[U-Boot] sunxi: Bug fixes, sun4i and sun5i support, pmic support and network improvements
Hi All,
Here is a patch series to be applied on top of Ian's recently merged series which added basic sun7i support.
This patch series begins with a few bug fixes found while working on preparing the rest of the series, adds sun4i and sun5i support, pmic support (which is necessary to clock the CPU at its max speed), and rounds things of with some networking fixes / additions.
Regards,
Hans
We should not be aligning the amount of bytes which we try to read from the disk, this leads to trying to read more bytes then there are which fails.
file_size is already aligned to BLOCK_SIZE before being stored in img.header.length, so there is no need for load_size at all.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- tools/mksunxiboot.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/tools/mksunxiboot.c b/tools/mksunxiboot.c index da7c9f0..1f0fbae 100644 --- a/tools/mksunxiboot.c +++ b/tools/mksunxiboot.c @@ -77,7 +77,7 @@ int main(int argc, char *argv[]) { int fd_in, fd_out; struct boot_img img; - unsigned file_size, load_size; + unsigned file_size; int count;
if (argc < 2) { @@ -101,8 +101,6 @@ int main(int argc, char *argv[]) if (file_size > SRAM_LOAD_MAX_SIZE) { fprintf(stderr, "ERROR: File too large!\n"); return EXIT_FAILURE; - } else { - load_size = ALIGN(file_size, sizeof(int)); }
fd_out = open(argv[2], O_WRONLY | O_CREAT, 0666); @@ -113,8 +111,8 @@ int main(int argc, char *argv[])
/* read file to buffer to calculate checksum */ lseek(fd_in, 0, SEEK_SET); - count = read(fd_in, img.code, load_size); - if (count != load_size) { + count = read(fd_in, img.code, file_size); + if (count != file_size) { perror("Reading input image"); return EXIT_FAILURE; } @@ -126,7 +124,7 @@ int main(int argc, char *argv[]) & 0x00FFFFFF); memcpy(img.header.magic, BOOT0_MAGIC, 8); /* no '0' termination */ img.header.length = - ALIGN(load_size + sizeof(struct boot_file_head), BLOCK_SIZE); + ALIGN(file_size + sizeof(struct boot_file_head), BLOCK_SIZE); gen_check_sum(&img.header);
count = write(fd_out, &img, img.header.length);
Acked-by: Ian Campbell ijc@hellion.org.uk
Acked-by: Siarhei Siamashka siarhei.siamashka@gmail.com
Was there any valid reason why this important bugfix has not been nominated for v2014.07?
Not sure what you mean, it is part of the PR at http://patchwork.ozlabs.org/patch/371704/
Ian.
Oh, you said .07 which was the last one.
There was no particular reason, it just didn't make it. We were still figuring out the upstream work flow at the time.
Ian.
Adjust the u-boot-spl.lds linker script to match the changes made in the "arm: move exception handling out of start.S files" commit.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/u-boot-spl.lds | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds index 5008028..c1ae227 100644 --- a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds +++ b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds @@ -27,6 +27,7 @@ SECTIONS .text : { __start = .; + *(.vectors) arch/arm/cpu/armv7/start.o (.text) *(.text*) } > .sram
(perhaps include the sha1 here)
The DMA code in sunxi_mmc.c is broken. mmc_trans_data_by_dma() allocates the dma descriptors on the stack, and then exits while the dma transfer is in progress, so the dma engine is reading stack memory which at that point may be re-used. So far we've gotten away with this by luck, but recent u-boot changes have shifted the stack start address by 16 bytes, which combined with dma alignment now exposes this problem.
Since we end up just busy waiting for the dma engine anyway, this commit fixes things by simply removing the dma code, resulting in smaller bug-free code.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/mmc/sunxi_mmc.c | 140 ++--------------------------------------- include/configs/sunxi-common.h | 1 - 2 files changed, 6 insertions(+), 135 deletions(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index eb7b115..ae0cf1a 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -16,28 +16,6 @@ #include <asm/arch/cpu.h> #include <asm/arch/mmc.h>
-struct sunxi_mmc_des { - u32 reserved1_1:1; - u32 dic:1; /* disable interrupt on completion */ - u32 last_des:1; /* 1-this data buffer is the last buffer */ - u32 first_des:1; /* 1-data buffer is the first buffer, - 0-data buffer contained in the next - descriptor is 1st buffer */ - u32 des_chain:1; /* 1-the 2nd address in the descriptor is the - next descriptor address */ - u32 end_of_ring:1; /* 1-last descriptor flag when using dual - data buffer in descriptor */ - u32 reserved1_2:24; - u32 card_err_sum:1; /* transfer error flag */ - u32 own:1; /* des owner:1-idma owns it, 0-host owns it */ -#define SDXC_DES_NUM_SHIFT 16 -#define SDXC_DES_BUFFER_MAX_LEN (1 << SDXC_DES_NUM_SHIFT) - u32 data_buf1_sz:16; - u32 data_buf2_sz:16; - u32 buf_addr_ptr1; - u32 buf_addr_ptr2; -}; - struct sunxi_mmc_host { unsigned mmc_no; uint32_t *mclkreg; @@ -189,6 +167,9 @@ static int mmc_core_init(struct mmc *mmc)
/* Reset controller */ writel(SUNXI_MMC_GCTRL_RESET, &mmchost->reg->gctrl); + udelay(1000); + /* Always read / write data through the CPU */ + writel(SUNXI_MMC_GCTRL_ACCESS_BY_AHB, &mmchost->reg->gctrl);
return 0; } @@ -220,85 +201,6 @@ static int mmc_trans_data_by_cpu(struct mmc *mmc, struct mmc_data *data) return 0; }
-static int mmc_trans_data_by_dma(struct mmc *mmc, struct mmc_data *data) -{ - struct sunxi_mmc_host *mmchost = mmc->priv; - unsigned byte_cnt = data->blocksize * data->blocks; - unsigned char *buff; - unsigned des_idx = 0; - unsigned buff_frag_num = - (byte_cnt + SDXC_DES_BUFFER_MAX_LEN - 1) >> SDXC_DES_NUM_SHIFT; - unsigned remain; - unsigned i, rval; - ALLOC_CACHE_ALIGN_BUFFER(struct sunxi_mmc_des, pdes, buff_frag_num); - - buff = data->flags & MMC_DATA_READ ? - (unsigned char *)data->dest : (unsigned char *)data->src; - remain = byte_cnt & (SDXC_DES_BUFFER_MAX_LEN - 1); - - flush_cache((unsigned long)buff, (unsigned long)byte_cnt); - for (i = 0; i < buff_frag_num; i++, des_idx++) { - memset((void *)&pdes[des_idx], 0, sizeof(struct sunxi_mmc_des)); - pdes[des_idx].des_chain = 1; - pdes[des_idx].own = 1; - pdes[des_idx].dic = 1; - if (buff_frag_num > 1 && i != buff_frag_num - 1) - pdes[des_idx].data_buf1_sz = 0; /* 0 == max_len */ - else - pdes[des_idx].data_buf1_sz = remain; - - pdes[des_idx].buf_addr_ptr1 = - (u32) buff + i * SDXC_DES_BUFFER_MAX_LEN; - if (i == 0) - pdes[des_idx].first_des = 1; - - if (i == buff_frag_num - 1) { - pdes[des_idx].dic = 0; - pdes[des_idx].last_des = 1; - pdes[des_idx].end_of_ring = 1; - pdes[des_idx].buf_addr_ptr2 = 0; - } else { - pdes[des_idx].buf_addr_ptr2 = (u32)&pdes[des_idx + 1]; - } - } - flush_cache((unsigned long)pdes, - sizeof(struct sunxi_mmc_des) * (des_idx + 1)); - - rval = readl(&mmchost->reg->gctrl); - /* Enable DMA */ - writel(rval | SUNXI_MMC_GCTRL_DMA_RESET | SUNXI_MMC_GCTRL_DMA_ENABLE, - &mmchost->reg->gctrl); - /* Reset iDMA */ - writel(SUNXI_MMC_IDMAC_RESET, &mmchost->reg->dmac); - /* Enable iDMA */ - writel(SUNXI_MMC_IDMAC_FIXBURST | SUNXI_MMC_IDMAC_ENABLE, - &mmchost->reg->dmac); - rval = readl(&mmchost->reg->idie) & - ~(SUNXI_MMC_IDIE_TXIRQ|SUNXI_MMC_IDIE_RXIRQ); - if (data->flags & MMC_DATA_WRITE) - rval |= SUNXI_MMC_IDIE_TXIRQ; - else - rval |= SUNXI_MMC_IDIE_RXIRQ; - writel(rval, &mmchost->reg->idie); - writel((u32) pdes, &mmchost->reg->dlba); - writel((0x2 << 28) | (0x7 << 16) | (0x01 << 3), - &mmchost->reg->ftrglevel); - - return 0; -} - -static void mmc_enable_dma_accesses(struct mmc *mmc, int dma) -{ - struct sunxi_mmc_host *mmchost = mmc->priv; - - unsigned int gctrl = readl(&mmchost->reg->gctrl); - if (dma) - gctrl &= ~SUNXI_MMC_GCTRL_ACCESS_BY_AHB; - else - gctrl |= SUNXI_MMC_GCTRL_ACCESS_BY_AHB; - writel(gctrl, &mmchost->reg->gctrl); -} - static int mmc_rint_wait(struct mmc *mmc, unsigned int timeout_msecs, unsigned int done_bit, const char *what) { @@ -327,7 +229,6 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, unsigned int timeout_msecs; int error = 0; unsigned int status = 0; - unsigned int usedma = 0; unsigned int bytecnt = 0;
if (mmchost->fatal_err) @@ -378,20 +279,8 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd,
bytecnt = data->blocksize * data->blocks; debug("trans data %d bytes\n", bytecnt); -#if defined(CONFIG_MMC_SUNXI_USE_DMA) && !defined(CONFIG_SPL_BUILD) - if (bytecnt > 64) { -#else - if (0) { -#endif - usedma = 1; - mmc_enable_dma_accesses(mmc, 1); - ret = mmc_trans_data_by_dma(mmc, data); - writel(cmdval | cmd->cmdidx, &mmchost->reg->cmd); - } else { - mmc_enable_dma_accesses(mmc, 0); - writel(cmdval | cmd->cmdidx, &mmchost->reg->cmd); - ret = mmc_trans_data_by_cpu(mmc, data); - } + writel(cmdval | cmd->cmdidx, &mmchost->reg->cmd); + ret = mmc_trans_data_by_cpu(mmc, data); if (ret) { error = readl(&mmchost->reg->rint) & \ SUNXI_MMC_RINT_INTERRUPT_ERROR_BIT; @@ -405,7 +294,7 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, goto out;
if (data) { - timeout_msecs = usedma ? 120 * bytecnt : 120; + timeout_msecs = 120; debug("cacl timeout %x msec\n", timeout_msecs); error = mmc_rint_wait(mmc, timeout_msecs, data->blocks > 1 ? @@ -442,23 +331,6 @@ static int mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, debug("mmc resp 0x%08x\n", cmd->response[0]); } out: - if (data && usedma) { - /* IDMASTAREG - * IDST[0] : idma tx int - * IDST[1] : idma rx int - * IDST[2] : idma fatal bus error - * IDST[4] : idma descriptor invalid - * IDST[5] : idma error summary - * IDST[8] : idma normal interrupt sumary - * IDST[9] : idma abnormal interrupt sumary - */ - status = readl(&mmchost->reg->idst); - writel(status, &mmchost->reg->idst); - writel(0, &mmchost->reg->idie); - writel(0, &mmchost->reg->dmac); - writel(readl(&mmchost->reg->gctrl) & ~SUNXI_MMC_GCTRL_DMA_ENABLE, - &mmchost->reg->gctrl); - } if (error < 0) { writel(SUNXI_MMC_GCTRL_RESET, &mmchost->reg->gctrl); mmc_update_clk(mmc); diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5d72d62..fd02d0d 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -70,7 +70,6 @@ #define CONFIG_CMD_MMC #define CONFIG_MMC_SUNXI #define CONFIG_MMC_SUNXI_SLOT 0 -#define CONFIG_MMC_SUNXI_USE_DMA #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* first detected MMC controller */
Oh dear!
