[U-Boot] Support in u-boot for PCI-Express NIC
Is there support under u-boot for newer pcie network cards? Under drivers/net, I notice that there is the e1000 and sk98 network drivers. Unfortunately, these seem a bit dated and the pcie x1 nic/s I am trying to use are not supported (checked the device ids). Pointers on any other supported pcie nic will be helpful.
Thanks, ~Sri
Dear "Srinivasan Srikanth-R9AABP",
In message FD7805B55F061E408EF265C9BDFCB64C0329AD8C@az33exm23.fsl.freescale.net you wrote:
At least the e1000 has been successfully tested not so long ago.
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Wolfgang Denk Sent: Wednesday, May 20, 2009 2:01 PM To: Srinivasan Srikanth-R9AABP Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Support in u-boot for PCI-Express NIC
[SNIP]
Thanks Wolfgang. That's good news. Can you pl point me to the pci-express card/device id that was tested recently (and/or the mails that talk about it)? ~Sri
In message FD7805B55F061E408EF265C9BDFCB64C0329AF77@az33exm23.fsl.freescale.net you wrote:
I think that was it:
commit aa3b8bf9c30065bb2ea852799d32db5020598495 Author: Wolfgang Grandegger wg@grandegger.com Date: Wed May 28 19:55:19 2008 +0200
E1000: Add support for the 82541GI LF Intel Pro 1000 GT Desktop Adapter
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Wolfgang Denk Sent: Friday, May 22, 2009 4:06 AM To: Srinivasan Srikanth-R9AABP Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Support in u-boot for PCI-Express NIC
In message <FD7805B55F061E408EF265C9BDFCB64C0329AF77@az33exm23.fsl.freesc ale.net> you wrote:
was tested
82541 is pci based e1000 silicon. For pcie based e1000 chip, extra code is needed. Roy
Dear "Zang Roy-R61911",
In message 7DF0AF56456B8F4081E3C44CCCE311DE34EEE4@zch01exm23.fsl.freescale.net you wrote:
was tested
You are right, my memory was wrong. The testing I remembered was done under Linux only for this very reason.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Friday, June 05, 2009 18:16 PM To: Zang Roy-R61911 Cc: Srinivasan Srikanth-R9AABP; u-boot@lists.denx.de Subject: Re: [U-Boot] Support in u-boot for PCI-Express NIC
In message <7DF0AF56456B8F4081E3C44CCCE311DE34EEE4@zch01exm23.fsl.freesca le.net> you wrote:
so long ago.
was tested
GT Desktop
Adapter
chip, extra code
is needed.
I have began to port e1000 pcie driver to u-boot. 82572EI is used for this work. I just curious that is there anyone else in this list to do the similar work previously. Roy
Zang Roy-R61911
