[U-Boot] ERROR: CTL:TIMEOUT - USB porting issue for UBoot on S3C2450
I am porting UBoot on S3C2450 and has an USB issue. Here is an error message:
ERROR: CTL:TIMEOUT USB device not responding, giving up (status=20) 2 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found
The problem seems submit_common_msg couldn't get description of USB flash memory device
Could I have help? Please tell me if you had this issue before. Thank you for your helping
Here is a log data
usb start
(Re)start USB...
USB: INFO: aligned ghcca c3e4f900
DEBUG: USB HC reset_hc usb-smdk2450: ctrl = 0x9F ;
DEBUG: OHCI controller usb-smdk2450 state
DEBUG: control: 0x0000008f HCFS=operational IE PLE CBSR=3
DEBUG: cmdstatus: 0x00000000 SOC=0
DEBUG: intrstatus: 0x00000044 RHSC SF
DEBUG: intrenable: 0x00000053 RHSC UE WDH SO
DEBUG: hcca frame #0000
DEBUG: roothub.a: 02001202 POTPGT=2 NOCP NPS NDP=2
DEBUG: roothub.b: 00000000 PPCM=0000 DR=0000
DEBUG: roothub.status: 00000000
DEBUG: roothub.portstatus [0] = 0x00010101 CSC PPS CCS
DEBUG: roothub.portstatus [1] = 0x00000100 PPS
scanning bus for devices... New Device 0
start 0st usb_new_device
usb_control_msg: request: 0x6, requesttype: 0x80
value 0x100 index 0x0 length 0x40
INFO: submit_control_msg
DEBUG: SUB URB:[ 0] dev: 0,ep: 0-I,type:CTRL,len:0/64 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 0,ep: 0-I,type:CTRL,len:0/64 stat:0x80000000
INFO: Root-Hub: adr: 0 cmd(8): 00000680 0100 0000 0040
DEBUG: RET(rh) URB:[ 0] dev: 0,ep: 0-I,type:CTRL,len:64/64 stat:0x0
start 1st usb_new_device
start 2st usb_new_device
set address 1
usb_control_msg: request: 0x5, requesttype: 0x0
value 0x1 index 0x0 length 0x0
DEBUG: SUB URB:[ 0] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000500 0001 0000 0000
DEBUG: RET(rh) URB:[ 0] dev: 0,ep: 0-O,type:CTRL,len:0/0 stat:0x0
value 0x100 index 0x0 length 0x12
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/18 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/18 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000680 0100 0000 0012
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:18/18 stat:0x0
value 0x200 index 0x0 length 0x8
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/8 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000680 0200 0000 0008
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:8/8 stat:0x0
value 0x200 index 0x0 length 0x19
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/25 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/25 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000680 0200 0000 0019
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:25/25 stat:0x0
get_conf_no 0 Result 25, wLength 25
if 0, ep 0
##EP epmaxpacketin[1] = 2
set configuration 1
usb_control_msg: request: 0x9, requesttype: 0x0
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000900 0001 0000 0000
INFO: WR:status 0x10000
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-O,type:CTRL,len:0/0 stat:0x0
new device strings: Mfr=0, Product=1, SerialNumber=0
value 0x300 index 0x0 length 0xFF
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/255 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 00000680 0300 0000 00ff
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:255/255 stat:0x0
USB device number 1 default language ID 0x409
value 0x301 index 0x409 length 0xFF
INFO: Root-Hub: adr: 1 cmd(8): 00000680 0301 0409 00ff
Manufacturer
Product OHCI Root Hub
SerialNumber
usb_control_msg: request: 0x6, requesttype: 0xA0
value 0x2900 index 0x0 length 0x4
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/4 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 000006a0 2900 0000 0004
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:4/4 stat:0x0
value 0x2900 index 0x0 length 0x9
DEBUG: SUB URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/9 stat:0x80000000
DEBUG: SUB(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:0/9 stat:0x80000000
INFO: Root-Hub: adr: 1 cmd(8): 000006a0 2900 0000 0009
DEBUG: RET(rh) URB:[ 0] dev: 1,ep: 0-I,type:CTRL,len:9/9 stat:0x0
usb_control_msg: request: 0x0, requesttype: 0xA0
value 0x0 index 0x0 length 0x4
INFO: Root-Hub: adr: 1 cmd(8): 000000a0 0000 0000 0004
usb_control_msg: request: 0x3, requesttype: 0x23
value 0x8 index 0x1 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000323 0008 0001 0000
INFO: WR:portstatus[0] 0x100
value 0x8 index 0x2 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000323 0008 0002 0000
INFO: WR:portstatus[1] 0x100
usb_control_msg: request: 0x0, requesttype: 0xA3
value 0x0 index 0x1 length 0x4
INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0001 0004
usb_control_msg: request: 0x1, requesttype: 0x23
value 0x10 index 0x1 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000123 0010 0001 0000
INFO: WR:portstatus[0] 0x10000
DEBUG: roothub.portstatus [0] = 0x00000101 PPS CCS
value 0x4 index 0x1 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000323 0004 0001 0000
DEBUG: roothub.portstatus [0] = 0x00100103 PRSC PPS PES CCS
value 0x14 index 0x1 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000123 0014 0001 0000
INFO: WR:portstatus[0] 0x100000
DEBUG: roothub.portstatus [0] = 0x00000103 PPS PES CCS
New Device 1
DEBUG: %
DEBUG: hc_interrupt: returning..
ERROR: hc_interrupt: returning..
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
DEBUG: %
ERROR: CTL:TIMEOUT
DEBUG: submit_common_msg: TO status ff
DEBUG: RET(ctlr) URB:[ 0] dev: 0,ep: 0-I,type:CTRL,len:0/64 stat:0x20
usb_new_device: 64 byte descr
set address 2
value 0x2 index 0x0 length 0x0
ERROR: submit_control_message: pipesize for pipe 80000000 is zero
USB device not accepting new address (error=80000000)
value 0x1 index 0x1 length 0x0
INFO: Root-Hub: adr: 1 cmd(8): 00000123 0001 0001 0000
value 0x0 index 0x2 length 0x4
INFO: Root-Hub: adr: 1 cmd(8): 000000a3 0000 0002 0004
Thank you a lot. Best regards
dongdaking <dongdaking <at> hotmail.com> writes:
Hi friend I have met the same problem with you ,haven't you solve it yet!
thank you1
dongdaking
rui Yang
