[U-Boot-Users] Kernel hanging after lmb_end_of_DRAM() function
Hi geeks, i am trying to bring up the latest kernel on EP8248 target, i am using U-boot-1.3.2 and linux-2.6.25-rc8, i started debugging using BDI2000 which helped me to know atleast what is going wrong, i have added some printk's in the kernel source but still i am not able to find where and what exactly is going wrong, The first statement it is printing in the log buffer is ""Using Embedded Planet EP8248E machine description"" and thats it the next message is Unable to handle kernel paging request for data at address 0xbfff0000 Faulting instruction address:0xc0012070 (This nearest address to this address in System.map file is cacheable_memzero) and tracing like this i came to know that in the file arch/powerpc/mm/ppc_mmu_32.c , here in the function __init MMU_init_hw() and in the line n_hpteg = total_memory / (PAGE_SIZE * 8); probably it is getting problem because when i tried to print the variable total_memory it is printing zero !!! :( :( so probably i am thinking it is not able to find some memory for Hash table :( Please share your knowledge and skills and help me to resolve this issue.. thanks :)
U can refer to patch for ep8248 support here http://patchwork.ozlabs.org/linuxppc/patch?id=15772
best wishes, Nethra
BDI2000 which helped me to >know atleast what is going wrong, i have added some printk's in the kernel source but still i am not able >to find where and what exactly is going wrong, The first statement it is printing in the log buffer is
message is
Faulting instruction >address:0xc0012070 (This nearest address to this address in System.map file is cacheable_memzero)
arch/powerpc/mm/ppc_mmu_32.c , here in the >function __init MMU_init_hw() and in the line n_hpteg = total_memory / (PAGE_SIZE * 8); >probably it is getting problem because when i tried to print the variable total_memory it is printing >zero !!! :( :( so probably i am thinking it is not able to find some memory for Hash table :(
I can't help with your Linux kernel problem, but I'm pretty sure that it is off topic on this mailing list.
As it turns out, it wasn't off-topic -- the problem is u-boot's fdt setup for 8260-ish chips.
-Scott
ACK. I stand corrected.
gforgcc
Nethra
Scott Wood