There is no way to reset the cpu, so use the watchdog for this.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 7 +++++++ arch/arm/include/asm/arch-sunxi/timer.h | 5 +++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 49c9448..c80b421 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -56,6 +56,13 @@ int gpio_init(void)
void reset_cpu(ulong addr) { + static const struct sunxi_wdog *wdog = + &((struct sunxi_timer_reg *)SUNXI_TIMER_BASE)->wdog; + + /* Set the watchdog for its shortest interval (.5s) and wait */ + writel(WDT_MODE_RESET_EN | WDT_MODE_EN, &wdog->mode); + writel(WDT_CTRL_KEY | WDT_CTRL_RESTART, &wdog->ctl); + while (1); }
/* do some early init */ diff --git a/arch/arm/include/asm/arch-sunxi/timer.h b/arch/arm/include/asm/arch-sunxi/timer.h index 6aacfd7..4a43ed9 100644 --- a/arch/arm/include/asm/arch-sunxi/timer.h +++ b/arch/arm/include/asm/arch-sunxi/timer.h @@ -11,6 +11,11 @@ #ifndef _SUNXI_TIMER_H_ #define _SUNXI_TIMER_H_
+#define WDT_CTRL_RESTART (0x1 << 0) +#define WDT_CTRL_KEY (0x0a57 << 1) +#define WDT_MODE_EN (0x1 << 0) +#define WDT_MODE_RESET_EN (0x1 << 1) + #ifndef __ASSEMBLY__
#include <linux/types.h>
One nit
Some sort of whitespace snafuu I think.
One nit
Yeah I somehow ended up using spaces for some of the indents, fixed in my local tree and personal git repo.
Regards,
Hans
Add support for the Allwinner A10 SoC also know as the Allwinner sun4i family.
Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/Makefile | 2 + arch/arm/cpu/armv7/sunxi/cpu_info.c | 7 ++++ arch/arm/cpu/armv7/sunxi/dram.c | 81 +++++++++++++++++++++++++++++++++++-- board/sunxi/Makefile | 1 + board/sunxi/dram_cubieboard.c | 31 ++++++++++++++ boards.cfg | 1 + include/configs/sun4i.h | 23 +++++++++++ 7 files changed, 143 insertions(+), 3 deletions(-) create mode 100644 board/sunxi/dram_cubieboard.c create mode 100644 include/configs/sun4i.h
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index a64bfa1..856d353 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -11,6 +11,7 @@ obj-y += timer.o obj-y += board.o obj-y += clock.o obj-y += pinmux.o +obj-$(CONFIG_SUN4I) += clock_sun4i.o obj-$(CONFIG_SUN7I) += clock_sun4i.o
ifndef CONFIG_SPL_BUILD @@ -18,6 +19,7 @@ obj-y += cpu_info.o endif
ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SUN4I) += dram.o obj-$(CONFIG_SUN7I) += dram.o ifdef CONFIG_SPL_FEL obj-y += start.o diff --git a/arch/arm/cpu/armv7/sunxi/cpu_info.c b/arch/arm/cpu/armv7/sunxi/cpu_info.c index b4c3d5c..b4b5089 100644 --- a/arch/arm/cpu/armv7/sunxi/cpu_info.c +++ b/arch/arm/cpu/armv7/sunxi/cpu_info.c @@ -13,7 +13,14 @@ #ifdef CONFIG_DISPLAY_CPUINFO int print_cpuinfo(void) { +#ifdef CONFIG_SUN4I + puts("CPU: Allwinner A10 (SUN4I)\n"); +#elif defined CONFIG_SUN7I puts("CPU: Allwinner A20 (SUN7I)\n"); +#else +#warning Please update cpu_info.c with correct CPU information + puts("CPU: SUNXI Family\n"); +#endif return 0; } #endif diff --git a/arch/arm/cpu/armv7/sunxi/dram.c b/arch/arm/cpu/armv7/sunxi/dram.c index b43c4b4..76753d7 100644 --- a/arch/arm/cpu/armv7/sunxi/dram.c +++ b/arch/arm/cpu/armv7/sunxi/dram.c @@ -53,16 +53,37 @@ static void mctl_ddr3_reset(void) struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
- clrbits_le32(&dram->mcr, DRAM_MCR_RESET); - udelay(2); - setbits_le32(&dram->mcr, DRAM_MCR_RESET); +#ifdef CONFIG_SUN4I + struct sunxi_timer_reg *timer = + (struct sunxi_timer_reg *)SUNXI_TIMER_BASE; + u32 reg_val; + + writel(0, &timer->cpu_cfg); + reg_val = readl(&timer->cpu_cfg); + + if ((reg_val & CPU_CFG_CHIP_VER_MASK) != + CPU_CFG_CHIP_VER(CPU_CFG_CHIP_REV_A)) { + setbits_le32(&dram->mcr, DRAM_MCR_RESET); + udelay(2); + clrbits_le32(&dram->mcr, DRAM_MCR_RESET); + } else +#endif + { + clrbits_le32(&dram->mcr, DRAM_MCR_RESET); + udelay(2); + setbits_le32(&dram->mcr, DRAM_MCR_RESET); + } }
static void mctl_set_drive(void) { struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
+#ifdef CONFIG_SUN7I clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3) | (0x3 << 28), +#else + clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3), +#endif DRAM_MCR_MODE_EN(0x3) | 0xffc); } @@ -134,6 +155,16 @@ static void mctl_enable_dllx(u32 phase) }
static u32 hpcr_value[32] = { +#ifdef CONFIG_SUN4I + 0x0301, 0x0301, 0x0301, 0x0301, + 0x0301, 0x0301, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0x1031, 0x1031, 0x0735, 0x5031, + 0x1035, 0x0731, 0x1031, 0x0735, + 0x1035, 0x1031, 0x0731, 0x1035, + 0x1031, 0x0301, 0x0301, 0x0731 +#endif #ifdef CONFIG_SUN7I 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, @@ -223,22 +254,32 @@ static void mctl_setup_dram_clock(u32 clk) clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_GPS); #endif
+#if defined(CONFIG_SUN5I) || defined(CONFIG_SUN7I) /* setup MBUS clock */ reg_val = CCM_MBUS_CTRL_GATE | CCM_MBUS_CTRL_CLK_SRC(CCM_MBUS_CTRL_CLK_SRC_PLL6) | CCM_MBUS_CTRL_N(CCM_MBUS_CTRL_N_X(2)) | CCM_MBUS_CTRL_M(CCM_MBUS_CTRL_M_X(2)); writel(reg_val, &ccm->mbus_clk_cfg); +#endif
/* * open DRAMC AHB & DLL register clock * close it first */ +#if defined(CONFIG_SUN5I) || defined(CONFIG_SUN7I) clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM | CCM_AHB_GATE_DLL); +#else + clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM); +#endif udelay(22);
/* then open it */ +#if defined(CONFIG_SUN5I) || defined(CONFIG_SUN7I) setbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM | CCM_AHB_GATE_DLL); +#else + setbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM); +#endif udelay(22); }
@@ -385,6 +426,13 @@ static void dramc_clock_output_en(u32 on) else clrbits_le32(&dram->mcr, DRAM_MCR_DCLK_OUT); #endif +#ifdef CONFIG_SUN4I + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + if (on) + setbits_le32(&ccm->dram_clk_cfg, CCM_DRAM_CTRL_DCLK_OUT); + else + clrbits_le32(&ccm->dram_clk_cfg, CCM_DRAM_CTRL_DCLK_OUT); +#endif }
static const u16 tRFC_table[2][6] = { @@ -421,11 +469,19 @@ unsigned long dramc_init(struct dram_para *para) mctl_setup_dram_clock(para->clock);
/* reset external DRAM */ +#ifndef CONFIG_SUN7I + mctl_ddr3_reset(); +#endif mctl_set_drive();
/* dram clock off */ dramc_clock_output_en(0);
+#ifdef CONFIG_SUN4I + /* select dram controller 1 */ + writel(DRAM_CSEL_MAGIC, &dram->csel); +#endif + mctl_itm_disable(); mctl_enable_dll0(para->tpr3);
@@ -482,6 +538,9 @@ unsigned long dramc_init(struct dram_para *para) mctl_ddr3_reset(); else setbits_le32(&dram->mcr, DRAM_MCR_RESET); +#else + /* dram clock on */ + dramc_clock_output_en(1); #endif
udelay(1); @@ -490,6 +549,22 @@ unsigned long dramc_init(struct dram_para *para)
mctl_enable_dllx(para->tpr3);
+#ifdef CONFIG_SUN4I + /* set odt impendance divide ratio */ + reg_val = ((para->zq) >> 8) & 0xfffff; + reg_val |= ((para->zq) & 0xff) << 20; + reg_val |= (para->zq) & 0xf0000000; + writel(reg_val, &dram->zqcr0); +#endif + +#ifdef CONFIG_SUN4I + /* set I/O configure register */ + reg_val = 0x00cc0000; + reg_val |= (para->odt_en) & 0x3; + reg_val |= ((para->odt_en) & 0x3) << 30; + writel(reg_val, &dram->iocr); +#endif + /* set refresh period */ dramc_set_autorefresh_cycle(para->clock, para->type - 2, density);
diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index cbf8f08..4902d70 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -10,4 +10,5 @@ # obj-y += board.o obj-$(CONFIG_SUNXI_GMAC) += gmac.o +obj-$(CONFIG_CUBIEBOARD) += dram_cubieboard.o obj-$(CONFIG_CUBIETRUCK) += dram_cubietruck.o diff --git a/board/sunxi/dram_cubieboard.c b/board/sunxi/dram_cubieboard.c new file mode 100644 index 0000000..399028c --- /dev/null +++ b/board/sunxi/dram_cubieboard.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 480, + .type = 3, + .rank_num = 1, + .density = 4096, + .io_width = 16, + .bus_width = 32, + .cas = 6, + .zq = 123, + .odt_en = 0, + .size = 1024, + .tpr0 = 0x30926692, + .tpr1 = 0x1090, + .tpr2 = 0x1a0c8, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0, + .emr2 = 0, + .emr3 = 0, +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/boards.cfg b/boards.cfg index 79105f5..177f680 100644 --- a/boards.cfg +++ b/boards.cfg @@ -380,6 +380,7 @@ Active arm armv7 rmobile renesas lager Active arm armv7 s5pc1xx samsung goni s5p_goni - Przemyslaw Marczak p.marczak@samsung.com Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - +Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,SUNXI_GMAC,RGMII - Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,SUNXI_GMAC,RGMII - Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org diff --git a/include/configs/sun4i.h b/include/configs/sun4i.h new file mode 100644 index 0000000..6560b65 --- /dev/null +++ b/include/configs/sun4i.h @@ -0,0 +1,23 @@ +/* + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * + * Configuration settings for the Allwinner A10 (sun4i) CPU + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * A10 specific configuration + */ +#define CONFIG_SUN4I /* sun4i SoC generation */ + +#define CONFIG_SYS_PROMPT "sun4i# " + +/* + * Include common sunxi configuration where most the settings are + */ +#include <configs/sunxi-common.h> + +#endif /* __CONFIG_H */
"known".
Could you enumerate the main differences vs the existing sun7i stuff. e.g.: - dram init and timing (hpcr?) values - CCM_AHB_GATE_DLL - ...
Please mention that you are enabling cb with this patch in the commit message.
- clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3),
This could be written as an ifdef around the "0x3<< 28 |" only (moved to its own line). Is that a better way though?
- /* set odt impendance divide ratio */
"impedance"
Ian.
"known".
Fixed / done.
Done.
I believe that that only will make the code harder to read, so lets keep this as is.
"impedance"
Fixed.
Thanks for the review.
Regards,
Hans
Add support for the Allwinner A13 and A10s SoCs also know as the Allwinner sun5i family.
Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/Makefile | 2 ++ arch/arm/cpu/armv7/sunxi/board.c | 12 ++++++++++++ arch/arm/cpu/armv7/sunxi/cpu_info.c | 8 ++++++++ arch/arm/cpu/armv7/sunxi/dram.c | 21 +++++++++++++++++++++ board/sunxi/Makefile | 2 ++ board/sunxi/dram_a13_oli_micro.c | 32 ++++++++++++++++++++++++++++++++ board/sunxi/dram_r7dongle.c | 31 +++++++++++++++++++++++++++++++ boards.cfg | 2 ++ include/configs/sun5i.h | 23 +++++++++++++++++++++++ include/configs/sunxi-common.h | 2 ++ 10 files changed, 135 insertions(+) create mode 100644 board/sunxi/dram_a13_oli_micro.c create mode 100644 board/sunxi/dram_r7dongle.c create mode 100644 include/configs/sun5i.h
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 856d353..6c70639 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -12,6 +12,7 @@ obj-y += board.o obj-y += clock.o obj-y += pinmux.o obj-$(CONFIG_SUN4I) += clock_sun4i.o +obj-$(CONFIG_SUN5I) += clock_sun4i.o obj-$(CONFIG_SUN7I) += clock_sun4i.o
ifndef CONFIG_SPL_BUILD @@ -20,6 +21,7 @@ endif
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SUN4I) += dram.o +obj-$(CONFIG_SUN5I) += dram.o obj-$(CONFIG_SUN7I) += dram.o ifdef CONFIG_SPL_FEL obj-y += start.o diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index c80b421..0118f5b 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -47,9 +47,21 @@ u32 spl_boot_mode(void)
int gpio_init(void) { +#if CONFIG_CONS_INDEX == 1 && (defined(CONFIG_SUN4I) || defined(CONFIG_SUN7I)) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB22_UART0_TX); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB23_UART0_RX); sunxi_gpio_set_pull(SUNXI_GPB(23), 1); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_SUN5I) + sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN5I_GPB19_UART0_TX); + sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN5I_GPB20_UART0_RX); + sunxi_gpio_set_pull(SUNXI_GPB(20), 1); +#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_SUN5I) + sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG3_UART1_TX); + sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG4_UART1_RX); + sunxi_gpio_set_pull(SUNXI_GPG(4), 1); +#else +#error Unsupported console port number. Please fix pin mux settings in board.c +#endif
return 0; } diff --git a/arch/arm/cpu/armv7/sunxi/cpu_info.c b/arch/arm/cpu/armv7/sunxi/cpu_info.c index b4b5089..5cf35ac 100644 --- a/arch/arm/cpu/armv7/sunxi/cpu_info.c +++ b/arch/arm/cpu/armv7/sunxi/cpu_info.c @@ -15,6 +15,14 @@ int print_cpuinfo(void) { #ifdef CONFIG_SUN4I puts("CPU: Allwinner A10 (SUN4I)\n"); +#elif defined CONFIG_SUN5I + u32 val = readl(SUNXI_SID_BASE + 0x08); + switch ((val >> 12) & 0xf) { + case 0: puts("CPU: Allwinner A12 (SUN5I)\n"); break; + case 3: puts("CPU: Allwinner A13 (SUN5I)\n"); break; + case 7: puts("CPU: Allwinner A10s (SUN5I)\n"); break; + default: puts("CPU: Allwinner A1X (SUN5I)\n"); + } #elif defined CONFIG_SUN7I puts("CPU: Allwinner A20 (SUN7I)\n"); #else diff --git a/arch/arm/cpu/armv7/sunxi/dram.c b/arch/arm/cpu/armv7/sunxi/dram.c index 76753d7..fd485db 100644 --- a/arch/arm/cpu/armv7/sunxi/dram.c +++ b/arch/arm/cpu/armv7/sunxi/dram.c @@ -155,6 +155,16 @@ static void mctl_enable_dllx(u32 phase) }
static u32 hpcr_value[32] = { +#ifdef CONFIG_SUN5I + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0x1031, 0x1031, 0x0735, 0x1035, + 0x1035, 0x0731, 0x1031, 0, + 0x0301, 0x0301, 0x0301, 0x0301, + 0x0301, 0x0301, 0x0301, 0 +#endif #ifdef CONFIG_SUN4I 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0, 0, @@ -257,9 +267,15 @@ static void mctl_setup_dram_clock(u32 clk) #if defined(CONFIG_SUN5I) || defined(CONFIG_SUN7I) /* setup MBUS clock */ reg_val = CCM_MBUS_CTRL_GATE | +#ifdef CONFIG_SUN7I CCM_MBUS_CTRL_CLK_SRC(CCM_MBUS_CTRL_CLK_SRC_PLL6) | CCM_MBUS_CTRL_N(CCM_MBUS_CTRL_N_X(2)) | CCM_MBUS_CTRL_M(CCM_MBUS_CTRL_M_X(2)); +#else /* defined(CONFIG_SUN5I) */ + CCM_MBUS_CTRL_CLK_SRC(CCM_MBUS_CTRL_CLK_SRC_PLL5) | + CCM_MBUS_CTRL_N(CCM_MBUS_CTRL_N_X(1)) | + CCM_MBUS_CTRL_M(CCM_MBUS_CTRL_M_X(2)); +#endif writel(reg_val, &ccm->mbus_clk_cfg); #endif
@@ -468,6 +484,11 @@ unsigned long dramc_init(struct dram_para *para) /* setup DRAM relative clock */ mctl_setup_dram_clock(para->clock);
