[U-Boot] [Patch v2 1/3] armv8: ls1088a: Add NXP LS1088A SoC support
The QorIQ LS1088A processor is built on the Layerscape architecture combining eight ARM A53 processor cores with advanced, high-performance datapath acceleration and networks, peripheral interfaces required for networking, wireless infrastructure, and general-purpose embedded applications.
LS1088A is compliant to the Layerscape Chassis Generation 3.
Features summary: - Eight 32-bit / 64-bit ARM v8 Cortex-A53 CPUs - Cores are in 2 cluster of 4-cores each - Cache coherent interconnect (CCI-400) - One 64-bit DDR4 SDRAM memory controller with ECC - Data path acceleration architecture 2.0 (DPAA2) - Ethernet interfaces: SGMIIs, RGMIIs, QSGMIIs, XFIs - QSPI, IFC, 3 PCIe, 1 SATA, 2 USB, 1 SDXC, 2 DUARTs etc
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v2: Fix indentaion in commit msg Separate RDB and Si specific file Move Macros to Kconfig
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 44 ++++++- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 10 ++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +- arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 126 +++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 5 + arch/arm/dts/fsl-ls1088a.dtsi | 78 +++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 62 +++++++++- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 + .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 3 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 11 ++ .../asm/arch-fsl-layerscape/ls1088a_stream_id.h | 57 ++++++++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 + drivers/ddr/fsl/util.c | 2 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/net/ldpaa_eth/ls1088a.c | 87 ++++++++++++++ 17 files changed, 494 insertions(+), 11 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c create mode 100644 arch/arm/dts/fsl-ls1088a.dtsi create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/ls1088a_stream_id.h create mode 100644 drivers/net/ldpaa_eth/ls1088a.c
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index fbb95cd..a3e8499 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -49,6 +49,29 @@ config ARCH_LS1046A select BOARD_EARLY_INIT_F select SYS_FSL_HAS_CCI400
+config ARCH_LS1088A + bool + select ARMV8_SET_SMPEN + select FSL_LSCH3 + select SYS_FSL_DDR + select SYS_FSL_DDR_LE + select SYS_FSL_DDR_VER_50 + select SYS_FSL_HAS_CCI400 + select SYS_FSL_HAS_DDR4 + select SYS_FSL_HAS_SEC + select SYS_FSL_SEC_COMPAT_5 + select SYS_FSL_SEC_LE + select SYS_FSL_SRDS_1 + select SYS_FSL_SRDS_2 + select FSL_TZASC_1 + select SYS_FSL_ERRATUM_A009803 + select SYS_FSL_ERRATUM_A009942 + select SYS_FSL_ERRATUM_A010165 + select SYS_FSL_ERRATUM_A008511 + select SYS_FSL_ERRATUM_A008850 + select ARCH_EARLY_INIT_R + select BOARD_EARLY_INIT_F + config ARCH_LS2080A bool select ARMV8_SET_SMPEN @@ -79,6 +102,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A009203 + select SYS_FSL_HAS_CCN504 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F
@@ -97,7 +121,7 @@ config FSL_LSCH3
config FSL_MC_ENET bool "Management Complex network" - depends on ARCH_LS2080A + depends on ARCH_LS2080A || ARCH_LS1088A default y select RESV_RAM help @@ -113,6 +137,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1043a-pcie" if ARCH_LS1043A default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A + default "fsl,ls1080a-pcie" if ARCH_LS1088A help This compatible is used to find pci controller node in Kernel DT to complete fixup. @@ -173,6 +198,7 @@ config MAX_CPUS default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A default 16 if ARCH_LS2080A + default 8 if ARCH_LS1088A default 1 help Set this number to the maximum number of possible CPUs in the SoC. @@ -195,13 +221,11 @@ config QSPI_AHB_INIT
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" - depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A + depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A || ARCH_LS1088A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A - default 8 if ARCH_LS2080A + default 8 if ARCH_LS2080A || ARCH_LS1088A
-config SYS_FSL_HAS_CCI400 - bool
config SYS_FSL_HAS_DP_DDR bool @@ -244,6 +268,7 @@ config SYS_FSL_PCLK_DIV int "Platform clock divider" default 1 if ARCH_LS1043A default 1 if ARCH_LS1046A + default 1 if ARCH_LS1088A default 2 help This is the divider that is used to derive Platform clock from @@ -313,6 +338,12 @@ config RESV_RAM config SYS_FSL_ERRATUM_A009203 bool
+config SYS_FSL_HAS_CCI400 + bool + +config SYS_FSL_HAS_CCN504 + bool + config SYS_FSL_ERRATUM_A008336 bool
@@ -337,7 +368,8 @@ config SYS_FSL_ERRATUM_A009929 config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM - default 0x20000000 + default 0x20000000 if ARCH_LS2080A + default 0x70000000 if ARCH_LS1088A help Reserved memory needs to be aligned for MC to use. Default value is 512MB. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index c9ab93e..cfad154 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -38,3 +38,7 @@ endif ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif + +ifneq ($(CONFIG_ARCH_LS1088A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1088a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index a826e33..a56cad5 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -14,6 +14,7 @@ #include <asm/arch/soc.h> #include <asm/arch/cpu.h> #include <asm/arch/speed.h> +#include <fsl_immap.h> #ifdef CONFIG_MP #include <asm/arch/mp.h> #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 955e0b7..d7e2d3c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -28,6 +28,11 @@ __weak void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) return; }
+__weak int serdes_get_number(int serdes, int cfg) +{ + return cfg; +} + int is_serdes_configured(enum srds_prtcl device) { int ret = 0; @@ -73,6 +78,9 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device) printf("invalid SerDes%d\n", sd); break; } + + cfg = serdes_get_number(sd, cfg); + /* Is serdes enabled at all? */ if (cfg == 0) return -ENODEV; @@ -99,6 +107,8 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask,
cfg = gur_in32(&gur->rcwsr[rcwsr - 1]) & sd_prctl_mask; cfg >>= sd_prctl_shift; + + cfg = serdes_get_number(sd, cfg); printf("Using SERDES%d Protocol: %d (0x%x)\n", sd + 1, cfg, cfg);
if (!is_serdes_prtcl_valid(sd, cfg)) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 79d1637..5852811 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -73,7 +73,7 @@ ENDPROC(smp_kick_all_cpus) ENTRY(lowlevel_init) mov x29, lr /* Save LR */
-#ifdef CONFIG_FSL_LSCH3 +#if defined(CONFIG_FSL_LSCH3) && defined (CONFIG_SYS_FSL_HAS_CCN504)
/* Set Wuo bit for RN-I 20 */ #ifdef CONFIG_LS2080A @@ -328,7 +328,9 @@ get_svr: ldr x1, =FSL_LSCH3_SVR ldr w0, [x1] ret +#endif
+#ifdef CONFIG_SYS_FSL_HAS_CCN504 hnf_pstate_poll: /* x0 has the desired status, return 0 for success, 1 for timeout * clobber x1, x2, x3, x4, x6, x7 @@ -406,7 +408,7 @@ ENTRY(__asm_flush_l3_dcache) mov lr, x29 ret ENDPROC(__asm_flush_l3_dcache) -#endif +#endif /* CONFIG_SYS_FSL_HAS_CCN504 */
#ifdef CONFIG_MP /* Keep literals not used by the secondary boot code outside it */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c new file mode 100644 index 0000000..9f5cdd5 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c @@ -0,0 +1,126 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/fsl_serdes.h> + +struct serdes_config { + u8 ip_protocol; + u8 lanes[SRDS_MAX_LANES]; + u8 rcw_lanes[SRDS_MAX_LANES]; +}; + +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x12, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 3 } }, + {0x15, {SGMII3, SGMII7, XFI1, XFI2 }, {3, 3, 1, 1 } }, + {0x16, {SGMII3, SGMII7, SGMII1, XFI2 }, {3, 3, 3, 1 } }, + {0x17, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 3, 2 } }, + {0x18, {SGMII3, SGMII7, SGMII1, SGMII2 }, {3, 3, 2, 2 } }, + {0x19, {SGMII3, QSGMII_B, XFI1, XFI2}, {3, 4, 1, 1 } }, + {0x1A, {SGMII3, QSGMII_B, SGMII1, XFI2 }, {3, 4, 3, 1 } }, + {0x1B, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 2 } }, + {0x1C, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 2, 2 } }, + {0x1D, {QSGMII_A, QSGMII_B, XFI1, XFI2 }, {4, 4, 1, 1 } }, + {0x1E, {QSGMII_A, QSGMII_B, SGMII1, XFI2 }, {4, 4, 3, 1 } }, + {0x1F, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 2 } }, + {0x20, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 2, 2 } }, + {0x35, {SGMII3, QSGMII_B, SGMII1, SGMII2 }, {3, 4, 3, 3 } }, + {0x36, {QSGMII_A, QSGMII_B, SGMII1, SGMII2 }, {4, 4, 3, 3 } }, + {0x3A, {SGMII3, PCIE1, SGMII1, SGMII2 }, {3, 5, 3, 3 } }, + {} +}; +static struct serdes_config serdes2_cfg_tbl[] = { + /* SerDes 2 */ + {0x0C, {PCIE1, PCIE1, PCIE1, PCIE1 }, {8, 8, 8, 8 } }, + {0x0D, {PCIE1, PCIE2, PCIE3, SATA1 }, {5, 5, 5, 9 } }, + {0x0E, {PCIE1, PCIE1, PCIE2, SATA1 }, {7, 7, 6, 9 } }, + {0x13, {PCIE1, PCIE1, PCIE3, PCIE3 }, {7, 7, 7, 7 } }, + {0x14, {PCIE1, PCIE2, PCIE3, PCIE3 }, {5, 5, 7, 7 } }, + {0x3C, {NONE, PCIE2, NONE, PCIE3 }, {0, 5, 0, 6 } }, + {} +}; + +static struct serdes_config *serdes_cfg_tbl[] = { + serdes1_cfg_tbl, + serdes2_cfg_tbl, +}; + +int serdes_get_number(int serdes, int cfg) +{ + struct serdes_config *ptr; + int i, j, index, lnk; + int is_found, max_lane = SRDS_MAX_LANES; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + + while (ptr->ip_protocol) { + is_found = 1; + for (i = 0, j = max_lane - 1; i < max_lane; i++, j--) { + lnk = cfg & (0xf << 4 * i); + lnk = lnk >> (4 * i); + + index = (serdes == FSL_SRDS_1) ? j : i; + + if (ptr->rcw_lanes[index] == lnk && is_found) + is_found = 1; + else + is_found = 0; + } + + if (is_found) + return ptr->ip_protocol; + ptr++; + } + + return 0; +} + +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{ + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->ip_protocol) { + if (ptr->ip_protocol == cfg) + return ptr->lanes[lane]; + ptr++; + } + + return 0; +} + +int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{ + int i; + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->ip_protocol) { + if (ptr->ip_protocol == prtcl) + break; + ptr++; + } + + if (!ptr->ip_protocol) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (ptr->lanes[i] != NONE) + return 1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 1e95540..f5a22ba 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -24,6 +24,7 @@ #ifdef CONFIG_CHAIN_OF_TRUST #include <fsl_validate.h> #endif +#include <fsl_immap.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -215,11 +216,14 @@ int sata_init(void) { struct ccsr_ahci __iomem *ccsr_ahci;
+#ifdef CONFIG_SYS_SATA2 ccsr_ahci = (void *)CONFIG_SYS_SATA2; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); out_le32(&ccsr_ahci->axicc, AHCI_PORT_AXICC_CFG); +#endif
+#ifdef CONFIG_SYS_SATA1 ccsr_ahci = (void *)CONFIG_SYS_SATA1; out_le32(&ccsr_ahci->ppcfg, AHCI_PORT_PHY_1_CFG); out_le32(&ccsr_ahci->ptc, AHCI_PORT_TRANS_CFG); @@ -227,6 +231,7 @@ int sata_init(void)
ahci_init((void __iomem *)CONFIG_SYS_SATA1); scsi_scan(0); +#endif
return 0; } diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi new file mode 100644 index 0000000..d6ec463 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -0,0 +1,78 @@ +/* + * NXP ls1088a SOC common device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + compatible = "fsl,ls2080a"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + memory@80000000 { + device_type = "memory"; + reg = <0x00000000 0x80000000 0 0x80000000>; + /* DRAM space - 1, size : 2 GB DRAM */ + }; + + gic: interrupt-controller@6000000 { + compatible = "arm,gic-v3"; + reg = <0x0 0x06000000 0 0x10000>, /* GIC Dist */ + <0x0 0x06100000 0 0x100000>; /* GICR (RD_base + SGI_base) */ + #interrupt-cells = <3>; + interrupt-controller; + interrupts = <1 9 0x4>; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <1 13 0x8>, /* Physical Secure PPI, active-low */ + <1 14 0x8>, /* Physical Non-Secure PPI, active-low */ + <1 11 0x8>, /* Virtual PPI, active-low */ + <1 10 0x8>; /* Hypervisor PPI, active-low */ + }; + + serial0: serial@21c0500 { + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21c0500 0x0 0x100>; + clock-frequency = <0>; /* Updated by bootloader */ + interrupts = <0 32 0x1>; /* edge triggered */ + }; + + serial1: serial@21c0600 { + device_type = "serial"; + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21c0600 0x0 0x100>; + clock-frequency = <0>; /* Updated by bootloader */ + interrupts = <0 32 0x1>; /* edge triggered */ + }; + + fsl_mc: fsl-mc@80c000000 { + compatible = "fsl,qoriq-mc"; + reg = <0x00000008 0x0c000000 0 0x40>, /* MC portal base */ + <0x00000000 0x08340000 0 0x40000>; /* MC control reg */ + }; + + dspi: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <0 26 0x4>; /* Level high type */ + num-cs = <6>; + }; + + qspi: quadspi@1550000 { + compatible = "fsl,vf610-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x20c0000 0x0 0x10000>, + <0x0 0x20000000 0x0 0x10000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; + num-cs = <4>; + }; +}; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index b5b08aa..48a846f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -115,6 +115,67 @@ #define CONFIG_SYS_FSL_ERRATUM_A008751
