[U-Boot] [PATCH 0/3] Fix building various esd boards in u-boot-testing repo's hastable branch
Fix building various esd boards in u-boot-testing repo's hastable branch.
Matthias Fuchs (3): ppc4xx: Fix building of AR405 board ppc4xx: Fix building of CANBT board ppc4xx: Fix building of PMC440 board
board/esd/ar405/config.mk | 9 +-------- board/esd/canbt/config.mk | 8 +------- board/esd/pmc440/config.mk | 2 +- include/configs/AR405.h | 10 +++++----- include/configs/CANBT.h | 6 +++--- include/configs/PMC440.h | 8 ++++---- 6 files changed, 15 insertions(+), 28 deletions(-)
Update image size after addition of new environment handling.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/ar405/config.mk | 9 +-------- include/configs/AR405.h | 10 +++++----- 2 files changed, 6 insertions(+), 13 deletions(-)
diff --git a/board/esd/ar405/config.mk b/board/esd/ar405/config.mk index 3e8baf6..da7c107 100644 --- a/board/esd/ar405/config.mk +++ b/board/esd/ar405/config.mk @@ -20,11 +20,4 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # - -# -# esd AR405 boards -# - -#TEXT_BASE = 0xFFFE0000 -#TEXT_BASE = 0xFFFD0000 -TEXT_BASE = 0xFFFC0000 +TEXT_BASE = 0xFFFA0000 diff --git a/include/configs/AR405.h b/include/configs/AR405.h index 52ead43..45c64c2 100644 --- a/include/configs/AR405.h +++ b/include/configs/AR405.h @@ -175,9 +175,9 @@ * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFC0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN (~(TEXT_BASE) + 1) #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */
/* @@ -209,11 +209,11 @@ #define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR 0xFFFB0000 /* Address of Environment Sector*/ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SECT_SIZE 0x10000 /* see README - env sector total size */ #define CONFIG_ENV_SIZE 0x04000 /* Size of Environment */
-#define CONFIG_ENV_ADDR_REDUND 0xFFFA0000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/canbt/config.mk | 8 +------- include/configs/CANBT.h | 6 +++--- 2 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/board/esd/canbt/config.mk b/board/esd/canbt/config.mk index 80076cd..ae855dc 100644 --- a/board/esd/canbt/config.mk +++ b/board/esd/canbt/config.mk @@ -20,10 +20,4 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # - -# -# esd ADCIOP boards -# - -TEXT_BASE = 0xFFFE0000 -#TEXT_BASE = 0xFFFD0000 +TEXT_BASE = 0xFFFC0000 diff --git a/include/configs/CANBT.h b/include/configs/CANBT.h index cdba81d..115a6f9 100644 --- a/include/configs/CANBT.h +++ b/include/configs/CANBT.h @@ -120,9 +120,9 @@ * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFE0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (128 * 1024) /* Reserve 128 kB for Monitor */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_LEN (~(TEXT_BASE) + 1) #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */
Update image size and default environment after addition of new environment handling.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/pmc440/config.mk | 2 +- include/configs/PMC440.h | 8 ++++---- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/esd/pmc440/config.mk b/board/esd/pmc440/config.mk index 91e65ec..6e9f735 100644 --- a/board/esd/pmc440/config.mk +++ b/board/esd/pmc440/config.mk @@ -23,7 +23,7 @@ sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp
ifndef TEXT_BASE -TEXT_BASE = 0xFFFA0000 +TEXT_BASE = 0xFFF90000 endif
PLATFORM_CPPFLAGS += -DCONFIG_440=1 diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index c2fb56c..3c19f52 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -53,7 +53,7 @@ * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) *----------------------------------------------------------------------*/ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (~(TEXT_BASE) + 1) #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserve 256 kB for malloc() */
#define CONFIG_PRAM 0 /* use pram variable to overwrite */ @@ -61,7 +61,7 @@ #define CONFIG_SYS_BOOT_BASE_ADDR 0xf0000000 #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* _must_ be 0 */ #define CONFIG_SYS_FLASH_BASE 0xfc000000 /* start of FLASH */ -#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE #define CONFIG_SYS_NAND_ADDR 0xd0000000 /* NAND Flash */ #define CONFIG_SYS_OCM_BASE 0xe0010000 /* ocm */ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_OCM_BASE @@ -301,8 +301,8 @@ "fdt_addr_r=800000\0" \ "fpga=fpga loadb 0 ${fpga_addr}\0" \ "load=tftp 200000 /tftpboot/pmc440/u-boot.bin\0" \ - "update=protect off fffa0000 ffffffff;era fffa0000 ffffffff;" \ - "cp.b 200000 fffa0000 60000\0" \ + "update=protect off fff90000 ffffffff;era fff90000 ffffffff;" \ + "cp.b 200000 fff90000 70000\0" \ ""
#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */
Hallo Stefan,
In message 12801574953946-git-send-email-matthias.fuchs@esd.eu Matthias Fuchs wrote:
Ping... See
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/81737/focus=81738
Whole patch-series: Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
