[PATCH v5 00/21] binman: Rework compression support
From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
Rework the compression support of binman. Add a length header attribute to dtb entry, manage the compression bintool in the entry class and add support for several compression tools.
Changes in v5: - Add commit to avoid duplicates in bintool lists - Add commit to forward AddBintools calls - Add commit to forward AddBintools calls to base class - Add commit to collect bintools before usage - Add commit to check only section data in multi section test - Add commit to add DecompressData function to entry class - Fix decompress - Disable header in testInvalidCompress function - Remove header value in testInvalidCompress - Add commit to move compression bintools creation into test setup - Add commit to select compression bintools in cbfs_util class - Add commit to move compression bintool management into entry class - Use record_missing_bintool function - Use tools.get_bytes function - Add support to DecompressData function - Reuse 85_compress_section.dts file - Remove 236_compress_dtb_missing_bintool.dts file - Use self.comp_bintools dict - Use _CheckBintool(bintool) function - Remove self.fetch_package not None check in fetch function - Add algorithm name to entry.py - Add tool name to ftest.py - Add algorithm name to entry.py - Add tool name to ftest.py - Add algorithm name to entry.py - Add tool name to entry.py and ftest.py - Add algorithm name to entry.py - Add tool name to ftest.py - Test that zstd compress of device-tree files failed - Add algorithm name to entry.py - Add tool name to ftest.py
Changes in v4: - Add missing 236_compress_dtb_missing_bintool.dts file
Changes in v3: - Move comp_util.py changes (drop with_header) into separate commits. - Add commit to disable compressed data header - Add commit to remove obsolete compressed data header handling - Add commit to support missing compression tools - Use 'tools.get_bytes(0, 64)' instead of 'bytes([0]) * 64' - Check if tool is present - Rename tests - Document class properties
Changes in v2: - Add commit to skip elf tests - Reworked to make the feature optional. - Add commit to add compression tests - Add commit to add BintoolPacker class to bintool - Add commit to add bzip2 bintool - Add commit to add gzip bintool - Add commit to add lzop bintool - Add commit to add xz bintool - Add commit to add zstd bintool
Stefan Herbrechtsmeier (21): binman: Skip elf tests if python elftools is not available binman: Avoid duplicates in bintool lists binman: Forward AddBintools calls to sub entries in cbfs_util binman: Forward AddBintools calls to base class binman: Collect bintools before usage binman: Check only section data in multi section test binman: Add DecompressData function to entry class binman: Add length header attribute to dtb entry binman: Disable compressed data header binman: Remove obsolete compressed data header handling binman: Move compression bintools creation into test setup binman: Select compression bintools in cbfs_util class binman: Move compression bintool management into entry class binman: Support missing compression tools binman: Add compression tests binman: Add BintoolPacker class to bintool binman: Add bzip2 bintool binman: Add gzip bintool binman: Add lzop bintool binman: Add xz bintool binman: Add zstd bintool
tools/binman/bintool.py | 106 ++++++++++++ tools/binman/btool/bzip2.py | 30 ++++ tools/binman/btool/gzip.py | 31 ++++ tools/binman/btool/lzop.py | 30 ++++ tools/binman/btool/xz.py | 31 ++++ tools/binman/btool/zstd.py | 30 ++++ tools/binman/cbfs_util.py | 20 +-- tools/binman/cbfs_util_test.py | 4 +- tools/binman/comp_util.py | 76 --------- tools/binman/control.py | 5 +- tools/binman/elf_test.py | 14 ++ tools/binman/entries.rst | 3 + tools/binman/entry.py | 54 ++++++- tools/binman/entry_test.py | 9 ++ tools/binman/etype/blob_dtb.py | 31 ++++ tools/binman/etype/cbfs.py | 5 + tools/binman/etype/gbb.py | 1 + tools/binman/etype/intel_ifwi.py | 1 + tools/binman/etype/mkimage.py | 1 + tools/binman/etype/section.py | 4 +- tools/binman/etype/vblock.py | 1 + tools/binman/ftest.py | 152 +++++++++++++++--- .../test/235_compress_dtb_prepend_invalid.dts | 17 ++ .../test/236_compress_dtb_prepend_length.dts | 19 +++ .../binman/test/237_compress_dtb_invalid.dts | 16 ++ tools/binman/test/238_compress_dtb_zstd.dts | 16 ++ 26 files changed, 590 insertions(+), 117 deletions(-) create mode 100644 tools/binman/btool/bzip2.py create mode 100644 tools/binman/btool/gzip.py create mode 100644 tools/binman/btool/lzop.py create mode 100644 tools/binman/btool/xz.py create mode 100644 tools/binman/btool/zstd.py delete mode 100644 tools/binman/comp_util.py create mode 100644 tools/binman/test/235_compress_dtb_prepend_invalid.dts create mode 100644 tools/binman/test/236_compress_dtb_prepend_length.dts create mode 100644 tools/binman/test/237_compress_dtb_invalid.dts create mode 100644 tools/binman/test/238_compress_dtb_zstd.dts
Skip tests which requires python elftools if the tool is not available.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com Reviewed-by: Simon Glass sjg@chromium.org
(no changes since v2)
tools/binman/elf_test.py | 14 ++++++++++++++ tools/binman/ftest.py | 18 ++++++++++++++++++ 2 files changed, 32 insertions(+)
diff --git a/tools/binman/elf_test.py b/tools/binman/elf_test.py index 5a51c64cfe..75b867c2be 100644 --- a/tools/binman/elf_test.py +++ b/tools/binman/elf_test.py @@ -122,6 +122,8 @@ class TestElf(unittest.TestCase):
def testOutsideFile(self): """Test a symbol which extends outside the entry area is detected""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') entry = FakeEntry(10) section = FakeSection() elf_fname = self.ElfTestFile('u_boot_binman_syms') @@ -147,6 +149,8 @@ class TestElf(unittest.TestCase): Only 32 and 64 bits are supported, since we need to store an offset into the image. """ + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') entry = FakeEntry(10) section = FakeSection() elf_fname =self.ElfTestFile('u_boot_binman_syms_size') @@ -161,6 +165,8 @@ class TestElf(unittest.TestCase): This should produce -1 values for all thress symbols, taking up the first 16 bytes of the image. """ + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') entry = FakeEntry(28) section = FakeSection(sym_value=None) elf_fname = self.ElfTestFile('u_boot_binman_syms') @@ -172,6 +178,8 @@ class TestElf(unittest.TestCase):
def testDebug(self): """Check that enabling debug in the elf module produced debug output""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') try: tout.init(tout.DEBUG) entry = FakeEntry(24) @@ -281,6 +289,8 @@ class TestElf(unittest.TestCase):
def test_read_segments_bad_data(self): """Test for read_loadable_segments() with an invalid ELF file""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') fname = self.ElfTestFile('embed_data') with self.assertRaises(ValueError) as e: elf.read_loadable_segments(tools.get_bytes(100, 100)) @@ -288,6 +298,8 @@ class TestElf(unittest.TestCase):
def test_get_file_offset(self): """Test GetFileOffset() gives the correct file offset for a symbol""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') fname = self.ElfTestFile('embed_data') syms = elf.GetSymbols(fname, ['embed']) addr = syms['embed'].address @@ -314,6 +326,8 @@ class TestElf(unittest.TestCase):
def test_get_symbol_from_address(self): """Test GetSymbolFromAddress()""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') fname = self.ElfTestFile('elf_sections') sym_name = 'calculate' syms = elf.GetSymbols(fname, [sym_name]) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index fa1f421c05..da9aa9e679 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -4807,6 +4807,8 @@ class TestFunctional(unittest.TestCase):
def testUpdateFdtInElf(self): """Test that we can update the devicetree in an ELF file""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') infile = elf_fname = self.ElfTestFile('u_boot_binman_embed') outfile = os.path.join(self._indir, 'u-boot.out') begin_sym = 'dtb_embed_begin' @@ -4858,6 +4860,8 @@ class TestFunctional(unittest.TestCase):
def testUpdateFdtInElfNoSyms(self): """Test that missing symbols are detected with --update-fdt-in-elf""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') infile = elf_fname = self.ElfTestFile('u_boot_binman_embed') outfile = '' begin_sym = 'wrong_begin' @@ -4871,6 +4875,8 @@ class TestFunctional(unittest.TestCase):
def testUpdateFdtInElfTooSmall(self): """Test that an over-large dtb is detected with --update-fdt-in-elf""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') infile = elf_fname = self.ElfTestFile('u_boot_binman_embed_sm') outfile = os.path.join(self._indir, 'u-boot.out') begin_sym = 'dtb_embed_begin' @@ -5344,6 +5350,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElf(self): """Test an image with an FIT with an split-elf operation""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') entry_args = { 'of-list': 'test-fdt1 test-fdt2', 'default-dt': 'test-fdt2', @@ -5421,6 +5429,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElfBadElf(self): """Test a FIT split-elf operation with an invalid ELF file""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') TestFunctional._MakeInputFile('bad.elf', tools.get_bytes(100, 100)) entry_args = { 'of-list': 'test-fdt1 test-fdt2', @@ -5440,6 +5450,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElfBadDirective(self): """Test a FIT split-elf invalid fit,xxx directive in an image node""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') err = self._check_bad_fit('227_fit_bad_dir.dts') self.assertIn( "Node '/binman/fit': subnode 'images/@atf-SEQ': Unknown directive 'fit,something'", @@ -5447,6 +5459,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElfBadDirectiveConfig(self): """Test a FIT split-elf with invalid fit,xxx directive in config""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') err = self._check_bad_fit('228_fit_bad_dir_config.dts') self.assertEqual( "Node '/binman/fit': subnode 'configurations/@config-SEQ': Unknown directive 'fit,config'", @@ -5470,6 +5484,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElfMissing(self): """Test an split-elf FIT with a missing ELF file""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') err = self.checkFitSplitElf(allow_missing=True) self.assertRegex( err, @@ -5477,6 +5493,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testFitSplitElfFaked(self): """Test an split-elf FIT with faked ELF file""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') err = self.checkFitSplitElf(allow_missing=True, allow_fake_blobs=True) self.assertRegex( err,
Avoid duplicate entries in the list of bintools used by the image and the list of missing bintools.
