[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks! Jagan.
The following changes since commit b24065c4ef21687787a74eef22dfa9232096f965:
Merge git://git.denx.de/u-boot-i2c (2017-08-10 07:22:59 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 585bf8ae6f467d85b8e9f17141c8562d96a83c51:
sun50i: a64: Add A64-OLinuXino initial support (2017-08-15 11:30:59 +0530)
---------------------------------------------------------------- Clément Bœsch (1): sunxi: reduce Orange Pi Zero DRAM clock speed
Emmanuel Vadot (1): ARM: dts: sunxi: Change node name for pwrseq pin on Olinuxino-lime2-emmc
Icenowy Zheng (3): sunxi: add PRCM secure switch register definition sunxi: switch PRCM to non-secure on H3/H5 SoCs sunxi: add MACPWR in Orange Pi PC2 defconfig
Jagan Teki (3): sun50i: a64: Sync Linux [oe]hci0 nodes sun50i: a64: Add initial NanoPi A64 support sun50i: a64: Add A64-OLinuXino initial support
Olliver Schinagl (1): sun7i: Add support for Olimex A20-OLinuXino-LIME2-eMMC
arch/arm/dts/Makefile | 2 + arch/arm/dts/sun50i-a64-nanopi-a64.dts | 115 ++++++++++++++++++++++++ arch/arm/dts/sun50i-a64-olinuxino.dts | 84 +++++++++++++++++ arch/arm/dts/sun50i-a64.dtsi | 22 +++++ arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts | 2 +- arch/arm/include/asm/arch-sunxi/prcm.h | 6 ++ arch/arm/mach-sunxi/clock_sun6i.c | 6 ++ board/sunxi/MAINTAINERS | 15 ++++ configs/A20-OLinuXino-Lime2-eMMC_defconfig | 36 ++++++++ configs/a64-olinuxino_defconfig | 15 ++++ configs/nanopi_a64_defconfig | 15 ++++ configs/orangepi_pc2_defconfig | 1 + configs/orangepi_zero_defconfig | 2 +- 13 files changed, 319 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-nanopi-a64.dts create mode 100644 arch/arm/dts/sun50i-a64-olinuxino.dts create mode 100644 configs/A20-OLinuXino-Lime2-eMMC_defconfig create mode 100644 configs/a64-olinuxino_defconfig create mode 100644 configs/nanopi_a64_defconfig
On Wed, Aug 16, 2017 at 06:41:09PM +0530, Jagan Teki wrote:
Hi Tom,
thanks! Jagan.
Jagan Teki
