO_3_13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA13__TPSMP_HDATA_27 = IOMUX_PAD(0x0568, 0x0198, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SRC_BT_CFG_13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EPDC_SDDO_13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__WEIM_WEIM_DA_A_14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EPDC_DATA13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x056C, 0x019C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA14__CCM_DI0_EXT_CLK = IOMUX_PAD(0x056C, 0x019C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA14__MIPI_CORE_DPHY_TEST_OUT_16 = IOMUX_PAD(0x056C, 0x019C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA14__SDMA_DEBUG_EVT_CHN_LINES_5 = IOMUX_PAD(0x056C, 0x019C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__GPIO_3_14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA14__TPSMP_HDATA_28 = IOMUX_PAD(0x056C, 0x019C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SRC_BT_CFG_14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EPDC_SDDO_14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__WEIM_WEIM_DA_A_15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN1 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN4 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EPDC_DATA14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA15__MIPI_CORE_DPHY_TEST_OUT_17 = IOMUX_PAD(0x0570, 0x01A0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__GPIO_3_15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA15__TPSMP_HDATA_29 = IOMUX_PAD(0x0570, 0x01A0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__SRC_BT_CFG_15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EPDC_SDDO_9 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__WEIM_WEIM_DA_A_2 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_DISP1_DAT_7 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_CSI1_D_7 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EPDC_DATA09 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_CSI1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA2__MIPI_CORE_DPHY_TEST_OUT_4 = IOMUX_PAD(0x0574, 0x01A4, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA2__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x0574, 0x01A4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__GPIO_3_2 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA2__TPSMP_HDATA_16 = IOMUX_PAD(0x0574, 0x01A4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__SRC_BT_CFG_2 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EPDC_BDR_0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__WEIM_WEIM_DA_A_3 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_DISP1_DAT_6 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_CSI1_D_6 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EPDC_BDR0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_CSI1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA3__MIPI_CORE_DPHY_TEST_OUT_5 = IOMUX_PAD(0x0578, 0x01A8, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA3__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x0578, 0x01A8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__GPIO_3_3 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA3__TPSMP_HDATA_17 = IOMUX_PAD(0x0578, 0x01A8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__SRC_BT_CFG_3 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EPDC_BDR_1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__WEIM_WEIM_DA_A_4 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_DISP1_DAT_5 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_CSI1_D_5 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EPDC_BDR1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_CSI1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA4__MIPI_CORE_DPHY_TEST_OUT_6 = IOMUX_PAD(0x057C, 0x01AC, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA4__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x057C, 0x01AC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__GPIO_3_4 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA4__TPSMP_HDATA_18 = IOMUX_PAD(0x057C, 0x01AC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__SRC_BT_CFG_4 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EPDC_SDCE_0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__WEIM_WEIM_DA_A_5 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_DISP1_DAT_4 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_CSI1_D_4 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EPDC_SDCE0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_CSI1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA5__MIPI_CORE_DPHY_TEST_OUT_7 = IOMUX_PAD(0x0580, 0x01B0, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA5__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x0580, 0x01B0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__GPIO_3_5 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA5__TPSMP_HDATA_19 = IOMUX_PAD(0x0580, 0x01B0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__SRC_BT_CFG_5 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EPDC_SDCE_1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__WEIM_WEIM_DA_A_6 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_DISP1_DAT_3 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_CSI1_D_3 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EPDC_SDCE1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_CSI1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA6__MIPI_CORE_DPHY_TEST_OUT_8 = IOMUX_PAD(0x0584, 0x01B4, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA6__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x0584, 0x01B4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__GPIO_3_6 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA6__TPSMP_HDATA_20 = IOMUX_PAD(0x0584, 0x01B4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__SRC_BT_CFG_6 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EPDC_SDCE_2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__WEIM_WEIM_DA_A_7 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_DISP1_DAT_2 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_CSI1_D_2 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EPDC_SDCE2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_CSI1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA7__MIPI_CORE_DPHY_TEST_OUT_9 = IOMUX_PAD(0x0588, 0x01B8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__GPIO_3_7 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA7__TPSMP_HDATA_21 = IOMUX_PAD(0x0588, 0x01B8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__SRC_BT_CFG_7 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EPDC_SDCE_3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__WEIM_WEIM_DA_A_8 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_DISP1_DAT_1 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_CSI1_D_1 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EPDC_SDCE3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_CSI1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA8__MIPI_CORE_DPHY_TEST_OUT_10 = IOMUX_PAD(0x058C, 0x01BC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__GPIO_3_8 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA8__TPSMP_HDATA_22 = IOMUX_PAD(0x058C, 0x01BC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__SRC_BT_CFG_8 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EPDC_SDCE_4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__WEIM_WEIM_DA_A_9 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_DISP1_DAT_0 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_CSI1_D_0 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EPDC_SDCE4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_CSI1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA9__MIPI_CORE_DPHY_TEST_OUT_11 = IOMUX_PAD(0x0590, 0x01C0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__GPIO_3_9 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA9__TPSMP_HDATA_23 = IOMUX_PAD(0x0590, 0x01C0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__SRC_BT_CFG_9 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EPDC_SDCE_5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__WEIM_WEIM_EB_0 = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_DISP1_DAT_11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_CSI1_D_11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), + MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EPDC_SDCE5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), MX6_PAD_EIM_EB0__MIPI_CORE_DPHY_TEST_OUT_0 = IOMUX_PAD(0x0594, 0x01C4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__CCM_PMIC_RDY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), - MX6_PAD_EIM_EB0__GPIO_2_28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), + MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB0__TPSMP_HDATA_12 = IOMUX_PAD(0x0594, 0x01C4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__SRC_BT_CFG_27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__EPDC_PWRCOM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__WEIM_WEIM_EB_1 = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_DISP1_DAT_10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_CSI1_D_10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), + MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__EPDC_PWR_COM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU1_CSI1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), MX6_PAD_EIM_EB1__MIPI_CORE_DPHY_TEST_OUT_1 = IOMUX_PAD(0x0598, 0x01C8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__GPIO_2_29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB1__TPSMP_HDATA_13 = IOMUX_PAD(0x0598, 0x01C8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__SRC_BT_CFG_28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EPDC_SDSHR = IOMUX_PAD(0x0598, 0x01C8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__WEIM_WEIM_EB_2 = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x059C, 0x01CC, 1, 0x07E4, 2, 0), MX6_PAD_EIM_EB2__CCM_DI1_EXT_CLK = IOMUX_PAD(0x059C, 0x01CC, 2, 0x07D0, 1, 0), - MX6_PAD_EIM_EB2__IPU1_CSI1_D_19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), + MX6_PAD_EIM_EB2__IPU1_CSI1_DATA19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x059C, 0x01CC, 4, 0x0860, 0, 0), - MX6_PAD_EIM_EB2__GPIO_2_30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0), - MX6_PAD_EIM_EB2__SRC_BT_CFG_30 = IOMUX_PAD(0x059C, 0x01CC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__EPDC_SDDO_5 = IOMUX_PAD(0x059C, 0x01CC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__WEIM_WEIM_EB_3 = IOMUX_PAD(0x05A0, 0x01D0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__SRC_BOOT_CFG30 = IOMUX_PAD(0x059C, 0x01CC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__EPDC_DATA05 = IOMUX_PAD(0x059C, 0x01CC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x05A0, 0x01D0, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x05A0, 0x01D0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_CTS = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_RTS = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0908, 3, 0), - MX6_PAD_EIM_EB3__UART1_RI = IOMUX_PAD(0x05A0, 0x01D0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_CTS_B = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_RTS_B = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0908, 3, 0), + MX6_PAD_EIM_EB3__UART1_RI_B = IOMUX_PAD(0x05A0, 0x01D0, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB3__IPU1_CSI1_HSYNC = IOMUX_PAD(0x05A0, 0x01D0, 4, 0x08B4, 1, 0), - MX6_PAD_EIM_EB3__GPIO_2_31 = IOMUX_PAD(0x05A0, 0x01D0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU1_DI1_PIN3 = IOMUX_PAD(0x05A0, 0x01D0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__SRC_BT_CFG_31 = IOMUX_PAD(0x05A0, 0x01D0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EPDC_SDCE_0 = IOMUX_PAD(0x05A0, 0x01D0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__WEIM_ACLK_FREERUN = IOMUX_PAD(0x05A0, 0x01D0, 9, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__WEIM_WEIM_LBA = IOMUX_PAD(0x05A4, 0x01D4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__GPIO2_IO31 = IOMUX_PAD(0x05A0, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__IPU1_DI1_PIN03 = IOMUX_PAD(0x05A0, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__SRC_BOOT_CFG31 = IOMUX_PAD(0x05A0, 0x01D0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EPDC_SDCE0 = IOMUX_PAD(0x05A0, 0x01D0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EIM_ACLK_FREERUN = IOMUX_PAD(0x05A0, 0x01D0, 9, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x05A4, 0x01D4, 0, 0x0000, 0, 0), MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x05A4, 0x01D4, 1, 0x0000, 0, 0), MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x05A4, 0x01D4, 2, 0x0804, 1, 0), - MX6_PAD_EIM_LBA__GPIO_2_27 = IOMUX_PAD(0x05A4, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x05A4, 0x01D4, 5, 0x0000, 0, 0), MX6_PAD_EIM_LBA__TPSMP_HDATA_11 = IOMUX_PAD(0x05A4, 0x01D4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__SRC_BT_CFG_26 = IOMUX_PAD(0x05A4, 0x01D4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__EPDC_SDDO_4 = IOMUX_PAD(0x05A4, 0x01D4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_OE__WEIM_WEIM_OE = IOMUX_PAD(0x05A8, 0x01D8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_OE__IPU1_DI1_PIN7 = IOMUX_PAD(0x05A8, 0x01D8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x05A4, 0x01D4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__EPDC_DATA04 = IOMUX_PAD(0x05A4, 0x01D4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x05A8, 0x01D8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x05A8, 0x01D8, 1, 0x0000, 0, 0), MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x05A8, 0x01D8, 2, 0x07F8, 2, 0), MX6_PAD_EIM_OE__MIPI_CORE_DPHY_TEST_OUT_26 = IOMUX_PAD(0x05A8, 0x01D8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_OE__GPIO_2_25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), MX6_PAD_EIM_OE__TPSMP_HDATA_9 = IOMUX_PAD(0x05A8, 0x01D8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_OE__EPDC_PWRIRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_RW__WEIM_WEIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_RW__IPU1_DI1_PIN8 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_OE__EPDC_PWR_IRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x05AC, 0x01DC, 2, 0x0800, 2, 0), MX6_PAD_EIM_RW__MIPI_CORE_DPHY_TEST_OUT_27 = IOMUX_PAD(0x05AC, 0x01DC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_RW__GPIO_2_26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), MX6_PAD_EIM_RW__TPSMP_HDATA_10 = IOMUX_PAD(0x05AC, 0x01DC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_RW__SRC_BT_CFG_29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EPDC_SDDO_7 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__WEIM_WEIM_WAIT = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__WEIM_WEIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__GPIO_5_0 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EPDC_DATA07 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__TPSMP_HDATA_30 = IOMUX_PAD(0x05B0, 0x01E0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__SRC_BT_CFG_25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x05B4, 0x01E4, 1, 0x0828, 0, 0), - MX6_PAD_ENET_CRS_DV__ESAI1_SCKT = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), - MX6_PAD_ENET_CRS_DV__SPDIF_SPDIF_EXTCLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), - MX6_PAD_ENET_CRS_DV__GPIO_1_25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), + MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), + MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__PHY_TDO = IOMUX_PAD(0x05B4, 0x01E4, 6, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x05B4, 0x01E4, 7, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__MLB_MLBDAT = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), + MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ESAI1_TX5_RX0 = IOMUX_PAD(0x05B8, 0x01E8, 2, 0x0858, 0, 0), + MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x05B8, 0x01E8, 2, 0x0858, 0, 0), MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x05B8, 0x01E8, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__GPIO_1_31 = IOMUX_PAD(0x05B8, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x05B8, 0x01E8, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05B8, 0x01E8, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), - MX6_PAD_ENET_MDIO__ESAI1_SCKR = IOMUX_PAD(0x05BC, 0x01EC, 2, 0x083C, 0, 0), + MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x05BC, 0x01EC, 2, 0x083C, 0, 0), MX6_PAD_ENET_MDIO__SDMA_DEBUG_BUS_DEVICE_3 = IOMUX_PAD(0x05BC, 0x01EC, 3, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x05BC, 0x01EC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__GPIO_1_22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__SPDIF_PLOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ESAI1_FSR = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), + MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), MX6_PAD_ENET_REF_CLK__SDMA_DEBUG_BUS_DEVICE_4 = IOMUX_PAD(0x05C0, 0x01F0, 3, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__GPIO_1_23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__SPDIF_SRCLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x05C0, 0x01F0, 7, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ANATOP_USBOTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), + MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x05C4, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI1_HCKR = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), - MX6_PAD_ENET_RX_ER__SPDIF_IN1 = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), + MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), + MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__GPIO_1_24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__PHY_TDI = IOMUX_PAD(0x05C4, 0x01F4, 6, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x05C4, 0x01F4, 7, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__OSC32K_32K_OUT = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ENET_RDATA_0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), - MX6_PAD_ENET_RXD0__ESAI1_HCKT = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), - MX6_PAD_ENET_RXD0__SPDIF_OUT1 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__GPIO_1_27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), + MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), + MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__PHY_TMS = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x05C8, 0x01F8, 7, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__MLB_MLBSIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), - MX6_PAD_ENET_RXD1__ENET_RDATA_1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), - MX6_PAD_ENET_RXD1__ESAI1_FST = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), + MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), + MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__GPIO_1_26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__PHY_TCK = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05CC, 0x01FC, 7, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ESAI1_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), - MX6_PAD_ENET_TX_EN__GPIO_1_28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), + MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x05D0, 0x0200, 7, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__I2C4_SCL = IOMUX_PAD(0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0), - MX6_PAD_ENET_TXD0__ENET_TDATA_0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI1_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), - MX6_PAD_ENET_TXD0__GPIO_1_30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), + MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x05D4, 0x0204, 7, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__MLB_MLBCLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), - MX6_PAD_ENET_TXD1__ENET_TDATA_1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI1_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), + MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__GPIO_1_29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x05D8, 0x0208, 7, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__I2C4_SDA = IOMUX_PAD(0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0), - MX6_PAD_GPIO_0__CCM_CLKO = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), - MX6_PAD_GPIO_0__KPP_COL_5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), - MX6_PAD_GPIO_0__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), - MX6_PAD_GPIO_0__EPIT1_EPITO = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_0__GPIO_1_0 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USBOH3_USBH1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_HP_WRAPPER_SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_1__ESAI1_SCKR = IOMUX_PAD(0x05E0, 0x0210, 0, 0x083C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_WDOG_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_1__KPP_ROW_5 = IOMUX_PAD(0x05E0, 0x0210, 2, 0x08CC, 1, 0), + MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), + MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), + MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), + MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05E0, 0x0210, 0, 0x083C, 1, 0), + MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05E0, 0x0210, 2, 0x08CC, 1, 0), MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0790, 1, 0), - MX6_PAD_GPIO_1__PWM2_PWMO = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_1__GPIO_1_1 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_1__USDHC1_CD = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), MX6_PAD_GPIO_1__SRC_TESTER_ACK = IOMUX_PAD(0x05E0, 0x0210, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ESAI1_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), + MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x05E4, 0x0214, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_ANATOP_ETHERNET_REF_OUT = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), - MX6_PAD_GPIO_16__USDHC1_LCTL = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_16__SPDIF_IN1 = IOMUX_PAD(0x05E4, 0x0214, 4, 0x08F0, 2, 0), - MX6_PAD_GPIO_16__GPIO_7_11 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), + MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x05E4, 0x0214, 4, 0x08F0, 2, 0), + MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), MX6_PAD_GPIO_16__I2C3_SDA = IOMUX_PAD(0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0), - MX6_PAD_GPIO_16__SJC_DE_B = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_17__ESAI1_TX0 = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0844, 0, 0), + MX6_PAD_GPIO_16__JTAG_DE_B = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_17__ESAI_TX0 = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0844, 0, 0), MX6_PAD_GPIO_17__ENET_1588_EVENT3_IN = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_17__CCM_PMIC_RDY = IOMUX_PAD(0x05E8, 0x0218, 2, 0x07D4, 1, 0), - MX6_PAD_GPIO_17__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x08E8, 1, 0), - MX6_PAD_GPIO_17__SPDIF_OUT1 = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_17__GPIO_7_12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_17__CCM_PMIC_READY = IOMUX_PAD(0x05E8, 0x0218, 2, 0x07D4, 1, 0), + MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x08E8, 1, 0), + MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), MX6_PAD_GPIO_17__SJC_JTAG_ACT = IOMUX_PAD(0x05E8, 0x0218, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_18__ESAI1_TX1 = IOMUX_PAD(0x05EC, 0x021C, 0, 0x0848, 0, 0), + MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x05EC, 0x021C, 0, 0x0848, 0, 0), MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0814, 0, 0), - MX6_PAD_GPIO_18__USDHC3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x08EC, 1, 0), - MX6_PAD_GPIO_18__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), - MX6_PAD_GPIO_18__GPIO_7_13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_HP_WRAPPER_SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x08EC, 1, 0), + MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), + MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), MX6_PAD_GPIO_18__SRC_SYSTEM_RST = IOMUX_PAD(0x05EC, 0x021C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_19__KPP_COL_5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), + MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x05F0, 0x0220, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SPDIF_OUT1 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_19__CCM_CLKO = IOMUX_PAD(0x05F0, 0x0220, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_19__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 3, 0x0000, 0, 0), MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_19__GPIO_4_5 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), MX6_PAD_GPIO_19__SRC_INT_BOOT = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_2__ESAI1_FST = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), + MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), MX6_PAD_GPIO_2__OBSERVE_MUX_OBSRV_INT_OUT2 = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_2__KPP_ROW_6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), + MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), MX6_PAD_GPIO_2__CCM_CCM_OUT_1 = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), MX6_PAD_GPIO_2__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_2__GPIO_1_2 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__USDHC2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_2__MLB_MLBDAT = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), - MX6_PAD_GPIO_3__ESAI1_HCKR = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), + MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), + MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), MX6_PAD_GPIO_3__OBSERVE_MUX_OBSRV_INT_OUT0 = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0), - MX6_PAD_GPIO_3__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_3__GPIO_1_3 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_3__USBOH3_USBH1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), - MX6_PAD_GPIO_3__MLB_MLBCLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), - MX6_PAD_GPIO_4__ESAI1_HCKT = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), + MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), + MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), + MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), MX6_PAD_GPIO_4__OBSERVE_MUX_OBSRV_INT_OUT3 = IOMUX_PAD(0x05FC, 0x022C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_4__KPP_COL_7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), + MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), MX6_PAD_GPIO_4__CCM_CCM_OUT_2 = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), MX6_PAD_GPIO_4__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_4__GPIO_1_4 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_4__USDHC2_CD = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0000, 0, 0), MX6_PAD_GPIO_4__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_5__ESAI1_TX2_RX3 = IOMUX_PAD(0x0600, 0x0230, 0, 0x084C, 1, 0), + MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x0600, 0x0230, 0, 0x084C, 1, 0), MX6_PAD_GPIO_5__OBSERVE_MUX_OBSRV_INT_OUT4 = IOMUX_PAD(0x0600, 0x0230, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_5__KPP_ROW_7 = IOMUX_PAD(0x0600, 0x0230, 2, 0x08D4, 1, 0), - MX6_PAD_GPIO_5__CCM_CLKO = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x0600, 0x0230, 2, 0x08D4, 1, 0), + MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), MX6_PAD_GPIO_5__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x0600, 0x0230, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_5__GPIO_1_5 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0), - MX6_PAD_GPIO_5__SIMBA_EVENTI = IOMUX_PAD(0x0600, 0x0230, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_6__ESAI1_SCKT = IOMUX_PAD(0x0604, 0x0234, 0, 0x0840, 1, 0), + MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x0600, 0x0230, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0604, 0x0234, 0, 0x0840, 1, 0), MX6_PAD_GPIO_6__OBSERVE_MUX_OBSRV_INT_OUT1 = IOMUX_PAD(0x0604, 0x0234, 1, 0x0000, 0, 0), MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0), MX6_PAD_GPIO_6__CCM_CCM_OUT_0 = IOMUX_PAD(0x0604, 0x0234, 3, 0x0000, 0, 0), MX6_PAD_GPIO_6__CSU_CSU_INT_DEB = IOMUX_PAD(0x0604, 0x0234, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_6__GPIO_1_6 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_6__USDHC2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_MLBSIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), - MX6_PAD_GPIO_7__ESAI1_TX4_RX1 = IOMUX_PAD(0x0608, 0x0238, 0, 0x0854, 1, 0), - MX6_PAD_GPIO_7__EPIT1_EPITO = IOMUX_PAD(0x0608, 0x0238, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_7__CAN1_TXCAN = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_TXD = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_RXD = IOMUX_PAD(0x0608, 0x0238, 4, 0x0904, 2, 0), - MX6_PAD_GPIO_7__GPIO_1_7 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_7__SPDIF_PLOCK = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_7__USBOH3_OTGUSB_HOST_MODE = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), + MX6_PAD_GPIO_7__ESAI_TX4_RX1 = IOMUX_PAD(0x0608, 0x0238, 0, 0x0854, 1, 0), + MX6_PAD_GPIO_7__EPIT1_OUT = IOMUX_PAD(0x0608, 0x0238, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_7__FLEXCAN1_TX = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_TX_DATA = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_RX_DATA = IOMUX_PAD(0x0608, 0x0238, 4, 0x0904, 2, 0), + MX6_PAD_GPIO_7__GPIO1_IO07 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_7__SPDIF_LOCK = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_7__USB_OTG_HOST_MODE = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), MX6_PAD_GPIO_7__I2C4_SCL = IOMUX_PAD(0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0), - MX6_PAD_GPIO_8__ESAI1_TX5_RX0 = IOMUX_PAD(0x060C, 0x023C, 0, 0x0858, 1, 0), - MX6_PAD_GPIO_8__ANATOP_ANATOP_32K_OUT = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_8__EPIT2_EPITO = IOMUX_PAD(0x060C, 0x023C, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_8__CAN1_RXCAN = IOMUX_PAD(0x060C, 0x023C, 3, 0x07C8, 0, 0), - MX6_PAD_GPIO_8__UART2_TXD = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_8__UART2_RXD = IOMUX_PAD(0x060C, 0x023C, 4, 0x0904, 3, 0), - MX6_PAD_GPIO_8__GPIO_1_8 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_8__SPDIF_SRCLK = IOMUX_PAD(0x060C, 0x023C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_8__USBOH3_OTGUSB_PWRCTL_WAKEUP = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_8__ESAI_TX5_RX0 = IOMUX_PAD(0x060C, 0x023C, 0, 0x0858, 1, 0), + MX6_PAD_GPIO_8__XTALOSC_REF_CLK_32K = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_8__EPIT2_OUT = IOMUX_PAD(0x060C, 0x023C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_8__FLEXCAN1_RX = IOMUX_PAD(0x060C, 0x023C, 3, 0x07C8, 0, 0), + MX6_PAD_GPIO_8__UART2_TX_DATA = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_8__UART2_RX_DATA = IOMUX_PAD(0x060C, 0x023C, 4, 0x0904, 3, 0), + MX6_PAD_GPIO_8__GPIO1_IO08 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_8__SPDIF_SR_CLK = IOMUX_PAD(0x060C, 0x023C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_8__I2C4_SDA = IOMUX_PAD(0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0), - MX6_PAD_GPIO_9__ESAI1_FSR = IOMUX_PAD(0x0610, 0x0240, 0, 0x082C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_WDOG_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_9__KPP_COL_6 = IOMUX_PAD(0x0610, 0x0240, 2, 0x08C4, 1, 0), + MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x0610, 0x0240, 0, 0x082C, 1, 0), + MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x0610, 0x0240, 2, 0x08C4, 1, 0), MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_9__PWM1_PWMO = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_9__GPIO_1_9 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__USDHC1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), + MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), MX6_PAD_GPIO_9__SRC_EARLY_RST = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x0614, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0618, NO_MUX_I, 0, 0x0000, 0, 0), @@ -1153,89 +1153,89 @@ enum { MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x0624, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_JTAG_TRSTB__SJC_TRSTB = IOMUX_PAD(0x0628, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x062C, 0x0244, 0, 0x07D8, 3, 0), - MX6_PAD_KEY_COL0__ENET_RDATA_3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), - MX6_PAD_KEY_COL0__AUDMUX_AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), - MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x062C, 0x0244, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_TXD = IOMUX_PAD(0x062C, 0x0244, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_RXD = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), - MX6_PAD_KEY_COL0__GPIO_4_6 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_DCIC_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), + MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), + MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x062C, 0x0244, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), + MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL0__SRC_ANY_PU_RST = IOMUX_PAD(0x062C, 0x0244, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x0630, 0x0248, 0, 0x07DC, 3, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x0630, 0x0248, 1, 0x0810, 1, 0), - MX6_PAD_KEY_COL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), - MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x0630, 0x0248, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_TXD = IOMUX_PAD(0x0630, 0x0248, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_RXD = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), - MX6_PAD_KEY_COL1__GPIO_4_8 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__USDHC1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), + MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x0630, 0x0248, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), + MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL1__PL301_SIM_MX6DL_PER1_HADDR_1 = IOMUX_PAD(0x0630, 0x0248, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x0634, 0x024C, 0, 0x07E8, 2, 0), - MX6_PAD_KEY_COL2__ENET_RDATA_2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), - MX6_PAD_KEY_COL2__CAN1_TXCAN = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x0634, 0x024C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), + MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__KEY_COL2 = IOMUX_PAD(0x0634, 0x024C, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x0634, 0x024C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__GPIO_4_10 = IOMUX_PAD(0x0634, 0x024C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__USBOH3_H1USB_PWRCTL_WAKEUP = IOMUX_PAD(0x0634, 0x024C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x0634, 0x024C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x0634, 0x024C, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL2__PL301_SIM_MX6DL_PER1_HADDR_3 = IOMUX_PAD(0x0634, 0x024C, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x0638, 0x0250, 0, 0x07F0, 1, 0), MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x0638, 0x0250, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x0638, 0x0250, 2, 0x0860, 1, 0), - MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x0638, 0x0250, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__KEY_COL3 = IOMUX_PAD(0x0638, 0x0250, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0), - MX6_PAD_KEY_COL3__GPIO_4_12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__SPDIF_IN1 = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), + MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), MX6_PAD_KEY_COL3__PL301_SIM_MX6DL_PER1_HADDR_5 = IOMUX_PAD(0x0638, 0x0250, 7, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__CAN2_TXCAN = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__IPU1_SISG_4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USBOH3_USBOTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), - MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x063C, 0x0254, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_CTS = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_RTS = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), - MX6_PAD_KEY_COL4__GPIO_4_14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), + MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x063C, 0x0254, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), + MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL4__MMDC_MMDC_DEBUG_49 = IOMUX_PAD(0x063C, 0x0254, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL4__PL301_SIM_MX6DL_PER1_HADDR_7 = IOMUX_PAD(0x063C, 0x0254, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0640, 0x0258, 0, 0x07E0, 3, 0), - MX6_PAD_KEY_ROW0__ENET_TDATA_3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUDMUX_AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), - MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x0640, 0x0258, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_TXD = IOMUX_PAD(0x0640, 0x0258, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_RXD = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), - MX6_PAD_KEY_ROW0__GPIO_4_7 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_DCIC_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), + MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x0640, 0x0258, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), + MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__PL301_SIM_MX6DL_PER1_HADDR_0 = IOMUX_PAD(0x0640, 0x0258, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x025C, 0, 0x07E4, 3, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x0644, 0x025C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), - MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x0644, 0x025C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_TXD = IOMUX_PAD(0x0644, 0x025C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_RXD = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), - MX6_PAD_KEY_ROW1__GPIO_4_9 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__USDHC2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), + MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x0644, 0x025C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), + MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__PL301_SIM_MX6DL_PER1_HADDR_2 = IOMUX_PAD(0x0644, 0x025C, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x0648, 0x0260, 0, 0x07EC, 1, 0), - MX6_PAD_KEY_ROW2__ENET_TDATA_2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__CAN1_RXCAN = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), - MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x0648, 0x0260, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__USDHC2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__GPIO_4_11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), + MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x0648, 0x0260, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0648, 0x0260, 6, 0x085C, 1, 0), MX6_PAD_KEY_ROW2__PL301_SIM_MX6DL_PER1_HADDR_4 = IOMUX_PAD(0x0648, 0x0260, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__OSC32K_32K_OUT = IOMUX_PAD(0x064C, 0x0264, 0, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), + MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x064C, 0x0264, 2, 0x0864, 1, 0), - MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), - MX6_PAD_KEY_ROW3__GPIO_4_13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__USDHC1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__PL301_SIM_MX6DL_PER1_HADDR_6 = IOMUX_PAD(0x064C, 0x0264, 7, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__CAN2_RXCAN = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), - MX6_PAD_KEY_ROW4__IPU1_SISG_5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USBOH3_USBOTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x0650, 0x0268, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_CTS = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_RTS = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), - MX6_PAD_KEY_ROW4__GPIO_4_15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), + MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x0650, 0x0268, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), + MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__MMDC_MMDC_DEBUG_50 = IOMUX_PAD(0x0650, 0x0268, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__PL301_SIM_MX6DL_PER1_HADDR_8 = IOMUX_PAD(0x0650, 0x0268, 7, 0x0000, 0, 0), MX6_PAD_LVDS0_CLK_P__LDB_LVDS0_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), @@ -1248,117 +1248,117 @@ enum { MX6_PAD_LVDS1_TX1_P__LDB_LVDS1_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_LVDS1_TX2_P__LDB_LVDS1_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_LVDS1_TX3_P__LDB_LVDS1_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__RAWNAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USDHC4_RST = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_0 = IOMUX_PAD(0x0654, 0x026C, 2, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__USBOH3_UH3_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__USBOH3_UH2_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__GPIO_6_8 = IOMUX_PAD(0x0654, 0x026C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x0654, 0x026C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__MIPI_CORE_DPHY_TEST_IN_24 = IOMUX_PAD(0x0654, 0x026C, 6, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__USDHC3_CLKI = IOMUX_PAD(0x0654, 0x026C, 8, 0x0934, 0, 0), - MX6_PAD_NANDF_CLE__RAWNAND_CLE = IOMUX_PAD(0x0658, 0x0270, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x0658, 0x0270, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_31 = IOMUX_PAD(0x0658, 0x0270, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__USBOH3_UH3_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__USBOH3_UH2_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__GPIO_6_7 = IOMUX_PAD(0x0658, 0x0270, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x0658, 0x0270, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__MIPI_CORE_DPHY_TEST_IN_23 = IOMUX_PAD(0x0658, 0x0270, 6, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__USDHC3_CLKO = IOMUX_PAD(0x0658, 0x0270, 8, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__RAWNAND_CE0N = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__USBOH3_UH3_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__USBOH3_UH2_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__GPIO_6_11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__USDHC1_CLKO = IOMUX_PAD(0x065C, 0x0274, 8, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__RAWNAND_CE1N = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__USDHC4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__USDHC3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_3 = IOMUX_PAD(0x0660, 0x0278, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__GPIO_6_14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__PL301_SIM_MX6DL_PER1_HREADYOUT = IOMUX_PAD(0x0660, 0x0278, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__USDHC1_CLKI = IOMUX_PAD(0x0660, 0x0278, 8, 0x0928, 0, 0), - MX6_PAD_NANDF_CS2__RAWNAND_CE2N = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU1_SISG_0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__ESAI1_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), - MX6_PAD_NANDF_CS2__WEIM_WEIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), + MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x0664, 0x027C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__GPIO_6_15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__USDHC2_CLKO = IOMUX_PAD(0x0664, 0x027C, 8, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__RAWNAND_CE3N = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU1_SISG_1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__ESAI1_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), - MX6_PAD_NANDF_CS3__WEIM_WEIM_A_26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), + MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_4 = IOMUX_PAD(0x0668, 0x0280, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__GPIO_6_16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__TPSMP_CLK = IOMUX_PAD(0x0668, 0x0280, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__USDHC2_CLKI = IOMUX_PAD(0x0668, 0x0280, 8, 0x0930, 0, 0), MX6_PAD_NANDF_CS3__I2C4_SDA = IOMUX_PAD(0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0), - MX6_PAD_NANDF_D0__RAWNAND_D0 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USDHC1_DAT4 = IOMUX_PAD(0x066C, 0x0284, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x066C, 0x0284, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D0__GPU3D_GPU_DEBUG_OUT_0 = IOMUX_PAD(0x066C, 0x0284, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D0__USBOH3_UH2_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D0__USBOH3_UH3_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPIO_2_0 = IOMUX_PAD(0x066C, 0x0284, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x066C, 0x0284, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D0__IPU1_IPU_DIAG_BUS_0 = IOMUX_PAD(0x066C, 0x0284, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__RAWNAND_D1 = IOMUX_PAD(0x0670, 0x0288, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USDHC1_DAT5 = IOMUX_PAD(0x0670, 0x0288, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x0670, 0x0288, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x0670, 0x0288, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D1__GPU3D_GPU_DEBUG_OUT_1 = IOMUX_PAD(0x0670, 0x0288, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D1__USBOH3_UH2_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D1__USBOH3_UH3_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPIO_2_1 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D1__IPU1_IPU_DIAG_BUS_1 = IOMUX_PAD(0x0670, 0x0288, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__RAWNAND_D2 = IOMUX_PAD(0x0674, 0x028C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USDHC1_DAT6 = IOMUX_PAD(0x0674, 0x028C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x0674, 0x028C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x0674, 0x028C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D2__GPU3D_GPU_DEBUG_OUT_2 = IOMUX_PAD(0x0674, 0x028C, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D2__USBOH3_UH2_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D2__USBOH3_UH3_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPIO_2_2 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D2__IPU1_IPU_DIAG_BUS_2 = IOMUX_PAD(0x0674, 0x028C, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__RAWNAND_D3 = IOMUX_PAD(0x0678, 0x0290, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USDHC1_DAT7 = IOMUX_PAD(0x0678, 0x0290, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x0678, 0x0290, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x0678, 0x0290, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D3__GPU3D_GPU_DEBUG_OUT_3 = IOMUX_PAD(0x0678, 0x0290, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D3__USBOH3_UH2_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D3__USBOH3_UH3_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPIO_2_3 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D3__IPU1_IPU_DIAG_BUS_3 = IOMUX_PAD(0x0678, 0x0290, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__RAWNAND_D4 = IOMUX_PAD(0x067C, 0x0294, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USDHC2_DAT4 = IOMUX_PAD(0x067C, 0x0294, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x067C, 0x0294, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x067C, 0x0294, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D4__GPU3D_GPU_DEBUG_OUT_4 = IOMUX_PAD(0x067C, 0x0294, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D4__USBOH3_UH2_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D4__USBOH3_UH3_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPIO_2_4 = IOMUX_PAD(0x067C, 0x0294, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x067C, 0x0294, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D4__IPU1_IPU_DIAG_BUS_4 = IOMUX_PAD(0x067C, 0x0294, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__RAWNAND_D5 = IOMUX_PAD(0x0680, 0x0298, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USDHC2_DAT5 = IOMUX_PAD(0x0680, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x0680, 0x0298, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x0680, 0x0298, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D5__GPU3D_GPU_DEBUG_OUT_5 = IOMUX_PAD(0x0680, 0x0298, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D5__USBOH3_UH2_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D5__USBOH3_UH3_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPIO_2_5 = IOMUX_PAD(0x0680, 0x0298, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x0680, 0x0298, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D5__IPU1_IPU_DIAG_BUS_5 = IOMUX_PAD(0x0680, 0x0298, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__RAWNAND_D6 = IOMUX_PAD(0x0684, 0x029C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USDHC2_DAT6 = IOMUX_PAD(0x0684, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x0684, 0x029C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x0684, 0x029C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D6__GPU3D_GPU_DEBUG_OUT_6 = IOMUX_PAD(0x0684, 0x029C, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D6__USBOH3_UH2_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D6__USBOH3_UH3_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPIO_2_6 = IOMUX_PAD(0x0684, 0x029C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x0684, 0x029C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D6__IPU1_IPU_DIAG_BUS_6 = IOMUX_PAD(0x0684, 0x029C, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__RAWNAND_D7 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USDHC2_DAT7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D7__GPU3D_GPU_DEBUG_OUT_7 = IOMUX_PAD(0x0688, 0x02A0, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D7__USBOH3_UH2_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D7__USBOH3_UH3_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPIO_2_7 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D7__IPU1_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0688, 0x02A0, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__RAWNAND_READY0 = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_2 = IOMUX_PAD(0x068C, 0x02A4, 2, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__USBOH3_UH3_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 3, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__USBOH3_UH2_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__GPIO_6_10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__MIPI_CORE_DPHY_TEST_OUT_33 = IOMUX_PAD(0x068C, 0x02A4, 6, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__USDHC4_CLKI = IOMUX_PAD(0x068C, 0x02A4, 8, 0x0938, 0, 0), - MX6_PAD_NANDF_WP_B__RAWNAND_RESETN = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__PCIE_CTRL_DIAG_STATUS_BUS_MUX_1 = IOMUX_PAD(0x0690, 0x02A8, 2, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USBOH3_UH3_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 3, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USBOH3_UH2_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__GPIO_6_9 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__MIPI_CORE_DPHY_TEST_OUT_32 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USDHC4_CLKO = IOMUX_PAD(0x0690, 0x02A8, 8, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), @@ -1366,305 +1366,305 @@ enum { MX6_PAD_PMIC_STBY_REQ__CCM_PMIC_VSTBY_REQ = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_POR_B__SRC_POR_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__MIPI_HSI_CTRL_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), - MX6_PAD_RGMII_RD0__GPIO_6_25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), + MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__MIPI_CORE_DPHY_TEST_IN_6 = IOMUX_PAD(0x0694, 0x02AC, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__MIPI_HSI_CTRL_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), - MX6_PAD_RGMII_RD1__GPIO_6_27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), + MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__MIPI_CORE_DPHY_TEST_IN_8 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__SJC_FAIL = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__MIPI_HSI_CTRL_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), - MX6_PAD_RGMII_RD2__GPIO_6_28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), + MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__MIPI_CORE_DPHY_TEST_IN_9 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__MIPI_HSI_CTRL_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), - MX6_PAD_RGMII_RD3__GPIO_6_29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), + MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__MIPI_CORE_DPHY_TEST_IN_10 = IOMUX_PAD(0x06A0, 0x02B8, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__USBOH3_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0828, 1, 0), - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__MIPI_CORE_DPHY_TEST_IN_5 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE_START = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), - MX6_PAD_RGMII_RXC__GPIO_6_30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), + MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), + MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__MIPI_CORE_DPHY_TEST_IN_11 = IOMUX_PAD(0x06A8, 0x02C0, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__MIPI_HSI_CTRL_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__GPIO_6_20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__MIPI_CORE_DPHY_TEST_IN_1 = IOMUX_PAD(0x06AC, 0x02C4, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__MIPI_HSI_CTRL_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__GPIO_6_21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__MIPI_CORE_DPHY_TEST_IN_2 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__CCM_PLL3_BYP = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__MIPI_HSI_CTRL_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__GPIO_6_22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__MIPI_CORE_DPHY_TEST_IN_3 = IOMUX_PAD(0x06B4, 0x02CC, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__CCM_PLL2_BYP = IOMUX_PAD(0x06B4, 0x02CC, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__MIPI_HSI_CTRL_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__GPIO_6_23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__MIPI_CORE_DPHY_TEST_IN_4 = IOMUX_PAD(0x06B8, 0x02D0, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE_START = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), + MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__GPIO_6_26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__MIPI_CORE_DPHY_TEST_IN_7 = IOMUX_PAD(0x06BC, 0x02D4, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__ENET_ANATOP_ETHERNET_REF_OUT = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), - MX6_PAD_RGMII_TXC__USBOH3_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__SPDIF_SPDIF_EXTCLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), - MX6_PAD_RGMII_TXC__GPIO_6_19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), + MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), + MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__MIPI_CORE_DPHY_TEST_IN_0 = IOMUX_PAD(0x06C0, 0x02D8, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), + MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), MX6_PAD_SD1_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x06C4, 0x02DC, 2, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__GPIO_1_20 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), MX6_PAD_SD1_CLK__PHY_DTB_0 = IOMUX_PAD(0x06C4, 0x02DC, 6, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__PWM4_PWMO = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPT_CMPOUT1 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPIO_1_18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), MX6_PAD_SD1_CMD__ANATOP_ANATOP_TESTO_5 = IOMUX_PAD(0x06C8, 0x02E0, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__USDHC1_DAT0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__CAAM_WRAPPER_RNG_OSC_OBS = IOMUX_PAD(0x06CC, 0x02E4, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPT_CAPIN1 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_8 = IOMUX_PAD(0x06CC, 0x02E4, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPIO_1_16 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__HDMI_TX_OPHYDTB_1 = IOMUX_PAD(0x06CC, 0x02E4, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__ANATOP_ANATOP_TESTO_7 = IOMUX_PAD(0x06CC, 0x02E4, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__USDHC1_DAT1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__PWM3_PWMO = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPT_CAPIN2 = IOMUX_PAD(0x06D0, 0x02E8, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x06D0, 