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 + +#elif defined(CONFIG_ARCH_LS1088A) +#define CONFIG_SYS_FSL_NUM_CC_PLLS 3 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } +#define CONFIG_GICV3 +#define CONFIG_FSL_TZPC_BP147 +#define CONFIG_FSL_TZASC_400 +#define CONFIG_SYS_PAGE_SIZE 0x10000 + +#define SRDS_MAX_LANES 4 + +/* TZ Protection Controller Definitions */ +#define TZPC_BASE 0x02200000 +#define TZPCR0SIZE_BASE (TZPC_BASE) +#define TZPCDECPROT_0_STAT_BASE (TZPC_BASE + 0x800) +#define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) +#define TZPCDECPROT_0_CLR_BASE (TZPC_BASE + 0x808) +#define TZPCDECPROT_1_STAT_BASE (TZPC_BASE + 0x80C) +#define TZPCDECPROT_1_SET_BASE (TZPC_BASE + 0x810) +#define TZPCDECPROT_1_CLR_BASE (TZPC_BASE + 0x814) +#define TZPCDECPROT_2_STAT_BASE (TZPC_BASE + 0x818) +#define TZPCDECPROT_2_SET_BASE (TZPC_BASE + 0x81C) +#define TZPCDECPROT_2_CLR_BASE (TZPC_BASE + 0x820) + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x06000000 +#define GICR_BASE 0x06100000 + +/* SMMU Defintions */ +#define SMMU_BASE 0x05000000 /* GR0 Base */ + +/* DDR */ +#define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE + +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_CCSR_SCFG_LE +#define CONFIG_SYS_FSL_ESDHC_LE +#define CONFIG_SYS_FSL_IFC_LE +#define CONFIG_SYS_FSL_PEX_LUT_LE + +#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN + +/* SFP */ +#define CONFIG_SYS_FSL_SFP_VER_3_4 +#define CONFIG_SYS_FSL_SFP_LE +#define CONFIG_SYS_FSL_SRK_LE + +/* Security Monitor */ +#define CONFIG_SYS_FSL_SEC_MON_LE + +/* Secure Boot */ +#define CONFIG_ESBC_HDR_LS + +/* DCFG - GUR */ +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ +#define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x00020000 /* Real size 128K */ + #elif defined(CONFIG_FSL_LSCH2) #define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ #define SYS_FSL_OCRAM_SPACE_SIZE 0x00200000 /* 2M space */ @@ -212,7 +273,6 @@ #define GICC_BASE 0x01420000
#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 - #else #error SoC not defined #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index bcf3e38..4157478 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -21,6 +21,10 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS1026A, LS1026A, 2), CPU_TYPE_ENTRY(LS2040A, LS2040A, 4), CPU_TYPE_ENTRY(LS1012A, LS1012A, 1), + CPU_TYPE_ENTRY(LS1088A, LS1088A, 8), + CPU_TYPE_ENTRY(LS1084A, LS1084A, 8), + CPU_TYPE_ENTRY(LS1048A, LS1048A, 4), + CPU_TYPE_ENTRY(LS1044A, LS1048A, 4), };
#ifndef CONFIG_SYS_DCACHE_OFF diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 70181c5..a2c7578 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -9,7 +9,7 @@
#include <config.h>
-#ifdef CONFIG_LS2080A +#ifdef CONFIG_FSL_LSCH3 enum srds_prtcl { /* * Nobody will check whether the device 'NONE' has been configured, @@ -158,6 +158,7 @@ void fsl_serdes_init(void); int serdes_get_first_lane(u32 sd, enum srds_prtcl device); enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); int is_serdes_prtcl_valid(int serdes, u32 prtcl); +int serdes_get_number(int serdes, int cfg);
#ifdef CONFIG_FSL_LSCH2 const char *serdes_clock_to_string(u32 clock); diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 04add3b..71dd7b5 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -245,6 +245,17 @@ struct ccsr_gur { #define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT #define FSL_CHASSIS3_SRDS1_REGSR 29 #define FSL_CHASSIS3_SRDS2_REGSR 29 +#elif defined(CONFIG_ARCH_LS1088A) +#define FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_MASK 0xFFFF0000 +#define FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_SHIFT 16 +#define FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_MASK 0x0000FFFF +#define FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_SHIFT 0 +#define FSL_CHASSIS3_SRDS1_PRTCL_MASK FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_MASK +#define FSL_CHASSIS3_SRDS1_PRTCL_SHIFT FSL_CHASSIS3_RCWSR29_SRDS1_PRTCL_SHIFT +#define FSL_CHASSIS3_SRDS2_PRTCL_MASK FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_MASK +#define FSL_CHASSIS3_SRDS2_PRTCL_SHIFT FSL_CHASSIS3_RCWSR30_SRDS2_PRTCL_SHIFT +#define FSL_CHASSIS3_SRDS1_REGSR 29 +#define FSL_CHASSIS3_SRDS2_REGSR 30 #endif #define RCW_SB_EN_REG_INDEX 9 #define RCW_SB_EN_MASK 0x00000400 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/ls1088a_stream_id.h b/arch/arm/include/asm/arch-fsl-layerscape/ls1088a_stream_id.h new file mode 100644 index 0000000..92c9a04 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/ls1088a_stream_id.h @@ -0,0 +1,57 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ +#ifndef __LS1088A_STREAM_ID_H +#define __LS1088A_STREAM_ID_H + +/* Stream IDs on ls1088a devices are not hardwired and are + * programmed by sw. There are a limited number of stream IDs + * available, and the partitioning of them is scenario dependent. + * This header defines the partitioning between legacy, PCI, + * and DPAA2 devices. + * + * This partitiong can be customized in this file depending + * on the specific hardware config-- e.g. perhaps not all + * PEX controllers are in use. + * + * On LS1088 stream IDs are programmed in AMQ registers (32-bits) for + * each of the different bus masters. The relationship between + * the AMQ registers and stream IDs is defined in the table below: + * AMQ bit streamID bit + * --------------------------- + * PL[18] 9 + * BMT[17] 8 + * VA[16] 7 + * [15] - + * ICID[14:7] - + * ICID[6:0] 6-0 + * ---------------------------- + */ + +#define AMQ_PL_MASK (0x1 << 18) /* privilege bit */ +#define AMQ_BMT_MASK (0x1 << 17) /* bypass bit */ + +#define FSL_INVALID_STREAM_ID 0 + +#define FSL_BYPASS_AMQ (AMQ_PL_MASK | AMQ_BMT_MASK) + +/* legacy devices */ +#define FSL_USB1_STREAM_ID 1 +#define FSL_USB2_STREAM_ID 2 +#define FSL_SDMMC_STREAM_ID 3 +#define FSL_SATA1_STREAM_ID 4 +#define FSL_DMA_STREAM_ID 5 + +/* PCI - programmed in PEXn_LUT by OS */ +/* 4 IDs per controller */ +#define FSL_PEX_STREAM_ID_START 7 +#define FSL_PEX_STREAM_ID_END 18 + +/* DPAA2 - set in MC DPC and alloced by MC */ +#define FSL_DPAA2_STREAM_ID_START 23 +#define FSL_DPAA2_STREAM_ID_END 63 + +#endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 426fe8e..2531d45 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -54,6 +54,10 @@ struct cpu_type { #define SVR_LS2084A 0x870910 #define SVR_LS2048A 0x870920 #define SVR_LS2044A 0x870930 +#define SVR_LS1048A 0x870320 +#define SVR_LS1084A 0x870302 +#define SVR_LS1088A 0x870300 +#define SVR_LS1044A 0x870322
#define SVR_DEV_LS2080A 0x8701
diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index b58784b..0f1883b 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -386,7 +386,7 @@ void fsl_ddr_sync_memctl_refresh(unsigned int first_ctrl,
void remove_unused_controllers(fsl_ddr_info_t *info) { -#ifdef CONFIG_FSL_LSCH3 +#ifdef CONFIG_SYS_FSL_HAS_CCN504 int i; u64 nodeid; void *hnf_sam_ctrl = (void *)(CCI_HN_F_0_BASE + CCN_HN_F_SAM_CTL); diff --git a/drivers/net/ldpaa_eth/Makefile b/drivers/net/ldpaa_eth/Makefile index 5587aa6..125d6c2 100644 --- a/drivers/net/ldpaa_eth/Makefile +++ b/drivers/net/ldpaa_eth/Makefile @@ -7,3 +7,4 @@ obj-y += ldpaa_wriop.o obj-y += ldpaa_eth.o obj-$(CONFIG_LS2080A) += ls2080a.o +obj-$(CONFIG_ARCH_LS1088A) += ls1088a.o diff --git a/drivers/net/ldpaa_eth/ls1088a.c b/drivers/net/ldpaa_eth/ls1088a.c new file mode 100644 index 0000000..703945c --- /dev/null +++ b/drivers/net/ldpaa_eth/ls1088a.c @@ -0,0 +1,87 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <phy.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> + +u32 dpmac_to_devdisr[] = { + [WRIOP1_DPMAC1] = FSL_CHASSIS3_DEVDISR2_DPMAC1, + [WRIOP1_DPMAC2] = FSL_CHASSIS3_DEVDISR2_DPMAC2, + [WRIOP1_DPMAC3] = FSL_CHASSIS3_DEVDISR2_DPMAC3, + [WRIOP1_DPMAC4] = FSL_CHASSIS3_DEVDISR2_DPMAC4, + [WRIOP1_DPMAC5] = FSL_CHASSIS3_DEVDISR2_DPMAC5, + [WRIOP1_DPMAC6] = FSL_CHASSIS3_DEVDISR2_DPMAC6, + [WRIOP1_DPMAC7] = FSL_CHASSIS3_DEVDISR2_DPMAC7, + [WRIOP1_DPMAC8] = FSL_CHASSIS3_DEVDISR2_DPMAC8, + [WRIOP1_DPMAC9] = FSL_CHASSIS3_DEVDISR2_DPMAC9, + [WRIOP1_DPMAC10] = FSL_CHASSIS3_DEVDISR2_DPMAC10, +}; + +static int is_device_disabled(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 devdisr2 = in_le32(&gur->devdisr2); + + return dpmac_to_devdisr[dpmac_id] & devdisr2; +} + +void wriop_dpmac_disable(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + setbits_le32(&gur->devdisr2, dpmac_to_devdisr[dpmac_id]); +} + +void wriop_dpmac_enable(int dpmac_id) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + clrbits_le32(&gur->devdisr2, dpmac_to_devdisr[dpmac_id]); +} + +phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtcl) +{ + enum srds_prtcl; + + if (is_device_disabled(dpmac_id + 1)) + return PHY_INTERFACE_MODE_NONE; + + switch (lane_prtcl) { + case SGMII1: + case SGMII2: + case SGMII3: + case SGMII7: + return PHY_INTERFACE_MODE_SGMII; + } + + if (lane_prtcl >= XFI1 && lane_prtcl <= XFI2) + return PHY_INTERFACE_MODE_XGMII; + + if (lane_prtcl >= QSGMII_A && lane_prtcl <= QSGMII_B) + return PHY_INTERFACE_MODE_QSGMII; + + return PHY_INTERFACE_MODE_NONE; +} + +void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) +{ + switch (lane_prtcl) { + case QSGMII_A: + wriop_init_dpmac(sd, 3, (int)lane_prtcl); + wriop_init_dpmac(sd, 4, (int)lane_prtcl); + wriop_init_dpmac(sd, 5, (int)lane_prtcl); + wriop_init_dpmac(sd, 6, (int)lane_prtcl); + break; + case QSGMII_B: + wriop_init_dpmac(sd, 7, (int)lane_prtcl); + wriop_init_dpmac(sd, 8, (int)lane_prtcl); + wriop_init_dpmac(sd, 9, (int)lane_prtcl); + wriop_init_dpmac(sd, 10, (int)lane_prtcl); + break; + } +}
LS1088A is an ARMv8 implementation. The LS1088ARDB is an evaluatoin platform that supports the LS1088A family SoCs. This patch add basic support of the platform.
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com --- v2: Fix indentaion in commit msg Separate RDB and Si specific file
arch/arm/Kconfig | 12 ++ arch/arm/cpu/armv8/Kconfig | 1 + arch/arm/dts/Makefile | 3 +- arch/arm/dts/fsl-ls1088a-rdb.dts | 40 ++++ board/freescale/ls1088a/Kconfig | 15 ++ board/freescale/ls1088a/MAINTAINERS | 9 + board/freescale/ls1088a/Makefile | 9 + board/freescale/ls1088a/ddr.c | 215 +++++++++++++++++++ board/freescale/ls1088a/ddr.h | 46 ++++ board/freescale/ls1088a/eth_ls1088ardb.c | 102 +++++++++ board/freescale/ls1088a/ls1088a.c | 336 ++++++++++++++++++++++++++++++ board/freescale/ls1088a/ls1088a_qixis.h | 34 +++ configs/ls1088ardb_qspi_defconfig | 33 +++ include/configs/ls1088a_common.h | 205 ++++++++++++++++++ include/configs/ls1088ardb.h | 346 +++++++++++++++++++++++++++++++ 15 files changed, 1405 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/fsl-ls1088a-rdb.dts create mode 100644 board/freescale/ls1088a/Kconfig create mode 100644 board/freescale/ls1088a/MAINTAINERS create mode 100644 board/freescale/ls1088a/Makefile create mode 100644 board/freescale/ls1088a/ddr.c create mode 100644 board/freescale/ls1088a/ddr.h create mode 100644 board/freescale/ls1088a/eth_ls1088ardb.c create mode 100644 board/freescale/ls1088a/ls1088a.c create mode 100644 board/freescale/ls1088a/ls1088a_qixis.h create mode 100644 configs/ls1088ardb_qspi_defconfig create mode 100644 include/configs/ls1088a_common.h create mode 100644 include/configs/ls1088ardb.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0a05662..a441cb3 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -954,6 +954,17 @@ config TARGET_LS1012AFRDM development platform that supports the QorIQ LS1012A Layerscape Architecture processor.
