[U-Boot] Pull request: u-boot-blackfin/master
The following changes since commit 47104c37de076e2be35ae1b3d144614f4d24a766:
MAKEALL: add support for per architecture toolchains (2013-02-20 09:40:34 -0500)
git://git.denx.de/u-boot-blackfin.git master
for you to fetch changes up to 9faf4f08e752ca95d0986a200d48b67b59cde5ef:
blackfin: bf60x: add resume from hibernate (2013-03-04 13:42:08 +0800)
---------------------------------------------------------------- Bob Liu (5): blackfin: bf60x: new processor header files blackfin: bf60x: add dma support blackfin: bf60x: support big cplb page blackfin: bf60x: add gpio support blackfin: bf60x: add hw watchdog support
Scott Jiang (1): blackfin: add bf6xx spi driver
Sonic Zhang (4): blackfin: bf60x: Port blackfin core architecture code to boot on bf60x. blackfin: bf60x: add serial support blackfin: bf60x: add board and headers files to support bf609 blackfin: bf60x: add rsi/sdh support
Steven Miao (1): blackfin: bf60x: add resume from hibernate
MAINTAINERS | 3 +- arch/blackfin/cpu/cpu.c | 4 +- arch/blackfin/cpu/gpio.c | 36 +- arch/blackfin/cpu/initcode.c | 384 +++++++++++++++++++- arch/blackfin/cpu/initcode.h | 52 +++ arch/blackfin/cpu/reset.c | 6 + arch/blackfin/cpu/serial.c | 81 +++-- arch/blackfin/cpu/serial.h | 222 +---------- arch/blackfin/cpu/serial1.h | 348 ++++++++++++++++++ arch/blackfin/cpu/serial4.h | 161 ++++++++ arch/blackfin/cpu/start.S | 2 + arch/blackfin/include/asm/blackfin_cdef.h | 3 + arch/blackfin/include/asm/blackfin_def.h | 5 + arch/blackfin/include/asm/blackfin_local.h | 3 + arch/blackfin/include/asm/config-pre.h | 4 + arch/blackfin/include/asm/cplb.h | 31 +- arch/blackfin/include/asm/dma.h | 81 +++-- arch/blackfin/include/asm/gpio.h | 2 +- arch/blackfin/include/asm/mach-bf533/BF531_def.h | 1 + arch/blackfin/include/asm/mach-bf561/BF561_def.h | 1 + arch/blackfin/include/asm/mach-bf609/BF609_cdef.h | 192 ++++++++++ arch/blackfin/include/asm/mach-bf609/BF609_def.h | 247 +++++++++++++ arch/blackfin/include/asm/mach-bf609/anomaly.h | 97 +++++ arch/blackfin/include/asm/mach-bf609/def_local.h | 5 + arch/blackfin/include/asm/mach-bf609/gpio.h | 151 ++++++++ arch/blackfin/include/asm/mach-bf609/portmux.h | 257 +++++++++++++ arch/blackfin/include/asm/mach-bf609/ports.h | 103 ++++++ arch/blackfin/include/asm/mach-common/bits/cgu.h | 80 ++++ arch/blackfin/include/asm/mach-common/bits/dde.h | 88 +++++ arch/blackfin/include/asm/mach-common/bits/dma.h | 54 ++- arch/blackfin/include/asm/mach-common/bits/mpu.h | 6 +- arch/blackfin/include/asm/mach-common/bits/pll.h | 5 + arch/blackfin/include/asm/mach-common/bits/sdh.h | 38 +- .../blackfin/include/asm/mach-common/bits/spi6xx.h | 240 ++++++++++++ arch/blackfin/include/asm/mach-common/bits/uart4.h | 66 ++++ arch/blackfin/lib/board.c | 25 +- arch/blackfin/lib/clocks.c | 112 ++++-- arch/blackfin/lib/string.c | 97 ++--- board/bf609-ezkit/Makefile | 55 +++ board/bf609-ezkit/bf609-ezkit.c | 67 ++++ boards.cfg | 1 + common/cmd_reginfo.c | 19 +- drivers/mmc/bfin_sdh.c | 68 +++- drivers/spi/Makefile | 1 + drivers/spi/bfin_spi6xx.c | 308 ++++++++++++++++ include/configs/bf609-ezkit.h | 162 +++++++++ include/configs/bfin_adi_common.h | 8 +- 47 files changed, 3589 insertions(+), 393 deletions(-) create mode 100644 arch/blackfin/cpu/serial1.h create mode 100644 arch/blackfin/cpu/serial4.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_cdef.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_def.h create mode 100644 arch/blackfin/include/asm/mach-bf609/anomaly.h create mode 100644 arch/blackfin/include/asm/mach-bf609/def_local.h create mode 100644 arch/blackfin/include/asm/mach-bf609/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf609/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf609/ports.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/cgu.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/dde.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/spi6xx.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/uart4.h create mode 100644 board/bf609-ezkit/Makefile create mode 100644 board/bf609-ezkit/bf609-ezkit.c create mode 100644 drivers/spi/bfin_spi6xx.c create mode 100644 include/configs/bf609-ezkit.h
Sonic Zhang