0x02E8, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_7 = IOMUX_PAD(0x06D0, 0x02E8, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPIO_1_17 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__HDMI_TX_OPHYDTB_0 = IOMUX_PAD(0x06D0, 0x02E8, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__ANATOP_ANATOP_TESTO_8 = IOMUX_PAD(0x06D0, 0x02E8, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__USDHC1_DAT2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPT_CMPOUT2 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__PWM2_PWMO = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_WDOG_B = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPIO_1_19 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__PWM2_OUT = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__ANATOP_ANATOP_TESTO_4 = IOMUX_PAD(0x06D4, 0x02EC, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__USDHC1_DAT3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPT_CMPOUT3 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__PWM1_PWMO = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_WDOG_B = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPIO_1_21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__PWM1_OUT = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__ANATOP_ANATOP_TESTO_6 = IOMUX_PAD(0x06D8, 0x02F0, 7, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), - MX6_PAD_SD2_CLK__KPP_COL_5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), - MX6_PAD_SD2_CLK__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), + MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), + MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), + MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), MX6_PAD_SD2_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_9 = IOMUX_PAD(0x06DC, 0x02F4, 4, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__GPIO_1_10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), MX6_PAD_SD2_CLK__PHY_DTB_1 = IOMUX_PAD(0x06DC, 0x02F4, 6, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__KPP_ROW_5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), - MX6_PAD_SD2_CMD__AUDMUX_AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), + MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), + MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), MX6_PAD_SD2_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_10 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__GPIO_1_11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__USDHC2_DAT0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__AUDMUX_AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), - MX6_PAD_SD2_DAT0__KPP_ROW_7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), - MX6_PAD_SD2_DAT0__GPIO_1_15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_DCIC_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), + MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), + MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__ANATOP_ANATOP_TESTO_2 = IOMUX_PAD(0x06E4, 0x02FC, 7, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__WEIM_WEIM_CS_2 = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), - MX6_PAD_SD2_DAT1__KPP_COL_7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), - MX6_PAD_SD2_DAT1__GPIO_1_14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), + MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), + MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__CCM_WAIT = IOMUX_PAD(0x06E8, 0x0300, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__ANATOP_ANATOP_TESTO_0 = IOMUX_PAD(0x06E8, 0x0300, 7, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__USDHC2_DAT2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__WEIM_WEIM_CS_3 = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUDMUX_AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), - MX6_PAD_SD2_DAT2__KPP_ROW_6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), - MX6_PAD_SD2_DAT2__GPIO_1_13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), + MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), + MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__CCM_STOP = IOMUX_PAD(0x06EC, 0x0304, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__ANATOP_ANATOP_TESTO_1 = IOMUX_PAD(0x06EC, 0x0304, 7, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__USDHC2_DAT3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__KPP_COL_6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), - MX6_PAD_SD2_DAT3__AUDMUX_AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), + MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), + MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), MX6_PAD_SD2_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_11 = IOMUX_PAD(0x06F0, 0x0308, 4, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__GPIO_1_12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SJC_DONE = IOMUX_PAD(0x06F0, 0x0308, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__ANATOP_ANATOP_TESTO_3 = IOMUX_PAD(0x06F0, 0x0308, 7, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), - MX6_PAD_SD3_CLK__UART2_CTS = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_RTS = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0900, 2, 0), - MX6_PAD_SD3_CLK__CAN1_RXCAN = IOMUX_PAD(0x06F4, 0x030C, 2, 0x07C8, 2, 0), + MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), + MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0900, 2, 0), + MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06F4, 0x030C, 2, 0x07C8, 2, 0), MX6_PAD_SD3_CLK__USBOH3_UH3_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 3, 0x0000, 0, 0), MX6_PAD_SD3_CLK__USBOH3_UH2_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 4, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__GPIO_7_3 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_TEST_IN_17 = IOMUX_PAD(0x06F4, 0x030C, 6, 0x0000, 0, 0), MX6_PAD_SD3_CLK__ANATOP_ANATOP_TESTO_14 = IOMUX_PAD(0x06F4, 0x030C, 7, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_CTS = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_RTS = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0900, 3, 0), - MX6_PAD_SD3_CMD__CAN1_TXCAN = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0900, 3, 0), + MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 3, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USBOH3_UH2_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 4, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__GPIO_7_2 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), MX6_PAD_SD3_CMD__MIPI_CORE_DPHY_TEST_IN_16 = IOMUX_PAD(0x06F8, 0x0310, 6, 0x0000, 0, 0), MX6_PAD_SD3_CMD__ANATOP_ANATOP_TESTO_13 = IOMUX_PAD(0x06F8, 0x0310, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_CTS = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_RTS = IOMUX_PAD(0x06FC, 0x0314, 1, 0x08F8, 2, 0), - MX6_PAD_SD3_DAT0__CAN2_TXCAN = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x08F8, 2, 0), + MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USBOH3_UH2_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__GPIO_7_4 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__MIPI_CORE_DPHY_TEST_IN_18 = IOMUX_PAD(0x06FC, 0x0314, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__ANATOP_ANATOP_TESTO_15 = IOMUX_PAD(0x06FC, 0x0314, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_CTS = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_RTS = IOMUX_PAD(0x0700, 0x0318, 1, 0x08F8, 3, 0), - MX6_PAD_SD3_DAT1__CAN2_RXCAN = IOMUX_PAD(0x0700, 0x0318, 2, 0x07CC, 1, 0), + MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x08F8, 3, 0), + MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x0700, 0x0318, 2, 0x07CC, 1, 0), MX6_PAD_SD3_DAT1__USBOH3_UH3_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__USBOH3_UH2_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__GPIO_7_5 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__MIPI_CORE_DPHY_TEST_IN_19 = IOMUX_PAD(0x0700, 0x0318, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__ANATOP_ANATOP_TESTI_0 = IOMUX_PAD(0x0700, 0x0318, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__PCIE_CTRL_DIAG_STATUS_BUS_MUX_28 = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__USBOH3_UH3_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__USBOH3_UH2_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__GPIO_7_6 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_TEST_IN_20 = IOMUX_PAD(0x0704, 0x031C, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__ANATOP_ANATOP_TESTI_1 = IOMUX_PAD(0x0704, 0x031C, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_CTS = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_RTS = IOMUX_PAD(0x0708, 0x0320, 1, 0x0908, 4, 0), + MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0908, 4, 0), MX6_PAD_SD3_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_29 = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USBOH3_UH2_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__GPIO_7_7 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__MIPI_CORE_DPHY_TEST_IN_21 = IOMUX_PAD(0x0708, 0x0320, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__ANATOP_ANATOP_TESTI_2 = IOMUX_PAD(0x0708, 0x0320, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USDHC3_DAT4 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_TXD = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_RXD = IOMUX_PAD(0x070C, 0x0324, 1, 0x0904, 4, 0), + MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0904, 4, 0), MX6_PAD_SD3_DAT4__PCIE_CTRL_DIAG_STATUS_BUS_MUX_27 = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__USBOH3_UH2_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__GPIO_7_1 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_TEST_IN_15 = IOMUX_PAD(0x070C, 0x0324, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__ANATOP_ANATOP_TESTO_12 = IOMUX_PAD(0x070C, 0x0324, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USDHC3_DAT5 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_TXD = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_RXD = IOMUX_PAD(0x0710, 0x0328, 1, 0x0904, 5, 0), + MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0904, 5, 0), MX6_PAD_SD3_DAT5__PCIE_CTRL_DIAG_STATUS_BUS_MUX_26 = IOMUX_PAD(0x0710, 0x0328, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__USBOH3_UH3_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__USBOH3_UH2_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__GPIO_7_0 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_TEST_IN_14 = IOMUX_PAD(0x0710, 0x0328, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__ANATOP_ANATOP_TESTO_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USDHC3_DAT6 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_TXD = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_RXD = IOMUX_PAD(0x0714, 0x032C, 1, 0x08FC, 2, 0), + MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x08FC, 2, 0), MX6_PAD_SD3_DAT6__PCIE_CTRL_DIAG_STATUS_BUS_MUX_25 = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__USBOH3_UH2_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__GPIO_6_18 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__MIPI_CORE_DPHY_TEST_IN_13 = IOMUX_PAD(0x0714, 0x032C, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__ANATOP_ANATOP_TESTO_10 = IOMUX_PAD(0x0714, 0x032C, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USDHC3_DAT7 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_TXD = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_RXD = IOMUX_PAD(0x0718, 0x0330, 1, 0x08FC, 3, 0), + MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x08FC, 3, 0), MX6_PAD_SD3_DAT7__PCIE_CTRL_DIAG_STATUS_BUS_MUX_24 = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBOH3_UH3_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBOH3_UH2_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__GPIO_6_17 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_TEST_IN_12 = IOMUX_PAD(0x0718, 0x0330, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USDHC3_RST = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_CTS = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_RTS = IOMUX_PAD(0x071C, 0x0334, 1, 0x0908, 5, 0), + MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0908, 5, 0), MX6_PAD_SD3_RST__PCIE_CTRL_DIAG_STATUS_BUS_MUX_30 = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), MX6_PAD_SD3_RST__USBOH3_UH3_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), MX6_PAD_SD3_RST__USBOH3_UH2_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0), - MX6_PAD_SD3_RST__GPIO_7_8 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), + MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), MX6_PAD_SD3_RST__MIPI_CORE_DPHY_TEST_IN_22 = IOMUX_PAD(0x071C, 0x0334, 6, 0x0000, 0, 0), MX6_PAD_SD3_RST__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x071C, 0x0334, 7, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__USDHC4_CLK = IOMUX_PAD(0x0720, 0x0338, 0, 0x0938, 1, 0), - MX6_PAD_SD4_CLK__RAWNAND_WRN = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_TXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_RXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x090C, 2, 0), + MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x0720, 0x0338, 0, 0x0938, 1, 0), + MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x090C, 2, 0), MX6_PAD_SD4_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_6 = IOMUX_PAD(0x0720, 0x0338, 4, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__GPIO_7_10 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__USDHC4_CMD = IOMUX_PAD(0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__RAWNAND_RDN = IOMUX_PAD(0x0724, 0x033C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_TXD = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_RXD = IOMUX_PAD(0x0724, 0x033C, 2, 0x090C, 3, 0), + MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x0724, 0x033C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x090C, 3, 0), MX6_PAD_SD4_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_5 = IOMUX_PAD(0x0724, 0x033C, 4, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__GPIO_7_9 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__RAWNAND_D8 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 = IOMUX_PAD(0x0728, 0x0340, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__RAWNAND_DQS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0728, 0x0340, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__USBOH3_UH2_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__USBOH3_UH3_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__GPIO_2_8 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__IPU1_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0728, 0x0340, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__RAWNAND_D9 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__PWM3_PWMO = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__USBOH3_UH2_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__USBOH3_UH3_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__GPIO_2_9 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__IPU1_IPU_DIAG_BUS_9 = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__RAWNAND_D10 = IOMUX_PAD(0x0730, 0x0348, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 = IOMUX_PAD(0x0730, 0x0348, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__PWM4_PWMO = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x0730, 0x0348, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__USBOH3_UH2_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__USBOH3_UH3_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__GPIO_2_10 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__IPU1_IPU_DIAG_BUS_10 = IOMUX_PAD(0x0730, 0x0348, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__RAWNAND_D11 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__USBOH3_UH2_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__USBOH3_UH3_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__GPIO_2_11 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__IPU1_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__USDHC4_DAT4 = IOMUX_PAD(0x0738, 0x0350, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_TXD = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_RXD = IOMUX_PAD(0x0738, 0x0350, 2, 0x0904, 6, 0), + MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0738, 0x0350, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0904, 6, 0), MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__GPIO_2_12 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__IPU1_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0738, 0x0350, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__RAWNAND_D13 = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__USDHC4_DAT5 = IOMUX_PAD(0x073C, 0x0354, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_CTS = IOMUX_PAD(0x073C, 0x0354, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_RTS = IOMUX_PAD(0x073C, 0x0354, 2, 0x0900, 4, 0), + MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x073C, 0x0354, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0900, 4, 0), MX6_PAD_SD4_DAT5__USBOH3_UH2_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__USBOH3_UH3_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__GPIO_2_13 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__IPU1_IPU_DIAG_BUS_13 = IOMUX_PAD(0x073C, 0x0354, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x0740, 0x0358, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__USDHC4_DAT6 = IOMUX_PAD(0x0740, 0x0358, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_CTS = IOMUX_PAD(0x0740, 0x0358, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_RTS = IOMUX_PAD(0x0740, 0x0358, 2, 0x0900, 5, 0), + MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x0740, 0x0358, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0900, 5, 0), MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__GPIO_2_14 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__IPU1_IPU_DIAG_BUS_14 = IOMUX_PAD(0x0740, 0x0358, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__RAWNAND_D15 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__USDHC4_DAT7 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_TXD = IOMUX_PAD(0x0744, 0x035C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_RXD = IOMUX_PAD(0x0744, 0x035C, 2, 0x0904, 7, 0), + MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0904, 7, 0), MX6_PAD_SD4_DAT7__USBOH3_UH2_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__USBOH3_UH3_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__GPIO_2_15 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__IPU1_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0744, 0x035C, 6, 0x0000, 0, 0), }; #endif /* __ASM_ARCH_MX6_MX6DL_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index fe9a8c3..a85a5fd 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -12,772 +12,772 @@ #include <asm/imx-common/iomux-v3.h>
enum { - MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0360, 0x004C, 1, 0x0834, 0, 0), - MX6_PAD_SD2_DAT1__WEIM_WEIM_CS_2 = IOMUX_PAD(0x0360, 0x004C, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), - MX6_PAD_SD2_DAT1__KPP_COL_7 = IOMUX_PAD(0x0360, 0x004C, 4, 0x08F0, 0, 0), - MX6_PAD_SD2_DAT1__GPIO_1_14 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x0360, 0x004C, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), + MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x0360, 0x004C, 4, 0x08F0, 0, 0), + MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__CCM_WAIT = IOMUX_PAD(0x0360, 0x004C, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__ANATOP_TESTO_0 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__USDHC2_DAT2 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0364, 0x0050, 1, 0x0838, 0, 0), - MX6_PAD_SD2_DAT2__WEIM_WEIM_CS_3 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), - MX6_PAD_SD2_DAT2__KPP_ROW_6 = IOMUX_PAD(0x0364, 0x0050, 4, 0x08F8, 0, 0), - MX6_PAD_SD2_DAT2__GPIO_1_13 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), + MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x0364, 0x0050, 4, 0x08F8, 0, 0), + MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__CCM_STOP = IOMUX_PAD(0x0364, 0x0050, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__ANATOP_TESTO_1 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__USDHC2_DAT0 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0368, 0x0054, 1, 0x082C, 0, 0), - MX6_PAD_SD2_DAT0__AUDMUX_AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), - MX6_PAD_SD2_DAT0__KPP_ROW_7 = IOMUX_PAD(0x0368, 0x0054, 4, 0x08FC, 0, 0), - MX6_PAD_SD2_DAT0__GPIO_1_15 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_DCIC_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), + MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x0368, 0x0054, 4, 0x08FC, 0, 0), + MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__TESTO_2 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__USBOH3_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__SPDIF_SPDIF_EXTCLK = IOMUX_PAD(0x036C, 0x0058, 2, 0x0918, 0, 0), - MX6_PAD_RGMII_TXC__GPIO_6_19 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x036C, 0x0058, 2, 0x0918, 0, 0), + MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__MIPI_CORE_DPHY_IN_0 = IOMUX_PAD(0x036C, 0x0058, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__ANATOP_24M_OUT = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__MIPI_HSI_CRL_TX_RDY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__GPIO_6_20 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__MIPI_CORE_DPHY_IN_1 = IOMUX_PAD(0x0370, 0x005C, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__MIPI_HSI_CRL_RX_FLG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__GPIO_6_21 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__MIPI_CORE_DPHY_IN_2 = IOMUX_PAD(0x0374, 0x0060, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__CCM_PLL3_BYP = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__MIPI_HSI_CRL_RX_DTA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__GPIO_6_22 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__MIPI_CORE_DPHY_IN_3 = IOMUX_PAD(0x0378, 0x0064, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__CCM_PLL2_BYP = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__MIPI_HSI_CRL_RX_WAK = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__GPIO_6_23 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__MIPI_CORE_DPHY_IN_4 = IOMUX_PAD(0x037C, 0x0068, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__USBOH3_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x0380, 0x006C, 1, 0x0858, 0, 0), - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__MIPI_DPHY_IN_5 = IOMUX_PAD(0x0380, 0x006C, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__MIPI_HSI_CRL_RX_RDY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), - MX6_PAD_RGMII_RD0__GPIO_6_25 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), + MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__MIPI_CORE_DPHY_IN_6 = IOMUX_PAD(0x0384, 0x0070, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__GPIO_6_26 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__CORE_DPHY_IN_7 = IOMUX_PAD(0x0388, 0x0074, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__ANATOP_REF_OUT = IOMUX_PAD(0x0388, 0x0074, 7, 0x083C, 0, 0), - MX6_PAD_RGMII_RD1__MIPI_HSI_CTRL_TX_FL = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), - MX6_PAD_RGMII_RD1__GPIO_6_27 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x0388, 0x0074, 7, 0x083C, 0, 0), + MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), + MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__CORE_DPHY_TEST_IN_8 = IOMUX_PAD(0x038C, 0x0078, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__SJC_FAIL = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__MIPI_HSI_CRL_TX_DTA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), - MX6_PAD_RGMII_RD2__GPIO_6_28 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), + MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__MIPI_CORE_DPHY_IN_9 = IOMUX_PAD(0x0390, 0x007C, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__MIPI_HSI_CRL_TX_WAK = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), - MX6_PAD_RGMII_RD3__GPIO_6_29 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), + MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__MIPI_CORE_DPHY_IN10 = IOMUX_PAD(0x0394, 0x0080, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), - MX6_PAD_RGMII_RXC__GPIO_6_30 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), + MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__MIPI_CORE_DPHY_IN11 = IOMUX_PAD(0x0398, 0x0084, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A25__WEIM_WEIM_A_25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x039C, 0x0088, 2, 0x0000, 0, 0), MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x039C, 0x0088, 3, 0x0000, 0, 0), MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x039C, 0x0088, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A25__GPIO_5_2 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x039C, 0x0088, 6, 0x088C, 0, 0), MX6_PAD_EIM_A25__PL301_PER1_HBURST_0 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__WEIM_WEIM_EB_2 = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0800, 0, 0), MX6_PAD_EIM_EB2__CCM_DI1_EXT_CLK = IOMUX_PAD(0x03A0, 0x008C, 2, 0x07EC, 0, 0), - MX6_PAD_EIM_EB2__IPU2_CSI1_D_19 = IOMUX_PAD(0x03A0, 0x008C, 3, 0x08D4, 0, 0), + MX6_PAD_EIM_EB2__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03A0, 0x008C, 3, 0x08D4, 0, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0890, 0, 0), - MX6_PAD_EIM_EB2__GPIO_2_30 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x03A0, 0x008C, 22, 0x08A0, 0, 0), - MX6_PAD_EIM_EB2__SRC_BT_CFG_30 = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D16__WEIM_WEIM_D_16 = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__SRC_BOOT_CFG30 = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x03A4, 0x0090, 1, 0x07F4, 0, 0), - MX6_PAD_EIM_D16__IPU1_DI0_PIN5 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D16__IPU2_CSI1_D_18 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x08D0, 0, 0), + MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D16__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x08D0, 0, 0), MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0894, 0, 0), - MX6_PAD_EIM_D16__GPIO_3_16 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0090, 22, 0x08A4, 0, 0), - MX6_PAD_EIM_D17__WEIM_WEIM_D_17 = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x03A8, 0x0094, 1, 0x07F8, 0, 0), - MX6_PAD_EIM_D17__IPU1_DI0_PIN6 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D17__IPU1_DI0_PIN06 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), MX6_PAD_EIM_D17__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 3, 0x08E0, 0, 0), - MX6_PAD_EIM_D17__DCIC1_DCIC_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D17__GPIO_3_17 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x03A8, 0x0094, 22, 0x08A8, 0, 0), MX6_PAD_EIM_D17__PL301_PER1_HBURST_1 = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D18__WEIM_WEIM_D_18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x0098, 1, 0x07FC, 0, 0), - MX6_PAD_EIM_D18__IPU1_DI0_PIN7 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D18__IPU2_CSI1_D_17 = IOMUX_PAD(0x03AC, 0x0098, 3, 0x08CC, 0, 0), + MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D18__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03AC, 0x0098, 3, 0x08CC, 0, 0), MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D18__GPIO_3_18 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x03AC, 0x0098, 22, 0x08AC, 0, 0), MX6_PAD_EIM_D18__PL301_PER1_HBURST_2 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D19__WEIM_WEIM_D_19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0804, 0, 0), - MX6_PAD_EIM_D19__IPU1_DI0_PIN8 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D19__IPU2_CSI1_D_16 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x08C8, 0, 0), - MX6_PAD_EIM_D19__UART1_CTS = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), - MX6_PAD_EIM_D19__GPIO_3_19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPIT1_EPITO = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D19__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x08C8, 0, 0), + MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), + MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), MX6_PAD_EIM_D19__PL301MX6QPER1_HRESP = IOMUX_PAD(0x03B0, 0x009C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D20__WEIM_WEIM_D_20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0824, 0, 0), MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D20__IPU2_CSI1_D_15 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x08C4, 0, 0), - MX6_PAD_EIM_D20__UART1_CTS = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D20__UART1_RTS = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x091C, 1, 0), - MX6_PAD_EIM_D20__GPIO_3_20 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EPIT2_EPITO = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D21__WEIM_WEIM_D_21 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x08C4, 0, 0), + MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x091C, 1, 0), + MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x0000, 0, 0), MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU2_CSI1_D_11 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x08B4, 0, 0), - MX6_PAD_EIM_D21__USBOH3_USBOTG_OC = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0944, 0, 0), - MX6_PAD_EIM_D21__GPIO_3_21 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D21__IPU2_CSI1_DATA11 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x08B4, 0, 0), + MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0944, 0, 0), + MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x03B8, 0x00A4, 22, 0x0898, 0, 0), - MX6_PAD_EIM_D21__SPDIF_IN1 = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0914, 0, 0), - MX6_PAD_EIM_D22__WEIM_WEIM_D_22 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0914, 0, 0), + MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_DI0_PIN1 = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU2_CSI1_D_10 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x08B0, 0, 0), - MX6_PAD_EIM_D22__USBOH3_USBOTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D22__GPIO_3_22 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D22__SPDIF_OUT1 = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU2_CSI1_DATA10 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x08B0, 0, 0), + MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), MX6_PAD_EIM_D22__PL301MX6QPER1_HWRITE = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D23__WEIM_WEIM_D_23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_CTS = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x092C, 0, 0), - MX6_PAD_EIM_D23__UART1_DCD = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x092C, 0, 0), + MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x08D8, 0, 0), - MX6_PAD_EIM_D23__GPIO_3_23 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN2 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D23__GPIO3_IO23 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI1_PIN02 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__WEIM_WEIM_EB_3 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_CTS = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_RTS = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x092C, 1, 0), - MX6_PAD_EIM_EB3__UART1_RI = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_CTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_RTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x092C, 1, 0), + MX6_PAD_EIM_EB3__UART1_RI_B = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB3__IPU2_CSI1_HSYNC = IOMUX_PAD(0x03C4, 0x00B0, 4, 0x08DC, 0, 0), - MX6_PAD_EIM_EB3__GPIO_2_31 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU1_DI1_PIN3 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__SRC_BT_CFG_31 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D24__WEIM_WEIM_D_24 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__GPIO2_IO31 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__IPU1_DI1_PIN03 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__SRC_BOOT_CFG31 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_TXD = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_TXD_RXD = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0930, 0, 0), + MX6_PAD_EIM_D24__UART3_TX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D24__UART3_RX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0930, 0, 0), MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0808, 0, 0), MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D24__GPIO_3_24 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x07D8, 0, 0), - MX6_PAD_EIM_D24__UART1_DTR = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D25__WEIM_WEIM_D_25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x07D8, 0, 0), + MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_RXD = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0930, 1, 0), + MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0930, 1, 0), MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x080C, 0, 0), MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D25__GPIO_3_25 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x07D4, 0, 0), - MX6_PAD_EIM_D25__UART1_DSR = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D26__WEIM_WEIM_D_26 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x07D4, 0, 0), + MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_D_1 = IOMUX_PAD(0x03D0, 0x00BC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU2_CSI1_D_14 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x08C0, 0, 0), - MX6_PAD_EIM_D26__UART2_TXD = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D26__UART2_TXD_RXD = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0928, 0, 0), - MX6_PAD_EIM_D26__GPIO_3_26 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_SISG_2 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DISP1_DAT_22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D27__WEIM_WEIM_D_27 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x03D0, 0x00BC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x08C0, 0, 0), + MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0928, 0, 0), + MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_SISG2 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_DISP1_DATA22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_D_0 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU2_CSI1_D_13 = IOMUX_PAD(0x03D4, 0x00C0, 3, 0x08BC, 0, 0), - MX6_PAD_EIM_D27__UART2_RXD = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0928, 1, 0), - MX6_PAD_EIM_D27__GPIO_3_27 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_SISG_3 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DISP1_DAT_23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D28__WEIM_WEIM_D_28 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU2_CSI1_DATA13 = IOMUX_PAD(0x03D4, 0x00C0, 3, 0x08BC, 0, 0), + MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0928, 1, 0), + MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_DISP1_DATA23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x03D8, 0x00C4, 17, 0x089C, 0, 0), MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x03D8, 0x00C4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU2_CSI1_D_12 = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x08B8, 0, 0), - MX6_PAD_EIM_D28__UART2_CTS = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), - MX6_PAD_EIM_D28__GPIO_3_28 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU2_CSI1_DATA12 = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x08B8, 0, 0), + MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), + MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D29__WEIM_WEIM_D_29 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x03DC, 0x00C8, 2, 0x0824, 1, 0), - MX6_PAD_EIM_D29__UART2_CTS = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D29__UART2_RTS = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0924, 1, 0), - MX6_PAD_EIM_D29__GPIO_3_29 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D29__UART2_CTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D29__UART2_RTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0924, 1, 0), + MX6_PAD_EIM_D29__GPIO3_IO29 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), MX6_PAD_EIM_D29__IPU2_CSI1_VSYNC = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x08E4, 0, 0), MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D30__WEIM_WEIM_D_30 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DISP1_DAT_21 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_D_3 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_CTS = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), - MX6_PAD_EIM_D30__GPIO_3_30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USBOH3_USBH1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), + MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), + MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), MX6_PAD_EIM_D30__PL301MX6QPER1_HPROT_0 = IOMUX_PAD(0x03E0, 0x00CC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D31__WEIM_WEIM_D_31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DISP1_DAT_20 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_D_2 = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_CTS = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_RTS = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x092C, 3, 0), - MX6_PAD_EIM_D31__GPIO_3_31 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USBOH3_USBH1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x092C, 3, 0), + MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), MX6_PAD_EIM_D31__PL301MX6QPER1_HPROT_1 = IOMUX_PAD(0x03E4, 0x00D0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A24__WEIM_WEIM_A_24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_DISP1_DAT_19 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU2_CSI1_D_19 = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x08D4, 1, 0), - MX6_PAD_EIM_A24__IPU2_SISG_2 = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_SISG_2 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A24__GPIO_5_4 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x08D4, 1, 0), + MX6_PAD_EIM_A24__IPU2_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A24__PL301MX6QPER1_HPROT_2 = IOMUX_PAD(0x03E8, 0x00D4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A24__SRC_BT_CFG_24 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A23__WEIM_WEIM_A_23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_DISP1_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU2_CSI1_D_18 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x08D0, 1, 0), - MX6_PAD_EIM_A23__IPU2_SISG_3 = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_SISG_3 = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A23__GPIO_6_6 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x08D0, 1, 0), + MX6_PAD_EIM_A23__IPU2_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), MX6_PAD_EIM_A23__PL301MX6QPER1_HPROT_3 = IOMUX_PAD(0x03EC, 0x00D8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A23__SRC_BT_CFG_23 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A22__WEIM_WEIM_A_22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_DISP1_DAT_17 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU2_CSI1_D_17 = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x08CC, 1, 0), - MX6_PAD_EIM_A22__GPIO_2_16 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x08CC, 1, 0), + MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), MX6_PAD_EIM_A22__TPSMP_HDATA_0 = IOMUX_PAD(0x03F0, 0x00DC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A22__SRC_BT_CFG_22 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A21__WEIM_WEIM_A_21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_DISP1_DAT_16 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU2_CSI1_D_16 = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x08C8, 1, 0), + MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x08C8, 1, 0), MX6_PAD_EIM_A21__RESERVED_RESERVED = IOMUX_PAD(0x03F4, 0x00E0, 3, 0x0000, 0, 0), MX6_PAD_EIM_A21__MIPI_CORE_DPHY_OUT_18 = IOMUX_PAD(0x03F4, 0x00E0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A21__GPIO_2_17 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), MX6_PAD_EIM_A21__TPSMP_HDATA_1 = IOMUX_PAD(0x03F4, 0x00E0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A21__SRC_BT_CFG_21 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A20__WEIM_WEIM_A_20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_DISP1_DAT_15 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU2_CSI1_D_15 = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x08C4, 1, 0), + MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x08C4, 1, 0), MX6_PAD_EIM_A20__RESERVED_RESERVED = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x0000, 0, 0), MX6_PAD_EIM_A20__MIPI_CORE_DPHY_OUT_19 = IOMUX_PAD(0x03F8, 0x00E4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A20__GPIO_2_18 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A20__TPSMP_HDATA_2 = IOMUX_PAD(0x03F8, 0x00E4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A20__SRC_BT_CFG_20 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A19__WEIM_WEIM_A_19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_DISP1_DAT_14 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU2_CSI1_D_14 = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x08C0, 1, 0), + MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x08C0, 1, 0), MX6_PAD_EIM_A19__RESERVED_RESERVED = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x0000, 0, 0), MX6_PAD_EIM_A19__MIPI_CORE_DPHY_OUT_20 = IOMUX_PAD(0x03FC, 0x00E8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A19__GPIO_2_19 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), MX6_PAD_EIM_A19__TPSMP_HDATA_3 = IOMUX_PAD(0x03FC, 0x00E8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A19__SRC_BT_CFG_19 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A18__WEIM_WEIM_A_18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_DISP1_DAT_13 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU2_CSI1_D_13 = IOMUX_PAD(0x0400, 0x00EC, 2, 0x08BC, 1, 0), + MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU2_CSI1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 2, 0x08BC, 1, 0), MX6_PAD_EIM_A18__RESERVED_RESERVED = IOMUX_PAD(0x0400, 0x00EC, 3, 0x0000, 0, 0), MX6_PAD_EIM_A18__MIPI_CORE_DPHY_OUT_21 = IOMUX_PAD(0x0400, 0x00EC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A18__GPIO_2_20 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), MX6_PAD_EIM_A18__TPSMP_HDATA_4 = IOMUX_PAD(0x0400, 0x00EC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A18__SRC_BT_CFG_18 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A17__WEIM_WEIM_A_17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_DISP1_DAT_12 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU2_CSI1_D_12 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x08B8, 1, 0), + MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU2_CSI1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x08B8, 1, 0), MX6_PAD_EIM_A17__RESERVED_RESERVED = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0000, 0, 0), MX6_PAD_EIM_A17__MIPI_CORE_DPHY_OUT_22 = IOMUX_PAD(0x0404, 0x00F0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A17__GPIO_2_21 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), MX6_PAD_EIM_A17__TPSMP_HDATA_5 = IOMUX_PAD(0x0404, 0x00F0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A17__SRC_BT_CFG_17 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A16__WEIM_WEIM_A_16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x0408, 0x00F4, 2, 0x08E0, 1, 0), MX6_PAD_EIM_A16__MIPI_CORE_DPHY_OUT_23 = IOMUX_PAD(0x0408, 0x00F4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A16__GPIO_2_22 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A16__TPSMP_HDATA_6 = IOMUX_PAD(0x0408, 0x00F4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A16__SRC_BT_CFG_16 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__WEIM_WEIM_CS_0 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__IPU1_DI1_PIN5 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0810, 0, 0), MX6_PAD_EIM_CS0__MIPI_CORE_DPHY_OUT_24 = IOMUX_PAD(0x040C, 0x00F8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__GPIO_2_23 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), MX6_PAD_EIM_CS0__TPSMP_HDATA_7 = IOMUX_PAD(0x040C, 0x00F8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__WEIM_WEIM_CS_1 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__IPU1_DI1_PIN6 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0818, 0, 0), MX6_PAD_EIM_CS1__MIPI_CORE_DPHY_OUT_25 = IOMUX_PAD(0x0410, 0x00FC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__GPIO_2_24 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), MX6_PAD_EIM_CS1__TPSMP_HDATA_8 = IOMUX_PAD(0x0410, 0x00FC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_OE__WEIM_WEIM_OE = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, 0), - MX6_PAD_EIM_OE__IPU1_DI1_PIN7 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), + MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, 0), + MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x0414, 0x0100, 2, 0x0814, 0, 0), MX6_PAD_EIM_OE__MIPI_CORE_DPHY_OUT_26 = IOMUX_PAD(0x0414, 0x0100, 4, 0x0000, 0, 0), - MX6_PAD_EIM_OE__GPIO_2_25 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), MX6_PAD_EIM_OE__TPSMP_HDATA_9 = IOMUX_PAD(0x0414, 0x0100, 6, 0x0000, 0, 0), - MX6_PAD_EIM_RW__WEIM_WEIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), - MX6_PAD_EIM_RW__IPU1_DI1_PIN8 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x0418, 0x0104, 2, 0x081C, 0, 0), MX6_PAD_EIM_RW__MIPI_CORE_DPHY_OUT_27 = IOMUX_PAD(0x0418, 0x0104, 4, 0x0000, 0, 0), - MX6_PAD_EIM_RW__GPIO_2_26 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), MX6_PAD_EIM_RW__TPSMP_HDATA_10 = IOMUX_PAD(0x0418, 0x0104, 6, 0x0000, 0, 0), - MX6_PAD_EIM_RW__SRC_BT_CFG_29 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__WEIM_WEIM_LBA = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, 0), MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x041C, 0x0108, 2, 0x0820, 0, 0), - MX6_PAD_EIM_LBA__GPIO_2_27 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), MX6_PAD_EIM_LBA__TPSMP_HDATA_11 = IOMUX_PAD(0x041C, 0x0108, 6, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__SRC_BT_CFG_26 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__WEIM_WEIM_EB_0 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_DISP1_DAT_11 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU2_CSI1_D_11 = IOMUX_PAD(0x0420, 0x010C, 2, 0x08B4, 1, 0), + MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU2_CSI1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 2, 0x08B4, 1, 0), MX6_PAD_EIM_EB0__MIPI_CORE_DPHY_OUT_0 = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__CCM_PMIC_RDY = IOMUX_PAD(0x0420, 0x010C, 4, 0x07F0, 0, 0), - MX6_PAD_EIM_EB0__GPIO_2_28 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0420, 0x010C, 4, 0x07F0, 0, 0), + MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB0__TPSMP_HDATA_12 = IOMUX_PAD(0x0420, 0x010C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__SRC_BT_CFG_27 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__WEIM_WEIM_EB_1 = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_DISP1_DAT_10 = IOMUX_PAD(0x0424, 0x0110, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU2_CSI1_D_10 = IOMUX_PAD(0x0424, 0x0110, 2, 0x08B0, 1, 0), + MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU2_CSI1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 2, 0x08B0, 1, 0), MX6_PAD_EIM_EB1__MIPI_CORE_DPHY__OUT_1 = IOMUX_PAD(0x0424, 0x0110, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__GPIO_2_29 = IOMUX_PAD(0x0424, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0424, 0x0110, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB1__TPSMP_HDATA_13 = IOMUX_PAD(0x0424, 0x0110, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__SRC_BT_CFG_28 = IOMUX_PAD(0x0424, 0x0110, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__WEIM_WEIM_DA_A_0 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_DISP1_DAT_9 = IOMUX_PAD(0x0428, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU2_CSI1_D_9 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0424, 0x0110, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU2_CSI1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA0__MIPI_CORE_DPHY__OUT_2 = IOMUX_PAD(0x0428, 0x0114, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__GPIO_3_0 = IOMUX_PAD(0x0428, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0428, 0x0114, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA0__TPSMP_HDATA_14 = IOMUX_PAD(0x0428, 0x0114, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__SRC_BT_CFG_0 = IOMUX_PAD(0x0428, 0x0114, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__WEIM_WEIM_DA_A_1 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_DISP1_DAT_8 = IOMUX_PAD(0x042C, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU2_CSI1_D_8 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0428, 0x0114, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU2_CSI1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA1__MIPI_CORE_DPHY_OUT_3 = IOMUX_PAD(0x042C, 0x0118, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA1__USBPHY1_TX_LS_MODE = IOMUX_PAD(0x042C, 0x0118, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__GPIO_3_1 = IOMUX_PAD(0x042C, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x042C, 0x0118, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA1__TPSMP_HDATA_15 = IOMUX_PAD(0x042C, 0x0118, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__SRC_BT_CFG_1 = IOMUX_PAD(0x042C, 0x0118, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__WEIM_WEIM_DA_A_2 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_DISP1_DAT_7 = IOMUX_PAD(0x0430, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU2_CSI1_D_7 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x042C, 0x0118, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU2_CSI1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA2__MIPI_CORE_DPHY_OUT_4 = IOMUX_PAD(0x0430, 0x011C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA2__USBPHY1_TX_HS_MODE = IOMUX_PAD(0x0430, 0x011C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__GPIO_3_2 = IOMUX_PAD(0x0430, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0430, 0x011C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA2__TPSMP_HDATA_16 = IOMUX_PAD(0x0430, 0x011C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__SRC_BT_CFG_2 = IOMUX_PAD(0x0430, 0x011C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__WEIM_WEIM_DA_A_3 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_DISP1_DAT_6 = IOMUX_PAD(0x0434, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU2_CSI1_D_6 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0430, 0x011C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU2_CSI1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA3__MIPI_CORE_DPHY_OUT_5 = IOMUX_PAD(0x0434, 0x0120, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA3__USBPHY1_TX_HIZ = IOMUX_PAD(0x0434, 0x0120, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__GPIO_3_3 = IOMUX_PAD(0x0434, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0434, 0x0120, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA3__TPSMP_HDATA_17 = IOMUX_PAD(0x0434, 0x0120, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__SRC_BT_CFG_3 = IOMUX_PAD(0x0434, 0x0120, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__WEIM_WEIM_DA_A_4 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_DISP1_DAT_5 = IOMUX_PAD(0x0438, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU2_CSI1_D_5 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0434, 0x0120, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU2_CSI1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA4__MIPI_CORE_DPHY_OUT_6 = IOMUX_PAD(0x0438, 0x0124, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA4__ANATOP_USBPHY1_TX_EN = IOMUX_PAD(0x0438, 0x0124, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__GPIO_3_4 = IOMUX_PAD(0x0438, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x0438, 0x0124, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA4__TPSMP_HDATA_18 = IOMUX_PAD(0x0438, 0x0124, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__SRC_BT_CFG_4 = IOMUX_PAD(0x0438, 0x0124, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__WEIM_WEIM_DA_A_5 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_DISP1_DAT_4 = IOMUX_PAD(0x043C, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU2_CSI1_D_4 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x0438, 0x0124, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU2_CSI1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA5__MIPI_CORE_DPHY_OUT_7 = IOMUX_PAD(0x043C, 0x0128, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA5__ANATOP_USBPHY1_TX_DP = IOMUX_PAD(0x043C, 0x0128, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__GPIO_3_5 = IOMUX_PAD(0x043C, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x043C, 0x0128, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA5__TPSMP_HDATA_19 = IOMUX_PAD(0x043C, 0x0128, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__SRC_BT_CFG_5 = IOMUX_PAD(0x043C, 0x0128, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__WEIM_WEIM_DA_A_6 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_DISP1_DAT_3 = IOMUX_PAD(0x0440, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU2_CSI1_D_3 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x043C, 0x0128, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU2_CSI1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA6__MIPI_CORE_DPHY_OUT_8 = IOMUX_PAD(0x0440, 0x012C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA6__ANATOP_USBPHY1_TX_DN = IOMUX_PAD(0x0440, 0x012C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__GPIO_3_6 = IOMUX_PAD(0x0440, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0440, 0x012C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA6__TPSMP_HDATA_20 = IOMUX_PAD(0x0440, 0x012C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__SRC_BT_CFG_6 = IOMUX_PAD(0x0440, 0x012C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__WEIM_WEIM_DA_A_7 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_DISP1_DAT_2 = IOMUX_PAD(0x0444, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU2_CSI1_D_2 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0440, 0x012C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU2_CSI1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA7__MIPI_CORE_DPHY_OUT_9 = IOMUX_PAD(0x0444, 0x0130, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__GPIO_3_7 = IOMUX_PAD(0x0444, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0444, 0x0130, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA7__TPSMP_HDATA_21 = IOMUX_PAD(0x0444, 0x0130, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__SRC_BT_CFG_7 = IOMUX_PAD(0x0444, 0x0130, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__WEIM_WEIM_DA_A_8 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_DISP1_DAT_1 = IOMUX_PAD(0x0448, 0x0134, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU2_CSI1_D_1 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0444, 0x0130, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU2_CSI1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA8__MIPI_CORE_DPHY_OUT_10 = IOMUX_PAD(0x0448, 0x0134, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__GPIO_3_8 = IOMUX_PAD(0x0448, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x0448, 0x0134, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA8__TPSMP_HDATA_22 = IOMUX_PAD(0x0448, 0x0134, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__SRC_BT_CFG_8 = IOMUX_PAD(0x0448, 0x0134, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__WEIM_WEIM_DA_A_9 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_DISP1_DAT_0 = IOMUX_PAD(0x044C, 0x0138, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU2_CSI1_D_0 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x0448, 0x0134, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU2_CSI1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA9__MIPI_CORE_DPHY_OUT_11 = IOMUX_PAD(0x044C, 0x0138, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__GPIO_3_9 = IOMUX_PAD(0x044C, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x044C, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA9__TPSMP_HDATA_23 = IOMUX_PAD(0x044C, 0x0138, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__SRC_BT_CFG_9 = IOMUX_PAD(0x044C, 0x0138, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__WEIM_WEIM_DA_A_10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x044C, 0x0138, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x0450, 0x013C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x0450, 0x013C, 2, 0x08D8, 1, 0), MX6_PAD_EIM_DA10__MIPI_CORE_DPHY_OUT12 = IOMUX_PAD(0x0450, 0x013C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__GPIO_3_10 = IOMUX_PAD(0x0450, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x0450, 0x013C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA10__TPSMP_HDATA_24 = IOMUX_PAD(0x0450, 0x013C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__SRC_BT_CFG_10 = IOMUX_PAD(0x0450, 0x013C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__WEIM_WEIM_DA_A_11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_DI1_PIN2 = IOMUX_PAD(0x0454, 0x0140, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0450, 0x013C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0454, 0x0140, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU2_CSI1_HSYNC = IOMUX_PAD(0x0454, 0x0140, 2, 0x08DC, 1, 0), MX6_PAD_EIM_DA11__MIPI_CORE_DPHY_OUT13 = IOMUX_PAD(0x0454, 0x0140, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA11__SDMA_DBG_EVT_CHN_6 = IOMUX_PAD(0x0454, 0x0140, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__GPIO_3_11 = IOMUX_PAD(0x0454, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0454, 0x0140, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA11__TPSMP_HDATA_25 = IOMUX_PAD(0x0454, 0x0140, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SRC_BT_CFG_11 = IOMUX_PAD(0x0454, 0x0140, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__WEIM_WEIM_DA_A_12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_DI1_PIN3 = IOMUX_PAD(0x0458, 0x0144, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0454, 0x0140, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0458, 0x0144, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU2_CSI1_VSYNC = IOMUX_PAD(0x0458, 0x0144, 2, 0x08E4, 1, 0), MX6_PAD_EIM_DA12__MIPI_CORE_DPHY_OUT14 = IOMUX_PAD(0x0458, 0x0144, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA12__SDMA_DEBUG_EVT_CHN_3 = IOMUX_PAD(0x0458, 0x0144, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__GPIO_3_12 = IOMUX_PAD(0x0458, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0458, 0x0144, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA12__TPSMP_HDATA_26 = IOMUX_PAD(0x0458, 0x0144, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SRC_BT_CFG_12 = IOMUX_PAD(0x0458, 0x0144, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__WEIM_WEIM_DA_A_13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0458, 0x0144, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x045C, 0x0148, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA13__CCM_DI1_EXT_CLK = IOMUX_PAD(0x045C, 0x0148, 2, 0x07EC, 1, 0), MX6_PAD_EIM_DA13__MIPI_CORE_DPHY_OUT15 = IOMUX_PAD(0x045C, 0x0148, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA13__SDMA_DEBUG_EVT_CHN_4 = IOMUX_PAD(0x045C, 0x0148, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__GPIO_3_13 = IOMUX_PAD(0x045C, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x045C, 0x0148, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA13__TPSMP_HDATA_27 = IOMUX_PAD(0x045C, 0x0148, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SRC_BT_CFG_13 = IOMUX_PAD(0x045C, 0x0148, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__WEIM_WEIM_DA_A_14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x045C, 0x0148, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x0460, 0x014C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA14__CCM_DI0_EXT_CLK = IOMUX_PAD(0x0460, 0x014C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA14__MIPI_CORE_DPHY_OUT16 = IOMUX_PAD(0x0460, 0x014C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA14__SDMA_DEBUG_EVT_CHN_5 = IOMUX_PAD(0x0460, 0x014C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__GPIO_3_14 = IOMUX_PAD(0x0460, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x0460, 0x014C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA14__TPSMP_HDATA_28 = IOMUX_PAD(0x0460, 0x014C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SRC_BT_CFG_14 = IOMUX_PAD(0x0460, 0x014C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__WEIM_WEIM_DA_A_15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN1 = IOMUX_PAD(0x0464, 0x0150, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN4 = IOMUX_PAD(0x0464, 0x0150, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0460, 0x014C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0464, 0x0150, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0464, 0x0150, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA15__MIPI_CORE_DPHY_OUT17 = IOMUX_PAD(0x0464, 0x0150, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__GPIO_3_15 = IOMUX_PAD(0x0464, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0464, 0x0150, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA15__TPSMP_HDATA_29 = IOMUX_PAD(0x0464, 0x0150, 6, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__SRC_BT_CFG_15 = IOMUX_PAD(0x0464, 0x0150, 7, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__WEIM_WEIM_WAIT = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__WEIM_WEIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__GPIO_5_0 = IOMUX_PAD(0x0468, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0464, 0x0150, 7, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x0468, 0x0154, 5, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__TPSMP_HDATA_30 = IOMUX_PAD(0x0468, 0x0154, 6, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__SRC_BT_CFG_25 = IOMUX_PAD(0x0468, 0x0154, 7, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__WEIM_WEIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x0468, 0x0154, 7, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x046C, 0x0158, 1, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__GPIO_6_31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x046C, 0x0158, 6, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__MIPI_CR_DPY_OT28 = IOMUX_PAD(0x0470, 0x015C, 3, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__SDMA_DBG_CR_STA0 = IOMUX_PAD(0x0470, 0x015C, 4, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__GPIO_4_16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__MMDC_DEBUG_0 = IOMUX_PAD(0x0470, 0x015C, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__IPU2_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUDMUX_AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__MIPI_CR_DPHY_OUT_29 = IOMUX_PAD(0x0474, 0x0160, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__SDMA_DBG_CORE_STA_1 = IOMUX_PAD(0x0474, 0x0160, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__GPIO_4_17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x0474, 0x0160, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN2__IPU2_DI0_PIN2 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__AUDMUX_AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN2__IPU2_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__MIPI_CR_DPHY_OUT_30 = IOMUX_PAD(0x0478, 0x0164, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__SDMA_DBG_CORE_STA_2 = IOMUX_PAD(0x0478, 0x0164, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__GPIO_4_18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__MMDC_DEBUG_2 = IOMUX_PAD(0x0478, 0x0164, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__PL301_PER1_HADDR_9 = IOMUX_PAD(0x0478, 0x0164, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN3__IPU2_DI0_PIN3 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN3__IPU2_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__MIPI_CORE_DPHY_OUT31 = IOMUX_PAD(0x047C, 0x0168, 3, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__SDMA_DBG_CORE_STA_3 = IOMUX_PAD(0x047C, 0x0168, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__GPIO_4_19 = IOMUX_PAD(0x047C, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x047C, 0x0168, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x047C, 0x0168, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__PL301_PER1_HADDR_10 = IOMUX_PAD(0x047C, 0x0168, 7, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN4 = IOMUX_PAD(0x0480, 0x016C, 0, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU2_DI0_PIN4 = IOMUX_PAD(0x0480, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__USDHC1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), + MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 0, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__IPU2_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), MX6_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x0480, 0x016C, 4, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x0480, 0x016C, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__PL301_PER1_HADDR_11 = IOMUX_PAD(0x0480, 0x016C, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT0__IPU2_DISP0_DAT_0 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__USDHC1_USDHC_DBG_0 = IOMUX_PAD(0x0484, 0x0170, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__SDMA_DBG_CORE_RUN = IOMUX_PAD(0x0484, 0x0170, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__GPIO_4_21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x0484, 0x0170, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT1__IPU2_DISP0_DAT_1 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__USDHC1_USDHC_DBG_1 = IOMUX_PAD(0x0488, 0x0174, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__SDMA_DBG_EVT_CHNSL = IOMUX_PAD(0x0488, 0x0174, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__GPIO_4_22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__MMDC_DEBUG_6 = IOMUX_PAD(0x0488, 0x0174, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__PL301_PER1_HADR_12 = IOMUX_PAD(0x0488, 0x0174, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT2__IPU2_DISP0_DAT_2 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__USDHC1_USDHC_DBG_2 = IOMUX_PAD(0x048C, 0x0178, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__SDMA_DEBUG_MODE = IOMUX_PAD(0x048C, 0x0178, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__GPIO_4_23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__MMDC_DEBUG_7 = IOMUX_PAD(0x048C, 0x0178, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__PL301_PER1_HADR_13 = IOMUX_PAD(0x048C, 0x0178, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT3__IPU2_DISP0_DAT_3 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0490, 0x017C, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__USDHC1_USDHC_DBG_3 = IOMUX_PAD(0x0490, 0x017C, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__SDMA_DBG_BUS_ERROR = IOMUX_PAD(0x0490, 0x017C, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__GPIO_4_24 = IOMUX_PAD(0x0490, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0490, 0x017C, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__MMDC_MMDC_DBG_8 = IOMUX_PAD(0x0490, 0x017C, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__PL301_PER1_HADR_14 = IOMUX_PAD(0x0490, 0x017C, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT4__IPU2_DISP0_DAT_4 = IOMUX_PAD(0x0494, 0x0180, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x0494, 0x0180, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__USDHC1_USDHC_DBG_4 = IOMUX_PAD(0x0494, 0x0180, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x0494, 0x0180, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__GPIO_4_25 = IOMUX_PAD(0x0494, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x0494, 0x0180, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x0494, 0x0180, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__PL301_PER1_HADR_15 = IOMUX_PAD(0x0494, 0x0180, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT5__IPU2_DISP0_DAT_5 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0498, 0x0184, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__SDMA_DBG_MCH_DMBUS = IOMUX_PAD(0x0498, 0x0184, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__GPIO_4_26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__MMDC_DEBUG_10 = IOMUX_PAD(0x0498, 0x0184, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__PL301_PER1_HADR_16 = IOMUX_PAD(0x0498, 0x0184, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT6__IPU2_DISP0_DAT_6 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x049C, 0x0188, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUDMUX_AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__SDMA_DBG_RTBUF_WRT = IOMUX_PAD(0x049C, 0x0188, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__GPIO_4_27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__MMDC_DEBUG_11 = IOMUX_PAD(0x049C, 0x0188, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__PL301_PER1_HADR_17 = IOMUX_PAD(0x049C, 0x0188, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT7__IPU2_DISP0_DAT_7 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x04A0, 0x018C, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__USDHC1_USDHC_DBG_5 = IOMUX_PAD(0x04A0, 0x018C, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__SDMA_DBG_EVT_CHN_0 = IOMUX_PAD(0x04A0, 0x018C, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__GPIO_4_28 = IOMUX_PAD(0x04A0, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x04A0, 0x018C, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__MMDC_DEBUG_12 = IOMUX_PAD(0x04A0, 0x018C, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__PL301_PER1_HADR_18 = IOMUX_PAD(0x04A0, 0x018C, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT8__IPU2_DISP0_DAT_8 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PWM1_PWMO = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_WDOG_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__SDMA_DBG_EVT_CHN_1 = IOMUX_PAD(0x04A4, 0x0190, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__GPIO_4_29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__MMDC_DEBUG_13 = IOMUX_PAD(0x04A4, 0x0190, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PL301_PER1_HADR_19 = IOMUX_PAD(0x04A4, 0x0190, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT9__IPU2_DISP0_DAT_9 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PWM2_PWMO = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_WDOG_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__SDMA_DBG_EVT_CHN_2 = IOMUX_PAD(0x04A8, 0x0194, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__GPIO_4_30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__MMDC_DEBUG_14 = IOMUX_PAD(0x04A8, 0x0194, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PL301_PER1_HADR_20 = IOMUX_PAD(0x04A8, 0x0194, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__IPU2_DISP0_DAT_10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__USDHC1_DBG_6 = IOMUX_PAD(0x04AC, 0x0198, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__SDMA_DBG_EVT_CHN3 = IOMUX_PAD(0x04AC, 0x0198, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__GPIO_4_31 = IOMUX_PAD(0x04AC, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x04AC, 0x0198, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__MMDC_DEBUG_15 = IOMUX_PAD(0x04AC, 0x0198, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__PL301_PER1_HADR21 = IOMUX_PAD(0x04AC, 0x0198, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__IPU2_DISP0_DAT_11 = IOMUX_PAD(0x04B0, 0x019C, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__USDHC1_USDHC_DBG7 = IOMUX_PAD(0x04B0, 0x019C, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__SDMA_DBG_EVT_CHN4 = IOMUX_PAD(0x04B0, 0x019C, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__GPIO_5_5 = IOMUX_PAD(0x04B0, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x04B0, 0x019C, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__MMDC_DEBUG_16 = IOMUX_PAD(0x04B0, 0x019C, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__PL301_PER1_HADR22 = IOMUX_PAD(0x04B0, 0x019C, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__IPU2_DISP0_DAT_12 = IOMUX_PAD(0x04B4, 0x01A0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__RESERVED_RESERVED = IOMUX_PAD(0x04B4, 0x01A0, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__SDMA_DBG_EVT_CHN5 = IOMUX_PAD(0x04B4, 0x01A0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__GPIO_5_6 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__MMDC_DEBUG_17 = IOMUX_PAD(0x04B4, 0x01A0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__PL301_PER1_HADR23 = IOMUX_PAD(0x04B4, 0x01A0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__IPU2_DISP0_DAT_13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), MX6_PAD_DISP0_DAT13__SDMA_DBG_EVT_CHN0 = IOMUX_PAD(0x04B8, 0x01A4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__GPIO_5_7 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__MMDC_DEBUG_18 = IOMUX_PAD(0x04B8, 0x01A4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__PL301_PER1_HADR24 = IOMUX_PAD(0x04B8, 0x01A4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__IPU2_DISP0_DAT_14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUDMUX_AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), MX6_PAD_DISP0_DAT14__SDMA_DBG_EVT_CHN1 = IOMUX_PAD(0x04BC, 0x01A8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__GPIO_5_8 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__MMDC_DEBUG_19 = IOMUX_PAD(0x04BC, 0x01A8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__IPU2_DISP0_DAT_15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), MX6_PAD_DISP0_DAT15__SDMA_DBG_EVT_CHN2 = IOMUX_PAD(0x04C0, 0x01AC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__GPIO_5_9 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__MMDC_DEBUG_20 = IOMUX_PAD(0x04C0, 0x01AC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__PL301_PER1_HADR25 = IOMUX_PAD(0x04C0, 0x01AC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__IPU2_DISP0_DAT_16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x01B0, 2, 0x0818, 1, 0), - MX6_PAD_DISP0_DAT16__AUDMUX_AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), - MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x04C4, 0x01B0, 4, 0x090C, 0, 0), - MX6_PAD_DISP0_DAT16__GPIO_5_10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), + MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x04C4, 0x01B0, 4, 0x090C, 0, 0), + MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__MMDC_DEBUG_21 = IOMUX_PAD(0x04C4, 0x01B0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__PL301_PER1_HADR26 = IOMUX_PAD(0x04C4, 0x01B0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__IPU2_DISP0_DAT_17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x04C8, 0x01B4, 2, 0x0814, 1, 0), - MX6_PAD_DISP0_DAT17__AUDMUX_AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), - MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT_1 = IOMUX_PAD(0x04C8, 0x01B4, 4, 0x0910, 0, 0), - MX6_PAD_DISP0_DAT17__GPIO_5_11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), + MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x04C8, 0x01B4, 4, 0x0910, 0, 0), + MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__MMDC_DEBUG_22 = IOMUX_PAD(0x04C8, 0x01B4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__PL301_PER1_HADR27 = IOMUX_PAD(0x04C8, 0x01B4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__IPU2_DISP0_DAT_18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), - MX6_PAD_DISP0_DAT18__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), - MX6_PAD_DISP0_DAT18__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), - MX6_PAD_DISP0_DAT18__GPIO_5_12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), + MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), + MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__MMDC_DEBUG_23 = IOMUX_PAD(0x04CC, 0x01B8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__WEIM_WEIM_CS_2 = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__IPU2_DISP0_DAT_19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x04D0, 0x01BC, 2, 0x0810, 1, 0), - MX6_PAD_DISP0_DAT19__AUDMUX_AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), - MX6_PAD_DISP0_DAT19__AUDMUX_AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), - MX6_PAD_DISP0_DAT19__GPIO_5_13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), + MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), + MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__MMDC_DEBUG_24 = IOMUX_PAD(0x04D0, 0x01BC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__WEIM_WEIM_CS_3 = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__IPU2_DISP0_DAT_20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x04D4, 0x01C0, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT20__AUDMUX_AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), + MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), MX6_PAD_DISP0_DAT20__SDMA_DBG_EVT_CHN7 = IOMUX_PAD(0x04D4, 0x01C0, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__GPIO_5_14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__MMDC_DEBUG_25 = IOMUX_PAD(0x04D4, 0x01C0, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__PL301_PER1_HADR28 = IOMUX_PAD(0x04D4, 0x01C0, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__IPU2_DISP0_DAT_21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x04D8, 0x01C4, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT21__AUDMUX_AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), + MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), MX6_PAD_DISP0_DAT21__SDMA_DBG_BUS_DEV0 = IOMUX_PAD(0x04D8, 0x01C4, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__GPIO_5_15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__MMDC_DEBUG_26 = IOMUX_PAD(0x04D8, 0x01C4, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__PL301_PER1_HADR29 = IOMUX_PAD(0x04D8, 0x01C4, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__IPU2_DISP0_DAT_22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x04DC, 0x01C8, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT22__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), + MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), MX6_PAD_DISP0_DAT22__SDMA_DBG_BUS_DEV1 = IOMUX_PAD(0x04DC, 0x01C8, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__GPIO_5_16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__MMDC_DEBUG_27 = IOMUX_PAD(0x04DC, 0x01C8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__PL301_PER1_HADR30 = IOMUX_PAD(0x04DC, 0x01C8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__IPU2_DISP0_DAT_23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT23__AUDMUX_AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), + MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), MX6_PAD_DISP0_DAT23__SDMA_DBG_BUS_DEV2 = IOMUX_PAD(0x04E0, 0x01CC, 4, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__GPIO_5_17 = IOMUX_PAD(0x04E0, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x04E0, 0x01CC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__MMDC_DEBUG_28 = IOMUX_PAD(0x04E0, 0x01CC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__PL301_PER1_HADR31 = IOMUX_PAD(0x04E0, 0x01CC, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__RESERVED_RESERVED = IOMUX_PAD(0x04E4, 0x01D0, 0, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x04E4, 0x01D0, 1, 0x0840, 0, 0), - MX6_PAD_ENET_MDIO__ESAI1_SCKR = IOMUX_PAD(0x04E4, 0x01D0, 2, 0x086C, 0, 0), + MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x04E4, 0x01D0, 2, 0x086C, 0, 0), MX6_PAD_ENET_MDIO__SDMA_DEBUG_BUS_DEV3 = IOMUX_PAD(0x04E4, 0x01D0, 3, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__ENET_1588_EVT1_OUT = IOMUX_PAD(0x04E4, 0x01D0, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__GPIO_1_22 = IOMUX_PAD(0x04E4, 0x01D0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__SPDIF_PLOCK = IOMUX_PAD(0x04E4, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x04E4, 0x01D0, 4, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x04E4, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x04E4, 0x01D0, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__RESERVED_RSRVED = IOMUX_PAD(0x04E8, 0x01D4, 0, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x04E8, 0x01D4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ESAI1_FSR = IOMUX_PAD(0x04E8, 0x01D4, 2, 0x085C, 0, 0), + MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x04E8, 0x01D4, 2, 0x085C, 0, 0), MX6_PAD_ENET_REF_CLK__SDMA_DBGBUS_DEV4 = IOMUX_PAD(0x04E8, 0x01D4, 3, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__GPIO_1_23 = IOMUX_PAD(0x04E8, 0x01D4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__SPDIF_SRCLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x04E8, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__USBPHY1_RX_SQH = IOMUX_PAD(0x04E8, 0x01D4, 7, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x04EC, 0x01D8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI1_HCKR = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), - MX6_PAD_ENET_RX_ER__SPDIF_IN1 = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), - MX6_PAD_ENET_RX_ER__ENET_1588_EVT2_OUT = IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__GPIO_1_24 = IOMUX_PAD(0x04EC, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), + MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), + MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x04EC, 0x01D8, 5, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__PHY_TDI = IOMUX_PAD(0x04EC, 0x01D8, 6, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__USBPHY1_RX_HS_RXD = IOMUX_PAD(0x04EC, 0x01D8, 7, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__RESERVED_RSRVED = IOMUX_PAD(0x04F0, 0x01DC, 0, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x04F0, 0x01DC, 1, 0x0858, 1, 0), - MX6_PAD_ENET_CRS_DV__ESAI1_SCKT = IOMUX_PAD(0x04F0, 0x01DC, 2, 0x0870, 0, 0), - MX6_PAD_ENET_CRS_DV__SPDIF_EXTCLK = IOMUX_PAD(0x04F0, 0x01DC, 3, 0x0918, 1, 0), - MX6_PAD_ENET_CRS_DV__GPIO_1_25 = IOMUX_PAD(0x04F0, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x04F0, 0x01DC, 2, 0x0870, 0, 0), + MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x04F0, 0x01DC, 3, 0x0918, 1, 0), + MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x04F0, 0x01DC, 5, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__PHY_TDO = IOMUX_PAD(0x04F0, 0x01DC, 6, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__USBPHY1_RX_FS_RXD = IOMUX_PAD(0x04F0, 0x01DC, 7, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__MLB_MLBSIG = IOMUX_PAD(0x04F4, 0x01E0, 0, 0x0908, 0, 0), - MX6_PAD_ENET_RXD1__ENET_RDATA_1 = IOMUX_PAD(0x04F4, 0x01E0, 1, 0x084C, 1, 0), - MX6_PAD_ENET_RXD1__ESAI1_FST = IOMUX_PAD(0x04F4, 0x01E0, 2, 0x0860, 0, 0), - MX6_PAD_ENET_RXD1__ENET_1588_EVT3_OUT = IOMUX_PAD(0x04F4, 0x01E0, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__GPIO_1_26 = IOMUX_PAD(0x04F4, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x04F4, 0x01E0, 0, 0x0908, 0, 0), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x04F4, 0x01E0, 1, 0x084C, 1, 0), + MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x04F4, 0x01E0, 2, 0x0860, 0, 0), + MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x04F4, 0x01E0, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x04F4, 0x01E0, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__PHY_TCK = IOMUX_PAD(0x04F4, 0x01E0, 6, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__USBPHY1_RX_DISCON = IOMUX_PAD(0x04F4, 0x01E0, 7, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__OSC32K_32K_OUT = IOMUX_PAD(0x04F8, 0x01E4, 0, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ENET_RDATA_0 = IOMUX_PAD(0x04F8, 0x01E4, 1, 0x0848, 1, 0), - MX6_PAD_ENET_RXD0__ESAI1_HCKT = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), - MX6_PAD_ENET_RXD0__SPDIF_OUT1 = IOMUX_PAD(0x04F8, 0x01E4, 3, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__GPIO_1_27 = IOMUX_PAD(0x04F8, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x04F8, 0x01E4, 1, 0x0848, 1, 0), + MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), + MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x04F8, 0x01E4, 3, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x04F8, 0x01E4, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__PHY_TMS = IOMUX_PAD(0x04F8, 0x01E4, 6, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__USBPHY1_PLL_CK20DIV = IOMUX_PAD(0x04F8, 0x01E4, 7, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__RESERVED_RSRVED = IOMUX_PAD(0x04FC, 0x01E8, 0, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x04FC, 0x01E8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ESAI1_TX3_RX2 = IOMUX_PAD(0x04FC, 0x01E8, 2, 0x0880, 0, 0), - MX6_PAD_ENET_TX_EN__GPIO_1_28 = IOMUX_PAD(0x04FC, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x04FC, 0x01E8, 2, 0x0880, 0, 0), + MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x04FC, 0x01E8, 5, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__SATA_PHY_TDI = IOMUX_PAD(0x04FC, 0x01E8, 6, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__USBPHY2_RX_SQH = IOMUX_PAD(0x04FC, 0x01E8, 7, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__MLB_MLBCLK = IOMUX_PAD(0x0500, 0x01EC, 0, 0x0900, 0, 0), - MX6_PAD_ENET_TXD1__ENET_TDATA_1 = IOMUX_PAD(0x0500, 0x01EC, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI1_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), + MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x0500, 0x01EC, 0, 0x0900, 0, 0), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x0500, 0x01EC, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x0500, 0x01EC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__GPIO_1_29 = IOMUX_PAD(0x0500, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x0500, 0x01EC, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__SATA_PHY_TDO = IOMUX_PAD(0x0500, 0x01EC, 6, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__USBPHY2_RX_HS_RXD = IOMUX_PAD(0x0500, 0x01EC, 7, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__RESERVED_RSRVED = IOMUX_PAD(0x0504, 0x01F0, 0, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ENET_TDATA_0 = IOMUX_PAD(0x0504, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI1_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), - MX6_PAD_ENET_TXD0__GPIO_1_30 = IOMUX_PAD(0x0504, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x0504, 0x01F0, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), + MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x0504, 0x01F0, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__SATA_PHY_TCK = IOMUX_PAD(0x0504, 0x01F0, 6, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__USBPHY2_RX_FS_RXD = IOMUX_PAD(0x0504, 0x01F0, 7, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__MLB_MLBDAT = IOMUX_PAD(0x0508, 0x01F4, 0, 0x0904, 0, 0), + MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x0508, 0x01F4, 0, 0x0904, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x0508, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ESAI1_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), + MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x0508, 0x01F4, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__GPIO_1_31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__SATA_PHY_TMS = IOMUX_PAD(0x0508, 0x01F4, 6, 0x0000, 0, 0), MX6_PAD_ENET_MDC__USBPHY2_RX_DISCON = IOMUX_PAD(0x0508, 0x01F4, 7, 0x0000, 0, 0), MX6_PAD_DRAM_D40__MMDC_DRAM_D_40 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), @@ -892,357 +892,357 @@ enum { MX6_PAD_DRAM_D62__MMDC_DRAM_D_62 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_D63__MMDC_DRAM_D_63 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x07F4, 2, 0), - MX6_PAD_KEY_COL0__ENET_RDATA_3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), - MX6_PAD_KEY_COL0__AUDMUX_AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), - MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_TXD = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_TXD_RXD = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), - MX6_PAD_KEY_COL0__GPIO_4_6 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_DCIC_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), + MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), + MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), + MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL0__SRC_ANY_PU_RST = IOMUX_PAD(0x05C8, 0x01F8, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x07FC, 2, 0), - MX6_PAD_KEY_ROW0__ENET_TDATA_3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUDMUX_AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), - MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x05CC, 0x01FC, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_RXD = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), - MX6_PAD_KEY_ROW0__GPIO_4_7 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_DCIC_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), + MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x05CC, 0x01FC, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), + MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__PL301_PER1_HADR_0 = IOMUX_PAD(0x05CC, 0x01FC, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x05D0, 0x0200, 0, 0x07F8, 2, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0840, 1, 0), - MX6_PAD_KEY_COL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), - MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x05D0, 0x0200, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_TXD = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_TXD_RXD = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), - MX6_PAD_KEY_COL1__GPIO_4_8 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__USDHC1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), + MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x05D0, 0x0200, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), + MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL1__PL301MX_PER1_HADR_1 = IOMUX_PAD(0x05D0, 0x0200, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x05D4, 0x0204, 0, 0x0800, 2, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), - MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x05D4, 0x0204, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_RXD = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), - MX6_PAD_KEY_ROW1__GPIO_4_9 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__USDHC2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), + MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x05D4, 0x0204, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), + MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__PL301_PER1_HADDR_2 = IOMUX_PAD(0x05D4, 0x0204, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x05D8, 0x0208, 0, 0x0804, 2, 0), - MX6_PAD_KEY_COL2__ENET_RDATA_2 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0850, 1, 0), - MX6_PAD_KEY_COL2__CAN1_TXCAN = IOMUX_PAD(0x05D8, 0x0208, 2, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x05D8, 0x0208, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0850, 1, 0), + MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x05D8, 0x0208, 2, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__KEY_COL2 = IOMUX_PAD(0x05D8, 0x0208, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__GPIO_4_10 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__USBOH3_H1_PWRCTL_WKP = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL2__PL301_PER1_HADDR_3 = IOMUX_PAD(0x05D8, 0x0208, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0808, 1, 0), - MX6_PAD_KEY_ROW2__ENET_TDATA_2 = IOMUX_PAD(0x05DC, 0x020C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__CAN1_RXCAN = IOMUX_PAD(0x05DC, 0x020C, 2, 0x07E4, 0, 0), - MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__USDHC2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__GPIO_4_11 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x05DC, 0x020C, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x05DC, 0x020C, 2, 0x07E4, 0, 0), + MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x05DC, 0x020C, 6, 0x088C, 1, 0), MX6_PAD_KEY_ROW2__PL301_PER1_HADR_4 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x05E0, 0x0210, 0, 0x080C, 1, 0), MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x05E0, 0x0210, 2, 0x0890, 1, 0), - MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__KEY_COL3 = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x05E0, 0x0210, 20, 0x08A0, 1, 0), - MX6_PAD_KEY_COL3__GPIO_4_12 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__SPDIF_IN1 = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0914, 2, 0), + MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0914, 2, 0), MX6_PAD_KEY_COL3__PL301_PER1_HADR_5 = IOMUX_PAD(0x05E0, 0x0210, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__OSC32K_32K_OUT = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), + MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x05E4, 0x0214, 2, 0x0894, 1, 0), - MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x05E4, 0x0214, 20, 0x08A4, 1, 0), - MX6_PAD_KEY_ROW3__GPIO_4_13 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__USDHC1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__PL301_PER1_HADR_6 = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__CAN2_TXCAN = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__IPU1_SISG_4 = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USBOH3_USBOTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), - MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_CTS = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_RTS = IOMUX_PAD(0x05E8, 0x0218, 4, 0x093C, 0, 0), - MX6_PAD_KEY_COL4__GPIO_4_14 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), + MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x093C, 0, 0), + MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL4__MMDC_DEBUG_49 = IOMUX_PAD(0x05E8, 0x0218, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL4__PL301_PER1_HADDR_7 = IOMUX_PAD(0x05E8, 0x0218, 7, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__CAN2_RXCAN = IOMUX_PAD(0x05EC, 0x021C, 0, 0x07E8, 0, 0), - MX6_PAD_KEY_ROW4__IPU1_SISG_5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USBOH3_USBOTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_CTS = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), - MX6_PAD_KEY_ROW4__GPIO_4_15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x05EC, 0x021C, 0, 0x07E8, 0, 0), + MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), + MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__MMDC_DEBUG_50 = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__PL301_PER1_HADR_8 = IOMUX_PAD(0x05EC, 0x021C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_0__CCM_CLKO = IOMUX_PAD(0x05F0, 0x0220, 0, 0x0000, 0, 0), - MX6_PAD_GPIO_0__KPP_COL_5 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x08E8, 0, 0), - MX6_PAD_GPIO_0__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), - MX6_PAD_GPIO_0__EPIT1_EPITO = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_0__GPIO_1_0 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USBOH3_USBH1_PWR = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_HP_WRAP_SNVS_VIO5 = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_1__ESAI1_SCKR = IOMUX_PAD(0x05F4, 0x0224, 0, 0x086C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_WDOG_B = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_1__KPP_ROW_5 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08F4, 0, 0), - MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_1__PWM2_PWMO = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_1__GPIO_1_1 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_1__USDHC1_CD = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x0000, 0, 0), + MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x08E8, 0, 0), + MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), + MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05F4, 0x0224, 0, 0x086C, 1, 0), + MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08F4, 0, 0), + MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), MX6_PAD_GPIO_1__SRC_TESTER_ACK = IOMUX_PAD(0x05F4, 0x0224, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_9__ESAI1_FSR = IOMUX_PAD(0x05F8, 0x0228, 0, 0x085C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_WDOG_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_9__KPP_COL_6 = IOMUX_PAD(0x05F8, 0x0228, 2, 0x08EC, 0, 0), + MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x05F8, 0x0228, 0, 0x085C, 1, 0), + MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x05F8, 0x0228, 2, 0x08EC, 0, 0), MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_9__PWM1_PWMO = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_9__GPIO_1_9 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__USDHC1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), + MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), MX6_PAD_GPIO_9__SRC_EARLY_RST = IOMUX_PAD(0x05F8, 0x0228, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_3__ESAI1_HCKR = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0864, 1, 0), + MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0864, 1, 0), MX6_PAD_GPIO_3__OBSERVE_MUX_INT_OUT0 = IOMUX_PAD(0x05FC, 0x022C, 1, 0x0000, 0, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05FC, 0x022C, 18, 0x08A8, 1, 0), - MX6_PAD_GPIO_3__ANATOP_24M_OUT = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_3__GPIO_1_3 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_3__USBOH3_USBH1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), - MX6_PAD_GPIO_3__MLB_MLBCLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), - MX6_PAD_GPIO_6__ESAI1_SCKT = IOMUX_PAD(0x0600, 0x0230, 0, 0x0870, 1, 0), + MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), + MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), + MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0600, 0x0230, 0, 0x0870, 1, 0), MX6_PAD_GPIO_6__OBSERVE_MUX_INT_OUT1 = IOMUX_PAD(0x0600, 0x0230, 1, 0x0000, 0, 0), MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0600, 0x0230, 18, 0x08AC, 1, 0), MX6_PAD_GPIO_6__CCM_CCM_OUT_0 = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), MX6_PAD_GPIO_6__CSU_CSU_INT_DEB = IOMUX_PAD(0x0600, 0x0230, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_6__GPIO_1_6 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_6__USDHC2_LCTL = IOMUX_PAD(0x0600, 0x0230, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_MLBSIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), - MX6_PAD_GPIO_2__ESAI1_FST = IOMUX_PAD(0x0604, 0x0234, 0, 0x0860, 1, 0), + MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0600, 0x0230, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), + MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x0604, 0x0234, 0, 0x0860, 1, 0), MX6_PAD_GPIO_2__OBSERVE_MUX_INT_OUT2 = IOMUX_PAD(0x0604, 0x0234, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_2__KPP_ROW_6 = IOMUX_PAD(0x0604, 0x0234, 2, 0x08F8, 1, 0), + MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x0604, 0x0234, 2, 0x08F8, 1, 0), MX6_PAD_GPIO_2__CCM_CCM_OUT_1 = IOMUX_PAD(0x0604, 0x0234, 3, 0x0000, 0, 0), MX6_PAD_GPIO_2__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x0604, 0x0234, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_2__GPIO_1_2 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__USDHC2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_2__MLB_MLBDAT = IOMUX_PAD(0x0604, 0x0234, 7, 0x0904, 1, 0), - MX6_PAD_GPIO_4__ESAI1_HCKT = IOMUX_PAD(0x0608, 0x0238, 0, 0x0868, 1, 0), + MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x0604, 0x0234, 7, 0x0904, 1, 0), + MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x0608, 0x0238, 0, 0x0868, 1, 0), MX6_PAD_GPIO_4__OBSERVE_MUX_INT_OUT3 = IOMUX_PAD(0x0608, 0x0238, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_4__KPP_COL_7 = IOMUX_PAD(0x0608, 0x0238, 2, 0x08F0, 1, 0), + MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x0608, 0x0238, 2, 0x08F0, 1, 0), MX6_PAD_GPIO_4__CCM_CCM_OUT_2 = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), MX6_PAD_GPIO_4__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_4__GPIO_1_4 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_4__USDHC2_CD = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), MX6_PAD_GPIO_4__OCOTP_CRL_WRAR_FUSE_LA = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_5__ESAI1_TX2_RX3 = IOMUX_PAD(0x060C, 0x023C, 0, 0x087C, 1, 0), + MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x060C, 0x023C, 0, 0x087C, 1, 0), MX6_PAD_GPIO_5__OBSERVE_MUX_INT_OUT4 = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_5__KPP_ROW_7 = IOMUX_PAD(0x060C, 0x023C, 2, 0x08FC, 1, 0), - MX6_PAD_GPIO_5__CCM_CLKO = IOMUX_PAD(0x060C, 0x023C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x060C, 0x023C, 2, 0x08FC, 1, 0), + MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x060C, 0x023C, 3, 0x0000, 0, 0), MX6_PAD_GPIO_5__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_5__GPIO_1_5 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x060C, 0x023C, 22, 0x08A8, 2, 0), - MX6_PAD_GPIO_5__CHEETAH_EVENTI = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_7__ESAI1_TX4_RX1 = IOMUX_PAD(0x0610, 0x0240, 0, 0x0884, 1, 0), + MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_7__ESAI_TX4_RX1 = IOMUX_PAD(0x0610, 0x0240, 0, 0x0884, 1, 0), MX6_PAD_GPIO_7__ECSPI5_RDY = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_7__EPIT1_EPITO = IOMUX_PAD(0x0610, 0x0240, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_7__CAN1_TXCAN = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_TXD = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_TXD_RXD = IOMUX_PAD(0x0610, 0x0240, 4, 0x0928, 2, 0), - MX6_PAD_GPIO_7__GPIO_1_7 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_7__SPDIF_PLOCK = IOMUX_PAD(0x0610, 0x0240, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_7__USBOH3_OTGUSB_HST_MODE = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_8__ESAI1_TX5_RX0 = IOMUX_PAD(0x0614, 0x0244, 0, 0x0888, 1, 0), - MX6_PAD_GPIO_8__ANATOP_ANATOP_32K_OUT = IOMUX_PAD(0x0614, 0x0244, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_8__EPIT2_EPITO = IOMUX_PAD(0x0614, 0x0244, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_8__CAN1_RXCAN = IOMUX_PAD(0x0614, 0x0244, 3, 0x07E4, 1, 0), - MX6_PAD_GPIO_8__UART2_RXD = IOMUX_PAD(0x0614, 0x0244, 4, 0x0928, 3, 0), - MX6_PAD_GPIO_8__GPIO_1_8 = IOMUX_PAD(0x0614, 0x0244, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_8__SPDIF_SRCLK = IOMUX_PAD(0x0614, 0x0244, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_8__USBOH3_OTG_PWRCTL_WAK = IOMUX_PAD(0x0614, 0x0244, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ESAI1_TX3_RX2 = IOMUX_PAD(0x0618, 0x0248, 0, 0x0880, 1, 0), + MX6_PAD_GPIO_7__EPIT1_OUT = IOMUX_PAD(0x0610, 0x0240, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_7__FLEXCAN1_TX = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_TX_DATA = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_RX_DATA = IOMUX_PAD(0x0610, 0x0240, 4, 0x0928, 2, 0), + MX6_PAD_GPIO_7__GPIO1_IO07 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_7__SPDIF_LOCK = IOMUX_PAD(0x0610, 0x0240, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_7__USB_OTG_HOST_MODE = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_8__ESAI_TX5_RX0 = IOMUX_PAD(0x0614, 0x0244, 0, 0x0888, 1, 0), + MX6_PAD_GPIO_8__XTALOSC_REF_CLK_32K = IOMUX_PAD(0x0614, 0x0244, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_8__EPIT2_OUT = IOMUX_PAD(0x0614, 0x0244, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_8__FLEXCAN1_RX = IOMUX_PAD(0x0614, 0x0244, 3, 0x07E4, 1, 0), + MX6_PAD_GPIO_8__UART2_RX_DATA = IOMUX_PAD(0x0614, 0x0244, 4, 0x0928, 3, 0), + MX6_PAD_GPIO_8__GPIO1_IO08 = IOMUX_PAD(0x0614, 0x0244, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_8__SPDIF_SR_CLK = IOMUX_PAD(0x0614, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x0614, 0x0244, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x0618, 0x0248, 0, 0x0880, 1, 0), MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x0618, 0x0248, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_ETHERNET_REF_OUT = IOMUX_PAD(0x0618, 0x0248, 2, 0x083C, 1, 0), - MX6_PAD_GPIO_16__USDHC1_LCTL = IOMUX_PAD(0x0618, 0x0248, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_16__SPDIF_IN1 = IOMUX_PAD(0x0618, 0x0248, 4, 0x0914, 3, 0), - MX6_PAD_GPIO_16__GPIO_7_11 = IOMUX_PAD(0x0618, 0x0248, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x0618, 0x0248, 2, 0x083C, 1, 0), + MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x0618, 0x0248, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x0618, 0x0248, 4, 0x0914, 3, 0), + MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x0618, 0x0248, 5, 0x0000, 0, 0), MX6_PAD_GPIO_16__I2C3_SDA = IOMUX_PAD(0x0618, 0x0248, 22, 0x08AC, 2, 0), - MX6_PAD_GPIO_16__SJC_DE_B = IOMUX_PAD(0x0618, 0x0248, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_17__ESAI1_TX0 = IOMUX_PAD(0x061C, 0x024C, 0, 0x0874, 0, 0), + MX6_PAD_GPIO_16__JTAG_DE_B = IOMUX_PAD(0x0618, 0x0248, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_17__ESAI_TX0 = IOMUX_PAD(0x061C, 0x024C, 0, 0x0874, 0, 0), MX6_PAD_GPIO_17__ENET_1588_EVENT3_IN = IOMUX_PAD(0x061C, 0x024C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_17__CCM_PMIC_RDY = IOMUX_PAD(0x061C, 0x024C, 2, 0x07F0, 1, 0), - MX6_PAD_GPIO_17__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x061C, 0x024C, 3, 0x090C, 1, 0), - MX6_PAD_GPIO_17__SPDIF_OUT1 = IOMUX_PAD(0x061C, 0x024C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_17__GPIO_7_12 = IOMUX_PAD(0x061C, 0x024C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_17__CCM_PMIC_READY = IOMUX_PAD(0x061C, 0x024C, 2, 0x07F0, 1, 0), + MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x061C, 0x024C, 3, 0x090C, 1, 0), + MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x061C, 0x024C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x061C, 0x024C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_17__SJC_JTAG_ACT = IOMUX_PAD(0x061C, 0x024C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_18__ESAI1_TX1 = IOMUX_PAD(0x0620, 0x0250, 0, 0x0878, 0, 0), + MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x0620, 0x0250, 0, 0x0878, 0, 0), MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x0620, 0x0250, 1, 0x0844, 1, 0), - MX6_PAD_GPIO_18__USDHC3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x0620, 0x0250, 3, 0x0910, 1, 0), - MX6_PAD_GPIO_18__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), - MX6_PAD_GPIO_18__GPIO_7_13 = IOMUX_PAD(0x0620, 0x0250, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_HP_WRA_SNVS_VIO5 = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0620, 0x0250, 3, 0x0910, 1, 0), + MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), + MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x0620, 0x0250, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), MX6_PAD_GPIO_18__SRC_SYSTEM_RST = IOMUX_PAD(0x0620, 0x0250, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_19__KPP_COL_5 = IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0), + MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SPDIF_OUT1 = IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_19__CCM_CLKO = IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_19__CCM_CLKO1 = IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0), MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_19__GPIO_4_5 = IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0), MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0), MX6_PAD_GPIO_19__SRC_INT_BOOT = IOMUX_PAD(0x0624, 0x0254, 7, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x0628, 0x0258, 0, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__PCIE_CTRL_MUX_12 = IOMUX_PAD(0x0628, 0x0258, 2, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x0628, 0x0258, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__GPIO_5_18 = IOMUX_PAD(0x0628, 0x0258, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x0628, 0x0258, 5, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK___MMDC_DEBUG_29 = IOMUX_PAD(0x0628, 0x0258, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__CHEETAH_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x062C, 0x025C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__PCIE_CTRL_MUX_13 = IOMUX_PAD(0x062C, 0x025C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__CCM_CLKO = IOMUX_PAD(0x062C, 0x025C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x062C, 0x025C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x062C, 0x025C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__GPIO_5_19 = IOMUX_PAD(0x062C, 0x025C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x062C, 0x025C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x062C, 0x025C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__CHEETAH_TRCTL = IOMUX_PAD(0x062C, 0x025C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DA_EN = IOMUX_PAD(0x0630, 0x0260, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__WEIM_WEIM_D_0 = IOMUX_PAD(0x0630, 0x0260, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x062C, 0x025C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x0630, 0x0260, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x0630, 0x0260, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__PCIE_CTRL_MUX_14 = IOMUX_PAD(0x0630, 0x0260, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x0630, 0x0260, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__GPIO_5_20 = IOMUX_PAD(0x0630, 0x0260, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x0630, 0x0260, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__MMDC_DEBUG_31 = IOMUX_PAD(0x0630, 0x0260, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__CHEETAH_TRCLK = IOMUX_PAD(0x0630, 0x0260, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x0630, 0x0260, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x0634, 0x0264, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__WEIM_WEIM_D_1 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__PCIE_CTRL_MUX_15 = IOMUX_PAD(0x0634, 0x0264, 2, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x0634, 0x0264, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__GPIO_5_21 = IOMUX_PAD(0x0634, 0x0264, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x0634, 0x0264, 5, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__MMDC_DEBUG_32 = IOMUX_PAD(0x0634, 0x0264, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__CHEETAH_TRACE_0 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__IPU1_CSI0_D_4 = IOMUX_PAD(0x0638, 0x0268, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__WEIM_WEIM_D_2 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0638, 0x0268, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0638, 0x0268, 2, 0x07F4, 3, 0), - MX6_PAD_CSI0_DAT4__KPP_COL_5 = IOMUX_PAD(0x0638, 0x0268, 3, 0x08E8, 2, 0), - MX6_PAD_CSI0_DAT4__AUDMUX_AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__GPIO_5_22 = IOMUX_PAD(0x0638, 0x0268, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0638, 0x0268, 3, 0x08E8, 2, 0), + MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0638, 0x0268, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__MMDC_DEBUG_43 = IOMUX_PAD(0x0638, 0x0268, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__CHEETAH_TRACE_1 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__IPU1_CSI0_D_5 = IOMUX_PAD(0x063C, 0x026C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__WEIM_WEIM_D_3 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x063C, 0x026C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x063C, 0x026C, 2, 0x07FC, 3, 0), - MX6_PAD_CSI0_DAT5__KPP_ROW_5 = IOMUX_PAD(0x063C, 0x026C, 3, 0x08F4, 1, 0), - MX6_PAD_CSI0_DAT5__AUDMUX_AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__GPIO_5_23 = IOMUX_PAD(0x063C, 0x026C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x063C, 0x026C, 3, 0x08F4, 1, 0), + MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x063C, 0x026C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__MMDC_MMDC_DEBUG_44 = IOMUX_PAD(0x063C, 0x026C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__CHEETAH_TRACE_2 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__IPU1_CSI0_D_6 = IOMUX_PAD(0x0640, 0x0270, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__WEIM_WEIM_D_4 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0640, 0x0270, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0640, 0x0270, 2, 0x07F8, 3, 0), - MX6_PAD_CSI0_DAT6__KPP_COL_6 = IOMUX_PAD(0x0640, 0x0270, 3, 0x08EC, 1, 0), - MX6_PAD_CSI0_DAT6__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__GPIO_5_24 = IOMUX_PAD(0x0640, 0x0270, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0640, 0x0270, 3, 0x08EC, 1, 0), + MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0640, 0x0270, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__MMDC_MMDC_DEBUG_45 = IOMUX_PAD(0x0640, 0x0270, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__CHEETAH_TRACE_3 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__IPU1_CSI0_D_7 = IOMUX_PAD(0x0644, 0x0274, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__WEIM_WEIM_D_5 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0644, 0x0274, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x0274, 2, 0x0800, 3, 0), - MX6_PAD_CSI0_DAT7__KPP_ROW_6 = IOMUX_PAD(0x0644, 0x0274, 3, 0x08F8, 2, 0), - MX6_PAD_CSI0_DAT7__AUDMUX_AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__GPIO_5_25 = IOMUX_PAD(0x0644, 0x0274, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0644, 0x0274, 3, 0x08F8, 2, 0), + MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0644, 0x0274, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__MMDC_MMDC_DEBUG_46 = IOMUX_PAD(0x0644, 0x0274, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__CHEETAH_TRACE_4 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__IPU1_CSI0_D_8 = IOMUX_PAD(0x0648, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__WEIM_WEIM_D_6 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0648, 0x0278, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0648, 0x0278, 2, 0x0810, 2, 0), - MX6_PAD_CSI0_DAT8__KPP_COL_7 = IOMUX_PAD(0x0648, 0x0278, 3, 0x08F0, 2, 0), + MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0648, 0x0278, 3, 0x08F0, 2, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0648, 0x0278, 20, 0x089C, 1, 0), - MX6_PAD_CSI0_DAT8__GPIO_5_26 = IOMUX_PAD(0x0648, 0x0278, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0648, 0x0278, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__MMDC_MMDC_DEBUG_47 = IOMUX_PAD(0x0648, 0x0278, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__CHEETAH_TRACE_5 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__IPU1_CSI0_D_9 = IOMUX_PAD(0x064C, 0x027C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__WEIM_WEIM_D_7 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x064C, 0x027C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x064C, 0x027C, 2, 0x0818, 2, 0), - MX6_PAD_CSI0_DAT9__KPP_ROW_7 = IOMUX_PAD(0x064C, 0x027C, 3, 0x08FC, 2, 0), + MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x064C, 0x027C, 3, 0x08FC, 2, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x064C, 0x027C, 20, 0x0898, 1, 0), - MX6_PAD_CSI0_DAT9__GPIO_5_27 = IOMUX_PAD(0x064C, 0x027C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x064C, 0x027C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__MMDC_MMDC_DEBUG_48 = IOMUX_PAD(0x064C, 0x027C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__CHEETAH_TRACE_6 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__IPU1_CSI0_D_10 = IOMUX_PAD(0x0650, 0x0280, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUDMUX_AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0650, 0x0280, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0650, 0x0280, 2, 0x0814, 2, 0), - MX6_PAD_CSI0_DAT10__UART1_TXD = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_TXD_RXD = IOMUX_PAD(0x0650, 0x0280, 3, 0x0920, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0920, 0, 0), MX6_PAD_CSI0_DAT10__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x0650, 0x0280, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__GPIO_5_28 = IOMUX_PAD(0x0650, 0x0280, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0650, 0x0280, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0650, 0x0280, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__CHEETAH_TRACE_7 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__IPU1_CSI0_D_11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0654, 0x0284, 2, 0x081C, 2, 0), - MX6_PAD_CSI0_DAT11__UART1_RXD = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0654, 0x0284, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__GPIO_5_29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x0654, 0x0284, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__CHEETAH_TRACE_8 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__IPU1_CSI0_D_12 = IOMUX_PAD(0x0658, 0x0288, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__WEIM_WEIM_D_8 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0658, 0x0288, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__PCIE_CTRL_MUX_16 = IOMUX_PAD(0x0658, 0x0288, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TXD = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TXD_RXD = IOMUX_PAD(0x0658, 0x0288, 3, 0x0938, 2, 0), + MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0938, 2, 0), MX6_PAD_CSI0_DAT12__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x0658, 0x0288, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__GPIO_5_30 = IOMUX_PAD(0x0658, 0x0288, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0658, 0x0288, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0658, 0x0288, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__CHEETAH_TRACE_9 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__IPU1_CSI0_D_13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__WEIM_WEIM_D_9 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__PCIE_CTRL_MUX_17 = IOMUX_PAD(0x065C, 0x028C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RXD = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x065C, 0x028C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__GPIO_5_31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x065C, 0x028C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__CHEETAH_TRACE_10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__IPU1_CSI0_D_14 = IOMUX_PAD(0x0660, 0x0290, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__WEIM_WEIM_D_10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0660, 0x0290, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__PCIE_CTRL_MUX_18 = IOMUX_PAD(0x0660, 0x0290, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TXD = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TXD_RXD = IOMUX_PAD(0x0660, 0x0290, 3, 0x0940, 2, 0), + MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0940, 2, 0), MX6_PAD_CSI0_DAT14__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0660, 0x0290, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__GPIO_6_0 = IOMUX_PAD(0x0660, 0x0290, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0660, 0x0290, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0660, 0x0290, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__CHEETAH_TRACE_11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__IPU1_CSI0_D_15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__WEIM_WEIM_D_11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__PCIE_CTRL_MUX_19 = IOMUX_PAD(0x0664, 0x0294, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RXD = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0664, 0x0294, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__GPIO_6_1 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x0664, 0x0294, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__CHEETAH_TRACE_12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__IPU1_CSI0_D_16 = IOMUX_PAD(0x0668, 0x0298, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__WEIM_WEIM_D_12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0668, 0x0298, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__PCIE_CTRL_MUX_20 = IOMUX_PAD(0x0668, 0x0298, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_CTS = IOMUX_PAD(0x0668, 0x0298, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_RTS = IOMUX_PAD(0x0668, 0x0298, 3, 0x0934, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0934, 0, 0), MX6_PAD_CSI0_DAT16__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x0668, 0x0298, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__GPIO_6_2 = IOMUX_PAD(0x0668, 0x0298, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0668, 0x0298, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0668, 0x0298, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__CHEETAH_TRACE_13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__IPU1_CSI0_D_17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__WEIM_WEIM_D_13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__PCIE_CTRL_MUX_21 = IOMUX_PAD(0x066C, 0x029C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_CTS = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), + MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x066C, 0x029C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__GPIO_6_3 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x066C, 0x029C, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__CHEETAH_TRACE_14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__IPU1_CSI0_D_18 = IOMUX_PAD(0x0670, 0x02A0, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__WEIM_WEIM_D_14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0670, 0x02A0, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__PCIE_CTRL_MUX_22 = IOMUX_PAD(0x0670, 0x02A0, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_CTS = IOMUX_PAD(0x0670, 0x02A0, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_RTS = IOMUX_PAD(0x0670, 0x02A0, 3, 0x093C, 2, 0), + MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x093C, 2, 0), MX6_PAD_CSI0_DAT18__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0670, 0x02A0, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__GPIO_6_4 = IOMUX_PAD(0x0670, 0x02A0, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0670, 0x02A0, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__MMDC_MMDC_DEBUG_41 = IOMUX_PAD(0x0670, 0x02A0, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__CHEETAH_TRACE_15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__IPU1_CSI0_D_19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__WEIM_WEIM_D_15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__PCIE_CTRL_MUX_23 = IOMUX_PAD(0x0674, 0x02A4, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_CTS = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), + MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0674, 0x02A4, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__GPIO_6_5 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__MMDC_MMDC_DEBUG_42 = IOMUX_PAD(0x0674, 0x02A4, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__ANATOP_TESTO_9 = IOMUX_PAD(0x0674, 0x02A4, 7, 0x0000, 0, 0), MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x0678, NO_MUX_I, 0, 0x0000, 0, 0), @@ -1269,362 +1269,362 @@ enum { MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_BOOT_MODE0__SRC_BOOT_MODE_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_TEST_MODE__TCU_TEST_MODE = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USDHC3_DAT7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_TXD = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_TXD_RXD = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), + MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), MX6_PAD_SD3_DAT7__PCIE_CTRL_MUX_24 = IOMUX_PAD(0x0690, 0x02A8, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBOH3_UH3_DFD_OUT_0 = IOMUX_PAD(0x0690, 0x02A8, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBOH3_UH2_DFD_OUT_0 = IOMUX_PAD(0x0690, 0x02A8, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__GPIO_6_17 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_IN_12 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBPHY2_CLK20DIV = IOMUX_PAD(0x0690, 0x02A8, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USDHC3_DAT6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_RXD = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0920, 3, 0), + MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0920, 3, 0), MX6_PAD_SD3_DAT6__PCIE_CTRL_MUX_25 = IOMUX_PAD(0x0694, 0x02AC, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0694, 0x02AC, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__USBOH3_UH2_DFD_OUT_1 = IOMUX_PAD(0x0694, 0x02AC, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__GPIO_6_18 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__MIPI_CORE_DPHY_IN_13 = IOMUX_PAD(0x0694, 0x02AC, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__ANATOP_TESTO_10 = IOMUX_PAD(0x0694, 0x02AC, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USDHC3_DAT5 = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_TXD = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_TXD_RXD = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), + MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), MX6_PAD_SD3_DAT5__PCIE_CTRL_MUX_26 = IOMUX_PAD(0x0698, 0x02B0, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__USBOH3_UH3_DFD_OUT_2 = IOMUX_PAD(0x0698, 0x02B0, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__USBOH3_UH2_DFD_OUT_2 = IOMUX_PAD(0x0698, 0x02B0, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__GPIO_7_0 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_IN_14 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__ANATOP_TESTO_11 = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USDHC3_DAT4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_RXD = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0928, 5, 0), + MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0928, 5, 0), MX6_PAD_SD3_DAT4__PCIE_CTRL_MUX_27 = IOMUX_PAD(0x069C, 0x02B4, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x069C, 0x02B4, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__USBOH3_UH2_DFD_OUT_3 = IOMUX_PAD(0x069C, 0x02B4, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__GPIO_7_1 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_IN_15 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__ANATOP_TESTO_12 = IOMUX_PAD(0x069C, 0x02B4, 7, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x06A0, 0x02B8, 16, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_CTS = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0924, 2, 0), - MX6_PAD_SD3_CMD__CAN1_TXCAN = IOMUX_PAD(0x06A0, 0x02B8, 2, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06A0, 0x02B8, 16, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0924, 2, 0), + MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06A0, 0x02B8, 2, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06A0, 0x02B8, 3, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USBOH3_UH2_DFD_OUT_4 = IOMUX_PAD(0x06A0, 0x02B8, 4, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__GPIO_7_2 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), MX6_PAD_SD3_CMD__MIPI_CORE_DPHY_IN_16 = IOMUX_PAD(0x06A0, 0x02B8, 6, 0x0000, 0, 0), MX6_PAD_SD3_CMD__ANATOP_TESTO_13 = IOMUX_PAD(0x06A0, 0x02B8, 7, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x06A4, 0x02BC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_CTS = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_RTS = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0924, 3, 0), - MX6_PAD_SD3_CLK__CAN1_RXCAN = IOMUX_PAD(0x06A4, 0x02BC, 2, 0x07E4, 2, 0), + MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06A4, 0x02BC, 0, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0924, 3, 0), + MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06A4, 0x02BC, 2, 0x07E4, 2, 0), MX6_PAD_SD3_CLK__USBOH3_UH3_DFD_OUT_5 = IOMUX_PAD(0x06A4, 0x02BC, 3, 0x0000, 0, 0), MX6_PAD_SD3_CLK__USBOH3_UH2_DFD_OUT_5 = IOMUX_PAD(0x06A4, 0x02BC, 4, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__GPIO_7_3 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_IN_17 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), MX6_PAD_SD3_CLK__ANATOP_TESTO_14 = IOMUX_PAD(0x06A4, 0x02BC, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 = IOMUX_PAD(0x06A8, 0x02C0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_CTS = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x091C, 2, 0), - MX6_PAD_SD3_DAT0__CAN2_TXCAN = IOMUX_PAD(0x06A8, 0x02C0, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06A8, 0x02C0, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x091C, 2, 0), + MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06A8, 0x02C0, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06A8, 0x02C0, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USBOH3_UH2_DFD_OUT_6 = IOMUX_PAD(0x06A8, 0x02C0, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__GPIO_7_4 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__MIPI_CORE_DPHY_IN_18 = IOMUX_PAD(0x06A8, 0x02C0, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__ANATOP_TESTO_15 = IOMUX_PAD(0x06A8, 0x02C0, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_CTS = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_RTS = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x091C, 3, 0), - MX6_PAD_SD3_DAT1__CAN2_RXCAN = IOMUX_PAD(0x06AC, 0x02C4, 2, 0x07E8, 1, 0), + MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x091C, 3, 0), + MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x06AC, 0x02C4, 2, 0x07E8, 1, 0), MX6_PAD_SD3_DAT1__USBOH3_UH3_DFD_OUT_7 = IOMUX_PAD(0x06AC, 0x02C4, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__USBOH3_UH2_DFD_OUT_7 = IOMUX_PAD(0x06AC, 0x02C4, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__GPIO_7_5 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__MIPI_CORE_DPHY_IN_19 = IOMUX_PAD(0x06AC, 0x02C4, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__ANATOP_TESTI_0 = IOMUX_PAD(0x06AC, 0x02C4, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__PCIE_CTRL_MUX_28 = IOMUX_PAD(0x06B0, 0x02C8, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__USBOH3_UH3_DFD_OUT_8 = IOMUX_PAD(0x06B0, 0x02C8, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__USBOH3_UH2_DFD_OUT_8 = IOMUX_PAD(0x06B0, 0x02C8, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__GPIO_7_6 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_IN_20 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__ANATOP_TESTI_1 = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_CTS = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x092C, 4, 0), + MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x092C, 4, 0), MX6_PAD_SD3_DAT3__PCIE_CTRL_MUX_29 = IOMUX_PAD(0x06B4, 0x02CC, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x06B4, 0x02CC, 3, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USBOH3_UH2_DFD_OUT_9 = IOMUX_PAD(0x06B4, 0x02CC, 4, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__GPIO_7_7 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__MIPI_CORE_DPHY_IN_21 = IOMUX_PAD(0x06B4, 0x02CC, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__ANATOP_TESTI_2 = IOMUX_PAD(0x06B4, 0x02CC, 7, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USDHC3_RST = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_CTS = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_RTS = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x092C, 5, 0), + MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x092C, 5, 0), MX6_PAD_SD3_RST__PCIE_CTRL_MUX_30 = IOMUX_PAD(0x06B8, 0x02D0, 2, 0x0000, 0, 0), MX6_PAD_SD3_RST__USBOH3_UH3_DFD_OUT_10 = IOMUX_PAD(0x06B8, 0x02D0, 3, 0x0000, 0, 0), MX6_PAD_SD3_RST__USBOH3_UH2_DFD_OUT_10 = IOMUX_PAD(0x06B8, 0x02D0, 4, 0x0000, 0, 0), - MX6_PAD_SD3_RST__GPIO_7_8 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), + MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), MX6_PAD_SD3_RST__MIPI_CORE_DPHY_IN_22 = IOMUX_PAD(0x06B8, 0x02D0, 6, 0x0000, 0, 0), MX6_PAD_SD3_RST__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x06B8, 0x02D0, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__RAWNAND_CLE = IOMUX_PAD(0x06BC, 0x02D4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__IPU2_SISG_4 = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x06BC, 0x02D4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__IPU2_SISG4 = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__PCIE_CTRL_MUX_31 = IOMUX_PAD(0x06BC, 0x02D4, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__USBOH3_UH3_DFD_OT11 = IOMUX_PAD(0x06BC, 0x02D4, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__USBOH3_UH2_DFD_OT11 = IOMUX_PAD(0x06BC, 0x02D4, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__GPIO_6_7 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__MIPI_CORE_DPHY_IN23 = IOMUX_PAD(0x06BC, 0x02D4, 6, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__TPSMP_HTRANS_0 = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__RAWNAND_ALE = IOMUX_PAD(0x06C0, 0x02D8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USDHC4_RST = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x06C0, 0x02D8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__PCIE_CTRL_MUX_0 = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__USBOH3_UH3_DFD_OT12 = IOMUX_PAD(0x06C0, 0x02D8, 3, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__USBOH3_UH2_DFD_OT12 = IOMUX_PAD(0x06C0, 0x02D8, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__GPIO_6_8 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__MIPI_CR_DPHY_IN_24 = IOMUX_PAD(0x06C0, 0x02D8, 6, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__TPSMP_HTRANS_1 = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__RAWNAND_RESETN = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__IPU2_SISG_5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__IPU2_SISG5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__PCIE_CTRL__MUX_1 = IOMUX_PAD(0x06C4, 0x02DC, 2, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USBOH3_UH3_DFDOT13 = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USBOH3_UH2_DFDOT13 = IOMUX_PAD(0x06C4, 0x02DC, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__GPIO_6_9 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__MIPI_CR_DPHY_OUT32 = IOMUX_PAD(0x06C4, 0x02DC, 6, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__PL301_PER1_HSIZE_0 = IOMUX_PAD(0x06C4, 0x02DC, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__RAWNAND_READY0 = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__IPU2_DI0_PIN1 = IOMUX_PAD(0x06C8, 0x02E0, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__IPU2_DI0_PIN01 = IOMUX_PAD(0x06C8, 0x02E0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__PCIE_CTRL_MUX_2 = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__USBOH3_UH3_DFD_OT14 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__USBOH3_UH2_DFD_OT14 = IOMUX_PAD(0x06C8, 0x02E0, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__GPIO_6_10 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__MIPI_CR_DPHY_OUT_33 = IOMUX_PAD(0x06C8, 0x02E0, 6, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__PL301_PER1_HSIZE_1 = IOMUX_PAD(0x06C8, 0x02E0, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__RAWNAND_CE0N = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__USBOH3_UH3_DFD_OT15 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__USBOH3_UH2_DFD_OT15 = IOMUX_PAD(0x06CC, 0x02E4, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__GPIO_6_11 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__PL301_PER1_HSIZE_2 = IOMUX_PAD(0x06CC, 0x02E4, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__RAWNAND_CE1N = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__USDHC4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__USDHC3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__PCIE_CTRL_MUX_3 = IOMUX_PAD(0x06D0, 0x02E8, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__GPIO_6_14 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__PL301_PER1_HRDYOUT = IOMUX_PAD(0x06D0, 0x02E8, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__RAWNAND_CE2N = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU1_SISG_0 = IOMUX_PAD(0x06D4, 0x02EC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__ESAI1_TX0 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0874, 1, 0), - MX6_PAD_NANDF_CS2__WEIM_WEIM_CRE = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0874, 1, 0), + MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__GPIO_6_15 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU2_SISG_0 = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__RAWNAND_CE3N = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU1_SISG_1 = IOMUX_PAD(0x06D8, 0x02F0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__ESAI1_TX1 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0878, 1, 0), - MX6_PAD_NANDF_CS3__WEIM_WEIM_A_26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__IPU2_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0878, 1, 0), + MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__PCIE_CTRL_MUX_4 = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__GPIO_6_16 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU2_SISG_1 = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__IPU2_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__TPSMP_CLK = IOMUX_PAD(0x06D8, 0x02F0, 7, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__USDHC4_CMD = IOMUX_PAD(0x06DC, 0x02F4, 16, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__RAWNAND_RDN = IOMUX_PAD(0x06DC, 0x02F4, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_TXD = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_TXD_RXD = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0930, 2, 0), + MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x06DC, 0x02F4, 16, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x06DC, 0x02F4, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0930, 2, 0), MX6_PAD_SD4_CMD__PCIE_CTRL_MUX_5 = IOMUX_PAD(0x06DC, 0x02F4, 4, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__GPIO_7_9 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), MX6_PAD_SD4_CMD__TPSMP_HDATA_DIR = IOMUX_PAD(0x06DC, 0x02F4, 7, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__USDHC4_CLK = IOMUX_PAD(0x06E0, 0x02F8, 0, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__RAWNAND_WRN = IOMUX_PAD(0x06E0, 0x02F8, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_RXD = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0930, 3, 0), + MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x06E0, 0x02F8, 0, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x06E0, 0x02F8, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0930, 3, 0), MX6_PAD_SD4_CLK__PCIE_CTRL_MUX_6 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__GPIO_7_10 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__RAWNAND_D0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USDHC1_DAT4 = IOMUX_PAD(0x06E4, 0x02FC, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x06E4, 0x02FC, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D0__GPU3D_GPU_DBG_OUT_0 = IOMUX_PAD(0x06E4, 0x02FC, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D0__USBOH3_UH2_DFD_OUT16 = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D0__USBOH3_UH3_DFD_OUT16 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPIO_2_0 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D0__IPU1_IPU_DIAG_BUS_0 = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D0__IPU2_IPU_DIAG_BUS_0 = IOMUX_PAD(0x06E4, 0x02FC, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__RAWNAND_D1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USDHC1_DAT5 = IOMUX_PAD(0x06E8, 0x0300, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x06E8, 0x0300, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D1__GPU3D_GPU_DEBUG_OUT1 = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D1__USBOH3_UH2_DFD_OUT17 = IOMUX_PAD(0x06E8, 0x0300, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D1__USBOH3_UH3_DFD_OUT17 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPIO_2_1 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D1__IPU1_IPU_DIAG_BUS_1 = IOMUX_PAD(0x06E8, 0x0300, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D1__IPU2_IPU_DIAG_BUS_1 = IOMUX_PAD(0x06E8, 0x0300, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__RAWNAND_D2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USDHC1_DAT6 = IOMUX_PAD(0x06EC, 0x0304, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x06EC, 0x0304, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D2__GPU3D_GPU_DBG_OUT_2 = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D2__USBOH3_UH2_DFD_OUT18 = IOMUX_PAD(0x06EC, 0x0304, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D2__USBOH3_UH3_DFD_OUT18 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPIO_2_2 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D2__IPU1_IPU_DIAG_BUS_2 = IOMUX_PAD(0x06EC, 0x0304, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D2__IPU2_IPU_DIAG_BUS_2 = IOMUX_PAD(0x06EC, 0x0304, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__RAWNAND_D3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USDHC1_DAT7 = IOMUX_PAD(0x06F0, 0x0308, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x06F0, 0x0308, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D3__GPU3D_GPU_DBG_OUT_3 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D3__USBOH3_UH2_DFD_OUT19 = IOMUX_PAD(0x06F0, 0x0308, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D3__USBOH3_UH3_DFD_OUT19 = IOMUX_PAD(0x06F0, 0x0308, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPIO_2_3 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D3__IPU1_IPU_DIAG_BUS_3 = IOMUX_PAD(0x06F0, 0x0308, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D3__IPU2_IPU_DIAG_BUS_3 = IOMUX_PAD(0x06F0, 0x0308, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__RAWNAND_D4 = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USDHC2_DAT4 = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D4__GPU3D_GPU_DBG_OUT_4 = IOMUX_PAD(0x06F4, 0x030C, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D4__USBOH3_UH2_DFD_OUT20 = IOMUX_PAD(0x06F4, 0x030C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D4__USBOH3_UH3_DFD_OUT20 = IOMUX_PAD(0x06F4, 0x030C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPIO_2_4 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D4__IPU1_IPU_DIAG_BUS_4 = IOMUX_PAD(0x06F4, 0x030C, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D4__IPU2_IPU_DIAG_BUS_4 = IOMUX_PAD(0x06F4, 0x030C, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__RAWNAND_D5 = IOMUX_PAD(0x06F8, 0x0310, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USDHC2_DAT5 = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x06F8, 0x0310, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D5__GPU3D_GPU_DBG_OUT_5 = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D5__USBOH3_UH2_DFD_OUT21 = IOMUX_PAD(0x06F8, 0x0310, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D5__USBOH3_UH3_DFD_OUT21 = IOMUX_PAD(0x06F8, 0x0310, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPIO_2_5 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D5__IPU1_IPU_DIAG_BUS_5 = IOMUX_PAD(0x06F8, 0x0310, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D5__IPU2_IPU_DIAG_BUS_5 = IOMUX_PAD(0x06F8, 0x0310, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__RAWNAND_D6 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USDHC2_DAT6 = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D6__GPU3D_GPU_DBG_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D6__USBOH3_UH2_DFD_OUT22 = IOMUX_PAD(0x06FC, 0x0314, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D6__USBOH3_UH3_DFD_OUT22 = IOMUX_PAD(0x06FC, 0x0314, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPIO_2_6 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D6__IPU1_IPU_DIAG_BUS_6 = IOMUX_PAD(0x06FC, 0x0314, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D6__IPU2_IPU_DIAG_BUS_6 = IOMUX_PAD(0x06FC, 0x0314, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__RAWNAND_D7 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USDHC2_DAT7 = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D7__GPU3D_GPU_DBG_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 2, 0x0000, 0, 0), MX6_PAD_NANDF_D7__USBOH3_UH2_DFD_OUT23 = IOMUX_PAD(0x0700, 0x0318, 3, 0x0000, 0, 0), MX6_PAD_NANDF_D7__USBOH3_UH3_DFD_OUT23 = IOMUX_PAD(0x0700, 0x0318, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPIO_2_7 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D7__IPU1_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0700, 0x0318, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D7__IPU2_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0700, 0x0318, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__RAWNAND_D8 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 = IOMUX_PAD(0x0704, 0x031C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__RAWNAND_DQS = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0704, 0x031C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__USBOH3_UH2_DFD_OUT24 = IOMUX_PAD(0x0704, 0x031C, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__USBOH3_UH3_DFD_OUT24 = IOMUX_PAD(0x0704, 0x031C, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__GPIO_2_8 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__IPU1_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0704, 0x031C, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__IPU2_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0704, 0x031C, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__RAWNAND_D9 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__PWM3_PWMO = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__USBOH3_UH2_DFD_OUT25 = IOMUX_PAD(0x0708, 0x0320, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__USBOH3_UH3_DFD_OUT25 = IOMUX_PAD(0x0708, 0x0320, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__GPIO_2_9 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__IPU1_IPU_DIAG_BUS_9 = IOMUX_PAD(0x0708, 0x0320, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__IPU2_IPU_DIAG_BUS_9 = IOMUX_PAD(0x0708, 0x0320, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__RAWNAND_D10 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__PWM4_PWMO = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__USBOH3_UH2_DFD_OUT26 = IOMUX_PAD(0x070C, 0x0324, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__USBOH3_UH3_DFD_OUT26 = IOMUX_PAD(0x070C, 0x0324, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__GPIO_2_10 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__IPU1_IPU_DIAG_BUS_10 = IOMUX_PAD(0x070C, 0x0324, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__IPU2_IPU_DIAG_BUS_10 = IOMUX_PAD(0x070C, 0x0324, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__RAWNAND_D11 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__USBOH3_UH2_DFD_OUT27 = IOMUX_PAD(0x0710, 0x0328, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__USBOH3_UH3_DFD_OUT27 = IOMUX_PAD(0x0710, 0x0328, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__GPIO_2_11 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__IPU1_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0710, 0x0328, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__IPU2_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__USDHC4_DAT4 = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_RXD = IOMUX_PAD(0x0714, 0x032C, 2, 0x0928, 6, 0), + MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0928, 6, 0), MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__GPIO_2_12 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__IPU1_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0714, 0x032C, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__IPU2_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0714, 0x032C, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__RAWNAND_D13 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__USDHC4_DAT5 = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_CTS = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_RTS = IOMUX_PAD(0x0718, 0x0330, 2, 0x0924, 4, 0), + MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0924, 4, 0), MX6_PAD_SD4_DAT5__USBOH3_UH2_DFD_OUT29 = IOMUX_PAD(0x0718, 0x0330, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__USBOH3_UH3_DFD_OUT29 = IOMUX_PAD(0x0718, 0x0330, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__GPIO_2_13 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__IPU1_IPU_DIAG_BUS_13 = IOMUX_PAD(0x0718, 0x0330, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__IPU2_IPU_DIAG_BUS_13 = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__USDHC4_DAT6 = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_CTS = IOMUX_PAD(0x071C, 0x0334, 2, 0x0924, 5, 0), + MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0924, 5, 0), MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__GPIO_2_14 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__IPU1_IPU_DIAG_BUS_14 = IOMUX_PAD(0x071C, 0x0334, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__IPU2_IPU_DIAG_BUS_14 = IOMUX_PAD(0x071C, 0x0334, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__RAWNAND_D15 = IOMUX_PAD(0x0720, 0x0338, 0, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__USDHC4_DAT7 = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_TXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_TXD_RXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), + MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), MX6_PAD_SD4_DAT7__USBOH3_UH2_DFD_OUT31 = IOMUX_PAD(0x0720, 0x0338, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__USBOH3_UH3_DFD_OUT31 = IOMUX_PAD(0x0720, 0x0338, 4, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__GPIO_2_15 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__IPU1_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0720, 0x0338, 6, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__IPU2_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0720, 0x0338, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__USDHC1_DAT1 = IOMUX_PAD(0x0724, 0x033C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x0724, 0x033C, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0724, 0x033C, 1, 0x0834, 1, 0), - MX6_PAD_SD1_DAT1__PWM3_PWMO = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPT_CAPIN2 = IOMUX_PAD(0x0724, 0x033C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x0724, 0x033C, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__PCIE_CTRL_MUX_7 = IOMUX_PAD(0x0724, 0x033C, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPIO_1_17 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__HDMI_TX_OPHYDTB_0 = IOMUX_PAD(0x0724, 0x033C, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__ANATOP_TESTO_8 = IOMUX_PAD(0x0724, 0x033C, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__USDHC1_DAT0 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0728, 0x0340, 1, 0x082C, 1, 0), MX6_PAD_SD1_DAT0__CAAM_WRAP_RNG_OSCOBS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPT_CAPIN1 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__PCIE_CTRL_MUX_8 = IOMUX_PAD(0x0728, 0x0340, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPIO_1_16 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__HDMI_TX_OPHYDTB_1 = IOMUX_PAD(0x0728, 0x0340, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__ANATOP_TESTO_7 = IOMUX_PAD(0x0728, 0x0340, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__USDHC1_DAT3 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__ECSPI5_SS2 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPT_CMPOUT3 = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__PWM1_PWMO = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_WDOG_B = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPIO_1_21 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__PWM1_OUT = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__ANATOP_TESTO_6 = IOMUX_PAD(0x072C, 0x0344, 7, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x0730, 0x0348, 16, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x0730, 0x0348, 16, 0x0000, 0, 0), MX6_PAD_SD1_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0730, 0x0348, 1, 0x0830, 0, 0), - MX6_PAD_SD1_CMD__PWM4_PWMO = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPT_CMPOUT1 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPIO_1_18 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), MX6_PAD_SD1_CMD__ANATOP_TESTO_5 = IOMUX_PAD(0x0730, 0x0348, 7, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__USDHC1_DAT2 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0838, 1, 0), - MX6_PAD_SD1_DAT2__GPT_CMPOUT2 = IOMUX_PAD(0x0734, 0x034C, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__PWM2_PWMO = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_WDOG_B = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPIO_1_19 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x0734, 0x034C, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__PWM2_OUT = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__ANATOP_TESTO_4 = IOMUX_PAD(0x0734, 0x034C, 7, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), MX6_PAD_SD1_CLK__ECSPI5_SCLK = IOMUX_PAD(0x0738, 0x0350, 1, 0x0828, 0, 0), MX6_PAD_SD1_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__GPIO_1_20 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), MX6_PAD_SD1_CLK__PHY_DTB_0 = IOMUX_PAD(0x0738, 0x0350, 6, 0x0000, 0, 0), MX6_PAD_SD1_CLK__SATA_PHY_DTB_0 = IOMUX_PAD(0x0738, 0x0350, 7, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), MX6_PAD_SD2_CLK__ECSPI5_SCLK = IOMUX_PAD(0x073C, 0x0354, 1, 0x0828, 1, 0), - MX6_PAD_SD2_CLK__KPP_COL_5 = IOMUX_PAD(0x073C, 0x0354, 2, 0x08E8, 3, 0), - MX6_PAD_SD2_CLK__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), + MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x073C, 0x0354, 2, 0x08E8, 3, 0), + MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), MX6_PAD_SD2_CLK__PCIE_CTRL_MUX_9 = IOMUX_PAD(0x073C, 0x0354, 4, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__GPIO_1_10 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), MX6_PAD_SD2_CLK__PHY_DTB_1 = IOMUX_PAD(0x073C, 0x0354, 6, 0x0000, 0, 0), MX6_PAD_SD2_CLK__SATA_PHY_DTB_1 = IOMUX_PAD(0x073C, 0x0354, 7, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0740, 0x0358, 16, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x0740, 0x0358, 16, 0x0000, 0, 0), MX6_PAD_SD2_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0740, 0x0358, 1, 0x0830, 1, 0), - MX6_PAD_SD2_CMD__KPP_ROW_5 = IOMUX_PAD(0x0740, 0x0358, 2, 0x08F4, 2, 0), - MX6_PAD_SD2_CMD__AUDMUX_AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), + MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x0740, 0x0358, 2, 0x08F4, 2, 0), + MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), MX6_PAD_SD2_CMD__PCIE_CTRL_MUX_10 = IOMUX_PAD(0x0740, 0x0358, 4, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__GPIO_1_11 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__USDHC2_DAT3 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__ECSPI5_SS3 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__KPP_COL_6 = IOMUX_PAD(0x0744, 0x035C, 2, 0x08EC, 2, 0), - MX6_PAD_SD2_DAT3__AUDMUX_AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), + MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x0744, 0x035C, 2, 0x08EC, 2, 0), + MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), MX6_PAD_SD2_DAT3__PCIE_CTRL_MUX_11 = IOMUX_PAD(0x0744, 0x035C, 4, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__GPIO_1_12 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SJC_DONE = IOMUX_PAD(0x0744, 0x035C, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__ANATOP_TESTO_3 = IOMUX_PAD(0x0744, 0x035C, 7, 0x0000, 0, 0), }; diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index 6025eb7..419990a 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -45,18 +45,18 @@ int dram_init(void) }
iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_SD3_DAT6__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD3_DAT7__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
iomux_v3_cfg_t const uart2_pads[] = { - MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
iomux_v3_cfg_t const uart4_pads[] = { - MX6_PAD_CSI0_DAT12__UART4_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_CSI0_DAT13__UART4_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT12__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) @@ -64,12 +64,12 @@ iomux_v3_cfg_t const uart4_pads[] = { struct i2c_pads_info i2c_pad_info0 = { .scl = { .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO_5_27 | PC, + .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC, .gp = IMX_GPIO_NR(5, 27) }, .sda = { .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO_5_26 | PC, + .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, .gp = IMX_GPIO_NR(5, 26) } }; @@ -77,81 +77,81 @@ struct i2c_pads_info i2c_pad_info0 = { struct i2c_pads_info i2c_pad_info2 = { .scl = { .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_3__GPIO_1_3 | PC, + .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC, .gp = IMX_GPIO_NR(1, 3) }, .sda = { .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_GPIO_16__GPIO_7_11 | PC, + .gpio_mode = MX6_PAD_GPIO_16__GPIO7_IO11 | PC, .gp = IMX_GPIO_NR(7, 11) } };
iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__GPIO_7_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
iomux_v3_cfg_t const enet_pads1[] = { MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), /* pin 35 - 1 (PHY_AD2) on reset */ - MX6_PAD_RGMII_RXC__GPIO_6_30 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RXC__GPIO6_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 32 - 1 - (MODE0) all */ - MX6_PAD_RGMII_RD0__GPIO_6_25 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD0__GPIO6_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 31 - 1 - (MODE1) all */ - MX6_PAD_RGMII_RD1__GPIO_6_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 28 - 1 - (MODE2) all */ - MX6_PAD_RGMII_RD2__GPIO_6_28 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD2__GPIO6_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 27 - 1 - (MODE3) all */ - MX6_PAD_RGMII_RD3__GPIO_6_29 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD3__GPIO6_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 42 PHY nRST */ - MX6_PAD_EIM_D23__GPIO_3_23 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D23__GPIO3_IO23 | MUX_PAD_CTRL(NO_PAD_CTRL), };
iomux_v3_cfg_t const enet_pads2[] = { - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), };
iomux_v3_cfg_t nfc_pads[] = { - MX6_PAD_NANDF_CLE__RAWNAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_ALE__RAWNAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_WP_B__RAWNAND_RESETN | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_RB0__RAWNAND_READY0 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_CS0__RAWNAND_CE0N | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_CS1__RAWNAND_CE1N | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_CS2__RAWNAND_CE2N | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_CS3__RAWNAND_CE3N | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_SD4_CMD__RAWNAND_RDN | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_SD4_CLK__RAWNAND_WRN | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D0__RAWNAND_D0 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D1__RAWNAND_D1 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D2__RAWNAND_D2 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D3__RAWNAND_D3 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D4__RAWNAND_D4 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D5__RAWNAND_D5 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D6__RAWNAND_D6 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_NANDF_D7__RAWNAND_D7 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_SD4_DAT0__RAWNAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS2__NAND_CE2_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS3__NAND_CE3_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void setup_gpmi_nand(void) diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 53cb8df..616ad55 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -71,13 +71,13 @@ int dram_init(void) }
#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) @@ -86,12 +86,12 @@ iomux_v3_cfg_t const uart2_pads[] = { struct i2c_pads_info i2c_pad_info0 = { .scl = { .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_EIM_D21__GPIO_3_21 | PC, + .gpio_mode = MX6_PAD_EIM_D21__GPIO3_IO21 | PC, .gp = IMX_GPIO_NR(3, 21) }, .sda = { .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D28__GPIO_3_28 | PC, + .gpio_mode = MX6_PAD_EIM_D28__GPIO3_IO28 | PC, .gp = IMX_GPIO_NR(3, 28) } }; @@ -100,12 +100,12 @@ struct i2c_pads_info i2c_pad_info0 = { struct i2c_pads_info i2c_pad_info1 = { .scl = { .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_KEY_COL3__GPIO_4_12 | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC, .gp = IMX_GPIO_NR(4, 12) }, .sda = { .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO_4_13 | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, .gp = IMX_GPIO_NR(4, 13) } }; @@ -114,87 +114,87 @@ struct i2c_pads_info i2c_pad_info1 = { struct i2c_pads_info i2c_pad_info2 = { .scl = { .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_5__GPIO_1_5 | PC, + .gpio_mode = MX6_PAD_GPIO_5__GPIO1_IO05 | PC, .gp = IMX_GPIO_NR(1, 5) }, .sda = { .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_GPIO_16__GPIO_7_11 | PC, + .gpio_mode = MX6_PAD_GPIO_16__GPIO7_IO11 | PC, .gp = IMX_GPIO_NR(7, 11) } };
iomux_v3_cfg_t const usdhc4_pads[] = { - MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D6__GPIO_2_6 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
iomux_v3_cfg_t const enet_pads1[] = { MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), /* pin 35 - 1 (PHY_AD2) on reset */ - MX6_PAD_RGMII_RXC__GPIO_6_30 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RXC__GPIO6_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 32 - 1 - (MODE0) all */ - MX6_PAD_RGMII_RD0__GPIO_6_25 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD0__GPIO6_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 31 - 1 - (MODE1) all */ - MX6_PAD_RGMII_RD1__GPIO_6_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 28 - 1 - (MODE2) all */ - MX6_PAD_RGMII_RD2__GPIO_6_28 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD2__GPIO6_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 27 - 1 - (MODE3) all */ - MX6_PAD_RGMII_RD3__GPIO_6_29 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RD3__GPIO6_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL), /* pin 42 PHY nRST */ - MX6_PAD_EIM_D23__GPIO_3_23 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_ENET_RXD0__GPIO_1_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D23__GPIO3_IO23 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static iomux_v3_cfg_t const misc_pads[] = { MX6_PAD_GPIO_1__USB_OTG_ID | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_KEY_COL4__USBOH3_USBOTG_OC | MUX_PAD_CTRL(WEAK_PULLUP), - MX6_PAD_EIM_D30__USBOH3_USBH1_OC | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_KEY_COL4__USB_OTG_OC | MUX_PAD_CTRL(WEAK_PULLUP), + MX6_PAD_EIM_D30__USB_H1_OC | MUX_PAD_CTRL(WEAK_PULLUP), /* OTG Power enable */ - MX6_PAD_EIM_D22__GPIO_3_22 | MUX_PAD_CTRL(OUTPUT_40OHM), + MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(OUTPUT_40OHM), };
/* wl1271 pads on nitrogen6x */ iomux_v3_cfg_t const wl12xx_pads[] = { - (MX6_PAD_NANDF_CS1__GPIO_6_14 & ~MUX_PAD_CTRL_MASK) + (MX6_PAD_NANDF_CS1__GPIO6_IO14 & ~MUX_PAD_CTRL_MASK) | MUX_PAD_CTRL(WEAK_PULLDOWN), - (MX6_PAD_NANDF_CS2__GPIO_6_15 & ~MUX_PAD_CTRL_MASK) + (MX6_PAD_NANDF_CS2__GPIO6_IO15 & ~MUX_PAD_CTRL_MASK) | MUX_PAD_CTRL(OUTPUT_40OHM), - (MX6_PAD_NANDF_CS3__GPIO_6_16 & ~MUX_PAD_CTRL_MASK) + (MX6_PAD_NANDF_CS3__GPIO6_IO16 & ~MUX_PAD_CTRL_MASK) | MUX_PAD_CTRL(OUTPUT_40OHM), }; #define WL12XX_WL_IRQ_GP IMX_GPIO_NR(6, 14) @@ -204,17 +204,17 @@ iomux_v3_cfg_t const wl12xx_pads[] = { /* Button assignments for J14 */ static iomux_v3_cfg_t const button_pads[] = { /* Menu */ - MX6_PAD_NANDF_D1__GPIO_2_1 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_NANDF_D1__GPIO2_IO01 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), /* Back */ - MX6_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), /* Labelled Search (mapped to Power under Android) */ - MX6_PAD_NANDF_D3__GPIO_2_3 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_NANDF_D3__GPIO2_IO03 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), /* Home */ - MX6_PAD_NANDF_D4__GPIO_2_4 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), /* Volume Down */ - MX6_PAD_GPIO_19__GPIO_4_5 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), /* Volume Up */ - MX6_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + MX6_PAD_GPIO_18__GPIO7_IO13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), };
static void setup_iomux_enet(void) @@ -238,7 +238,7 @@ static void setup_iomux_enet(void) }
iomux_v3_cfg_t const usb_pads[] = { - MX6_PAD_GPIO_17__GPIO_7_12 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void setup_iomux_uart(void) @@ -330,7 +330,7 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_MXC_SPI iomux_v3_cfg_t const ecspi1_pads[] = { /* SS1 */ - MX6_PAD_EIM_D19__GPIO_3_19 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D19__GPIO3_IO19 | MUX_PAD_CTRL(SPI_PAD_CTRL), MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), @@ -431,44 +431,44 @@ int setup_sata(void)
static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight on RGB connector: J15 */ - MX6_PAD_SD1_DAT3__GPIO_1_21 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD1_DAT3__GPIO1_IO21 | MUX_PAD_CTRL(NO_PAD_CTRL), #define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21)
/* Backlight on LVDS connector: J6 */ - MX6_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD1_CMD__GPIO1_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), #define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) };
static iomux_v3_cfg_t const rgb_pads[] = { MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2, - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3, - MX6_PAD_DI0_PIN4__GPIO_4_20, - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0, - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1, - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2, - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3, - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4, - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5, - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6, - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7, - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8, - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9, - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10, - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11, - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12, - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13, - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14, - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15, - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16, - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17, - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18, - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19, - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20, - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21, - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22, - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02, + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03, + MX6_PAD_DI0_PIN4__GPIO4_IO20, + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00, + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01, + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02, + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03, + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04, + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05, + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06, + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07, + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08, + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09, + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10, + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11, + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12, + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13, + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14, + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15, + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16, + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17, + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18, + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19, + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20, + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21, + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22, + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23, };
struct display_info_t { diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 1ea68f4..7492534 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -35,32 +35,32 @@ int dram_init(void) }
iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_GPIO_4__GPIO_1_4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
iomux_v3_cfg_t const usdhc4_pads[] = { - MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT4__USDHC4_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT5__USDHC4_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT6__USDHC4_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT7__USDHC4_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D6__GPIO_2_6 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D6__GPIO2_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
static void setup_iomux_uart(void) diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index 05c938f..1b4791c 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -38,52 +38,52 @@ int dram_init(void) }
iomux_v3_cfg_t const uart4_pads[] = { - MX6_PAD_KEY_COL0__UART4_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_KEY_ROW0__UART4_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__USDHC3_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__USDHC3_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__USDHC3_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__USDHC3_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_CS0__GPIO_6_11 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_CS0__GPIO6_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
iomux_v3_cfg_t const usdhc4_pads[] = { - MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT4__USDHC4_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT5__USDHC4_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT6__USDHC4_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT7__USDHC4_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
iomux_v3_cfg_t const enet_pads[] = { MX6_PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), };
diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index c55ee87..1cf649c 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -51,25 +51,25 @@ int dram_init(void) }
@@ -77,12 +77,12 @@ iomux_v3_cfg_t const enet_pads[] = { struct i2c_pads_info i2c_pad_info1 = { .scl = { .i2c_mode = MX6_PAD_EIM_EB2__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_EIM_EB2__GPIO_2_30 | PC, + .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | PC, .gp = IMX_GPIO_NR(2, 30) }, .sda = { .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO_4_13 | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, .gp = IMX_GPIO_NR(4, 13) } }; @@ -94,22 +94,22 @@ struct i2c_pads_info i2c_pad_info1 = { struct i2c_pads_info i2c_pad_info2 = { .scl = { .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_3__GPIO_1_3 | PC, + .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC, .gp = IMX_GPIO_NR(1, 3) }, .sda = { .i2c_mode = MX6_PAD_EIM_D18__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D18__GPIO_3_18 | PC, + .gpio_mode = MX6_PAD_EIM_D18__GPIO3_IO18 | PC, .gp = IMX_GPIO_NR(3, 18) } };
iomux_v3_cfg_t const i2c3_pads[] = { - MX6_PAD_EIM_A24__GPIO_5_4 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), };