tools/binman/entry.py | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/tools/binman/entry.py b/tools/binman/entry.py index e3767aefa7..8f846e55b6 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1047,7 +1047,8 @@ features to produce new behaviours. Args: bintool (Bintool): Bintool that was missing """ - self.missing_bintools.append(bintool) + if bintool not in self.missing_bintools: + self.missing_bintools.append(bintool)
def check_missing_bintools(self, missing_list): """Check if any entries in this section have missing bintools @@ -1057,7 +1058,10 @@ features to produce new behaviours. Args: missing_list: List of Bintool objects to be added to """ - missing_list += self.missing_bintools + for bintool in self.missing_bintools: + if bintool not in missing_list: + missing_list.append(bintool) +
def GetHelpTags(self): """Get the tags use for missing-blob help
Forward AddBintools calls to sub entries in cbfs_util to collect bintools of sub entries.
Changes in v5: - Add commit to forward AddBintools calls
tools/binman/etype/cbfs.py | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/tools/binman/etype/cbfs.py b/tools/binman/etype/cbfs.py index 4a1837f26c..832f8d038f 100644 --- a/tools/binman/etype/cbfs.py +++ b/tools/binman/etype/cbfs.py @@ -296,3 +296,8 @@ class Entry_cbfs(Entry): # so that child.data is used to pack into the FIP. self.ObtainContents(skip_entry=child) return True + + def AddBintools(self, btools): + super().AddBintools(btools) + for entry in self._entries.values(): + entry.AddBintools(btools)
Forward AddBintools calls to base class to collect bintools of base class.
Changes in v5: - Add commit to forward AddBintools calls to base class
tools/binman/etype/gbb.py | 1 + tools/binman/etype/intel_ifwi.py | 1 + tools/binman/etype/mkimage.py | 1 + tools/binman/etype/section.py | 1 + tools/binman/etype/vblock.py | 1 + 5 files changed, 5 insertions(+)
diff --git a/tools/binman/etype/gbb.py b/tools/binman/etype/gbb.py index 7394e4e5d3..ba2a362bb5 100644 --- a/tools/binman/etype/gbb.py +++ b/tools/binman/etype/gbb.py @@ -100,4 +100,5 @@ class Entry_gbb(Entry): return True
def AddBintools(self, btools): + super().AddBintools(btools) self.futility = self.AddBintool(btools, 'futility') diff --git a/tools/binman/etype/intel_ifwi.py b/tools/binman/etype/intel_ifwi.py index 4fa7d636fe..04fad401ee 100644 --- a/tools/binman/etype/intel_ifwi.py +++ b/tools/binman/etype/intel_ifwi.py @@ -144,4 +144,5 @@ class Entry_intel_ifwi(Entry_blob_ext): entry.WriteSymbols(self)
def AddBintools(self, btools): + super().AddBintools(btools) self.ifwitool = self.AddBintool(btools, 'ifwitool') diff --git a/tools/binman/etype/mkimage.py b/tools/binman/etype/mkimage.py index 5f6def2287..16a4eb4744 100644 --- a/tools/binman/etype/mkimage.py +++ b/tools/binman/etype/mkimage.py @@ -105,4 +105,5 @@ class Entry_mkimage(Entry): entry.CheckFakedBlobs(faked_blobs_list)
def AddBintools(self, btools): + super().AddBintools(btools) self.mkimage = self.AddBintool(btools, 'mkimage') diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index bd67238b91..48165abf6a 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -899,5 +899,6 @@ class Entry_section(Entry): entry.CheckAltFormats(alt_formats)
def AddBintools(self, btools): + super().AddBintools(btools) for entry in self._entries.values(): entry.AddBintools(btools) diff --git a/tools/binman/etype/vblock.py b/tools/binman/etype/vblock.py index c3ef08bbb2..04cb7228aa 100644 --- a/tools/binman/etype/vblock.py +++ b/tools/binman/etype/vblock.py @@ -98,4 +98,5 @@ class Entry_vblock(Entry_collection): return self.ProcessContentsUpdate(data)
Collect and thereby initialize bintools before any usage but after generation of entries. This is needed to handle bintools for compress and decompress like other bintools.
Changes in v5: - Add commit to collect bintools before usage
tools/binman/control.py | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index ce57dc7efc..f8b1733b14 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -215,6 +215,7 @@ def ReadEntry(image_fname, entry_path, decomp=True): from binman.image import Image
image = Image.FromFile(image_fname) + image.CollectBintools() entry = image.FindEntryPath(entry_path) return entry.ReadData(decomp)
@@ -251,6 +252,7 @@ def ExtractEntries(image_fname, output_fname, outdir, entry_paths, List of EntryInfo records that were written """ image = Image.FromFile(image_fname) + image.CollectBintools()
if alt_format == 'list': ShowAltFormats(image) @@ -370,6 +372,7 @@ def WriteEntry(image_fname, entry_path, data, do_compress=True, """ tout.info("Write entry '%s', file '%s'" % (entry_path, image_fname)) image = Image.FromFile(image_fname) + image.CollectBintools() entry = image.FindEntryPath(entry_path) WriteEntryToImage(image, entry, data, do_compress=do_compress, allow_resize=allow_resize, write_map=write_map) @@ -507,8 +510,8 @@ def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt, use_expanded): # without changing the device-tree size, thus ensuring that our # entry offsets remain the same. for image in images.values(): - image.CollectBintools() image.gen_entries() + image.CollectBintools() if update_fdt: image.AddMissingProperties(True) image.ProcessFdt(dtb)
Check only section data instead of the rest of the image in multi section test.
