[PATCH 00/18] x86: Improve operation under QEMU
U-Boot can start and boot an OS in both qemu-x86 and qemu-x86_64 but it is not perfect.
With both builds, executing the VESA ROM causes an intermittent hang, at least on some AMD CPUs.
With qemu-x86_64 kvm cannot be used since the move to long mode (64-bit) is done in a way that works on real hardware but not with QEMU. This means that performance is 4-5x slower than it could be, at least on my CPU.
We can work around the first problem by using Bochs, which is anyway a better choice than VESA for QEMU. But this results in the Ubuntu installer failing to boot via EFI. It isn't clear whether this due to a problem with the UEFI GOP, or something else. It hangs before the Ubuntu logo appears.
So this series is unfinished. I thought it best to post what is here in the hope that others can help work out the kinks.
Simon Glass (18): scripts: Add a script for building and booting QEMU x86: Expand x86_64 early memory RFC: x86: qemu: Switch to bochs display x86: qemu: Enable dhrystone x86: qemu: Avoid accessing BSS too early x86: Drop mpspec from the SPL build x86: Add some log categories x86: Drop use of CONFIG_REALMODE_DEBUG x86: Avoid clearing the VESA display x86: Add 64-bit entries to the GDT x86: Use defines for the cache flags x86: spl: Drop duplicate CPU init x86: Drop the message about features missing in 64-bit x86: Include stdbool.h in interrupt header x86: Tidy up the GDT size in start/16.S x86: Disable paging before changing to long mode x86: Use the same GDT when jumping to long mode x86: Use a simple jump into long mode
MAINTAINERS | 8 ++ arch/x86/cpu/i386/call64.S | 35 +++---- arch/x86/cpu/i386/cpu.c | 18 +++- arch/x86/cpu/qemu/qemu.c | 20 ++-- arch/x86/cpu/start.S | 4 +- arch/x86/cpu/start16.S | 3 +- arch/x86/include/asm/interrupt.h | 1 + arch/x86/include/asm/processor.h | 5 +- arch/x86/lib/Makefile | 2 + arch/x86/lib/bios.c | 27 +++-- arch/x86/lib/bios_interrupts.c | 8 +- arch/x86/lib/i8259.c | 2 + arch/x86/lib/spl.c | 4 +- configs/qemu-x86_64_defconfig | 10 +- configs/qemu-x86_defconfig | 6 +- doc/board/emulation/index.rst | 1 + doc/board/emulation/script.rst | 61 +++++++++++ scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++ 18 files changed, 331 insertions(+), 59 deletions(-) create mode 100644 doc/board/emulation/script.rst create mode 100755 scripts/build-qemu.sh
It is handy to be able to quickly build and boot a QEMU image for a particular architecture and distro.
Add a script for this purpose. It supports only arm and x86 at present. For distros it only supports Ubuntu. Both 32- and 64-bit builds are supported.
MAINTAINERS | 8 ++ doc/board/emulation/index.rst | 1 + doc/board/emulation/script.rst | 61 ++++++++++++ scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ 4 files changed, 245 insertions(+) create mode 100644 doc/board/emulation/script.rst create mode 100755 scripts/build-qemu.sh
diff --git a/MAINTAINERS b/MAINTAINERS index 0399ed1dbf6..b45bb96d5a5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1110,6 +1110,14 @@ F: tools/efivar.py F: tools/file2include.c F: tools/mkeficapsule.c
+EMULATION +M: Simon Glass sjg@chromium.org +S: Maintained +W: https://docs.u-boot.org/en/latest/board/emulation/script.html +F: configs/qemu_x86* +F: doc/board/emulation/script.rst +F: scripts/build-qemu.sh + ENVIRONMENT M: Joe Hershberger joe.hershberger@ni.com S: Maintained diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst index f8908166276..5a2a00ae225 100644 --- a/doc/board/emulation/index.rst +++ b/doc/board/emulation/index.rst @@ -8,6 +8,7 @@ Emulation
acpi blkdev + script qemu-arm qemu-mips qemu-ppce500 diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst new file mode 100644 index 00000000000..23981e333cb --- /dev/null +++ b/doc/board/emulation/script.rst @@ -0,0 +1,61 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Script for building and running +=============================== + +You may find the script `scripts/build-qemu.sh` helpful for building and testing +U-Boot on QEMU. + +If uses a environment variables to control how it works: + +ubdir + base directory for building U-Boot, with each board being in its own + subdirectory + +imagedir + directory containing OS images, containin a subdirectory for each distro + type (e.g. ubuntu/ + +Once configured, you can build and run QEMU for arm64 like this:: + + scripts/build-qemu.sh -rsw + +No support is currently included for specifying a root disk, so this script can +only be used to start installers. + +Options +~~~~~~~ + +Options are available to control the script: + +-a <arch> + Select architecture (default arm, x86) + +-B + Don't build; assume a build exists + +-k + Use kvm - kernel-based Virtual Machine. By default QEMU uses its own + emulator + +-o <os> + Run an Operating System. For now this only supports 'ubuntu'. The name of + the OS file must remain unchanged from its standard name on the Ubuntu + website. + +-r + Run QEMU with the image (by default this is not done) + +-R + Select OS release (e.g. 24.04). + +-s + Use serial only (no display) + +-w + Use word version (32-bit). By default, 64-bit is used + +.. note:: + + Note: For now this is a shell script, but if it expands it might be better + as Python, accepting the slower startup. diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh new file mode 100755 index 00000000000..0ff53593cf9 --- /dev/null +++ b/scripts/build-qemu.sh @@ -0,0 +1,175 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +# +# Script to build U-Boot suitable for booting with QEMU, possibly running +# it, possibly with an OS image + +# This just an example. It assumes that + +# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config +# - your OS images are in ${imagedir}/{distroname}/... + +# So far the script supports only ARM and x86. + +set -e + +usage() { + ( + if [[ -n "$1" ]]; then + echo "$1" + echo + fi + echo "Usage: $0 -aBkrsw" + echo + echo " -a - Select architecture (arm, x86)" + echo " -B - Don't build; assume a build exists" + echo " -k - Use kvm (kernel-based Virtual Machine)" + echo " -o - Run Operating System ('ubuntu' only for now)" + echo " -r - Run QEMU with the image" + echo " -R - Select OS release (e.g. 24.04)" + echo " -s - Use serial only (no display)" + echo " -w - Use word version (32-bit)" ) >&2 + exit 1 +} + +# Directory tree for OS images +imagedir=${imagedir-/vid/software/linux} + +# architecture (arm or x86) +arch=arm + +# 32- or 64-bit build +bitness=64 + +# Build U-Boot +build=yes + +# Extra setings +extra= + +# Operating System to boot (ubuntu) +os= + +release=24.04.1 + +# run the image with QEMU +run= + +# run QEMU without a display (U-Boot must be set to stdout=serial) +serial= + +# Use kvm +kvm= + +# Set ubdir to the build directory where you build U-Boot out-of-tree +# We avoid in-tree build because it gets confusing trying different builds +ubdir=${ubdir-/tmp/b} + +while getopts "a:Bko:rR:sw" opt; do + case "${opt}" in + a) + arch=$OPTARG + ;; + B) + build= + ;; + k) + kvm="-enable-kvm" + ;; + o) + os=$OPTARG + + # Expand memory and CPUs + extra+=" -m 4G -smp 4" + ;; + r) + run=1 + ;; + R) + release=$OPTARG + ;; + s) + serial=1 + ;; + w) + bitness=32 + ;; + *) + usage + ;; + esac +done + +# Build U-Boot for the selected board +build_u_boot() { + buildman -w -o $DIR --board $BOARD -I || exit $? +} + +# Run QEMU with U-Boot +run_qemu() { + if [[ -n "${os_image}" ]]; then + extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" + fi + if [[ -n "${serial}" ]]; then + extra+=" -display none -serial mon:stdio" + else + extra+=" -serial mon:stdio" + fi + echo "Running ${qemu} ${extra}" + "${qemu}" -bios "$DIR/${BIOS}" \ + -m 512 \ + -nic none \ + ${kvm} \ + ${extra} +} + +# Check architecture +case "${arch}" in +arm) + BOARD="qemu_arm" + BIOS="u-boot.bin" + qemu=qemu-system-arm + extra+=" -machine virt" + suffix="arm" + if [[ "${bitness}" == "64" ]]; then + BOARD="qemu_arm64" + qemu=qemu-system-aarch64 + extra+=" -cpu cortex-a57" + suffix="arm64" + fi + ;; +x86) + BOARD="qemu-x86" + BIOS="u-boot.rom" + qemu=qemu-system-i386 + suffix="i386" + if [[ "${bitness}" == "64" ]]; then + BOARD="qemu-x86_64" + qemu=qemu-system-x86_64 + suffix="amd64" + fi + ;; +*) + usage "Unknown architecture '${arch}'" +esac + +# Check OS +case "${os}" in +ubuntu) + os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso" + ;; +"") + ;; +*) + usage "Unknown OS '${os}'" +esac + +DIR=${ubdir}/${BOARD} + +if [[ -n "${build}" ]]; then + build_u_boot +fi + +if [[ -n "${run}" ]]; then + run_qemu +fi
I don't know that this is an appropriate thing to merge. It's missing all of the other architectures and platforms we support via QEMU and run in CI all of the time. I feel it would be better to document how to "read" the combination of CI yaml files and u-boot-test-hooks to see the common cases of "fire up QEMU with U-Boot" instead of adding yet another tool to support.
Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org:
Please, avoid misnomers. This script does not build QEMU.
acpi blkdev
- script qemu-arm qemu-mips qemu-ppce500
Just another misnomer. This page is not about script.sh.
This is not a valid SPDX identifier.
+ubdir
- base directory for building U-Boot, with each board being in its own
- subdirectory
+imagedir
- directory containing OS images, containin a subdirectory for each distro
- type (e.g. ubuntu/
This downloads the QEMU source and builds it?
- scripts/build-qemu.sh -rsw
+Options +~~~~~~~
+-a <arch>
- Select architecture (default arm, x86)
+-B
+-k
- Use kvm - kernel-based Virtual Machine. By default QEMU uses its own
- emulator
+-o <os>
- Run an Operating System. For now this only supports 'ubuntu'. The name of
- the OS file must remain unchanged from its standard name on the Ubuntu
- website.
The U-Boot project should remain open to all operating systems. How will this work with OpenBSD?
Use the URL of the image as argument.
+-r
- Run QEMU with the image (by default this is not done)
+-R
- Select OS release (e.g. 24.04).
+-s
+-w
- Use word version (32-bit). By default, 64-bit is used
"word version" is not helpful as explanation.
Look at https://en.m.wikipedia.org/wiki/Word_(computer_architecture) which says a word is 64 bit on a 64-bit system and 16 bit on a 16-bit system.
+.. note::
- Note: For now this is a shell script, but if it expands it might be better
- as Python, accepting the slower startup.
Why support obsolete i386 but not riscv64?
+set -e
+usage() {
- if [[ -n "$1" ]]; then
echo "$1"
echo
- fi
- echo "Usage: $0 -aBkrsw"
- echo
- echo " -a - Select architecture (arm, x86)"
- echo " -B - Don't build; assume a build exists"
- echo " -k - Use kvm (kernel-based Virtual Machine)"
- echo " -o - Run Operating System ('ubuntu' only for now)"
- echo " -r - Run QEMU with the image"
- echo " -R - Select OS release (e.g. 24.04)"
- echo " -s - Use serial only (no display)"
- echo " -w - Use word version (32-bit)" ) >&2
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- buildman -w -o $DIR --board $BOARD -I || exit $?
- if [[ -n "${os_image}" ]]; then
- fi
- if [[ -n "${serial}" ]]; then
- else
- fi
- echo "Running ${qemu} ${extra}"
- "${qemu}" -bios "$DIR/${BIOS}" \
-m 512 \
Ubuntu suggests 4 GiB as minimum for a desktop.