+config TARGET_LS1088ARDB + bool "Support ls1088ardb" + select ARCH_LS1088A + select ARM64 + select ARMV8_MULTIENTRY + help + Support for NXP LS1088ARDB platform. + The LS1088AA Reference design board (RDB) is a high-performance + development platform that supports the QorIQ LS1088A + Layerscape Architecture processor. + config TARGET_LS1021AQDS bool "Support ls1021aqds" select BOARD_LATE_INIT @@ -1207,6 +1218,7 @@ source "board/denx/m53evk/Kconfig" source "board/freescale/ls2080a/Kconfig" source "board/freescale/ls2080aqds/Kconfig" source "board/freescale/ls2080ardb/Kconfig" +source "board/freescale/ls1088a/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 0188b95..630bb78 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -88,6 +88,7 @@ config PSCI_RESET depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && !TARGET_LS2080A_EMU && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ !TARGET_LS2080ARDB && !TARGET_LS1012AQDS && \ + !TARGET_LS1088ARDB && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eb68c20..5ac8ea3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -163,7 +163,8 @@ dtb-$(CONFIG_LS102XA) += ls1021a-qds-duart.dtb \ ls1021a-twr-duart.dtb ls1021a-twr-lpuart.dtb \ ls1021a-iot-duart.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ - fsl-ls2080a-rdb.dtb + fsl-ls2080a-rdb.dtb \ + fsl-ls1088a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1088a-rdb.dts b/arch/arm/dts/fsl-ls1088a-rdb.dts new file mode 100644 index 0000000..30ceed8 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-rdb.dts @@ -0,0 +1,40 @@ +/* + * NXP ls1088a RDB board device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls1088a.dtsi" + +/ { + model = "NXP Layerscape 1088a RDB Board"; + compatible = "fsl,ls1088a-rdb", "fsl,ls1088a"; + aliases { + spi0 = &qspi; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/board/freescale/ls1088a/Kconfig b/board/freescale/ls1088a/Kconfig new file mode 100644 index 0000000..a4d8223 --- /dev/null +++ b/board/freescale/ls1088a/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LS1088ARDB + +config SYS_BOARD + default "ls1088a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1088ardb" + +endif diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS new file mode 100644 index 0000000..1abbf91 --- /dev/null +++ b/board/freescale/ls1088a/MAINTAINERS @@ -0,0 +1,9 @@ +LS1088ARDB BOARD +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Ashish Kumar Ashish.Kumar@nxp.com +S: Maintained +F: board/freescale/ls1088a/ +F: include/configs/ls1088ardb.h +F: configs/ls1088ardb_qspi_defconfig +F: configs/ls1088ardb_sdcard_defconfig +F: configs/ls1088ardb_sdcard_qspi_defconfig diff --git a/board/freescale/ls1088a/Makefile b/board/freescale/ls1088a/Makefile new file mode 100644 index 0000000..e997cf1 --- /dev/null +++ b/board/freescale/ls1088a/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ls1088a.o +obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o +obj-y += ddr.o diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c new file mode 100644 index 0000000..5b5a89f --- /dev/null +++ b/board/freescale/ls1088a/ddr.c @@ -0,0 +1,215 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include "ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + /* + * we use identical timing for all slots. If needed, change the code + * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; + */ + pbsp = udimms[ctrl_num]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks && + (pdimm->rank_density >> 30) >= pbsp->rank_gb) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: +#if defined(CONFIG_EMU) + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" + "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, wrlvl_ctrl_3 0x%x\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, + pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, + pbsp->wrlvl_ctl_3); +#else + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + pdimm[0].dq_mapping[0] = 0x15; + pdimm[0].dq_mapping[1] = 0x35; + pdimm[0].dq_mapping[2] = 0x0b; + pdimm[0].dq_mapping[3] = 0x2c; + pdimm[0].dq_mapping[4] = 0x15; + pdimm[0].dq_mapping[5] = 0x35; + pdimm[0].dq_mapping[6] = 0x15; + pdimm[0].dq_mapping[7] = 0x35; + pdimm[0].dq_mapping[8] = 0xc; + pdimm[0].dq_mapping[9] = 0; + pdimm[0].dq_mapping[10] = 0; + pdimm[0].dq_mapping[11] = 0; + pdimm[0].dq_mapping[12] = 0; + pdimm[0].dq_mapping[13] = 0; + pdimm[0].dq_mapping[14] = 0; + pdimm[0].dq_mapping[15] = 0; + pdimm[0].dq_mapping[16] = 0; + pdimm[0].dq_mapping[17] = 0; + + /* force DDR bus width to 32 bits */ + popts->data_bus_width = 1; + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ +#endif + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ +#if defined(CONFIG_EMU) + popts->half_strength_driver_enable = 1; +#else + popts->half_strength_driver_enable = 0; +#endif + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + +#if defined(CONFIG_EMU) + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ +#else + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_100ohm) | + DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ +#endif + popts->cpo_sample = 0x6d; +} + +#ifdef CONFIG_SYS_DDR_RAW_TIMING +dimm_params_t ddr_raw_timing = { + .n_ranks = 1, + .rank_density = 4294967296u, + .capacity = 4294967296u, + .primary_sdram_width = 64, + .ec_sdram_width = 8, + .registered_dimm = 0, + .mirrored_dimm = 1, + .n_row_addr = 15, + .n_col_addr = 10, + .bank_addr_bits = 0, + .bank_group_bits = 2, + .edc_config = 2, + .burst_lengths_bitmask = 0x0c, + + .tckmin_x_ps = 938, + .tckmax_ps = 1500, + .caslat_x = 0x000DFA00, + .taa_ps = 13500, + .trcd_ps = 13500, + .trp_ps = 13500, + .tras_ps = 33000, + .trc_ps = 46500, + .trfc1_ps = 260000, + .trfc2_ps = 160000, + .trfc4_ps = 110000, + .tfaw_ps = 21000, + .trrds_ps = 3700, + .trrdl_ps = 5300, + .tccdl_ps = 5355, + .refresh_rate_ps = 7800000, + .dq_mapping[0] = 0x00, + .dq_mapping[1] = 0x00, + .dq_mapping[2] = 0x00, + .dq_mapping[3] = 0x00, + .dq_mapping[4] = 0x00, + .dq_mapping[5] = 0x00, + .dq_mapping[6] = 0x00, + .dq_mapping[7] = 0x00, + .dq_mapping[8] = 0x00, + .dq_mapping[9] = 0x00, + .dq_mapping[10] = 0x00, + .dq_mapping[11] = 0x00, + .dq_mapping[12] = 0x00, + .dq_mapping[13] = 0x00, + .dq_mapping[14] = 0x00, + .dq_mapping[15] = 0x00, + .dq_mapping[16] = 0x00, + .dq_mapping[17] = 0x00, + .dq_mapping_ors = 1, +}; + +int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, + unsigned int controller_number, + unsigned int dimm_number) +{ + static const char dimm_model[] = "Fixed DDR on board"; + + if (dimm_number == 0) + memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); + + return 0; +} +#endif + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + + puts("Initializing DDR...."); + + puts("using SPD\n"); + dram_size = fsl_ddr_sdram(); + + return dram_size; +} diff --git a/board/freescale/ls1088a/ddr.h b/board/freescale/ls1088a/ddr.h new file mode 100644 index 0000000..1658c22 --- /dev/null +++ b/board/freescale/ls1088a/ddr.h @@ -0,0 +1,46 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_DDR_H__ +#define __LS1088A_DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ + +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 + */ +#if defined(CONFIG_TARGET_LS1088ARDB) + {2, 1666, 0, 8, 8, 0x0A0A0C0E, 0x0F10110C,}, + {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,}, + {} +#else + {2, 2140, 0, 4, 4, 0x0, 0x0}, + {1, 2140, 0, 4, 4, 0x0, 0x0}, + {} +#endif +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; +#endif diff --git a/board/freescale/ls1088a/eth_ls1088ardb.c b/board/freescale/ls1088a/eth_ls1088ardb.c new file mode 100644 index 0000000..91f1b45 --- /dev/null +++ b/board/freescale/ls1088a/eth_ls1088ardb.c @@ -0,0 +1,102 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <malloc.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <exports.h> +#include <asm/arch/fsl_serdes.h> +#include <fsl-mc/ldpaa_wriop.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define MC_BOOT_ENV_VAR "mcinitcmd" +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_FSL_MC_ENET) + char *mc_boot_env_var; + int i, interface; + struct memac_mdio_info mdio_info; + struct mii_dev *dev; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + struct memac_mdio_controller *reg; + u32 srds_s1, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + + srds_s1 = serdes_get_number(FSL_SRDS_1, cfg); + + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = reg; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /* Register the EMI 1 */ + fm_memac_mdio_init(bis, &mdio_info); + + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + mdio_info.regs = reg; + mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME; + + /* Register the EMI 2 */ + fm_memac_mdio_init(bis, &mdio_info); + + switch (srds_s1) { + case 0x1D: + /* + * XFI does not need a PHY to work, but to avoid U-boot use + * default PHY address which is zero to a MAC when it found + * a MAC has no PHY address, we give a PHY address to XFI + * MAC error. + */ + wriop_set_phy_address(WRIOP1_DPMAC1, 0x0a); + wriop_set_phy_address(WRIOP1_DPMAC2, AQ_PHY_ADDR1); + wriop_set_phy_address(WRIOP1_DPMAC3, QSGMII1_PORT1_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC4, QSGMII1_PORT2_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC5, QSGMII1_PORT3_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC6, QSGMII1_PORT4_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC7, QSGMII2_PORT1_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC8, QSGMII2_PORT2_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC9, QSGMII2_PORT3_PHY_ADDR); + wriop_set_phy_address(WRIOP1_DPMAC10, QSGMII2_PORT4_PHY_ADDR); + + break; + default: + printf("SerDes1 protocol 0x%x is not supported on LS1088ARDB\n", + srds_s1); + break; + } + + for (i = WRIOP1_DPMAC3; i <= WRIOP1_DPMAC10; i++) { + interface = wriop_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_QSGMII: + dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + wriop_set_mdio(i, dev); + break; + default: + break; + } + } + + dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); + wriop_set_mdio(WRIOP1_DPMAC2, dev); + + mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c new file mode 100644 index 0000000..151d56c --- /dev/null +++ b/board/freescale/ls1088a/ls1088a.c @@ -0,0 +1,336 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <i2c.h> +#include <malloc.h> +#include <errno.h> +#include <netdev.h> +#include <fsl_ifc.h> +#include <fsl_ddr.h> +#include <fsl_sec.h> +#include <asm/io.h> +#include <fdt_support.h> +#include <libfdt.h> +#include <fsl-mc/fsl_mc.h> +#include <environment.h> +#include <asm/arch-fsl-layerscape/soc.h> + +#include "../common/qixis.h" +#include "ls1088a_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +unsigned long long get_qixis_addr(void) +{ + unsigned long long addr; + + if (gd->flags & GD_FLG_RELOC) + addr = QIXIS_BASE_PHYS; + else + addr = QIXIS_BASE_PHYS_EARLY; + + /* + * IFC address under 256MB is mapped to 0x30000000, any address above + * is mapped to 0x5_10000000 up to 4GB. + */ + addr = addr > 0x10000000 ? addr + 0x500000000ULL : addr + 0x30000000; + + return addr; +} + +int checkboard(void) +{ + char buf[64]; + u8 sw; + static const char *const freq[] = {"100", "125", "156.25", + "100 separate SSCG"}; + int clock; + + printf("Board: LS1088A-RDB, "); + + sw = QIXIS_READ(arch); + printf("Board Arch: V%d, ", sw >> 4); + printf("Board version: %c, boot from ", (sw & 0xf) + 'A' - 1); + + memset((u8 *)buf, 0x00, ARRAY_SIZE(buf)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + +#ifdef CONFIG_SD_BOOT + puts("SD card\n"); +#endif + switch (sw) { + case 0: + puts("QSPI:"); + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT; + if (sw == 0 || sw == 4) + puts("0\n"); + else if (sw == 1) + puts("1\n"); + else + puts("EMU\n"); + break; + + default: + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + break; + } + + printf("FPGA: v%d (%s), build %d", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + /* the timestamp string contains "\n" at the end */ + printf(" on %s", qixis_read_time(buf)); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES1 Reference : "); + sw = QIXIS_READ(brdcfg[2]); + clock = (sw >> 6) & 3; + printf("Clock1 = %sMHz ", freq[clock]); + clock = (sw >> 4) & 3; + printf("Clock2 = %sMHz", freq[clock]); + + puts("\nSERDES2 Reference : "); + clock = (sw >> 2) & 3; + printf("Clock1 = %sMHz ", freq[clock]); + clock = (sw >> 0) & 3; + printf("Clock2 = %sMHz\n", freq[clock]); + + return 0; +} + +bool if_board_diff_clk(void) +{ + u8 diff_conf = QIXIS_READ(dutcfg[11]); + + return diff_conf & 0x80; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0f) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + if (if_board_diff_clk()) + return get_board_sys_clk(); + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + + return 66666666; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +void board_retimer_init(void) +{ + u8 reg; + + /* Retimer is connected to I2C1_CH7_CH5 */ + select_i2c_ch_pca9547(I2C_MUX_CH5); + + /* Access to Control/Shared register */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Read device revision and ID */ + i2c_read(I2C_RETIMER_ADDR, 1, 1, ®, 1); + debug("Retimer version id = 0x%x\n", reg); + + /* Enable Broadcast. All writes target all channel register sets */ + reg = 0x0c; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Reset Channel Registers */ + i2c_read(I2C_RETIMER_ADDR, 0, 1, ®, 1); + reg |= 0x4; + i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1); + + /* Enable override divider select and Enable Override Output Mux */ + i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1); + reg |= 0x24; + i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1); + + /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + reg &= 0x8f; + i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + + /* Selects active PFD MUX Input as Re-timed Data (001) */ + i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + reg &= 0x3f; + reg |= 0x20; + i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + + /* Set data rate as 10.3125 Gbps */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); + reg = 0xb0; + i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR, 0x63, 1, ®, 1); + reg = 0xcd; + i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1); + + /*return the default channel*/ + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); +} + +int board_init(void) +{ + init_final_memctl_regs(); +#if defined(CONFIG_TARGET_LS1088ARDB) && defined(CONFIG_FSL_MC_ENET) + u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE; +#endif + + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + board_retimer_init(); + +#ifdef CONFIG_ENV_IS_NOWHERE + gd->env_addr = (ulong)&default_environment[0]; +#endif + +#if defined(CONFIG_TARGET_LS1088ARDB) && defined(CONFIG_FSL_MC_ENET) + /* invert AQR105 IRQ pins polarity */ + out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK); +#endif + + return 0; +} + +int board_early_init_f(void) +{ + fsl_lsch3_early_init_f(); + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); + print_size(gd->bd->bi_dram[0].size + gd->bd->bi_dram[1].size, ""); + print_ddr_info(0); +} + +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + return 0; +} +#endif + +#ifdef CONFIG_FSL_MC_ENET +void fdt_fixup_board_enet(void *fdt) +{ + int offset; + + offset = fdt_path_offset(fdt, "/fsl-mc"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl,dprc@0"); + + if (offset < 0) { + printf("%s: ERROR: fsl-mc node not found in device tree (error %d)\n", + __func__, offset); + return; + } + + if (get_mc_boot_status() == 0) + fdt_status_okay(fdt, offset); + else + fdt_status_fail(fdt, offset); +} +#endif + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + int err, i; + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + ft_cpu_setup(blob, bd); + + /* fixup DT for the two GPP DDR banks */ + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + base[i] = gd->bd->bi_dram[i].start; + size[i] = gd->bd->bi_dram[i].size; + } + +#ifdef CONFIG_RESV_RAM + /* reduce size if reserved memory is within this bank */ + if (gd->arch.resv_ram >= base[0] && + gd->arch.resv_ram < base[0] + size[0]) + size[0] = gd->arch.resv_ram - base[0]; + else if (gd->arch.resv_ram >= base[1] && + gd->arch.resv_ram < base[1] + size[1]) + size[1] = gd->arch.resv_ram - base[1]; +#endif + + fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS); + +#ifdef CONFIG_FSL_MC_ENET + fdt_fixup_board_enet(blob); + err = fsl_mc_ldpaa_exit(bd); + if (err) + return err; +#endif + + return 0; +} +#endif diff --git a/board/freescale/ls1088a/ls1088a_qixis.h b/board/freescale/ls1088a/ls1088a_qixis.h new file mode 100644 index 0000000..9757d1b --- /dev/null +++ b/board/freescale/ls1088a/ls1088a_qixis.h @@ -0,0 +1,34 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088AQDS_QIXIS_H__ +#define __LS1088AQDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for LS1088AQDS */ + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +/* BRDCFG2 - SD clock*/ +#define QIXIS_SDCLK1_100 0x0 +#define QIXIS_SDCLK1_125 0x1 +#define QIXIS_SDCLK1_165 0x2 +#define QIXIS_SDCLK1_100_SP 0x3 + +#endif diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig new file mode 100644 index 0000000..223d581 --- /dev/null +++ b/configs/ls1088ardb_qspi_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088ARDB=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" +CONFIG_BOOTDELAY=10 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h new file mode 100644 index 0000000..5d16c78 --- /dev/null +++ b/include/configs/ls1088a_common.h @@ -0,0 +1,205 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088_COMMON_H +#define __LS1088_COMMON_H + + +#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE +#define CONFIG_MP + +#include <asm/arch/ls1088a_stream_id.h> +#include <asm/arch/config.h> + +/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + +/* We need architecture specific misc initializations */ +#define CONFIG_ARCH_MISC_INIT + +/* Link Definitions */ +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_SYS_TEXT_BASE 0x20100000 +#else +#define CONFIG_SYS_TEXT_BASE 0x30100000 +#endif + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* Flat Device Tree Definitions */ +/* #define CONFIG_OF_LIBFDT */ + +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL +#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_SYS_DDR_BLOCK2_BASE 0x8080000000ULL +#define CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS 1 +#define CONFIG_BOARD_LATE_INIT +/* + * SMP Definitinos + */ +#define CPU_RELEASE_ADDR secondary_boot_func + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024) + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* IFC */ +#define CONFIG_FSL_IFC + +/* + * During booting, IFC is mapped at the region of 0x30000000. + * But this region is limited to 256MB. To accommodate NOR, promjet + * and FPGA. This region is divided as below: + * 0x30000000 - 0x37ffffff : 128MB : NOR flash + * 0x38000000 - 0x3BFFFFFF : 64MB : Promjet + * 0x3C000000 - 0x40000000 : 64MB : FPGA etc + * + * To accommodate bigger NOR flash and other devices, we will map IFC + * chip selects to as below: + * 0x5_1000_0000..0x5_1fff_ffff Memory Hole + * 0x5_2000_0000..0x5_3fff_ffff IFC CSx (FPGA, NAND and others 512MB) + * 0x5_4000_0000..0x5_7fff_ffff ASIC or others 1GB + * 0x5_8000_0000..0x5_bfff_ffff IFC CS0 1GB (NOR/Promjet) + * 0x5_C000_0000..0x5_ffff_ffff IFC CS1 1GB (NOR/Promjet) + * + * For e.g. NOR flash at CS0 will be mapped to 0x580000000 after relocation. + * CONFIG_SYS_FLASH_BASE has the final address (core view) + * CONFIG_SYS_FLASH_BASE_PHYS has the final address (IFC view) + * CONFIG_SYS_FLASH_BASE_PHYS_EARLY has the temporary IFC address + * CONFIG_SYS_TEXT_BASE is linked to 0x30000000 for booting + */ + +#define CONFIG_SYS_FLASH_BASE 0x580000000ULL +#define CONFIG_SYS_FLASH_BASE_PHYS 0x80000000 +#define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000 + +#define CONFIG_SYS_FLASH1_BASE_PHYS 0xC0000000 +#define CONFIG_SYS_FLASH1_BASE_PHYS_EARLY 0x8000000 + +#ifndef __ASSEMBLY__ +unsigned long long get_qixis_addr(void); +#endif + +#define QIXIS_BASE get_qixis_addr() +#define QIXIS_BASE_PHYS 0x20000000 +#define QIXIS_BASE_PHYS_EARLY 0xC000000 + + +#define CONFIG_SYS_NAND_BASE 0x530000000ULL +#define CONFIG_SYS_NAND_BASE_PHYS 0x30000000 + + +/* MC firmware */ +/* TODO Actual DPL max length needs to be confirmed with the MC FW team */ +#define CONFIG_SYS_LS_MC_DPC_MAX_LENGTH 0x20000 +#define CONFIG_SYS_LS_MC_DRAM_DPC_OFFSET 0x00F00000 +#define CONFIG_SYS_LS_MC_DPL_MAX_LENGTH 0x20000 +#define CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET 0x00F20000 +#define CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH 0x200000 +#define CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET 0x07000000 +/* + * Carve out a DDR region which will not be used by u-boot/Linux + * + * It will be used by MC and Debug Server. The MC region must be + * 512MB aligned, so the min size to hide is 512MB. + */ + +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) +#endif + +#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ + +/* Command line configuration */ +#define CONFIG_CMD_ENV + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) + +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#define CONFIG_NR_DRAM_BANKS 2 + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 128 + +/* #define CONFIG_DISPLAY_CPUINFO */ + +/* Allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x581200000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "console=ttyAMA0,38400n8\0" \ + "mcinitcmd=fsl_mc start mc 0x580300000" \ + " 0x580800000 \0" + +#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ + "earlycon=uart8250,mmio,0x21c0500 " \ + "ramdisk_size=0x3000000 default_hugepagesz=2m" \ + " hugepagesz=2m hugepages=256" +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read 0x80200000 0x700000 0x100000;"\ + " fsl_mc apply dpl 0x80200000 &&" \ + " sf read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" +#else +#define CONFIG_BOOTCOMMAND "fsl_mc apply dpl 0x580700000 &&" \ + " cp.b $kernel_start $kernel_load" \ + " $kernel_size && bootm $kernel_load" +#endif + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#endif /* __LS1088_COMMON_H */ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h new file mode 100644 index 0000000..49349f7 --- /dev/null +++ b/include/configs/ls1088ardb.h @@ -0,0 +1,346 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_RDB_H +#define __LS1088A_RDB_H + +#include "ls1088a_common.h" + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_DISPLAY_BOARDINFO_LATE +#else +#define CONFIG_DISPLAY_BOARDINFO +#endif + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (2 * 1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_QIXIS_I2C_ACCESS +#define SYS_NO_FLASH +#undef CONFIG_CMD_IMLS +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 +#define COUNTER_FREQUENCY_REAL 25000000 /* 25MHz */ +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +#define CONFIG_DDR_SPD +#ifdef CONFIG_EMU +#define CONFIG_SYS_FSL_DDR_EMU +#define CONFIG_SYS_MXC_I2C1_SPEED 40000000 +#define CONFIG_SYS_MXC_I2C2_SPEED 40000000 +#else +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 /* SPD on I2C bus 0 */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 + + +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128 * 1024 * 1024) +#define CONFIG_SYS_NOR_AMASK_EARLY IFC_AMASK(64 * 1024 * 1024) + +#define CONFIG_SYS_NOR0_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR0_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(6) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x1)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ + FTIM2_NOR_TCH(0x0) | \ + FTIM2_NOR_TWP(0x1)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#ifndef SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#endif +#endif +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_MAX_ECCPOS 256 +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#define CONFIG_FSL_QIXIS +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 2 +#define QIXIS_QMAP_MASK 0xe0 +#define QIXIS_QMAP_SHIFT 5 +#define QIXIS_LBMAP_MASK 0x1f +#define QIXIS_LBMAP_SHIFT 5 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x20 +#define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0x00 +#define QIXIS_LBMAP_QSPI 0x00 +#define QIXIS_RCW_SRC_SD 0x40 +#define QIXIS_RCW_SRC_QSPI 0x62 +#define QIXIS_RST_CTL_RESET 0x31 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RST_FORCE_MEM 0x01 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS_EARLY) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define SYS_FPGA_CSPR_FINAL (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) + +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) +/* QIXIS Timing parameters*/ +#define SYS_FPGA_CS_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define SYS_FPGA_CS_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define SYS_FPGA_CS_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define SYS_FPGA_CS_FTIM3 0x0 + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR2_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK2 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS2_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 SYS_FPGA_CS_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#endif + + +/* Debug Server firmware */ +#define CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR +#define CONFIG_SYS_DEBUG_SERVER_FW_ADDR 0x580D00000ULL + +#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000 + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH5 0xD +/* +* RTC configuration +*/ +#define RTC +#define CONFIG_RTC_PCF8563 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 3*/ +#define CONFIG_CMD_DATE + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* QSPI device */ +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +/*#define CONFIG_SYS_FSL_ERRATUM_A009282 // move to layersacpe kconfig*/ +#endif + +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff +#define CONFIG_FSL_MEMAC + +/* Initial environment variables */ +#if defined(CONFIG_QSPI_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1100000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=sf probe 0:0;sf read 0x80000000 0x300000 0x100000;" \ + "sf read 0x80100000 0x800000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#else /* NOR_BOOT */ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1100000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=fsl_mc start mc 0x580300000 0x580800000\0" \ + "sf read 0x80100000 0x800000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#endif + +/* MAC/PHY configuration */ +#ifdef CONFIG_FSL_MC_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_GIGE +#define CONFIG_PHYLIB + +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_AQUANTIA +#define AQ_PHY_ADDR1 0x00 +#define AQR105_IRQ_MASK 0x00000004 + +#define QSGMII1_PORT1_PHY_ADDR 0x0c +#define QSGMII1_PORT2_PHY_ADDR 0x0d +#define QSGMII1_PORT3_PHY_ADDR 0x0e +#define QSGMII1_PORT4_PHY_ADDR 0x0f +#define QSGMII2_PORT1_PHY_ADDR 0x1c +#define QSGMII2_PORT2_PHY_ADDR 0x1d +#define QSGMII2_PORT3_PHY_ADDR 0x1e +#define QSGMII2_PORT4_PHY_ADDR 0x1f + +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC1@xgmii" +#define CONFIG_PHY_GIGE +#endif + +/* MMC */ +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#endif + +#undef CONFIG_CMDLINE_EDITING +#include <config_distro_defaults.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1088A_RDB_H */
- bool "Support ls1088ardb"
- select ARCH_LS1088A
- select ARM64
- select ARMV8_MULTIENTRY
- help
!TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \!TARGET_LS1088ARDB && \
- fsl-ls2080a-rdb.dtb \
- fsl-ls1088a-rdb.dtb
- NXP ls1088a RDB board device tree source
- Copyright 2017 NXP
+/dts-v1/;
- model = "NXP Layerscape 1088a RDB Board";
- compatible = "fsl,ls1088a-rdb", "fsl,ls1088a";
- aliases {
spi0 = &qspi;
+&qspi {
- bus-num = <0>;
- status = "okay";
- qflash0: s25fs512s@0 {
#size-cells = <1>;
reg = <0>;
- qflash1: s25fs512s@1 {
#size-cells = <1>;
reg = <1>;
+config SYS_BOARD
- default "ls1088a"
+config SYS_VENDOR
- default "freescale"
+config SYS_SOC
- default "fsl-layerscape"
- default "ls1088ardb"
- const struct board_specific_parameters *pbsp, *pbsp_highest = NULL;
- ulong ddr_freq;
- if (ctrl_num > 1) {
return;
- if (!pdimm->n_ranks)
return;
- pbsp = udimms[ctrl_num];
- /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr
- ddr_freq = get_ddr_freq(0) / 1000000;
- while (pbsp->datarate_mhz_high) {
goto found;
pbsp++;
- if (pbsp_highest) {
ddr_freq);
- } else {
Do you want to keep emulator support?
- debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n"
pbsp->wrlvl_ctl_3);
+#else
- debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n",
- pdimm[0].dq_mapping[0] = 0x15;
- pdimm[0].dq_mapping[1] = 0x35;
- pdimm[0].dq_mapping[2] = 0x0b;
- pdimm[0].dq_mapping[3] = 0x2c;
- pdimm[0].dq_mapping[4] = 0x15;
- pdimm[0].dq_mapping[5] = 0x35;
- pdimm[0].dq_mapping[6] = 0x15;
- pdimm[0].dq_mapping[7] = 0x35;
- pdimm[0].dq_mapping[8] = 0xc;
- pdimm[0].dq_mapping[9] = 0;
- pdimm[0].dq_mapping[10] = 0;
- pdimm[0].dq_mapping[11] = 0;
- pdimm[0].dq_mapping[12] = 0;
- pdimm[0].dq_mapping[13] = 0;
- pdimm[0].dq_mapping[14] = 0;
- pdimm[0].dq_mapping[15] = 0;
- pdimm[0].dq_mapping[16] = 0;
- pdimm[0].dq_mapping[17] = 0;
- /* force DDR bus width to 32 bits */
- popts->data_bus_width = 1;
- popts->otf_burst_chop_en = 0;
- popts->burst_length = DDR_BL8;
- popts->bstopre = 0; /* enable auto precharge */
- popts->half_strength_driver_enable = 1;
+#else
- popts->half_strength_driver_enable = 0;
- popts->wrlvl_override = 1;
- popts->wrlvl_sample = 0xf;
- popts->rtt_override = 0;
- /* Enable ZQ calibration */
- popts->zq_en = 1;
- popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm);
- popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) |
+#else
- popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm);
- popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_100ohm) |
- popts->cpo_sample = 0x6d;
You don't need the RAW timing support if you are using regular DIMM, unless you don't have I2C bus. And your DQ mapping is different. It seems wrong.
- .n_ranks = 1,
- .rank_density = 4294967296u,
- .capacity = 4294967296u,
- .primary_sdram_width = 64,
- .ec_sdram_width = 8,
- .registered_dimm = 0,
- .mirrored_dimm = 1,
- .n_row_addr = 15,
- .n_col_addr = 10,
- .bank_addr_bits = 0,
- .bank_group_bits = 2,
- .edc_config = 2,
- .burst_lengths_bitmask = 0x0c,
- .tckmin_x_ps = 938,
- .tckmax_ps = 1500,
- .caslat_x = 0x000DFA00,
- .taa_ps = 13500,
- .trcd_ps = 13500,
- .trp_ps = 13500,
- .tras_ps = 33000,
- .trc_ps = 46500,
- .trfc1_ps = 260000,
- .trfc2_ps = 160000,
- .trfc4_ps = 110000,
- .tfaw_ps = 21000,
- .trrds_ps = 3700,
- .trrdl_ps = 5300,
- .tccdl_ps = 5355,
- .refresh_rate_ps = 7800000,
- .dq_mapping[0] = 0x00,
- .dq_mapping[1] = 0x00,
- .dq_mapping[2] = 0x00,
- .dq_mapping[3] = 0x00,
- .dq_mapping[4] = 0x00,
- .dq_mapping[5] = 0x00,
- .dq_mapping[6] = 0x00,
- .dq_mapping[7] = 0x00,
- .dq_mapping[8] = 0x00,
- .dq_mapping[9] = 0x00,
- .dq_mapping[10] = 0x00,
- .dq_mapping[11] = 0x00,
- .dq_mapping[12] = 0x00,
- .dq_mapping[13] = 0x00,
- .dq_mapping[14] = 0x00,
- .dq_mapping[15] = 0x00,
- .dq_mapping[16] = 0x00,
- .dq_mapping[17] = 0x00,
- .dq_mapping_ors = 1,
- static const char dimm_model[] = "Fixed DDR on board";
- if (dimm_number == 0)
+} +#endif
- phys_size_t dram_size;
- puts("Initializing DDR....");
- puts("using SPD\n");
- dram_size = fsl_ddr_sdram();
- return dram_size;
- u32 n_ranks;
- u32 datarate_mhz_high;
- u32 rank_gb;
- u32 clk_adjust;
- u32 wrlvl_start;
- u32 wrlvl_ctl_2;
- u32 wrlvl_ctl_3;
- These tables contain all valid speeds we want to override with board
- specific parameters. datarate_mhz_high values need to be in ascending order
- for each n_ranks group.
- {2, 1666, 0, 8, 8, 0x0A0A0C0E, 0x0F10110C,},
- {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,},
- {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,},
+#else
What's the else for?
- {2, 2140, 0, 4, 4, 0x0, 0x0},
- {1, 2140, 0, 4, 4, 0x0, 0x0},
+#endif +};
- udimm0,
- char *mc_boot_env_var;
- int i, interface;
- struct memac_mdio_info mdio_info;
- struct mii_dev *dev;
- struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- struct memac_mdio_controller *reg;
- u32 srds_s1, cfg;
- cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) &
- cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT;
- srds_s1 = serdes_get_number(FSL_SRDS_1, cfg);
- reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1;
- mdio_info.regs = reg;
- mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME;
- /* Register the EMI 1 */
- fm_memac_mdio_init(bis, &mdio_info);
- reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2;
- mdio_info.name = DEFAULT_WRIOP_MDIO2_NAME;
- /* Register the EMI 2 */
- switch (srds_s1) {
- case 0x1D:
* MAC error.
break;
- default:
srds_s1);
break;
- for (i = WRIOP1_DPMAC3; i <= WRIOP1_DPMAC10; i++) {
break;
default:
break;
- dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME);
- wriop_set_mdio(WRIOP1_DPMAC2, dev);
- mc_boot_env_var = getenv(MC_BOOT_ENV_VAR);
- if (mc_boot_env_var)
- cpu_eth_init(bis);
- return pci_eth_init(bis);
- unsigned long long addr;
- if (gd->flags & GD_FLG_RELOC)
- else
- addr = addr > 0x10000000 ? addr + 0x500000000ULL : addr + 0x30000000;
- return addr;
- char buf[64];
- u8 sw;
- static const char *const freq[] = {"100", "125", "156.25",
- int clock;
- printf("Board: LS1088A-RDB, ");
- sw = QIXIS_READ(arch);
- printf("Board Arch: V%d, ", sw >> 4);
- printf("Board version: %c, boot from ", (sw & 0xf) + 'A' - 1);
- memset((u8 *)buf, 0x00, ARRAY_SIZE(buf));
- sw = QIXIS_READ(brdcfg[0]);
- sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT;
- puts("SD card\n");
- switch (sw) {
- case 0:
puts("QSPI:");
puts("0\n");
else if (sw == 1)
puts("1\n");
else
puts("EMU\n");
break;
- default:
break;
- printf("FPGA: v%d (%s), build %d",
- /* the timestamp string contains "\n" at the end */
- printf(" on %s", qixis_read_time(buf));
* don't match.