Changes in v5: - Add commit to check only section data in multi section test
tools/binman/ftest.py | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index da9aa9e679..293108d738 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -4427,15 +4427,17 @@ class TestFunctional(unittest.TestCase): rest = base[len(U_BOOT_DATA):]
# Check compressed data - section1 = self._decompress(rest) expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4') - self.assertEquals(expect1, rest[:len(expect1)]) + data1 = rest[:len(expect1)] + section1 = self._decompress(data1) + self.assertEquals(expect1, data1) self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, section1) rest1 = rest[len(expect1):]
- section2 = self._decompress(rest1) expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4') - self.assertEquals(expect2, rest1[:len(expect2)]) + data2 = rest1[:len(expect2)] + section2 = self._decompress(data2) + self.assertEquals(expect2, data2) self.assertEquals(COMPRESS_DATA + COMPRESS_DATA, section2) rest2 = rest1[len(expect2):]
Add a DecompressData function to entry class to allow override in child classes and to centralize the compress and decompress in a single class.
Changes in v5: - Add commit to add DecompressData function to entry class
tools/binman/entry.py | 15 +++++++++++++++ tools/binman/etype/section.py | 3 +-- 2 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 8f846e55b6..6d58410e91 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1086,6 +1086,21 @@ features to produce new behaviours. data = comp_util.compress(indata, self.compress) return data
+ def DecompressData(self, indata): + """Decompress data according to the entry's compression method + + Args: + indata: Data to decompress + + Returns: + Decompressed data + """ + data = comp_util.decompress(indata, self.compress) + if self.compress != 'none': + self.uncomp_size = len(data) + self.uncomp_data = data + return data + @classmethod def UseExpanded(cls, node, etype, new_etype): """Check whether to use an expanded entry type diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 48165abf6a..b9b2f25345 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -13,7 +13,6 @@ import concurrent.futures import re import sys
-from binman import comp_util from binman.entry import Entry from binman import state from dtoc import fdt_util @@ -777,7 +776,7 @@ class Entry_section(Entry): data = parent_data[offset:offset + child.size] if decomp: indata = data - data = comp_util.decompress(indata, child.compress) + data = child.DecompressData(indata) if child.uncomp_size: tout.info("%s: Decompressing data size %#x with algo '%s' to data size %#x" % (child.GetPath(), len(indata), child.compress,
Add an optional length header attribute to the device tree blob entry class based on the compressed data header from the utilities to compress and decompress data.
If needed the header could be enabled with the following attribute beside the compress attribute: prepend = "length";
The header was introduced as part of commit eb0f4a4cb402 ("binman: Support replacing data in a cbfs") to allow device tree entries to be larger than the compressed contents. Regarding the commit "this is necessary to cope with a compressed device tree being updated in such a way that it shrinks after the entry size is already set (an obscure case)". This case need to be fixed without influence any compressed data by itself.
Changes in v5: - Fix decompress
Changes in v2: - Reworked to make the feature optional.
tools/binman/entries.rst | 3 ++ tools/binman/etype/blob_dtb.py | 27 +++++++++++++ tools/binman/ftest.py | 39 +++++++++++++++++++ .../test/235_compress_dtb_prepend_invalid.dts | 17 ++++++++ .../test/236_compress_dtb_prepend_length.dts | 19 +++++++++ 5 files changed, 105 insertions(+) create mode 100644 tools/binman/test/235_compress_dtb_prepend_invalid.dts create mode 100644 tools/binman/test/236_compress_dtb_prepend_length.dts
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 782bff1f8d..c9336d1bb4 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -216,6 +216,9 @@ This is a blob containing a device tree. The contents of the blob are obtained from the list of available device-tree files, managed by the 'state' module.
+Additional Properties / Entry arguments: + - prepend: Header type to use: + length: 32-bit length header
.. _etype_blob_ext: diff --git a/tools/binman/etype/blob_dtb.py b/tools/binman/etype/blob_dtb.py index 4159e3032a..5a6a454748 100644 --- a/tools/binman/etype/blob_dtb.py +++ b/tools/binman/etype/blob_dtb.py @@ -7,6 +7,8 @@
from binman.entry import Entry from binman.etype.blob import Entry_blob +from dtoc import fdt_util +import struct
# This is imported if needed state = None @@ -17,6 +19,9 @@ class Entry_blob_dtb(Entry_blob): This is a blob containing a device tree. The contents of the blob are obtained from the list of available device-tree files, managed by the 'state' module. + + Additional attributes: + prepend: Header used (e.g. 'length') """ def __init__(self, section, etype, node): # Put this here to allow entry-docs and help to work without libfdt @@ -24,6 +29,14 @@ class Entry_blob_dtb(Entry_blob): from binman import state
super().__init__(section, etype, node) + self.prepend = None + + def ReadNode(self): + super().ReadNode() + self.prepend = fdt_util.GetString(self._node, 'prepend') + if self.prepend and self.prepend not in ['length']: + self.Raise("Invalid prepend in '%s': '%s'" % + (self._node.name, self.prepend))
def ObtainContents(self): """Get the device-tree from the list held by the 'state' module""" @@ -58,3 +71,17 @@ class Entry_blob_dtb(Entry_blob): # will still return the old contents state.UpdateFdtContents(self.GetFdtEtype(), data) return ok + + def CompressData(self, indata): + data = super().CompressData(indata) + if self.prepend == 'length': + hdr = struct.pack('<I', len(data)) + data = hdr + data + return data + + def DecompressData(self, indata): + if self.prepend == 'length': + data_len = struct.unpack('<I', indata[:4])[0] + indata = indata[4:4 + data_len] + data = super().DecompressData(indata) + return data diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 293108d738..6e63b7c27a 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -5723,6 +5723,45 @@ fdt fdtmap Extract the devicetree blob from the fdtmap dts='234_replace_section_simple.dts') self.assertEqual(new_data, data)
+ def testCompressDtbPrependInvalid(self): + """Test that invalid header is detected""" + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('235_compress_dtb_prepend_invalid.dts') + self.assertIn("Node '/binman/u-boot-dtb': Invalid prepend in " + "'u-boot-dtb': 'invalid'", str(e.exception)) + + def testCompressDtbPrependLength(self): + """Test that compress with length header works as expected""" + data = self._DoReadFileRealDtb('236_compress_dtb_prepend_length.dts') + image = control.images['image'] + entries = image.GetEntries() + self.assertIn('u-boot-dtb', entries) + u_boot_dtb = entries['u-boot-dtb'] + self.assertIn('fdtmap', entries) + fdtmap = entries['fdtmap'] + + image_fname = tools.get_output_filename('image.bin') + orig = control.ReadEntry(image_fname, 'u-boot-dtb') + dtb = fdt.Fdt.FromData(orig) + dtb.Scan() + props = self._GetPropTree(dtb, ['size', 'uncomp-size']) + expected = { + 'u-boot:size': len(U_BOOT_DATA), + 'u-boot-dtb:uncomp-size': len(orig), + 'u-boot-dtb:size': u_boot_dtb.size, + 'fdtmap:size': fdtmap.size, + 'size': len(data), + } + self.assertEqual(expected, props) + + # Check implementation + self.assertEqual(U_BOOT_DATA, data[:len(U_BOOT_DATA)]) + rest = data[len(U_BOOT_DATA):] + comp_data_len = struct.unpack('<I', rest[:4])[0] + comp_data = rest[4:4 + comp_data_len] + orig2 = self._decompress(comp_data) + self.assertEqual(orig, orig2) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/235_compress_dtb_prepend_invalid.dts b/tools/binman/test/235_compress_dtb_prepend_invalid.dts new file mode 100644 index 0000000000..ee32670a91 --- /dev/null +++ b/tools/binman/test/235_compress_dtb_prepend_invalid.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + u-boot-dtb { + compress = "lz4"; + prepend = "invalid"; + }; + }; +}; diff --git a/tools/binman/test/236_compress_dtb_prepend_length.dts b/tools/binman/test/236_compress_dtb_prepend_length.dts new file mode 100644 index 0000000000..1570233637 --- /dev/null +++ b/tools/binman/test/236_compress_dtb_prepend_length.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + u-boot-dtb { + compress = "lz4"; + prepend = "length"; + }; + fdtmap { + }; + }; +};
Disable the compressed data header of the utilities to compress and decompress data. The header is uncommon, not supported by U-Boot and incompatible with external compressed artifacts.