-nic none \
Who wants to run without network? Use the virtio nic.
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- qemu=qemu-system-arm
- extra+=" -machine virt"
- suffix="arm"
- if [[ "${bitness}" == "64" ]]; then
BOARD="qemu_arm64"
That CPU is 12 years old and not all distros are stuck on ARM v8.0. See https://en.opensuse.org/Arm_architecture_support.
-cpu max works fine with both tcg and kvm.
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- qemu=qemu-system-i386
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
- usage "Unknown architecture '${arch}'"
+esac
- os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso"
There is no ARM 32-bit Ubuntu desktop. And for i386 there is no image in 24.04.1.
Running a foreign architecture desktop with tcg is not enjoyable.
For testing U-Boot a server image is all it takes.
Best regards
Heinrich
- usage "Unknown OS '${os}'"
+esac
- build_u_boot
+fi
- run_qemu
+fi
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
And _all_ of this is why I don't want to add a useful personal script as an additional tool we support. I've seen how much work goes in to the OpenEmbedded runqemu script, we don't have the spare cycles for something like that. Doubly so when ultimately I believe we would be well served by having a document that says (in much more words) to look at u-boot-test-hooks for how to invoke QEMU for a large number of architectures and platforms and to then further leverage general QEMU tips and guides on how to run an OS of your choice with that.
Hi Tom,
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
I'm not sure it matters that much. Everyone is going to have their preference as to how this script should look, but no one else has taken the time to write one...
People are free to send patches to enhance it. But I believe it is helpful, e.g. for repeating problems caused by recent lmb patches.
Re the test hooks, I just get tired of looking them up and trying to figure out what to do. Every board name and arch is slightly different. Just a hassle that I don't need.
We can put it in scripts/contrib if you like.
On Fri, Nov 15, 2024 at 07:21:47AM -0700, Simon Glass wrote:
Hi Tom,
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
It's handy to point people to scripts, yes. I frequently point people at my wrappers around buildman for example for "how do I find code bloat?" and similar. But no, I don't think this rises to the level of "scripts/contrib".
Hi Tom,
Hi Tom,
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
I find this useful and it makes it easier to report problems with booting if we are using the same tool. I plan to add RISC-V at some point.
Hi Tom,
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
Coming back to this question again. I'd be willing to make a new top-level repository for "contributor tooling" and also make that more widely writable. But I also think you're underestimating the level of work required to have a "generic" script here that works on arbitrary developer machines.
Hi Tom,
Hi Tom,
acpi blkdev
+ubdir
- subdirectory
+imagedir
+Options +~~~~~~~
+-a <arch>
+-B
+-k
- emulator
+-o <os>
- website.
+-r
+-R
+-s
+-w
+.. note::
+set -e
+usage() {
echo "$1"
echo
- fi
- echo
- exit 1
+release=24.04.1
+# Use kvm +kvm=
- case "${opt}" in
- a)
arch=$OPTARG
- B)
build=
- k)
kvm="-enable-kvm"
- o)
os=$OPTARG
- r)
run=1
- R)
release=$OPTARG
- s)
serial=1
- w)
bitness=32
usage
- esac
+done
- fi
- else
- fi
-m 512 \
-nic none \
${kvm} \
${extra}
- BOARD="qemu_arm"
- BIOS="u-boot.bin"
- suffix="arm"
BOARD="qemu_arm64"
suffix="arm64"
- fi
+x86)
- BOARD="qemu-x86"
- BIOS="u-boot.rom"
- suffix="i386"
BOARD="qemu-x86_64"
suffix="amd64"
- fi
+esac
Having it in a separate repo seems like too much of a pain, to me. When things change in U-Boot I would want to update the script (e.g. to add UPL support, booting Ubuntu and the like).
On Thu, Jan 09, 2025 at 05:36:34AM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org: >It is handy to be able to quickly build and boot a QEMU image for a >particular architecture and distro. > >Add a script for this purpose. It supports only arm and x86 at present. >For distros it only supports Ubuntu. Both 32- and 64-bit builds are >supported. > >Signed-off-by: Simon Glass sjg@chromium.org >--- > > MAINTAINERS | 8 ++ > doc/board/emulation/index.rst | 1 + > doc/board/emulation/script.rst | 61 ++++++++++++ > scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ > 4 files changed, 245 insertions(+) > create mode 100644 doc/board/emulation/script.rst > create mode 100755 scripts/build-qemu.sh > >diff --git a/MAINTAINERS b/MAINTAINERS >index 0399ed1dbf6..b45bb96d5a5 100644 >--- a/MAINTAINERS >+++ b/MAINTAINERS >@@ -1110,6 +1110,14 @@ F: tools/efivar.py > F: tools/file2include.c > F: tools/mkeficapsule.c > >+EMULATION >+M: Simon Glass sjg@chromium.org >+S: Maintained >+W: https://docs.u-boot.org/en/latest/board/emulation/script.html >+F: configs/qemu_x86* >+F: doc/board/emulation/script.rst >+F: scripts/build-qemu.sh
>+ > ENVIRONMENT > M: Joe Hershberger joe.hershberger@ni.com > S: Maintained >diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst >index f8908166276..5a2a00ae225 100644 >--- a/doc/board/emulation/index.rst >+++ b/doc/board/emulation/index.rst >@@ -8,6 +8,7 @@ Emulation > > acpi > blkdev >+ script > qemu-arm > qemu-mips > qemu-ppce500 >diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst
>new file mode 100644 >index 00000000000..23981e333cb >--- /dev/null >+++ b/doc/board/emulation/script.rst >@@ -0,0 +1,61 @@ >+.. SPDX-License-Identifier: GPL-2.0+
>+ >+Script for building and running >+=============================== >+ >+You may find the script `scripts/build-qemu.sh` helpful for building and testing >+U-Boot on QEMU. >+ >+If uses a environment variables to control how it works: >+ >+ubdir >+ base directory for building U-Boot, with each board being in its own >+ subdirectory >+ >+imagedir >+ directory containing OS images, containin a subdirectory for each distro >+ type (e.g. ubuntu/ >+ >+Once configured, you can build and run QEMU for arm64 like this::
>+ >+ scripts/build-qemu.sh -rsw >+ >+No support is currently included for specifying a root disk, so this script can >+only be used to start installers. >+ >+Options >+~~~~~~~ >+ >+Options are available to control the script: >+ >+-a <arch> >+ Select architecture (default arm, x86) >+ >+-B >+ Don't build; assume a build exists >+ >+-k >+ Use kvm - kernel-based Virtual Machine. By default QEMU uses its own >+ emulator >+ >+-o <os> >+ Run an Operating System. For now this only supports 'ubuntu'. The name of >+ the OS file must remain unchanged from its standard name on the Ubuntu >+ website.
>+ >+-r >+ Run QEMU with the image (by default this is not done) >+ >+-R >+ Select OS release (e.g. 24.04). >+ >+-s >+ Use serial only (no display) >+ >+-w >+ Use word version (32-bit). By default, 64-bit is used
>+ >+.. note:: >+ >+ Note: For now this is a shell script, but if it expands it might be better >+ as Python, accepting the slower startup. >diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh >new file mode 100755 >index 00000000000..0ff53593cf9 >--- /dev/null >+++ b/scripts/build-qemu.sh >@@ -0,0 +1,175 @@ >+#!/bin/bash >+# SPDX-License-Identifier: GPL-2.0+
>+# >+# Script to build U-Boot suitable for booting with QEMU, possibly running >+# it, possibly with an OS image >+ >+# This just an example. It assumes that >+ >+# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config >+# - your OS images are in ${imagedir}/{distroname}/... >+ >+# So far the script supports only ARM and x86.
>+ >+set -e >+ >+usage() { >+ ( >+ if [[ -n "$1" ]]; then >+ echo "$1" >+ echo >+ fi >+ echo "Usage: $0 -aBkrsw" >+ echo >+ echo " -a - Select architecture (arm, x86)" >+ echo " -B - Don't build; assume a build exists" >+ echo " -k - Use kvm (kernel-based Virtual Machine)" >+ echo " -o - Run Operating System ('ubuntu' only for now)" >+ echo " -r - Run QEMU with the image" >+ echo " -R - Select OS release (e.g. 24.04)" >+ echo " -s - Use serial only (no display)" >+ echo " -w - Use word version (32-bit)" ) >&2 >+ exit 1 >+} >+ >+# Directory tree for OS images >+imagedir=${imagedir-/vid/software/linux} >+ >+# architecture (arm or x86) >+arch=arm >+ >+# 32- or 64-bit build >+bitness=64 >+ >+# Build U-Boot >+build=yes >+ >+# Extra setings >+extra= >+ >+# Operating System to boot (ubuntu) >+os= >+ >+release=24.04.1 >+ >+# run the image with QEMU >+run= >+ >+# run QEMU without a display (U-Boot must be set to stdout=serial) >+serial= >+ >+# Use kvm >+kvm= >+ >+# Set ubdir to the build directory where you build U-Boot out-of-tree >+# We avoid in-tree build because it gets confusing trying different builds >+ubdir=${ubdir-/tmp/b} >+ >+while getopts "a:Bko:rR:sw" opt; do >+ case "${opt}" in >+ a) >+ arch=$OPTARG >+ ;; >+ B) >+ build= >+ ;; >+ k) >+ kvm="-enable-kvm" >+ ;; >+ o) >+ os=$OPTARG >+ >+ # Expand memory and CPUs >+ extra+=" -m 4G -smp 4" >+ ;; >+ r) >+ run=1 >+ ;; >+ R) >+ release=$OPTARG >+ ;; >+ s) >+ serial=1 >+ ;; >+ w) >+ bitness=32 >+ ;; >+ *) >+ usage >+ ;; >+ esac >+done >+ >+# Build U-Boot for the selected board >+build_u_boot() { >+ buildman -w -o $DIR --board $BOARD -I || exit $? >+} >+ >+# Run QEMU with U-Boot >+run_qemu() { >+ if [[ -n "${os_image}" ]]; then >+ extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" >+ fi >+ if [[ -n "${serial}" ]]; then >+ extra+=" -display none -serial mon:stdio" >+ else >+ extra+=" -serial mon:stdio" >+ fi >+ echo "Running ${qemu} ${extra}" >+ "${qemu}" -bios "$DIR/${BIOS}" \ >+ -m 512 \
>+ -nic none \
>+ ${kvm} \ >+ ${extra} >+} >+ >+# Check architecture >+case "${arch}" in >+arm) >+ BOARD="qemu_arm" >+ BIOS="u-boot.bin" >+ qemu=qemu-system-arm >+ extra+=" -machine virt" >+ suffix="arm" >+ if [[ "${bitness}" == "64" ]]; then >+ BOARD="qemu_arm64" >+ qemu=qemu-system-aarch64 >+ extra+=" -cpu cortex-a57"
>+ suffix="arm64"
>+ fi >+ ;; >+x86) >+ BOARD="qemu-x86" >+ BIOS="u-boot.rom" >+ qemu=qemu-system-i386 >+ suffix="i386" >+ if [[ "${bitness}" == "64" ]]; then >+ BOARD="qemu-x86_64" >+ qemu=qemu-system-x86_64 >+ suffix="amd64" >+ fi >+ ;; >+*) >+ usage "Unknown architecture '${arch}'" >+esac >+ >+# Check OS >+case "${os}" in >+ubuntu) >+ os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso"
Being external means it's easier to use for bisect'ing problems and you still have to handle UPL / no UPL and so on.