- puts("SERDES1 Reference : ");
- sw = QIXIS_READ(brdcfg[2]);
- clock = (sw >> 6) & 3;
- printf("Clock1 = %sMHz ", freq[clock]);
- clock = (sw >> 4) & 3;
- printf("Clock2 = %sMHz", freq[clock]);
- puts("\nSERDES2 Reference : ");
- clock = (sw >> 2) & 3;
- clock = (sw >> 0) & 3;
- printf("Clock2 = %sMHz\n", freq[clock]);
- u8 diff_conf = QIXIS_READ(dutcfg[11]);
- return diff_conf & 0x80;
- u8 sysclk_conf = QIXIS_READ(brdcfg[1]);
- switch (sysclk_conf & 0x0f) {
- case QIXIS_SYSCLK_83:
return 83333333;
- case QIXIS_SYSCLK_100:
return 100000000;
- case QIXIS_SYSCLK_125:
return 125000000;
- case QIXIS_SYSCLK_133:
return 133333333;
- case QIXIS_SYSCLK_150:
return 150000000;
- case QIXIS_SYSCLK_160:
return 160000000;
- case QIXIS_SYSCLK_166:
return 166666666;
- return 66666666;
- u8 ddrclk_conf = QIXIS_READ(brdcfg[1]);
- if (if_board_diff_clk())
- switch ((ddrclk_conf & 0x30) >> 4) {
- case QIXIS_DDRCLK_100:
return 100000000;
- case QIXIS_DDRCLK_125:
return 125000000;
- case QIXIS_DDRCLK_133:
return 133333333;
- return 66666666;
- int ret;
- ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1);
- if (ret) {
return ret;
- u8 reg;
- /* Retimer is connected to I2C1_CH7_CH5 */
- select_i2c_ch_pca9547(I2C_MUX_CH5);
- /* Access to Control/Shared register */
- reg = 0x0;
- i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1);
- /* Read device revision and ID */
- i2c_read(I2C_RETIMER_ADDR, 1, 1, ®, 1);
- debug("Retimer version id = 0x%x\n", reg);
- /* Enable Broadcast. All writes target all channel register sets */
- reg = 0x0c;
- /* Reset Channel Registers */
- i2c_read(I2C_RETIMER_ADDR, 0, 1, ®, 1);
- reg |= 0x4;
- i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1);
- /* Enable override divider select and Enable Override Output Mux */
- i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1);
- reg |= 0x24;
- i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1);
- /* Select VCO Divider to full rate (000) */
- i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1);
- reg &= 0x8f;
- i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1);
- /* Selects active PFD MUX Input as Re-timed Data (001) */
- i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1);
- reg &= 0x3f;
- reg |= 0x20;
- i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1);
- /* Set data rate as 10.3125 Gbps */
- reg = 0x0;
- i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1);
- reg = 0xb0;
- i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1);
- reg = 0x90;
- i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1);
- reg = 0xb3;
- i2c_write(I2C_RETIMER_ADDR, 0x63, 1, ®, 1);
- reg = 0xcd;
- i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1);
- /*return the default channel*/
- select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT);
- init_final_memctl_regs();
- u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE;
- board_retimer_init();
- gd->env_addr = (ulong)&default_environment[0];
- /* invert AQR105 IRQ pins polarity */
- out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK);
- fsl_lsch3_early_init_f();
- puts("\nDDR ");
- print_size(gd->bd->bi_dram[0].size + gd->bd->bi_dram[1].size, "");
- print_ddr_info(0);
- sec_init();
+} +#endif
- int offset;
- offset = fdt_path_offset(fdt, "/fsl-mc");
- if (offset < 0)
- if (offset < 0) {
__func__, offset);
return;
- if (get_mc_boot_status() == 0)
- else
+} +#endif
- int err, i;
- u64 base[CONFIG_NR_DRAM_BANKS];
- u64 size[CONFIG_NR_DRAM_BANKS];
- ft_cpu_setup(blob, bd);
- /* fixup DT for the two GPP DDR banks */
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
- /* reduce size if reserved memory is within this bank */
- if (gd->arch.resv_ram >= base[0] &&
- else if (gd->arch.resv_ram >= base[1] &&
- fdt_fixup_memory_banks(blob, base, size, CONFIG_NR_DRAM_BANKS);
- fdt_fixup_board_enet(blob);
- err = fsl_mc_ldpaa_exit(bd);
- if (err)
return err;
- SMP Definitinos
- During booting, IFC is mapped at the region of 0x30000000.
- But this region is limited to 256MB. To accommodate NOR, promjet
- and FPGA. This region is divided as below:
- 0x30000000 - 0x37ffffff : 128MB : NOR flash
- 0x38000000 - 0x3BFFFFFF : 64MB : Promjet
- 0x3C000000 - 0x40000000 : 64MB : FPGA etc
- To accommodate bigger NOR flash and other devices, we will map IFC
- chip selects to as below:
- 0x5_1000_0000..0x5_1fff_ffff Memory Hole
- 0x5_2000_0000..0x5_3fff_ffff IFC CSx (FPGA, NAND and others 512MB)
- 0x5_4000_0000..0x5_7fff_ffff ASIC or others 1GB
- 0x5_8000_0000..0x5_bfff_ffff IFC CS0 1GB (NOR/Promjet)
- 0x5_C000_0000..0x5_ffff_ffff IFC CS1 1GB (NOR/Promjet)
- For e.g. NOR flash at CS0 will be mapped to 0x580000000 after relocation.
- CONFIG_SYS_FLASH_BASE has the final address (core view)
- CONFIG_SYS_FLASH_BASE_PHYS has the final address (IFC view)
- CONFIG_SYS_FLASH_BASE_PHYS_EARLY has the temporary IFC address
- CONFIG_SYS_TEXT_BASE is linked to 0x30000000 for booting
- Carve out a DDR region which will not be used by u-boot/Linux
- It will be used by MC and Debug Server. The MC region must be
- 512MB aligned, so the min size to hide is 512MB.
- "hwconfig=fsl_ddr:bank_intlv=auto\0" \
- "loadaddr=0x80100000\0" \
- "kernel_addr=0x100000\0" \
- "ramdisk_addr=0x800000\0" \
- "ramdisk_size=0x2000000\0" \
- "fdt_high=0xa0000000\0" \
- "initrd_high=0xffffffffffffffff\0" \
- "kernel_start=0x581200000\0" \
- "kernel_load=0xa0000000\0" \
- "kernel_size=0x2800000\0" \
- "console=ttyAMA0,38400n8\0" \
- "mcinitcmd=fsl_mc start mc 0x580300000" \
- " 0x580800000 \0"
Please stop using this copying.
Why this?
- (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \
- CSPR_PORT_SIZE_16 | \
- CSPR_MSEL_NOR | \
- CSPR_V)
- (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \
- CSPR_MSEL_NOR | \
- CSPR_V)
FTIM2_NOR_TWP(0x1))
| CSPR_V)
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_GPCM \
| CSPR_V)
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_GPCM \
| CSPR_V)
- I2C bus multiplexer
- "loadaddr=0x90100000\0" \
- "kernel_start=0x1100000\0" \
- "mcinitcmd=sf probe 0:0;sf read 0x80000000 0x300000 0x100000;" \
- "sf read 0x80100000 0x800000 0x100000;" \
- "fsl_mc start mc 0x80000000 0x80100000\0" \
- "mcmemsize=0x70000000 \0"
- "mcinitcmd=fsl_mc start mc 0x580300000 0x580800000\0" \
Why this?
- func(USB, usb, 0) \
- func(MMC, mmc, 0) \
- func(SCSI, scsi, 0) \
- func(DHCP, dhcp, na)
Curiously, did you verify distroboot?
York
Hello York,
Thanks for your comments, Please see inline, most comments address in v3
Regards Ashish
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 12, 2017 2:26 AM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de; u-boot@linux.freescale.net Cc: Alison Wang alison.wang@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Raghav Dogra raghav.dogra@nxp.com; Shaohui Xie Shaohui.Xie@nxp.com Subject: Re: [Patch v2 2/3] armv8: ls1088ardb: Add support for LS1088ARDB platform
- select ARM64
- help
!TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ diff --git!TARGET_LS1088ARDB && \
+/dts-v1/;
- aliases {
spi0 = &qspi;
+&qspi {
- bus-num = <0>;
- status = "okay";
#size-cells = <1>;
reg = <0>;
#size-cells = <1>;
reg = <1>;
+config SYS_BOARD
- default "ls1088a"
+config SYS_VENDOR
+config SYS_SOC
+obj-y += ls1088a.o +obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o obj-y += ddr.o diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c new file mode 100644 index 0000000..5b5a89f --- /dev/null +++ b/board/freescale/ls1088a/ddr.c @@ -0,0 +1,215 @@ +/*
- ulong ddr_freq;
return;
return;
goto found;
pbsp++;
ddr_freq);
- } else {
pbsp->wrlvl_ctl_3);
+#else
- popts->half_strength_driver_enable = 1; #else
- popts->half_strength_driver_enable = 0; #endif
- popts->zq_en = 1;
+#else
You don't need the RAW timing support if you are using regular DIMM, unless you don't have I2C bus. And your DQ mapping is different. It seems wrong. [Ashish Kumar] Removed in v3
- .n_ranks = 1,
- .n_row_addr = 15,
- .n_col_addr = 10,
- .edc_config = 2,
- .taa_ps = 13500,
- .trcd_ps = 13500,
- .trp_ps = 13500,
- .tras_ps = 33000,
- .trc_ps = 46500,
- .tfaw_ps = 21000,
- .trrds_ps = 3700,
- .trrdl_ps = 5300,
- .tccdl_ps = 5355,
+} +#endif
- return dram_size;
- u32 n_ranks;
- u32 rank_gb;
- u32 clk_adjust;
- u32 wrlvl_start;
- u32 wrlvl_ctl_2;
- u32 wrlvl_ctl_3;
+board
+ascending order
+#else
What's the else for? [Ashish Kumar] Removed in v3
+#endif +};
- udimm0,
- int i, interface;
- u32 srds_s1, cfg;
- case 0x1D:
* MAC error.
break;
- default:
srds_s1);
break;
break;
default:
break;
+unsigned long long get_qixis_addr(void) {
- else
+0x30000000;
- return addr;
- char buf[64];
- u8 sw;
- int clock;
- switch (sw) {
- case 0:
puts("QSPI:");
puts("0\n");
else if (sw == 1)
puts("1\n");
else
puts("EMU\n");
break;
- default:
break;
* don't match.
+unsigned long get_board_sys_clk(void) {
return 83333333;
return 100000000;
return 125000000;
return 133333333;
return 150000000;
return 160000000;
return 166666666;
- return 66666666;
+unsigned long get_board_ddr_clk(void) {
return 100000000;
return 125000000;
return 133333333;
- return 66666666;
- int ret;
- if (ret) {
return ret;
- u8 reg;
- reg = 0x0;
- reg = 0x0c;
- reg |= 0x4;
- reg |= 0x24;
- reg &= 0x8f;
- reg &= 0x3f;
- reg |= 0x20;
- reg = 0x0;
- reg = 0xb0;
- reg = 0x90;
- reg = 0xb3;
- reg = 0xcd;
- u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE; #endif
- gd->env_addr = (ulong)&default_environment[0]; #endif
- out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK); #endif
- puts("\nDDR ");
- sec_init();
+} +#endif
- int offset;
- if (offset < 0)
- if (offset < 0) {
__func__, offset);
return;
- else
+} +#endif
+#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) {
- int err, i;
size[1] = gd->arch.resv_ram - base[1]; #endif
- if (err)
return err;
+#include <asm/arch/ls1088a_stream_id.h> #include <asm/arch/config.h>
+/* We need architecture specific misc initializations */ #define +CONFIG_ARCH_MISC_INIT
- SMP Definitinos
- CONFIG_SYS_TEXT_BASE is linked to 0x30000000 for booting */
+#ifndef __ASSEMBLY__ +unsigned long long get_qixis_addr(void); #endif
+/* Allow to overwrite serial and ethaddr */ #define +CONFIG_ENV_OVERWRITE
- " 0x580800000 \0"
Please stop using this copying. [Ashish Kumar] Fixed in v3
Why this? [Ashish Kumar] Because CONFIG_DISPLAY_BOARDINFO is reporting junk values Board: LS1088A-RDB, Board Arch: V0, Board version: @, boot from QSPI:0 FPGA: v0 (123456789:;<=>?), build 1541 on Wed Apr 10 07:15:23 1974
Correct value is Board: LS1088A-RDB, Board Arch: V1, Board version: A, boot from QSPI:1 FPGA: v1 (), build 1799 on Wed Sep 26 14:17:43 1973
+#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define +CONFIG_QIXIS_I2C_ACCESS #define SYS_NO_FLASH #undef CONFIG_CMD_IMLS +#endif
- CSPR_MSEL_NOR | \
- CSPR_V)
- CSPR_MSEL_NOR | \
- CSPR_V)
FTIM2_NOR_TWP(0x1))
+#ifndef SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #define +CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
| CSPR_V)
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_GPCM \
| CSPR_V)
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_GPCM \
| CSPR_V)
+/* QSPI device */ +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +/*#define CONFIG_SYS_FSL_ERRATUM_A009282 // move to layersacpe +kconfig*/ #endif
Why this? [Ashish Kumar] 1. I took clue from an earlier patches, commit b99ebaf9f01ebe864061818e00beb70cb1ddc635 Author: Alexander Graf agraf@suse.de Date: Thu Nov 17 01:03:02 2016 +0100
ls2080ardb: Convert to distro boot
Most new systems in U-Boot these days make use of the generic "distro" framework which allows a user to have U-Boot scan for a bootable OS on all available media types.
This patch extends the LS2080ARDB board to use that framework if the hard coded NOR flash location does not contain a bootable image.
Signed-off-by: Alexander Graf agraf@suse.de
2. Also on removing I get this error, so it seems it is required. include/config_distro_defaults.h:23:0: warning: "CONFIG_CMDLINE_EDITING" redefined #define CONFIG_CMDLINE_EDITING ^ In file included from include/configs/ls1088ardb.h:10:0, from include/config.h:7, from include/common.h:21, from common/bootm.c:9: include/configs/ls1088a_common.h:196:0: note: this is the location of the previous definition #define CONFIG_CMDLINE_EDITING 1
Curiously, did you verify distroboot? [Ashish Kumar] There is follow-up patch to introduce distro boot, tested on SCSI and MMC
York
This patch add support of LS1088AQDS platform.