+#ifdef CONFIG_SUN5I + /* Disable any pad power save control */ + writel(0, &dram->ppwrsctl); +#endif + /* reset external DRAM */ #ifndef CONFIG_SUN7I mctl_ddr3_reset(); diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index 4902d70..7083632 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -10,5 +10,7 @@ # obj-y += board.o obj-$(CONFIG_SUNXI_GMAC) += gmac.o +obj-$(CONFIG_A13_OLINUXINOM) += dram_a13_oli_micro.o obj-$(CONFIG_CUBIEBOARD) += dram_cubieboard.o obj-$(CONFIG_CUBIETRUCK) += dram_cubietruck.o +obj-$(CONFIG_R7DONGLE) += dram_r7dongle.o diff --git a/board/sunxi/dram_a13_oli_micro.c b/board/sunxi/dram_a13_oli_micro.c new file mode 100644 index 0000000..8154ea2 --- /dev/null +++ b/board/sunxi/dram_a13_oli_micro.c @@ -0,0 +1,32 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 408, + .type = 3, + .rank_num = 1, + .density = 2048, + .io_width = 16, + .bus_width = 16, + .cas = 9, + .zq = 123, + .odt_en = 0, + .size = 256, + .tpr0 = 0x42d899b7, + .tpr1 = 0xa090, + .tpr2 = 0x22a00, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0, + .emr2 = 0x10, + .emr3 = 0, + +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/board/sunxi/dram_r7dongle.c b/board/sunxi/dram_r7dongle.c new file mode 100644 index 0000000..59343cb --- /dev/null +++ b/board/sunxi/dram_r7dongle.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 384, + .type = 3, + .rank_num = 1, + .density = 2048, + .io_width = 8, + .bus_width = 32, + .cas = 9, + .zq = 123, + .odt_en = 0, + .size = 1024, + .tpr0 = 0x42d899b7, + .tpr1 = 0xa090, + .tpr2 = 0x22a00, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0x04, + .emr2 = 0x10, + .emr3 = 0, +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/boards.cfg b/boards.cfg index 177f680..6029f00 100644 --- a/boards.cfg +++ b/boards.cfg @@ -380,9 +380,11 @@ Active arm armv7 rmobile renesas lager Active arm armv7 s5pc1xx samsung goni s5p_goni - Przemyslaw Marczak p.marczak@samsung.com Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - +Active arm armv7 sunxi - sunxi A13-OLinuXinoM sun5i:A13_OLINUXINOM,SPL,CONS_INDEX=2 Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,SUNXI_GMAC,RGMII - Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,SUNXI_GMAC,RGMII - +Active arm armv7 sunxi - sunxi r7-tv-dongle sun5i:R7DONGLE,SPL Hans de Goede hdegoede@redhat.com Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org Active arm armv7 u8500 st-ericsson u8500 u8500_href - - Active arm armv7 vf610 freescale vf610twr vf610twr vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg Alison Wang b18965@freescale.com diff --git a/include/configs/sun5i.h b/include/configs/sun5i.h new file mode 100644 index 0000000..43f0d67 --- /dev/null +++ b/include/configs/sun5i.h @@ -0,0 +1,23 @@ +/* + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * + * Configuration settings for the Allwinner A13 (sun5i) CPU + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_SUN5I /* sun5i SoC generation */ + +#define CONFIG_SYS_PROMPT "sun5i# " + +/* + * Include common sunxi configuration where most the settings are + */ +#include <configs/sunxi-common.h> + +#endif /* __CONFIG_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index fd02d0d..1d1c87d 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -161,7 +161,9 @@ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
+#ifndef CONFIG_CONS_INDEX #define CONFIG_CONS_INDEX 1 /* UART0 */ +#endif
#ifdef CONFIG_SUNXI_GMAC #define CONFIG_DESIGNWARE_ETH /* GMAC can use designware driver */
The sun5i is much more similar to sun7i than 4i was, but are there any differences worth mentioning?
Please mention these new boards in the commit log.
Code all looks good to me.
Ian.
Add support for the i2c controller found on all Allwinner sunxi SoCs, this is the same controller as found on the Marvell orion5x and kirkwood SoC families, with a slightly different register layout, so this patch uses the existing mvtwsi code.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 6 ++++++ arch/arm/include/asm/arch-sunxi/i2c.h | 15 +++++++++++++++ board/sunxi/board.c | 7 +++++++ drivers/i2c/Makefile | 1 + drivers/i2c/mvtwsi.c | 18 ++++++++++++++++++ include/configs/sunxi-common.h | 9 +++++++++ 6 files changed, 56 insertions(+) create mode 100644 arch/arm/include/asm/arch-sunxi/i2c.h
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 0118f5b..7d86409 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -11,6 +11,7 @@ */
#include <common.h> +#include <i2c.h> #include <netdev.h> #include <miiphy.h> #include <serial.h> @@ -91,11 +92,16 @@ void s_init(void) clock_init(); timer_init(); gpio_init(); + i2c_init_board();
#ifdef CONFIG_SPL_BUILD gd = &gdata; preloader_console_init();
+#ifdef CONFIG_SPL_I2C_SUPPORT + /* Needed early by sunxi_board_init if PMU is enabled */ + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif sunxi_board_init(); #endif } diff --git a/arch/arm/include/asm/arch-sunxi/i2c.h b/arch/arm/include/asm/arch-sunxi/i2c.h new file mode 100644 index 0000000..dc5406b --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/i2c.h @@ -0,0 +1,15 @@ +/* + * Copyright 2014 - Hans de Goede hdegoede@redhat.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _SUNXI_I2C_H_ +#define _SUNXI_I2C_H_ + +#include <asm/arch/cpu.h> + +#define CONFIG_I2C_MVTWSI_BASE SUNXI_TWI0_BASE +/* This is abp0-clk on sun4i/5i/7i / abp1-clk on sun6i/sun8i which is 24MHz */ +#define CONFIG_SYS_TCLK 24000000 + +#endif diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b05d0b9..543b809 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -106,6 +106,13 @@ int board_mmc_init(bd_t *bis) } #endif
+void i2c_init_board(void) +{ + sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUNXI_GPB0_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUNXI_GPB0_TWI0); + clock_twi_onoff(0, 1); +} + #ifdef CONFIG_SPL_BUILD void sunxi_board_init(void) { diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index e33586d..494c5c7 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -27,5 +27,6 @@ obj-$(CONFIG_SYS_I2C_RCAR) += rcar_i2c.o obj-$(CONFIG_SYS_I2C_S3C24X0) += s3c24x0_i2c.o obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o +obj-$(CONFIG_SYS_I2C_SUNXI) += mvtwsi.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o obj-$(CONFIG_SYS_I2C_ZYNQ) += zynq_i2c.o diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 5ba0e03..e670515 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -22,6 +22,8 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined(CONFIG_SUNXI) +#include <asm/arch/i2c.h> #else #error Driver mvtwsi not supported by SoC or board #endif @@ -30,6 +32,20 @@ * TWSI register structure */
+#ifdef CONFIG_SUNXI + +struct mvtwsi_registers { + u32 slave_address; + u32 xtnd_slave_addr; + u32 data; + u32 control; + u32 status; + u32 baudrate; + u32 soft_reset; +}; + +#else + struct mvtwsi_registers { u32 slave_address; u32 data; @@ -43,6 +59,8 @@ struct mvtwsi_registers { u32 soft_reset; };
+#endif + /* * Control register fields */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 1d1c87d..2db083c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -161,6 +161,15 @@ #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
+/* I2C */ +#define CONFIG_SPL_I2C_SUPPORT +/* No CONFIG_SYS_I2C as we use the non converted mvtwsi driver */ +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SUNXI +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_CMD_I2C + #ifndef CONFIG_CONS_INDEX #define CONFIG_CONS_INDEX 1 /* UART0 */ #endif
Add support for the x-powers axp209 pmic which is found on most A10, A13 and A20 boards.
While changing the boards.cfg lines for the Cubietruck, add myself as board maintainer for the Cubietruck.
Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/board.c | 26 ++++++ boards.cfg | 6 +- drivers/power/Makefile | 1 + drivers/power/axp209.c | 198 +++++++++++++++++++++++++++++++++++++++++ include/axp209.h | 15 ++++ include/configs/sunxi-common.h | 5 ++ 6 files changed, 248 insertions(+), 3 deletions(-) create mode 100644 drivers/power/axp209.c create mode 100644 include/axp209.h
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 543b809..309bbd2 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -12,6 +12,9 @@ */
#include <common.h> +#ifdef CONFIG_AXP209_POWER +#include <axp209.h> +#endif #include <asm/arch/clock.h> #include <asm/arch/dram.h> #include <asm/arch/gpio.h> @@ -116,12 +119,35 @@ void i2c_init_board(void) #ifdef CONFIG_SPL_BUILD void sunxi_board_init(void) { + int power_failed = 0; unsigned long ramsize;
+#ifdef CONFIG_AXP209_POWER + power_failed |= axp209_init(); + power_failed |= axp209_set_dcdc2(1400); + power_failed |= axp209_set_dcdc3(1250); + power_failed |= axp209_set_ldo2(3000); + power_failed |= axp209_set_ldo3(2800); + power_failed |= axp209_set_ldo4(2800); +#endif + printf("DRAM:"); ramsize = sunxi_dram_init(); printf(" %lu MiB\n", ramsize >> 20); if (!ramsize) hang(); + + /* + * Only clock up the CPU to full speed if we are reasonably + * assured it's being powered with suitable core voltage + */ + if (!power_failed) +#ifdef CONFIG_SUN7I + clock_set_pll1(912000000); +#else + clock_set_pll1(1008000000); +#endif + else + printf("Failed to set core voltage! Can't set CPU frequency\n"); } #endif diff --git a/boards.cfg b/boards.cfg index 6029f00..72585a9 100644 --- a/boards.cfg +++ b/boards.cfg @@ -381,9 +381,9 @@ Active arm armv7 s5pc1xx samsung goni Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - Active arm armv7 sunxi - sunxi A13-OLinuXinoM sun5i:A13_OLINUXINOM,SPL,CONS_INDEX=2 Hans de Goede hdegoede@redhat.com -Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL Hans de Goede hdegoede@redhat.com -Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,SUNXI_GMAC,RGMII - -Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,SUNXI_GMAC,RGMII - +Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL,AXP209_POWER Hans de Goede hdegoede@redhat.com +Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com +Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi r7-tv-dongle sun5i:R7DONGLE,SPL Hans de Goede hdegoede@redhat.com Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org Active arm armv7 u8500 st-ericsson u8500 u8500_href - - diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 53ff97d..063ac8f 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -5,6 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_AXP209_POWER) += axp209.o obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o obj-$(CONFIG_FTPMU010_POWER) += ftpmu010.o obj-$(CONFIG_TPS6586X_POWER) += tps6586x.o diff --git a/drivers/power/axp209.c b/drivers/power/axp209.c new file mode 100644 index 0000000..a3f9d52 --- /dev/null +++ b/drivers/power/axp209.c @@ -0,0 +1,198 @@ +/* + * (C) Copyright 2012 + * Henrik Nordstrom henrik@henriknordstrom.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <axp209.h> + +enum axp209_reg { + AXP209_POWER_STATUS = 0x00, + AXP209_CHIP_VERSION = 0x03, + AXP209_DCDC2_VOLTAGE = 0x23, + AXP209_DCDC3_VOLTAGE = 0x27, + AXP209_LDO24_VOLTAGE = 0x28, + AXP209_LDO3_VOLTAGE = 0x29, + AXP209_IRQ_STATUS3 = 0x4a, + AXP209_IRQ_STATUS5 = 0x4c, + AXP209_SHUTDOWN = 0x32, +}; + +#define AXP209_POWER_STATUS_ON_BY_DC (1<<0) + +#define AXP209_IRQ3_PEK_SHORT (1<<1) +#define AXP209_IRQ3_PEK_LONG (1<<0) + +#define AXP209_IRQ5_PEK_UP (1<<6) +#define AXP209_IRQ5_PEK_DOWN (1<<5) + +int axp209_write(enum axp209_reg reg, u8 val) +{ + return i2c_write(0x34, reg, 1, &val, 1); +} + +int axp209_read(enum axp209_reg reg, u8 *val) +{ + return i2c_read(0x34, reg, 1, val, 1); +} + +int axp209_set_dcdc2(int mvolt) +{ + int cfg = (mvolt - 700) / 25; + int rc; + u8 current; + + if (cfg < 0) + cfg = 0; + if (cfg > (1 << 6) - 1) + cfg = (1 << 6) - 1; + + /* Do we really need to be this gentle? It has built-in voltage slope */ + while ((rc = axp209_read(AXP209_DCDC2_VOLTAGE, ¤t)) == 0 && + current != cfg) { + if (current < cfg) + current++; + else + current--; + + rc = axp209_write(AXP209_DCDC2_VOLTAGE, current); + if (rc) + break; + } + + return rc; +} + +int axp209_set_dcdc3(int mvolt) +{ + int cfg = (mvolt - 700) / 25; + u8 reg; + int rc; + + if (cfg < 0) + cfg = 0; + if (cfg > (1 << 7) - 1) + cfg = (1 << 7) - 1; + + rc = axp209_write(AXP209_DCDC3_VOLTAGE, cfg); + rc |= axp209_read(AXP209_DCDC3_VOLTAGE, ®); + + return rc; +} + +int axp209_set_ldo2(int mvolt) +{ + int cfg = (mvolt - 1800) / 100; + int rc; + u8 reg; + + if (cfg < 0) + cfg = 0; + if (cfg > 15) + cfg = 15; + + rc = axp209_read(AXP209_LDO24_VOLTAGE, ®); + if (rc) + return rc; + + reg = (reg & 0x0f) | (cfg << 4); + rc = axp209_write(AXP209_LDO24_VOLTAGE, reg); + if (rc) + return rc; + + return 0; +} + +int axp209_set_ldo3(int mvolt) +{ + int cfg = (mvolt - 700) / 25; + + if (cfg < 0) + cfg = 0; + if (cfg > 127) + cfg = 127; + if (mvolt == -1) + cfg = 0x80; /* detemined by LDO3IN pin */ + + return axp209_write(AXP209_LDO3_VOLTAGE, cfg); +} + +int axp209_set_ldo4(int mvolt) +{ + int cfg, rc; + static const int vindex[] = { + 1250, 1300, 1400, 1500, 1600, 1700, 1800, 1900, 2000, 2500, + 2700, 2800, 3000, 3100, 3200, 3300 + }; + u8 reg; + + /* Translate mvolt to register cfg value, requested <= selected */ + for (cfg = 15; vindex[cfg] > mvolt && cfg > 0; cfg--); + + rc = axp209_read(AXP209_LDO24_VOLTAGE, ®); + if (rc) + return rc; + + /* LDO4 configuration is in lower 4 bits */ + reg = (reg & 0xf0) | (cfg << 0); + rc = axp209_write(AXP209_LDO24_VOLTAGE, reg); + if (rc) + return rc; + + return 0; +} + +void axp209_poweroff(void) +{ + u8 val; + + if (axp209_read(AXP209_SHUTDOWN, &val) != 0) + return; + + val |= 1 << 7; + + if (axp209_write(AXP209_SHUTDOWN, val) != 0) + return; + + udelay(10000); /* wait for power to drain */ +} + +int axp209_init(void) +{ + u8 ver; + int rc; + + rc = axp209_read(AXP209_CHIP_VERSION, &ver); + if (rc) + return rc; + + /* Low 4 bits is chip version */ + ver &= 0x0f; + + if (ver != 0x1) + return -1; + + return 0; +} + +int axp209_poweron_by_dc(void) +{ + u8 v; + + if (axp209_read(AXP209_POWER_STATUS, &v)) + return 0; + return (v & AXP209_POWER_STATUS_ON_BY_DC); +} + +int axp209_power_button(void) +{ + u8 v; + + if (axp209_read(AXP209_IRQ_STATUS5, &v)) + return 0; + axp209_write(AXP209_IRQ_STATUS5, AXP209_IRQ5_PEK_DOWN); + return v & AXP209_IRQ5_PEK_DOWN; +} diff --git a/include/axp209.h b/include/axp209.h new file mode 100644 index 0000000..9edfa3f --- /dev/null +++ b/include/axp209.h @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2012 Henrik Nordstrom henrik@henriknordstrom.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +extern int axp209_set_dcdc2(int mvolt); +extern int axp209_set_dcdc3(int mvolt); +extern int axp209_set_ldo2(int mvolt); +extern int axp209_set_ldo3(int mvolt); +extern int axp209_set_ldo4(int mvolt); +extern void axp209_poweroff(void); +extern int axp209_init(void); +extern int axp209_poweron_by_dc(void); +extern int axp209_power_button(void); diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 2db083c..b76227e 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -170,6 +170,11 @@ #define CONFIG_SYS_I2C_SLAVE 0x7f #define CONFIG_CMD_I2C
+/* PMU */ +#if defined CONFIG_AXP152_POWER || defined CONFIG_AXP209_POWER || defined CONFIG_AXP221_POWER +#define CONFIG_SPL_POWER_SUPPORT +#endif + #ifndef CONFIG_CONS_INDEX #define CONFIG_CONS_INDEX 1 /* UART0 */ #endif
I don't know much about these PMIC things, so just some general comments/questions.
- int power_failed = 0;
bool?
- power_failed |= axp209_init();
- power_failed |= axp209_set_dcdc2(1400);
- power_failed |= axp209_set_dcdc3(1250);
- power_failed |= axp209_set_ldo2(3000);
- power_failed |= axp209_set_ldo3(2800);
- power_failed |= axp209_set_ldo4(2800);
I take it that it is safe to keep poking at things after one of them fails?
- printf("DRAM:"); ramsize = sunxi_dram_init(); printf(" %lu MiB\n", ramsize >> 20); if (!ramsize) hang();
- if (!power_failed)
+#else
#define CLK_FULL_SPEED in the relevant sun?i-config.h-es?
- else
} #endif diff --git a/drivers/power/axp209.c b/drivers/power/axp209.c new file mode 100644 index 0000000..a3f9d52 --- /dev/null +++ b/drivers/power/axp209.c @@ -0,0 +1,198 @@ +/*
- (C) Copyright 2012
- Henrik Nordstrom henrik@henriknordstrom.net
+enum axp209_reg {
- AXP209_POWER_STATUS = 0x00,
- AXP209_CHIP_VERSION = 0x03,
- AXP209_DCDC2_VOLTAGE = 0x23,
- AXP209_DCDC3_VOLTAGE = 0x27,
- AXP209_LDO24_VOLTAGE = 0x28,
- AXP209_LDO3_VOLTAGE = 0x29,
- AXP209_IRQ_STATUS3 = 0x4a,
- AXP209_IRQ_STATUS5 = 0x4c,
- AXP209_SHUTDOWN = 0x32,
Only IRQ5 is used?
- return i2c_write(0x34, reg, 1, &val, 1);
- return i2c_read(0x34, reg, 1, val, 1);
- int cfg = (mvolt - 700) / 25;
- int rc;
- u8 current;
- if (cfg < 0)
cfg = 0;
Can we make mvolt and cfg unsigned? (I suppose you'd then need a range check on mvolt before the subtraction, so perhaps it doesn't save much?)
- if (cfg > (1 << 6) - 1)
cfg = (1 << 6) - 1;
#define AXP209_DCDC2_MAX?
- u8 reg;
- int rc;
- if (cfg < 0)
cfg = 0;
- if (cfg > (1 << 7) - 1)
cfg = (1 << 7) - 1;
Some two comments as for DCDC2 (which I won't bother making for subsequent clocks).
perhaps cfg = clamp(cfg, 0, 1<<7-1)? Or even cfg = mvolt_to_cfg(mvolt, 700, 25, 0, 1<<7-1)?
- rc = axp209_write(AXP209_DCDC3_VOLTAGE, cfg);
- rc |= axp209_read(AXP209_DCDC3_VOLTAGE, ®);
Is read safe if the write failed? Since the reg is never used I assume it's just some sort of sync? Or do you need to confirm the contents "took"? If not you could remove reg and readback into cfg.
- rc = axp209_read(AXP209_LDO24_VOLTAGE, ®);
- if (rc)
return rc;
- reg = (reg & 0x0f) | (cfg << 4);
Do we know what these magic numbers mean?
(ah, you have a comment on the use of the lower 4 bits, but not the upper 4 used here...)
