[U-Boot] [PATCH v2 1/4] drivers: mmc: dwmmc: enable support for DT
This patch enable support for device tree for dw-mmc driver. Driver have been fixed because it is used exynos5 and exynos4. And then, add fdt compat id of exynos4 dwmmc.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- drivers/mmc/exynos_dw_mmc.c | 20 ++++++++++++++++---- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 3 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index de8cdcc..47119e2 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -13,6 +13,7 @@ #include <asm/arch/dwmmc.h> #include <asm/arch/clk.h> #include <asm/arch/pinmux.h> +#include <asm/gpio.h>
#define DWMMC_MAX_CH_NUM 4 #define DWMMC_MAX_FREQ 52000000 @@ -118,15 +119,21 @@ int exynos_dwmmc_init(const void *blob) { int index, bus_width; int node_list[DWMMC_MAX_CH_NUM]; - int err = 0, dev_id, flag, count, i; + int err = 0, dev_id, flag, count, i, compat_id; u32 clksel_val, base, timing[3];
+#ifdef CONFIG_EXYNOS4 + compat_id = COMPAT_SAMSUNG_EXYNOS4_DWMMC; +#else + compat_id = COMPAT_SAMSUNG_EXYNOS5_DWMMC; +#endif + count = fdtdec_find_aliases_for_id(blob, "mmc", - COMPAT_SAMSUNG_EXYNOS5_DWMMC, node_list, - DWMMC_MAX_CH_NUM); + compat_id, node_list, DWMMC_MAX_CH_NUM);
for (i = 0; i < count; i++) { int node = node_list[i]; + struct fdt_gpio_state pwr_gpio;
if (node <= 0) continue; @@ -145,6 +152,9 @@ int exynos_dwmmc_init(const void *blob) else flag = PINMUX_FLAG_NONE;
+ fdtdec_decode_gpio(blob, node, "pwr-gpios", &pwr_gpio); + if (fdt_gpio_isvalid(&pwr_gpio)) + gpio_direction_output(pwr_gpio.gpio, 1); /* config pinmux for each mmc channel */ err = exynos_pinmux_config(dev_id, flag); if (err) { @@ -152,7 +162,9 @@ int exynos_dwmmc_init(const void *blob) return err; }
- index = dev_id - PERIPH_ID_SDMMC0; + index = fdtdec_get_int(blob, node, "index", dev_id); + if (index == dev_id) + index = dev_id - PERIPH_ID_SDMMC0;
/* Get the base address from the device node */ base = fdtdec_get_addr(blob, node, "reg"); diff --git a/include/fdtdec.h b/include/fdtdec.h index 63027bd..15f50fe 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -83,6 +83,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ + COMPAT_SAMSUNG_EXYNOS4_DWMMC, /* Exynos4 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index be04598..79179cf 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -56,6 +56,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), + COMPAT(SAMSUNG_EXYNOS4_DWMMC, "samsung,exynos4412-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
Beomho Seo