Changes in v5: - Disable header in testInvalidCompress function
Changes in v3: - Add commit to disable compressed data header
tools/binman/entry.py | 4 ++-- tools/binman/ftest.py | 12 +++++++----- 2 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 6d58410e91..ecce721ac6 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1083,7 +1083,7 @@ features to produce new behaviours. self.uncomp_data = indata if self.compress != 'none': self.uncomp_size = len(indata) - data = comp_util.compress(indata, self.compress) + data = comp_util.compress(indata, self.compress, with_header=False) return data
def DecompressData(self, indata): @@ -1095,7 +1095,7 @@ features to produce new behaviours. Returns: Decompressed data """ - data = comp_util.decompress(indata, self.compress) + data = comp_util.decompress(indata, self.compress, with_header=False) if self.compress != 'none': self.uncomp_size = len(data) self.uncomp_data = data diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 6e63b7c27a..edee1f3984 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -1967,7 +1967,7 @@ class TestFunctional(unittest.TestCase): self._ResetDtbs()
def _decompress(self, data): - return comp_util.decompress(data, 'lz4') + return comp_util.decompress(data, 'lz4', with_header=False)
def testCompress(self): """Test compression of blobs""" @@ -4427,14 +4427,16 @@ class TestFunctional(unittest.TestCase): rest = base[len(U_BOOT_DATA):]
# Check compressed data - expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4') + expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4', + with_header=False) data1 = rest[:len(expect1)] section1 = self._decompress(data1) self.assertEquals(expect1, data1) self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, section1) rest1 = rest[len(expect1):]
- expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4') + expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4', + with_header=False) data2 = rest1[:len(expect2)] section2 = self._decompress(data2) self.assertEquals(expect2, data2) @@ -5219,11 +5221,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testInvalidCompress(self): with self.assertRaises(ValueError) as e: - comp_util.compress(b'', 'invalid') + comp_util.compress(b'', 'invalid', with_header=False) self.assertIn("Unknown algorithm 'invalid'", str(e.exception))
with self.assertRaises(ValueError) as e: - comp_util.decompress(b'1234', 'invalid') + comp_util.decompress(b'1234', 'invalid', with_header=False) self.assertIn("Unknown algorithm 'invalid'", str(e.exception))
def testBintoolDocs(self):
Remove the obsolete compressed data header handling from the utilities to compress and decompress data. The header is uncommon, not supported by U-Boot and incompatible with external compressed artifacts.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com ---
Changes in v5: - Remove header value in testInvalidCompress
Changes in v3: - Add commit to remove obsolete compressed data header handling
tools/binman/cbfs_util.py | 8 ++++---- tools/binman/comp_util.py | 11 ++--------- tools/binman/entry.py | 6 +++--- tools/binman/ftest.py | 14 ++++++-------- 4 files changed, 15 insertions(+), 24 deletions(-)
diff --git a/tools/binman/cbfs_util.py b/tools/binman/cbfs_util.py index 9cad03886f..a1836f4ad3 100644 --- a/tools/binman/cbfs_util.py +++ b/tools/binman/cbfs_util.py @@ -241,9 +241,9 @@ class CbfsFile(object): """Handle decompressing data if necessary""" indata = self.data if self.compress == COMPRESS_LZ4: - data = comp_util.decompress(indata, 'lz4', with_header=False) + data = comp_util.decompress(indata, 'lz4') elif self.compress == COMPRESS_LZMA: - data = comp_util.decompress(indata, 'lzma', with_header=False) + data = comp_util.decompress(indata, 'lzma') else: data = indata self.memlen = len(data) @@ -362,9 +362,9 @@ class CbfsFile(object): elif self.ftype == TYPE_RAW: orig_data = data if self.compress == COMPRESS_LZ4: - data = comp_util.compress(orig_data, 'lz4', with_header=False) + data = comp_util.compress(orig_data, 'lz4') elif self.compress == COMPRESS_LZMA: - data = comp_util.compress(orig_data, 'lzma', with_header=False) + data = comp_util.compress(orig_data, 'lzma') self.memlen = len(orig_data) self.data_len = len(data) attr = struct.pack(ATTR_COMPRESSION_FORMAT, diff --git a/tools/binman/comp_util.py b/tools/binman/comp_util.py index dc76adab35..269bbf7975 100644 --- a/tools/binman/comp_util.py +++ b/tools/binman/comp_util.py @@ -3,7 +3,6 @@ # """Utilities to compress and decompress data"""
-import struct import tempfile
from binman import bintool @@ -16,7 +15,7 @@ LZMA_ALONE = bintool.Bintool.create('lzma_alone') HAVE_LZMA_ALONE = LZMA_ALONE.is_present()
-def compress(indata, algo, with_header=True): +def compress(indata, algo): """Compress some data using a given algorithm
Note that for lzma this uses an old version of the algorithm, not that @@ -41,12 +40,9 @@ def compress(indata, algo, with_header=True): data = LZMA_ALONE.compress(indata) else: raise ValueError("Unknown algorithm '%s'" % algo) - if with_header: - hdr = struct.pack('<I', len(data)) - data = hdr + data return data
-def decompress(indata, algo, with_header=True): +def decompress(indata, algo): """Decompress some data using a given algorithm
Note that for lzma this uses an old version of the algorithm, not that @@ -64,9 +60,6 @@ def decompress(indata, algo, with_header=True): """ if algo == 'none': return indata - if with_header: - data_len = struct.unpack('<I', indata[:4])[0] - indata = indata[4:4 + data_len] if algo == 'lz4': data = LZ4.decompress(indata) elif algo == 'lzma': diff --git a/tools/binman/entry.py b/tools/binman/entry.py index ecce721ac6..398d5caa39 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1078,12 +1078,12 @@ features to produce new behaviours. indata: Data to compress
Returns: - Compressed data (first word is the compressed size) + Compressed data """ self.uncomp_data = indata if self.compress != 'none': self.uncomp_size = len(indata) - data = comp_util.compress(indata, self.compress, with_header=False) + data = comp_util.compress(indata, self.compress) return data
def DecompressData(self, indata): @@ -1095,7 +1095,7 @@ features to produce new behaviours. Returns: Decompressed data """ - data = comp_util.decompress(indata, self.compress, with_header=False) + data = comp_util.decompress(indata, self.compress) if self.compress != 'none': self.uncomp_size = len(data) self.uncomp_data = data diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index edee1f3984..1538ca3c4e 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -1967,7 +1967,7 @@ class TestFunctional(unittest.TestCase): self._ResetDtbs()
def _decompress(self, data): - return comp_util.decompress(data, 'lz4', with_header=False) + return comp_util.decompress(data, 'lz4')
def testCompress(self): """Test compression of blobs""" @@ -2856,7 +2856,7 @@ class TestFunctional(unittest.TestCase): def testExtractCbfsRaw(self): """Test extracting CBFS compressed data without decompressing it""" data = self._RunExtractCmd('section/cbfs/u-boot-dtb', decomp=False) - dtb = comp_util.decompress(data, 'lzma', with_header=False) + dtb = comp_util.decompress(data, 'lzma') self.assertEqual(EXTRACT_DTB_SIZE, len(dtb))
def testExtractBadEntry(self): @@ -4427,16 +4427,14 @@ class TestFunctional(unittest.TestCase): rest = base[len(U_BOOT_DATA):]
# Check compressed data - expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4', - with_header=False) + expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4') data1 = rest[:len(expect1)] section1 = self._decompress(data1) self.assertEquals(expect1, data1) self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, section1) rest1 = rest[len(expect1):]
- expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4', - with_header=False) + expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4') data2 = rest1[:len(expect2)] section2 = self._decompress(data2) self.assertEquals(expect2, data2) @@ -5221,11 +5219,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testInvalidCompress(self): with self.assertRaises(ValueError) as e: - comp_util.compress(b'', 'invalid', with_header=False) + comp_util.compress(b'', 'invalid') self.assertIn("Unknown algorithm 'invalid'", str(e.exception))
with self.assertRaises(ValueError) as e: - comp_util.decompress(b'1234', 'invalid', with_header=False) + comp_util.decompress(b'1234', 'invalid') self.assertIn("Unknown algorithm 'invalid'", str(e.exception))
Move compression bintools (packer) creation into test setup to reuse bintool objects between tests.