Hi Tom,
Hi Tom,
Hi Tom,
On Wed, Nov 13, 2024 at 01:49:30AM +0100, Heinrich Schuchardt wrote: > Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org: > >It is handy to be able to quickly build and boot a QEMU image for a > >particular architecture and distro. > > > >Add a script for this purpose. It supports only arm and x86 at present. > >For distros it only supports Ubuntu. Both 32- and 64-bit builds are > >supported. > > > >Signed-off-by: Simon Glass sjg@chromium.org > >--- > > > > MAINTAINERS | 8 ++ > > doc/board/emulation/index.rst | 1 + > > doc/board/emulation/script.rst | 61 ++++++++++++ > > scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ > > 4 files changed, 245 insertions(+) > > create mode 100644 doc/board/emulation/script.rst > > create mode 100755 scripts/build-qemu.sh > > > >diff --git a/MAINTAINERS b/MAINTAINERS > >index 0399ed1dbf6..b45bb96d5a5 100644 > >--- a/MAINTAINERS > >+++ b/MAINTAINERS > >@@ -1110,6 +1110,14 @@ F: tools/efivar.py > > F: tools/file2include.c > > F: tools/mkeficapsule.c > > > >+EMULATION > >+M: Simon Glass sjg@chromium.org > >+S: Maintained > >+W: https://docs.u-boot.org/en/latest/board/emulation/script.html > >+F: configs/qemu_x86* > >+F: doc/board/emulation/script.rst > >+F: scripts/build-qemu.sh > > Please, avoid misnomers. This script does not build QEMU. > > >+ > > ENVIRONMENT > > M: Joe Hershberger joe.hershberger@ni.com > > S: Maintained > >diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst > >index f8908166276..5a2a00ae225 100644 > >--- a/doc/board/emulation/index.rst > >+++ b/doc/board/emulation/index.rst > >@@ -8,6 +8,7 @@ Emulation > > > > acpi > > blkdev > >+ script > > qemu-arm > > qemu-mips > > qemu-ppce500 > >diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst > > Just another misnomer. This page is not about script.sh. > > >new file mode 100644 > >index 00000000000..23981e333cb > >--- /dev/null > >+++ b/doc/board/emulation/script.rst > >@@ -0,0 +1,61 @@ > >+.. SPDX-License-Identifier: GPL-2.0+ > > This is not a valid SPDX identifier. > > >+ > >+Script for building and running > >+=============================== > >+ > >+You may find the script `scripts/build-qemu.sh` helpful for building and testing > >+U-Boot on QEMU. > >+ > >+If uses a environment variables to control how it works: > >+ > >+ubdir > >+ base directory for building U-Boot, with each board being in its own > >+ subdirectory > >+ > >+imagedir > >+ directory containing OS images, containin a subdirectory for each distro > >+ type (e.g. ubuntu/ > >+ > >+Once configured, you can build and run QEMU for arm64 like this:: > > This downloads the QEMU source and builds it? > > >+ > >+ scripts/build-qemu.sh -rsw > >+ > >+No support is currently included for specifying a root disk, so this script can > >+only be used to start installers. > >+ > >+Options > >+~~~~~~~ > >+ > >+Options are available to control the script: > >+ > >+-a <arch> > >+ Select architecture (default arm, x86) > >+ > >+-B > >+ Don't build; assume a build exists > >+ > >+-k > >+ Use kvm - kernel-based Virtual Machine. By default QEMU uses its own > >+ emulator > >+ > >+-o <os> > >+ Run an Operating System. For now this only supports 'ubuntu'. The name of > >+ the OS file must remain unchanged from its standard name on the Ubuntu > >+ website. > > The U-Boot project should remain open to all operating systems. How will this work with OpenBSD? > > Use the URL of the image as argument. > > >+ > >+-r > >+ Run QEMU with the image (by default this is not done) > >+ > >+-R > >+ Select OS release (e.g. 24.04). > >+ > >+-s > >+ Use serial only (no display) > >+ > >+-w > >+ Use word version (32-bit). By default, 64-bit is used > > "word version" is not helpful as explanation. > > Look at https://en.m.wikipedia.org/wiki/Word_(computer_architecture) which says a word is 64 bit on a 64-bit system and 16 bit on a 16-bit system. > > >+ > >+.. note:: > >+ > >+ Note: For now this is a shell script, but if it expands it might be better > >+ as Python, accepting the slower startup. > >diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh > >new file mode 100755 > >index 00000000000..0ff53593cf9 > >--- /dev/null > >+++ b/scripts/build-qemu.sh > >@@ -0,0 +1,175 @@ > >+#!/bin/bash > >+# SPDX-License-Identifier: GPL-2.0+ > > This is not a valid SPDX identifier. > > >+# > >+# Script to build U-Boot suitable for booting with QEMU, possibly running > >+# it, possibly with an OS image > >+ > >+# This just an example. It assumes that > >+ > >+# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config > >+# - your OS images are in ${imagedir}/{distroname}/... > >+ > >+# So far the script supports only ARM and x86. > > Why support obsolete i386 but not riscv64? > > >+ > >+set -e > >+ > >+usage() { > >+ ( > >+ if [[ -n "$1" ]]; then > >+ echo "$1" > >+ echo > >+ fi > >+ echo "Usage: $0 -aBkrsw" > >+ echo > >+ echo " -a - Select architecture (arm, x86)" > >+ echo " -B - Don't build; assume a build exists" > >+ echo " -k - Use kvm (kernel-based Virtual Machine)" > >+ echo " -o - Run Operating System ('ubuntu' only for now)" > >+ echo " -r - Run QEMU with the image" > >+ echo " -R - Select OS release (e.g. 24.04)" > >+ echo " -s - Use serial only (no display)" > >+ echo " -w - Use word version (32-bit)" ) >&2 > >+ exit 1 > >+} > >+ > >+# Directory tree for OS images > >+imagedir=${imagedir-/vid/software/linux} > >+ > >+# architecture (arm or x86) > >+arch=arm > >+ > >+# 32- or 64-bit build > >+bitness=64 > >+ > >+# Build U-Boot > >+build=yes > >+ > >+# Extra setings > >+extra= > >+ > >+# Operating System to boot (ubuntu) > >+os= > >+ > >+release=24.04.1 > >+ > >+# run the image with QEMU > >+run= > >+ > >+# run QEMU without a display (U-Boot must be set to stdout=serial) > >+serial= > >+ > >+# Use kvm > >+kvm= > >+ > >+# Set ubdir to the build directory where you build U-Boot out-of-tree > >+# We avoid in-tree build because it gets confusing trying different builds > >+ubdir=${ubdir-/tmp/b} > >+ > >+while getopts "a:Bko:rR:sw" opt; do > >+ case "${opt}" in > >+ a) > >+ arch=$OPTARG > >+ ;; > >+ B) > >+ build= > >+ ;; > >+ k) > >+ kvm="-enable-kvm" > >+ ;; > >+ o) > >+ os=$OPTARG > >+ > >+ # Expand memory and CPUs > >+ extra+=" -m 4G -smp 4" > >+ ;; > >+ r) > >+ run=1 > >+ ;; > >+ R) > >+ release=$OPTARG > >+ ;; > >+ s) > >+ serial=1 > >+ ;; > >+ w) > >+ bitness=32 > >+ ;; > >+ *) > >+ usage > >+ ;; > >+ esac > >+done > >+ > >+# Build U-Boot for the selected board > >+build_u_boot() { > >+ buildman -w -o $DIR --board $BOARD -I || exit $? > >+} > >+ > >+# Run QEMU with U-Boot > >+run_qemu() { > >+ if [[ -n "${os_image}" ]]; then > >+ extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" > >+ fi > >+ if [[ -n "${serial}" ]]; then > >+ extra+=" -display none -serial mon:stdio" > >+ else > >+ extra+=" -serial mon:stdio" > >+ fi > >+ echo "Running ${qemu} ${extra}" > >+ "${qemu}" -bios "$DIR/${BIOS}" \ > >+ -m 512 \ > > Ubuntu suggests 4 GiB as minimum for a desktop. > > >+ -nic none \ > > Who wants to run without network? > Use the virtio nic. > > >+ ${kvm} \ > >+ ${extra} > >+} > >+ > >+# Check architecture > >+case "${arch}" in > >+arm) > >+ BOARD="qemu_arm" > >+ BIOS="u-boot.bin" > >+ qemu=qemu-system-arm > >+ extra+=" -machine virt" > >+ suffix="arm" > >+ if [[ "${bitness}" == "64" ]]; then > >+ BOARD="qemu_arm64" > >+ qemu=qemu-system-aarch64 > >+ extra+=" -cpu cortex-a57" > > That CPU is 12 years old and not all distros are stuck on ARM v8.0. See https://en.opensuse.org/Arm_architecture_support. > > -cpu max works fine with both tcg and kvm. > > >+ suffix="arm64" > > >+ fi > >+ ;; > >+x86) > >+ BOARD="qemu-x86" > >+ BIOS="u-boot.rom" > >+ qemu=qemu-system-i386 > >+ suffix="i386" > >+ if [[ "${bitness}" == "64" ]]; then > >+ BOARD="qemu-x86_64" > >+ qemu=qemu-system-x86_64 > >+ suffix="amd64" > >+ fi > >+ ;; > >+*) > >+ usage "Unknown architecture '${arch}'" > >+esac > >+ > >+# Check OS > >+case "${os}" in > >+ubuntu) > >+ os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso" > > There is no ARM 32-bit Ubuntu desktop. And for i386 there is no image in 24.04.1. > > Running a foreign architecture desktop with tcg is not enjoyable. > > For testing U-Boot a server image is all it takes.
There are trade-offs, for sure. Sometimes I use buildman from a separate tree when trying to debug something which changes buildman. But I don't think that warrants creating an entirely new tree for scripts.