The LS1088A QorIQTM Development System (QDS) is a high-performance computing, evaluation, and development platform that supports the LS1088A QorIQ Architecture processor.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com --- v2: Fix indentaion in commit msg
arch/arm/Kconfig | 11 + arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1088a-qds.dts | 70 ++++ board/freescale/ls1088a/Kconfig | 16 + board/freescale/ls1088a/MAINTAINERS | 10 +- board/freescale/ls1088a/Makefile | 1 + board/freescale/ls1088a/ddr.c | 119 +----- board/freescale/ls1088a/ddr.h | 9 +- board/freescale/ls1088a/eth_ls1088aqds.c | 650 +++++++++++++++++++++++++++++++ board/freescale/ls1088a/ls1088a.c | 106 ++++- board/freescale/ls1088a/ls1088a_qixis.h | 5 + configs/ls1088aqds_qspi_defconfig | 27 ++ configs/ls1088ardb_qspi_defconfig | 6 - include/configs/ls1088a_common.h | 8 +- include/configs/ls1088aqds.h | 422 ++++++++++++++++++++ 16 files changed, 1316 insertions(+), 147 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1088a-qds.dts create mode 100644 board/freescale/ls1088a/eth_ls1088aqds.c create mode 100644 configs/ls1088aqds_qspi_defconfig create mode 100644 include/configs/ls1088aqds.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a441cb3..a5a5927 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -883,6 +883,17 @@ config TARGET_LS2080A_SIMU development platform that supports the QorIQ LS2080A Layerscape Architecture processor.
+config TARGET_LS1088AQDS + bool "Support ls1088aqds" + select ARCH_LS1088A + select ARM64 + select ARMV8_MULTIENTRY + help + Support for NXP LS1088AQDS platform + The LS1088A Development System (QDS) is a high-performance + development platform that supports the QorIQ LS1088A + Layerscape Architecture processor. + config TARGET_LS2080AQDS bool "Support ls2080aqds" select ARCH_LS2080A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 630bb78..b3565a5 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -88,7 +88,7 @@ config PSCI_RESET depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && !TARGET_LS2080A_EMU && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ !TARGET_LS2080ARDB && !TARGET_LS1012AQDS && \ - !TARGET_LS1088ARDB && \ + !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5ac8ea3..2ec5c12 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -164,6 +164,7 @@ dtb-$(CONFIG_LS102XA) += ls1021a-qds-duart.dtb \ ls1021a-iot-duart.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb \ + fsl-ls1088a-qds.dtb \ fsl-ls1088a-rdb.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ diff --git a/arch/arm/dts/fsl-ls1088a-qds.dts b/arch/arm/dts/fsl-ls1088a-qds.dts new file mode 100644 index 0000000..9b7bef4 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds.dts @@ -0,0 +1,70 @@ +/* + * NXP ls1088a QDS board device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls1088a.dtsi" + +/ { + model = "NXP Layerscape 1088a QDS Board"; + compatible = "fsl,ls1088a-qds", "fsl,ls1088a"; + aliases { + spi0 = &qspi; + spi1 = &dspi; + }; +}; + +&dspi { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3500000>; + reg = <2>; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; diff --git a/board/freescale/ls1088a/Kconfig b/board/freescale/ls1088a/Kconfig index a4d8223..1ada661 100644 --- a/board/freescale/ls1088a/Kconfig +++ b/board/freescale/ls1088a/Kconfig @@ -1,3 +1,19 @@ +if TARGET_LS1088AQDS + +config SYS_BOARD + default "ls1088a" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1088aqds" + +endif + if TARGET_LS1088ARDB
config SYS_BOARD diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS index 1abbf91..e1e6d4b 100644 --- a/board/freescale/ls1088a/MAINTAINERS +++ b/board/freescale/ls1088a/MAINTAINERS @@ -5,5 +5,11 @@ S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088ardb.h F: configs/ls1088ardb_qspi_defconfig -F: configs/ls1088ardb_sdcard_defconfig -F: configs/ls1088ardb_sdcard_qspi_defconfig + +LS1088AQDS BOARD +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Ashish Kumar Ashish.Kumar@nxp.com +S: Maintained +F: board/freescale/ls1088a/ +F: include/configs/ls1088aqds.h +F: configs/ls1088aqds_qspi_defconfig diff --git a/board/freescale/ls1088a/Makefile b/board/freescale/ls1088a/Makefile index e997cf1..bdcce9e 100644 --- a/board/freescale/ls1088a/Makefile +++ b/board/freescale/ls1088a/Makefile @@ -6,4 +6,5 @@
obj-y += ls1088a.o obj-$(CONFIG_TARGET_LS1088ARDB) += eth_ls1088ardb.o +obj-$(CONFIG_TARGET_LS1088AQDS) += eth_ls1088aqds.o obj-y += ddr.o diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 5b5a89f..872a178 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -25,19 +25,14 @@ void fsl_ddr_board_options(memctl_options_t *popts, if (!pdimm->n_ranks) return;
- /* - * we use identical timing for all slots. If needed, change the code - * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; - */ - pbsp = udimms[ctrl_num]; + pbsp = udimms[0];
/* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr * freqency and n_banks specified in board_specific_parameters table. */ ddr_freq = get_ddr_freq(0) / 1000000; while (pbsp->datarate_mhz_high) { - if (pbsp->n_ranks == pdimm->n_ranks && - (pdimm->rank_density >> 30) >= pbsp->rank_gb) { + if (pbsp->n_ranks == pdimm->n_ranks) { if (ddr_freq <= pbsp->datarate_mhz_high) { popts->clk_adjust = pbsp->clk_adjust; popts->wrlvl_start = pbsp->wrlvl_start; @@ -63,51 +58,18 @@ void fsl_ddr_board_options(memctl_options_t *popts, panic("DIMM is not supported by this board"); } found: -#if defined(CONFIG_EMU) debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, wrlvl_ctrl_3 0x%x\n", pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, pbsp->wrlvl_ctl_3); -#else - debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", - pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); - - pdimm[0].dq_mapping[0] = 0x15; - pdimm[0].dq_mapping[1] = 0x35; - pdimm[0].dq_mapping[2] = 0x0b; - pdimm[0].dq_mapping[3] = 0x2c; - pdimm[0].dq_mapping[4] = 0x15; - pdimm[0].dq_mapping[5] = 0x35; - pdimm[0].dq_mapping[6] = 0x15; - pdimm[0].dq_mapping[7] = 0x35; - pdimm[0].dq_mapping[8] = 0xc; - pdimm[0].dq_mapping[9] = 0; - pdimm[0].dq_mapping[10] = 0; - pdimm[0].dq_mapping[11] = 0; - pdimm[0].dq_mapping[12] = 0; - pdimm[0].dq_mapping[13] = 0; - pdimm[0].dq_mapping[14] = 0; - pdimm[0].dq_mapping[15] = 0; - pdimm[0].dq_mapping[16] = 0; - pdimm[0].dq_mapping[17] = 0; - - /* force DDR bus width to 32 bits */ - popts->data_bus_width = 1; + + popts->data_bus_width = 0; /* 64b data bus */ popts->otf_burst_chop_en = 0; popts->burst_length = DDR_BL8; - popts->bstopre = 0; /* enable auto precharge */ -#endif + popts->bstopre = 0; /* enable auto precharge */
- /* - * Factors to consider for half-strength driver enable: - * - number of DIMMs installed - */ -#if defined(CONFIG_EMU) - popts->half_strength_driver_enable = 1; -#else popts->half_strength_driver_enable = 0; -#endif /* * Write leveling override */ @@ -122,10 +84,10 @@ found: /* Enable ZQ calibration */ popts->zq_en = 1;
-#if defined(CONFIG_EMU) +#if defined(CONFIG_TARGET_LS1088AQDS) popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | - DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ + DDR_CDR2_VREF_TRAIN_EN | DDR_CDR2_VREF_RANGE_2; #else popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_60ohm); popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_100ohm) | @@ -134,73 +96,6 @@ found: popts->cpo_sample = 0x6d; }
-#ifdef CONFIG_SYS_DDR_RAW_TIMING -dimm_params_t ddr_raw_timing = { - .n_ranks = 1, - .rank_density = 4294967296u, - .capacity = 4294967296u, - .primary_sdram_width = 64, - .ec_sdram_width = 8, - .registered_dimm = 0, - .mirrored_dimm = 1, - .n_row_addr = 15, - .n_col_addr = 10, - .bank_addr_bits = 0, - .bank_group_bits = 2, - .edc_config = 2, - .burst_lengths_bitmask = 0x0c, - - .tckmin_x_ps = 938, - .tckmax_ps = 1500, - .caslat_x = 0x000DFA00, - .taa_ps = 13500, - .trcd_ps = 13500, - .trp_ps = 13500, - .tras_ps = 33000, - .trc_ps = 46500, - .trfc1_ps = 260000, - .trfc2_ps = 160000, - .trfc4_ps = 110000, - .tfaw_ps = 21000, - .trrds_ps = 3700, - .trrdl_ps = 5300, - .tccdl_ps = 5355, - .refresh_rate_ps = 7800000, - .dq_mapping[0] = 0x00, - .dq_mapping[1] = 0x00, - .dq_mapping[2] = 0x00, - .dq_mapping[3] = 0x00, - .dq_mapping[4] = 0x00, - .dq_mapping[5] = 0x00, - .dq_mapping[6] = 0x00, - .dq_mapping[7] = 0x00, - .dq_mapping[8] = 0x00, - .dq_mapping[9] = 0x00, - .dq_mapping[10] = 0x00, - .dq_mapping[11] = 0x00, - .dq_mapping[12] = 0x00, - .dq_mapping[13] = 0x00, - .dq_mapping[14] = 0x00, - .dq_mapping[15] = 0x00, - .dq_mapping[16] = 0x00, - .dq_mapping[17] = 0x00, - .dq_mapping_ors = 1, -}; - -int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, - unsigned int controller_number, - unsigned int dimm_number) -{ - static const char dimm_model[] = "Fixed DDR on board"; - - if (dimm_number == 0) - memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); - memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); - memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); - - return 0; -} -#endif
phys_size_t initdram(int board_type) { diff --git a/board/freescale/ls1088a/ddr.h b/board/freescale/ls1088a/ddr.h index 1658c22..bfc5dae 100644 --- a/board/freescale/ls1088a/ddr.h +++ b/board/freescale/ls1088a/ddr.h @@ -33,9 +33,14 @@ static const struct board_specific_parameters udimm0[] = { {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,}, {} +#elif defined(CONFIG_TARGET_LS1088AQDS) + {2, 1666, 0, 8, 8, 0x0A0A0C0E, 0x0F10110C,}, + {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 4, 9, 0x0A0C0D11, 0x1214150E,}, + {} #else - {2, 2140, 0, 4, 4, 0x0, 0x0}, - {1, 2140, 0, 4, 4, 0x0, 0x0}, + {2, 2140, 0, 8, 4, 0x0, 0x0}, + {1, 2140, 0, 8, 4, 0x0, 0x0}, {} #endif }; diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c new file mode 100644 index 0000000..3e78ac7 --- /dev/null +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -0,0 +1,650 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> +#include <hwconfig.h> +#include <fsl_mdio.h> +#include <malloc.h> +#include <fm_eth.h> +#include <i2c.h> +#include <miiphy.h> +#include <fsl-mc/ldpaa_wriop.h> + +#include "../common/qixis.h" + +#include "ls1088a_qixis.h" + +#define MC_BOOT_ENV_VAR "mcinitcmd" + +#ifdef CONFIG_FSL_MC_ENET + +#define SFP_TX 0 + + /* - In LS1088A A there are only 16 SERDES lanes, spread across 2 SERDES banks. + * Bank 1 -> Lanes A, B, C, D, + * Bank 2 -> Lanes A,B, C, D, + */ + + /* Mapping of 8 SERDES lanes to LS1088A QDS board slots. A value of '0' here + * means that the mapping must be determined dynamically, or that the lane + * maps to something other than a board slot. + */ + +static u8 lane_to_slot_fsm1[] = { + 0, 0, 0, 0, 0, 0, 0, 0 +}; + +/* On the Vitesse VSC8234XHG SGMII riser card there are 4 SGMII PHYs + * housed. + */ + +static int xqsgii_riser_phy_addr[] = { + XQSGMII_CARD_PHY1_PORT0_ADDR, + XQSGMII_CARD_PHY2_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT0_ADDR, + XQSGMII_CARD_PHY4_PORT0_ADDR, + XQSGMII_CARD_PHY3_PORT2_ADDR, + XQSGMII_CARD_PHY1_PORT2_ADDR, + XQSGMII_CARD_PHY4_PORT2_ADDR, + XQSGMII_CARD_PHY2_PORT2_ADDR, +}; + +static int sgmii_riser_phy_addr[] = { + SGMII_CARD_PORT1_PHY_ADDR, + SGMII_CARD_PORT2_PHY_ADDR, + SGMII_CARD_PORT3_PHY_ADDR, + SGMII_CARD_PORT4_PHY_ADDR, +}; + +/* Slot2 does not have EMI connections */ +#define EMI_NONE 0xFF +#define EMI1_RGMII1 0 +#define EMI1_RGMII2 1 +#define EMI1_SLOT1 2 + +static const char * const mdio_names[] = { + "LS1088A_QDS_MDIO0", + "LS1088A_QDS_MDIO1", + "LS1088A_QDS_MDIO2", + DEFAULT_WRIOP_MDIO2_NAME, +}; + +struct ls1088a_qds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void sgmii_configure_repeater(int dpmac) +{ + struct mii_dev *bus; + uint8_t a = 0xf; + int i, j, ret; + unsigned short value; + const char *dev = "LS1088A_QDS_MDIO2"; + int i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b}; + int i2c_phy_addr = 0; + int phy_addr = 0; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + switch (dpmac) { + case 1: + i2c_phy_addr = i2c_addr[1]; + phy_addr = 4; + break; + case 2: + i2c_phy_addr = i2c_addr[0]; + phy_addr = 0; + break; + case 3: + i2c_phy_addr = i2c_addr[3]; + phy_addr = 0xc; + break; + case 7: + i2c_phy_addr = i2c_addr[2]; + phy_addr = 8; + break; + } + + /* Check the PHY status */ + ret = miiphy_set_current_dev(dev); + if (ret > 0) + goto error; + + bus = mdio_get_current_dev(); + debug("Reading from bus %s\n", bus->name); + + ret = miiphy_write(dev, phy_addr, 0x1f, 3); + if (ret > 0) + goto error; + + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + mdelay(10); + + if ((value & 0xfff) == 0x401) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d:PHY is ..... Configured\n", dpmac); + return; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_phy_addr, 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_phy_addr, 8, 1, &a, 1); + + i2c_write(i2c_phy_addr, 0xf, 1, + &ch_a_eq[i], 1); + i2c_write(i2c_phy_addr, 0x11, 1, + &ch_a_ctl2[j], 1); + + i2c_write(i2c_phy_addr, 0x16, 1, + &ch_b_eq[i], 1); + i2c_write(i2c_phy_addr, 0x18, 1, + &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_phy_addr, 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + + if ((value & 0xfff) == 0x401) { + printf("DPMAC %d :PHY is configured ", + dpmac); + printf("after setting repeater 0x%x\n", + value); + i = 5; + j = 5; + } else { + printf("DPMAC %d :PHY is failed to ", + dpmac); + printf("configure the repeater 0x%x\n", value); + } + } + } + miiphy_write(dev, phy_addr, 0x1f, 0); +error: + if (ret) + printf("DPMAC %d ..... FAILED to configure PHY\n", dpmac); + return; +} + +static void qsgmii_configure_repeater(int dpmac) +{ + uint8_t a = 0xf; + int i, j; + int i2c_phy_addr = 0; + int phy_addr = 0; + int i2c_addr[] = {0x58, 0x59, 0x5a, 0x5b}; + + uint8_t ch_a_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_a_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + uint8_t ch_b_eq[] = {0x1, 0x2, 0x3, 0x7}; + uint8_t ch_b_ctl2[] = {0x81, 0x82, 0x83, 0x84}; + + const char *dev = mdio_names[EMI1_SLOT1]; + int ret = 0; + unsigned short value; + + /* Set I2c to Slot 1 */ + i2c_write(0x77, 0, 0, &a, 1); + + switch (dpmac) { + case 7: + case 8: + case 9: + case 10: + i2c_phy_addr = i2c_addr[2]; + phy_addr = 8; + break; + + case 3: + case 4: + case 5: + case 6: + i2c_phy_addr = i2c_addr[3]; + phy_addr = 0xc; + break; + } + + /* Check the PHY status */ + ret = miiphy_set_current_dev(dev); + ret = miiphy_write(dev, phy_addr, 0x1f, 3); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + mdelay(10); + if ((value & 0xf) == 0xf) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d :PHY is ..... Configured\n", dpmac); + return; + } + + for (i = 0; i < 4; i++) { + for (j = 0; j < 4; j++) { + a = 0x18; + i2c_write(i2c_phy_addr, 6, 1, &a, 1); + a = 0x38; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + a = 0x4; + i2c_write(i2c_phy_addr, 8, 1, &a, 1); + + i2c_write(i2c_phy_addr, 0xf, 1, &ch_a_eq[i], 1); + i2c_write(i2c_phy_addr, 0x11, 1, &ch_a_ctl2[j], 1); + + i2c_write(i2c_phy_addr, 0x16, 1, &ch_b_eq[i], 1); + i2c_write(i2c_phy_addr, 0x18, 1, &ch_b_ctl2[j], 1); + + a = 0x14; + i2c_write(i2c_phy_addr, 0x23, 1, &a, 1); + a = 0xb5; + i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); + a = 0x20; + i2c_write(i2c_phy_addr, 4, 1, &a, 1); + mdelay(100); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(1); + ret = miiphy_read(dev, phy_addr, 0x11, &value); + if (ret > 0) + goto error; + mdelay(10); + if ((value & 0xf) == 0xf) { + miiphy_write(dev, phy_addr, 0x1f, 0); + printf("DPMAC %d :PHY is ..... Configured\n", + dpmac); + return; + } + } + } +error: + printf("DPMAC %d :PHY ..... FAILED to configure PHY\n", dpmac); + return; +} + +static const char *ls1088a_qds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name = ls1088a_qds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +static void ls1088a_qds_enable_SFP_TX(u8 muxval) +{ + u8 brdcfg9; + + brdcfg9 = QIXIS_READ(brdcfg[9]); + brdcfg9 &= ~BRDCFG9_SFPTX_MASK; + brdcfg9 |= (muxval << BRDCFG9_SFPTX_SHIFT); + QIXIS_WRITE(brdcfg[9], brdcfg9); +} + +static void ls1088a_qds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + + if (muxval <= 5) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int ls1088a_qds_mdio_read(struct mii_dev *bus, int addr, + int devad, int regnum) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + ls1088a_qds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int ls1088a_qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + ls1088a_qds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int ls1088a_qds_mdio_reset(struct mii_dev *bus) +{ + struct ls1088a_qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int ls1088a_qds_mdio_init(char *realbusname, u8 muxval) +{ + struct ls1088a_qds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate ls1088a_qds MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate ls1088a_qds private data\n"); + free(bus); + return -1; + } + + bus->read = ls1088a_qds_mdio_read; + bus->write = ls1088a_qds_mdio_write; + bus->reset = ls1088a_qds_mdio_reset; + sprintf(bus->name, ls1088a_qds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + + return mdio_register(bus); +} + +/* + * Initialize the dpmac_info array. + * + */ +static void initialize_dpmac_to_slot(void) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x12: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI1_SLOT1 - 1; + break; + case 0x15: + case 0x1D: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI_NONE; + lane_to_slot_fsm1[3] = EMI_NONE; + break; + case 0x1E: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI_NONE; + break; + case 0x3A: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + lane_to_slot_fsm1[0] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[1] = EMI_NONE; + lane_to_slot_fsm1[2] = EMI1_SLOT1 - 1; + lane_to_slot_fsm1[3] = EMI1_SLOT1 - 1; + break; + + default: + printf("%s qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", + __func__, serdes1_prtcl); + break; + } +} + +void ls1088a_handle_phy_interface_sgmii(int dpmac_id) +{ + struct mii_dev *bus; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + int *riser_phy_addr; + char *env_hwconfig = getenv("hwconfig"); + + if (hwconfig_f("xqsgmii", env_hwconfig)) + riser_phy_addr = &xqsgii_riser_phy_addr[0]; + else + riser_phy_addr = &sgmii_riser_phy_addr[0]; + + switch (serdes1_prtcl) { + case 0x12: + case 0x15: + case 0x1E: + case 0x3A: + switch (dpmac_id) { + case 1: + wriop_set_phy_address(dpmac_id, riser_phy_addr[1]); + break; + case 2: + wriop_set_phy_address(dpmac_id, riser_phy_addr[0]); + break; + case 3: + wriop_set_phy_address(dpmac_id, riser_phy_addr[3]); + break; + case 7: + wriop_set_phy_address(dpmac_id, riser_phy_addr[2]); + break; + default: + printf("WRIOP: Wrong DPMAC%d set to SGMII", dpmac_id); + break; + } + break; + default: + printf("%s qds: WRIOP: Unsupported SerDes1 Protocol 0x%02x\n", + __func__, serdes1_prtcl); + return; + } + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); +} + +void ls1088a_handle_phy_interface_qsgmii(int dpmac_id) +{ + struct mii_dev *bus; + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x1D: + case 0x1E: + switch (dpmac_id) { + case 3: + case 4: + case 5: + case 6: + wriop_set_phy_address(dpmac_id, dpmac_id + 9); + break; + case 7: + case 8: + case 9: + case 10: + wriop_set_phy_address(dpmac_id, dpmac_id + 1); + break; + } + + dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; + bus = mii_dev_for_muxval(EMI1_SLOT1); + wriop_set_mdio(dpmac_id, bus); + break; + default: + printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + serdes1_prtcl); + break; + } +} + +void ls1088a_handle_phy_interface_xsgmii(int i) +{ + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 serdes1_prtcl, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + serdes1_prtcl = serdes_get_number(FSL_SRDS_1, cfg); + + switch (serdes1_prtcl) { + case 0x15: + case 0x1D: + case 0x1E: + wriop_set_phy_address(i, i + 26); + ls1088a_qds_enable_SFP_TX(SFP_TX); + break; + default: + printf("qds: WRIOP: Unsupported SerDes Protocol 0x%02x\n", + serdes1_prtcl); + break; + } +} +#endif + +int board_eth_init(bd_t *bis) +{ + int error = 0, i; + char *mc_boot_env_var; +#ifdef CONFIG_FSL_MC_ENET + struct memac_mdio_info *memac_mdio0_info; + char *env_hwconfig = getenv("hwconfig"); + + initialize_dpmac_to_slot(); + + memac_mdio0_info = (struct memac_mdio_info *)malloc( + sizeof(struct memac_mdio_info)); + memac_mdio0_info->regs = + (struct memac_mdio_controller *) + CONFIG_SYS_FSL_WRIOP1_MDIO1; + memac_mdio0_info->name = DEFAULT_WRIOP_MDIO1_NAME; + + /* Register the real MDIO1 bus */ + fm_memac_mdio_init(bis, memac_mdio0_info); + + /* Register the muxing front-ends to the MDIO buses */ + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_RGMII1); + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_RGMII2); + ls1088a_qds_mdio_init(DEFAULT_WRIOP_MDIO1_NAME, EMI1_SLOT1); + + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + switch (wriop_get_enet_if(i)) { + case PHY_INTERFACE_MODE_QSGMII: + ls1088a_handle_phy_interface_qsgmii(i); + break; + case PHY_INTERFACE_MODE_SGMII: + ls1088a_handle_phy_interface_sgmii(i); + break; + case PHY_INTERFACE_MODE_XGMII: + ls1088a_handle_phy_interface_xsgmii(i); + break; + default: + break; + + if (i == 16) + i = NUM_WRIOP_PORTS; + } + } + + mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); + error = cpu_eth_init(bis); + + if (hwconfig_f("xqsgmii", env_hwconfig)) { + for (i = WRIOP1_DPMAC1; i < NUM_WRIOP_PORTS; i++) { + switch (wriop_get_enet_if(i)) { + case PHY_INTERFACE_MODE_QSGMII: + qsgmii_configure_repeater(i); + break; + case PHY_INTERFACE_MODE_SGMII: + sgmii_configure_repeater(i); + break; + default: + break; + } + + if (i == 16) + i = NUM_WRIOP_PORTS; + } + } +#endif + error = pci_eth_init(bis); + return error; +} diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 151d56c..e2ba23c 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -49,11 +49,18 @@ int checkboard(void) "100 separate SSCG"}; int clock;
+#ifdef CONFIG_TARGET_LS1088AQDS + printf("Board: LS1088A-QDS, "); +#else printf("Board: LS1088A-RDB, "); - +#endif sw = QIXIS_READ(arch); printf("Board Arch: V%d, ", sw >> 4); +#ifdef CONFIG_TARGET_LS1088AQDS printf("Board version: %c, boot from ", (sw & 0xf) + 'A' - 1); +#else + printf("Board version: %c, boot from ", (sw & 0xf) + 'A'); +#endif
@@ -64,7 +71,27 @@ int checkboard(void) puts("SD card\n"); #endif switch (sw) { +#ifdef CONFIG_TARGET_LS1088AQDS case 0: + case 1: + case 2: + case 3: + case 4: + case 5: + case 6: + case 7: + printf("vBank: %d\n", sw); + break; + case 8: + puts("PromJet\n"); + break; + case 15: + puts("IFCCard\n"); + break; + case 14: +#else + case 0: +#endif puts("QSPI:"); sw = QIXIS_READ(brdcfg[0]); sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT; @@ -81,11 +108,15 @@ int checkboard(void) break; }
+#ifdef CONFIG_TARGET_LS1088AQDS printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); /* the timestamp string contains "\n" at the end */ printf(" on %s", qixis_read_time(buf)); +#else + printf("CPLD: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); +#endif
/* * Display the actual SERDES reference clocks as configured by the @@ -113,9 +144,13 @@ int checkboard(void)
bool if_board_diff_clk(void) { +#ifdef CONFIG_TARGET_LS1088AQDS + u8 diff_conf = QIXIS_READ(brdcfg[11]); + return diff_conf & 0x40; +#else u8 diff_conf = QIXIS_READ(dutcfg[11]); - return diff_conf & 0x80; +#endif }
unsigned long get_board_sys_clk(void) @@ -177,7 +212,7 @@ void board_retimer_init(void) { u8 reg;
- /* Retimer is connected to I2C1_CH7_CH5 */ + /* Retimer is connected to I2C1_CH5 */ select_i2c_ch_pca9547(I2C_MUX_CH5);
/* Access to Control/Shared register */ @@ -197,26 +232,10 @@ void board_retimer_init(void) reg |= 0x4; i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1);
- /* Enable override divider select and Enable Override Output Mux */ - i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1); - reg |= 0x24; - i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1); - - /* Select VCO Divider to full rate (000) */ - i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); - reg &= 0x8f; - i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); - - /* Selects active PFD MUX Input as Re-timed Data (001) */ - i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); - reg &= 0x3f; - reg |= 0x20; - i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); - /* Set data rate as 10.3125 Gbps */ - reg = 0x0; + reg = 0x90; i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); - reg = 0xb0; + reg = 0xb3; i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); reg = 0x90; i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); @@ -225,6 +244,51 @@ void board_retimer_init(void) reg = 0xcd; i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1);
+ /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); + reg &= 0x0f; + reg |= 0x70; + i2c_write(I2C_RETIMER_ADDR, 0x2F, 1, ®, 1); + +#ifdef CONFIG_TARGET_LS1088AQDS + /* Retimer is connected to I2C1_CH5 */ + select_i2c_ch_pca9547(I2C_MUX_CH5); + + /* Access to Control/Shared register */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); + + /* Read device revision and ID */ + i2c_read(I2C_RETIMER_ADDR2, 1, 1, ®, 1); + debug("Retimer version id = 0x%x\n", reg); + + /* Enable Broadcast. All writes target all channel register sets */ + reg = 0x0c; + i2c_write(I2C_RETIMER_ADDR2, 0xff, 1, ®, 1); + + /* Reset Channel Registers */ + i2c_read(I2C_RETIMER_ADDR2, 0, 1, ®, 1); + reg |= 0x4; + i2c_write(I2C_RETIMER_ADDR2, 0, 1, ®, 1); + + /* Set data rate as 10.3125 Gbps */ + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR2, 0x60, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR2, 0x61, 1, ®, 1); + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR2, 0x62, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR2, 0x63, 1, ®, 1); + reg = 0xcd; + i2c_write(I2C_RETIMER_ADDR2, 0x64, 1, ®, 1); + + /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); + reg &= 0x0f; + reg |= 0x70; + i2c_write(I2C_RETIMER_ADDR2, 0x2F, 1, ®, 1); +#endif /*return the default channel*/ select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); } diff --git a/board/freescale/ls1088a/ls1088a_qixis.h b/board/freescale/ls1088a/ls1088a_qixis.h index 9757d1b..4790461 100644 --- a/board/freescale/ls1088a/ls1088a_qixis.h +++ b/board/freescale/ls1088a/ls1088a_qixis.h @@ -31,4 +31,9 @@ #define QIXIS_SDCLK1_165 0x2 #define QIXIS_SDCLK1_100_SP 0x3
+#define BRDCFG4_EMISEL_MASK 0xE0 +#define BRDCFG4_EMISEL_SHIFT 5 +#define BRDCFG9_SFPTX_MASK 0x10 +#define BRDCFG9_SFPTX_SHIFT 4 + #endif diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig new file mode 100644 index 0000000..3511d92 --- /dev/null +++ b/configs/ls1088aqds_qspi_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088AQDS=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y + +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 223d581..a0559a7 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -9,19 +9,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" -CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y -CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 5d16c78..5432e4f 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -33,9 +33,6 @@ #define CONFIG_SPI_FLASH_BAR #define CONFIG_SKIP_LOWLEVEL_INIT
-/* Flat Device Tree Definitions */ -/* #define CONFIG_OF_LIBFDT */ - #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */
#define CONFIG_VERY_BIG_RAM @@ -139,6 +136,11 @@ unsigned long long get_qixis_addr(void);
