[PATCH] disk: part_dos: update partition table entries after write
Fixes issues when switching from GPT to MBR partition tables.
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com --- Hi,
Sending this patch as a follow-up to the other one [1] doing the same thing for GPT write.
Let me know if you have any questions.
Regards, Gary
[1] https://lists.denx.de/pipermail/u-boot/2021-January/438764.html --- disk/part_dos.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/disk/part_dos.c b/disk/part_dos.c index f431925745..470886f4bb 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -499,6 +499,9 @@ int write_mbr_sector(struct blk_desc *dev_desc, void *buf) return 1; }
+ /* Update the partition table entries*/ + part_init(dev_desc); + return 0; }
This does not catch all cases of changing the MBR. See function write_mbr_partitions() with writes both the MBR and EBRs (if applicable).
Android devices typically have more than 4 partitions. Why does fastboot not update the extended boot records?
Best regards
Heinrich
Regards, Gary
- /* Update the partition table entries*/
- part_init(dev_desc);
- return 0; }
Hi Heinrich,
Good catch! That's correct, I missed it for 2 reasons: 1- I focused on the fastboot code which indeed only calls write_mbr_sector() 2- I did that work on 2020.10 U-Boot which didn't include write_mbr_partitions().
Fastboot is not only used for Android, we generally use it to flash our Linux images as well. I guess the code just hasn't been updated to handle EBR although I'd say that most people use GPT, especially Android users.
Anyway, I'll submit a v2 that take care of write_mbr_partitions().
Regards, Gary
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com --- Changes for v2: - added part_init() inside write_mbr_partitions(), as suggested by Heinrich --- disk/part_dos.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/disk/part_dos.c b/disk/part_dos.c index f431925745c..60addc6e00d 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -423,6 +423,9 @@ int write_mbr_partitions(struct blk_desc *dev, ext_part_sect = next_ebr; }
@@ -499,6 +502,9 @@ int write_mbr_sector(struct blk_desc *dev_desc, void *buf) return 1; }
Acked-by: Marek Szyprowski m.szyprowski@samsung.com
Changes for v2:
- return 0; }
- return 0; }
Best regards
Signed-off-by: Gary Bisson gary.bisson@boundarydevices.com Acked-by: Marek Szyprowski m.szyprowski@samsung.com
This breaks the build if CONFIG_CMD_MBR is enabled. Christian Melki sent a patch but it didn't get picked up?
-- Tom
Ah. The commit message wasn't clear that it was reproducible problem so it was on my list to look at / confirm at some point. I'll take a look sooner now, thanks.
participants (5)
Da Xue
Gary Bisson
Marek Szyprowski
