[PATCH 0/2] Add quad & octal spi flash mini u-boot configuration files
Add new configuration files for quad and octal spi flash mini u-boot. With these configs's mini u-boot will run from on chip memory(OCM) and uses DCC terminal for console output.
Ashok Reddy Soma (2): arm64: versal: Add qspi flash mini u-boot configuration arm64: versal: Add octal spi flash mini u-boot configuration
MAINTAINERS | 1 + configs/xilinx_versal_mini_ospi_defconfig | 71 ++++++++++++++++++++++ configs/xilinx_versal_mini_qspi_defconfig | 74 +++++++++++++++++++++++ 3 files changed, 146 insertions(+) create mode 100644 configs/xilinx_versal_mini_ospi_defconfig create mode 100644 configs/xilinx_versal_mini_qspi_defconfig
Add configuration file for mini u-boot configuration which runs on a smaller footprint from on chip memory(OCM). This configuration has required CONFIG's enabled to support qspi flash and uses DCC terminal for console output.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
MAINTAINERS | 1 + configs/xilinx_versal_mini_qspi_defconfig | 74 +++++++++++++++++++++++ 2 files changed, 75 insertions(+) create mode 100644 configs/xilinx_versal_mini_qspi_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 83346183ee..70ad67a0ce 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -634,6 +634,7 @@ M: Michal Simek michal.simek@amd.com S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-microblaze.git F: arch/arm/mach-versal/ +F: configs/xilinx_* F: drivers/net/xilinx_axi_mrmac.* F: drivers/soc/soc_xilinx_versal.c F: drivers/spi/cadence_ospi_versal.c diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig new file mode 100644 index 0000000000..bb53e6c913 --- /dev/null +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_mini_qspi" +CONFIG_ARCH_VERSAL=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-qspi-single" +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_COUNTER_FREQUENCY=100000000 +CONFIG_VERSAL_NO_DDR=y +# CONFIG_PSCI_RESET is not set +# CONFIG_EXPERT is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +# CONFIG_AUTOBOOT is not set +CONFIG_LOGLEVEL=0 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal> " +# CONFIG_SYS_XTRACE is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_PARTITIONS is not set +# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +# CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +# CONFIG_SPI_FLASH_SMART_HWCAPS is not set +# CONFIG_SPI_FLASH_UNLOCK_ALL is not set +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +# CONFIG_POWER is not set +CONFIG_ARM_DCC=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ZYNQMP_GQSPI=y +# CONFIG_LMB is not set
this is not needed because it is already the part of board/xilinx/versal/MAINTAINERS fragment.
And please run savedefconfig for both patches to make sure that they are aligned with the latest Kconfig layout.
M
Hi Michal,
-----Original Message----- From: Simek, Michal michal.simek@amd.com Sent: Tuesday, October 4, 2022 6:19 PM To: Soma, Ashok Reddy ashok.reddy.soma@amd.com; u-boot@lists.denx.de Cc: git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH 1/2] arm64: versal: Add qspi flash mini u-boot configuration
Ok, I will remove it.
F: drivers/net/xilinx_axi_mrmac.* F: drivers/soc/soc_xilinx_versal.c F: drivers/spi/cadence_ospi_versal.c diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig new file mode 100644 index 0000000000..bb53e6c913 --- /dev/null +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_mini_qspi" +CONFIG_ARCH_VERSAL=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-qspi-single" +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_COUNTER_FREQUENCY=100000000 +CONFIG_VERSAL_NO_DDR=y +# CONFIG_PSCI_RESET is not set +# CONFIG_EXPERT is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set # CONFIG_AUTOBOOT is not +set +CONFIG_LOGLEVEL=0 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal> " +# CONFIG_SYS_XTRACE is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_PARTITIONS is not set +# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set # CONFIG_NET is not +set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_GPIO is not set # CONFIG_I2C is not set # CONFIG_INPUT is +not set # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +# CONFIG_SPI_FLASH_SMART_HWCAPS is not set # +CONFIG_SPI_FLASH_UNLOCK_ALL is not set CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # +CONFIG_SPI_FLASH_USE_4K_SECTORS is not set # CONFIG_POWER is not set +CONFIG_ARM_DCC=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ZYNQMP_GQSPI=y # +CONFIG_LMB is not set
Sure, I will send v2 after running savedefconfig.
M
Add configuration file for mini u-boot configuration which runs on a smaller footprint from on chip memory(OCM). This configuration has required CONFIG's enabled to support octal spi flash and uses DCC terminal for console output.
configs/xilinx_versal_mini_ospi_defconfig | 71 +++++++++++++++++++++++ 1 file changed, 71 insertions(+) create mode 100644 configs/xilinx_versal_mini_ospi_defconfig
diff --git a/configs/xilinx_versal_mini_ospi_defconfig b/configs/xilinx_versal_mini_ospi_defconfig new file mode 100644 index 0000000000..7212c38083 --- /dev/null +++ b/configs/xilinx_versal_mini_ospi_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_mini_qspi" +CONFIG_ARCH_VERSAL=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x500 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x80 +# CONFIG_DM_GPIO is not set +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-ospi-single" +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_COUNTER_FREQUENCY=100000000 +CONFIG_VERSAL_NO_DDR=y +# CONFIG_PSCI_RESET is not set +# CONFIG_EXPERT is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +# CONFIG_AUTOBOOT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="Versal> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_PARTITIONS is not set +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MT35XU=y +CONFIG_ARM_DCC=y +CONFIG_SOC_XILINX_VERSAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_CADENCE_OSPI_VERSAL=y +CONFIG_HAS_CQSPI_REF_CLK=y +CONFIG_CQSPI_REF_CLK=200000000 +# CONFIG_LMB is not set
Ashok Reddy Soma
Michal Simek
Soma, Ashok Reddy
