[PATCH] efi_loader: adjust config options for capsule updates
EFI_IGNORE_OSINDICATIONS is used to ignore OsIndications if setvariable at runtime is not supported and allow the platform to perform capsule updates on disk. With the recent changes boards can conditionally enable setvariable at runtime using EFI_RT_VOLATILE_STORE.
Let's make that visible in our Kconfigs and enable EFI_IGNORE_OSINDICATIONS when set variable at runtime is disabled.
Since EFI_RT_VOLATILE_STORE needs help from the OS to persist the variables, allow users to ignore OsIndications even if setvariable at runtime is enabled.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index ee71f417147a..6006e845cb1f 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -220,6 +220,7 @@ config EFI_CAPSULE_ON_DISK config EFI_IGNORE_OSINDICATIONS bool "Ignore OsIndications for CapsuleUpdate on-disk" depends on EFI_CAPSULE_ON_DISK + default y if !EFI_RT_VOLATILE_STORE help There are boards where U-Boot does not support SetVariable at runtime. Select this option if you want to use the capsule-on-disk feature -- 2.43.0
So this v2:
v2: allow EFI_IGNORE_OSINDICATIONS if EFI_RT_VOLATILE_STORE=y
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- default y if !EFI_RT_VOLATILE_STORE help There are boards where U-Boot does not support SetVariable at runtime. Select this option if you want to use the capsule-on-disk feature
-- 2.43.0
So this v2:
Yes sorry, forgot to add the tile and log...
Thanks Heinrich
-- 2.43.0
So this v2:
With this patch I get a failure on the sandbox in the CI:
https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/21382
Without the patch the sandbox runs fine:
https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/21383
Best regards
Heinrich
Thanks Heinrich
-- 2.43.0
Hi Heinrich,
So this v2:
Yes, this test is trying to test updates with OsIndications not set and it obviously fails, because it expects the update to stop.
I'll send a v3 and adjust the tests.
Cheers /Ilias
Best regards
Heinrich
Thanks Heinrich
-- 2.43.0
Hi Heinrich
On Sun, 30 Jun 2024 at 15:47, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Heinrich,
So this v2:
I don't have to send a v3 eventually. The CI failure is a pre-existing problem and the solution is posted here [0]. This can be merged as-is after we merge the CI fixes
[0] https://lore.kernel.org/u-boot/20240704144316.251029-1-ilias.apalodimas@lina...
Regards /Ilias
Cheers /Ilias
Best regards
Heinrich
Thanks Heinrich
-- 2.43.0
Ilias Apalodimas