- rc = axp209_write(AXP209_LDO24_VOLTAGE, reg);
- if (rc)
return rc;
- if (cfg < 0)
cfg = 0;
- if (cfg > 127)
cfg = 127;
- if (mvolt == -1)
"determined"
- return axp209_write(AXP209_LDO3_VOLTAGE, cfg);
- int cfg, rc;
- static const int vindex[] = {
- u8 reg;
- /* Translate mvolt to register cfg value, requested <= selected */
- for (cfg = 15; vindex[cfg] > mvolt && cfg > 0; cfg--);
- if (rc)
return rc;
- /* LDO4 configuration is in lower 4 bits */
- reg = (reg & 0xf0) | (cfg << 0);
- if (rc)
return rc;
- u8 val;
- if (axp209_read(AXP209_SHUTDOWN, &val) != 0)
return;
- val |= 1 << 7;
#define?
- if (axp209_write(AXP209_SHUTDOWN, val) != 0)
return;
- udelay(10000); /* wait for power to drain */
Ian.
bool?
I would prefer to keep this as an int, doing |= on a bool just feels wrong.
Yes.
+#else
Good idea, done.
- else
} #endifprintf("Failed to set core voltage! Can't set CPU frequency\n");
+enum axp209_reg {
Only IRQ5 is used?
True, I've dropped the IRQ3 defines.
- int rc;
- u8 current;
- if (cfg < 0)
cfg = 0;
I don't think making them unsigned is helpful.
cfg = (1 << 6) - 1;
- u8 reg;
- int rc;
- if (cfg < 0)
cfg = 0;
cfg = (1 << 7) - 1;
I've added an mvolt_to_cfg function and used that everywhere.
The read is useless, good catch, I've dropped it.
- if (rc)
return rc;
Added a comment.
- if (rc)
return rc;
- if (cfg < 0)
cfg = 0;
- if (cfg > 127)
cfg = 127;
- if (mvolt == -1)
"determined"
Fixed.
- int cfg, rc;
- u8 reg;
- if (rc)
return rc;
- if (rc)
return rc;
- u8 val;
return;
- val |= 1 << 7;
#define?
Fixed.
Regards,
Hans
Add support for the x-powers axp152 pmic which is found on most A10s boards.
Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Ian Campbell ijc@hellion.org.uk Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/board.c | 10 ++++ boards.cfg | 2 +- drivers/power/Makefile | 1 + drivers/power/axp152.c | 122 +++++++++++++++++++++++++++++++++++++++++++++++++ include/axp152.h | 11 +++++ 5 files changed, 145 insertions(+), 1 deletion(-) create mode 100644 drivers/power/axp152.c create mode 100644 include/axp152.h
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 309bbd2..c6d4b3c 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -12,6 +12,9 @@ */
#include <common.h> +#ifdef CONFIG_AXP152_POWER +#include <axp152.h> +#endif #ifdef CONFIG_AXP209_POWER #include <axp209.h> #endif @@ -122,6 +125,13 @@ void sunxi_board_init(void) int power_failed = 0; unsigned long ramsize;
+#ifdef CONFIG_AXP152_POWER + power_failed = axp152_init(); + power_failed |= axp152_set_dcdc2(1400); + power_failed |= axp152_set_dcdc3(1500); + power_failed |= axp152_set_dcdc4(1250); + power_failed |= axp152_set_ldo2(3000); +#endif #ifdef CONFIG_AXP209_POWER power_failed |= axp209_init(); power_failed |= axp209_set_dcdc2(1400); diff --git a/boards.cfg b/boards.cfg index 72585a9..f4f870a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -384,7 +384,7 @@ Active arm armv7 sunxi - sunxi Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL,AXP209_POWER Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com -Active arm armv7 sunxi - sunxi r7-tv-dongle sun5i:R7DONGLE,SPL Hans de Goede hdegoede@redhat.com +Active arm armv7 sunxi - sunxi r7-tv-dongle sun5i:R7DONGLE,SPL,AXP152_POWER Hans de Goede hdegoede@redhat.com Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org Active arm armv7 u8500 st-ericsson u8500 u8500_href - - Active arm armv7 vf610 freescale vf610twr vf610twr vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg Alison Wang b18965@freescale.com diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 063ac8f..dc64e4d 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -5,6 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_AXP152_POWER) += axp152.o obj-$(CONFIG_AXP209_POWER) += axp209.o obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o obj-$(CONFIG_FTPMU010_POWER) += ftpmu010.o diff --git a/drivers/power/axp152.c b/drivers/power/axp152.c new file mode 100644 index 0000000..a7a7909 --- /dev/null +++ b/drivers/power/axp152.c @@ -0,0 +1,122 @@ +/* + * (C) Copyright 2012 + * Henrik Nordstrom henrik@henriknordstrom.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <i2c.h> +#include <axp152.h> + +enum axp152_reg { + AXP152_CHIP_VERSION = 0x3, + AXP152_DCDC2_VOLTAGE = 0x23, + AXP152_DCDC3_VOLTAGE = 0x27, + AXP152_DCDC4_VOLTAGE = 0x2B, + AXP152_LDO2_VOLTAGE = 0x2A, + AXP152_SHUTDOWN = 0x32, +}; + +int axp152_write(enum axp152_reg reg, u8 val) +{ + return i2c_write(0x30, reg, 1, &val, 1); +} + +int axp152_read(enum axp152_reg reg, u8 *val) +{ + return i2c_read(0x30, reg, 1, val, 1); +} + +int axp152_set_dcdc2(int mvolt) +{ + int target = (mvolt - 700) / 25; + int rc; + u8 current; + + if (target < 0) + target = 0; + if (target > (1<<6)-1) + target = (1<<6)-1; + /* Do we really need to be this gentle? It has built-in voltage slope */ + while ((rc = axp152_read(AXP152_DCDC2_VOLTAGE, ¤t)) == 0 && + current != target) { + if (current < target) + current++; + else + current--; + rc = axp152_write(AXP152_DCDC2_VOLTAGE, current); + if (rc) + break; + } + return rc; +} + +int axp152_set_dcdc3(int mvolt) +{ + int target = (mvolt - 700) / 50; + u8 reg; + int rc; + + if (target < 0) + target = 0; + if (target > (1<<6)-1) + target = (1<<6)-1; + rc = axp152_write(AXP152_DCDC3_VOLTAGE, target); + rc |= axp152_read(AXP152_DCDC3_VOLTAGE, ®); + return rc; +} + +int axp152_set_dcdc4(int mvolt) +{ + int target = (mvolt - 700) / 25; + u8 reg; + int rc; + + if (target < 0) + target = 0; + if (target > (1<<7)-1) + target = (1<<7)-1; + rc = axp152_write(AXP152_DCDC4_VOLTAGE, target); + rc |= axp152_read(AXP152_DCDC4_VOLTAGE, ®); + return rc; +} + +int axp152_set_ldo2(int mvolt) +{ + int target = (mvolt - 700) / 100; + int rc; + u8 reg; + + if (target < 0) + target = 0; + if (target > 31) + target = 31; + rc = axp152_write(AXP152_LDO2_VOLTAGE, target); + rc |= axp152_read(AXP152_LDO2_VOLTAGE, ®); + return rc; +} + +void axp152_poweroff(void) +{ + u8 val; + + if (axp152_read(AXP152_SHUTDOWN, &val) != 0) + return; + val |= 1 << 7; + if (axp152_write(AXP152_SHUTDOWN, val) != 0) + return; + udelay(10000); /* wait for power to drain */ +} + +int axp152_init(void) +{ + u8 ver; + int rc; + + rc = axp152_read(AXP152_CHIP_VERSION, &ver); + if (rc) + return rc; + if (ver != 0x05) + return -1; + return 0; +} diff --git a/include/axp152.h b/include/axp152.h new file mode 100644 index 0000000..b34c194 --- /dev/null +++ b/include/axp152.h @@ -0,0 +1,11 @@ +/* + * (C) Copyright 2012 Henrik Nordstrom henrik@henriknordstrom.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ +int axp152_set_dcdc2(int mvolt); +int axp152_set_dcdc3(int mvolt); +int axp152_set_dcdc4(int mvolt); +int axp152_set_ldo2(int mvolt); +void axp152_poweroff(void); +int axp152_init(void);
This driver looks superficially very similar to the last one, have you considered merging them?
Other than that most of the generic questions I had on the last one seem to appear here too, magic numbers and so on.
Ian
The AXP152 and AXP209 look similar, but they have different register addresses, different ranges for the LDO-s, different number of DCDC convertors, etc. Doing both in one driver would very quickly become a very ugly #ifdef fest.
I've applied similar fixes as to the AXP209 driver.
Regards,
Hans
There have been 3 versions of the sunxi_emac support patch during its development. Somehow version 2 ended up in upstream u-boot where as the u-boot-sunxi git repo got version 3.