Changes in v5: - Add commit to move compression bintools creation into test setup
tools/binman/ftest.py | 27 +++++++++++++++++++-------- 1 file changed, 19 insertions(+), 8 deletions(-)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 1538ca3c4e..7ab9289a88 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -23,7 +23,6 @@ import urllib.error from binman import bintool from binman import cbfs_util from binman import cmdline -from binman import comp_util from binman import control from binman import elf from binman import elf_test @@ -107,6 +106,8 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] # Extra properties expected to be in the device tree when allow-repack is used REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
+# Supported compression bintools +COMP_BINTOOLS = ['lz4', 'lzma_alone']
class TestFunctional(unittest.TestCase): """Functional tests for binman @@ -212,7 +213,9 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tee.elf', tools.read_file(cls.ElfTestFile('elf_sections')))
- cls.have_lz4 = comp_util.HAVE_LZ4 + cls.comp_bintools = {} + for name in COMP_BINTOOLS: + cls.comp_bintools[name] = bintool.Bintool.create(name)
@classmethod def tearDownClass(cls): @@ -242,9 +245,13 @@ class TestFunctional(unittest.TestCase): cls.toolpath = toolpath cls.verbosity = verbosity
+ def _CheckBintool(self, bintool): + if not bintool.is_present(): + self.skipTest('%s not available' % bintool.name) + def _CheckLz4(self): - if not self.have_lz4: - self.skipTest('lz4 --no-frame-crc not available') + bintool = self.comp_bintools['lz4'] + self._CheckBintool(bintool)
def _CleanupOutputDir(self): """Remove the temporary output directory""" @@ -1967,7 +1974,8 @@ class TestFunctional(unittest.TestCase): self._ResetDtbs()
def _decompress(self, data): - return comp_util.decompress(data, 'lz4') + bintool = self.comp_bintools['lz4'] + return bintool.decompress(data)
def testCompress(self): """Test compression of blobs""" @@ -2855,8 +2863,10 @@ class TestFunctional(unittest.TestCase):
def testExtractCbfsRaw(self): """Test extracting CBFS compressed data without decompressing it""" + bintool = self.comp_bintools['lzma_alone'] + self._CheckBintool(bintool) data = self._RunExtractCmd('section/cbfs/u-boot-dtb', decomp=False) - dtb = comp_util.decompress(data, 'lzma') + dtb = bintool.decompress(data) self.assertEqual(EXTRACT_DTB_SIZE, len(dtb))
def testExtractBadEntry(self): @@ -4427,14 +4437,15 @@ class TestFunctional(unittest.TestCase): rest = base[len(U_BOOT_DATA):]
# Check compressed data - expect1 = comp_util.compress(COMPRESS_DATA + U_BOOT_DATA, 'lz4') + bintool = self.comp_bintools['lz4'] + expect1 = bintool.compress(COMPRESS_DATA + U_BOOT_DATA) data1 = rest[:len(expect1)] section1 = self._decompress(data1) self.assertEquals(expect1, data1) self.assertEquals(COMPRESS_DATA + U_BOOT_DATA, section1) rest1 = rest[len(expect1):]
- expect2 = comp_util.compress(COMPRESS_DATA + COMPRESS_DATA, 'lz4') + expect2 = bintool.compress(COMPRESS_DATA + COMPRESS_DATA) data2 = rest1[:len(expect2)] section2 = self._decompress(data2) self.assertEquals(expect2, data2)
Select the lz4 and lzma_alone bintools in cbfs_util class to centralize the supported compression algorithm evaluation inside the class and over multiple classes.
Changes in v5: - Add commit to select compression bintools in cbfs_util class
tools/binman/cbfs_util.py | 20 +++++++++++--------- tools/binman/cbfs_util_test.py | 4 ++-- 2 files changed, 13 insertions(+), 11 deletions(-)
diff --git a/tools/binman/cbfs_util.py b/tools/binman/cbfs_util.py index a1836f4ad3..7bd3d89798 100644 --- a/tools/binman/cbfs_util.py +++ b/tools/binman/cbfs_util.py @@ -20,7 +20,7 @@ import io import struct import sys
-from binman import comp_util +from binman import bintool from binman import elf from patman import command from patman import tools @@ -236,14 +236,18 @@ class CbfsFile(object): self.data_len = len(data) self.erase_byte = None self.size = None + if self.compress == COMPRESS_LZ4: + self.comp_bintool = bintool.Bintool.create('lz4') + elif self.compress == COMPRESS_LZMA: + self.comp_bintool = bintool.Bintool.create('lzma_alone') + else: + self.comp_bintool = None
def decompress(self): """Handle decompressing data if necessary""" indata = self.data - if self.compress == COMPRESS_LZ4: - data = comp_util.decompress(indata, 'lz4') - elif self.compress == COMPRESS_LZMA: - data = comp_util.decompress(indata, 'lzma') + if self.comp_bintool: + data = self.comp_bintool.decompress(indata) else: data = indata self.memlen = len(data) @@ -361,10 +365,8 @@ class CbfsFile(object): data = elf_data.data elif self.ftype == TYPE_RAW: orig_data = data - if self.compress == COMPRESS_LZ4: - data = comp_util.compress(orig_data, 'lz4') - elif self.compress == COMPRESS_LZMA: - data = comp_util.compress(orig_data, 'lzma') + if self.comp_bintool: + data = self.comp_bintool.compress(orig_data) self.memlen = len(orig_data) self.data_len = len(data) attr = struct.pack(ATTR_COMPRESSION_FORMAT, diff --git a/tools/binman/cbfs_util_test.py b/tools/binman/cbfs_util_test.py index f86b295149..e0f792fd34 100755 --- a/tools/binman/cbfs_util_test.py +++ b/tools/binman/cbfs_util_test.py @@ -19,7 +19,6 @@ import unittest from binman import bintool from binman import cbfs_util from binman.cbfs_util import CbfsWriter -from binman import comp_util from binman import elf from patman import test_util from patman import tools @@ -50,7 +49,8 @@ class TestCbfs(unittest.TestCase): cls.cbfstool = bintool.Bintool.create('cbfstool') cls.have_cbfstool = cls.cbfstool.is_present()
- cls.have_lz4 = comp_util.HAVE_LZ4 + lz4 = bintool.Bintool.create('lz4') + cls.have_lz4 = lz4.is_present()
Move management of the bintool to compress and decompress data into the entry class and add the bintool to the list of required bintools.