/* Command line configuration */ #define CONFIG_CMD_ENV +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_MII +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h new file mode 100644 index 0000000..00c91e2 --- /dev/null +++ b/include/configs/ls1088aqds.h @@ -0,0 +1,422 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1088A_QDS_H +#define __LS1088A_QDS_H + +#include "ls1088a_common.h" + +#ifdef CONFIG_QSPI_BOOT +#define CONFIG_DISPLAY_BOARDINFO_LATE +#else +#define CONFIG_DISPLAY_BOARDINFO +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (2 * 1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_QIXIS_I2C_ACCESS +#define SYS_NO_FLASH +#define CONFIG_SYS_I2C_EARLY_INIT /* swap get_board_sys_clk else part here*/ +#undef CONFIG_CMD_IMLS +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 +#else +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() +#endif + +#define COUNTER_FREQUENCY_REAL (CONFIG_SYS_CLK_FREQ/4) +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 + +#define CONFIG_DDR_SPD +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + + +/* + * IFC Definitions + */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +#define CONFIG_SYS_NOR_AMASK_EARLY IFC_AMASK(64*1024*1024) + +#define CONFIG_SYS_NOR0_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR0_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH1_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EARLY \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH1_BASE_PHYS_EARLY) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(12) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1a) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#ifndef SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE,\ + CONFIG_SYS_FLASH_BASE + 0x40000000} +#endif +#endif + +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_MAX_ECCPOS 256 +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#define CONFIG_FSL_QIXIS +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_QMAP_MASK 0xe0 +#define QIXIS_QMAP_SHIFT 5 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x0e +#define QIXIS_LBMAP_ALTBANK 0x2e +#define QIXIS_LBMAP_SD 0x00 +#define QIXIS_LBMAP_SD_QSPI 0x0e +#define QIXIS_LBMAP_QSPI 0x0e +#define QIXIS_RCW_SRC_SD 0x40 +#define QIXIS_RCW_SRC_QSPI 0x62 +#define QIXIS_RST_CTL_RESET 0x41 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_RST_FORCE_MEM 0x01 +#define QIXIS_STAT_PRES1 0xb +#define QIXIS_SDID_MASK 0x07 +#define QIXIS_ESDHC_NO_ADAPTER 0x7 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS_EARLY) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define SYS_FPGA_CSPR_FINAL (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) + +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) +#else +#define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(12) +#endif +/* QIXIS Timing parameters*/ +#define SYS_FPGA_CS_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define SYS_FPGA_CS_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define SYS_FPGA_CS_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0x3E)) +#define SYS_FPGA_CS_FTIM3 0x0 + +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR2_FINAL SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK2 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS2_FTIM0 SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 SYS_FPGA_CS_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY +#define CONFIG_SYS_CSPR0_FINAL CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR_EARLY +#define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK_EARLY +#define CONFIG_SYS_AMASK1_FINAL CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_CSPR3_FINAL CONFIG_SYS_FPGA_CSPR_FINAL +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_CS_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_CS_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_CS_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_CS_FTIM3 +#endif + +#define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 5000 + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_RETIMER_ADDR2 0x19 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH5 0xD + +/* +* RTC configuration +*/ +#define RTC +#define CONFIG_RTC_PCF8563 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 3*/ +#define CONFIG_CMD_DATE + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* QSPI device */ +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_FSL_QSPI +#define CONFIG_SPI_FLASH_SPANSION +#define FSL_QSPI_FLASH_SIZE (1 << 26) +#define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SYS_FSL_QSPI_AHB +#endif + +#ifdef CONFIG_FSL_DSPI +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_SST +#define CONFIG_SPI_FLASH_EON +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#endif +#endif + +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_FSL_MEMAC + +/* MMC */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_ESDHC_DETECT_QUIRK ((readb(QIXIS_BASE + QIXIS_STAT_PRES1) & \ + QIXIS_SDID_MASK) != QIXIS_ESDHC_NO_ADAPTER) + +/* Initial environment variables */ +#if defined(CONFIG_QSPI_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1100000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=sf probe 0:0;sf read 0x80000000 0x300000 0x100000;" \ + "sf read 0x80100000 0x800000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#else /* NOR BOOT */ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x1100000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "mcinitcmd=fsl_mc start mc 0x580300000 0x580800000\0" \ + "sf read 0x80100000 0x800000 0x100000;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" +#endif + +#ifdef CONFIG_FSL_MC_ENET +#define CONFIG_FSL_MEMAC +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_TERANETICS +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1d +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F + +#define XQSGMII_CARD_PHY1_PORT0_ADDR 0x0 +#define XQSGMII_CARD_PHY1_PORT1_ADDR 0x1 +#define XQSGMII_CARD_PHY1_PORT2_ADDR 0x2 +#define XQSGMII_CARD_PHY1_PORT3_ADDR 0x3 +#define XQSGMII_CARD_PHY2_PORT0_ADDR 0x4 +#define XQSGMII_CARD_PHY2_PORT1_ADDR 0x5 +#define XQSGMII_CARD_PHY2_PORT2_ADDR 0x6 +#define XQSGMII_CARD_PHY2_PORT3_ADDR 0x7 +#define XQSGMII_CARD_PHY3_PORT0_ADDR 0x8 +#define XQSGMII_CARD_PHY3_PORT1_ADDR 0x9 +#define XQSGMII_CARD_PHY3_PORT2_ADDR 0xa +#define XQSGMII_CARD_PHY3_PORT3_ADDR 0xb +#define XQSGMII_CARD_PHY4_PORT0_ADDR 0xc +#define XQSGMII_CARD_PHY4_PORT1_ADDR 0xd +#define XQSGMII_CARD_PHY4_PORT2_ADDR 0xe +#define XQSGMII_CARD_PHY4_PORT3_ADDR 0xf + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "DPMAC1@xgmii" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#endif + +#undef CONFIG_CMDLINE_EDITING +#include <config_distro_defaults.h> +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(MMC, mmc, 0) \ + func(SCSI, scsi, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1088A_QDS_H */
- bool "Support ls1088aqds"
- select ARCH_LS1088A
- select ARM64
- select ARMV8_MULTIENTRY
- help
!TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \!TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \
- fsl-ls1088a-qds.dtb \ fsl-ls1088a-rdb.dtb
- NXP ls1088a QDS board device tree source
- Copyright 2017 NXP
+/dts-v1/;
- model = "NXP Layerscape 1088a QDS Board";
- compatible = "fsl,ls1088a-qds", "fsl,ls1088a";
- aliases {
spi0 = &qspi;
spi1 = &dspi;
+&dspi {
- bus-num = <0>;
- status = "okay";
- dflash0: n25q128a {
#size-cells = <1>;
reg = <0>;
- dflash1: sst25wf040b {
#size-cells = <1>;
reg = <1>;
- dflash2: en25s64 {
#size-cells = <1>;
reg = <2>;
+&qspi {
- bus-num = <0>;
- status = "okay";
- qflash0: s25fs512s@0 {
#size-cells = <1>;
reg = <0>;
- qflash1: s25fs512s@1 {
#size-cells = <1>;
reg = <1>;
+config SYS_BOARD
- default "ls1088a"
+config SYS_VENDOR
- default "freescale"
+config SYS_SOC
- default "fsl-layerscape"
- default "ls1088aqds"
+endif
These two lines shouldn't be added in previous patch.
- pbsp = udimms[0];
Please fix it in previous patch.
Guess you don't really need emulator support. Please remove from previous patch.
- popts->data_bus_width = 0; /* 64b data bus */ popts->otf_burst_chop_en = 0; popts->burst_length = DDR_BL8;
-#endif
- .n_ranks = 1,
- .n_row_addr = 15,
- .n_col_addr = 10,
- .edc_config = 2,
- .taa_ps = 13500,
- .trcd_ps = 13500,
- .trp_ps = 13500,
- .tras_ps = 33000,
- .trc_ps = 46500,
- .tfaw_ps = 21000,
- .trrds_ps = 3700,
- .trrdl_ps = 5300,
- .tccdl_ps = 5355,
I am going to stop here. Please respin the patch set.
York
The QorIQ LS1088A processor is built on the Layerscape architecture combining eight ARM A53 processor cores with advanced, high-performance datapath acceleration and networks, peripheral interfaces required for networking, wireless infrastructure, and general-purpose embedded applications.
LS1088A is compliant to the Layerscape Chassis Generation 3.
Features summary:
- Eight 32-bit / 64-bit ARM v8 Cortex-A53 CPUs
- Cores are in 2 cluster of 4-cores each
- Cache coherent interconnect (CCI-400)
- One 64-bit DDR4 SDRAM memory controller with ECC
- Data path acceleration architecture 2.0 (DPAA2)
- Ethernet interfaces: SGMIIs, RGMIIs, QSGMIIs, XFIs
- QSPI, IFC, 3 PCIe, 1 SATA, 2 USB, 1 SDXC, 2 DUARTs etc
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com
v2: Fix indentaion in commit msg Separate RDB and Si specific file Move Macros to Kconfig
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 44 ++++++- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 1 + .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 10 ++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 6 +- arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 126 +++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 5 + arch/arm/dts/fsl-ls1088a.dtsi | 78 +++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 62 +++++++++- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 + .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 3 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 11 ++ .../asm/arch-fsl-layerscape/ls1088a_stream_id.h | 57 ++++++++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 + drivers/ddr/fsl/util.c | 2 +- drivers/net/ldpaa_eth/Makefile | 1 + drivers/net/ldpaa_eth/ls1088a.c | 87 ++++++++++++++ 17 files changed, 494 insertions(+), 11 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c create mode 100644 arch/arm/dts/fsl-ls1088a.dtsi create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/ls1088a_stream_id.h create mode 100644 drivers/net/ldpaa_eth/ls1088a.c
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index fbb95cd..a3e8499 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -49,6 +49,29 @@ config ARCH_LS1046A select BOARD_EARLY_INIT_F select SYS_FSL_HAS_CCI400
+config ARCH_LS1088A
- bool
- select ARMV8_SET_SMPEN
- select FSL_LSCH3
- select SYS_FSL_DDR
- select SYS_FSL_DDR_LE
- select SYS_FSL_DDR_VER_50
- select SYS_FSL_HAS_CCI400
- select SYS_FSL_HAS_DDR4
- select SYS_FSL_HAS_SEC
- select SYS_FSL_SEC_COMPAT_5
- select SYS_FSL_SEC_LE
- select SYS_FSL_SRDS_1
- select SYS_FSL_SRDS_2
- select FSL_TZASC_1
- select SYS_FSL_ERRATUM_A009803
- select SYS_FSL_ERRATUM_A009942
- select SYS_FSL_ERRATUM_A010165
- select SYS_FSL_ERRATUM_A008511
- select SYS_FSL_ERRATUM_A008850
- select ARCH_EARLY_INIT_R
- select BOARD_EARLY_INIT_F
config ARCH_LS2080A bool select ARMV8_SET_SMPEN @@ -79,6 +102,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A009203
- select SYS_FSL_HAS_CCN504 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F
@@ -97,7 +121,7 @@ config FSL_LSCH3
config FSL_MC_ENET bool "Management Complex network"
- depends on ARCH_LS2080A
- depends on ARCH_LS2080A || ARCH_LS1088A default y select RESV_RAM help
@@ -113,6 +137,7 @@ config FSL_PCIE_COMPAT default "fsl,ls1043a-pcie" if ARCH_LS1043A default "fsl,ls1046a-pcie" if ARCH_LS1046A default "fsl,ls2080a-pcie" if ARCH_LS2080A
- default "fsl,ls1080a-pcie" if ARCH_LS1088A help This compatible is used to find pci controller node in Kernel DT to complete fixup.
@@ -173,6 +198,7 @@ config MAX_CPUS default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A default 16 if ARCH_LS2080A
- default 8 if ARCH_LS1088A default 1 help Set this number to the maximum number of possible CPUs in the SoC.
@@ -195,13 +221,11 @@ config QSPI_AHB_INIT
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller"
- depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A
- depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A || ARCH_LS1088A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A
- default 8 if ARCH_LS2080A
- default 8 if ARCH_LS2080A || ARCH_LS1088A
-config SYS_FSL_HAS_CCI400
- bool
config SYS_FSL_HAS_DP_DDR bool @@ -244,6 +268,7 @@ config SYS_FSL_PCLK_DIV int "Platform clock divider" default 1 if ARCH_LS1043A default 1 if ARCH_LS1046A
- default 1 if ARCH_LS1088A default 2 help This is the divider that is used to derive Platform clock from
@@ -313,6 +338,12 @@ config RESV_RAM config SYS_FSL_ERRATUM_A009203 bool
+config SYS_FSL_HAS_CCI400
- bool
+config SYS_FSL_HAS_CCN504
- bool
Unless you are doing cleanup, don't move them.
config SYS_FSL_ERRATUM_A008336 bool
@@ -337,7 +368,8 @@ config SYS_FSL_ERRATUM_A009929 config SYS_MC_RSV_MEM_ALIGN hex "Management Complex reserved memory alignment" depends on RESV_RAM
- default 0x20000000
- default 0x20000000 if ARCH_LS2080A
- default 0x70000000 if ARCH_LS1088A help Reserved memory needs to be aligned for MC to use. Default value is 512MB.
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index c9ab93e..cfad154 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -38,3 +38,7 @@ endif ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif
+ifneq ($(CONFIG_ARCH_LS1088A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1088a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index a826e33..a56cad5 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -14,6 +14,7 @@ #include <asm/arch/soc.h> #include <asm/arch/cpu.h> #include <asm/arch/speed.h> +#include <fsl_immap.h> #ifdef CONFIG_MP #include <asm/arch/mp.h> #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 955e0b7..d7e2d3c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -28,6 +28,11 @@ __weak void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) return; }
+__weak int serdes_get_number(int serdes, int cfg) +{
- return cfg;
How about this
/* If serdes is not enabled, return an error. */ __weak int serdes_get_number(int serdes, int cfg) { return cfg > 0 : cfg ? -ENODEV; }
York
Hello York,
Please see response inline
Regards Ashish
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 12, 2017 2:04 AM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de; u-boot@linux.freescale.net Cc: Alison Wang alison.wang@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Raghav Dogra raghav.dogra@nxp.com; Shaohui Xie Shaohui.Xie@nxp.com Subject: Re: [Patch v2 1/3] armv8: ls1088a: Add NXP LS1088A SoC support
Features summary:
- bool
- select FSL_LSCH3
+ARCH_LS1088A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A
- bool
- default 1 if ARCH_LS1088A default 2 help This is the divider that is used to derive Platform clock from @@
- bool
- bool
Unless you are doing cleanup, don't move them. [Ashish Kumar] Will take care in next version
+ifneq ($(CONFIG_ARCH_LS1088A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1088a_serdes.o endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index a826e33..a56cad5 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -14,6 +14,7 @@ #include <asm/arch/soc.h> #include <asm/arch/cpu.h> #include <asm/arch/speed.h> +#include <fsl_immap.h> #ifdef CONFIG_MP #include <asm/arch/mp.h> #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 955e0b7..d7e2d3c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -28,6 +28,11 @@ __weak void wriop_init_dpmac_qsgmii(int sd, int lane_prtcl) return; }
+__weak int serdes_get_number(int serdes, int cfg) {
- return cfg;
How about this
/* If serdes is not enabled, return an error. */ __weak int serdes_get_number(int serdes, int cfg) { return cfg > 0 : cfg ? -ENODEV; } [Ashish Kumar] It is taken care here in function
int serdes_get_first_lane(u32 sd, enum srds_prtcl device) { . . . /* Is serdes enabled at all? */ if (cfg == 0) return -ENODEV;
York
Ashish Kumar
Ashish Kumar
York Sun
