[PATCH] common: memtop: Fix the return type for find_ram_top
As the return type is "int" for find_ram_top() function and returning the "base" which is of phys_addr_t is breaking when the "base" address is 64-bit. So fix this by updating the return type as phys_addr_t.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- common/memtop.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/memtop.c b/common/memtop.c index 841d89e0799..114ba64067d 100644 --- a/common/memtop.c +++ b/common/memtop.c @@ -121,7 +121,7 @@ static long region_overlap_check(struct mem_region *mem_rgn, phys_addr_t base, return (i < mem_rgn->count) ? i : -1; }
-static int find_ram_top(struct mem_region *free_mem, +static phys_addr_t find_ram_top(struct mem_region *free_mem, struct mem_region *reserved_mem, phys_size_t size) { long i, rgn;
You should actually align this line too to match (.
With that fixed feel free to add
Reviewed-by: Michal Simek michal.simek@amd.com
and I like to get this to 2025.01 version.
Thanks, Michal
Michal Simek