Changes in v5: - Add commit to move compression bintool management into entry class
tools/binman/comp_util.py | 69 ------------------- tools/binman/entry.py | 23 +++++-- tools/binman/ftest.py | 15 ++-- .../binman/test/237_compress_dtb_invalid.dts | 16 +++++ 4 files changed, 41 insertions(+), 82 deletions(-) delete mode 100644 tools/binman/comp_util.py create mode 100644 tools/binman/test/237_compress_dtb_invalid.dts
diff --git a/tools/binman/comp_util.py b/tools/binman/comp_util.py deleted file mode 100644 index 269bbf7975..0000000000 --- a/tools/binman/comp_util.py +++ /dev/null @@ -1,69 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# Copyright 2022 Google LLC -# -"""Utilities to compress and decompress data""" - -import tempfile - -from binman import bintool -from patman import tools - -LZ4 = bintool.Bintool.create('lz4') -HAVE_LZ4 = LZ4.is_present() - -LZMA_ALONE = bintool.Bintool.create('lzma_alone') -HAVE_LZMA_ALONE = LZMA_ALONE.is_present() - - -def compress(indata, algo): - """Compress some data using a given algorithm - - Note that for lzma this uses an old version of the algorithm, not that - provided by xz. - - This requires 'lz4' and 'lzma_alone' tools. It also requires an output - directory to be previously set up, by calling PrepareOutputDir(). - - Args: - indata (bytes): Input data to compress - algo (str): Algorithm to use ('none', 'lz4' or 'lzma') - - Returns: - bytes: Compressed data - """ - if algo == 'none': - return indata - if algo == 'lz4': - data = LZ4.compress(indata) - # cbfstool uses a very old version of lzma - elif algo == 'lzma': - data = LZMA_ALONE.compress(indata) - else: - raise ValueError("Unknown algorithm '%s'" % algo) - return data - -def decompress(indata, algo): - """Decompress some data using a given algorithm - - Note that for lzma this uses an old version of the algorithm, not that - provided by xz. - - This requires 'lz4' and 'lzma_alone' tools. It also requires an output - directory to be previously set up, by calling PrepareOutputDir(). - - Args: - indata (bytes): Input data to decompress - algo (str): Algorithm to use ('none', 'lz4' or 'lzma') - - Returns: - (bytes) Compressed data - """ - if algo == 'none': - return indata - if algo == 'lz4': - data = LZ4.decompress(indata) - elif algo == 'lzma': - data = LZMA_ALONE.decompress(indata) - else: - raise ValueError("Unknown algorithm '%s'" % algo) - return data diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 398d5caa39..6a6c3e6bb4 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -11,7 +11,6 @@ import pathlib import sys
from binman import bintool -from binman import comp_util from dtoc import fdt_util from patman import tools from patman.tools import to_hex, to_hex_size @@ -82,6 +81,7 @@ class Entry(object): missing_bintools: List of missing bintools for this entry update_hash: True if this entry's "hash" subnode should be updated with a hash of the entry contents + comp_bintool: Bintools used for compress and decompress data """ def __init__(self, section, etype, node, name_prefix=''): # Put this here to allow entry-docs and help to work without libfdt @@ -116,6 +116,7 @@ class Entry(object): self.bintools = {} self.missing_bintools = [] self.update_hash = True + self.comp_bintool = None
@staticmethod def FindEntryClass(etype, expanded): @@ -1083,7 +1084,9 @@ features to produce new behaviours. self.uncomp_data = indata if self.compress != 'none': self.uncomp_size = len(indata) - data = comp_util.compress(indata, self.compress) + data = self.comp_bintool.compress(indata) + else: + data = indata return data
def DecompressData(self, indata): @@ -1095,9 +1098,11 @@ features to produce new behaviours. Returns: Decompressed data """ - data = comp_util.decompress(indata, self.compress) if self.compress != 'none': self.uncomp_size = len(data) + data = self.comp_bintool.decompress(indata) + else: + data = indata self.uncomp_data = data return data
@@ -1138,8 +1143,18 @@ features to produce new behaviours.
Args: btools (dict of Bintool): + + Raise: + ValueError if compression algorithm is not supported """ - pass + algo = self.compress + if algo != 'none': + algos = ['lz4', 'lzma'] + if algo not in algos: + raise ValueError("Unknown algorithm '%s'" % algo) + names = {'lzma': 'lzma_alone'} + name = names.get(self.compress, self.compress) + self.comp_bintool = self.AddBintool(btools, name)
@classmethod def AddBintool(self, tools, name): diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 7ab9289a88..939b265d7c 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -5228,15 +5228,6 @@ fdt fdtmap Extract the devicetree blob from the fdtmap self._DoBinman(*args) self.assertIn('failed to fetch with all methods', stdout.getvalue())
- def testInvalidCompress(self): - with self.assertRaises(ValueError) as e: - comp_util.compress(b'', 'invalid') - self.assertIn("Unknown algorithm 'invalid'", str(e.exception)) - - with self.assertRaises(ValueError) as e: - comp_util.decompress(b'1234', 'invalid') - self.assertIn("Unknown algorithm 'invalid'", str(e.exception)) - def testBintoolDocs(self): """Test for creation of bintool documentation""" with test_util.capture_sys_output() as (stdout, stderr): @@ -5773,6 +5764,12 @@ fdt fdtmap Extract the devicetree blob from the fdtmap orig2 = self._decompress(comp_data) self.assertEqual(orig, orig2)
+ def testInvalidCompress(self): + """Test that invalid compress algorithm is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('237_compress_dtb_invalid.dts') + self.assertIn("Unknown algorithm 'invalid'", str(e.exception)) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/237_compress_dtb_invalid.dts b/tools/binman/test/237_compress_dtb_invalid.dts new file mode 100644 index 0000000000..228139060b --- /dev/null +++ b/tools/binman/test/237_compress_dtb_invalid.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + u-boot-dtb { + compress = "invalid"; + }; + }; +};
Handle missing compression tools by returning empty data and record missing bintool.
Changes in v5: - Use record_missing_bintool function - Use tools.get_bytes function - Add support to DecompressData function - Reuse 85_compress_section.dts file - Remove 236_compress_dtb_missing_bintool.dts file
Changes in v3: - Add commit to support missing compression tools
tools/binman/entry.py | 12 ++++++++++-- tools/binman/entry_test.py | 9 +++++++++ tools/binman/ftest.py | 9 +++++++++ 3 files changed, 28 insertions(+), 2 deletions(-)
diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 6a6c3e6bb4..31389be672 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1084,7 +1084,11 @@ features to produce new behaviours. self.uncomp_data = indata if self.compress != 'none': self.uncomp_size = len(indata) - data = self.comp_bintool.compress(indata) + if self.comp_bintool.is_present(): + data = self.comp_bintool.compress(indata) + else: + self.record_missing_bintool(self.comp_bintool) + data = tools.get_bytes(0, 1024) else: data = indata return data @@ -1100,7 +1104,11 @@ features to produce new behaviours. """ if self.compress != 'none': self.uncomp_size = len(data) - data = self.comp_bintool.decompress(indata) + if self.comp_bintool.is_present(): + data = self.comp_bintool.decompress(indata) + else: + self.record_missing_bintool(self.comp_bintool) + return tools.get_bytes(0, 1024) else: data = indata self.uncomp_data = data diff --git a/tools/binman/entry_test.py b/tools/binman/entry_test.py index 1d60076be1..aa470c5816 100644 --- a/tools/binman/entry_test.py +++ b/tools/binman/entry_test.py @@ -105,6 +105,15 @@ class TestEntry(unittest.TestCase): self.assertTrue(isinstance(ent, Entry_blob)) self.assertEquals('missing', ent.etype)
+ def testDecompressData(self): + """Test the DecompressData() method of the base class""" + base = entry.Entry.Create(None, self.GetNode(), 'blob-dtb') + base.compress = 'lz4' + bintools = {} + base.comp_bintool = base.AddBintool(bintools, '_testing') + self.assertEquals(tools.get_bytes(0, 1024), base.CompressData(b'abc')) + self.assertEquals(tools.get_bytes(0, 1024), base.DecompressData(b'abc')) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 939b265d7c..ffcd7d2567 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -4422,6 +4422,15 @@ class TestFunctional(unittest.TestCase): } self.assertEqual(expected, props)
+ def testLz4Missing(self): + """Test that binman still produces an image if lz4 is missing""" + with test_util.capture_sys_output() as (_, stderr): + self._DoTestFile('185_compress_section.dts', + force_missing_bintools='lz4') + err = stderr.getvalue() + self.assertRegex(err, + "Image 'main-section'.*missing bintools.*: lz4") + def testCompressExtra(self): """Test compression of a section with no fixed size""" self._CheckLz4()
Add common test functions to test all supported compressions.
--- Instead of the for loop it is possible to use Parameterized [1] testing.
[1] https://github.com/wolever/parameterized
Changes in v5: - Use self.comp_bintools dict - Use _CheckBintool(bintool) function
Changes in v3: - Use 'tools.get_bytes(0, 64)' instead of 'bytes([0]) * 64' - Check if tool is present - Rename tests
Changes in v2: - Add commit to add compression tests
tools/binman/ftest.py | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index ffcd7d2567..bbb2fa19c1 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -5779,6 +5779,32 @@ fdt fdtmap Extract the devicetree blob from the fdtmap self._DoTestFile('237_compress_dtb_invalid.dts') self.assertIn("Unknown algorithm 'invalid'", str(e.exception))
+ def testCompUtilCompressions(self): + """Test compression algorithms""" + for bintool in self.comp_bintools.values(): + self._CheckBintool(bintool) + data = bintool.compress(COMPRESS_DATA) + self.assertNotEqual(COMPRESS_DATA, data) + orig = bintool.decompress(data) + self.assertEquals(COMPRESS_DATA, orig) + + def testCompUtilVersions(self): + """Test tool version of compression algorithms""" + for bintool in self.comp_bintools.values(): + self._CheckBintool(bintool) + version = bintool.version() + self.assertRegex(version, '^v?[0-9]+[0-9.]*') + + def testCompUtilPadding(self): + """Test padding of compression algorithms""" + for bintool in self.comp_bintools.values(): + self._CheckBintool(bintool) + data = bintool.compress(COMPRESS_DATA) + self.assertNotEqual(COMPRESS_DATA, data) + data += tools.get_bytes(0, 64) + orig = bintool.decompress(data) + self.assertEquals(COMPRESS_DATA, orig) +
Add a bintools base class for packers which compression / decompression entry contents.