On Fri, Jan 10, 2025 at 06:39:19AM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Tue, 12 Nov 2024 at 17:54, Tom Rini trini@konsulko.com wrote: > > On Wed, Nov 13, 2024 at 01:49:30AM +0100, Heinrich Schuchardt wrote: > > Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org: > > >It is handy to be able to quickly build and boot a QEMU image for a > > >particular architecture and distro. > > > > > >Add a script for this purpose. It supports only arm and x86 at present. > > >For distros it only supports Ubuntu. Both 32- and 64-bit builds are > > >supported. > > > > > >Signed-off-by: Simon Glass sjg@chromium.org > > >--- > > > > > > MAINTAINERS | 8 ++ > > > doc/board/emulation/index.rst | 1 + > > > doc/board/emulation/script.rst | 61 ++++++++++++ > > > scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ > > > 4 files changed, 245 insertions(+) > > > create mode 100644 doc/board/emulation/script.rst > > > create mode 100755 scripts/build-qemu.sh > > > > > >diff --git a/MAINTAINERS b/MAINTAINERS > > >index 0399ed1dbf6..b45bb96d5a5 100644 > > >--- a/MAINTAINERS > > >+++ b/MAINTAINERS > > >@@ -1110,6 +1110,14 @@ F: tools/efivar.py > > > F: tools/file2include.c > > > F: tools/mkeficapsule.c > > > > > >+EMULATION > > >+M: Simon Glass sjg@chromium.org > > >+S: Maintained > > >+W: https://docs.u-boot.org/en/latest/board/emulation/script.html > > >+F: configs/qemu_x86* > > >+F: doc/board/emulation/script.rst > > >+F: scripts/build-qemu.sh > > > > Please, avoid misnomers. This script does not build QEMU. > > > > >+ > > > ENVIRONMENT > > > M: Joe Hershberger joe.hershberger@ni.com > > > S: Maintained > > >diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst > > >index f8908166276..5a2a00ae225 100644 > > >--- a/doc/board/emulation/index.rst > > >+++ b/doc/board/emulation/index.rst > > >@@ -8,6 +8,7 @@ Emulation > > > > > > acpi > > > blkdev > > >+ script > > > qemu-arm > > > qemu-mips > > > qemu-ppce500 > > >diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst > > > > Just another misnomer. This page is not about script.sh. > > > > >new file mode 100644 > > >index 00000000000..23981e333cb > > >--- /dev/null > > >+++ b/doc/board/emulation/script.rst > > >@@ -0,0 +1,61 @@ > > >+.. SPDX-License-Identifier: GPL-2.0+ > > > > This is not a valid SPDX identifier. > > > > >+ > > >+Script for building and running > > >+=============================== > > >+ > > >+You may find the script `scripts/build-qemu.sh` helpful for building and testing > > >+U-Boot on QEMU. > > >+ > > >+If uses a environment variables to control how it works: > > >+ > > >+ubdir > > >+ base directory for building U-Boot, with each board being in its own > > >+ subdirectory > > >+ > > >+imagedir > > >+ directory containing OS images, containin a subdirectory for each distro > > >+ type (e.g. ubuntu/ > > >+ > > >+Once configured, you can build and run QEMU for arm64 like this:: > > > > This downloads the QEMU source and builds it? > > > > >+ > > >+ scripts/build-qemu.sh -rsw > > >+ > > >+No support is currently included for specifying a root disk, so this script can > > >+only be used to start installers. > > >+ > > >+Options > > >+~~~~~~~ > > >+ > > >+Options are available to control the script: > > >+ > > >+-a <arch> > > >+ Select architecture (default arm, x86) > > >+ > > >+-B > > >+ Don't build; assume a build exists > > >+ > > >+-k > > >+ Use kvm - kernel-based Virtual Machine. By default QEMU uses its own > > >+ emulator > > >+ > > >+-o <os> > > >+ Run an Operating System. For now this only supports 'ubuntu'. The name of > > >+ the OS file must remain unchanged from its standard name on the Ubuntu > > >+ website. > > > > The U-Boot project should remain open to all operating systems. How will this work with OpenBSD? > > > > Use the URL of the image as argument. > > > > >+ > > >+-r > > >+ Run QEMU with the image (by default this is not done) > > >+ > > >+-R > > >+ Select OS release (e.g. 24.04). > > >+ > > >+-s > > >+ Use serial only (no display) > > >+ > > >+-w > > >+ Use word version (32-bit). By default, 64-bit is used > > > > "word version" is not helpful as explanation. > > > > Look at https://en.m.wikipedia.org/wiki/Word_(computer_architecture) which says a word is 64 bit on a 64-bit system and 16 bit on a 16-bit system. > > > > >+ > > >+.. note:: > > >+ > > >+ Note: For now this is a shell script, but if it expands it might be better > > >+ as Python, accepting the slower startup. > > >diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh > > >new file mode 100755 > > >index 00000000000..0ff53593cf9 > > >--- /dev/null > > >+++ b/scripts/build-qemu.sh > > >@@ -0,0 +1,175 @@ > > >+#!/bin/bash > > >+# SPDX-License-Identifier: GPL-2.0+ > > > > This is not a valid SPDX identifier. > > > > >+# > > >+# Script to build U-Boot suitable for booting with QEMU, possibly running > > >+# it, possibly with an OS image > > >+ > > >+# This just an example. It assumes that > > >+ > > >+# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config > > >+# - your OS images are in ${imagedir}/{distroname}/... > > >+ > > >+# So far the script supports only ARM and x86. > > > > Why support obsolete i386 but not riscv64? > > > > >+ > > >+set -e > > >+ > > >+usage() { > > >+ ( > > >+ if [[ -n "$1" ]]; then > > >+ echo "$1" > > >+ echo > > >+ fi > > >+ echo "Usage: $0 -aBkrsw" > > >+ echo > > >+ echo " -a - Select architecture (arm, x86)" > > >+ echo " -B - Don't build; assume a build exists" > > >+ echo " -k - Use kvm (kernel-based Virtual Machine)" > > >+ echo " -o - Run Operating System ('ubuntu' only for now)" > > >+ echo " -r - Run QEMU with the image" > > >+ echo " -R - Select OS release (e.g. 24.04)" > > >+ echo " -s - Use serial only (no display)" > > >+ echo " -w - Use word version (32-bit)" ) >&2 > > >+ exit 1 > > >+} > > >+ > > >+# Directory tree for OS images > > >+imagedir=${imagedir-/vid/software/linux} > > >+ > > >+# architecture (arm or x86) > > >+arch=arm > > >+ > > >+# 32- or 64-bit build > > >+bitness=64 > > >+ > > >+# Build U-Boot > > >+build=yes > > >+ > > >+# Extra setings > > >+extra= > > >+ > > >+# Operating System to boot (ubuntu) > > >+os= > > >+ > > >+release=24.04.1 > > >+ > > >+# run the image with QEMU > > >+run= > > >+ > > >+# run QEMU without a display (U-Boot must be set to stdout=serial) > > >+serial= > > >+ > > >+# Use kvm > > >+kvm= > > >+ > > >+# Set ubdir to the build directory where you build U-Boot out-of-tree > > >+# We avoid in-tree build because it gets confusing trying different builds > > >+ubdir=${ubdir-/tmp/b} > > >+ > > >+while getopts "a:Bko:rR:sw" opt; do > > >+ case "${opt}" in > > >+ a) > > >+ arch=$OPTARG > > >+ ;; > > >+ B) > > >+ build= > > >+ ;; > > >+ k) > > >+ kvm="-enable-kvm" > > >+ ;; > > >+ o) > > >+ os=$OPTARG > > >+ > > >+ # Expand memory and CPUs > > >+ extra+=" -m 4G -smp 4" > > >+ ;; > > >+ r) > > >+ run=1 > > >+ ;; > > >+ R) > > >+ release=$OPTARG > > >+ ;; > > >+ s) > > >+ serial=1 > > >+ ;; > > >+ w) > > >+ bitness=32 > > >+ ;; > > >+ *) > > >+ usage > > >+ ;; > > >+ esac > > >+done > > >+ > > >+# Build U-Boot for the selected board > > >+build_u_boot() { > > >+ buildman -w -o $DIR --board $BOARD -I || exit $? > > >+} > > >+ > > >+# Run QEMU with U-Boot > > >+run_qemu() { > > >+ if [[ -n "${os_image}" ]]; then > > >+ extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" > > >+ fi > > >+ if [[ -n "${serial}" ]]; then > > >+ extra+=" -display none -serial mon:stdio" > > >+ else > > >+ extra+=" -serial mon:stdio" > > >+ fi > > >+ echo "Running ${qemu} ${extra}" > > >+ "${qemu}" -bios "$DIR/${BIOS}" \ > > >+ -m 512 \ > > > > Ubuntu suggests 4 GiB as minimum for a desktop. > > > > >+ -nic none \ > > > > Who wants to run without network? > > Use the virtio nic. > > > > >+ ${kvm} \ > > >+ ${extra} > > >+} > > >+ > > >+# Check architecture > > >+case "${arch}" in > > >+arm) > > >+ BOARD="qemu_arm" > > >+ BIOS="u-boot.bin" > > >+ qemu=qemu-system-arm > > >+ extra+=" -machine virt" > > >+ suffix="arm" > > >+ if [[ "${bitness}" == "64" ]]; then > > >+ BOARD="qemu_arm64" > > >+ qemu=qemu-system-aarch64 > > >+ extra+=" -cpu cortex-a57" > > > > That CPU is 12 years old and not all distros are stuck on ARM v8.0. See https://en.opensuse.org/Arm_architecture_support. > > > > -cpu max works fine with both tcg and kvm. > > > > >+ suffix="arm64" > > > > >+ fi > > >+ ;; > > >+x86) > > >+ BOARD="qemu-x86" > > >+ BIOS="u-boot.rom" > > >+ qemu=qemu-system-i386 > > >+ suffix="i386" > > >+ if [[ "${bitness}" == "64" ]]; then > > >+ BOARD="qemu-x86_64" > > >+ qemu=qemu-system-x86_64 > > >+ suffix="amd64" > > >+ fi > > >+ ;; > > >+*) > > >+ usage "Unknown architecture '${arch}'" > > >+esac > > >+ > > >+# Check OS > > >+case "${os}" in > > >+ubuntu) > > >+ os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso" > > > > There is no ARM 32-bit Ubuntu desktop. And for i386 there is no image in 24.04.1. > > > > Running a foreign architecture desktop with tcg is not enjoyable. > > > > For testing U-Boot a server image is all it takes. > > And _all_ of this is why I don't want to add a useful personal script > as an additional tool we support. I've seen how much work goes in to the > OpenEmbedded runqemu script, we don't have the spare cycles for > something like that. Doubly so when ultimately I believe we would be > well served by having a document that says (in much more words) to look > at u-boot-test-hooks for how to invoke QEMU for a large number of > architectures and platforms and to then further leverage general QEMU > tips and guides on how to run an OS of your choice with that.
It would also encourage others. I for example might put the scripts I use for having buildman do various tasks there as well.