This bumps the version in upstream u-boot to version 3 of the patch: - Initialize MII clock earlier so mii access to allow independent use - Name change from WEMAC to EMAC to match mainline kernel & chip manual - Cosmetic code cleanup
Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/net/Makefile | 2 +- drivers/net/sunxi_emac.c | 521 +++++++++++++++++++++++++++++++++++++++++++++ drivers/net/sunxi_wemac.c | 525 ---------------------------------------------- include/netdev.h | 2 +- 4 files changed, 523 insertions(+), 527 deletions(-) create mode 100644 drivers/net/sunxi_emac.c delete mode 100644 drivers/net/sunxi_wemac.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 6005f7e..da2b5f8 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_E1000) += e1000.o obj-$(CONFIG_E1000_SPI) += e1000_spi.o obj-$(CONFIG_EEPRO100) += eepro100.o +obj-$(CONFIG_SUNXI_EMAC) += sunxi_emac.o obj-$(CONFIG_ENC28J60) += enc28j60.o obj-$(CONFIG_EP93XX) += ep93xx_eth.o obj-$(CONFIG_ETHOC) += ethoc.o @@ -51,7 +52,6 @@ obj-$(CONFIG_RTL8169) += rtl8169.o obj-$(CONFIG_SH_ETHER) += sh_eth.o obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o -obj-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o diff --git a/drivers/net/sunxi_emac.c b/drivers/net/sunxi_emac.c new file mode 100644 index 0000000..5a06d68 --- /dev/null +++ b/drivers/net/sunxi_emac.c @@ -0,0 +1,521 @@ +/* + * sunxi_emac.c -- Allwinner A10 ethernet driver + * + * (C) Copyright 2012, Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/err.h> +#include <malloc.h> +#include <miiphy.h> +#include <net.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> + +/* EMAC register */ +struct emac_regs { + u32 ctl; /* 0x00 */ + u32 tx_mode; /* 0x04 */ + u32 tx_flow; /* 0x08 */ + u32 tx_ctl0; /* 0x0c */ + u32 tx_ctl1; /* 0x10 */ + u32 tx_ins; /* 0x14 */ + u32 tx_pl0; /* 0x18 */ + u32 tx_pl1; /* 0x1c */ + u32 tx_sta; /* 0x20 */ + u32 tx_io_data; /* 0x24 */ + u32 tx_io_data1;/* 0x28 */ + u32 tx_tsvl0; /* 0x2c */ + u32 tx_tsvh0; /* 0x30 */ + u32 tx_tsvl1; /* 0x34 */ + u32 tx_tsvh1; /* 0x38 */ + u32 rx_ctl; /* 0x3c */ + u32 rx_hash0; /* 0x40 */ + u32 rx_hash1; /* 0x44 */ + u32 rx_sta; /* 0x48 */ + u32 rx_io_data; /* 0x4c */ + u32 rx_fbc; /* 0x50 */ + u32 int_ctl; /* 0x54 */ + u32 int_sta; /* 0x58 */ + u32 mac_ctl0; /* 0x5c */ + u32 mac_ctl1; /* 0x60 */ + u32 mac_ipgt; /* 0x64 */ + u32 mac_ipgr; /* 0x68 */ + u32 mac_clrt; /* 0x6c */ + u32 mac_maxf; /* 0x70 */ + u32 mac_supp; /* 0x74 */ + u32 mac_test; /* 0x78 */ + u32 mac_mcfg; /* 0x7c */ + u32 mac_mcmd; /* 0x80 */ + u32 mac_madr; /* 0x84 */ + u32 mac_mwtd; /* 0x88 */ + u32 mac_mrdd; /* 0x8c */ + u32 mac_mind; /* 0x90 */ + u32 mac_ssrr; /* 0x94 */ + u32 mac_a0; /* 0x98 */ + u32 mac_a1; /* 0x9c */ +}; + +/* SRAMC register */ +struct sunxi_sramc_regs { + u32 ctrl0; + u32 ctrl1; +}; + +/* 0: Disable 1: Aborted frame enable(default) */ +#define EMAC_TX_AB_M (0x1 << 0) +/* 0: CPU 1: DMA(default) */ +#define EMAC_TX_TM (0x1 << 1) + +#define EMAC_TX_SETUP (0) + +/* 0: DRQ asserted 1: DRQ automatically(default) */ +#define EMAC_RX_DRQ_MODE (0x1 << 1) +/* 0: CPU 1: DMA(default) */ +#define EMAC_RX_TM (0x1 << 2) +/* 0: Normal(default) 1: Pass all Frames */ +#define EMAC_RX_PA (0x1 << 4) +/* 0: Normal(default) 1: Pass Control Frames */ +#define EMAC_RX_PCF (0x1 << 5) +/* 0: Normal(default) 1: Pass Frames with CRC Error */ +#define EMAC_RX_PCRCE (0x1 << 6) +/* 0: Normal(default) 1: Pass Frames with Length Error */ +#define EMAC_RX_PLE (0x1 << 7) +/* 0: Normal 1: Pass Frames length out of range(default) */ +#define EMAC_RX_POR (0x1 << 8) +/* 0: Not accept 1: Accept unicast Packets(default) */ +#define EMAC_RX_UCAD (0x1 << 16) +/* 0: Normal(default) 1: DA Filtering */ +#define EMAC_RX_DAF (0x1 << 17) +/* 0: Not accept 1: Accept multicast Packets(default) */ +#define EMAC_RX_MCO (0x1 << 20) +/* 0: Disable(default) 1: Enable Hash filter */ +#define EMAC_RX_MHF (0x1 << 21) +/* 0: Not accept 1: Accept Broadcast Packets(default) */ +#define EMAC_RX_BCO (0x1 << 22) +/* 0: Disable(default) 1: Enable SA Filtering */ +#define EMAC_RX_SAF (0x1 << 24) +/* 0: Normal(default) 1: Inverse Filtering */ +#define EMAC_RX_SAIF (0x1 << 25) + +#define EMAC_RX_SETUP (EMAC_RX_POR | EMAC_RX_UCAD | EMAC_RX_DAF | \ + EMAC_RX_MCO | EMAC_RX_BCO) + +/* 0: Disable 1: Enable Receive Flow Control(default) */ +#define EMAC_MAC_CTL0_RFC (0x1 << 2) +/* 0: Disable 1: Enable Transmit Flow Control(default) */ +#define EMAC_MAC_CTL0_TFC (0x1 << 3) + +#define EMAC_MAC_CTL0_SETUP (EMAC_MAC_CTL0_RFC | EMAC_MAC_CTL0_TFC) + +/* 0: Disable 1: Enable MAC Frame Length Checking(default) */ +#define EMAC_MAC_CTL1_FLC (0x1 << 1) +/* 0: Disable(default) 1: Enable Huge Frame */ +#define EMAC_MAC_CTL1_HF (0x1 << 2) +/* 0: Disable(default) 1: Enable MAC Delayed CRC */ +#define EMAC_MAC_CTL1_DCRC (0x1 << 3) +/* 0: Disable 1: Enable MAC CRC(default) */ +#define EMAC_MAC_CTL1_CRC (0x1 << 4) +/* 0: Disable 1: Enable MAC PAD Short frames(default) */ +#define EMAC_MAC_CTL1_PC (0x1 << 5) +/* 0: Disable(default) 1: Enable MAC PAD Short frames and append CRC */ +#define EMAC_MAC_CTL1_VC (0x1 << 6) +/* 0: Disable(default) 1: Enable MAC auto detect Short frames */ +#define EMAC_MAC_CTL1_ADP (0x1 << 7) +/* 0: Disable(default) 1: Enable */ +#define EMAC_MAC_CTL1_PRE (0x1 << 8) +/* 0: Disable(default) 1: Enable */ +#define EMAC_MAC_CTL1_LPE (0x1 << 9) +/* 0: Disable(default) 1: Enable no back off */ +#define EMAC_MAC_CTL1_NB (0x1 << 12) +/* 0: Disable(default) 1: Enable */ +#define EMAC_MAC_CTL1_BNB (0x1 << 13) +/* 0: Disable(default) 1: Enable */ +#define EMAC_MAC_CTL1_ED (0x1 << 14) + +#define EMAC_MAC_CTL1_SETUP (EMAC_MAC_CTL1_FLC | EMAC_MAC_CTL1_CRC | \ + EMAC_MAC_CTL1_PC) + +#define EMAC_MAC_IPGT 0x15 + +#define EMAC_MAC_NBTB_IPG1 0xc +#define EMAC_MAC_NBTB_IPG2 0x12 + +#define EMAC_MAC_CW 0x37 +#define EMAC_MAC_RM 0xf + +#define EMAC_MAC_MFL 0x0600 + +/* Receive status */ +#define EMAC_CRCERR (0x1 << 4) +#define EMAC_LENERR (0x3 << 5) + +#define DMA_CPU_TRRESHOLD 2000 + +struct emac_eth_dev { + u32 speed; + u32 duplex; + u32 phy_configured; + int link_printed; +}; + +struct emac_rxhdr { + s16 rx_len; + u16 rx_status; +}; + +static void emac_inblk_32bit(void *reg, void *data, int count) +{ + int cnt = (count + 3) >> 2; + + if (cnt) { + u32 *buf = data; + + do { + u32 x = readl(reg); + *buf++ = x; + } while (--cnt); + } +} + +static void emac_outblk_32bit(void *reg, void *data, int count) +{ + int cnt = (count + 3) >> 2; + + if (cnt) { + const u32 *buf = data; + + do { + writel(*buf++, reg); + } while (--cnt); + } +} + +/* Read a word from phyxcer */ +static int emac_phy_read(const char *devname, unsigned char addr, + unsigned char reg, unsigned short *value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + + /* issue the phy address and reg */ + writel(addr << 8 | reg, ®s->mac_madr); + + /* pull up the phy io line */ + writel(0x1, ®s->mac_mcmd); + + /* Wait read complete */ + mdelay(1); + + /* push down the phy io line */ + writel(0x0, ®s->mac_mcmd); + + /* and write data */ + *value = readl(®s->mac_mrdd); + + return 0; +} + +/* Write a word to phyxcer */ +static int emac_phy_write(const char *devname, unsigned char addr, + unsigned char reg, unsigned short value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + + /* issue the phy address and reg */ + writel(addr << 8 | reg, ®s->mac_madr); + + /* pull up the phy io line */ + writel(0x1, ®s->mac_mcmd); + + /* Wait write complete */ + mdelay(1); + + /* push down the phy io line */ + writel(0x0, ®s->mac_mcmd); + + /* and write data */ + writel(value, ®s->mac_mwtd); + + return 0; +} + +static void emac_setup(struct eth_device *dev) +{ + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + u32 reg_val; + u16 phy_val; + u32 duplex_flag; + + /* Set up TX */ + writel(EMAC_TX_SETUP, ®s->tx_mode); + + /* Set up RX */ + writel(EMAC_RX_SETUP, ®s->rx_ctl); + + /* Set MAC */ + /* Set MAC CTL0 */ + writel(EMAC_MAC_CTL0_SETUP, ®s->mac_ctl0); + + /* Set MAC CTL1 */ + emac_phy_read(dev->name, 1, 0, &phy_val); + debug("PHY SETUP, reg 0 value: %x\n", phy_val); + duplex_flag = !!