[U-Boot] [PATCH] drivers/ddr/fsl: fsl_ddr_sdram_size remove unused controllers
Following commit 61bd2f75, exclude unused DDR controller from calculating RAM size for SPL boot.
Signed-off-by: Ed Swarthout Ed.Swarthout@nxp.com ---
Applies to v2016.01. Tested on ls2080aqds.
drivers/ddr/fsl/main.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index c686632..6031396 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -859,6 +859,7 @@ fsl_ddr_sdram_size(void) info.num_ctrls = CONFIG_SYS_FSL_DDR_MAIN_NUM_CTRLS; info.dimm_slots_per_ctrl = CONFIG_DIMM_SLOTS_PER_CTLR; info.board_need_mem_reset = NULL; + remove_unused_controllers(&info);
/* Compute it once normally. */ total_memory = fsl_ddr_compute(&info, STEP_GET_SPD, 1);
Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Ed Swarthout
york sun