Hi Tom,
Hi Tom,
Hi Tom,
On Fri, Nov 15, 2024 at 07:21:47AM -0700, Simon Glass wrote: > Hi Tom, > > On Tue, 12 Nov 2024 at 17:54, Tom Rini trini@konsulko.com wrote: > > > > On Wed, Nov 13, 2024 at 01:49:30AM +0100, Heinrich Schuchardt wrote: > > > Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org: > > > >It is handy to be able to quickly build and boot a QEMU image for a > > > >particular architecture and distro. > > > > > > > >Add a script for this purpose. It supports only arm and x86 at present. > > > >For distros it only supports Ubuntu. Both 32- and 64-bit builds are > > > >supported. > > > > > > > >Signed-off-by: Simon Glass sjg@chromium.org > > > >--- > > > > > > > > MAINTAINERS | 8 ++ > > > > doc/board/emulation/index.rst | 1 + > > > > doc/board/emulation/script.rst | 61 ++++++++++++ > > > > scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ > > > > 4 files changed, 245 insertions(+) > > > > create mode 100644 doc/board/emulation/script.rst > > > > create mode 100755 scripts/build-qemu.sh > > > > > > > >diff --git a/MAINTAINERS b/MAINTAINERS > > > >index 0399ed1dbf6..b45bb96d5a5 100644 > > > >--- a/MAINTAINERS > > > >+++ b/MAINTAINERS > > > >@@ -1110,6 +1110,14 @@ F: tools/efivar.py > > > > F: tools/file2include.c > > > > F: tools/mkeficapsule.c > > > > > > > >+EMULATION > > > >+M: Simon Glass sjg@chromium.org > > > >+S: Maintained > > > >+W: https://docs.u-boot.org/en/latest/board/emulation/script.html > > > >+F: configs/qemu_x86* > > > >+F: doc/board/emulation/script.rst > > > >+F: scripts/build-qemu.sh > > > > > > Please, avoid misnomers. This script does not build QEMU. > > > > > > >+ > > > > ENVIRONMENT > > > > M: Joe Hershberger joe.hershberger@ni.com > > > > S: Maintained > > > >diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst > > > >index f8908166276..5a2a00ae225 100644 > > > >--- a/doc/board/emulation/index.rst > > > >+++ b/doc/board/emulation/index.rst > > > >@@ -8,6 +8,7 @@ Emulation > > > > > > > > acpi > > > > blkdev > > > >+ script > > > > qemu-arm > > > > qemu-mips > > > > qemu-ppce500 > > > >diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst > > > > > > Just another misnomer. This page is not about script.sh. > > > > > > >new file mode 100644 > > > >index 00000000000..23981e333cb > > > >--- /dev/null > > > >+++ b/doc/board/emulation/script.rst > > > >@@ -0,0 +1,61 @@ > > > >+.. SPDX-License-Identifier: GPL-2.0+ > > > > > > This is not a valid SPDX identifier. > > > > > > >+ > > > >+Script for building and running > > > >+=============================== > > > >+ > > > >+You may find the script `scripts/build-qemu.sh` helpful for building and testing > > > >+U-Boot on QEMU. > > > >+ > > > >+If uses a environment variables to control how it works: > > > >+ > > > >+ubdir > > > >+ base directory for building U-Boot, with each board being in its own > > > >+ subdirectory > > > >+ > > > >+imagedir > > > >+ directory containing OS images, containin a subdirectory for each distro > > > >+ type (e.g. ubuntu/ > > > >+ > > > >+Once configured, you can build and run QEMU for arm64 like this:: > > > > > > This downloads the QEMU source and builds it? > > > > > > >+ > > > >+ scripts/build-qemu.sh -rsw > > > >+ > > > >+No support is currently included for specifying a root disk, so this script can > > > >+only be used to start installers. > > > >+ > > > >+Options > > > >+~~~~~~~ > > > >+ > > > >+Options are available to control the script: > > > >+ > > > >+-a <arch> > > > >+ Select architecture (default arm, x86) > > > >+ > > > >+-B > > > >+ Don't build; assume a build exists > > > >+ > > > >+-k > > > >+ Use kvm - kernel-based Virtual Machine. By default QEMU uses its own > > > >+ emulator > > > >+ > > > >+-o <os> > > > >+ Run an Operating System. For now this only supports 'ubuntu'. The name of > > > >+ the OS file must remain unchanged from its standard name on the Ubuntu > > > >+ website. > > > > > > The U-Boot project should remain open to all operating systems. How will this work with OpenBSD? > > > > > > Use the URL of the image as argument. > > > > > > >+ > > > >+-r > > > >+ Run QEMU with the image (by default this is not done) > > > >+ > > > >+-R > > > >+ Select OS release (e.g. 24.04). > > > >+ > > > >+-s > > > >+ Use serial only (no display) > > > >+ > > > >+-w > > > >+ Use word version (32-bit). By default, 64-bit is used > > > > > > "word version" is not helpful as explanation. > > > > > > Look at https://en.m.wikipedia.org/wiki/Word_(computer_architecture) which says a word is 64 bit on a 64-bit system and 16 bit on a 16-bit system. > > > > > > >+ > > > >+.. note:: > > > >+ > > > >+ Note: For now this is a shell script, but if it expands it might be better > > > >+ as Python, accepting the slower startup. > > > >diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh > > > >new file mode 100755 > > > >index 00000000000..0ff53593cf9 > > > >--- /dev/null > > > >+++ b/scripts/build-qemu.sh > > > >@@ -0,0 +1,175 @@ > > > >+#!/bin/bash > > > >+# SPDX-License-Identifier: GPL-2.0+ > > > > > > This is not a valid SPDX identifier. > > > > > > >+# > > > >+# Script to build U-Boot suitable for booting with QEMU, possibly running > > > >+# it, possibly with an OS image > > > >+ > > > >+# This just an example. It assumes that > > > >+ > > > >+# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config > > > >+# - your OS images are in ${imagedir}/{distroname}/... > > > >+ > > > >+# So far the script supports only ARM and x86. > > > > > > Why support obsolete i386 but not riscv64? > > > > > > >+ > > > >+set -e > > > >+ > > > >+usage() { > > > >+ ( > > > >+ if [[ -n "$1" ]]; then > > > >+ echo "$1" > > > >+ echo > > > >+ fi > > > >+ echo "Usage: $0 -aBkrsw" > > > >+ echo > > > >+ echo " -a - Select architecture (arm, x86)" > > > >+ echo " -B - Don't build; assume a build exists" > > > >+ echo " -k - Use kvm (kernel-based Virtual Machine)" > > > >+ echo " -o - Run Operating System ('ubuntu' only for now)" > > > >+ echo " -r - Run QEMU with the image" > > > >+ echo " -R - Select OS release (e.g. 24.04)" > > > >+ echo " -s - Use serial only (no display)" > > > >+ echo " -w - Use word version (32-bit)" ) >&2 > > > >+ exit 1 > > > >+} > > > >+ > > > >+# Directory tree for OS images > > > >+imagedir=${imagedir-/vid/software/linux} > > > >+ > > > >+# architecture (arm or x86) > > > >+arch=arm > > > >+ > > > >+# 32- or 64-bit build > > > >+bitness=64 > > > >+ > > > >+# Build U-Boot > > > >+build=yes > > > >+ > > > >+# Extra setings > > > >+extra= > > > >+ > > > >+# Operating System to boot (ubuntu) > > > >+os= > > > >+ > > > >+release=24.04.1 > > > >+ > > > >+# run the image with QEMU > > > >+run= > > > >+ > > > >+# run QEMU without a display (U-Boot must be set to stdout=serial) > > > >+serial= > > > >+ > > > >+# Use kvm > > > >+kvm= > > > >+ > > > >+# Set ubdir to the build directory where you build U-Boot out-of-tree > > > >+# We avoid in-tree build because it gets confusing trying different builds > > > >+ubdir=${ubdir-/tmp/b} > > > >+ > > > >+while getopts "a:Bko:rR:sw" opt; do > > > >+ case "${opt}" in > > > >+ a) > > > >+ arch=$OPTARG > > > >+ ;; > > > >+ B) > > > >+ build= > > > >+ ;; > > > >+ k) > > > >+ kvm="-enable-kvm" > > > >+ ;; > > > >+ o) > > > >+ os=$OPTARG > > > >+ > > > >+ # Expand memory and CPUs > > > >+ extra+=" -m 4G -smp 4" > > > >+ ;; > > > >+ r) > > > >+ run=1 > > > >+ ;; > > > >+ R) > > > >+ release=$OPTARG > > > >+ ;; > > > >+ s) > > > >+ serial=1 > > > >+ ;; > > > >+ w) > > > >+ bitness=32 > > > >+ ;; > > > >+ *) > > > >+ usage > > > >+ ;; > > > >+ esac > > > >+done > > > >+ > > > >+# Build U-Boot for the selected board > > > >+build_u_boot() { > > > >+ buildman -w -o $DIR --board $BOARD -I || exit $? > > > >+} > > > >+ > > > >+# Run QEMU with U-Boot > > > >+run_qemu() { > > > >+ if [[ -n "${os_image}" ]]; then > > > >+ extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" > > > >+ fi > > > >+ if [[ -n "${serial}" ]]; then > > > >+ extra+=" -display none -serial mon:stdio" > > > >+ else > > > >+ extra+=" -serial mon:stdio" > > > >+ fi > > > >+ echo "Running ${qemu} ${extra}" > > > >+ "${qemu}" -bios "$DIR/${BIOS}" \ > > > >+ -m 512 \ > > > > > > Ubuntu suggests 4 GiB as minimum for a desktop. > > > > > > >+ -nic none \ > > > > > > Who wants to run without network? > > > Use the virtio nic. > > > > > > >+ ${kvm} \ > > > >+ ${extra} > > > >+} > > > >+ > > > >+# Check architecture > > > >+case "${arch}" in > > > >+arm) > > > >+ BOARD="qemu_arm" > > > >+ BIOS="u-boot.bin" > > > >+ qemu=qemu-system-arm > > > >+ extra+=" -machine virt" > > > >+ suffix="arm" > > > >+ if [[ "${bitness}" == "64" ]]; then > > > >+ BOARD="qemu_arm64" > > > >+ qemu=qemu-system-aarch64 > > > >+ extra+=" -cpu cortex-a57" > > > > > > That CPU is 12 years old and not all distros are stuck on ARM v8.0. See https://en.opensuse.org/Arm_architecture_support. > > > > > > -cpu max works fine with both tcg and kvm. > > > > > > >+ suffix="arm64" > > > > > > >+ fi > > > >+ ;; > > > >+x86) > > > >+ BOARD="qemu-x86" > > > >+ BIOS="u-boot.rom" > > > >+ qemu=qemu-system-i386 > > > >+ suffix="i386" > > > >+ if [[ "${bitness}" == "64" ]]; then > > > >+ BOARD="qemu-x86_64" > > > >+ qemu=qemu-system-x86_64 > > > >+ suffix="amd64" > > > >+ fi > > > >+ ;; > > > >+*) > > > >+ usage "Unknown architecture '${arch}'" > > > >+esac > > > >+ > > > >+# Check OS > > > >+case "${os}" in > > > >+ubuntu) > > > >+ os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso" > > > > > > There is no ARM 32-bit Ubuntu desktop. And for i386 there is no image in 24.04.1. > > > > > > Running a foreign architecture desktop with tcg is not enjoyable. > > > > > > For testing U-Boot a server image is all it takes. > > > > And _all_ of this is why I don't want to add a useful personal script > > as an additional tool we support. I've seen how much work goes in to the > > OpenEmbedded runqemu script, we don't have the spare cycles for > > something like that. Doubly so when ultimately I believe we would be > > well served by having a document that says (in much more words) to look > > at u-boot-test-hooks for how to invoke QEMU for a large number of > > architectures and platforms and to then further leverage general QEMU > > tips and guides on how to run an OS of your choice with that. > > I'm not sure it matters that much. Everyone is going to have their > preference as to how this script should look, but no one else has > taken the time to write one... > > People are free to send patches to enhance it. But I believe it is > helpful, e.g. for repeating problems caused by recent lmb patches. > > Re the test hooks, I just get tired of looking them up and trying to > figure out what to do. Every board name and arch is slightly > different. Just a hassle that I don't need. > > We can put it in scripts/contrib if you like.
OK well I think we've reached a dead end here. If you'd like to create a repo for it, please do. I can then try it out and see how useful it is for me. I wonder if it should share the u-boot-test-hooks thing to reduce the number of repos? Rename to u-boot-extra ?
For u-boot-test-hooks at some point you said you don't want to take patches specific to my setup, so it has become a complete mess on my side, with different versions for upstream Labgrid, etc. Just some feedback...
