[U-Boot] [PATCH] drivers: mmc: Avoid memory leak in case of failure
priv pointer should be freed before returning with an error value from exynos_dwmci_get_config().
Signed-off-by: Suniel Mahesh sunil.m@techveda.org Signed-off-by: Raghu Bharadwaj raghu@techveda.org --- drivers/mmc/exynos_dw_mmc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 40f7892..84ef2da 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -168,6 +168,7 @@ static int exynos_dwmci_get_config(const void *blob, int node,
if (host->dev_index > 4) { printf("DWMMC%d: Can't get the dev index\n", host->dev_index); + free(priv); return -EINVAL; }
@@ -178,6 +179,7 @@ static int exynos_dwmci_get_config(const void *blob, int node, base = fdtdec_get_addr(blob, node, "reg"); if (!base) { printf("DWMMC%d: Can't get base address\n", host->dev_index); + free(priv); return -EINVAL; } host->ioaddr = (void *)base; @@ -187,6 +189,7 @@ static int exynos_dwmci_get_config(const void *blob, int node, if (err) { printf("DWMMC%d: Can't get sdr-timings for devider\n", host->dev_index); + free(priv); return -EINVAL; }
Applied to u-boot-mmc.
Best Regards, Jaehoon Chung
return -EINVAL; }free(priv);
return -EINVAL; } host->ioaddr = (void *)base;free(priv);
Hi, It says the patch has been applied to u-boot-mmc git tree, but I couldn't find it there applied. http://git.denx.de/?p=u-boot/u-boot-mmc.git;a=summary
are there any issues with the patch or am I looking at the wrong place ?
Thanks suniel
Right place..Sorry..i missed it..when i rebased..will re-apply. Thanks for pointing out.
Thanks suniel
Hi, Just a reminder, please re-apply.
I am rebasing the patch w.r.t latest u-boot source tree and will shortly send it.
Thanks suniel
Thanks suniel
Signed-off-by: Suniel Mahesh sunil.m@techveda.org Signed-off-by: Raghu Bharadwaj raghu@techveda.org --- Changes for v2: - rebased on latest u-boot tree (2017.11.rc1) - patch was accepted long time ago, but not applied to u-boot-mmc, please apply. --- Note: Tested on latest u-boot mainline tree, no build issues. --- drivers/mmc/exynos_dw_mmc.c | 3 +++ 1 file changed, 3 insertions(+)
Changes for v2:
Jaehoon Chung
Suniel Mahesh
