[U-Boot] [PATCH 1/2] ARM: zynq: Remove DTC 1.2 warnings
DTC 1.2 reports these warnings: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /pmu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property
This patch is fixing them.
arch/arm/dts/zynq-7000.dtsi | 7 ++++--- arch/arm/dts/zynq-microzed.dts | 2 +- arch/arm/dts/zynq-picozed.dts | 2 +- arch/arm/dts/zynq-topic-miami.dts | 2 +- arch/arm/dts/zynq-zc702.dts | 2 +- arch/arm/dts/zynq-zc706.dts | 2 +- arch/arm/dts/zynq-zc770-xm010.dts | 2 +- arch/arm/dts/zynq-zc770-xm011.dts | 2 +- arch/arm/dts/zynq-zc770-xm012.dts | 2 +- arch/arm/dts/zynq-zc770-xm013.dts | 2 +- arch/arm/dts/zynq-zed.dts | 2 +- arch/arm/dts/zynq-zybo.dts | 2 +- 12 files changed, 15 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index b618a3f484f0..6df0329cfc90 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -6,9 +6,10 @@ * * SPDX-License-Identifier: GPL-2.0+ */ -/include/ "skeleton.dtsi"
/ { + #address-cells = <1>; + #size-cells = <1>; compatible = "xlnx,zynq-7000";
cpus { @@ -37,14 +38,14 @@ }; };
- pmu { + pmu@f8891000 { compatible = "arm,cortex-a9-pmu"; interrupts = <0 5 4>, <0 6 4>; interrupt-parent = <&intc>; reg = < 0xf8891000 0x1000 0xf8893000 0x1000 >; };
- regulator_vccpint: fixedregulator@0 { + regulator_vccpint: fixedregulator { compatible = "regulator-fixed"; regulator-name = "VCCPINT"; regulator-min-microvolt = <1000000>; diff --git a/arch/arm/dts/zynq-microzed.dts b/arch/arm/dts/zynq-microzed.dts index cb238cd5e7bb..2d07b92e9cff 100644 --- a/arch/arm/dts/zynq-microzed.dts +++ b/arch/arm/dts/zynq-microzed.dts @@ -18,7 +18,7 @@ mmc0 = &sdhci0; };
- memory { + memory@0 { device_type = "memory"; reg = <0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-picozed.dts b/arch/arm/dts/zynq-picozed.dts index 3408df8b8b3d..fea04ab45a72 100644 --- a/arch/arm/dts/zynq-picozed.dts +++ b/arch/arm/dts/zynq-picozed.dts @@ -16,7 +16,7 @@ serial0 = &uart1; };
- memory { + memory@0 { device_type = "memory"; reg = <0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-topic-miami.dts b/arch/arm/dts/zynq-topic-miami.dts index 8e988f92877c..aa05c4d368b2 100644 --- a/arch/arm/dts/zynq-topic-miami.dts +++ b/arch/arm/dts/zynq-topic-miami.dts @@ -21,7 +21,7 @@ mmc0 = &sdhci0; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc702.dts b/arch/arm/dts/zynq-zc702.dts index 6585010f4bc8..478e9fd4ef25 100644 --- a/arch/arm/dts/zynq-zc702.dts +++ b/arch/arm/dts/zynq-zc702.dts @@ -21,7 +21,7 @@ mmc0 = &sdhci0; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc706.dts b/arch/arm/dts/zynq-zc706.dts index d04880a2cdd3..8b0177bc512a 100644 --- a/arch/arm/dts/zynq-zc706.dts +++ b/arch/arm/dts/zynq-zc706.dts @@ -21,7 +21,7 @@ mmc0 = &sdhci0; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts index 33524cb6def5..42af313c13dd 100644 --- a/arch/arm/dts/zynq-zc770-xm010.dts +++ b/arch/arm/dts/zynq-zc770-xm010.dts @@ -25,7 +25,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm011.dts b/arch/arm/dts/zynq-zc770-xm011.dts index 463b14b5ea15..7f08961491a6 100644 --- a/arch/arm/dts/zynq-zc770-xm011.dts +++ b/arch/arm/dts/zynq-zc770-xm011.dts @@ -23,7 +23,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm012.dts b/arch/arm/dts/zynq-zc770-xm012.dts index 6cab83266770..699cd2c0fb1c 100644 --- a/arch/arm/dts/zynq-zc770-xm012.dts +++ b/arch/arm/dts/zynq-zc770-xm012.dts @@ -24,7 +24,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index d5bb4efcc58a..07e92b88fb0f 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -25,7 +25,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zed.dts b/arch/arm/dts/zynq-zed.dts index 4363a4fcaccb..0ac7532300f0 100644 --- a/arch/arm/dts/zynq-zed.dts +++ b/arch/arm/dts/zynq-zed.dts @@ -20,7 +20,7 @@ mmc0 = &sdhci0; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x20000000>; }; diff --git a/arch/arm/dts/zynq-zybo.dts b/arch/arm/dts/zynq-zybo.dts index f8dcf1d6995c..d59a3831352d 100644 --- a/arch/arm/dts/zynq-zybo.dts +++ b/arch/arm/dts/zynq-zybo.dts @@ -20,7 +20,7 @@ mmc0 = &sdhci0; };
DTC 1.2 reports these warnings: Warning (unit_address_vs_reg): Node /amba_apu has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /amba has a reg or ranges property, but no unit name Warning (unit_address_vs_reg): Node /amba/usb@fe200000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/usb@fe300000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video0channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video1channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-video2channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-graphicschannel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-audio0channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /amba/dma@fd4c0000/dma-audio1channel@fd4c0000 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
arch/arm/dts/zynqmp-ep108.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 2 +- arch/arm/dts/zynqmp-zcu102.dts | 2 +- arch/arm/dts/zynqmp.dtsi | 20 ++++++++++---------- 7 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/zynqmp-ep108.dts b/arch/arm/dts/zynqmp-ep108.dts index 0bbf9a759756..751717028b50 100644 --- a/arch/arm/dts/zynqmp-ep108.dts +++ b/arch/arm/dts/zynqmp-ep108.dts @@ -31,7 +31,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index c68a41bea79a..f3bca60c7e8d 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -34,7 +34,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts index 3fdfcc8a11ae..09a114be1610 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts @@ -36,7 +36,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts index 03f1ad7934c1..1f03a94820e2 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts @@ -41,7 +41,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts b/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts index d754f9f9040a..698e72e0c5d0 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts @@ -32,7 +32,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/zynqmp-zcu102.dts b/arch/arm/dts/zynqmp-zcu102.dts index de9960245664..b3f5eaacaefc 100644 --- a/arch/arm/dts/zynqmp-zcu102.dts +++ b/arch/arm/dts/zynqmp-zcu102.dts @@ -35,7 +35,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 619450e1ba92..ac17c4723a13 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -243,7 +243,7 @@ <1 10 0xf01>; };
- amba_apu: amba_apu { + amba_apu: amba_apu@0 { compatible = "simple-bus"; #address-cells = <2>; #size-cells = <1>; @@ -262,7 +262,7 @@ }; };
- amba: amba { + amba: amba@0 { compatible = "simple-bus"; u-boot,dm-pre-reloc; #address-cells = <2>; @@ -800,7 +800,7 @@ power-domains = <&pd_uart1>; };
- usb0: usb@fe200000 { + usb0: usb0 { #address-cells = <2>; #size-cells = <1>; status = "disabled"; @@ -821,7 +821,7 @@ }; };
- usb1: usb@fe300000 { + usb1: usb1 { #address-cells = <2>; #size-cells = <1>; status = "disabled"; @@ -938,22 +938,22 @@ clock-names = "axi_clk"; dma-channels = <6>; #dma-cells = <1>; - dma-video0channel@fd4c0000 { + dma-video0channel { compatible = "xlnx,video0"; }; - dma-video1channel@fd4c0000 { + dma-video1channel { compatible = "xlnx,video1"; }; - dma-video2channel@fd4c0000 { + dma-video2channel { compatible = "xlnx,video2"; }; - dma-graphicschannel@fd4c0000 { + dma-graphicschannel { compatible = "xlnx,graphics"; }; - dma-audio0channel@fd4c0000 { + dma-audio0channel { compatible = "xlnx,audio0"; }; - dma-audio1channel@fd4c0000 { + dma-audio1channel { compatible = "xlnx,audio1"; }; };
Have you addressed these in Linux as well?
2016-11-11 17:04 GMT+01:00 Tom Rini trini@konsulko.com:
Going to do so next week. Both should be in sync.
Thanks, Michal
Agreed. I'd prefer to pull them in via Linux but at least once they're on their way into the right tree for upstream we can bring them in here as well (as I want to ensure future re-syncs are easy). Thanks!
I have sent them to Linux too. http://lists.infradead.org/pipermail/linux-arm-kernel/2016-November/467965.h... http://lists.infradead.org/pipermail/linux-arm-kernel/2016-November/467967.h... http://lists.infradead.org/pipermail/linux-arm-kernel/2016-November/467968.h...
For our case we have more dtses in u-boot especially for arm64 than in Linux. Also u-boot,dm-pre-reloc AFAIK hasn't been validated via dt mailing list. I see one thread in 2015 without any resolution. That's why taking stuff from Linux is sort of goal but nothing what we can do without additional work.
Thanks, Michal
OK.
Intentional or just boards that have not yet made it there?
Yes, this is something that might get a re-visit someday, but is indeed local to U-Boot only for now.
So long as everything relevant to upstream has been posted upstream (and you're saying it is, so good, I'm happy) then we're in good shape here.
OK.
Simply because getting these stuff to U-Boot is easier then to Linux.
Adding this to chosen node with list of IPs should be IMHO reasonable solution.
Trying to keep all stuff in sync as much as possible and definitely we need to do more Linux upstreaming.
Thanks, Michal
Hi.
2016-11-16 4:01 GMT+09:00 Michal Simek monstr@monstr.eu:
DTC 1.2 ?
Do you use such old DTC?
The top-level Makefile of U-Boot requires DTC 1.4 or newer, so you cannot use DTC 1.2 from U-Boot build system.
checkdtc: @if test $(call dtc-version) -lt 0104; then \ echo '*** Your dtc is too old, please upgrade to dtc 1.4 or newer'; \ false; \ fi
Did you run DTC directly, and were you hit by a problem?
On 16.11.2016 01:34, Masahiro Yamada wrote:
Hi.
> On Fri, Nov 11, 2016 at 01:26:05PM +0100, Michal Simek wrote: > >> DTC 1.2 reports these warnings:
DTC 1.2 ?
That was typo - it is 1.4.2 dtc.
Thanks, Michal
Masahiro Yamada
Michal Simek
Michal Simek