On Fri, Jan 10, 2025 at 12:50:20PM -0700, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Fri, Nov 15, 2024 at 09:14:03AM -0600, Tom Rini wrote: > On Fri, Nov 15, 2024 at 07:21:47AM -0700, Simon Glass wrote: > > Hi Tom, > > > > On Tue, 12 Nov 2024 at 17:54, Tom Rini trini@konsulko.com wrote: > > > > > > On Wed, Nov 13, 2024 at 01:49:30AM +0100, Heinrich Schuchardt wrote: > > > > Am 12. November 2024 14:58:54 MEZ schrieb Simon Glass sjg@chromium.org: > > > > >It is handy to be able to quickly build and boot a QEMU image for a > > > > >particular architecture and distro. > > > > > > > > > >Add a script for this purpose. It supports only arm and x86 at present. > > > > >For distros it only supports Ubuntu. Both 32- and 64-bit builds are > > > > >supported. > > > > > > > > > >Signed-off-by: Simon Glass sjg@chromium.org > > > > >--- > > > > > > > > > > MAINTAINERS | 8 ++ > > > > > doc/board/emulation/index.rst | 1 + > > > > > doc/board/emulation/script.rst | 61 ++++++++++++ > > > > > scripts/build-qemu.sh | 175 +++++++++++++++++++++++++++++++++ > > > > > 4 files changed, 245 insertions(+) > > > > > create mode 100644 doc/board/emulation/script.rst > > > > > create mode 100755 scripts/build-qemu.sh > > > > > > > > > >diff --git a/MAINTAINERS b/MAINTAINERS > > > > >index 0399ed1dbf6..b45bb96d5a5 100644 > > > > >--- a/MAINTAINERS > > > > >+++ b/MAINTAINERS > > > > >@@ -1110,6 +1110,14 @@ F: tools/efivar.py > > > > > F: tools/file2include.c > > > > > F: tools/mkeficapsule.c > > > > > > > > > >+EMULATION > > > > >+M: Simon Glass sjg@chromium.org > > > > >+S: Maintained > > > > >+W: https://docs.u-boot.org/en/latest/board/emulation/script.html > > > > >+F: configs/qemu_x86* > > > > >+F: doc/board/emulation/script.rst > > > > >+F: scripts/build-qemu.sh > > > > > > > > Please, avoid misnomers. This script does not build QEMU. > > > > > > > > >+ > > > > > ENVIRONMENT > > > > > M: Joe Hershberger joe.hershberger@ni.com > > > > > S: Maintained > > > > >diff --git a/doc/board/emulation/index.rst b/doc/board/emulation/index.rst > > > > >index f8908166276..5a2a00ae225 100644 > > > > >--- a/doc/board/emulation/index.rst > > > > >+++ b/doc/board/emulation/index.rst > > > > >@@ -8,6 +8,7 @@ Emulation > > > > > > > > > > acpi > > > > > blkdev > > > > >+ script > > > > > qemu-arm > > > > > qemu-mips > > > > > qemu-ppce500 > > > > >diff --git a/doc/board/emulation/script.rst b/doc/board/emulation/script.rst > > > > > > > > Just another misnomer. This page is not about script.sh. > > > > > > > > >new file mode 100644 > > > > >index 00000000000..23981e333cb > > > > >--- /dev/null > > > > >+++ b/doc/board/emulation/script.rst > > > > >@@ -0,0 +1,61 @@ > > > > >+.. SPDX-License-Identifier: GPL-2.0+ > > > > > > > > This is not a valid SPDX identifier. > > > > > > > > >+ > > > > >+Script for building and running > > > > >+=============================== > > > > >+ > > > > >+You may find the script `scripts/build-qemu.sh` helpful for building and testing > > > > >+U-Boot on QEMU. > > > > >+ > > > > >+If uses a environment variables to control how it works: > > > > >+ > > > > >+ubdir > > > > >+ base directory for building U-Boot, with each board being in its own > > > > >+ subdirectory > > > > >+ > > > > >+imagedir > > > > >+ directory containing OS images, containin a subdirectory for each distro > > > > >+ type (e.g. ubuntu/ > > > > >+ > > > > >+Once configured, you can build and run QEMU for arm64 like this:: > > > > > > > > This downloads the QEMU source and builds it? > > > > > > > > >+ > > > > >+ scripts/build-qemu.sh -rsw > > > > >+ > > > > >+No support is currently included for specifying a root disk, so this script can > > > > >+only be used to start installers. > > > > >+ > > > > >+Options > > > > >+~~~~~~~ > > > > >+ > > > > >+Options are available to control the script: > > > > >+ > > > > >+-a <arch> > > > > >+ Select architecture (default arm, x86) > > > > >+ > > > > >+-B > > > > >+ Don't build; assume a build exists > > > > >+ > > > > >+-k > > > > >+ Use kvm - kernel-based Virtual Machine. By default QEMU uses its own > > > > >+ emulator > > > > >+ > > > > >+-o <os> > > > > >+ Run an Operating System. For now this only supports 'ubuntu'. The name of > > > > >+ the OS file must remain unchanged from its standard name on the Ubuntu > > > > >+ website. > > > > > > > > The U-Boot project should remain open to all operating systems. How will this work with OpenBSD? > > > > > > > > Use the URL of the image as argument. > > > > > > > > >+ > > > > >+-r > > > > >+ Run QEMU with the image (by default this is not done) > > > > >+ > > > > >+-R > > > > >+ Select OS release (e.g. 24.04). > > > > >+ > > > > >+-s > > > > >+ Use serial only (no display) > > > > >+ > > > > >+-w > > > > >+ Use word version (32-bit). By default, 64-bit is used > > > > > > > > "word version" is not helpful as explanation. > > > > > > > > Look at https://en.m.wikipedia.org/wiki/Word_(computer_architecture) which says a word is 64 bit on a 64-bit system and 16 bit on a 16-bit system. > > > > > > > > >+ > > > > >+.. note:: > > > > >+ > > > > >+ Note: For now this is a shell script, but if it expands it might be better > > > > >+ as Python, accepting the slower startup. > > > > >diff --git a/scripts/build-qemu.sh b/scripts/build-qemu.sh > > > > >new file mode 100755 > > > > >index 00000000000..0ff53593cf9 > > > > >--- /dev/null > > > > >+++ b/scripts/build-qemu.sh > > > > >@@ -0,0 +1,175 @@ > > > > >+#!/bin/bash > > > > >+# SPDX-License-Identifier: GPL-2.0+ > > > > > > > > This is not a valid SPDX identifier. > > > > > > > > >+# > > > > >+# Script to build U-Boot suitable for booting with QEMU, possibly running > > > > >+# it, possibly with an OS image > > > > >+ > > > > >+# This just an example. It assumes that > > > > >+ > > > > >+# - you build U-Boot in ${ubdir}/<name> where <name> is the U-Boot board config > > > > >+# - your OS images are in ${imagedir}/{distroname}/... > > > > >+ > > > > >+# So far the script supports only ARM and x86. > > > > > > > > Why support obsolete i386 but not riscv64? > > > > > > > > >+ > > > > >+set -e > > > > >+ > > > > >+usage() { > > > > >+ ( > > > > >+ if [[ -n "$1" ]]; then > > > > >+ echo "$1" > > > > >+ echo > > > > >+ fi > > > > >+ echo "Usage: $0 -aBkrsw" > > > > >+ echo > > > > >+ echo " -a - Select architecture (arm, x86)" > > > > >+ echo " -B - Don't build; assume a build exists" > > > > >+ echo " -k - Use kvm (kernel-based Virtual Machine)" > > > > >+ echo " -o - Run Operating System ('ubuntu' only for now)" > > > > >+ echo " -r - Run QEMU with the image" > > > > >+ echo " -R - Select OS release (e.g. 24.04)" > > > > >+ echo " -s - Use serial only (no display)" > > > > >+ echo " -w - Use word version (32-bit)" ) >&2 > > > > >+ exit 1 > > > > >+} > > > > >+ > > > > >+# Directory tree for OS images > > > > >+imagedir=${imagedir-/vid/software/linux} > > > > >+ > > > > >+# architecture (arm or x86) > > > > >+arch=arm > > > > >+ > > > > >+# 32- or 64-bit build > > > > >+bitness=64 > > > > >+ > > > > >+# Build U-Boot > > > > >+build=yes > > > > >+ > > > > >+# Extra setings > > > > >+extra= > > > > >+ > > > > >+# Operating System to boot (ubuntu) > > > > >+os= > > > > >+ > > > > >+release=24.04.1 > > > > >+ > > > > >+# run the image with QEMU > > > > >+run= > > > > >+ > > > > >+# run QEMU without a display (U-Boot must be set to stdout=serial) > > > > >+serial= > > > > >+ > > > > >+# Use kvm > > > > >+kvm= > > > > >+ > > > > >+# Set ubdir to the build directory where you build U-Boot out-of-tree > > > > >+# We avoid in-tree build because it gets confusing trying different builds > > > > >+ubdir=${ubdir-/tmp/b} > > > > >+ > > > > >+while getopts "a:Bko:rR:sw" opt; do > > > > >+ case "${opt}" in > > > > >+ a) > > > > >+ arch=$OPTARG > > > > >+ ;; > > > > >+ B) > > > > >+ build= > > > > >+ ;; > > > > >+ k) > > > > >+ kvm="-enable-kvm" > > > > >+ ;; > > > > >+ o) > > > > >+ os=$OPTARG > > > > >+ > > > > >+ # Expand memory and CPUs > > > > >+ extra+=" -m 4G -smp 4" > > > > >+ ;; > > > > >+ r) > > > > >+ run=1 > > > > >+ ;; > > > > >+ R) > > > > >+ release=$OPTARG > > > > >+ ;; > > > > >+ s) > > > > >+ serial=1 > > > > >+ ;; > > > > >+ w) > > > > >+ bitness=32 > > > > >+ ;; > > > > >+ *) > > > > >+ usage > > > > >+ ;; > > > > >+ esac > > > > >+done > > > > >+ > > > > >+# Build U-Boot for the selected board > > > > >+build_u_boot() { > > > > >+ buildman -w -o $DIR --board $BOARD -I || exit $? > > > > >+} > > > > >+ > > > > >+# Run QEMU with U-Boot > > > > >+run_qemu() { > > > > >+ if [[ -n "${os_image}" ]]; then > > > > >+ extra+=" -drive if=virtio,file=${os_image},format=raw,id=hd0" > > > > >+ fi > > > > >+ if [[ -n "${serial}" ]]; then > > > > >+ extra+=" -display none -serial mon:stdio" > > > > >+ else > > > > >+ extra+=" -serial mon:stdio" > > > > >+ fi > > > > >+ echo "Running ${qemu} ${extra}" > > > > >+ "${qemu}" -bios "$DIR/${BIOS}" \ > > > > >+ -m 512 \ > > > > > > > > Ubuntu suggests 4 GiB as minimum for a desktop. > > > > > > > > >+ -nic none \ > > > > > > > > Who wants to run without network? > > > > Use the virtio nic. > > > > > > > > >+ ${kvm} \ > > > > >+ ${extra} > > > > >+} > > > > >+ > > > > >+# Check architecture > > > > >+case "${arch}" in > > > > >+arm) > > > > >+ BOARD="qemu_arm" > > > > >+ BIOS="u-boot.bin" > > > > >+ qemu=qemu-system-arm > > > > >+ extra+=" -machine virt" > > > > >+ suffix="arm" > > > > >+ if [[ "${bitness}" == "64" ]]; then > > > > >+ BOARD="qemu_arm64" > > > > >+ qemu=qemu-system-aarch64 > > > > >+ extra+=" -cpu cortex-a57" > > > > > > > > That CPU is 12 years old and not all distros are stuck on ARM v8.0. See https://en.opensuse.org/Arm_architecture_support. > > > > > > > > -cpu max works fine with both tcg and kvm. > > > > > > > > >+ suffix="arm64" > > > > > > > > >+ fi > > > > >+ ;; > > > > >+x86) > > > > >+ BOARD="qemu-x86" > > > > >+ BIOS="u-boot.rom" > > > > >+ qemu=qemu-system-i386 > > > > >+ suffix="i386" > > > > >+ if [[ "${bitness}" == "64" ]]; then > > > > >+ BOARD="qemu-x86_64" > > > > >+ qemu=qemu-system-x86_64 > > > > >+ suffix="amd64" > > > > >+ fi > > > > >+ ;; > > > > >+*) > > > > >+ usage "Unknown architecture '${arch}'" > > > > >+esac > > > > >+ > > > > >+# Check OS > > > > >+case "${os}" in > > > > >+ubuntu) > > > > >+ os_image="${imagedir}/${os}/${os}-${release}-desktop-${suffix}.iso" > > > > > > > > There is no ARM 32-bit Ubuntu desktop. And for i386 there is no image in 24.04.1. > > > > > > > > Running a foreign architecture desktop with tcg is not enjoyable. > > > > > > > > For testing U-Boot a server image is all it takes. > > > > > > And _all_ of this is why I don't want to add a useful personal script > > > as an additional tool we support. I've seen how much work goes in to the > > > OpenEmbedded runqemu script, we don't have the spare cycles for > > > something like that. Doubly so when ultimately I believe we would be > > > well served by having a document that says (in much more words) to look > > > at u-boot-test-hooks for how to invoke QEMU for a large number of > > > architectures and platforms and to then further leverage general QEMU > > > tips and guides on how to run an OS of your choice with that. > > > > I'm not sure it matters that much. Everyone is going to have their > > preference as to how this script should look, but no one else has > > taken the time to write one... > > > > People are free to send patches to enhance it. But I believe it is > > helpful, e.g. for repeating problems caused by recent lmb patches. > > > > Re the test hooks, I just get tired of looking them up and trying to > > figure out what to do. Every board name and arch is slightly > > different. Just a hassle that I don't need. > > > > We can put it in scripts/contrib if you like. > > It's handy to point people to scripts, yes. I frequently point people at > my wrappers around buildman for example for "how do I find code bloat?" > and similar. But no, I don't think this rises to the level of > "scripts/contrib".
