[PATCH] spi: ti_qspi: Add support for CS other than CS0
Make sure corresponding setup registers are updated depending on CS. This ensures that driver can support QSPI flashes on ChipSelects other than on CS0
Reported-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/spi/ti_qspi.c | 21 +++++++++++++-------- 1 file changed, 13 insertions(+), 8 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index c3d9e7f2ee0c..664b9cad79d9 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -60,6 +60,8 @@ DECLARE_GLOBAL_DATA_PTR; #define QSPI_SETUP0_ADDR_SHIFT (8) #define QSPI_SETUP0_DBITS_SHIFT (10)
+#define TI_QSPI_SETUP_REG(priv, cs) (&(priv)->base->setup0 + (cs)) + /* ti qspi register set */ struct ti_qspi_regs { u32 pid; @@ -275,8 +277,8 @@ static void ti_qspi_copy_mmap(void *data, void *offset, size_t len) *((unsigned int *)offset) += len; }
-static void ti_qspi_setup_mmap_read(struct ti_qspi_priv *priv, u8 opcode, - u8 data_nbits, u8 addr_width, +static void ti_qspi_setup_mmap_read(struct ti_qspi_priv *priv, int cs, + u8 opcode, u8 data_nbits, u8 addr_width, u8 dummy_bytes) { u32 memval = opcode; @@ -296,7 +298,7 @@ static void ti_qspi_setup_mmap_read(struct ti_qspi_priv *priv, u8 opcode, memval |= ((addr_width - 1) << QSPI_SETUP0_ADDR_SHIFT | dummy_bytes << QSPI_SETUP0_DBITS_SHIFT);
- writel(memval, &priv->base->setup0); + writel(memval, TI_QSPI_SETUP_REG(priv, cs)); }
static int ti_qspi_set_mode(struct udevice *bus, uint mode) @@ -317,13 +319,15 @@ static int ti_qspi_set_mode(struct udevice *bus, uint mode) static int ti_qspi_exec_mem_op(struct spi_slave *slave, const struct spi_mem_op *op) { + struct dm_spi_slave_platdata *slave_plat; struct ti_qspi_priv *priv; struct udevice *bus; + u32 from = 0; + int ret = 0;
bus = slave->dev->parent; priv = dev_get_priv(bus); - u32 from = 0; - int ret = 0; + slave_plat = dev_get_parent_platdata(slave->dev);
/* Only optimize read path. */ if (!op->data.nbytes || op->data.dir != SPI_MEM_DATA_IN || @@ -335,8 +339,9 @@ static int ti_qspi_exec_mem_op(struct spi_slave *slave, if (from + op->data.nbytes > priv->mmap_size) return -ENOTSUPP;
- ti_qspi_setup_mmap_read(priv, op->cmd.opcode, op->data.buswidth, - op->addr.nbytes, op->dummy.nbytes); + ti_qspi_setup_mmap_read(priv, slave_plat->cs, op->cmd.opcode, + op->data.buswidth, op->addr.nbytes, + op->dummy.nbytes);
ti_qspi_copy_mmap((void *)op->data.buf.in, (void *)priv->memory_map + from, op->data.nbytes); @@ -390,7 +395,7 @@ static int ti_qspi_release_bus(struct udevice *dev) writel(0, &priv->base->dc); writel(0, &priv->base->cmd); writel(0, &priv->base->data); - writel(0, &priv->base->setup0); + writel(0, TI_QSPI_SETUP_REG(priv, slave_plat->cs));
return 0; }
Applied to u-boot-spi/master
Jagan Teki
Vignesh Raghavendra