iomux_v3_cfg_t const port_exp[] = { - MX6_PAD_SD2_DAT0__GPIO_1_15 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void setup_iomux_enet(void) @@ -118,18 +118,18 @@ static void setup_iomux_enet(void) }
iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__USDHC3_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__USDHC3_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__USDHC3_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__USDHC3_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_GPIO_18__USDHC3_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_CS2__GPIO_6_15 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_GPIO_18__SD3_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void setup_iomux_uart(void) diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 9dbe605..1ecedac 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -45,28 +45,28 @@ int dram_init(void) }
iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_CSI0_DAT10__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
iomux_v3_cfg_t const enet_pads[] = { MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), /* AR8031 PHY Reset */ - MX6_PAD_ENET_CRS_DV__GPIO_1_25 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void setup_iomux_enet(void) @@ -80,44 +80,44 @@ static void setup_iomux_enet(void) }
iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D4__USDHC2_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D5__USDHC2_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D6__USDHC2_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D7__USDHC2_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D4__SD2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D5__SD2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D6__SD2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D7__SD2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__USDHC3_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__USDHC3_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__USDHC3_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__USDHC3_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D0__GPIO_2_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
static void setup_iomux_uart(void) diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index e9d6375..ab7b655 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -40,22 +40,22 @@ int dram_init(void) }
static iomux_v3_cfg_t const uart2_pads[] = { - MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
static iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
static iomux_v3_cfg_t const wdog_pads[] = { - MX6_PAD_EIM_A24__GPIO_5_4 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_EIM_D19__GPIO_3_19, + MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D19__GPIO3_IO19, };
static void setup_iomux_uart(void) diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 23a78c1..0507a31 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -51,50 +51,50 @@ int dram_init(void) }
static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_CSI0_DAT10__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
iomux_v3_cfg_t const usdhc1_pads[] = { - MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT0__USDHC1_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT1__USDHC1_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT2__USDHC1_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT3__USDHC1_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* Carrier MicroSD Card Detect */ - MX6_PAD_GPIO_2__GPIO_1_2 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* SOM MicroSD Card Detect */ - MX6_PAD_EIM_DA9__GPIO_3_9 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static iomux_v3_cfg_t const enet_pads[] = { MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), /* AR8031 PHY Reset */ - MX6_PAD_EIM_D29__GPIO_3_29 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), };
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- No change in V2 arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 78 ---------------------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 82 ------------------------------ 2 files changed, 160 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 94f49c0..63ea4da 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -424,70 +424,6 @@ enum { MX6_PAD_DRAM_CAS__MMDC_DRAM_CAS = IOMUX_PAD(0x0464, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_CS0__MMDC_DRAM_CS_0 = IOMUX_PAD(0x0468, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_CS1__MMDC_DRAM_CS_1 = IOMUX_PAD(0x046C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D0__MMDC_DRAM_D_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D1__MMDC_DRAM_D_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D10__MMDC_DRAM_D_10 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D11__MMDC_DRAM_D_11 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D12__MMDC_DRAM_D_12 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D13__MMDC_DRAM_D_13 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D14__MMDC_DRAM_D_14 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D15__MMDC_DRAM_D_15 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D16__MMDC_DRAM_D_16 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D17__MMDC_DRAM_D_17 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D18__MMDC_DRAM_D_18 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D19__MMDC_DRAM_D_19 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D2__MMDC_DRAM_D_2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D20__MMDC_DRAM_D_20 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D21__MMDC_DRAM_D_21 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D22__MMDC_DRAM_D_22 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D23__MMDC_DRAM_D_23 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D24__MMDC_DRAM_D_24 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D25__MMDC_DRAM_D_25 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D26__MMDC_DRAM_D_26 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D27__MMDC_DRAM_D_27 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D28__MMDC_DRAM_D_28 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D29__MMDC_DRAM_D_29 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D3__MMDC_DRAM_D_3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D30__MMDC_DRAM_D_30 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D31__MMDC_DRAM_D_31 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D32__MMDC_DRAM_D_32 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D33__MMDC_DRAM_D_33 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D34__MMDC_DRAM_D_34 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D35__MMDC_DRAM_D_35 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D36__MMDC_DRAM_D_36 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D37__MMDC_DRAM_D_37 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D38__MMDC_DRAM_D_38 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D39__MMDC_DRAM_D_39 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D4__MMDC_DRAM_D_4 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D40__MMDC_DRAM_D_40 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D41__MMDC_DRAM_D_41 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D42__MMDC_DRAM_D_42 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D43__MMDC_DRAM_D_43 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D44__MMDC_DRAM_D_44 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D45__MMDC_DRAM_D_45 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D46__MMDC_DRAM_D_46 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D47__MMDC_DRAM_D_47 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D48__MMDC_DRAM_D_48 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D49__MMDC_DRAM_D_49 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D5__MMDC_DRAM_D_5 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D50__MMDC_DRAM_D_50 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D51__MMDC_DRAM_D_51 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D52__MMDC_DRAM_D_52 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D53__MMDC_DRAM_D_53 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D54__MMDC_DRAM_D_54 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D55__MMDC_DRAM_D_55 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D56__MMDC_DRAM_D_56 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D57__MMDC_DRAM_D_57 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D58__MMDC_DRAM_D_58 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D59__MMDC_DRAM_D_59 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D6__MMDC_DRAM_D_6 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D60__MMDC_DRAM_D_60 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D61__MMDC_DRAM_D_61 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D62__MMDC_DRAM_D_62 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D63__MMDC_DRAM_D_63 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D7__MMDC_DRAM_D_7 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D8__MMDC_DRAM_D_8 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D9__MMDC_DRAM_D_9 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x0470, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x0474, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0478, NO_MUX_I, 0, 0x0000, 0, 0), @@ -1238,16 +1174,6 @@ enum { MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__MMDC_MMDC_DEBUG_50 = IOMUX_PAD(0x0650, 0x0268, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__PL301_SIM_MX6DL_PER1_HADDR_8 = IOMUX_PAD(0x0650, 0x0268, 7, 0x0000, 0, 0), - MX6_PAD_LVDS0_CLK_P__LDB_LVDS0_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX0_P__LDB_LVDS0_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX1_P__LDB_LVDS0_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX2_P__LDB_LVDS0_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX3_P__LDB_LVDS0_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_CLK_P__LDB_LVDS1_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX0_P__LDB_LVDS1_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX1_P__LDB_LVDS1_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX2_P__LDB_LVDS1_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX3_P__LDB_LVDS1_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_0 = IOMUX_PAD(0x0654, 0x026C, 2, 0x0000, 0, 0), @@ -1362,10 +1288,6 @@ enum { MX6_PAD_NANDF_WP_B__MIPI_CORE_DPHY_TEST_OUT_32 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__USDHC4_CLKO = IOMUX_PAD(0x0690, 0x02A8, 8, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), - MX6_PAD_PMIC_ON_REQ__SNVS_LP_WRAPPER_SNVS_WAKEUP_ALARM = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_PMIC_STBY_REQ__CCM_PMIC_VSTBY_REQ = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_POR_B__SRC_POR_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index a85a5fd..437ea31 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -780,45 +780,13 @@ enum { MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__SATA_PHY_TMS = IOMUX_PAD(0x0508, 0x01F4, 6, 0x0000, 0, 0), MX6_PAD_ENET_MDC__USBPHY2_RX_DISCON = IOMUX_PAD(0x0508, 0x01F4, 7, 0x0000, 0, 0), - MX6_PAD_DRAM_D40__MMDC_DRAM_D_40 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D41__MMDC_DRAM_D_41 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D42__MMDC_DRAM_D_42 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D43__MMDC_DRAM_D_43 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D44__MMDC_DRAM_D_44 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D45__MMDC_DRAM_D_45 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D46__MMDC_DRAM_D_46 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D47__MMDC_DRAM_D_47 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS5__MMDC_DRAM_SDQS_5 = IOMUX_PAD(0x050C, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM5__MMDC_DRAM_DQM_5 = IOMUX_PAD(0x0510, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D32__MMDC_DRAM_D_32 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D33__MMDC_DRAM_D_33 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D34__MMDC_DRAM_D_34 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D35__MMDC_DRAM_D_35 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D36__MMDC_DRAM_D_36 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D37__MMDC_DRAM_D_37 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D38__MMDC_DRAM_D_38 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D39__MMDC_DRAM_D_39 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM4__MMDC_DRAM_DQM_4 = IOMUX_PAD(0x0514, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS4__MMDC_DRAM_SDQS_4 = IOMUX_PAD(0x0518, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D24__MMDC_DRAM_D_24 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D25__MMDC_DRAM_D_25 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D26__MMDC_DRAM_D_26 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D27__MMDC_DRAM_D_27 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D28__MMDC_DRAM_D_28 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D29__MMDC_DRAM_D_29 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS3__MMDC_DRAM_SDQS_3 = IOMUX_PAD(0x051C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D30__MMDC_DRAM_D_30 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D31__MMDC_DRAM_D_31 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM3__MMDC_DRAM_DQM_3 = IOMUX_PAD(0x0520, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D16__MMDC_DRAM_D_16 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D17__MMDC_DRAM_D_17 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D18__MMDC_DRAM_D_18 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D19__MMDC_DRAM_D_19 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D20__MMDC_DRAM_D_20 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D21__MMDC_DRAM_D_21 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D22__MMDC_DRAM_D_22 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS2__MMDC_DRAM_SDQS_2 = IOMUX_PAD(0x0524, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D23__MMDC_DRAM_D_23 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0528, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x052C, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_A1__MMDC_DRAM_A_1 = IOMUX_PAD(0x0530, NO_MUX_I, 0, 0x0000, 0, 0), @@ -851,46 +819,14 @@ enum { MX6_PAD_DRAM_SDODT0__MMDC_DRAM_ODT_0 = IOMUX_PAD(0x059C, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDODT1__MMDC_DRAM_ODT_1 = IOMUX_PAD(0x05A0, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x05A4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D0__MMDC_DRAM_D_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D1__MMDC_DRAM_D_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D2__MMDC_DRAM_D_2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D3__MMDC_DRAM_D_3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D4__MMDC_DRAM_D_4 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D5__MMDC_DRAM_D_5 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS0__MMDC_DRAM_SDQS_0 = IOMUX_PAD(0x05A8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D6__MMDC_DRAM_D_6 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D7__MMDC_DRAM_D_7 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x05AC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D8__MMDC_DRAM_D_8 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D9__MMDC_DRAM_D_9 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D10__MMDC_DRAM_D_10 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D11__MMDC_DRAM_D_11 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D12__MMDC_DRAM_D_12 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D13__MMDC_DRAM_D_13 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D14__MMDC_DRAM_D_14 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS1__MMDC_DRAM_SDQS_1 = IOMUX_PAD(0x05B0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D15__MMDC_DRAM_D_15 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x05B4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D48__MMDC_DRAM_D_48 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D49__MMDC_DRAM_D_49 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D50__MMDC_DRAM_D_50 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D51__MMDC_DRAM_D_51 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D52__MMDC_DRAM_D_52 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D53__MMDC_DRAM_D_53 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D54__MMDC_DRAM_D_54 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D55__MMDC_DRAM_D_55 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS6__MMDC_DRAM_SDQS_6 = IOMUX_PAD(0x05B8, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM6__MMDC_DRAM_DQM_6 = IOMUX_PAD(0x05BC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D56__MMDC_DRAM_D_56 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_SDQS7__MMDC_DRAM_SDQS_7 = IOMUX_PAD(0x05C0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D57__MMDC_DRAM_D_57 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D58__MMDC_DRAM_D_58 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D59__MMDC_DRAM_D_59 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D60__MMDC_DRAM_D_60 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_DRAM_DQM7__MMDC_DRAM_DQM_7 = IOMUX_PAD(0x05C4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D61__MMDC_DRAM_D_61 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D62__MMDC_DRAM_D_62 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_D63__MMDC_DRAM_D_63 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x07F4, 2, 0), MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), @@ -1251,24 +1187,6 @@ enum { MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x0684, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0688, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x068C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX3_P__LDB_LVDS1_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX2_P__LDB_LVDS1_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_CLK_P__LDB_LVDS1_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX1_P__LDB_LVDS1_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS1_TX0_P__LDB_LVDS1_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX3_P__LDB_LVDS0_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_CLK_P__LDB_LVDS0_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX2_P__LDB_LVDS0_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX1_P__LDB_LVDS0_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_LVDS0_TX0_P__LDB_LVDS0_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_TAMPER__SNVS_LP_WRAP_SNVS_TD1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_PMIC_ON_REQ__SNVS_LPWRAP_WKALM = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_PMIC_STBY_REQ__CCM_PMIC_STBYRQ = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_POR_B__SRC_POR_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_BOOT_MODE1__SRC_BOOT_MODE_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_BOOT_MODE0__SRC_BOOT_MODE_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_TEST_MODE__TCU_TEST_MODE = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0),
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- No change in V2 arch/arm/include/asm/arch-mx6/mx6q_pins.h | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index 437ea31..ec1bbdd 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -132,6 +132,7 @@ enum { MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0804, 0, 0), MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), MX6_PAD_EIM_D19__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x08C8, 0, 0), + MX6_PAD_EIM_D19__UART1_CTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), @@ -162,6 +163,7 @@ enum { MX6_PAD_EIM_D22__PL301MX6QPER1_HWRITE = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x092C, 0, 0), MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x08D8, 0, 0), @@ -188,6 +190,7 @@ enum { MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D25__UART3_TX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0000, 0, 0), MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0930, 1, 0), MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x080C, 0, 0), MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), @@ -207,6 +210,7 @@ enum { MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU2_CSI1_DATA13 = IOMUX_PAD(0x03D4, 0x00C0, 3, 0x08BC, 0, 0), + MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0928, 1, 0), MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), @@ -216,6 +220,7 @@ enum { MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x03D8, 0x00C4, 2, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU2_CSI1_DATA12 = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x08B8, 0, 0), MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), + MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), @@ -231,6 +236,7 @@ enum { MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), @@ -726,6 +732,7 @@ enum { MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x04E8, 0x01D4, 5, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__USBPHY1_RX_SQH = IOMUX_PAD(0x04E8, 0x01D4, 7, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x04EC, 0x01D8, 0, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x04EC, 0x01D8, 1, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), @@ -840,6 +847,7 @@ enum { MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x05CC, 0x01FC, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), @@ -857,6 +865,7 @@ enum { MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x05D4, 0x0204, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), @@ -906,6 +915,7 @@ enum { MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__MMDC_DEBUG_50 = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), @@ -986,6 +996,7 @@ enum { MX6_PAD_GPIO_8__XTALOSC_REF_CLK_32K = IOMUX_PAD(0x0614, 0x0244, 1, 0x0000, 0, 0), MX6_PAD_GPIO_8__EPIT2_OUT = IOMUX_PAD(0x0614, 0x0244, 2, 0x0000, 0, 0), MX6_PAD_GPIO_8__FLEXCAN1_RX = IOMUX_PAD(0x0614, 0x0244, 3, 0x07E4, 1, 0), + MX6_PAD_GPIO_8__UART2_TX_DATA = IOMUX_PAD(0x0614, 0x0244, 4, 0x0000, 0, 0), MX6_PAD_GPIO_8__UART2_RX_DATA = IOMUX_PAD(0x0614, 0x0244, 4, 0x0928, 3, 0), MX6_PAD_GPIO_8__GPIO1_IO08 = IOMUX_PAD(0x0614, 0x0244, 5, 0x0000, 0, 0), MX6_PAD_GPIO_8__SPDIF_SR_CLK = IOMUX_PAD(0x0614, 0x0244, 6, 0x0000, 0, 0), @@ -1108,6 +1119,7 @@ enum { MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0654, 0x0284, 2, 0x081C, 2, 0), + MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0654, 0x0284, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), @@ -1125,6 +1137,7 @@ enum { MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__PCIE_CTRL_MUX_17 = IOMUX_PAD(0x065C, 0x028C, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x065C, 0x028C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), @@ -1142,6 +1155,7 @@ enum { MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__PCIE_CTRL_MUX_19 = IOMUX_PAD(0x0664, 0x0294, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0664, 0x0294, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), @@ -1159,6 +1173,7 @@ enum { MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__PCIE_CTRL_MUX_21 = IOMUX_PAD(0x066C, 0x029C, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x066C, 0x029C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), @@ -1176,6 +1191,7 @@ enum { MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__PCIE_CTRL_MUX_23 = IOMUX_PAD(0x0674, 0x02A4, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0674, 0x02A4, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), @@ -1197,6 +1213,7 @@ enum { MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_IN_12 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__USBPHY2_CLK20DIV = IOMUX_PAD(0x0690, 0x02A8, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0920, 3, 0), MX6_PAD_SD3_DAT6__PCIE_CTRL_MUX_25 = IOMUX_PAD(0x0694, 0x02AC, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0694, 0x02AC, 3, 0x0000, 0, 0), @@ -1214,6 +1231,7 @@ enum { MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_IN_14 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__ANATOP_TESTO_11 = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0928, 5, 0), MX6_PAD_SD3_DAT4__PCIE_CTRL_MUX_27 = IOMUX_PAD(0x069C, 0x02B4, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x069C, 0x02B4, 3, 0x0000, 0, 0), @@ -1222,6 +1240,7 @@ enum { MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_IN_15 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__ANATOP_TESTO_12 = IOMUX_PAD(0x069C, 0x02B4, 7, 0x0000, 0, 0), MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06A0, 0x02B8, 16, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0000, 0, 0), MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0924, 2, 0), MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06A0, 0x02B8, 2, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06A0, 0x02B8, 3, 0x0000, 0, 0), @@ -1239,6 +1258,7 @@ enum { MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_IN_17 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), MX6_PAD_SD3_CLK__ANATOP_TESTO_14 = IOMUX_PAD(0x06A4, 0x02BC, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06A8, 0x02C0, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x091C, 2, 0), MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06A8, 0x02C0, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06A8, 0x02C0, 3, 0x0000, 0, 0), @@ -1263,6 +1283,7 @@ enum { MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_IN_20 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__ANATOP_TESTI_1 = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x092C, 4, 0), MX6_PAD_SD3_DAT3__PCIE_CTRL_MUX_29 = IOMUX_PAD(0x06B4, 0x02CC, 2, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x06B4, 0x02CC, 3, 0x0000, 0, 0), @@ -1346,6 +1367,7 @@ enum { MX6_PAD_SD4_CMD__TPSMP_HDATA_DIR = IOMUX_PAD(0x06DC, 0x02F4, 7, 0x0000, 0, 0), MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x06E0, 0x02F8, 0, 0x0000, 0, 0), MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x06E0, 0x02F8, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0000, 0, 0), MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0930, 3, 0), MX6_PAD_SD4_CLK__PCIE_CTRL_MUX_6 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), @@ -1446,6 +1468,7 @@ enum { MX6_PAD_SD4_DAT3__IPU2_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0928, 6, 0), MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), @@ -1463,6 +1486,7 @@ enum { MX6_PAD_SD4_DAT5__IPU2_IPU_DIAG_BUS_13 = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0924, 5, 0), MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0),
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- No change in V2 arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 509 --------------------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 534 ----------------------------- 2 files changed, 1043 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 63ea4da..47d704b 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -15,98 +15,68 @@ enum { MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0360, 0x004C, 2, 0x07F8, 0, 0), MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), - MX6_PAD_CSI0_DAT10__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x0360, 0x004C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0360, 0x004C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0800, 0, 0), MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), - MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0364, 0x0050, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x0364, 0x0050, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__PCIE_CTRL_DIAG_STATUS_BUS_MUX_16 = IOMUX_PAD(0x0368, 0x0054, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), - MX6_PAD_CSI0_DAT12__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x0368, 0x0054, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__PCIE_CTRL_DIAG_STATUS_BUS_MUX_17 = IOMUX_PAD(0x036C, 0x0058, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), - MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x036C, 0x0058, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x036C, 0x0058, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__PCIE_CTRL_DIAG_STATUS_BUS_MUX_18 = IOMUX_PAD(0x0370, 0x005C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), - MX6_PAD_CSI0_DAT14__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0370, 0x005C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0370, 0x005C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__PCIE_CTRL_DIAG_STATUS_BUS_MUX_19 = IOMUX_PAD(0x0374, 0x0060, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), - MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0374, 0x0060, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x0374, 0x0060, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__PCIE_CTRL_DIAG_STATUS_BUS_MUX_20 = IOMUX_PAD(0x0378, 0x0064, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), - MX6_PAD_CSI0_DAT16__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x0378, 0x0064, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0378, 0x0064, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__PCIE_CTRL_DIAG_STATUS_BUS_MUX_21 = IOMUX_PAD(0x037C, 0x0068, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), - MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x037C, 0x0068, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x037C, 0x0068, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__PCIE_CTRL_DIAG_STATUS_BUS_MUX_22 = IOMUX_PAD(0x0380, 0x006C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), - MX6_PAD_CSI0_DAT18__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0380, 0x006C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__MMDC_MMDC_DEBUG_41 = IOMUX_PAD(0x0380, 0x006C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__PCIE_CTRL_DIAG_STATUS_BUS_MUX_23 = IOMUX_PAD(0x0384, 0x0070, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), - MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0384, 0x0070, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__MMDC_MMDC_DEBUG_42 = IOMUX_PAD(0x0384, 0x0070, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__ANATOP_ANATOP_TESTO_9 = IOMUX_PAD(0x0384, 0x0070, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0388, 0x0074, 2, 0x07D8, 0, 0), MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__MMDC_MMDC_DEBUG_43 = IOMUX_PAD(0x0388, 0x0074, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), @@ -114,7 +84,6 @@ enum { MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__MMDC_MMDC_DEBUG_44 = IOMUX_PAD(0x038C, 0x0078, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), @@ -122,7 +91,6 @@ enum { MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__MMDC_MMDC_DEBUG_45 = IOMUX_PAD(0x0390, 0x007C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), @@ -130,7 +98,6 @@ enum { MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__MMDC_MMDC_DEBUG_46 = IOMUX_PAD(0x0394, 0x0080, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), @@ -138,7 +105,6 @@ enum { MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0), MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__MMDC_MMDC_DEBUG_47 = IOMUX_PAD(0x0398, 0x0084, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), @@ -146,160 +112,95 @@ enum { MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0), MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__MMDC_MMDC_DEBUG_48 = IOMUX_PAD(0x039C, 0x0088, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__PCIE_CTRL_DIAG_STATUS_BUS_MUX_14 = IOMUX_PAD(0x03A0, 0x008C, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__MMDC_MMDC_DEBUG_31 = IOMUX_PAD(0x03A0, 0x008C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_13 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x03A4, 0x0090, 6, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_12 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__MMDC_MMDC_DEBUG_29 = IOMUX_PAD(0x03A8, 0x0094, 6, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__PCIE_CTRL_DIAG_STATUS_BUS_MUX_15 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__MMDC_MMDC_DEBUG_32 = IOMUX_PAD(0x03AC, 0x0098, 6, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_DISP_CLK__LCD_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__MIPI_CORE_DPHY_TEST_OUT_28 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__SDMA_DEBUG_CORE_STATE_0 = IOMUX_PAD(0x03B0, 0x009C, 4, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__MMDC_MMDC_DEBUG_0 = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__TPSMP_HDATA_DIR = IOMUX_PAD(0x03B0, 0x009C, 7, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__LCD_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__LCD_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__MIPI_CORE_DPHY_TEST_OUT_29 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__SDMA_DEBUG_CORE_STATE_1 = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__PL301_SIM_MX6DL_PER1_HSIZE_0 = IOMUX_PAD(0x03B4, 0x00A0, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__LCD_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN2__LCD_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__MIPI_CORE_DPHY_TEST_OUT_30 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__SDMA_DEBUG_CORE_STATE_2 = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__MMDC_MMDC_DEBUG_2 = IOMUX_PAD(0x03B8, 0x00A4, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__PL301_SIM_MX6DL_PER1_HADDR_9 = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__LCD_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN3__LCD_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__MIPI_CORE_DPHY_TEST_OUT_31 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__SDMA_DEBUG_CORE_STATE_3 = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__PL301_SIM_MX6DL_PER1_HADDR_10 = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__LCD_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN4__LCD_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), - MX6_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__PL301_SIM_MX6DL_PER1_HADDR_11 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__LCD_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT0__LCD_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__USDHC1_USDHC_DEBUG_0 = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__SDMA_DEBUG_CORE_RUN = IOMUX_PAD(0x03C4, 0x00B0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__PL301_SIM_MX6DL_PER1_HSIZE_1 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT1__LCD_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__USDHC1_USDHC_DEBUG_1 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__SDMA_DEBUG_EVENT_CHANNEL_SEL = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__MMDC_MMDC_DEBUG_6 = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__PL301_SIM_MX6DL_PER1_HADDR_12 = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__LCD_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__USDHC1_USDHC_DEBUG_6 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__SDMA_DEBUG_EVENT_CHANNEL_3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__MMDC_MMDC_DEBUG_15 = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__PL301_SIM_MX6DL_PER1_HADDR_21 = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT11__LCD_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__USDHC1_USDHC_DEBUG_7 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__SDMA_DEBUG_EVENT_CHANNEL_4 = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__MMDC_MMDC_DEBUG_16 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__PL301_SIM_MX6DL_PER1_HADDR_22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT12__LCD_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__SDMA_DEBUG_EVENT_CHANNEL_5 = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__MMDC_MMDC_DEBUG_17 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__PL301_SIM_MX6DL_PER1_HADDR_23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT13__LCD_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), - MX6_PAD_DISP0_DAT13__SDMA_DEBUG_EVT_CHN_LINES_0 = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__MMDC_MMDC_DEBUG_18 = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__PL301_SIM_MX6DL_PER1_HADDR_24 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT14__LCD_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), - MX6_PAD_DISP0_DAT14__SDMA_DEBUG_EVT_CHN_LINES_1 = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__MMDC_MMDC_DEBUG_19 = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__PL301_SIM_MX6DL_PER1_HSIZE_2 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT15__LCD_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x07E8, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0804, 0, 0), - MX6_PAD_DISP0_DAT15__SDMA_DEBUG_EVT_CHN_LINES_2 = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__MMDC_MMDC_DEBUG_20 = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__PL301_SIM_MX6DL_PER1_HADDR_25 = IOMUX_PAD(0x03E0, 0x00CC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT16__LCD_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x07FC, 1, 0), MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__MMDC_MMDC_DEBUG_21 = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__PL301_SIM_MX6DL_PER1_HADDR_26 = IOMUX_PAD(0x03E4, 0x00D0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT17__LCD_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x07F8, 1, 0), MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__MMDC_MMDC_DEBUG_22 = IOMUX_PAD(0x03E8, 0x00D4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__PL301_SIM_MX6DL_PER1_HADDR_27 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT18__LCD_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x0800, 1, 0), MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__MMDC_MMDC_DEBUG_23 = IOMUX_PAD(0x03EC, 0x00D8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT19__LCD_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), @@ -307,204 +208,103 @@ enum { MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__MMDC_MMDC_DEBUG_24 = IOMUX_PAD(0x03F0, 0x00DC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__LCD_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__USDHC1_USDHC_DEBUG_2 = IOMUX_PAD(0x03F4, 0x00E0, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__SDMA_DEBUG_MODE = IOMUX_PAD(0x03F4, 0x00E0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__MMDC_MMDC_DEBUG_7 = IOMUX_PAD(0x03F4, 0x00E0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__PL301_SIM_MX6DL_PER1_HADDR_13 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT20__LCD_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x07D8, 1, 0), MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), - MX6_PAD_DISP0_DAT20__SDMA_DEBUG_EVT_CHN_LINES_7 = IOMUX_PAD(0x03F8, 0x00E4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__MMDC_MMDC_DEBUG_25 = IOMUX_PAD(0x03F8, 0x00E4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__PL301_SIM_MX6DL_PER1_HADDR_28 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT21__LCD_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x07E0, 1, 0), MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), - MX6_PAD_DISP0_DAT21__SDMA_DEBUG_BUS_DEVICE_0 = IOMUX_PAD(0x03FC, 0x00E8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__MMDC_MMDC_DEBUG_26 = IOMUX_PAD(0x03FC, 0x00E8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__PL301_SIM_MX6DL_PER1_HADDR_29 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT22__LCD_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x00EC, 2, 0x07DC, 1, 0), MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), - MX6_PAD_DISP0_DAT22__SDMA_DEBUG_BUS_DEVICE_1 = IOMUX_PAD(0x0400, 0x00EC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__MMDC_MMDC_DEBUG_27 = IOMUX_PAD(0x0400, 0x00EC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__PL301_SIM_MX6DL_PER1_HADDR_30 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT23__LCD_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x07E4, 1, 0), MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), - MX6_PAD_DISP0_DAT23__SDMA_DEBUG_BUS_DEVICE_2 = IOMUX_PAD(0x0404, 0x00F0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__MMDC_MMDC_DEBUG_28 = IOMUX_PAD(0x0404, 0x00F0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__PL301_SIM_MX6DL_PER1_HADDR_31 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT3__LCD_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0408, 0x00F4, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__USDHC1_USDHC_DEBUG_3 = IOMUX_PAD(0x0408, 0x00F4, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__SDMA_DEBUG_BUS_ERROR = IOMUX_PAD(0x0408, 0x00F4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__MMDC_MMDC_DEBUG_8 = IOMUX_PAD(0x0408, 0x00F4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__PL301_SIM_MX6DL_PER1_HADDR_14 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT4__LCD_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__USDHC1_USDHC_DEBUG_4 = IOMUX_PAD(0x040C, 0x00F8, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x040C, 0x00F8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x040C, 0x00F8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__PL301_SIM_MX6DL_PER1_HADDR_15 = IOMUX_PAD(0x040C, 0x00F8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT5__LCD_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__SDMA_DEBUG_MATCHED_DMBUS = IOMUX_PAD(0x0410, 0x00FC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__MMDC_MMDC_DEBUG_10 = IOMUX_PAD(0x0410, 0x00FC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__PL301_SIM_MX6DL_PER1_HADDR_16 = IOMUX_PAD(0x0410, 0x00FC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT6__LCD_DATA06 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x0414, 0x0100, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__SDMA_DEBUG_RTBUFFER_WRITE = IOMUX_PAD(0x0414, 0x0100, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__MMDC_MMDC_DEBUG_11 = IOMUX_PAD(0x0414, 0x0100, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__PL301_SIM_MX6DL_PER1_HADDR_17 = IOMUX_PAD(0x0414, 0x0100, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT7__LCD_DATA07 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x0418, 0x0104, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__USDHC1_USDHC_DEBUG_5 = IOMUX_PAD(0x0418, 0x0104, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__SDMA_DEBUG_EVENT_CHANNEL_0 = IOMUX_PAD(0x0418, 0x0104, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__MMDC_MMDC_DEBUG_12 = IOMUX_PAD(0x0418, 0x0104, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__PL301_SIM_MX6DL_PER1_HADDR_18 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT8__LCD_DATA08 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__SDMA_DEBUG_EVENT_CHANNEL_1 = IOMUX_PAD(0x041C, 0x0108, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__MMDC_MMDC_DEBUG_13 = IOMUX_PAD(0x041C, 0x0108, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PL301_SIM_MX6DL_PER1_HADDR_19 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT9__LCD_DATA09 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__SDMA_DEBUG_EVENT_CHANNEL_2 = IOMUX_PAD(0x0420, 0x010C, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__MMDC_MMDC_DEBUG_14 = IOMUX_PAD(0x0420, 0x010C, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PL301_SIM_MX6DL_PER1_HADDR_20 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), - MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x0424, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A1__MMDC_DRAM_A_1 = IOMUX_PAD(0x0428, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A10__MMDC_DRAM_A_10 = IOMUX_PAD(0x042C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A11__MMDC_DRAM_A_11 = IOMUX_PAD(0x0430, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A12__MMDC_DRAM_A_12 = IOMUX_PAD(0x0434, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A13__MMDC_DRAM_A_13 = IOMUX_PAD(0x0438, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A14__MMDC_DRAM_A_14 = IOMUX_PAD(0x043C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A15__MMDC_DRAM_A_15 = IOMUX_PAD(0x0440, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A2__MMDC_DRAM_A_2 = IOMUX_PAD(0x0444, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A3__MMDC_DRAM_A_3 = IOMUX_PAD(0x0448, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A4__MMDC_DRAM_A_4 = IOMUX_PAD(0x044C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A5__MMDC_DRAM_A_5 = IOMUX_PAD(0x0450, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A6__MMDC_DRAM_A_6 = IOMUX_PAD(0x0454, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A7__MMDC_DRAM_A_7 = IOMUX_PAD(0x0458, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A8__MMDC_DRAM_A_8 = IOMUX_PAD(0x045C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A9__MMDC_DRAM_A_9 = IOMUX_PAD(0x0460, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CAS__MMDC_DRAM_CAS = IOMUX_PAD(0x0464, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CS0__MMDC_DRAM_CS_0 = IOMUX_PAD(0x0468, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CS1__MMDC_DRAM_CS_1 = IOMUX_PAD(0x046C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x0470, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x0474, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0478, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM3__MMDC_DRAM_DQM_3 = IOMUX_PAD(0x047C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM4__MMDC_DRAM_DQM_4 = IOMUX_PAD(0x0480, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM5__MMDC_DRAM_DQM_5 = IOMUX_PAD(0x0484, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM6__MMDC_DRAM_DQM_6 = IOMUX_PAD(0x0488, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM7__MMDC_DRAM_DQM_7 = IOMUX_PAD(0x048C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_RAS__MMDC_DRAM_RAS = IOMUX_PAD(0x0490, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_RESET__MMDC_DRAM_RESET = IOMUX_PAD(0x0494, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA0__MMDC_DRAM_SDBA_0 = IOMUX_PAD(0x0498, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA1__MMDC_DRAM_SDBA_1 = IOMUX_PAD(0x049C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA2__MMDC_DRAM_SDBA_2 = IOMUX_PAD(0x04A0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCKE0__MMDC_DRAM_SDCKE_0 = IOMUX_PAD(0x04A4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCKE1__MMDC_DRAM_SDCKE_1 = IOMUX_PAD(0x04A8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCLK_0__MMDC_DRAM_SDCLK0 = IOMUX_PAD(0x04AC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCLK_1__MMDC_DRAM_SDCLK1 = IOMUX_PAD(0x04B0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDODT0__MMDC_DRAM_ODT_0 = IOMUX_PAD(0x04B4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDODT1__MMDC_DRAM_ODT_1 = IOMUX_PAD(0x04B8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS0__MMDC_DRAM_SDQS_0 = IOMUX_PAD(0x04BC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS1__MMDC_DRAM_SDQS_1 = IOMUX_PAD(0x04C0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS2__MMDC_DRAM_SDQS_2 = IOMUX_PAD(0x04C4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS3__MMDC_DRAM_SDQS_3 = IOMUX_PAD(0x04C8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS4__MMDC_DRAM_SDQS_4 = IOMUX_PAD(0x04CC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS5__MMDC_DRAM_SDQS_5 = IOMUX_PAD(0x04D0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS6__MMDC_DRAM_SDQS_6 = IOMUX_PAD(0x04D4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS7__MMDC_DRAM_SDQS_7 = IOMUX_PAD(0x04D8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x04DC, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x04E0, 0x0110, 1, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x04E0, 0x0110, 2, 0x08B8, 0, 0), - MX6_PAD_EIM_A16__MIPI_CORE_DPHY_TEST_OUT_23 = IOMUX_PAD(0x04E0, 0x0110, 4, 0x0000, 0, 0), MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x04E0, 0x0110, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A16__TPSMP_HDATA_6 = IOMUX_PAD(0x04E0, 0x0110, 6, 0x0000, 0, 0), MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x04E0, 0x0110, 7, 0x0000, 0, 0), MX6_PAD_EIM_A16__EPDC_DATA00 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU1_CSI1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), - MX6_PAD_EIM_A17__MIPI_CORE_DPHY_TEST_OUT_22 = IOMUX_PAD(0x04E4, 0x0114, 4, 0x0000, 0, 0), MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A17__TPSMP_HDATA_5 = IOMUX_PAD(0x04E4, 0x0114, 6, 0x0000, 0, 0), MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), MX6_PAD_EIM_A17__EPDC_PWR_STAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU1_CSI1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), - MX6_PAD_EIM_A18__MIPI_CORE_DPHY_TEST_OUT_21 = IOMUX_PAD(0x04E8, 0x0118, 4, 0x0000, 0, 0), MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A18__TPSMP_HDATA_4 = IOMUX_PAD(0x04E8, 0x0118, 6, 0x0000, 0, 0), MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), MX6_PAD_EIM_A18__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU1_CSI1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), - MX6_PAD_EIM_A19__MIPI_CORE_DPHY_TEST_OUT_20 = IOMUX_PAD(0x04EC, 0x011C, 4, 0x0000, 0, 0), MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A19__TPSMP_HDATA_3 = IOMUX_PAD(0x04EC, 0x011C, 6, 0x0000, 0, 0), MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), MX6_PAD_EIM_A19__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), - MX6_PAD_EIM_A20__MIPI_CORE_DPHY_TEST_OUT_19 = IOMUX_PAD(0x04F0, 0x0120, 4, 0x0000, 0, 0), MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A20__TPSMP_HDATA_2 = IOMUX_PAD(0x04F0, 0x0120, 6, 0x0000, 0, 0), MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), MX6_PAD_EIM_A20__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU1_CSI1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), - MX6_PAD_EIM_A21__MIPI_CORE_DPHY_TEST_OUT_18 = IOMUX_PAD(0x04F4, 0x0124, 4, 0x0000, 0, 0), MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A21__TPSMP_HDATA_1 = IOMUX_PAD(0x04F4, 0x0124, 6, 0x0000, 0, 0), MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), MX6_PAD_EIM_A21__EPDC_GDCLK = IOMUX_PAD(0x04F4, 0x0124, 8, 0x0000, 0, 0), MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU1_CSI1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A22__TPSMP_HDATA_0 = IOMUX_PAD(0x04F8, 0x0128, 6, 0x0000, 0, 0), MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), MX6_PAD_EIM_A22__EPDC_GDSP = IOMUX_PAD(0x04F8, 0x0128, 8, 0x0000, 0, 0), MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), @@ -512,7 +312,6 @@ enum { MX6_PAD_EIM_A23__IPU1_CSI1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A23__PL301_SIM_MX6DL_PER1_HPROT_3 = IOMUX_PAD(0x04FC, 0x012C, 6, 0x0000, 0, 0), MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), MX6_PAD_EIM_A23__EPDC_GDOE = IOMUX_PAD(0x04FC, 0x012C, 8, 0x0000, 0, 0), MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), @@ -520,7 +319,6 @@ enum { MX6_PAD_EIM_A24__IPU1_CSI1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A24__PL301_SIM_MX6DL_PER1_HPROT_2 = IOMUX_PAD(0x0500, 0x0130, 6, 0x0000, 0, 0), MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), MX6_PAD_EIM_A24__EPDC_GDRL = IOMUX_PAD(0x0500, 0x0130, 8, 0x0000, 0, 0), MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x0504, 0x0134, 0, 0x0000, 0, 0), @@ -530,27 +328,21 @@ enum { MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x0504, 0x0134, 4, 0x0000, 0, 0), MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x0504, 0x0134, 5, 0x0000, 0, 0), MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0504, 0x0134, 6, 0x085C, 0, 0), - MX6_PAD_EIM_A25__PL301_SIM_MX6DL_PER1_HBURST_0 = IOMUX_PAD(0x0504, 0x0134, 7, 0x0000, 0, 0), MX6_PAD_EIM_A25__EPDC_DATA15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), MX6_PAD_EIM_A25__EIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x0508, 0x0138, 1, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x0508, 0x0138, 6, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__EPDC_SDCE9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x050C, 0x013C, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x050C, 0x013C, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x050C, 0x013C, 2, 0x07F4, 2, 0), - MX6_PAD_EIM_CS0__MIPI_CORE_DPHY_TEST_OUT_24 = IOMUX_PAD(0x050C, 0x013C, 4, 0x0000, 0, 0), MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x050C, 0x013C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__TPSMP_HDATA_7 = IOMUX_PAD(0x050C, 0x013C, 6, 0x0000, 0, 0), MX6_PAD_EIM_CS0__EPDC_DATA06 = IOMUX_PAD(0x050C, 0x013C, 8, 0x0000, 0, 0), MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0510, 0x0140, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0510, 0x0140, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0510, 0x0140, 2, 0x07FC, 2, 0), - MX6_PAD_EIM_CS1__MIPI_CORE_DPHY_TEST_OUT_25 = IOMUX_PAD(0x0510, 0x0140, 4, 0x0000, 0, 0), MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0510, 0x0140, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__TPSMP_HDATA_8 = IOMUX_PAD(0x0510, 0x0140, 6, 0x0000, 0, 0), MX6_PAD_EIM_CS1__EPDC_DATA08 = IOMUX_PAD(0x0510, 0x0140, 8, 0x0000, 0, 0), MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x0514, 0x0144, 1, 0x07D8, 2, 0), @@ -559,7 +351,6 @@ enum { MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x0514, 0x0144, 4, 0x0864, 0, 0), MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0), - MX6_PAD_EIM_D16__TPSMP_HTRANS_0 = IOMUX_PAD(0x0514, 0x0144, 7, 0x0000, 0, 0), MX6_PAD_EIM_D16__EPDC_DATA10 = IOMUX_PAD(0x0514, 0x0144, 8, 0x0000, 0, 0), MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x0518, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x0518, 0x0148, 1, 0x07DC, 2, 0), @@ -568,7 +359,6 @@ enum { MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x0518, 0x0148, 4, 0x0000, 0, 0), MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x0518, 0x0148, 5, 0x0000, 0, 0), MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0), - MX6_PAD_EIM_D17__PL301_SIM_MX6DL_PER1_HBURST_1 = IOMUX_PAD(0x0518, 0x0148, 7, 0x0000, 0, 0), MX6_PAD_EIM_D17__EPDC_VCOM0 = IOMUX_PAD(0x0518, 0x0148, 8, 0x0000, 0, 0), MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x051C, 0x014C, 1, 0x07E0, 2, 0), @@ -577,7 +367,6 @@ enum { MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x051C, 0x014C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0), - MX6_PAD_EIM_D18__PL301_SIM_MX6DL_PER1_HBURST_2 = IOMUX_PAD(0x051C, 0x014C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D18__EPDC_VCOM1 = IOMUX_PAD(0x051C, 0x014C, 8, 0x0000, 0, 0), MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x0520, 0x0150, 1, 0x07E8, 1, 0), @@ -587,7 +376,6 @@ enum { MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x0520, 0x0150, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D19__PL301_SIM_MX6DL_PER1_HRESP = IOMUX_PAD(0x0520, 0x0150, 7, 0x0000, 0, 0), MX6_PAD_EIM_D19__EPDC_DATA12 = IOMUX_PAD(0x0520, 0x0150, 8, 0x0000, 0, 0), MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x0524, 0x0154, 1, 0x0808, 0, 0), @@ -597,7 +385,6 @@ enum { MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x0524, 0x0154, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D20__TPSMP_HTRANS_1 = IOMUX_PAD(0x0524, 0x0154, 7, 0x0000, 0, 0), MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x0528, 0x0158, 1, 0x0000, 0, 0), MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x0528, 0x0158, 2, 0x0000, 0, 0), @@ -613,7 +400,6 @@ enum { MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D22__PL301_SIM_MX6DL_PER1_HWRITE = IOMUX_PAD(0x052C, 0x015C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D22__EPDC_SDCE6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x0530, 0x0160, 0, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x0530, 0x0160, 1, 0x0000, 0, 0), @@ -692,7 +478,6 @@ enum { MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), - MX6_PAD_EIM_D30__PL301_SIM_MX6DL_PER1_HPROT_0 = IOMUX_PAD(0x054C, 0x017C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D30__EPDC_SDOEZ = IOMUX_PAD(0x054C, 0x017C, 8, 0x0000, 0, 0), MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), @@ -702,167 +487,117 @@ enum { MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D31__PL301_SIM_MX6DL_PER1_HPROT_1 = IOMUX_PAD(0x0550, 0x0180, 7, 0x0000, 0, 0), MX6_PAD_EIM_D31__EPDC_SDCLK_P = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), MX6_PAD_EIM_D31__EIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU1_CSI1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__MIPI_CORE_DPHY_TEST_OUT_2 = IOMUX_PAD(0x0554, 0x0184, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__TPSMP_HDATA_14 = IOMUX_PAD(0x0554, 0x0184, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA0__EPDC_SDCLK_N = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU1_CSI1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__MIPI_CORE_DPHY_TEST_OUT_3 = IOMUX_PAD(0x0558, 0x0188, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0558, 0x0188, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__TPSMP_HDATA_15 = IOMUX_PAD(0x0558, 0x0188, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA1__EPDC_SDLE = IOMUX_PAD(0x0558, 0x0188, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x055C, 0x018C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x055C, 0x018C, 2, 0x08B0, 1, 0), - MX6_PAD_EIM_DA10__MIPI_CORE_DPHY_TEST_OUT_12 = IOMUX_PAD(0x055C, 0x018C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__TPSMP_HDATA_24 = IOMUX_PAD(0x055C, 0x018C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA10__EPDC_DATA01 