I've created a "u-boot-extras" repository at the top level, added you as well to the maintainers (aside, any other custodians that want to contribute scripts/etc here are welcome to DM me for write access), and added "u-boot-size-test.sh" to "contrib/trini". Please feel free to start populating "contrib/sjg" with any/all scripts you feel are ready for public viewing / use.
FWIW, your labgrid is in u-boot-test-hooks as well and has been for a while. I had to rebase my local branches on top of that, but it was mostly progmatic sed'ing. I'm still less clear on the value of putting all of the lab details in a public repository instead of just example levels, but I'm open to changing my mind there if that will really help.
The SPL and pre-reloc malloc()-space is not large enough to start up with a display. Expand it.
Switch the order of SPL_SYS_MALLOC_F_LEN and SPL_TEXT_BASE since this matches what 'savedefconfig' gives us.
configs/qemu-x86_64_defconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 008eb46a01c..218c3535d15 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -1,13 +1,13 @@ CONFIG_X86=y CONFIG_TEXT_BASE=0x1110000 -CONFIG_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SYS_MALLOC_F_LEN=0x1800 CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x40000 CONFIG_MAX_CPUS=2 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" +CONFIG_SPL_SYS_MALLOC_F_LEN=0x4800 CONFIG_SPL_TEXT_BASE=0xfffd4000 -CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_X86_RUN_64BIT=y
The vesa display is widely used on hardware, but it is a bit of a pain with QEMU. It requires executing option ROMs, which either doesn't work with kvm, or is difficult to do in a kvm/QEMU-friendly way.
THe bochs display is probably better anyway, so switch to that. It works fine with kvm as it doesn't need an option ROM.
Unfortunately this causes the Ubuntu 22.04 installer to stop booting, which needs further investigation
Signed-off-by: Simon Glass sjg@chromium.org Fixes: https://source.denx.de/u-boot/custodians/u-boot-dm/-/issues/31 ---
configs/qemu-x86_64_defconfig | 5 ++--- configs/qemu-x86_defconfig | 5 ++--- 2 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 218c3535d15..1670c122002 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -81,9 +81,8 @@ CONFIG_SYS_NS16550_PORT_MAPPED=y CONFIG_SPI=y CONFIG_USB_KEYBOARD=y CONFIG_CONSOLE_TRUETYPE=y -CONFIG_FRAMEBUFFER_SET_VESA_MODE=y -CONFIG_FRAMEBUFFER_VESA_MODE_USER=y -CONFIG_FRAMEBUFFER_VESA_MODE=0x144 +CONFIG_VIDEO_BOCHS=y +# CONFIG_VIDEO_VESA is not set CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_SPL_VIDEO=y # CONFIG_SPL_USE_TINY_PRINTF is not set diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 947d15cd727..40c2f1cd362 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -58,9 +58,8 @@ CONFIG_SYS_NS16550_PORT_MAPPED=y CONFIG_SPI=y CONFIG_USB_KEYBOARD=y CONFIG_CONSOLE_TRUETYPE=y -CONFIG_FRAMEBUFFER_SET_VESA_MODE=y -CONFIG_FRAMEBUFFER_VESA_MODE_USER=y -CONFIG_FRAMEBUFFER_VESA_MODE=0x144 +CONFIG_VIDEO_BOCHS=y +# CONFIG_VIDEO_VESA is not set CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_GENERATE_ACPI_TABLE=y # CONFIG_GZIP is not set
Provide the 'dhry' command, which helps to check that kvm is being used properly with QEMU.
configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 1670c122002..151c5f3e0e7 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -87,4 +87,5 @@ CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_SPL_VIDEO=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_CMD_DHRYSTONE=y # CONFIG_GZIP is not set diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 40c2f1cd362..5c5cacd734c 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -62,4 +62,5 @@ CONFIG_VIDEO_BOCHS=y # CONFIG_VIDEO_VESA is not set CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_CMD_DHRYSTONE=y # CONFIG_GZIP is not set
BSS is placed in DRAM which is actually available early with QEMU. But it is cleared by the init sequence, so values stored there are lost.
Move the system-type flag into a function, instead.
arch/x86/cpu/qemu/qemu.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index 563f63e2bc8..e846ccd44aa 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -15,14 +15,21 @@ #include <asm/arch/qemu.h> #include <asm/u-boot-x86.h>
-static bool i440fx; - #if CONFIG_IS_ENABLED(QFW_PIO) U_BOOT_DRVINFO(x86_qfw_pio) = { .name = "qfw_pio", }; #endif
+static bool is_i440fx(void) +{ + u16 device; + + pci_read_config16(PCI_BDF(0, 0, 0), PCI_DEVICE_ID, &device); + + return device == PCI_DEVICE_ID_INTEL_82441; +} + static void enable_pm_piix(void) { u8 en; @@ -50,16 +57,17 @@ static void enable_pm_ich9(void)
void qemu_chipset_init(void) { - u16 device, xbcs; + bool i440fx; + u16 xbcs; int pam, i;
+ i440fx = is_i440fx(); + /* * i440FX and Q35 chipset have different PAM register offset, but with * the same bitfield layout. Here we determine the offset based on its * PCI device ID. */ - pci_read_config16(PCI_BDF(0, 0, 0), PCI_DEVICE_ID, &device); - i440fx = (device == PCI_DEVICE_ID_INTEL_82441); pam = i440fx ? I440FX_PAM : Q35_PAM;
/* @@ -123,7 +131,7 @@ int mp_determine_pci_dstirq(int bus, int dev, int func, int pirq) { u8 irq;
- if (i440fx) { + if (is_i440fx()) { /* * Not like most x86 platforms, the PIRQ[A-D] on PIIX3 are not * connected to I/O APIC INTPIN#16-19. Instead they are routed
This is not needed in SPL, so drop it.
arch/x86/lib/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 43e6a1de77d..a908356e8a6 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -26,7 +26,9 @@ obj-y += e820.o obj-y += init_helpers.o obj-y += interrupts.o obj-y += lpc-uclass.o +ifndef CONFIG_XPL_BUILD obj-y += mpspec.o +endif obj-$(CONFIG_$(PHASE_)ACPIGEN) += acpi_nhlt.o obj-y += northbridge-uclass.o obj-$(CONFIG_I8259_PIC) += i8259.o
Add categories for i8259 and bios files, so that log statements have the right category.
arch/x86/lib/bios.c | 3 +++ arch/x86/lib/bios_interrupts.c | 2 ++ arch/x86/lib/i8259.c | 2 ++ 3 files changed, 7 insertions(+)
diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 03f7360032c..acae635cf19 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -5,6 +5,9 @@ * Copyright (C) 2007 Advanced Micro Devices, Inc. * Copyright (C) 2009-2010 coresystems GmbH */ + +#define LOG_CATEGRORY LOGC_ARCH + #include <compiler.h> #include <bios_emul.h> #include <irq_func.h> diff --git a/arch/x86/lib/bios_interrupts.c b/arch/x86/lib/bios_interrupts.c index b2cf1527b1c..3ae6c193ec7 100644 --- a/arch/x86/lib/bios_interrupts.c +++ b/arch/x86/lib/bios_interrupts.c @@ -7,6 +7,8 @@ * Copyright (C) 2007-2009 coresystems GmbH */
+#define LOG_CATEGRORY LOGC_ARCH + #include <log.h> #include <asm/pci.h> #include "bios_emul.h" diff --git a/arch/x86/lib/i8259.c b/arch/x86/lib/i8259.c index 465ff70146f..088f78f4661 100644 --- a/arch/x86/lib/i8259.c +++ b/arch/x86/lib/i8259.c @@ -13,6 +13,8 @@ * Programmable Interrupt Controllers. */
+#define LOG_CATEGORY UCLASS_IRQ + #include <log.h> #include <asm/io.h> #include <asm/i8259.h>
This option is not actually defined in Kconfig anymore. Use a normal debug print instead, which has a similar effect.
arch/x86/lib/bios.c | 18 ++++++++---------- arch/x86/lib/bios_interrupts.c | 6 ++---- 2 files changed, 10 insertions(+), 14 deletions(-)
diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index acae635cf19..5dfe5a647eb 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -301,16 +301,14 @@ asmlinkage int interrupt_handler(u32 intnumber, u32 gsfs, u32 dses, cs = cs_ip >> 16; flags = stackflags;
-#ifdef CONFIG_REALMODE_DEBUG - debug("oprom: INT# 0x%x\n", intnumber); - debug("oprom: eax: %08x ebx: %08x ecx: %08x edx: %08x\n", - eax, ebx, ecx, edx); - debug("oprom: ebp: %08x esp: %08x edi: %08x esi: %08x\n", - ebp, esp, edi, esi); - debug("oprom: ip: %04x cs: %04x flags: %08x\n", - ip, cs, flags); - debug("oprom: stackflags = %04x\n", stackflags); -#endif + log_debug("oprom: INT# 0x%x\n", intnumber); + log_debug("oprom: eax: %08x ebx: %08x ecx: %08x edx: %08x\n", + eax, ebx, ecx, edx); + log_debug("oprom: ebp: %08x esp: %08x edi: %08x esi: %08x\n", + ebp, esp, edi, esi); + log_debug("oprom: ip: %04x cs: %04x flags: %08x\n", + ip, cs, flags); + log_debug("oprom: stackflags = %04x\n", stackflags);
/* * Fetch arguments from the stack and put them to a place diff --git a/arch/x86/lib/bios_interrupts.c b/arch/x86/lib/bios_interrupts.c index 3ae6c193ec7..e0c2284a901 100644 --- a/arch/x86/lib/bios_interrupts.c +++ b/arch/x86/lib/bios_interrupts.c @@ -200,10 +200,8 @@ int int1a_handler(void) dm_pci_write_config32(dev, reg, dword); break; } -#ifdef CONFIG_REALMODE_DEBUG - debug("0x%x: bus %d devfn 0x%x reg 0x%x val 0x%x\n", func, - bus, devfn, reg, M.x86.R_ECX); -#endif + log_debug("0x%x: bus %d devfn 0x%x reg 0x%x val 0x%x\n", func, + bus, devfn, reg, M.x86.R_ECX); M.x86.R_EAX &= 0xffff00ff; /* Clear AH */ M.x86.R_EAX |= PCIBIOS_SUCCESSFUL; retval = 1;
U-Boot clears the display when it starts up, so there is no need to ask the VESA driver to do this. Fix this and add a comment explaining the flags.
arch/x86/lib/bios.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/bios.c b/arch/x86/lib/bios.c index 5dfe5a647eb..de4578666fb 100644 --- a/arch/x86/lib/bios.c +++ b/arch/x86/lib/bios.c @@ -231,7 +231,11 @@ static void vbe_set_graphics(int vesa_mode, struct vesa_state *mode_info) { unsigned char *framebuffer;
- mode_info->video_mode = (1 << 14) | vesa_mode; + /* + * bit 14 is linear-framebuffer mode + * bit 15 means don't clear the display + */ + mode_info->video_mode = (1 << 14) | (1 << 15) | vesa_mode; vbe_get_mode_info(mode_info);
framebuffer = (unsigned char *)(ulong)mode_info->vesa.phys_base_ptr;
At present it is not possible to execution 64-bit code without installing an entire new Global Descriptor Table. This is inconvenient since kvm does not seem to like switching into long mode with a new table.