Changes in v5: - Remove self.fetch_package not None check in fetch function
Changes in v3: - Document class properties
Changes in v2: - Add commit to add BintoolPacker class to bintool
tools/binman/bintool.py | 106 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 106 insertions(+)
diff --git a/tools/binman/bintool.py b/tools/binman/bintool.py index 8435b29749..ccc1904d62 100644 --- a/tools/binman/bintool.py +++ b/tools/binman/bintool.py @@ -1,5 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # Copyright 2022 Google LLC +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com # """Base class for all bintools
@@ -464,3 +466,107 @@ binaries. It is fairly easy to create new bintools. Just add a new file to the str: Version string for this bintool """ return 'unknown' + +class BintoolPacker(Bintool): + """Tool which compression / decompression entry contents + + This is a bintools base class for compression / decompression packer + + Properties: + name: Name of packer tool + compression: Compression type (COMPRESS_...), value of 'name' property + if none + compress_args: List of positional args provided to tool for compress, + ['--compress'] if none + decompress_args: List of positional args provided to tool for + decompress, ['--decompress'] if none + fetch_package: Name of the tool installed using the apt, value of 'name' + property if none + version_regex: Regular expressions to extract the version from tool + version output, '(v[0-9.]+)' if none + """ + def __init__(self, name, compression=None, compress_args=None, + decompress_args=None, fetch_package=None, + version_regex=r'(v[0-9.]+)'): + desc = '%s compression' % (compression if compression else name) + super().__init__(name, desc) + if compress_args is None: + compress_args = ['--compress'] + self.compress_args = compress_args + if decompress_args is None: + decompress_args = ['--decompress'] + self.decompress_args = decompress_args + if fetch_package is None: + fetch_package = name + self.fetch_package = fetch_package + self.version_regex = version_regex + + def compress(self, indata): + """Compress data + + Args: + indata (bytes): Data to compress + + Returns: + bytes: Compressed data + """ + with tempfile.NamedTemporaryFile(prefix='comp.tmp', + dir=tools.get_output_dir()) as tmp: + tools.write_file(tmp.name, indata) + args = self.compress_args + ['--stdout', tmp.name] + return self.run_cmd(*args, binary=True) + + def decompress(self, indata): + """Decompress data + + Args: + indata (bytes): Data to decompress + + Returns: + bytes: Decompressed data + """ + with tempfile.NamedTemporaryFile(prefix='decomp.tmp', + dir=tools.get_output_dir()) as inf: + tools.write_file(inf.name, indata) + args = self.decompress_args + ['--stdout', inf.name] + return self.run_cmd(*args, binary=True) + + def fetch(self, method): + """Fetch handler + + This installs the gzip package using the apt utility. + + Args: + method (FETCH_...): Method to use + + Returns: + True if the file was fetched and now installed, None if a method + other than FETCH_BIN was requested + + Raises: + Valuerror: Fetching could not be completed + """ + if method != FETCH_BIN: + return None + return self.apt_install(self.fetch_package) + + def version(self): + """Version handler + + Returns: + str: Version number + """ + import re + + result = self.run_cmd_result('-V') + if not result: + return super().version() + + out = result.stdout.strip() + if not out: + out = result.stderr.strip() + if not out: + return super().version() + + m_version = re.search(self.version_regex, out) + return m_version.group(1) if m_version else out
Add bzip2 bintool to binman to support on-the-fly compression.
Changes in v5: - Add algorithm name to entry.py - Add tool name to ftest.py
Changes in v2: - Add commit to add bzip2 bintool
tools/binman/btool/bzip2.py | 30 ++++++++++++++++++++++++++++++ tools/binman/entry.py | 2 +- tools/binman/ftest.py | 2 +- 3 files changed, 32 insertions(+), 2 deletions(-) create mode 100644 tools/binman/btool/bzip2.py
diff --git a/tools/binman/btool/bzip2.py b/tools/binman/btool/bzip2.py new file mode 100644 index 0000000000..9be87a621f --- /dev/null +++ b/tools/binman/btool/bzip2.py @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com +# +"""Bintool implementation for bzip2 + +bzip2 allows compression and decompression of files. + +Documentation is available via:: + + man bzip2 +""" + +from binman import bintool + +# pylint: disable=C0103 +class Bintoolbzip2(bintool.BintoolPacker): + """Compression/decompression using the bzip2 algorithm + + This bintool supports running `bzip2` to compress and decompress data, as + used by binman. + + It is also possible to fetch the tool, which uses `apt` to install it. + + Documentation is available via:: + + man bzip2 + """ + def __init__(self, name): + super().__init__(name, version_regex=r'bzip2.*Version ([0-9.]+)') diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 31389be672..5fb8517329 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1157,7 +1157,7 @@ features to produce new behaviours. """ algo = self.compress if algo != 'none': - algos = ['lz4', 'lzma'] + algos = ['bzip2', 'lz4', 'lzma'] if algo not in algos: raise ValueError("Unknown algorithm '%s'" % algo) names = {'lzma': 'lzma_alone'} diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index bbb2fa19c1..9fa8e9e049 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -107,7 +107,7 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
# Supported compression bintools -COMP_BINTOOLS = ['lz4', 'lzma_alone'] +COMP_BINTOOLS = ['bzip2', 'lz4', 'lzma_alone']
Add gzip bintool to binman to support on-the-fly compression of Linux kernel images and FPGA bitstreams. The SPL basic fitImage implementation supports only gzip decompression.
Changes in v2: - Add commit to add gzip bintool
tools/binman/btool/gzip.py | 31 +++++++++++++++++++++++++++++++ tools/binman/entry.py | 2 +- tools/binman/ftest.py | 2 +- 3 files changed, 33 insertions(+), 2 deletions(-) create mode 100644 tools/binman/btool/gzip.py
diff --git a/tools/binman/btool/gzip.py b/tools/binman/btool/gzip.py new file mode 100644 index 0000000000..0d75028120 --- /dev/null +++ b/tools/binman/btool/gzip.py @@ -0,0 +1,31 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com +# +"""Bintool implementation for gzip + +gzip allows compression and decompression of files. + +Documentation is available via:: + + man gzip +""" + +from binman import bintool + +# pylint: disable=C0103 +class Bintoolgzip(bintool.BintoolPacker): + """Compression/decompression using the gzip algorithm + + This bintool supports running `gzip` to compress and decompress data, as + used by binman. + + It is also possible to fetch the tool, which uses `apt` to install it. + + Documentation is available via:: + + man gzip + """ + def __init__(self, name): + super().__init__(name, compress_args=[], + version_regex=r'gzip ([0-9.]+)') diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 5fb8517329..8562a65d30 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1157,7 +1157,7 @@ features to produce new behaviours. """ algo = self.compress if algo != 'none': - algos = ['bzip2', 'lz4', 'lzma'] + algos = ['bzip2', 'gzip', 'lz4', 'lzma'] if algo not in algos: raise ValueError("Unknown algorithm '%s'" % algo) names = {'lzma': 'lzma_alone'} diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 9fa8e9e049..911c955cba 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -107,7 +107,7 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
# Supported compression bintools -COMP_BINTOOLS = ['bzip2', 'lz4', 'lzma_alone'] +COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone']
Add lzop bintool to binman to support on-the-fly compression.
Changes in v5: - Add algorithm name to entry.py - Add tool name to entry.py and ftest.py
Changes in v2: - Add commit to add lzop bintool
tools/binman/btool/lzop.py | 30 ++++++++++++++++++++++++++++++ tools/binman/entry.py | 4 ++-- tools/binman/ftest.py | 2 +- 3 files changed, 33 insertions(+), 3 deletions(-) create mode 100644 tools/binman/btool/lzop.py
diff --git a/tools/binman/btool/lzop.py b/tools/binman/btool/lzop.py new file mode 100644 index 0000000000..f6903b4db7 --- /dev/null +++ b/tools/binman/btool/lzop.py @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com +# +"""Bintool implementation for lzop + +lzop allows compression and decompression of files. + +Documentation is available via:: + + man lzop +""" + +from binman import bintool + +# pylint: disable=C0103 +class Bintoollzop(bintool.BintoolPacker): + """Compression/decompression using the lzop algorithm + + This bintool supports running `lzop` to compress and decompress data, as + used by binman. + + It is also possible to fetch the tool, which uses `apt` to install it. + + Documentation is available via:: + + man lzop + """ + def __init__(self, name): + super().__init__(name, 'lzo', compress_args=[]) diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 8562a65d30..ae3e94a167 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1157,10 +1157,10 @@ features to produce new behaviours. """ algo = self.compress if algo != 'none': - algos = ['bzip2', 'gzip', 'lz4', 'lzma'] + algos = ['bzip2', 'gzip', 'lz4', 'lzma', 'lzo'] if algo not in algos: raise ValueError("Unknown algorithm '%s'" % algo) - names = {'lzma': 'lzma_alone'} + names = {'lzma': 'lzma_alone', 'lzo': 'lzop'} name = names.get(self.compress, self.compress) self.comp_bintool = self.AddBintool(btools, name)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 911c955cba..2cac505d8b 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -107,7 +107,7 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
# Supported compression bintools -COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone'] +COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop']
From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
Add xz bintool to binman to support on-the-fly compression.
Changes in v2: - Add commit to add xz bintool
tools/binman/btool/xz.py | 31 +++++++++++++++++++++++++++++++ tools/binman/entry.py | 2 +- tools/binman/ftest.py | 2 +- 3 files changed, 33 insertions(+), 2 deletions(-) create mode 100644 tools/binman/btool/xz.py
diff --git a/tools/binman/btool/xz.py b/tools/binman/btool/xz.py new file mode 100644 index 0000000000..e2b413d18b --- /dev/null +++ b/tools/binman/btool/xz.py @@ -0,0 +1,31 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com +# +"""Bintool implementation for xz + +xz allows compression and decompression of files. + +Documentation is available via:: + + man xz +""" + +from binman import bintool + +# pylint: disable=C0103 +class Bintoolxz(bintool.BintoolPacker): + """Compression/decompression using the xz algorithm + + This bintool supports running `xz` to compress and decompress data, as + used by binman. + + It is also possible to fetch the tool, which uses `apt` to install it. + + Documentation is available via:: + + man xz + """ + def __init__(self, name): + super().__init__(name, fetch_package='xz-utils', + version_regex=r'xz (XZ Utils) ([0-9.]+)') diff --git a/tools/binman/entry.py b/tools/binman/entry.py index ae3e94a167..0d4990cf5d 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1157,7 +1157,7 @@ features to produce new behaviours. """ algo = self.compress if algo != 'none': - algos = ['bzip2', 'gzip', 'lz4', 'lzma', 'lzo'] + algos = ['bzip2', 'gzip', 'lz4', 'lzma', 'lzo', 'xz'] if algo not in algos: raise ValueError("Unknown algorithm '%s'" % algo) names = {'lzma': 'lzma_alone', 'lzo': 'lzop'} diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 2cac505d8b..b337e2168c 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -107,7 +107,7 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
# Supported compression bintools -COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop'] +COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop', 'xz']
Add zstd bintool to binman to support on-the-fly compression.
Changes in v5: - Test that zstd compress of device-tree files failed - Add algorithm name to entry.py - Add tool name to ftest.py
Changes in v2: - Add commit to add zstd bintool
tools/binman/btool/zstd.py | 30 +++++++++++++++++++++ tools/binman/entry.py | 2 +- tools/binman/etype/blob_dtb.py | 4 +++ tools/binman/ftest.py | 12 +++++++-- tools/binman/test/238_compress_dtb_zstd.dts | 16 +++++++++++ 5 files changed, 61 insertions(+), 3 deletions(-) create mode 100644 tools/binman/btool/zstd.py create mode 100644 tools/binman/test/238_compress_dtb_zstd.dts
diff --git a/tools/binman/btool/zstd.py b/tools/binman/btool/zstd.py new file mode 100644 index 0000000000..299bd37126 --- /dev/null +++ b/tools/binman/btool/zstd.py @@ -0,0 +1,30 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Weidmüller Interface GmbH & Co. KG +# Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com +# +"""Bintool implementation for zstd + +zstd allows compression and decompression of files. + +Documentation is available via:: + + man zstd +""" + +from binman import bintool + +# pylint: disable=C0103 +class Bintoolzstd(bintool.BintoolPacker): + """Compression/decompression using the zstd algorithm + + This bintool supports running `zstd` to compress and decompress data, as + used by binman. + + It is also possible to fetch the tool, which uses `apt` to install it. + + Documentation is available via:: + + man zstd + """ + def __init__(self, name): + super().__init__(name) diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 0d4990cf5d..8e4a5e301a 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1157,7 +1157,7 @@ features to produce new behaviours. """ algo = self.compress if algo != 'none': - algos = ['bzip2', 'gzip', 'lz4', 'lzma', 'lzo', 'xz'] + algos = ['bzip2', 'gzip', 'lz4', 'lzma', 'lzo', 'xz', 'zstd'] if algo not in algos: raise ValueError("Unknown algorithm '%s'" % algo) names = {'lzma': 'lzma_alone', 'lzo': 'lzop'} diff --git a/tools/binman/etype/blob_dtb.py b/tools/binman/etype/blob_dtb.py index 5a6a454748..6a3fbc4775 100644 --- a/tools/binman/etype/blob_dtb.py +++ b/tools/binman/etype/blob_dtb.py @@ -47,6 +47,10 @@ class Entry_blob_dtb(Entry_blob): def ProcessContents(self): """Re-read the DTB contents so that we get any calculated properties""" _, indata = state.GetFdtContents(self.GetFdtEtype()) + + if self.compress == 'zstd' and self.prepend != 'length': + self.Raise('The zstd compression requires a length header') + data = self.CompressData(indata) return self.ProcessContentsUpdate(data)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index b337e2168c..134301365e 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -107,7 +107,7 @@ BASE_DTB_PROPS = ['offset', 'size', 'image-pos'] REPACK_DTB_PROPS = ['orig-offset', 'orig-size']
# Supported compression bintools -COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop', 'xz'] +COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop', 'xz', 'zstd']
class TestFunctional(unittest.TestCase): """Functional tests for binman @@ -5797,7 +5797,8 @@ fdt fdtmap Extract the devicetree blob from the fdtmap
def testCompUtilPadding(self): """Test padding of compression algorithms""" - for bintool in self.comp_bintools.values(): + # Skip zstd because it doesn't support padding + for bintool in [v for k,v in self.comp_bintools.items() if k != 'zstd']: self._CheckBintool(bintool) data = bintool.compress(COMPRESS_DATA) self.assertNotEqual(COMPRESS_DATA, data) @@ -5805,6 +5806,13 @@ fdt fdtmap Extract the devicetree blob from the fdtmap orig = bintool.decompress(data) self.assertEquals(COMPRESS_DATA, orig)
+ def testCompressDtbZstd(self): + """Test that zstd compress of device-tree files failed""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('238_compress_dtb_zstd.dts') + self.assertIn("Node '/binman/u-boot-dtb': The zstd compression " + "requires a length header", str(e.exception)) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/238_compress_dtb_zstd.dts b/tools/binman/test/238_compress_dtb_zstd.dts new file mode 100644 index 0000000000..90cf85d1e2 --- /dev/null +++ b/tools/binman/test/238_compress_dtb_zstd.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + u-boot-dtb { + compress = "zstd"; + }; + }; +};