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_CSI1_HSYNC = IOMUX_PAD(0x0560, 0x0190, 2, 0x08B4, 0, 0), - MX6_PAD_EIM_DA11__MIPI_CORE_DPHY_TEST_OUT_13 = IOMUX_PAD(0x0560, 0x0190, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SDMA_DEBUG_EVT_CHN_LINES_6 = IOMUX_PAD(0x0560, 0x0190, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__TPSMP_HDATA_25 = IOMUX_PAD(0x0560, 0x0190, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA11__EPDC_DATA03 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0564, 0x0194, 2, 0x08BC, 1, 0), - MX6_PAD_EIM_DA12__MIPI_CORE_DPHY_TEST_OUT_14 = IOMUX_PAD(0x0564, 0x0194, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SDMA_DEBUG_EVT_CHN_LINES_3 = IOMUX_PAD(0x0564, 0x0194, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__TPSMP_HDATA_26 = IOMUX_PAD(0x0564, 0x0194, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA12__EPDC_DATA02 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x0568, 0x0198, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__CCM_DI1_EXT_CLK = IOMUX_PAD(0x0568, 0x0198, 2, 0x07D0, 0, 0), - MX6_PAD_EIM_DA13__MIPI_CORE_DPHY_TEST_OUT_15 = IOMUX_PAD(0x0568, 0x0198, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SDMA_DEBUG_EVT_CHN_LINES_4 = IOMUX_PAD(0x0568, 0x0198, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__TPSMP_HDATA_27 = IOMUX_PAD(0x0568, 0x0198, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA13__EPDC_DATA13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x056C, 0x019C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__CCM_DI0_EXT_CLK = IOMUX_PAD(0x056C, 0x019C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__MIPI_CORE_DPHY_TEST_OUT_16 = IOMUX_PAD(0x056C, 0x019C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SDMA_DEBUG_EVT_CHN_LINES_5 = IOMUX_PAD(0x056C, 0x019C, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__TPSMP_HDATA_28 = IOMUX_PAD(0x056C, 0x019C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA14__EPDC_DATA14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__MIPI_CORE_DPHY_TEST_OUT_17 = IOMUX_PAD(0x0570, 0x01A0, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__TPSMP_HDATA_29 = IOMUX_PAD(0x0570, 0x01A0, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA15__EPDC_DATA09 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU1_CSI1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__MIPI_CORE_DPHY_TEST_OUT_4 = IOMUX_PAD(0x0574, 0x01A4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x0574, 0x01A4, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__TPSMP_HDATA_16 = IOMUX_PAD(0x0574, 0x01A4, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA2__EPDC_BDR0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU1_CSI1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__MIPI_CORE_DPHY_TEST_OUT_5 = IOMUX_PAD(0x0578, 0x01A8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x0578, 0x01A8, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__TPSMP_HDATA_17 = IOMUX_PAD(0x0578, 0x01A8, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA3__EPDC_BDR1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU1_CSI1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__MIPI_CORE_DPHY_TEST_OUT_6 = IOMUX_PAD(0x057C, 0x01AC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x057C, 0x01AC, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__TPSMP_HDATA_18 = IOMUX_PAD(0x057C, 0x01AC, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA4__EPDC_SDCE0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU1_CSI1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__MIPI_CORE_DPHY_TEST_OUT_7 = IOMUX_PAD(0x0580, 0x01B0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x0580, 0x01B0, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__TPSMP_HDATA_19 = IOMUX_PAD(0x0580, 0x01B0, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA5__EPDC_SDCE1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU1_CSI1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__MIPI_CORE_DPHY_TEST_OUT_8 = IOMUX_PAD(0x0584, 0x01B4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x0584, 0x01B4, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__TPSMP_HDATA_20 = IOMUX_PAD(0x0584, 0x01B4, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA6__EPDC_SDCE2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU1_CSI1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__MIPI_CORE_DPHY_TEST_OUT_9 = IOMUX_PAD(0x0588, 0x01B8, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__TPSMP_HDATA_21 = IOMUX_PAD(0x0588, 0x01B8, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA7__EPDC_SDCE3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU1_CSI1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__MIPI_CORE_DPHY_TEST_OUT_10 = IOMUX_PAD(0x058C, 0x01BC, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__TPSMP_HDATA_22 = IOMUX_PAD(0x058C, 0x01BC, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA8__EPDC_SDCE4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU1_CSI1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__MIPI_CORE_DPHY_TEST_OUT_11 = IOMUX_PAD(0x0590, 0x01C0, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__TPSMP_HDATA_23 = IOMUX_PAD(0x0590, 0x01C0, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA9__EPDC_SDCE5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), - MX6_PAD_EIM_EB0__MIPI_CORE_DPHY_TEST_OUT_0 = IOMUX_PAD(0x0594, 0x01C4, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__TPSMP_HDATA_12 = IOMUX_PAD(0x0594, 0x01C4, 6, 0x0000, 0, 0), MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB0__EPDC_PWR_COM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU1_CSI1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), - MX6_PAD_EIM_EB1__MIPI_CORE_DPHY_TEST_OUT_1 = IOMUX_PAD(0x0598, 0x01C8, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__TPSMP_HDATA_13 = IOMUX_PAD(0x0598, 0x01C8, 6, 0x0000, 0, 0), MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EPDC_SDSHR = IOMUX_PAD(0x0598, 0x01C8, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x059C, 0x01CC, 1, 0x07E4, 2, 0), - MX6_PAD_EIM_EB2__CCM_DI1_EXT_CLK = IOMUX_PAD(0x059C, 0x01CC, 2, 0x07D0, 1, 0), MX6_PAD_EIM_EB2__IPU1_CSI1_DATA19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x059C, 0x01CC, 4, 0x0860, 0, 0), MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), @@ -884,90 +619,68 @@ enum { MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x05A4, 0x01D4, 1, 0x0000, 0, 0), MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x05A4, 0x01D4, 2, 0x0804, 1, 0), MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x05A4, 0x01D4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__TPSMP_HDATA_11 = IOMUX_PAD(0x05A4, 0x01D4, 6, 0x0000, 0, 0), MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x05A4, 0x01D4, 7, 0x0000, 0, 0), MX6_PAD_EIM_LBA__EPDC_DATA04 = IOMUX_PAD(0x05A4, 0x01D4, 8, 0x0000, 0, 0), MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x05A8, 0x01D8, 0, 0x0000, 0, 0), MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x05A8, 0x01D8, 1, 0x0000, 0, 0), MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x05A8, 0x01D8, 2, 0x07F8, 2, 0), - MX6_PAD_EIM_OE__MIPI_CORE_DPHY_TEST_OUT_26 = IOMUX_PAD(0x05A8, 0x01D8, 4, 0x0000, 0, 0), MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_OE__TPSMP_HDATA_9 = IOMUX_PAD(0x05A8, 0x01D8, 6, 0x0000, 0, 0), MX6_PAD_EIM_OE__EPDC_PWR_IRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x05AC, 0x01DC, 2, 0x0800, 2, 0), - MX6_PAD_EIM_RW__MIPI_CORE_DPHY_TEST_OUT_27 = IOMUX_PAD(0x05AC, 0x01DC, 4, 0x0000, 0, 0), MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__TPSMP_HDATA_10 = IOMUX_PAD(0x05AC, 0x01DC, 6, 0x0000, 0, 0), MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), MX6_PAD_EIM_RW__EPDC_DATA07 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__TPSMP_HDATA_30 = IOMUX_PAD(0x05B0, 0x01E0, 6, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x05B4, 0x01E4, 1, 0x0828, 0, 0), MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__PHY_TDO = IOMUX_PAD(0x05B4, 0x01E4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x05B4, 0x01E4, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x05B8, 0x01E8, 2, 0x0858, 0, 0), MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x05B8, 0x01E8, 4, 0x0000, 0, 0), MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x05B8, 0x01E8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05B8, 0x01E8, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x05BC, 0x01EC, 2, 0x083C, 0, 0), - MX6_PAD_ENET_MDIO__SDMA_DEBUG_BUS_DEVICE_3 = IOMUX_PAD(0x05BC, 0x01EC, 3, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x05BC, 0x01EC, 4, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), - MX6_PAD_ENET_REF_CLK__SDMA_DEBUG_BUS_DEVICE_4 = IOMUX_PAD(0x05C0, 0x01F0, 3, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x05C0, 0x01F0, 7, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x05C4, 0x01F4, 1, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__PHY_TDI = IOMUX_PAD(0x05C4, 0x01F4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x05C4, 0x01F4, 7, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__OSC32K_32K_OUT = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__PHY_TMS = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x05C8, 0x01F8, 7, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__PHY_TCK = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05CC, 0x01FC, 7, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x05D0, 0x0200, 7, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__I2C4_SCL = IOMUX_PAD(0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0), MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x05D4, 0x0204, 7, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x05D8, 0x0208, 7, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__I2C4_SDA = IOMUX_PAD(0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0), MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), @@ -983,7 +696,6 @@ enum { MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_1__SRC_TESTER_ACK = IOMUX_PAD(0x05E0, 0x0210, 7, 0x0000, 0, 0), MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x05E4, 0x0214, 1, 0x0000, 0, 0), MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), @@ -998,7 +710,6 @@ enum { MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x08E8, 1, 0), MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_17__SJC_JTAG_ACT = IOMUX_PAD(0x05E8, 0x0218, 7, 0x0000, 0, 0), MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x05EC, 0x021C, 0, 0x0848, 0, 0), MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0814, 0, 0), MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), @@ -1006,7 +717,6 @@ enum { MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SRC_SYSTEM_RST = IOMUX_PAD(0x05EC, 0x021C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x05F0, 0x0220, 1, 0x0000, 0, 0), MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), @@ -1014,17 +724,12 @@ enum { MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SRC_INT_BOOT = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), - MX6_PAD_GPIO_2__OBSERVE_MUX_OBSRV_INT_OUT2 = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), - MX6_PAD_GPIO_2__CCM_CCM_OUT_1 = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_2__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), - MX6_PAD_GPIO_3__OBSERVE_MUX_OBSRV_INT_OUT0 = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0), MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), @@ -1032,26 +737,17 @@ enum { MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), - MX6_PAD_GPIO_4__OBSERVE_MUX_OBSRV_INT_OUT3 = IOMUX_PAD(0x05FC, 0x022C, 1, 0x0000, 0, 0), MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), - MX6_PAD_GPIO_4__CCM_CCM_OUT_2 = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_4__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_4__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x0600, 0x0230, 0, 0x084C, 1, 0), - MX6_PAD_GPIO_5__OBSERVE_MUX_OBSRV_INT_OUT4 = IOMUX_PAD(0x0600, 0x0230, 1, 0x0000, 0, 0), MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x0600, 0x0230, 2, 0x08D4, 1, 0), MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_5__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x0600, 0x0230, 4, 0x0000, 0, 0), MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0), MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x0600, 0x0230, 7, 0x0000, 0, 0), MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0604, 0x0234, 0, 0x0840, 1, 0), - MX6_PAD_GPIO_6__OBSERVE_MUX_OBSRV_INT_OUT1 = IOMUX_PAD(0x0604, 0x0234, 1, 0x0000, 0, 0), MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0), - MX6_PAD_GPIO_6__CCM_CCM_OUT_0 = IOMUX_PAD(0x0604, 0x0234, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_6__CSU_CSU_INT_DEB = IOMUX_PAD(0x0604, 0x0234, 4, 0x0000, 0, 0), MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), @@ -1081,13 +777,6 @@ enum { MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), - MX6_PAD_GPIO_9__SRC_EARLY_RST = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), - MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x0614, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0618, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x061C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x0620, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x0624, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TRSTB__SJC_TRSTB = IOMUX_PAD(0x0628, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x062C, 0x0244, 0, 0x07D8, 3, 0), MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), @@ -1096,7 +785,6 @@ enum { MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__SRC_ANY_PU_RST = IOMUX_PAD(0x062C, 0x0244, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x0630, 0x0248, 0, 0x07DC, 3, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x0630, 0x0248, 1, 0x0810, 1, 0), MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), @@ -1105,7 +793,6 @@ enum { MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__PL301_SIM_MX6DL_PER1_HADDR_1 = IOMUX_PAD(0x0630, 0x0248, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x0634, 0x024C, 0, 0x07E8, 2, 0), MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), @@ -1113,7 +800,6 @@ enum { MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x0634, 0x024C, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x0634, 0x024C, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x0634, 0x024C, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__PL301_SIM_MX6DL_PER1_HADDR_3 = IOMUX_PAD(0x0634, 0x024C, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x0638, 0x0250, 0, 0x07F0, 1, 0), MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x0638, 0x0250, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x0638, 0x0250, 2, 0x0860, 1, 0), @@ -1121,7 +807,6 @@ enum { MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0), MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), - MX6_PAD_KEY_COL3__PL301_SIM_MX6DL_PER1_HADDR_5 = IOMUX_PAD(0x0638, 0x0250, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), @@ -1129,8 +814,6 @@ enum { MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__MMDC_MMDC_DEBUG_49 = IOMUX_PAD(0x063C, 0x0254, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__PL301_SIM_MX6DL_PER1_HADDR_7 = IOMUX_PAD(0x063C, 0x0254, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0640, 0x0258, 0, 0x07E0, 3, 0), MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), @@ -1139,7 +822,6 @@ enum { MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__PL301_SIM_MX6DL_PER1_HADDR_0 = IOMUX_PAD(0x0640, 0x0258, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x025C, 0, 0x07E4, 3, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x0644, 0x025C, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), @@ -1148,7 +830,6 @@ enum { MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__PL301_SIM_MX6DL_PER1_HADDR_2 = IOMUX_PAD(0x0644, 0x025C, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x0648, 0x0260, 0, 0x07EC, 1, 0), MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), @@ -1156,15 +837,12 @@ enum { MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0648, 0x0260, 6, 0x085C, 1, 0), - MX6_PAD_KEY_ROW2__PL301_SIM_MX6DL_PER1_HADDR_4 = IOMUX_PAD(0x0648, 0x0260, 7, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__OSC32K_32K_OUT = IOMUX_PAD(0x064C, 0x0264, 0, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x064C, 0x0264, 2, 0x0864, 1, 0), MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__PL301_SIM_MX6DL_PER1_HADDR_6 = IOMUX_PAD(0x064C, 0x0264, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), @@ -1172,421 +850,234 @@ enum { MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__MMDC_MMDC_DEBUG_50 = IOMUX_PAD(0x0650, 0x0268, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__PL301_SIM_MX6DL_PER1_HADDR_8 = IOMUX_PAD(0x0650, 0x0268, 7, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_0 = IOMUX_PAD(0x0654, 0x026C, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USBOH3_UH3_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USBOH3_UH2_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x0654, 0x026C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__MIPI_CORE_DPHY_TEST_IN_24 = IOMUX_PAD(0x0654, 0x026C, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USDHC3_CLKI = IOMUX_PAD(0x0654, 0x026C, 8, 0x0934, 0, 0), MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x0658, 0x0270, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_31 = IOMUX_PAD(0x0658, 0x0270, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__USBOH3_UH3_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__USBOH3_UH2_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x0658, 0x0270, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__MIPI_CORE_DPHY_TEST_IN_23 = IOMUX_PAD(0x0658, 0x0270, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__USDHC3_CLKO = IOMUX_PAD(0x0658, 0x0270, 8, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__USBOH3_UH3_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__USBOH3_UH2_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__USDHC1_CLKO = IOMUX_PAD(0x065C, 0x0274, 8, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_3 = IOMUX_PAD(0x0660, 0x0278, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__PL301_SIM_MX6DL_PER1_HREADYOUT = IOMUX_PAD(0x0660, 0x0278, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__USDHC1_CLKI = IOMUX_PAD(0x0660, 0x0278, 8, 0x0928, 0, 0), MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x0664, 0x027C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__USDHC2_CLKO = IOMUX_PAD(0x0664, 0x027C, 8, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_4 = IOMUX_PAD(0x0668, 0x0280, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__TPSMP_CLK = IOMUX_PAD(0x0668, 0x0280, 7, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__USDHC2_CLKI = IOMUX_PAD(0x0668, 0x0280, 8, 0x0930, 0, 0), MX6_PAD_NANDF_CS3__I2C4_SDA = IOMUX_PAD(0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0), MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x066C, 0x0284, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPU3D_GPU_DEBUG_OUT_0 = IOMUX_PAD(0x066C, 0x0284, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USBOH3_UH2_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USBOH3_UH3_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x066C, 0x0284, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__IPU1_IPU_DIAG_BUS_0 = IOMUX_PAD(0x066C, 0x0284, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x0670, 0x0288, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x0670, 0x0288, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPU3D_GPU_DEBUG_OUT_1 = IOMUX_PAD(0x0670, 0x0288, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USBOH3_UH2_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USBOH3_UH3_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__IPU1_IPU_DIAG_BUS_1 = IOMUX_PAD(0x0670, 0x0288, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x0674, 0x028C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x0674, 0x028C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPU3D_GPU_DEBUG_OUT_2 = IOMUX_PAD(0x0674, 0x028C, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USBOH3_UH2_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USBOH3_UH3_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__IPU1_IPU_DIAG_BUS_2 = IOMUX_PAD(0x0674, 0x028C, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x0678, 0x0290, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x0678, 0x0290, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPU3D_GPU_DEBUG_OUT_3 = IOMUX_PAD(0x0678, 0x0290, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USBOH3_UH2_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USBOH3_UH3_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__IPU1_IPU_DIAG_BUS_3 = IOMUX_PAD(0x0678, 0x0290, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x067C, 0x0294, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x067C, 0x0294, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPU3D_GPU_DEBUG_OUT_4 = IOMUX_PAD(0x067C, 0x0294, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USBOH3_UH2_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USBOH3_UH3_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x067C, 0x0294, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__IPU1_IPU_DIAG_BUS_4 = IOMUX_PAD(0x067C, 0x0294, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x0680, 0x0298, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x0680, 0x0298, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPU3D_GPU_DEBUG_OUT_5 = IOMUX_PAD(0x0680, 0x0298, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USBOH3_UH2_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USBOH3_UH3_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x0680, 0x0298, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__IPU1_IPU_DIAG_BUS_5 = IOMUX_PAD(0x0680, 0x0298, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x0684, 0x029C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x0684, 0x029C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPU3D_GPU_DEBUG_OUT_6 = IOMUX_PAD(0x0684, 0x029C, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USBOH3_UH2_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USBOH3_UH3_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x0684, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__IPU1_IPU_DIAG_BUS_6 = IOMUX_PAD(0x0684, 0x029C, 6, 0x0000, 0, 0), MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPU3D_GPU_DEBUG_OUT_7 = IOMUX_PAD(0x0688, 0x02A0, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USBOH3_UH2_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USBOH3_UH3_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__IPU1_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0688, 0x02A0, 6, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_2 = IOMUX_PAD(0x068C, 0x02A4, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__USBOH3_UH3_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__USBOH3_UH2_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 4, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__MIPI_CORE_DPHY_TEST_OUT_33 = IOMUX_PAD(0x068C, 0x02A4, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__USDHC4_CLKI = IOMUX_PAD(0x068C, 0x02A4, 8, 0x0938, 0, 0), MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__PCIE_CTRL_DIAG_STATUS_BUS_MUX_1 = IOMUX_PAD(0x0690, 0x02A8, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__USBOH3_UH3_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__USBOH3_UH2_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 4, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__MIPI_CORE_DPHY_TEST_OUT_32 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__USDHC4_CLKO = IOMUX_PAD(0x0690, 0x02A8, 8, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__MIPI_CORE_DPHY_TEST_IN_6 = IOMUX_PAD(0x0694, 0x02AC, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__MIPI_CORE_DPHY_TEST_IN_8 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__SJC_FAIL = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__MIPI_CORE_DPHY_TEST_IN_9 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__MIPI_CORE_DPHY_TEST_IN_10 = IOMUX_PAD(0x06A0, 0x02B8, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0828, 1, 0), MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__MIPI_CORE_DPHY_TEST_IN_5 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__MIPI_CORE_DPHY_TEST_IN_11 = IOMUX_PAD(0x06A8, 0x02C0, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__MIPI_CORE_DPHY_TEST_IN_1 = IOMUX_PAD(0x06AC, 0x02C4, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__MIPI_CORE_DPHY_TEST_IN_2 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__CCM_PLL3_BYP = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__MIPI_CORE_DPHY_TEST_IN_3 = IOMUX_PAD(0x06B4, 0x02CC, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__CCM_PLL2_BYP = IOMUX_PAD(0x06B4, 0x02CC, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__MIPI_CORE_DPHY_TEST_IN_4 = IOMUX_PAD(0x06B8, 0x02D0, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__MIPI_CORE_DPHY_TEST_IN_7 = IOMUX_PAD(0x06BC, 0x02D4, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__MIPI_CORE_DPHY_TEST_IN_0 = IOMUX_PAD(0x06C0, 0x02D8, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), - MX6_PAD_SD1_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x06C4, 0x02DC, 2, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__PHY_DTB_0 = IOMUX_PAD(0x06C4, 0x02DC, 6, 0x0000, 0, 0), MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__ANATOP_ANATOP_TESTO_5 = IOMUX_PAD(0x06C8, 0x02E0, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__CAAM_WRAPPER_RNG_OSC_OBS = IOMUX_PAD(0x06CC, 0x02E4, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_8 = IOMUX_PAD(0x06CC, 0x02E4, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__HDMI_TX_OPHYDTB_1 = IOMUX_PAD(0x06CC, 0x02E4, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__ANATOP_ANATOP_TESTO_7 = IOMUX_PAD(0x06CC, 0x02E4, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x06D0, 0x02E8, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_7 = IOMUX_PAD(0x06D0, 0x02E8, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__HDMI_TX_OPHYDTB_0 = IOMUX_PAD(0x06D0, 0x02E8, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__ANATOP_ANATOP_TESTO_8 = IOMUX_PAD(0x06D0, 0x02E8, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__PWM2_OUT = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__ANATOP_ANATOP_TESTO_4 = IOMUX_PAD(0x06D4, 0x02EC, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__PWM1_OUT = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__ANATOP_ANATOP_TESTO_6 = IOMUX_PAD(0x06D8, 0x02F0, 7, 0x0000, 0, 0), MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), - MX6_PAD_SD2_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_9 = IOMUX_PAD(0x06DC, 0x02F4, 4, 0x0000, 0, 0), MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__PHY_DTB_1 = IOMUX_PAD(0x06DC, 0x02F4, 6, 0x0000, 0, 0), MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), - MX6_PAD_SD2_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_10 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__ANATOP_ANATOP_TESTO_2 = IOMUX_PAD(0x06E4, 0x02FC, 7, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__CCM_WAIT = IOMUX_PAD(0x06E8, 0x0300, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__ANATOP_ANATOP_TESTO_0 = IOMUX_PAD(0x06E8, 0x0300, 7, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__CCM_STOP = IOMUX_PAD(0x06EC, 0x0304, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__ANATOP_ANATOP_TESTO_1 = IOMUX_PAD(0x06EC, 0x0304, 7, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), - MX6_PAD_SD2_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_11 = IOMUX_PAD(0x06F0, 0x0308, 4, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__SJC_DONE = IOMUX_PAD(0x06F0, 0x0308, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__ANATOP_ANATOP_TESTO_3 = IOMUX_PAD(0x06F0, 0x0308, 7, 0x0000, 0, 0), MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0900, 2, 0), MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06F4, 0x030C, 2, 0x07C8, 2, 0), - MX6_PAD_SD3_CLK__USBOH3_UH3_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 3, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__USBOH3_UH2_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 4, 0x0000, 0, 0), MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_TEST_IN_17 = IOMUX_PAD(0x06F4, 0x030C, 6, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__ANATOP_ANATOP_TESTO_14 = IOMUX_PAD(0x06F4, 0x030C, 7, 0x0000, 0, 0), MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0900, 3, 0), MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 3, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USBOH3_UH2_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 4, 0x0000, 0, 0), MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__MIPI_CORE_DPHY_TEST_IN_16 = IOMUX_PAD(0x06F8, 0x0310, 6, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__ANATOP_ANATOP_TESTO_13 = IOMUX_PAD(0x06F8, 0x0310, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x08F8, 2, 0), MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USBOH3_UH2_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__MIPI_CORE_DPHY_TEST_IN_18 = IOMUX_PAD(0x06FC, 0x0314, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__ANATOP_ANATOP_TESTO_15 = IOMUX_PAD(0x06FC, 0x0314, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x08F8, 3, 0), MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x0700, 0x0318, 2, 0x07CC, 1, 0), - MX6_PAD_SD3_DAT1__USBOH3_UH3_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__USBOH3_UH2_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__MIPI_CORE_DPHY_TEST_IN_19 = IOMUX_PAD(0x0700, 0x0318, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__ANATOP_ANATOP_TESTI_0 = IOMUX_PAD(0x0700, 0x0318, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__PCIE_CTRL_DIAG_STATUS_BUS_MUX_28 = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USBOH3_UH3_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USBOH3_UH2_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_TEST_IN_20 = IOMUX_PAD(0x0704, 0x031C, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__ANATOP_ANATOP_TESTI_1 = IOMUX_PAD(0x0704, 0x031C, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0908, 4, 0), - MX6_PAD_SD3_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_29 = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USBOH3_UH2_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__MIPI_CORE_DPHY_TEST_IN_21 = IOMUX_PAD(0x0708, 0x0320, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__ANATOP_ANATOP_TESTI_2 = IOMUX_PAD(0x0708, 0x0320, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0904, 4, 0), - MX6_PAD_SD3_DAT4__PCIE_CTRL_DIAG_STATUS_BUS_MUX_27 = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USBOH3_UH2_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_TEST_IN_15 = IOMUX_PAD(0x070C, 0x0324, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__ANATOP_ANATOP_TESTO_12 = IOMUX_PAD(0x070C, 0x0324, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0904, 5, 0), - MX6_PAD_SD3_DAT5__PCIE_CTRL_DIAG_STATUS_BUS_MUX_26 = IOMUX_PAD(0x0710, 0x0328, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USBOH3_UH3_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USBOH3_UH2_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_TEST_IN_14 = IOMUX_PAD(0x0710, 0x0328, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__ANATOP_ANATOP_TESTO_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x08FC, 2, 0), - MX6_PAD_SD3_DAT6__PCIE_CTRL_DIAG_STATUS_BUS_MUX_25 = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USBOH3_UH2_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__MIPI_CORE_DPHY_TEST_IN_13 = IOMUX_PAD(0x0714, 0x032C, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__ANATOP_ANATOP_TESTO_10 = IOMUX_PAD(0x0714, 0x032C, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x08FC, 3, 0), - MX6_PAD_SD3_DAT7__PCIE_CTRL_DIAG_STATUS_BUS_MUX_24 = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USBOH3_UH3_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USBOH3_UH2_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_TEST_IN_12 = IOMUX_PAD(0x0718, 0x0330, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0908, 5, 0), - MX6_PAD_SD3_RST__PCIE_CTRL_DIAG_STATUS_BUS_MUX_30 = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USBOH3_UH3_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USBOH3_UH2_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0), MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), - MX6_PAD_SD3_RST__MIPI_CORE_DPHY_TEST_IN_22 = IOMUX_PAD(0x071C, 0x0334, 6, 0x0000, 0, 0), - MX6_PAD_SD3_RST__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x071C, 0x0334, 7, 0x0000, 0, 0), MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x0720, 0x0338, 0, 0x0938, 1, 0), MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x090C, 2, 0), - MX6_PAD_SD4_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_6 = IOMUX_PAD(0x0720, 0x0338, 4, 0x0000, 0, 0), MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x0724, 0x033C, 1, 0x0000, 0, 0), MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x090C, 3, 0), - MX6_PAD_SD4_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_5 = IOMUX_PAD(0x0724, 0x033C, 4, 0x0000, 0, 0), MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__RAWNAND_D8 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0728, 0x0340, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USBOH3_UH2_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USBOH3_UH3_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__IPU1_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0728, 0x0340, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__RAWNAND_D9 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USBOH3_UH2_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USBOH3_UH3_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__IPU1_IPU_DIAG_BUS_9 = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__RAWNAND_D10 = IOMUX_PAD(0x0730, 0x0348, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x0730, 0x0348, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USBOH3_UH2_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USBOH3_UH3_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__IPU1_IPU_DIAG_BUS_10 = IOMUX_PAD(0x0730, 0x0348, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__RAWNAND_D11 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USBOH3_UH2_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USBOH3_UH3_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__IPU1_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0738, 0x0350, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0904, 6, 0), - MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__IPU1_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0738, 0x0350, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__RAWNAND_D13 = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x073C, 0x0354, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0900, 4, 0), - MX6_PAD_SD4_DAT5__USBOH3_UH2_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__USBOH3_UH3_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__IPU1_IPU_DIAG_BUS_13 = IOMUX_PAD(0x073C, 0x0354, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x0740, 0x0358, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x0740, 0x0358, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0900, 5, 0), - MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__IPU1_IPU_DIAG_BUS_14 = IOMUX_PAD(0x0740, 0x0358, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__RAWNAND_D15 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0904, 7, 0), - MX6_PAD_SD4_DAT7__USBOH3_UH2_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__USBOH3_UH3_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__IPU1_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0744, 0x035C, 6, 0x0000, 0, 0), }; #endif /* __ASM_ARCH_MX6_MX6DL_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index ec1bbdd..5e38556 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -18,77 +18,57 @@ enum { MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x0360, 0x004C, 4, 0x08F0, 0, 0), MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__CCM_WAIT = IOMUX_PAD(0x0360, 0x004C, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__ANATOP_TESTO_0 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0364, 0x0050, 1, 0x0838, 0, 0), MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x0364, 0x0050, 4, 0x08F8, 0, 0), MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__CCM_STOP = IOMUX_PAD(0x0364, 0x0050, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__ANATOP_TESTO_1 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0368, 0x0054, 1, 0x082C, 0, 0), MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x0368, 0x0054, 4, 0x08FC, 0, 0), MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__TESTO_2 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x036C, 0x0058, 2, 0x0918, 0, 0), MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__MIPI_CORE_DPHY_IN_0 = IOMUX_PAD(0x036C, 0x0058, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__MIPI_CORE_DPHY_IN_1 = IOMUX_PAD(0x0370, 0x005C, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__MIPI_CORE_DPHY_IN_2 = IOMUX_PAD(0x0374, 0x0060, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__CCM_PLL3_BYP = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__MIPI_CORE_DPHY_IN_3 = IOMUX_PAD(0x0378, 0x0064, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__CCM_PLL2_BYP = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__MIPI_CORE_DPHY_IN_4 = IOMUX_PAD(0x037C, 0x0068, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x0380, 0x006C, 1, 0x0858, 0, 0), MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__MIPI_DPHY_IN_5 = IOMUX_PAD(0x0380, 0x006C, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__MIPI_CORE_DPHY_IN_6 = IOMUX_PAD(0x0384, 0x0070, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__CORE_DPHY_IN_7 = IOMUX_PAD(0x0388, 0x0074, 6, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x0388, 0x0074, 7, 0x083C, 0, 0), MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__CORE_DPHY_TEST_IN_8 = IOMUX_PAD(0x038C, 0x0078, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__SJC_FAIL = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__MIPI_CORE_DPHY_IN_9 = IOMUX_PAD(0x0390, 0x007C, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__MIPI_CORE_DPHY_IN10 = IOMUX_PAD(0x0394, 0x0080, 6, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__MIPI_CORE_DPHY_IN11 = IOMUX_PAD(0x0398, 0x0084, 6, 0x0000, 0, 0), MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x039C, 0x0088, 2, 0x0000, 0, 0), @@ -96,10 +76,8 @@ enum { MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x039C, 0x0088, 4, 0x0000, 0, 0), MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x039C, 0x0088, 6, 0x088C, 0, 0), - MX6_PAD_EIM_A25__PL301_PER1_HBURST_0 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0800, 0, 0), - MX6_PAD_EIM_EB2__CCM_DI1_EXT_CLK = IOMUX_PAD(0x03A0, 0x008C, 2, 0x07EC, 0, 0), MX6_PAD_EIM_EB2__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03A0, 0x008C, 3, 0x08D4, 0, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0890, 0, 0), MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), @@ -119,7 +97,6 @@ enum { MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x03A8, 0x0094, 22, 0x08A8, 0, 0), - MX6_PAD_EIM_D17__PL301_PER1_HBURST_1 = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x0098, 1, 0x07FC, 0, 0), MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), @@ -127,7 +104,6 @@ enum { MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x03AC, 0x0098, 22, 0x08AC, 0, 0), - MX6_PAD_EIM_D18__PL301_PER1_HBURST_2 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0804, 0, 0), MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), @@ -136,7 +112,6 @@ enum { MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D19__PL301MX6QPER1_HRESP = IOMUX_PAD(0x03B0, 0x009C, 7, 0x0000, 0, 0), MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0824, 0, 0), MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), @@ -160,7 +135,6 @@ enum { MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D22__PL301MX6QPER1_HWRITE = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), @@ -240,7 +214,6 @@ enum { MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), - MX6_PAD_EIM_D30__PL301MX6QPER1_HPROT_0 = IOMUX_PAD(0x03E0, 0x00CC, 7, 0x0000, 0, 0), MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x0000, 0, 0), @@ -249,14 +222,12 @@ enum { MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x092C, 3, 0), MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D31__PL301MX6QPER1_HPROT_1 = IOMUX_PAD(0x03E4, 0x00D0, 7, 0x0000, 0, 0), MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x08D4, 1, 0), MX6_PAD_EIM_A24__IPU2_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x0000, 0, 0), MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A24__PL301MX6QPER1_HPROT_2 = IOMUX_PAD(0x03E8, 0x00D4, 6, 0x0000, 0, 0), MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), @@ -264,419 +235,264 @@ enum { MX6_PAD_EIM_A23__IPU2_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x0000, 0, 0), MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A23__PL301MX6QPER1_HPROT_3 = IOMUX_PAD(0x03EC, 0x00D8, 6, 0x0000, 0, 0), MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x08CC, 1, 0), MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A22__TPSMP_HDATA_0 = IOMUX_PAD(0x03F0, 0x00DC, 6, 0x0000, 0, 0), MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x08C8, 1, 0), - MX6_PAD_EIM_A21__RESERVED_RESERVED = IOMUX_PAD(0x03F4, 0x00E0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A21__MIPI_CORE_DPHY_OUT_18 = IOMUX_PAD(0x03F4, 0x00E0, 4, 0x0000, 0, 0), MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A21__TPSMP_HDATA_1 = IOMUX_PAD(0x03F4, 0x00E0, 6, 0x0000, 0, 0), MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x08C4, 1, 0), - MX6_PAD_EIM_A20__RESERVED_RESERVED = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A20__MIPI_CORE_DPHY_OUT_19 = IOMUX_PAD(0x03F8, 0x00E4, 4, 0x0000, 0, 0), MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A20__TPSMP_HDATA_2 = IOMUX_PAD(0x03F8, 0x00E4, 6, 0x0000, 0, 0), MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x08C0, 1, 0), - MX6_PAD_EIM_A19__RESERVED_RESERVED = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A19__MIPI_CORE_DPHY_OUT_20 = IOMUX_PAD(0x03FC, 0x00E8, 4, 0x0000, 0, 0), MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A19__TPSMP_HDATA_3 = IOMUX_PAD(0x03FC, 0x00E8, 6, 0x0000, 0, 0), MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU2_CSI1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 2, 0x08BC, 1, 0), - MX6_PAD_EIM_A18__RESERVED_RESERVED = IOMUX_PAD(0x0400, 0x00EC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A18__MIPI_CORE_DPHY_OUT_21 = IOMUX_PAD(0x0400, 0x00EC, 4, 0x0000, 0, 0), MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A18__TPSMP_HDATA_4 = IOMUX_PAD(0x0400, 0x00EC, 6, 0x0000, 0, 0), MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU2_CSI1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x08B8, 1, 0), - MX6_PAD_EIM_A17__RESERVED_RESERVED = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A17__MIPI_CORE_DPHY_OUT_22 = IOMUX_PAD(0x0404, 0x00F0, 4, 0x0000, 0, 0), MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A17__TPSMP_HDATA_5 = IOMUX_PAD(0x0404, 0x00F0, 6, 0x0000, 0, 0), MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x0408, 0x00F4, 2, 0x08E0, 1, 0), - MX6_PAD_EIM_A16__MIPI_CORE_DPHY_OUT_23 = IOMUX_PAD(0x0408, 0x00F4, 4, 0x0000, 0, 0), MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A16__TPSMP_HDATA_6 = IOMUX_PAD(0x0408, 0x00F4, 6, 0x0000, 0, 0), MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0810, 0, 0), - MX6_PAD_EIM_CS0__MIPI_CORE_DPHY_OUT_24 = IOMUX_PAD(0x040C, 0x00F8, 4, 0x0000, 0, 0), MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__TPSMP_HDATA_7 = IOMUX_PAD(0x040C, 0x00F8, 6, 0x0000, 0, 0), MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0818, 0, 0), - MX6_PAD_EIM_CS1__MIPI_CORE_DPHY_OUT_25 = IOMUX_PAD(0x0410, 0x00FC, 4, 0x0000, 0, 0), MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__TPSMP_HDATA_8 = IOMUX_PAD(0x0410, 0x00FC, 6, 0x0000, 0, 0), MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, 0), MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x0414, 0x0100, 2, 0x0814, 0, 0), - MX6_PAD_EIM_OE__MIPI_CORE_DPHY_OUT_26 = IOMUX_PAD(0x0414, 0x0100, 4, 0x0000, 0, 0), MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), - MX6_PAD_EIM_OE__TPSMP_HDATA_9 = IOMUX_PAD(0x0414, 0x0100, 6, 0x0000, 0, 0), MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x0418, 0x0104, 2, 0x081C, 0, 0), - MX6_PAD_EIM_RW__MIPI_CORE_DPHY_OUT_27 = IOMUX_PAD(0x0418, 0x0104, 4, 0x0000, 0, 0), MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__TPSMP_HDATA_10 = IOMUX_PAD(0x0418, 0x0104, 6, 0x0000, 0, 0), MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, 0), MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x041C, 0x0108, 2, 0x0820, 0, 0), MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__TPSMP_HDATA_11 = IOMUX_PAD(0x041C, 0x0108, 6, 0x0000, 0, 0), MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU2_CSI1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 2, 0x08B4, 1, 0), - MX6_PAD_EIM_EB0__MIPI_CORE_DPHY_OUT_0 = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0420, 0x010C, 4, 0x07F0, 0, 0), MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__TPSMP_HDATA_12 = IOMUX_PAD(0x0420, 0x010C, 6, 0x0000, 0, 0), MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU2_CSI1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 2, 0x08B0, 1, 0), - MX6_PAD_EIM_EB1__MIPI_CORE_DPHY__OUT_1 = IOMUX_PAD(0x0424, 0x0110, 3, 0x0000, 0, 0), MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0424, 0x0110, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__TPSMP_HDATA_13 = IOMUX_PAD(0x0424, 0x0110, 6, 0x0000, 0, 0), MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0424, 0x0110, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU2_CSI1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__MIPI_CORE_DPHY__OUT_2 = IOMUX_PAD(0x0428, 0x0114, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0428, 0x0114, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__TPSMP_HDATA_14 = IOMUX_PAD(0x0428, 0x0114, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0428, 0x0114, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU2_CSI1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__MIPI_CORE_DPHY_OUT_3 = IOMUX_PAD(0x042C, 0x0118, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__USBPHY1_TX_LS_MODE = IOMUX_PAD(0x042C, 0x0118, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x042C, 0x0118, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__TPSMP_HDATA_15 = IOMUX_PAD(0x042C, 0x0118, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x042C, 0x0118, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU2_CSI1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__MIPI_CORE_DPHY_OUT_4 = IOMUX_PAD(0x0430, 0x011C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__USBPHY1_TX_HS_MODE = IOMUX_PAD(0x0430, 0x011C, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0430, 0x011C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__TPSMP_HDATA_16 = IOMUX_PAD(0x0430, 0x011C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0430, 0x011C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU2_CSI1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__MIPI_CORE_DPHY_OUT_5 = IOMUX_PAD(0x0434, 0x0120, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__USBPHY1_TX_HIZ = IOMUX_PAD(0x0434, 0x0120, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0434, 0x0120, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__TPSMP_HDATA_17 = IOMUX_PAD(0x0434, 0x0120, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0434, 0x0120, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU2_CSI1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__MIPI_CORE_DPHY_OUT_6 = IOMUX_PAD(0x0438, 0x0124, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__ANATOP_USBPHY1_TX_EN = IOMUX_PAD(0x0438, 0x0124, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x0438, 0x0124, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__TPSMP_HDATA_18 = IOMUX_PAD(0x0438, 0x0124, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x0438, 0x0124, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU2_CSI1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__MIPI_CORE_DPHY_OUT_7 = IOMUX_PAD(0x043C, 0x0128, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__ANATOP_USBPHY1_TX_DP = IOMUX_PAD(0x043C, 0x0128, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x043C, 0x0128, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__TPSMP_HDATA_19 = IOMUX_PAD(0x043C, 0x0128, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x043C, 0x0128, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU2_CSI1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__MIPI_CORE_DPHY_OUT_8 = IOMUX_PAD(0x0440, 0x012C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__ANATOP_USBPHY1_TX_DN = IOMUX_PAD(0x0440, 0x012C, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0440, 0x012C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__TPSMP_HDATA_20 = IOMUX_PAD(0x0440, 0x012C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0440, 0x012C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU2_CSI1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__MIPI_CORE_DPHY_OUT_9 = IOMUX_PAD(0x0444, 0x0130, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0444, 0x0130, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__TPSMP_HDATA_21 = IOMUX_PAD(0x0444, 0x0130, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0444, 0x0130, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU2_CSI1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__MIPI_CORE_DPHY_OUT_10 = IOMUX_PAD(0x0448, 0x0134, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x0448, 0x0134, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__TPSMP_HDATA_22 = IOMUX_PAD(0x0448, 0x0134, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x0448, 0x0134, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU2_CSI1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__MIPI_CORE_DPHY_OUT_11 = IOMUX_PAD(0x044C, 0x0138, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x044C, 0x0138, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__TPSMP_HDATA_23 = IOMUX_PAD(0x044C, 0x0138, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x044C, 0x0138, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x0450, 0x013C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x0450, 0x013C, 2, 0x08D8, 1, 0), - MX6_PAD_EIM_DA10__MIPI_CORE_DPHY_OUT12 = IOMUX_PAD(0x0450, 0x013C, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x0450, 0x013C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__TPSMP_HDATA_24 = IOMUX_PAD(0x0450, 0x013C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0450, 0x013C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0454, 0x0140, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU2_CSI1_HSYNC = IOMUX_PAD(0x0454, 0x0140, 2, 0x08DC, 1, 0), - MX6_PAD_EIM_DA11__MIPI_CORE_DPHY_OUT13 = IOMUX_PAD(0x0454, 0x0140, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SDMA_DBG_EVT_CHN_6 = IOMUX_PAD(0x0454, 0x0140, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0454, 0x0140, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__TPSMP_HDATA_25 = IOMUX_PAD(0x0454, 0x0140, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0454, 0x0140, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0458, 0x0144, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU2_CSI1_VSYNC = IOMUX_PAD(0x0458, 0x0144, 2, 0x08E4, 1, 0), - MX6_PAD_EIM_DA12__MIPI_CORE_DPHY_OUT14 = IOMUX_PAD(0x0458, 0x0144, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SDMA_DEBUG_EVT_CHN_3 = IOMUX_PAD(0x0458, 0x0144, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0458, 0x0144, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__TPSMP_HDATA_26 = IOMUX_PAD(0x0458, 0x0144, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0458, 0x0144, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x045C, 0x0148, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__CCM_DI1_EXT_CLK = IOMUX_PAD(0x045C, 0x0148, 2, 0x07EC, 1, 0), - MX6_PAD_EIM_DA13__MIPI_CORE_DPHY_OUT15 = IOMUX_PAD(0x045C, 0x0148, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SDMA_DEBUG_EVT_CHN_4 = IOMUX_PAD(0x045C, 0x0148, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x045C, 0x0148, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__TPSMP_HDATA_27 = IOMUX_PAD(0x045C, 0x0148, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x045C, 0x0148, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x0460, 0x014C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__CCM_DI0_EXT_CLK = IOMUX_PAD(0x0460, 0x014C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__MIPI_CORE_DPHY_OUT16 = IOMUX_PAD(0x0460, 0x014C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SDMA_DEBUG_EVT_CHN_5 = IOMUX_PAD(0x0460, 0x014C, 4, 0x0000, 0, 0), MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x0460, 0x014C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__TPSMP_HDATA_28 = IOMUX_PAD(0x0460, 0x014C, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0460, 0x014C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0464, 0x0150, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0464, 0x0150, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__MIPI_CORE_DPHY_OUT17 = IOMUX_PAD(0x0464, 0x0150, 3, 0x0000, 0, 0), MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0464, 0x0150, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__TPSMP_HDATA_29 = IOMUX_PAD(0x0464, 0x0150, 6, 0x0000, 0, 0), MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0464, 0x0150, 7, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x0468, 0x0154, 5, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__TPSMP_HDATA_30 = IOMUX_PAD(0x0468, 0x0154, 6, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x0468, 0x0154, 7, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x046C, 0x0158, 1, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x046C, 0x0158, 6, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__MIPI_CR_DPY_OT28 = IOMUX_PAD(0x0470, 0x015C, 3, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__SDMA_DBG_CR_STA0 = IOMUX_PAD(0x0470, 0x015C, 4, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__MMDC_DEBUG_0 = IOMUX_PAD(0x0470, 0x015C, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__IPU2_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__MIPI_CR_DPHY_OUT_29 = IOMUX_PAD(0x0474, 0x0160, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__SDMA_DBG_CORE_STA_1 = IOMUX_PAD(0x0474, 0x0160, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x0474, 0x0160, 6, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN2__IPU2_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__MIPI_CR_DPHY_OUT_30 = IOMUX_PAD(0x0478, 0x0164, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__SDMA_DBG_CORE_STA_2 = IOMUX_PAD(0x0478, 0x0164, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__MMDC_DEBUG_2 = IOMUX_PAD(0x0478, 0x0164, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__PL301_PER1_HADDR_9 = IOMUX_PAD(0x0478, 0x0164, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN3__IPU2_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__MIPI_CORE_DPHY_OUT31 = IOMUX_PAD(0x047C, 0x0168, 3, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__SDMA_DBG_CORE_STA_3 = IOMUX_PAD(0x047C, 0x0168, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x047C, 0x0168, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x047C, 0x0168, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__PL301_PER1_HADDR_10 = IOMUX_PAD(0x047C, 0x0168, 7, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 0, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__IPU2_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 1, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), - MX6_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x0480, 0x016C, 4, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x0480, 0x016C, 6, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__PL301_PER1_HADDR_11 = IOMUX_PAD(0x0480, 0x016C, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__USDHC1_USDHC_DBG_0 = IOMUX_PAD(0x0484, 0x0170, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__SDMA_DBG_CORE_RUN = IOMUX_PAD(0x0484, 0x0170, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x0484, 0x0170, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__USDHC1_USDHC_DBG_1 = IOMUX_PAD(0x0488, 0x0174, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__SDMA_DBG_EVT_CHNSL = IOMUX_PAD(0x0488, 0x0174, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__MMDC_DEBUG_6 = IOMUX_PAD(0x0488, 0x0174, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__PL301_PER1_HADR_12 = IOMUX_PAD(0x0488, 0x0174, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__USDHC1_USDHC_DBG_2 = IOMUX_PAD(0x048C, 0x0178, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__SDMA_DEBUG_MODE = IOMUX_PAD(0x048C, 0x0178, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__MMDC_DEBUG_7 = IOMUX_PAD(0x048C, 0x0178, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__PL301_PER1_HADR_13 = IOMUX_PAD(0x048C, 0x0178, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0490, 0x017C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__USDHC1_USDHC_DBG_3 = IOMUX_PAD(0x0490, 0x017C, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__SDMA_DBG_BUS_ERROR = IOMUX_PAD(0x0490, 0x017C, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0490, 0x017C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__MMDC_MMDC_DBG_8 = IOMUX_PAD(0x0490, 0x017C, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__PL301_PER1_HADR_14 = IOMUX_PAD(0x0490, 0x017C, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x0494, 0x0180, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__USDHC1_USDHC_DBG_4 = IOMUX_PAD(0x0494, 0x0180, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x0494, 0x0180, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x0494, 0x0180, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x0494, 0x0180, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__PL301_PER1_HADR_15 = IOMUX_PAD(0x0494, 0x0180, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0498, 0x0184, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__SDMA_DBG_MCH_DMBUS = IOMUX_PAD(0x0498, 0x0184, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__MMDC_DEBUG_10 = IOMUX_PAD(0x0498, 0x0184, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__PL301_PER1_HADR_16 = IOMUX_PAD(0x0498, 0x0184, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x049C, 0x0188, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__SDMA_DBG_RTBUF_WRT = IOMUX_PAD(0x049C, 0x0188, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__MMDC_DEBUG_11 = IOMUX_PAD(0x049C, 0x0188, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__PL301_PER1_HADR_17 = IOMUX_PAD(0x049C, 0x0188, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x04A0, 0x018C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__USDHC1_USDHC_DBG_5 = IOMUX_PAD(0x04A0, 0x018C, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__SDMA_DBG_EVT_CHN_0 = IOMUX_PAD(0x04A0, 0x018C, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x04A0, 0x018C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__MMDC_DEBUG_12 = IOMUX_PAD(0x04A0, 0x018C, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__PL301_PER1_HADR_18 = IOMUX_PAD(0x04A0, 0x018C, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__SDMA_DBG_EVT_CHN_1 = IOMUX_PAD(0x04A4, 0x0190, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__MMDC_DEBUG_13 = IOMUX_PAD(0x04A4, 0x0190, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PL301_PER1_HADR_19 = IOMUX_PAD(0x04A4, 0x0190, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__SDMA_DBG_EVT_CHN_2 = IOMUX_PAD(0x04A8, 0x0194, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__MMDC_DEBUG_14 = IOMUX_PAD(0x04A8, 0x0194, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PL301_PER1_HADR_20 = IOMUX_PAD(0x04A8, 0x0194, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__USDHC1_DBG_6 = IOMUX_PAD(0x04AC, 0x0198, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__SDMA_DBG_EVT_CHN3 = IOMUX_PAD(0x04AC, 0x0198, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x04AC, 0x0198, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__MMDC_DEBUG_15 = IOMUX_PAD(0x04AC, 0x0198, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__PL301_PER1_HADR21 = IOMUX_PAD(0x04AC, 0x0198, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__USDHC1_USDHC_DBG7 = IOMUX_PAD(0x04B0, 0x019C, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__SDMA_DBG_EVT_CHN4 = IOMUX_PAD(0x04B0, 0x019C, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x04B0, 0x019C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__MMDC_DEBUG_16 = IOMUX_PAD(0x04B0, 0x019C, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__PL301_PER1_HADR22 = IOMUX_PAD(0x04B0, 0x019C, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__RESERVED_RESERVED = IOMUX_PAD(0x04B4, 0x01A0, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__SDMA_DBG_EVT_CHN5 = IOMUX_PAD(0x04B4, 0x01A0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__MMDC_DEBUG_17 = IOMUX_PAD(0x04B4, 0x01A0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__PL301_PER1_HADR23 = IOMUX_PAD(0x04B4, 0x01A0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), - MX6_PAD_DISP0_DAT13__SDMA_DBG_EVT_CHN0 = IOMUX_PAD(0x04B8, 0x01A4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__MMDC_DEBUG_18 = IOMUX_PAD(0x04B8, 0x01A4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__PL301_PER1_HADR24 = IOMUX_PAD(0x04B8, 0x01A4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), - MX6_PAD_DISP0_DAT14__SDMA_DBG_EVT_CHN1 = IOMUX_PAD(0x04BC, 0x01A8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__MMDC_DEBUG_19 = IOMUX_PAD(0x04BC, 0x01A8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), - MX6_PAD_DISP0_DAT15__SDMA_DBG_EVT_CHN2 = IOMUX_PAD(0x04C0, 0x01AC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__MMDC_DEBUG_20 = IOMUX_PAD(0x04C0, 0x01AC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__PL301_PER1_HADR25 = IOMUX_PAD(0x04C0, 0x01AC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x01B0, 2, 0x0818, 1, 0), MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x04C4, 0x01B0, 4, 0x090C, 0, 0), MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__MMDC_DEBUG_21 = IOMUX_PAD(0x04C4, 0x01B0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__PL301_PER1_HADR26 = IOMUX_PAD(0x04C4, 0x01B0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x04C8, 0x01B4, 2, 0x0814, 1, 0), MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x04C8, 0x01B4, 4, 0x0910, 0, 0), MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__MMDC_DEBUG_22 = IOMUX_PAD(0x04C8, 0x01B4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__PL301_PER1_HADR27 = IOMUX_PAD(0x04C8, 0x01B4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__MMDC_DEBUG_23 = IOMUX_PAD(0x04CC, 0x01B8, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), @@ -684,156 +500,71 @@ enum { MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__MMDC_DEBUG_24 = IOMUX_PAD(0x04D0, 0x01BC, 6, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x04D4, 0x01C0, 2, 0x07F4, 1, 0), MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), - MX6_PAD_DISP0_DAT20__SDMA_DBG_EVT_CHN7 = IOMUX_PAD(0x04D4, 0x01C0, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__MMDC_DEBUG_25 = IOMUX_PAD(0x04D4, 0x01C0, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__PL301_PER1_HADR28 = IOMUX_PAD(0x04D4, 0x01C0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x04D8, 0x01C4, 2, 0x07FC, 1, 0), MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), - MX6_PAD_DISP0_DAT21__SDMA_DBG_BUS_DEV0 = IOMUX_PAD(0x04D8, 0x01C4, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__MMDC_DEBUG_26 = IOMUX_PAD(0x04D8, 0x01C4, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__PL301_PER1_HADR29 = IOMUX_PAD(0x04D8, 0x01C4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x04DC, 0x01C8, 2, 0x07F8, 1, 0), MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), - MX6_PAD_DISP0_DAT22__SDMA_DBG_BUS_DEV1 = IOMUX_PAD(0x04DC, 0x01C8, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__MMDC_DEBUG_27 = IOMUX_PAD(0x04DC, 0x01C8, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__PL301_PER1_HADR30 = IOMUX_PAD(0x04DC, 0x01C8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), - MX6_PAD_DISP0_DAT23__SDMA_DBG_BUS_DEV2 = IOMUX_PAD(0x04E0, 0x01CC, 4, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x04E0, 0x01CC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__MMDC_DEBUG_28 = IOMUX_PAD(0x04E0, 0x01CC, 6, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__PL301_PER1_HADR31 = IOMUX_PAD(0x04E0, 0x01CC, 7, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__RESERVED_RESERVED = IOMUX_PAD(0x04E4, 0x01D0, 0, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x04E4, 0x01D0, 1, 0x0840, 0, 0), MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x04E4, 0x01D0, 2, 0x086C, 0, 0), - MX6_PAD_ENET_MDIO__SDMA_DEBUG_BUS_DEV3 = IOMUX_PAD(0x04E4, 0x01D0, 3, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x04E4, 0x01D0, 4, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x04E4, 0x01D0, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x04E4, 0x01D0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__RESERVED_RSRVED = IOMUX_PAD(0x04E8, 0x01D4, 0, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x04E8, 0x01D4, 1, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x04E8, 0x01D4, 2, 0x085C, 0, 0), - MX6_PAD_ENET_REF_CLK__SDMA_DBGBUS_DEV4 = IOMUX_PAD(0x04E8, 0x01D4, 3, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x04E8, 0x01D4, 5, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__USBPHY1_RX_SQH = IOMUX_PAD(0x04E8, 0x01D4, 7, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x04EC, 0x01D8, 0, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x04EC, 0x01D8, 1, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x04EC, 0x01D8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__PHY_TDI = IOMUX_PAD(0x04EC, 0x01D8, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__USBPHY1_RX_HS_RXD = IOMUX_PAD(0x04EC, 0x01D8, 7, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__RESERVED_RSRVED = IOMUX_PAD(0x04F0, 0x01DC, 0, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x04F0, 0x01DC, 1, 0x0858, 1, 0), MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x04F0, 0x01DC, 2, 0x0870, 0, 0), MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x04F0, 0x01DC, 3, 0x0918, 1, 0), MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x04F0, 0x01DC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__PHY_TDO = IOMUX_PAD(0x04F0, 0x01DC, 6, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__USBPHY1_RX_FS_RXD = IOMUX_PAD(0x04F0, 0x01DC, 7, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x04F4, 0x01E0, 0, 0x0908, 0, 0), MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x04F4, 0x01E0, 1, 0x084C, 1, 0), MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x04F4, 0x01E0, 2, 0x0860, 0, 0), MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x04F4, 0x01E0, 4, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x04F4, 0x01E0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__PHY_TCK = IOMUX_PAD(0x04F4, 0x01E0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__USBPHY1_RX_DISCON = IOMUX_PAD(0x04F4, 0x01E0, 7, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__OSC32K_32K_OUT = IOMUX_PAD(0x04F8, 0x01E4, 0, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x04F8, 0x01E4, 1, 0x0848, 1, 0), MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x04F8, 0x01E4, 3, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x04F8, 0x01E4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__PHY_TMS = IOMUX_PAD(0x04F8, 0x01E4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__USBPHY1_PLL_CK20DIV = IOMUX_PAD(0x04F8, 0x01E4, 7, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__RESERVED_RSRVED = IOMUX_PAD(0x04FC, 0x01E8, 0, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x04FC, 0x01E8, 1, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x04FC, 0x01E8, 2, 0x0880, 0, 0), MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x04FC, 0x01E8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__SATA_PHY_TDI = IOMUX_PAD(0x04FC, 0x01E8, 6, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__USBPHY2_RX_SQH = IOMUX_PAD(0x04FC, 0x01E8, 7, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x0500, 0x01EC, 0, 0x0900, 0, 0), MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x0500, 0x01EC, 1, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x0500, 0x01EC, 4, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x0500, 0x01EC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__SATA_PHY_TDO = IOMUX_PAD(0x0500, 0x01EC, 6, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__USBPHY2_RX_HS_RXD = IOMUX_PAD(0x0500, 0x01EC, 7, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__RESERVED_RSRVED = IOMUX_PAD(0x0504, 0x01F0, 0, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x0504, 0x01F0, 1, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x0504, 0x01F0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__SATA_PHY_TCK = IOMUX_PAD(0x0504, 0x01F0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__USBPHY2_RX_FS_RXD = IOMUX_PAD(0x0504, 0x01F0, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x0508, 0x01F4, 0, 0x0904, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x0508, 0x01F4, 1, 0x0000, 0, 0), MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x0508, 0x01F4, 4, 0x0000, 0, 0), MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__SATA_PHY_TMS = IOMUX_PAD(0x0508, 0x01F4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__USBPHY2_RX_DISCON = IOMUX_PAD(0x0508, 0x01F4, 7, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS5__MMDC_DRAM_SDQS_5 = IOMUX_PAD(0x050C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM5__MMDC_DRAM_DQM_5 = IOMUX_PAD(0x0510, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM4__MMDC_DRAM_DQM_4 = IOMUX_PAD(0x0514, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS4__MMDC_DRAM_SDQS_4 = IOMUX_PAD(0x0518, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS3__MMDC_DRAM_SDQS_3 = IOMUX_PAD(0x051C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM3__MMDC_DRAM_DQM_3 = IOMUX_PAD(0x0520, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS2__MMDC_DRAM_SDQS_2 = IOMUX_PAD(0x0524, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0528, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x052C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A1__MMDC_DRAM_A_1 = IOMUX_PAD(0x0530, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A2__MMDC_DRAM_A_2 = IOMUX_PAD(0x0534, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A3__MMDC_DRAM_A_3 = IOMUX_PAD(0x0538, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A4__MMDC_DRAM_A_4 = IOMUX_PAD(0x053C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A5__MMDC_DRAM_A_5 = IOMUX_PAD(0x0540, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A6__MMDC_DRAM_A_6 = IOMUX_PAD(0x0544, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A7__MMDC_DRAM_A_7 = IOMUX_PAD(0x0548, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A8__MMDC_DRAM_A_8 = IOMUX_PAD(0x054C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A9__MMDC_DRAM_A_9 = IOMUX_PAD(0x0550, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A10__MMDC_DRAM_A_10 = IOMUX_PAD(0x0554, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A11__MMDC_DRAM_A_11 = IOMUX_PAD(0x0558, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A12__MMDC_DRAM_A_12 = IOMUX_PAD(0x055C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A13__MMDC_DRAM_A_13 = IOMUX_PAD(0x0560, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A14__MMDC_DRAM_A_14 = IOMUX_PAD(0x0564, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_A15__MMDC_DRAM_A_15 = IOMUX_PAD(0x0568, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CAS__MMDC_DRAM_CAS = IOMUX_PAD(0x056C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CS0__MMDC_DRAM_CS_0 = IOMUX_PAD(0x0570, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_CS1__MMDC_DRAM_CS_1 = IOMUX_PAD(0x0574, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_RAS__MMDC_DRAM_RAS = IOMUX_PAD(0x0578, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_RESET__MMDC_DRAM_RESET = IOMUX_PAD(0x057C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA0__MMDC_DRAM_SDBA_0 = IOMUX_PAD(0x0580, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA1__MMDC_DRAM_SDBA_1 = IOMUX_PAD(0x0584, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCLK_0__MMDC_DRAM_SDCLK0 = IOMUX_PAD(0x0588, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDBA2__MMDC_DRAM_SDBA_2 = IOMUX_PAD(0x058C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCKE0__MMDC_DRAM_SDCKE_0 = IOMUX_PAD(0x0590, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCLK_1__MMDC_DRAM_SDCLK1 = IOMUX_PAD(0x0594, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDCKE1__MMDC_DRAM_SDCKE_1 = IOMUX_PAD(0x0598, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDODT0__MMDC_DRAM_ODT_0 = IOMUX_PAD(0x059C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDODT1__MMDC_DRAM_ODT_1 = IOMUX_PAD(0x05A0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x05A4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS0__MMDC_DRAM_SDQS_0 = IOMUX_PAD(0x05A8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x05AC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS1__MMDC_DRAM_SDQS_1 = IOMUX_PAD(0x05B0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x05B4, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS6__MMDC_DRAM_SDQS_6 = IOMUX_PAD(0x05B8, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM6__MMDC_DRAM_DQM_6 = IOMUX_PAD(0x05BC, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_SDQS7__MMDC_DRAM_SDQS_7 = IOMUX_PAD(0x05C0, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_DRAM_DQM7__MMDC_DRAM_DQM_7 = IOMUX_PAD(0x05C4, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x07F4, 2, 0), MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), @@ -842,7 +573,6 @@ enum { MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__SRC_ANY_PU_RST = IOMUX_PAD(0x05C8, 0x01F8, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x07FC, 2, 0), MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), @@ -851,7 +581,6 @@ enum { MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__PL301_PER1_HADR_0 = IOMUX_PAD(0x05CC, 0x01FC, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x05D0, 0x0200, 0, 0x07F8, 2, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0840, 1, 0), MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), @@ -860,7 +589,6 @@ enum { MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__PL301MX_PER1_HADR_1 = IOMUX_PAD(0x05D0, 0x0200, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x05D4, 0x0204, 0, 0x0800, 2, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), @@ -869,7 +597,6 @@ enum { MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__PL301_PER1_HADDR_2 = IOMUX_PAD(0x05D4, 0x0204, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x05D8, 0x0208, 0, 0x0804, 2, 0), MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0850, 1, 0), MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x05D8, 0x0208, 2, 0x0000, 0, 0), @@ -877,7 +604,6 @@ enum { MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__PL301_PER1_HADDR_3 = IOMUX_PAD(0x05D8, 0x0208, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0808, 1, 0), MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x05DC, 0x020C, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x05DC, 0x020C, 2, 0x07E4, 0, 0), @@ -885,7 +611,6 @@ enum { MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x05DC, 0x020C, 6, 0x088C, 1, 0), - MX6_PAD_KEY_ROW2__PL301_PER1_HADR_4 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x05E0, 0x0210, 0, 0x080C, 1, 0), MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x05E0, 0x0210, 2, 0x0890, 1, 0), @@ -893,15 +618,12 @@ enum { MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x05E0, 0x0210, 20, 0x08A0, 1, 0), MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0914, 2, 0), - MX6_PAD_KEY_COL3__PL301_PER1_HADR_5 = IOMUX_PAD(0x05E0, 0x0210, 7, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__OSC32K_32K_OUT = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x05E4, 0x0214, 2, 0x0894, 1, 0), MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x05E4, 0x0214, 20, 0x08A4, 1, 0), MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__PL301_PER1_HADR_6 = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), @@ -909,8 +631,6 @@ enum { MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x093C, 0, 0), MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__MMDC_DEBUG_49 = IOMUX_PAD(0x05E8, 0x0218, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__PL301_PER1_HADDR_7 = IOMUX_PAD(0x05E8, 0x0218, 7, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x05EC, 0x021C, 0, 0x07E8, 0, 0), MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), @@ -918,8 +638,6 @@ enum { MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__MMDC_DEBUG_50 = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__PL301_PER1_HADR_8 = IOMUX_PAD(0x05EC, 0x021C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x0000, 0, 0), MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x08E8, 0, 0), MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), @@ -934,7 +652,6 @@ enum { MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_1__SRC_TESTER_ACK = IOMUX_PAD(0x05F4, 0x0224, 7, 0x0000, 0, 0), MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x05F8, 0x0228, 0, 0x085C, 1, 0), MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x05F8, 0x0228, 2, 0x08EC, 0, 0), @@ -942,9 +659,7 @@ enum { MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), - MX6_PAD_GPIO_9__SRC_EARLY_RST = IOMUX_PAD(0x05F8, 0x0228, 7, 0x0000, 0, 0), MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0864, 1, 0), - MX6_PAD_GPIO_3__OBSERVE_MUX_INT_OUT0 = IOMUX_PAD(0x05FC, 0x022C, 1, 0x0000, 0, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05FC, 0x022C, 18, 0x08A8, 1, 0), MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), @@ -952,34 +667,22 @@ enum { MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0600, 0x0230, 0, 0x0870, 1, 0), - MX6_PAD_GPIO_6__OBSERVE_MUX_INT_OUT1 = IOMUX_PAD(0x0600, 0x0230, 1, 0x0000, 0, 0), MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0600, 0x0230, 18, 0x08AC, 1, 0), - MX6_PAD_GPIO_6__CCM_CCM_OUT_0 = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_6__CSU_CSU_INT_DEB = IOMUX_PAD(0x0600, 0x0230, 4, 0x0000, 0, 0), MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0600, 0x0230, 6, 0x0000, 0, 0), MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x0604, 0x0234, 0, 0x0860, 1, 0), - MX6_PAD_GPIO_2__OBSERVE_MUX_INT_OUT2 = IOMUX_PAD(0x0604, 0x0234, 1, 0x0000, 0, 0), MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x0604, 0x0234, 2, 0x08F8, 1, 0), - MX6_PAD_GPIO_2__CCM_CCM_OUT_1 = IOMUX_PAD(0x0604, 0x0234, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_2__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x0604, 0x0234, 4, 0x0000, 0, 0), MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x0604, 0x0234, 7, 0x0904, 1, 0), MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x0608, 0x0238, 0, 0x0868, 1, 0), - MX6_PAD_GPIO_4__OBSERVE_MUX_INT_OUT3 = IOMUX_PAD(0x0608, 0x0238, 1, 0x0000, 0, 0), MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x0608, 0x0238, 2, 0x08F0, 1, 0), - MX6_PAD_GPIO_4__CCM_CCM_OUT_2 = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_4__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_4__OCOTP_CRL_WRAR_FUSE_LA = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x060C, 0x023C, 0, 0x087C, 1, 0), - MX6_PAD_GPIO_5__OBSERVE_MUX_INT_OUT4 = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x060C, 0x023C, 2, 0x08FC, 1, 0), MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x060C, 0x023C, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_5__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x060C, 0x023C, 22, 0x08A8, 2, 0), MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), @@ -1015,7 +718,6 @@ enum { MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x061C, 0x024C, 3, 0x090C, 1, 0), MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x061C, 0x024C, 4, 0x0000, 0, 0), MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x061C, 0x024C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_17__SJC_JTAG_ACT = IOMUX_PAD(0x061C, 0x024C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x0620, 0x0250, 0, 0x0878, 0, 0), MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x0620, 0x0250, 1, 0x0844, 1, 0), MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), @@ -1023,7 +725,6 @@ enum { MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x0620, 0x0250, 5, 0x0000, 0, 0), MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SRC_SYSTEM_RST = IOMUX_PAD(0x0620, 0x0250, 7, 0x0000, 0, 0), MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0), MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0), @@ -1031,33 +732,20 @@ enum { MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0), MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0), MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SRC_INT_BOOT = IOMUX_PAD(0x0624, 0x0254, 7, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x0628, 0x0258, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__PCIE_CTRL_MUX_12 = IOMUX_PAD(0x0628, 0x0258, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x0628, 0x0258, 4, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x0628, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK___MMDC_DEBUG_29 = IOMUX_PAD(0x0628, 0x0258, 6, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x062C, 0x025C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__PCIE_CTRL_MUX_13 = IOMUX_PAD(0x062C, 0x025C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x062C, 0x025C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x062C, 0x025C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x062C, 0x025C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x062C, 0x025C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x062C, 0x025C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x0630, 0x0260, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x0630, 0x0260, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__PCIE_CTRL_MUX_14 = IOMUX_PAD(0x0630, 0x0260, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x0630, 0x0260, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x0630, 0x0260, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__MMDC_DEBUG_31 = IOMUX_PAD(0x0630, 0x0260, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x0630, 0x0260, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x0634, 0x0264, 0, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__PCIE_CTRL_MUX_15 = IOMUX_PAD(0x0634, 0x0264, 2, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x0634, 0x0264, 4, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x0634, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__MMDC_DEBUG_32 = IOMUX_PAD(0x0634, 0x0264, 6, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0638, 0x0268, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), @@ -1065,7 +753,6 @@ enum { MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0638, 0x0268, 3, 0x08E8, 2, 0), MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0638, 0x0268, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__MMDC_DEBUG_43 = IOMUX_PAD(0x0638, 0x0268, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x063C, 0x026C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), @@ -1073,7 +760,6 @@ enum { MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x063C, 0x026C, 3, 0x08F4, 1, 0), MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x063C, 0x026C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__MMDC_MMDC_DEBUG_44 = IOMUX_PAD(0x063C, 0x026C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0640, 0x0270, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), @@ -1081,7 +767,6 @@ enum { MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0640, 0x0270, 3, 0x08EC, 1, 0), MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0640, 0x0270, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__MMDC_MMDC_DEBUG_45 = IOMUX_PAD(0x0640, 0x0270, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0644, 0x0274, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), @@ -1089,7 +774,6 @@ enum { MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0644, 0x0274, 3, 0x08F8, 2, 0), MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0644, 0x0274, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__MMDC_MMDC_DEBUG_46 = IOMUX_PAD(0x0644, 0x0274, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0648, 0x0278, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), @@ -1097,7 +781,6 @@ enum { MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0648, 0x0278, 3, 0x08F0, 2, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0648, 0x0278, 20, 0x089C, 1, 0), MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0648, 0x0278, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__MMDC_MMDC_DEBUG_47 = IOMUX_PAD(0x0648, 0x0278, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x064C, 0x027C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), @@ -1105,244 +788,132 @@ enum { MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x064C, 0x027C, 3, 0x08FC, 2, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x064C, 0x027C, 20, 0x0898, 1, 0), MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x064C, 0x027C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__MMDC_MMDC_DEBUG_48 = IOMUX_PAD(0x064C, 0x027C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0650, 0x0280, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0650, 0x0280, 2, 0x0814, 2, 0), MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0920, 0, 0), - MX6_PAD_CSI0_DAT10__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x0650, 0x0280, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0650, 0x0280, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0650, 0x0280, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0654, 0x0284, 2, 0x081C, 2, 0), MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), - MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0654, 0x0284, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x0654, 0x0284, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0658, 0x0288, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__PCIE_CTRL_MUX_16 = IOMUX_PAD(0x0658, 0x0288, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0938, 2, 0), - MX6_PAD_CSI0_DAT12__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x0658, 0x0288, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0658, 0x0288, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0658, 0x0288, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__PCIE_CTRL_MUX_17 = IOMUX_PAD(0x065C, 0x028C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), - MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x065C, 0x028C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x065C, 0x028C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0660, 0x0290, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__PCIE_CTRL_MUX_18 = IOMUX_PAD(0x0660, 0x0290, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0940, 2, 0), - MX6_PAD_CSI0_DAT14__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0660, 0x0290, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0660, 0x0290, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0660, 0x0290, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__PCIE_CTRL_MUX_19 = IOMUX_PAD(0x0664, 0x0294, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), - MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0664, 0x0294, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x0664, 0x0294, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0668, 0x0298, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__PCIE_CTRL_MUX_20 = IOMUX_PAD(0x0668, 0x0298, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0934, 0, 0), - MX6_PAD_CSI0_DAT16__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x0668, 0x0298, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0668, 0x0298, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0668, 0x0298, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__PCIE_CTRL_MUX_21 = IOMUX_PAD(0x066C, 0x029C, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), - MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x066C, 0x029C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x066C, 0x029C, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0670, 0x02A0, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__PCIE_CTRL_MUX_22 = IOMUX_PAD(0x0670, 0x02A0, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x093C, 2, 0), - MX6_PAD_CSI0_DAT18__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0670, 0x02A0, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0670, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__MMDC_MMDC_DEBUG_41 = IOMUX_PAD(0x0670, 0x02A0, 6, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__PCIE_CTRL_MUX_23 = IOMUX_PAD(0x0674, 0x02A4, 2, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), - MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0674, 0x02A4, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__MMDC_MMDC_DEBUG_42 = IOMUX_PAD(0x0674, 0x02A4, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__ANATOP_TESTO_9 = IOMUX_PAD(0x0674, 0x02A4, 7, 0x0000, 0, 0), - MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x0678, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x067C, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TRSTB__SJC_TRSTB = IOMUX_PAD(0x0680, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x0684, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0688, NO_MUX_I, 0, 0x0000, 0, 0), - MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x068C, NO_MUX_I, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), - MX6_PAD_SD3_DAT7__PCIE_CTRL_MUX_24 = IOMUX_PAD(0x0690, 0x02A8, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USBOH3_UH3_DFD_OUT_0 = IOMUX_PAD(0x0690, 0x02A8, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USBOH3_UH2_DFD_OUT_0 = IOMUX_PAD(0x0690, 0x02A8, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_IN_12 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__USBPHY2_CLK20DIV = IOMUX_PAD(0x0690, 0x02A8, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0920, 3, 0), - MX6_PAD_SD3_DAT6__PCIE_CTRL_MUX_25 = IOMUX_PAD(0x0694, 0x02AC, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0694, 0x02AC, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__USBOH3_UH2_DFD_OUT_1 = IOMUX_PAD(0x0694, 0x02AC, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__MIPI_CORE_DPHY_IN_13 = IOMUX_PAD(0x0694, 0x02AC, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__ANATOP_TESTO_10 = IOMUX_PAD(0x0694, 0x02AC, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), - MX6_PAD_SD3_DAT5__PCIE_CTRL_MUX_26 = IOMUX_PAD(0x0698, 0x02B0, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USBOH3_UH3_DFD_OUT_2 = IOMUX_PAD(0x0698, 0x02B0, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__USBOH3_UH2_DFD_OUT_2 = IOMUX_PAD(0x0698, 0x02B0, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_IN_14 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__ANATOP_TESTO_11 = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0928, 5, 0), - MX6_PAD_SD3_DAT4__PCIE_CTRL_MUX_27 = IOMUX_PAD(0x069C, 0x02B4, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x069C, 0x02B4, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__USBOH3_UH2_DFD_OUT_3 = IOMUX_PAD(0x069C, 0x02B4, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_IN_15 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__ANATOP_TESTO_12 = IOMUX_PAD(0x069C, 0x02B4, 7, 0x0000, 0, 0), MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06A0, 0x02B8, 16, 0x0000, 0, 0), MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0000, 0, 0), MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0924, 2, 0), MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06A0, 0x02B8, 2, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06A0, 0x02B8, 3, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__USBOH3_UH2_DFD_OUT_4 = IOMUX_PAD(0x06A0, 0x02B8, 4, 0x0000, 0, 0), MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__MIPI_CORE_DPHY_IN_16 = IOMUX_PAD(0x06A0, 0x02B8, 6, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__ANATOP_TESTO_13 = IOMUX_PAD(0x06A0, 0x02B8, 7, 0x0000, 0, 0), MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06A4, 0x02BC, 0, 0x0000, 0, 0), MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0000, 0, 0), MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0924, 3, 0), MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06A4, 0x02BC, 2, 0x07E4, 2, 0), - MX6_PAD_SD3_CLK__USBOH3_UH3_DFD_OUT_5 = IOMUX_PAD(0x06A4, 0x02BC, 3, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__USBOH3_UH2_DFD_OUT_5 = IOMUX_PAD(0x06A4, 0x02BC, 4, 0x0000, 0, 0), MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_IN_17 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__ANATOP_TESTO_14 = IOMUX_PAD(0x06A4, 0x02BC, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06A8, 0x02C0, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x091C, 2, 0), MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06A8, 0x02C0, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06A8, 0x02C0, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__USBOH3_UH2_DFD_OUT_6 = IOMUX_PAD(0x06A8, 0x02C0, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__MIPI_CORE_DPHY_IN_18 = IOMUX_PAD(0x06A8, 0x02C0, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__ANATOP_TESTO_15 = IOMUX_PAD(0x06A8, 0x02C0, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x091C, 3, 0), MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x06AC, 0x02C4, 2, 0x07E8, 1, 0), - MX6_PAD_SD3_DAT1__USBOH3_UH3_DFD_OUT_7 = IOMUX_PAD(0x06AC, 0x02C4, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__USBOH3_UH2_DFD_OUT_7 = IOMUX_PAD(0x06AC, 0x02C4, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__MIPI_CORE_DPHY_IN_19 = IOMUX_PAD(0x06AC, 0x02C4, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__ANATOP_TESTI_0 = IOMUX_PAD(0x06AC, 0x02C4, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__PCIE_CTRL_MUX_28 = IOMUX_PAD(0x06B0, 0x02C8, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USBOH3_UH3_DFD_OUT_8 = IOMUX_PAD(0x06B0, 0x02C8, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__USBOH3_UH2_DFD_OUT_8 = IOMUX_PAD(0x06B0, 0x02C8, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_IN_20 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__ANATOP_TESTI_1 = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x092C, 4, 0), - MX6_PAD_SD3_DAT3__PCIE_CTRL_MUX_29 = IOMUX_PAD(0x06B4, 0x02CC, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x06B4, 0x02CC, 3, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__USBOH3_UH2_DFD_OUT_9 = IOMUX_PAD(0x06B4, 0x02CC, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__MIPI_CORE_DPHY_IN_21 = IOMUX_PAD(0x06B4, 0x02CC, 6, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__ANATOP_TESTI_2 = IOMUX_PAD(0x06B4, 0x02CC, 7, 0x0000, 0, 0), MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x092C, 5, 0), - MX6_PAD_SD3_RST__PCIE_CTRL_MUX_30 = IOMUX_PAD(0x06B8, 0x02D0, 2, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USBOH3_UH3_DFD_OUT_10 = IOMUX_PAD(0x06B8, 0x02D0, 3, 0x0000, 0, 0), - MX6_PAD_SD3_RST__USBOH3_UH2_DFD_OUT_10 = IOMUX_PAD(0x06B8, 0x02D0, 4, 0x0000, 0, 0), MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), - MX6_PAD_SD3_RST__MIPI_CORE_DPHY_IN_22 = IOMUX_PAD(0x06B8, 0x02D0, 6, 0x0000, 0, 0), - MX6_PAD_SD3_RST__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x06B8, 0x02D0, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x06BC, 0x02D4, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__IPU2_SISG4 = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__PCIE_CTRL_MUX_31 = IOMUX_PAD(0x06BC, 0x02D4, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__USBOH3_UH3_DFD_OT11 = IOMUX_PAD(0x06BC, 0x02D4, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__USBOH3_UH2_DFD_OT11 = IOMUX_PAD(0x06BC, 0x02D4, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__MIPI_CORE_DPHY_IN23 = IOMUX_PAD(0x06BC, 0x02D4, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__TPSMP_HTRANS_0 = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x06C0, 0x02D8, 0, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__PCIE_CTRL_MUX_0 = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USBOH3_UH3_DFD_OT12 = IOMUX_PAD(0x06C0, 0x02D8, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__USBOH3_UH2_DFD_OT12 = IOMUX_PAD(0x06C0, 0x02D8, 4, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__MIPI_CR_DPHY_IN_24 = IOMUX_PAD(0x06C0, 0x02D8, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__TPSMP_HTRANS_1 = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__IPU2_SISG5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__PCIE_CTRL__MUX_1 = IOMUX_PAD(0x06C4, 0x02DC, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__USBOH3_UH3_DFDOT13 = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__USBOH3_UH2_DFDOT13 = IOMUX_PAD(0x06C4, 0x02DC, 4, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__MIPI_CR_DPHY_OUT32 = IOMUX_PAD(0x06C4, 0x02DC, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__PL301_PER1_HSIZE_0 = IOMUX_PAD(0x06C4, 0x02DC, 7, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__IPU2_DI0_PIN01 = IOMUX_PAD(0x06C8, 0x02E0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__PCIE_CTRL_MUX_2 = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__USBOH3_UH3_DFD_OT14 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__USBOH3_UH2_DFD_OT14 = IOMUX_PAD(0x06C8, 0x02E0, 4, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__MIPI_CR_DPHY_OUT_33 = IOMUX_PAD(0x06C8, 0x02E0, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__PL301_PER1_HSIZE_1 = IOMUX_PAD(0x06C8, 0x02E0, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__USBOH3_UH3_DFD_OT15 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__USBOH3_UH2_DFD_OT15 = IOMUX_PAD(0x06CC, 0x02E4, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__PL301_PER1_HSIZE_2 = IOMUX_PAD(0x06CC, 0x02E4, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__PCIE_CTRL_MUX_3 = IOMUX_PAD(0x06D0, 0x02E8, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__PL301_PER1_HRDYOUT = IOMUX_PAD(0x06D0, 0x02E8, 7, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0874, 1, 0), @@ -1354,170 +925,78 @@ enum { MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0878, 1, 0), MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__PCIE_CTRL_MUX_4 = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__IPU2_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__TPSMP_CLK = IOMUX_PAD(0x06D8, 0x02F0, 7, 0x0000, 0, 0), MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x06DC, 0x02F4, 16, 0x0000, 0, 0), MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x06DC, 0x02F4, 1, 0x0000, 0, 0), MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0000, 0, 0), MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0930, 2, 0), - MX6_PAD_SD4_CMD__PCIE_CTRL_MUX_5 = IOMUX_PAD(0x06DC, 0x02F4, 4, 0x0000, 0, 0), MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__TPSMP_HDATA_DIR = IOMUX_PAD(0x06DC, 0x02F4, 7, 0x0000, 0, 0), MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x06E0, 0x02F8, 0, 0x0000, 0, 0), MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x06E0, 0x02F8, 1, 0x0000, 0, 0), MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0000, 0, 0), MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0930, 3, 0), - MX6_PAD_SD4_CLK__PCIE_CTRL_MUX_6 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x06E4, 0x02FC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPU3D_GPU_DBG_OUT_0 = IOMUX_PAD(0x06E4, 0x02FC, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USBOH3_UH2_DFD_OUT16 = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__USBOH3_UH3_DFD_OUT16 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__IPU1_IPU_DIAG_BUS_0 = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__IPU2_IPU_DIAG_BUS_0 = IOMUX_PAD(0x06E4, 0x02FC, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x06E8, 0x0300, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPU3D_GPU_DEBUG_OUT1 = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USBOH3_UH2_DFD_OUT17 = IOMUX_PAD(0x06E8, 0x0300, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__USBOH3_UH3_DFD_OUT17 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__IPU1_IPU_DIAG_BUS_1 = IOMUX_PAD(0x06E8, 0x0300, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__IPU2_IPU_DIAG_BUS_1 = IOMUX_PAD(0x06E8, 0x0300, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x06EC, 0x0304, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPU3D_GPU_DBG_OUT_2 = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USBOH3_UH2_DFD_OUT18 = IOMUX_PAD(0x06EC, 0x0304, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__USBOH3_UH3_DFD_OUT18 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__IPU1_IPU_DIAG_BUS_2 = IOMUX_PAD(0x06EC, 0x0304, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__IPU2_IPU_DIAG_BUS_2 = IOMUX_PAD(0x06EC, 0x0304, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x06F0, 0x0308, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPU3D_GPU_DBG_OUT_3 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USBOH3_UH2_DFD_OUT19 = IOMUX_PAD(0x06F0, 0x0308, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__USBOH3_UH3_DFD_OUT19 = IOMUX_PAD(0x06F0, 0x0308, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__IPU1_IPU_DIAG_BUS_3 = IOMUX_PAD(0x06F0, 0x0308, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__IPU2_IPU_DIAG_BUS_3 = IOMUX_PAD(0x06F0, 0x0308, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPU3D_GPU_DBG_OUT_4 = IOMUX_PAD(0x06F4, 0x030C, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USBOH3_UH2_DFD_OUT20 = IOMUX_PAD(0x06F4, 0x030C, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__USBOH3_UH3_DFD_OUT20 = IOMUX_PAD(0x06F4, 0x030C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__IPU1_IPU_DIAG_BUS_4 = IOMUX_PAD(0x06F4, 0x030C, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__IPU2_IPU_DIAG_BUS_4 = IOMUX_PAD(0x06F4, 0x030C, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x06F8, 0x0310, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPU3D_GPU_DBG_OUT_5 = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USBOH3_UH2_DFD_OUT21 = IOMUX_PAD(0x06F8, 0x0310, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__USBOH3_UH3_DFD_OUT21 = IOMUX_PAD(0x06F8, 0x0310, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__IPU1_IPU_DIAG_BUS_5 = IOMUX_PAD(0x06F8, 0x0310, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__IPU2_IPU_DIAG_BUS_5 = IOMUX_PAD(0x06F8, 0x0310, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPU3D_GPU_DBG_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USBOH3_UH2_DFD_OUT22 = IOMUX_PAD(0x06FC, 0x0314, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__USBOH3_UH3_DFD_OUT22 = IOMUX_PAD(0x06FC, 0x0314, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__IPU1_IPU_DIAG_BUS_6 = IOMUX_PAD(0x06FC, 0x0314, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__IPU2_IPU_DIAG_BUS_6 = IOMUX_PAD(0x06FC, 0x0314, 7, 0x0000, 0, 0), MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPU3D_GPU_DBG_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USBOH3_UH2_DFD_OUT23 = IOMUX_PAD(0x0700, 0x0318, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__USBOH3_UH3_DFD_OUT23 = IOMUX_PAD(0x0700, 0x0318, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__IPU1_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0700, 0x0318, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__IPU2_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0700, 0x0318, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__RAWNAND_D8 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0704, 0x031C, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USBOH3_UH2_DFD_OUT24 = IOMUX_PAD(0x0704, 0x031C, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__USBOH3_UH3_DFD_OUT24 = IOMUX_PAD(0x0704, 0x031C, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__IPU1_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0704, 0x031C, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__IPU2_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0704, 0x031C, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__RAWNAND_D9 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USBOH3_UH2_DFD_OUT25 = IOMUX_PAD(0x0708, 0x0320, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__USBOH3_UH3_DFD_OUT25 = IOMUX_PAD(0x0708, 0x0320, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__IPU1_IPU_DIAG_BUS_9 = IOMUX_PAD(0x0708, 0x0320, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__IPU2_IPU_DIAG_BUS_9 = IOMUX_PAD(0x0708, 0x0320, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__RAWNAND_D10 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USBOH3_UH2_DFD_OUT26 = IOMUX_PAD(0x070C, 0x0324, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__USBOH3_UH3_DFD_OUT26 = IOMUX_PAD(0x070C, 0x0324, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__IPU1_IPU_DIAG_BUS_10 = IOMUX_PAD(0x070C, 0x0324, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__IPU2_IPU_DIAG_BUS_10 = IOMUX_PAD(0x070C, 0x0324, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__RAWNAND_D11 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USBOH3_UH2_DFD_OUT27 = IOMUX_PAD(0x0710, 0x0328, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__USBOH3_UH3_DFD_OUT27 = IOMUX_PAD(0x0710, 0x0328, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__IPU1_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0710, 0x0328, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__IPU2_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0928, 6, 0), - MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT28 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__IPU1_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0714, 0x032C, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__IPU2_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0714, 0x032C, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__RAWNAND_D13 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0924, 4, 0), - MX6_PAD_SD4_DAT5__USBOH3_UH2_DFD_OUT29 = IOMUX_PAD(0x0718, 0x0330, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__USBOH3_UH3_DFD_OUT29 = IOMUX_PAD(0x0718, 0x0330, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__IPU1_IPU_DIAG_BUS_13 = IOMUX_PAD(0x0718, 0x0330, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__IPU2_IPU_DIAG_BUS_13 = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0924, 5, 0), - MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT30 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__IPU1_IPU_DIAG_BUS_14 = IOMUX_PAD(0x071C, 0x0334, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__IPU2_IPU_DIAG_BUS_14 = IOMUX_PAD(0x071C, 0x0334, 7, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__RAWNAND_D15 = IOMUX_PAD(0x0720, 0x0338, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), - MX6_PAD_SD4_DAT7__USBOH3_UH2_DFD_OUT31 = IOMUX_PAD(0x0720, 0x0338, 3, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__USBOH3_UH3_DFD_OUT31 = IOMUX_PAD(0x0720, 0x0338, 4, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__IPU1_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0720, 0x0338, 6, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__IPU2_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0720, 0x0338, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x0724, 0x033C, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0724, 0x033C, 1, 0x0834, 1, 0), MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x0724, 0x033C, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__PCIE_CTRL_MUX_7 = IOMUX_PAD(0x0724, 0x033C, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__HDMI_TX_OPHYDTB_0 = IOMUX_PAD(0x0724, 0x033C, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__ANATOP_TESTO_8 = IOMUX_PAD(0x0724, 0x033C, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0728, 0x0340, 1, 0x082C, 1, 0), - MX6_PAD_SD1_DAT0__CAAM_WRAP_RNG_OSCOBS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__PCIE_CTRL_MUX_8 = IOMUX_PAD(0x0728, 0x0340, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__HDMI_TX_OPHYDTB_1 = IOMUX_PAD(0x0728, 0x0340, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__ANATOP_TESTO_7 = IOMUX_PAD(0x0728, 0x0340, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__ECSPI5_SS2 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), @@ -1525,13 +1004,11 @@ enum { MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__ANATOP_TESTO_6 = IOMUX_PAD(0x072C, 0x0344, 7, 0x0000, 0, 0), MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x0730, 0x0348, 16, 0x0000, 0, 0), MX6_PAD_SD1_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0730, 0x0348, 1, 0x0830, 0, 0), MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__ANATOP_TESTO_5 = IOMUX_PAD(0x0730, 0x0348, 7, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0838, 1, 0), MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x0734, 0x034C, 2, 0x0000, 0, 0), @@ -1539,36 +1016,25 @@ enum { MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__ANATOP_TESTO_4 = IOMUX_PAD(0x0734, 0x034C, 7, 0x0000, 0, 0), MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), MX6_PAD_SD1_CLK__ECSPI5_SCLK = IOMUX_PAD(0x0738, 0x0350, 1, 0x0828, 0, 0), - MX6_PAD_SD1_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__PHY_DTB_0 = IOMUX_PAD(0x0738, 0x0350, 6, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__SATA_PHY_DTB_0 = IOMUX_PAD(0x0738, 0x0350, 7, 0x0000, 0, 0), MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), MX6_PAD_SD2_CLK__ECSPI5_SCLK = IOMUX_PAD(0x073C, 0x0354, 1, 0x0828, 1, 0), MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x073C, 0x0354, 2, 0x08E8, 3, 0), MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), - MX6_PAD_SD2_CLK__PCIE_CTRL_MUX_9 = IOMUX_PAD(0x073C, 0x0354, 4, 0x0000, 0, 0), MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__PHY_DTB_1 = IOMUX_PAD(0x073C, 0x0354, 6, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__SATA_PHY_DTB_1 = IOMUX_PAD(0x073C, 0x0354, 7, 0x0000, 0, 0), MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x0740, 0x0358, 16, 0x0000, 0, 0), MX6_PAD_SD2_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0740, 0x0358, 1, 0x0830, 1, 0), MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x0740, 0x0358, 2, 0x08F4, 2, 0), MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), - MX6_PAD_SD2_CMD__PCIE_CTRL_MUX_10 = IOMUX_PAD(0x0740, 0x0358, 4, 0x0000, 0, 0), MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__ECSPI5_SS3 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x0744, 0x035C, 2, 0x08EC, 2, 0), MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), - MX6_PAD_SD2_DAT3__PCIE_CTRL_MUX_11 = IOMUX_PAD(0x0744, 0x035C, 4, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__SJC_DONE = IOMUX_PAD(0x0744, 0x035C, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__ANATOP_TESTO_3 = IOMUX_PAD(0x0744, 0x035C, 7, 0x0000, 0, 0), };
#endif /* __ASM_ARCH_MX6_MX6Q_PINS_H__ */
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- No change in V2 arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 478 +++++++++++++-------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 502 ++++++++++++++--------------- 2 files changed, 490 insertions(+), 490 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 47d704b..d194eb0 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -11,145 +11,145 @@
enum { MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0360, 0x004C, 2, 0x07F8, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0800, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), + MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), + MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), + MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), + MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), + MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0388, 0x0074, 2, 0x07D8, 0, 0), MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), - MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x038C, 0x0078, 2, 0x07E0, 0, 0), MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), - MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0390, 0x007C, 2, 0x07DC, 0, 0), MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), - MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0394, 0x0080, 2, 0x07E4, 0, 0), MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), - MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0398, 0x0084, 2, 0x07F4, 0, 0), MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0), MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x039C, 0x0088, 2, 0x07FC, 0, 0), MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0), MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_DISP_CLK__LCD_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__LCD_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__LCD_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__LCD_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN2__LCD_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), - MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__LCD_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN3__LCD_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__LCD_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN4__LCD_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), - MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__LCD_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), @@ -162,76 +162,76 @@ enum { MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__LCD_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT10__LCD_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__LCD_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__LCD_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__LCD_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__LCD_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__LCD_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), + MX6_PAD_DISP0_DAT13__LCD_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__LCD_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), + MX6_PAD_DISP0_DAT14__LCD_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__LCD_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__LCD_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x07E8, 0, 0), MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0804, 0, 0), MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__LCD_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__LCD_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), + MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__LCD_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__LCD_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), + MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__LCD_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__LCD_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), - MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), + MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), + MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__LCD_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__LCD_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), - MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), + MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), + MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__LCD_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__LCD_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__LCD_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x07D8, 1, 0), - MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), + MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__LCD_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__LCD_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x07E0, 1, 0), - MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), + MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__LCD_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__LCD_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x00EC, 2, 0x07DC, 1, 0), - MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), + MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__LCD_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__LCD_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x07E4, 1, 0), - MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), + MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT3__LCD_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), @@ -244,12 +244,12 @@ enum { MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT5__LCD_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT6__LCD_DATA06 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x0414, 0x0100, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT7__LCD_DATA07 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), @@ -258,12 +258,12 @@ enum { MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT8__LCD_DATA08 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT9__LCD_DATA09 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x04E0, 0x0110, 1, 0x0000, 0, 0), @@ -273,50 +273,50 @@ enum { MX6_PAD_EIM_A16__EPDC_DATA00 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_CSI1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), + MX6_PAD_EIM_A17__IPU1_CSI1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), MX6_PAD_EIM_A17__EPDC_PWR_STAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_CSI1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), + MX6_PAD_EIM_A18__IPU1_CSI1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), MX6_PAD_EIM_A18__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_CSI1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), + MX6_PAD_EIM_A19__IPU1_CSI1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), MX6_PAD_EIM_A19__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), + MX6_PAD_EIM_A20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), MX6_PAD_EIM_A20__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_CSI1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), + MX6_PAD_EIM_A21__IPU1_CSI1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), MX6_PAD_EIM_A21__EPDC_GDCLK = IOMUX_PAD(0x04F4, 0x0124, 8, 0x0000, 0, 0), MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_CSI1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), + MX6_PAD_EIM_A22__IPU1_CSI1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), MX6_PAD_EIM_A22__EPDC_GDSP = IOMUX_PAD(0x04F8, 0x0128, 8, 0x0000, 0, 0), MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_CSI1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), + MX6_PAD_EIM_A23__IPU1_CSI1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), MX6_PAD_EIM_A23__EPDC_GDOE = IOMUX_PAD(0x04FC, 0x012C, 8, 0x0000, 0, 0), MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_CSI1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), + MX6_PAD_EIM_A24__IPU1_CSI1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), @@ -330,7 +330,7 @@ enum { MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0504, 0x0134, 6, 0x085C, 0, 0), MX6_PAD_EIM_A25__EPDC_DATA15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), MX6_PAD_EIM_A25__EIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x0508, 0x0138, 1, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__EPDC_SDCE9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), @@ -347,7 +347,7 @@ enum { MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x0514, 0x0144, 1, 0x07D8, 2, 0), MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x0514, 0x0144, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D16__IPU1_CSI1_DATA18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), + MX6_PAD_EIM_D16__IPU1_CSI1_DATA18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x0514, 0x0144, 4, 0x0864, 0, 0), MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0), @@ -363,7 +363,7 @@ enum { MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x051C, 0x014C, 1, 0x07E0, 2, 0), MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x051C, 0x014C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D18__IPU1_CSI1_DATA17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), + MX6_PAD_EIM_D18__IPU1_CSI1_DATA17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x051C, 0x014C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0), @@ -371,7 +371,7 @@ enum { MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x0520, 0x0150, 1, 0x07E8, 1, 0), MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x0520, 0x0150, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D19__IPU1_CSI1_DATA16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), + MX6_PAD_EIM_D19__IPU1_CSI1_DATA16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), MX6_PAD_EIM_D19__UART1_CTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x0000, 0, 0), MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), @@ -380,7 +380,7 @@ enum { MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x0524, 0x0154, 1, 0x0808, 0, 0), MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x0524, 0x0154, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), + MX6_PAD_EIM_D20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x0000, 0, 0), MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), @@ -388,16 +388,16 @@ enum { MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x0528, 0x0158, 1, 0x0000, 0, 0), MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x0528, 0x0158, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), - MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), + MX6_PAD_EIM_D21__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), + MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x0528, 0x0158, 5, 0x0000, 0, 0), MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0), MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x0528, 0x0158, 7, 0x08F0, 0, 0), MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x052C, 0x015C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x052C, 0x015C, 1, 0x0000, 0, 0), MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x052C, 0x015C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_CSI1_DATA10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), - MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_CSI1_DATA10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), + MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), MX6_PAD_EIM_D22__EPDC_SDCE6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), @@ -418,7 +418,7 @@ enum { MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x0534, 0x0164, 3, 0x07EC, 0, 0), MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x0534, 0x0164, 4, 0x0000, 0, 0), MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x0534, 0x0164, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), + MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x0534, 0x0164, 7, 0x0000, 0, 0), MX6_PAD_EIM_D24__EPDC_SDCE7 = IOMUX_PAD(0x0534, 0x0164, 8, 0x0000, 0, 0), MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x0538, 0x0168, 0, 0x0000, 0, 0), @@ -428,13 +428,13 @@ enum { MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x0538, 0x0168, 3, 0x07F0, 0, 0), MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x0538, 0x0168, 4, 0x0000, 0, 0), MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x0538, 0x0168, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), + MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x0538, 0x0168, 7, 0x0000, 0, 0), MX6_PAD_EIM_D25__EPDC_SDCE8 = IOMUX_PAD(0x0538, 0x0168, 8, 0x0000, 0, 0), MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x053C, 0x016C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x053C, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI1_DATA14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), + MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI1_DATA14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0904, 0, 0), MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x053C, 0x016C, 5, 0x0000, 0, 0), @@ -443,8 +443,8 @@ enum { MX6_PAD_EIM_D26__EPDC_SDOED = IOMUX_PAD(0x053C, 0x016C, 8, 0x0000, 0, 0), MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x0540, 0x0170, 0, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x0540, 0x0170, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI1_DATA13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), + MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI1_DATA13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0000, 0, 0), MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x0540, 0x0170, 5, 0x0000, 0, 0), @@ -454,9 +454,9 @@ enum { MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x0544, 0x0174, 0, 0x0000, 0, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x0544, 0x0174, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_CSI1_DATA12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), - MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), + MX6_PAD_EIM_D28__IPU1_CSI1_DATA12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), + MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x0544, 0x0174, 6, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x0544, 0x0174, 7, 0x0000, 0, 0), @@ -473,132 +473,132 @@ enum { MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x054C, 0x017C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x054C, 0x017C, 1, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x054C, 0x017C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0000, 0, 0), MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), + MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), MX6_PAD_EIM_D30__EPDC_SDOEZ = IOMUX_PAD(0x054C, 0x017C, 8, 0x0000, 0, 0), MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x0550, 0x0180, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0000, 0, 0), MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), MX6_PAD_EIM_D31__EPDC_SDCLK_P = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), MX6_PAD_EIM_D31__EIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_CSI1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_CSI1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA0__EPDC_SDCLK_N = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_CSI1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_CSI1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA1__EPDC_SDLE = IOMUX_PAD(0x0558, 0x0188, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x055C, 0x018C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x055C, 0x018C, 2, 0x08B0, 1, 0), MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA10__EPDC_DATA01 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_CSI1_HSYNC = IOMUX_PAD(0x0560, 0x0190, 2, 0x08B4, 0, 0), MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA11__EPDC_DATA03 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0564, 0x0194, 2, 0x08BC, 1, 0), MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA12__EPDC_DATA02 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x0568, 0x0198, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA13__EPDC_DATA13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x056C, 0x019C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA14__EPDC_DATA14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA15__EPDC_DATA09 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_CSI1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_CSI1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA2__EPDC_BDR0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_CSI1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_CSI1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA3__EPDC_BDR1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_CSI1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_CSI1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA4__EPDC_SDCE0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_CSI1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_CSI1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA5__EPDC_SDCE1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_CSI1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_CSI1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA6__EPDC_SDCE2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_CSI1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_CSI1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA7__EPDC_SDCE3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_CSI1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_CSI1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA8__EPDC_SDCE4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_CSI1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_CSI1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), MX6_PAD_EIM_DA9__EPDC_SDCE5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), + MX6_PAD_EIM_EB0__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB0__EPDC_PWR_COM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_CSI1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), + MX6_PAD_EIM_EB1__IPU1_CSI1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), MX6_PAD_EIM_EB1__EPDC_SDSHR = IOMUX_PAD(0x0598, 0x01C8, 8, 0x0000, 0, 0), MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x059C, 0x01CC, 1, 0x07E4, 2, 0), - MX6_PAD_EIM_EB2__IPU1_CSI1_DATA19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), + MX6_PAD_EIM_EB2__IPU1_CSI1_DATA19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x059C, 0x01CC, 4, 0x0860, 0, 0), MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0), @@ -626,18 +626,18 @@ enum { MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x05A8, 0x01D8, 2, 0x07F8, 2, 0), MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), MX6_PAD_EIM_OE__EPDC_PWR_IRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x05AC, 0x01DC, 2, 0x0800, 2, 0), MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), MX6_PAD_EIM_RW__EPDC_DATA07 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x05B4, 0x01E4, 1, 0x0828, 0, 0), - MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), + MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), @@ -651,21 +651,21 @@ enum { MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), - MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), + MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), + MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x05C4, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), + MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), - MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT= IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), - MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), + MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), - MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), @@ -673,24 +673,24 @@ enum { MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__I2C4_SCL = IOMUX_PAD(0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0), - MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), - MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__I2C4_SDA = IOMUX_PAD(0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0), MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), - MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), + MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05E0, 0x0210, 0, 0x083C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05E0, 0x0210, 2, 0x08CC, 1, 0), MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0790, 1, 0), MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), @@ -698,7 +698,7 @@ enum { MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x05E4, 0x0214, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), + MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x05E4, 0x0214, 4, 0x08F0, 2, 0), MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), @@ -714,9 +714,9 @@ enum { MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0814, 0, 0), MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x08EC, 1, 0), - MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), + MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x05F0, 0x0220, 1, 0x0000, 0, 0), MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), @@ -727,7 +727,7 @@ enum { MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0), @@ -735,7 +735,7 @@ enum { MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), - MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), + MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), @@ -750,7 +750,7 @@ enum { MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0), MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), + MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), MX6_PAD_GPIO_7__ESAI_TX4_RX1 = IOMUX_PAD(0x0608, 0x0238, 0, 0x0854, 1, 0), MX6_PAD_GPIO_7__EPIT1_OUT = IOMUX_PAD(0x0608, 0x0238, 2, 0x0000, 0, 0), MX6_PAD_GPIO_7__FLEXCAN1_TX = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), @@ -771,28 +771,28 @@ enum { MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), MX6_PAD_GPIO_8__I2C4_SDA = IOMUX_PAD(0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0), MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x0610, 0x0240, 0, 0x082C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x0610, 0x0240, 2, 0x08C4, 1, 0), MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), + MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x062C, 0x0244, 0, 0x07D8, 3, 0), MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), - MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), + MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x062C, 0x0244, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x0630, 0x0248, 0, 0x07DC, 3, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x0630, 0x0248, 1, 0x0810, 1, 0), - MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), + MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x0630, 0x0248, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x0634, 0x024C, 0, 0x07E8, 2, 0), MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), @@ -809,43 +809,43 @@ enum { MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), + MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x063C, 0x0254, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0640, 0x0258, 0, 0x07E0, 3, 0), MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), + MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x0640, 0x0258, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x025C, 0, 0x07E4, 3, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x0644, 0x025C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), + MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x0644, 0x025C, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x0648, 0x0260, 0, 0x07EC, 1, 0), MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x0648, 0x0260, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0648, 0x0260, 6, 0x085C, 1, 0), - MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), + MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x064C, 0x0264, 2, 0x0864, 1, 0), MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x0650, 0x0268, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), @@ -858,19 +858,19 @@ enum { MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), - MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x0664, 0x027C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), - MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__I2C4_SDA = IOMUX_PAD(0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0), MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), @@ -897,49 +897,49 @@ enum { MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), - MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), + MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), + MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), + MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), + MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0828, 1, 0), - MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), - MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), + MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), - MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), @@ -971,30 +971,30 @@ enum { MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), - MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), + MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), - MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), + MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), + MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), + MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), + MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), - MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), + MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index 5e38556..f01f2e0 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -14,97 +14,97 @@ enum { MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0360, 0x004C, 1, 0x0834, 0, 0), - MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x0360, 0x004C, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), + MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x0360, 0x004C, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x0360, 0x004C, 4, 0x08F0, 0, 0), MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0364, 0x0050, 1, 0x0838, 0, 0), - MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), + MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x0364, 0x0050, 4, 0x08F8, 0, 0), MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0368, 0x0054, 1, 0x082C, 0, 0), - MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), + MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x0368, 0x0054, 4, 0x08FC, 0, 0), MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x036C, 0x0058, 2, 0x0918, 0, 0), MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x0380, 0x006C, 1, 0x0858, 0, 0), MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), + MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x0388, 0x0074, 7, 0x083C, 0, 0), - MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), + MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), + MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), + MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), + MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x039C, 0x0088, 2, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x039C, 0x0088, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x039C, 0x0088, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x039C, 0x0088, 3, 0x0000, 0, 0), + MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x039C, 0x0088, 4, 0x0000, 0, 0), MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x039C, 0x0088, 6, 0x088C, 0, 0), - MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0800, 0, 0), MX6_PAD_EIM_EB2__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03A0, 0x008C, 3, 0x08D4, 0, 0), MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0890, 0, 0), MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x03A0, 0x008C, 22, 0x08A0, 0, 0), MX6_PAD_EIM_EB2__SRC_BOOT_CFG30 = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x03A4, 0x0090, 1, 0x07F4, 0, 0), MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), MX6_PAD_EIM_D16__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x08D0, 0, 0), MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0894, 0, 0), MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0090, 22, 0x08A4, 0, 0), - MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x03A8, 0x0094, 1, 0x07F8, 0, 0), MX6_PAD_EIM_D17__IPU1_DI0_PIN06 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), MX6_PAD_EIM_D17__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 3, 0x08E0, 0, 0), - MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x03A8, 0x0094, 22, 0x08A8, 0, 0), - MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x0098, 1, 0x07FC, 0, 0), MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), MX6_PAD_EIM_D18__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03AC, 0x0098, 3, 0x08CC, 0, 0), - MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x03AC, 0x0098, 22, 0x08AC, 0, 0), - MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0804, 0, 0), MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), MX6_PAD_EIM_D19__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x08C8, 0, 0), @@ -112,39 +112,39 @@ enum { MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0824, 0, 0), - MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), MX6_PAD_EIM_D20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x08C4, 0, 0), MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x091C, 1, 0), MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), MX6_PAD_EIM_D21__IPU2_CSI1_DATA11 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x08B4, 0, 0), - MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0944, 0, 0), + MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0944, 0, 0), MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x03B8, 0x00A4, 22, 0x0898, 0, 0), MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0914, 0, 0), - MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), MX6_PAD_EIM_D22__IPU2_CSI1_DATA10 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x08B0, 0, 0), - MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x092C, 0, 0), MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x08D8, 0, 0), MX6_PAD_EIM_D23__GPIO3_IO23 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), MX6_PAD_EIM_D23__IPU1_DI1_PIN02 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB3__UART3_CTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), MX6_PAD_EIM_EB3__UART3_RTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x092C, 1, 0), @@ -153,129 +153,129 @@ enum { MX6_PAD_EIM_EB3__GPIO2_IO31 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB3__IPU1_DI1_PIN03 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), MX6_PAD_EIM_EB3__SRC_BOOT_CFG31 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), MX6_PAD_EIM_D24__UART3_TX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), MX6_PAD_EIM_D24__UART3_RX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0930, 0, 0), MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0808, 0, 0), MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x07D8, 0, 0), + MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x07D8, 0, 0), MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, 0), MX6_PAD_EIM_D25__UART3_TX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0000, 0, 0), MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0930, 1, 0), MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x080C, 0, 0), MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x07D4, 0, 0), + MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x07D4, 0, 0), MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x03D0, 0x00BC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x03D0, 0x00BC, 2, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x08C0, 0, 0), MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0928, 0, 0), MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU1_SISG2 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), MX6_PAD_EIM_D26__IPU1_DISP1_DATA22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU2_CSI1_DATA13 = IOMUX_PAD(0x03D4, 0x00C0, 3, 0x08BC, 0, 0), MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0928, 1, 0), MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), MX6_PAD_EIM_D27__IPU1_DISP1_DATA23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x03D8, 0x00C4, 17, 0x089C, 0, 0), MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x03D8, 0x00C4, 2, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU2_CSI1_DATA12 = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x08B8, 0, 0), - MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), + MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x03DC, 0x00C8, 2, 0x0824, 1, 0), MX6_PAD_EIM_D29__UART2_CTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), MX6_PAD_EIM_D29__UART2_RTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0924, 1, 0), MX6_PAD_EIM_D29__GPIO3_IO29 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), MX6_PAD_EIM_D29__IPU2_CSI1_VSYNC = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x08E4, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, 0), MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), - MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), + MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x0000, 0, 0), MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x0000, 0, 0), MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x092C, 3, 0), MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x08D4, 1, 0), MX6_PAD_EIM_A24__IPU2_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x0000, 0, 0), MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x0000, 0, 0), MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x08D0, 1, 0), MX6_PAD_EIM_A23__IPU2_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x0000, 0, 0), MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x0000, 0, 0), MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), MX6_PAD_EIM_A22__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x08CC, 1, 0), MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), MX6_PAD_EIM_A21__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x08C8, 1, 0), MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x08C4, 1, 0), MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), MX6_PAD_EIM_A19__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x08C0, 1, 0), MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), MX6_PAD_EIM_A18__IPU2_CSI1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 2, 0x08BC, 1, 0), MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), MX6_PAD_EIM_A17__IPU2_CSI1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x08B8, 1, 0), MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), MX6_PAD_EIM_A16__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x0408, 0x00F4, 2, 0x08E0, 1, 0), MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0810, 0, 0), MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0818, 0, 0), MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), @@ -283,143 +283,143 @@ enum { MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x0414, 0x0100, 2, 0x0814, 0, 0), MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x0418, 0x0104, 2, 0x081C, 0, 0), MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x041C, 0x0108, 2, 0x0820, 0, 0), MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB0__IPU2_CSI1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 2, 0x08B4, 1, 0), MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0420, 0x010C, 4, 0x07F0, 0, 0), MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 1, 0x0000, 0, 0), MX6_PAD_EIM_EB1__IPU2_CSI1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 2, 0x08B0, 1, 0), MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0424, 0x0110, 5, 0x0000, 0, 0), MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0424, 0x0110, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU2_CSI1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU2_CSI1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0428, 0x0114, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0428, 0x0114, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU2_CSI1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU2_CSI1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x042C, 0x0118, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x042C, 0x0118, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU2_CSI1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU2_CSI1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0430, 0x011C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0430, 0x011C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU2_CSI1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU2_CSI1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0434, 0x0120, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0434, 0x0120, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU2_CSI1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU2_CSI1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x0438, 0x0124, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x0438, 0x0124, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU2_CSI1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU2_CSI1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x043C, 0x0128, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x043C, 0x0128, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU2_CSI1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU2_CSI1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0440, 0x012C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0440, 0x012C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU2_CSI1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU2_CSI1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0444, 0x0130, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0444, 0x0130, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU2_CSI1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU2_CSI1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x0448, 0x0134, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x0448, 0x0134, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU2_CSI1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU2_CSI1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x044C, 0x0138, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x044C, 0x0138, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x0450, 0x013C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x0450, 0x013C, 2, 0x08D8, 1, 0), + MX6_PAD_EIM_DA10__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x0450, 0x013C, 2, 0x08D8, 1, 0), MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x0450, 0x013C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0450, 0x013C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0454, 0x0140, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA11__IPU2_CSI1_HSYNC = IOMUX_PAD(0x0454, 0x0140, 2, 0x08DC, 1, 0), MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0454, 0x0140, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0454, 0x0140, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0458, 0x0144, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA12__IPU2_CSI1_VSYNC = IOMUX_PAD(0x0458, 0x0144, 2, 0x08E4, 1, 0), MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0458, 0x0144, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0458, 0x0144, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x045C, 0x0148, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x045C, 0x0148, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x045C, 0x0148, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x0460, 0x014C, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x0460, 0x014C, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0460, 0x014C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0464, 0x0150, 1, 0x0000, 0, 0), MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0464, 0x0150, 2, 0x0000, 0, 0), MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0464, 0x0150, 5, 0x0000, 0, 0), MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0464, 0x0150, 7, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x0468, 0x0154, 5, 0x0000, 0, 0), MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x0468, 0x0154, 7, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x046C, 0x0158, 1, 0x0000, 0, 0), MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN15__IPU2_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN2__IPU2_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DI0_PIN3__IPU2_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x047C, 0x0168, 5, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 0, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__IPU2_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), @@ -432,12 +432,12 @@ enum { MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0498, 0x0184, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x049C, 0x0188, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), @@ -446,12 +446,12 @@ enum { MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), @@ -464,62 +464,62 @@ enum { MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), + MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), + MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), - MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), + MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), + MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x01B0, 2, 0x0818, 1, 0), - MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), + MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x04C4, 0x01B0, 4, 0x090C, 0, 0), MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x04C8, 0x01B4, 2, 0x0814, 1, 0), - MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), + MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x04C8, 0x01B4, 4, 0x0910, 0, 0), MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), - MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), - MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), + MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), + MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), + MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x04D0, 0x01BC, 2, 0x0810, 1, 0), - MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), - MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), + MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), + MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x04D4, 0x01C0, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), + MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x04D8, 0x01C4, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), + MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x04DC, 0x01C8, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), + MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), + MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), + MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x04E0, 0x01CC, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x04E4, 0x01D0, 1, 0x0840, 0, 0), MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x04E4, 0x01D0, 2, 0x086C, 0, 0), @@ -532,11 +532,11 @@ enum { MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x04EC, 0x01D8, 0, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x04EC, 0x01D8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), + MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), - MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT= IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x04EC, 0x01D8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x04F0, 0x01DC, 1, 0x0858, 1, 0), + MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x04F0, 0x01DC, 1, 0x0858, 1, 0), MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x04F0, 0x01DC, 2, 0x0870, 0, 0), MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x04F0, 0x01DC, 3, 0x0918, 1, 0), MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x04F0, 0x01DC, 5, 0x0000, 0, 0), @@ -546,7 +546,7 @@ enum { MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x04F4, 0x01E0, 4, 0x0000, 0, 0), MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x04F4, 0x01E0, 5, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x04F8, 0x01E4, 1, 0x0848, 1, 0), - MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), + MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x04F8, 0x01E4, 3, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x04F8, 0x01E4, 5, 0x0000, 0, 0), MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x04FC, 0x01E8, 1, 0x0000, 0, 0), @@ -554,61 +554,61 @@ enum { MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x04FC, 0x01E8, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x0500, 0x01EC, 0, 0x0900, 0, 0), MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x0500, 0x01EC, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), + MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x0500, 0x01EC, 4, 0x0000, 0, 0), MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x0500, 0x01EC, 5, 0x0000, 0, 0), MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x0504, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), + MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x0504, 0x01F0, 5, 0x0000, 0, 0), MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x0508, 0x01F4, 0, 0x0904, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x0508, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), + MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x0508, 0x01F4, 4, 0x0000, 0, 0), MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x07F4, 2, 0), MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), - MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), + MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), + MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x07FC, 2, 0), MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), + MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x05CC, 0x01FC, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x05D0, 0x0200, 0, 0x07F8, 2, 0), MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0840, 1, 0), - MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), + MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x05D0, 0x0200, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), + MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x05D4, 0x0204, 0, 0x0800, 2, 0), MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), + MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x05D4, 0x0204, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x05D8, 0x0208, 0, 0x0804, 2, 0), MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0850, 1, 0), MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x05D8, 0x0208, 2, 0x0000, 0, 0), MX6_PAD_KEY_COL2__KEY_COL2 = IOMUX_PAD(0x05D8, 0x0208, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0808, 1, 0), MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x05DC, 0x020C, 1, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x05DC, 0x020C, 2, 0x07E4, 0, 0), MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x05DC, 0x020C, 6, 0x088C, 1, 0), MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x05E0, 0x0210, 0, 0x080C, 1, 0), @@ -618,63 +618,63 @@ enum { MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x05E0, 0x0210, 20, 0x08A0, 1, 0), MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0914, 2, 0), - MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), + MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x05E4, 0x0214, 2, 0x0894, 1, 0), MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x05E4, 0x0214, 20, 0x08A4, 1, 0), MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0000, 0, 0), MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), + MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x093C, 0, 0), MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x05EC, 0x021C, 0, 0x07E8, 0, 0), MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0000, 0, 0), MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x0000, 0, 0), MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x08E8, 0, 0), - MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), + MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05F4, 0x0224, 0, 0x086C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08F4, 0, 0), - MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x05F8, 0x0228, 0, 0x085C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x05F8, 0x0228, 2, 0x08EC, 0, 0), MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), + MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0864, 1, 0), MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05FC, 0x022C, 18, 0x08A8, 1, 0), - MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), - MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), + MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), + MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0600, 0x0230, 0, 0x0870, 1, 0), MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0600, 0x0230, 18, 0x08AC, 1, 0), MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0600, 0x0230, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), + MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x0604, 0x0234, 0, 0x0860, 1, 0), MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x0604, 0x0234, 2, 0x08F8, 1, 0), MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x0604, 0x0234, 7, 0x0904, 1, 0), MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x0608, 0x0238, 0, 0x0868, 1, 0), MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x0608, 0x0238, 2, 0x08F0, 1, 0), @@ -706,7 +706,7 @@ enum { MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x0614, 0x0244, 7, 0x0000, 0, 0), MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x0618, 0x0248, 0, 0x0880, 1, 0), MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x0618, 0x0248, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x0618, 0x0248, 2, 0x083C, 1, 0), + MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x0618, 0x0248, 2, 0x083C, 1, 0), MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x0618, 0x0248, 3, 0x0000, 0, 0), MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x0618, 0x0248, 4, 0x0914, 3, 0), MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x0618, 0x0248, 5, 0x0000, 0, 0), @@ -720,11 +720,11 @@ enum { MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x061C, 0x024C, 5, 0x0000, 0, 0), MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x0620, 0x0250, 0, 0x0878, 0, 0), MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x0620, 0x0250, 1, 0x0844, 1, 0), - MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0620, 0x0250, 3, 0x0910, 1, 0), - MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), + MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0620, 0x0250, 3, 0x0910, 1, 0), + MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x0620, 0x0250, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0), MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0), MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0), @@ -734,7 +734,7 @@ enum { MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x0628, 0x0258, 0, 0x0000, 0, 0), MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x0628, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x062C, 0x025C, 0, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x062C, 0x025C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x062C, 0x025C, 5, 0x0000, 0, 0), @@ -744,115 +744,115 @@ enum { MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x0630, 0x0260, 5, 0x0000, 0, 0), MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x0630, 0x0260, 7, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x0634, 0x0264, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x0634, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0638, 0x0268, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0638, 0x0268, 2, 0x07F4, 3, 0), MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0638, 0x0268, 3, 0x08E8, 2, 0), - MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0638, 0x0268, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x063C, 0x026C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x063C, 0x026C, 2, 0x07FC, 3, 0), MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x063C, 0x026C, 3, 0x08F4, 1, 0), - MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x063C, 0x026C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0640, 0x0270, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0640, 0x0270, 2, 0x07F8, 3, 0), MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0640, 0x0270, 3, 0x08EC, 1, 0), - MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0640, 0x0270, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0644, 0x0274, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x0274, 2, 0x0800, 3, 0), MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0644, 0x0274, 3, 0x08F8, 2, 0), - MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0644, 0x0274, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0648, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0648, 0x0278, 2, 0x0810, 2, 0), MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0648, 0x0278, 3, 0x08F0, 2, 0), MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0648, 0x0278, 20, 0x089C, 1, 0), MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0648, 0x0278, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x064C, 0x027C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x064C, 0x027C, 2, 0x0818, 2, 0), MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x064C, 0x027C, 3, 0x08FC, 2, 0), MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x064C, 0x027C, 20, 0x0898, 1, 0), MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x064C, 0x027C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0650, 0x0280, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0650, 0x0280, 2, 0x0814, 2, 0), - MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0650, 0x0280, 2, 0x0814, 2, 0), + MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0920, 0, 0), MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0650, 0x0280, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0654, 0x0284, 2, 0x081C, 2, 0), MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0658, 0x0288, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0938, 2, 0), MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0658, 0x0288, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), + MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0660, 0x0290, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0940, 2, 0), MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0660, 0x0290, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), + MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0668, 0x0298, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0934, 0, 0), MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0668, 0x0298, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0670, 0x02A0, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x093C, 2, 0), MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0670, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), + MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0000, 0, 0), @@ -860,7 +860,7 @@ enum { MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), + MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0000, 0, 0), @@ -902,29 +902,29 @@ enum { MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x06C0, 0x02D8, 0, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__IPU2_SISG5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__IPU2_SISG5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__IPU2_DI0_PIN01 = IOMUX_PAD(0x06C8, 0x02E0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0874, 1, 0), - MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__IPU2_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 1, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0878, 1, 0), - MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__IPU2_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x06DC, 0x02F4, 16, 0x0000, 0, 0), @@ -986,7 +986,7 @@ enum { MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), + MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x0724, 0x033C, 0, 0x0000, 0, 0), MX6_PAD_SD1_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0724, 0x033C, 1, 0x0834, 1, 0), @@ -1023,17 +1023,17 @@ enum { MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), MX6_PAD_SD2_CLK__ECSPI5_SCLK = IOMUX_PAD(0x073C, 0x0354, 1, 0x0828, 1, 0), MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x073C, 0x0354, 2, 0x08E8, 3, 0), - MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), + MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x0740, 0x0358, 16, 0x0000, 0, 0), MX6_PAD_SD2_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0740, 0x0358, 1, 0x0830, 1, 0), MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x0740, 0x0358, 2, 0x08F4, 2, 0), - MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), + MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__ECSPI5_SS3 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x0744, 0x035C, 2, 0x08EC, 2, 0), - MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), + MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), };
Hi Eric,
On 05/11/2013 01:00, Eric Nelson wrote:
This patch set consolidates mux and pad declarations for the i.MX6 Dual/Quad and Dual-Lite/Solo processor variants.
Patch 1 replaces the mux/pad names with their equivalents from the Linux kernel (from linux-next). This Patch 2 removes a set of completely useless pad declarations Patch 3 adds a number of registers that are defined in the Linux kernel and in the DLS variant, but not in the DQ. Patch 4 removes pad declarations that aren't used and aren't defined in the Linux kernel tree Patch 5 cleans up the whitespace in mx6[q|dl]_pins.h so the IOMUX_PAD() columns line up.
Eric, thanks again for the great job.
Applied (whole patchset) to u-boot-imx, thanks !
Best regards, Stefano Babic
Thanks Stefano,
On 11/13/2013 02:36 AM, Stefano Babic wrote:
Hi Eric,
Oops.
I was kinda hoping to get a head-not from Fabio on the macro-fication of mx6[q|dl]_pins.h.
If we can get that, we can drop patch 5 of this patch set, since the white-space changes all around...
Regards,
Eric
Hi Eric,
On Wed, Nov 13, 2013 at 3:23 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
Oops.
I am not sure I understood the issue with patch 5.
Please clarify.
Regards,
Fabio Estevam
Hi Fabio,
On 11/13/2013 10:30 AM, Fabio Estevam wrote:
Hi Eric,
Oops.
In the RFC e-mail change regarding README.imx6-something, I proposed that we replace the pad declaration form currently in use:
enum { MX6_PAD_SD3_DAT2__USDHC3_DAT2 = IOMUX_PAD(...) };
with macros of this form so that they can be pre-pended with MX6Q_ and MX6DL_ when we need both in an image (SPL?) that can run on either variant of processor.
MX6_PAD_DECL(SD3_DAT2__USDHC3_DAT2, ...)
If we do this, then lining up the columns based on the first form doesn't make much sense.
Section 3 of this post is the easiest place to see things: http://lists.denx.de/pipermail/u-boot/2013-November/166678.html
This post has my list of oustanding questions:
http://lists.denx.de/pipermail/u-boot/2013-November/166876.html
And we're addressing #1 and 2: 1. Whether to turn declarations in mx6q_pins.h/mx6dl_pins.h into macros 2. Whether to double-include the same in mx6-pins.h 3. Whether to define baseline pads (the 90% case) in a header and double-include it, and 4. Whether to macro-fy the memory layout files like 1066mhz_4x128mx16.cfg so they can be used by imximage and gcc.
Regards,
Eric
Hi Eric,
On Wed, Nov 13, 2013 at 3:56 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
I thinks this macro approach should work fine. Do we see any objections?
Understood it now. Thanks for clarifying.
Regards,
Fabio Estevam
Hi Fabio,
On 11/13/2013 01:07 PM, Fabio Estevam wrote:
Hi Eric,
Not so far.
I think everybody would rather not have so much macro-fu, but the only real alternatives are either lots of duplication or an immediate "big bang" switch to have all boards support all CPU variants.
Since we have some boards that are expected to be Solo-Only or Quad-Only forever, we'd like to retain the single-variant build without explicitly listing the pads as MX6Q_ or MX6DL_.
Cool.
I'll re-base the macro patch I have floating here and submit it officially.
It's mostly mechanical and easy to validate.
I'll also submit an updated patch for README.imx6, but will keep it separate because I expect more suggestions regarding the wording.
Regards,
Eric
Eric Nelson
Fabio Estevam
Stefano Babic