It isn't actually necessary, since we can just extend the existing table. Add some new entries to this effect.
arch/x86/cpu/i386/cpu.c | 3 +++ arch/x86/include/asm/processor.h | 5 ++++- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index a51a24498a7..3bbad3b2eca 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -160,6 +160,9 @@ void arch_setup_gd(gd_t *new_gd)
gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_CS] = GDT_ENTRY(0x809b, 0, 0xfffff); gdt_addr[X86_GDT_ENTRY_16BIT_FLAT_DS] = GDT_ENTRY(0x8093, 0, 0xfffff); + gdt_addr[X86_GDT_ENTRY_64BIT_CS] = GDT_ENTRY(0xaf9b, 0, 0xfffff); + gdt_addr[X86_GDT_ENTRY_64BIT_TS1] = GDT_ENTRY(0x8980, 0, 0xfffff); + gdt_addr[X86_GDT_ENTRY_64BIT_TS2] = 0;
load_gdt(gdt_addr, X86_GDT_NUM_ENTRIES); load_ds(X86_GDT_ENTRY_32BIT_DS); diff --git a/arch/x86/include/asm/processor.h b/arch/x86/include/asm/processor.h index d7b68367861..ad8240be387 100644 --- a/arch/x86/include/asm/processor.h +++ b/arch/x86/include/asm/processor.h @@ -18,7 +18,10 @@ #define X86_GDT_ENTRY_16BIT_DS 6 #define X86_GDT_ENTRY_16BIT_FLAT_CS 7 #define X86_GDT_ENTRY_16BIT_FLAT_DS 8 -#define X86_GDT_NUM_ENTRIES 9 +#define X86_GDT_ENTRY_64BIT_CS 9 +#define X86_GDT_ENTRY_64BIT_TS1 10 +#define X86_GDT_ENTRY_64BIT_TS2 11 +#define X86_GDT_NUM_ENTRIES 12
#define X86_GDT_SIZE (X86_GDT_NUM_ENTRIES * X86_GDT_ENTRY_SIZE)
Use some named flags when setting up the cache, so it is easier to see what is going on.
arch/x86/cpu/i386/cpu.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index 3bbad3b2eca..845e00ca439 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -592,6 +592,13 @@ int cpu_has_64bit(void) #define PAGETABLE_BASE 0x80000 #define PAGETABLE_SIZE (6 * 4096)
+#define _PRES BIT(0) /* present */ +#define _RW BIT(1) /* write allowed */ +#define _US BIT(2) /* user-access allowed */ +#define _A BIT(5) /* has been accessed */ +#define _D BIT(6) /* has been written to */ +#define _PS BIT(7) /* indicates 2MB page size here */ + /** * build_pagetable() - build a flat 4GiB page table structure for 64-bti mode * @@ -604,15 +611,17 @@ static void build_pagetable(uint32_t *pgtable) memset(pgtable, '\0', PAGETABLE_SIZE);
/* Level 4 needs a single entry */ - pgtable[0] = (ulong)&pgtable[1024] + 7; + pgtable[0] = (ulong)&pgtable[1024] + _PRES + _RW + _US + _A;
/* Level 3 has one 64-bit entry for each GiB of memory */ for (i = 0; i < 4; i++) - pgtable[1024 + i * 2] = (ulong)&pgtable[2048] + 0x1000 * i + 7; + pgtable[1024 + i * 2] = (ulong)&pgtable[2048] + 0x1000 * i + + _PRES + _RW + _US + _A;
/* Level 2 has 2048 64-bit entries, each repesenting 2MiB */ for (i = 0; i < 2048; i++) - pgtable[2048 + i * 2] = 0x183 + (i << 21UL); + pgtable[2048 + i * 2] = _PRES + _RW + _US + _PS + _A + _D + + (i << 21UL); }
int cpu_jump_to_64bit(ulong setup_base, ulong target)
x86_cpu_init_f() is called by arch_cpu_init() a few lines below this code. Drop the duplicate call.
arch/x86/lib/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/x86/lib/spl.c b/arch/x86/lib/spl.c index f761fbc8bc3..2586a81093b 100644 --- a/arch/x86/lib/spl.c +++ b/arch/x86/lib/spl.c @@ -84,8 +84,6 @@ static int x86_spl_init(void) log_debug("x86 spl starting\n"); if (IS_ENABLED(TPL)) ret = x86_cpu_reinit_f(); - else - ret = x86_cpu_init_f(); ret = spl_init(); if (ret) { log_debug("spl_init() failed (err=%d)\n", ret);
This functions normally and has done for a while, so drop this scary message.
arch/x86/lib/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/lib/spl.c b/arch/x86/lib/spl.c index 2586a81093b..715c8cdc3ac 100644 --- a/arch/x86/lib/spl.c +++ b/arch/x86/lib/spl.c @@ -281,7 +281,7 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { int ret;
- printf("Jumping to 64-bit U-Boot: Note many features are missing\n"); + log_debug("Jumping to 64-bit U-Boot\n"); ret = cpu_jump_to_64bit_uboot(spl_image->entry_point); debug("ret=%d\n", ret); hang();
This makes use of a 'bool' type, so include the required header.
arch/x86/include/asm/interrupt.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/include/asm/interrupt.h b/arch/x86/include/asm/interrupt.h index e23fb2c8e72..c689fc23d08 100644 --- a/arch/x86/include/asm/interrupt.h +++ b/arch/x86/include/asm/interrupt.h @@ -10,6 +10,7 @@ #ifndef __ASM_INTERRUPT_H_ #define __ASM_INTERRUPT_H_ 1
+#include <stdbool.h> #include <asm/types.h>
#define SYS_NUM_IRQS 16
Use a symbol to select the size of the GDT, rather than hard-coding a value. This matches how it is done in start64
arch/x86/cpu/start.S | 4 +++- arch/x86/cpu/start16.S | 3 ++- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/start.S b/arch/x86/cpu/start.S index 0ef27cc5a00..385a691265e 100644 --- a/arch/x86/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -254,7 +254,7 @@ multiboot_header: * GDT is setup in a safe location in RAM */ gdt_ptr2: - .word 0x1f /* limit (31 bytes = 4 GDT entries - 1) */ + .word gdt2_end - gdt_ptr2 - 1 .long gdt_rom2 /* base */
/* Some CPUs are picky about GDT alignment... */ @@ -313,4 +313,6 @@ gdt_rom2: .byte 0x93 /* access */ .byte 0xcf /* flags + limit_high */ .byte 0x00 /* base_high */ +gdt2_end: + #endif diff --git a/arch/x86/cpu/start16.S b/arch/x86/cpu/start16.S index 865a49731e5..8d9acb193e0 100644 --- a/arch/x86/cpu/start16.S +++ b/arch/x86/cpu/start16.S @@ -61,7 +61,7 @@ idt_ptr: * GDT is setup in a safe location in RAM */ gdt_ptr: - .word 0x1f /* limit (31 bytes = 4 GDT entries - 1) */ + .word gdt_end - gdt_rom - 1 .long BOOT_SEG + gdt_rom /* base */
/* Some CPUs are picky about GDT alignment... */ @@ -120,3 +120,4 @@ gdt_rom: .byte 0x93 /* access */ .byte 0xcf /* flags + limit_high */ .byte 0x00 /* base_high */ +gdt_end:
This is required as part of the procedure. The existing code works because it changes the GDT at the same time, but this makes kvm unhappy.
Update the algorithm to disable and then re-enable paging.
arch/x86/cpu/i386/call64.S | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/i386/call64.S b/arch/x86/cpu/i386/call64.S index d81bcc6f8f4..e5a0420d1ba 100644 --- a/arch/x86/cpu/i386/call64.S +++ b/arch/x86/cpu/i386/call64.S @@ -25,6 +25,11 @@ cpu_call64: push %edx /* arg1 = setup_base */ mov %eax, %ebx
+ # disable paging + movl %cr0, %eax + andl $~X86_CR0_PG, %eax + movl %eax, %cr0 + /* Load new GDT with the 64bit segments using 32bit descriptor */ leal gdt, %eax movl %eax, gdt+2 @@ -67,7 +72,8 @@ cpu_call64: pushl %eax
/* Enter paged protected Mode, activating Long Mode */ - movl $(X86_CR0_PG | X86_CR0_PE), %eax + movl %cr0, %eax + orl $X86_CR0_PG, %eax movl %eax, %cr0
/* Jump from 32bit compatibility mode into 64bit mode. */
Make use the existing GDT which now includes entries for 64-bit code. Leave the interrupt descriptors alone. They can be tidied up once U-Boot starts up.
With this, kvm mode works with QEMU.
arch/x86/cpu/i386/call64.S | 14 ++------------ 1 file changed, 2 insertions(+), 12 deletions(-)
diff --git a/arch/x86/cpu/i386/call64.S b/arch/x86/cpu/i386/call64.S index e5a0420d1ba..3137ec17d31 100644 --- a/arch/x86/cpu/i386/call64.S +++ b/arch/x86/cpu/i386/call64.S @@ -7,6 +7,7 @@ */
#include <asm/msr-index.h> +#include <asm/processor.h> #include <asm/processor-flags.h>
.code32 @@ -30,11 +31,6 @@ cpu_call64: andl $~X86_CR0_PG, %eax movl %eax, %cr0
- /* Load new GDT with the 64bit segments using 32bit descriptor */ - leal gdt, %eax - movl %eax, gdt+2 - lgdt gdt - /* Enable PAE mode */ movl $(X86_CR4_PAE), %eax movl %eax, %cr4 @@ -49,12 +45,6 @@ cpu_call64: btsl $_EFER_LME, %eax wrmsr
- /* After gdt is loaded */ - xorl %eax, %eax - lldt %ax - movl $0x20, %eax - ltr %ax - /* * Setup for the jump to 64bit mode * @@ -67,7 +57,7 @@ cpu_call64: */ pop %esi /* setup_base */
- pushl $0x10 + pushl $(X86_GDT_ENTRY_64BIT_CS * X86_GDT_ENTRY_SIZE) leal lret_target, %eax pushl %eax
With the 64-bit descriptor we can use a jump instruction, rather than pushing things on the stack.
Since the processor is in 64-bit mode by this point, pop a 64-bit value from the stack, containing the target address.
This simplifies the code slightly, in particular its use of the stack.
arch/x86/cpu/i386/call64.S | 17 +++++++---------- 1 file changed, 7 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/i386/call64.S b/arch/x86/cpu/i386/call64.S index 3137ec17d31..c6308b92e25 100644 --- a/arch/x86/cpu/i386/call64.S +++ b/arch/x86/cpu/i386/call64.S @@ -22,6 +22,7 @@ cpu_call64: * ecx - target */ cli + pushl $0 /* top 64-bits of target */ push %ecx /* arg2 = target */ push %edx /* arg1 = setup_base */ mov %eax, %ebx @@ -32,7 +33,8 @@ cpu_call64: movl %eax, %cr0
/* Enable PAE mode */ - movl $(X86_CR4_PAE), %eax + movl %cr4, %eax + orl $X86_CR4_PAE, %eax movl %eax, %cr4
/* Enable the boot page tables */ @@ -57,23 +59,18 @@ cpu_call64: */ pop %esi /* setup_base */
- pushl $(X86_GDT_ENTRY_64BIT_CS * X86_GDT_ENTRY_SIZE) - leal lret_target, %eax - pushl %eax - /* Enter paged protected Mode, activating Long Mode */ movl %cr0, %eax orl $X86_CR0_PG, %eax movl %eax, %cr0
/* Jump from 32bit compatibility mode into 64bit mode. */ - lret + ljmp $(X86_GDT_ENTRY_64BIT_CS * X86_GDT_ENTRY_SIZE), $lret_target
-code64: +.code64 lret_target: - pop %eax /* target */ - mov %eax, %eax /* Clear bits 63:32 */ - jmp *%eax /* Jump to the 64-bit target */ + pop %rax /* target */ + jmp *%rax /* Jump to the 64-bit target */
.globl call64_stub_size call64_stub_size:
