[PATCH 0/1] common:autoboot:modify function parameters
In the autoboot.c file under uboot/common/, the blob parameter of the function process_fdt_options has not been invoked in the function body and should be changed to void type
Shenlin Liang (1): common:autoboot:modify function parameters
common/autoboot.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
Signed-off-by: Shenlin Liang liangshenlin@eswincomputing.com --- common/autoboot.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/autoboot.c b/common/autoboot.c index ea44fdf6ad..848c33b2f2 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -422,7 +422,7 @@ static int abortboot(int bootdelay) return abort; }
-static void process_fdt_options(const void *blob) +static void process_fdt_options(void) { #ifdef CONFIG_TEXT_BASE ulong addr; @@ -474,7 +474,7 @@ const char *bootdelay_process(void) s = env_get("bootcmd");
if (IS_ENABLED(CONFIG_OF_CONTROL)) - process_fdt_options(gd->fdt_blob); + process_fdt_options(); stored_bootdelay = bootdelay;
return s;
On Sat, 3 Dec 2022 at 01:25, Shenlin Liang liangshenlin@eswincomputing.com wrote:
Signed-off-by: Shenlin Liang liangshenlin@eswincomputing.com Reviewed-by: Simon Glass sjg@chromium.org
Shenlin Liang
