Hi Tom,
The following changes since commit c149bf41404e34014e37de32fac332892b11bd4a:
Prepare v2022.04-rc4 (2022-03-14 16:39:08 -0400)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to aa34e13346cf727197981c599f688b406005049a:
pinctrl: k210: Fix bias-pull-up (2022-03-15 17:43:11 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/11297
---------------------------------------------------------------- Damien Le Moal (4): k210: use the board vendor name rather than the marketing name k210: dts: add missing power bus clocks k210: dts: align fpioa node with Linux spi: dw: Force set K210 fifo length to 31
Niklas Cassel (3): k210: dts: align plic node with Linux pinctrl: k210: Fix loop in k210_pc_get_drive() pinctrl: k210: Fix bias-pull-up
Sean Anderson (1): spi: dw: Actually mask interrupts
MAINTAINERS | 12 +- arch/riscv/dts/k210-maix-bit.dts | 3 +- arch/riscv/dts/k210.dtsi | 177 ++++++++++++--------- board/sipeed/maix/maix.c | 2 +- doc/board/sipeed/maix.rst | 20 +-- ...ryte,k210-sysctl.txt => canaan,k210-sysctl.txt} | 8 +- ...ndryte,k210-fpioa.txt => canaan,k210-fpioa.txt} | 12 +- doc/device-tree-bindings/spi/snps,dw-apb-ssi.txt | 4 +- drivers/clk/Makefile | 2 +- drivers/clk/{clk_kendryte.c => clk_k210.c} | 4 +- drivers/pinctrl/Makefile | 2 +- .../pinctrl/{pinctrl-kendryte.c => pinctrl-k210.c} | 25 ++- drivers/spi/designware_spi.c | 20 ++- include/configs/sipeed-maix.h | 2 +- include/{kendryte => k210}/pll.h | 0 test/dm/k210_pll.c | 2 +- 16 files changed, 174 insertions(+), 121 deletions(-) rename doc/device-tree-bindings/mfd/{kendryte,k210-sysctl.txt => canaan,k210-sysctl.txt} (78%) rename doc/device-tree-bindings/pinctrl/{kendryte,k210-fpioa.txt => canaan,k210-fpioa.txt} (91%) rename drivers/clk/{clk_kendryte.c => clk_k210.c} (99%) rename drivers/pinctrl/{pinctrl-kendryte.c => pinctrl-k210.c} (97%) rename include/{kendryte => k210}/pll.h (100%)
Best regards, Leo
On Wed, Mar 16, 2022 at 10:56:40AM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