(phy_val & (1 << 8)); + + reg_val = 0; + if (duplex_flag) + reg_val = (0x1 << 0); + writel(EMAC_MAC_CTL1_SETUP | reg_val, ®s->mac_ctl1); + + /* Set up IPGT */ + writel(EMAC_MAC_IPGT, ®s->mac_ipgt); + + /* Set up IPGR */ + writel(EMAC_MAC_NBTB_IPG2 | (EMAC_MAC_NBTB_IPG1 << 8), ®s->mac_ipgr); + + /* Set up Collison window */ + writel(EMAC_MAC_RM | (EMAC_MAC_CW << 8), ®s->mac_clrt); + + /* Set up Max Frame Length */ + writel(EMAC_MAC_MFL, ®s->mac_maxf); +} + +static void emac_reset(struct eth_device *dev) +{ + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + + debug("resetting device\n"); + + /* RESET device */ + writel(0, ®s->ctl); + udelay(200); + + writel(1, ®s->ctl); + udelay(200); +} + +static int sunxi_emac_eth_init(struct eth_device *dev, bd_t *bd) +{ + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + struct emac_eth_dev *priv = dev->priv; + u16 phy_reg; + + /* Init EMAC */ + + /* Flush RX FIFO */ + setbits_le32(®s->rx_ctl, 0x8); + udelay(1); + + /* Init MAC */ + + /* Soft reset MAC */ + clrbits_le32(®s->mac_ctl0, 0x1 << 15); + + /* Clear RX counter */ + writel(0x0, ®s->rx_fbc); + udelay(1); + + /* Set up EMAC */ + emac_setup(dev); + + writel(dev->enetaddr[0] << 16 | dev->enetaddr[1] << 8 | + dev->enetaddr[2], ®s->mac_a1); + writel(dev->enetaddr[3] << 16 | dev->enetaddr[4] << 8 | + dev->enetaddr[5], ®s->mac_a0); + + mdelay(1); + + emac_reset(dev); + + /* PHY POWER UP */ + emac_phy_read(dev->name, 1, 0, &phy_reg); + emac_phy_write(dev->name, 1, 0, phy_reg & (~(0x1 << 11))); + mdelay(1); + + emac_phy_read(dev->name, 1, 0, &phy_reg); + + priv->speed = miiphy_speed(dev->name, 0); + priv->duplex = miiphy_duplex(dev->name, 0); + + /* Print link status only once */ + if (!priv->link_printed) { + printf("ENET Speed is %d Mbps - %s duplex connection\n", + priv->speed, (priv->duplex == HALF) ? "HALF" : "FULL"); + priv->link_printed = 1; + } + + /* Set EMAC SPEED depend on PHY */ + clrsetbits_le32(®s->mac_supp, 1 << 8, + ((phy_reg & (0x1 << 13)) >> 13) << 8); + + /* Set duplex depend on phy */ + clrsetbits_le32(®s->mac_ctl1, 1 << 0, + ((phy_reg & (0x1 << 8)) >> 8) << 0); + + /* Enable RX/TX */ + setbits_le32(®s->ctl, 0x7); + + return 0; +} + +static void sunxi_emac_eth_halt(struct eth_device *dev) +{ + /* Nothing to do here */ +} + +static int sunxi_emac_eth_recv(struct eth_device *dev) +{ + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + struct emac_rxhdr rxhdr; + u32 rxcount; + u32 reg_val; + int rx_len; + int rx_status; + int good_packet; + + /* Check packet ready or not */ + + /* Race warning: The first packet might arrive with + * the interrupts disabled, but the second will fix + */ + rxcount = readl(®s->rx_fbc); + if (!rxcount) { + /* Had one stuck? */ + rxcount = readl(®s->rx_fbc); + if (!rxcount) + return 0; + } + + reg_val = readl(®s->rx_io_data); + if (reg_val != 0x0143414d) { + /* Disable RX */ + clrbits_le32(®s->ctl, 0x1 << 2); + + /* Flush RX FIFO */ + setbits_le32(®s->rx_ctl, 0x1 << 3); + while (readl(®s->rx_ctl) & (0x1 << 3)) + ; + + /* Enable RX */ + setbits_le32(®s->ctl, 0x1 << 2); + + return 0; + } + + /* A packet ready now + * Get status/length + */ + good_packet = 1; + + emac_inblk_32bit(®s->rx_io_data, &rxhdr, sizeof(rxhdr)); + + rx_len = rxhdr.rx_len; + rx_status = rxhdr.rx_status; + + /* Packet Status check */ + if (rx_len < 0x40) { + good_packet = 0; + debug("RX: Bad Packet (runt)\n"); + } + + /* rx_status is identical to RSR register. */ + if (0 & rx_status & (EMAC_CRCERR | EMAC_LENERR)) { + good_packet = 0; + if (rx_status & EMAC_CRCERR) + printf("crc error\n"); + if (rx_status & EMAC_LENERR) + printf("length error\n"); + } + + /* Move data from EMAC */ + if (good_packet) { + if (rx_len > DMA_CPU_TRRESHOLD) { + printf("Received packet is too big (len=%d)\n", rx_len); + } else { + emac_inblk_32bit((void *)®s->rx_io_data, + NetRxPackets[0], rx_len); + + /* Pass to upper layer */ + NetReceive(NetRxPackets[0], rx_len); + return rx_len; + } + } + + return 0; +} + +static int sunxi_emac_eth_send(struct eth_device *dev, void *packet, int len) +{ + struct emac_regs *regs = (struct emac_regs *)dev->iobase; + + /* Select channel 0 */ + writel(0, ®s->tx_ins); + + /* Write packet */ + emac_outblk_32bit((void *)®s->tx_io_data, packet, len); + + /* Set TX len */ + writel(len, ®s->tx_pl0); + + /* Start translate from fifo to phy */ + setbits_le32(®s->tx_ctl0, 1); + + return 0; +} + +int sunxi_emac_initialize(void) +{ + struct sunxi_ccm_reg *const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_sramc_regs *sram = + (struct sunxi_sramc_regs *)SUNXI_SRAMC_BASE; + struct emac_regs *regs = + (struct emac_regs *)SUNXI_EMAC_BASE; + struct eth_device *dev; + struct emac_eth_dev *priv; + int pin; + + dev = malloc(sizeof(*dev)); + if (dev == NULL) + return -ENOMEM; + + priv = (struct emac_eth_dev *)malloc(sizeof(struct emac_eth_dev)); + if (!priv) { + free(dev); + return -ENOMEM; + } + + memset(dev, 0, sizeof(*dev)); + memset(priv, 0, sizeof(struct emac_eth_dev)); + + /* Map SRAM to EMAC */ + setbits_le32(&sram->ctrl1, 0x5 << 2); + + /* Configure pin mux settings for MII Ethernet */ + for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(17); pin++) + sunxi_gpio_set_cfgpin(pin, SUNXI_GPA0_EMAC); + + /* Set up clock gating */ + setbits_le32(&ccm->ahb_gate0, 0x1 << AHB_GATE_OFFSET_EMAC); + + /* Set MII clock */ + clrsetbits_le32(®s->mac_mcfg, 0xf << 2, 0xd << 2); + + dev->iobase = (int)regs; + dev->priv = priv; + dev->init = sunxi_emac_eth_init; + dev->halt = sunxi_emac_eth_halt; + dev->send = sunxi_emac_eth_send; + dev->recv = sunxi_emac_eth_recv; + strcpy(dev->name, "emac"); + + eth_register(dev); + + miiphy_register(dev->name, emac_phy_read, emac_phy_write); + + return 0; +} diff --git a/drivers/net/sunxi_wemac.c b/drivers/net/sunxi_wemac.c deleted file mode 100644 index 699a381..0000000 --- a/drivers/net/sunxi_wemac.c +++ /dev/null @@ -1,525 +0,0 @@ -/* - * sunxi_wemac.c -- Allwinner A10 ethernet driver - * - * (C) Copyright 2012, Stefan Roese sr@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <net.h> -#include <miiphy.h> -#include <linux/err.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/gpio.h> - -/* EMAC register */ -struct wemac_regs { - u32 ctl; /* 0x00 */ - u32 tx_mode; /* 0x04 */ - u32 tx_flow; /* 0x08 */ - u32 tx_ctl0; /* 0x0c */ - u32 tx_ctl1; /* 0x10 */ - u32 tx_ins; /* 0x14 */ - u32 tx_pl0; /* 0x18 */ - u32 tx_pl1; /* 0x1c */ - u32 tx_sta; /* 0x20 */ - u32 tx_io_data; /* 0x24 */ - u32 tx_io_data1; /* 0x28 */ - u32 tx_tsvl0; /* 0x2c */ - u32 tx_tsvh0; /* 0x30 */ - u32 tx_tsvl1; /* 0x34 */ - u32 tx_tsvh1; /* 0x38 */ - u32 rx_ctl; /* 0x3c */ - u32 rx_hash0; /* 0x40 */ - u32 rx_hash1; /* 0x44 */ - u32 rx_sta; /* 0x48 */ - u32 rx_io_data; /* 0x4c */ - u32 rx_fbc; /* 0x50 */ - u32 int_ctl; /* 0x54 */ - u32 int_sta; /* 0x58 */ - u32 mac_ctl0; /* 0x5c */ - u32 mac_ctl1; /* 0x60 */ - u32 mac_ipgt; /* 0x64 */ - u32 mac_ipgr; /* 0x68 */ - u32 mac_clrt; /* 0x6c */ - u32 mac_maxf; /* 0x70 */ - u32 mac_supp; /* 0x74 */ - u32 mac_test; /* 0x78 */ - u32 mac_mcfg; /* 0x7c */ - u32 mac_mcmd; /* 0x80 */ - u32 mac_madr; /* 0x84 */ - u32 mac_mwtd; /* 0x88 */ - u32 mac_mrdd; /* 0x8c */ - u32 mac_mind; /* 0x90 */ - u32 mac_ssrr; /* 0x94 */ - u32 mac_a0; /* 0x98 */ - u32 mac_a1; /* 0x9c */ -}; - -/* SRAMC register */ -struct sunxi_sramc_regs { - u32 ctrl0; - u32 ctrl1; -}; - -/* 0: Disable 1: Aborted frame enable(default) */ -#define EMAC_TX_AB_M (0x1 << 0) -/* 0: CPU 1: DMA(default) */ -#define EMAC_TX_TM (0x1 << 1) - -#define EMAC_TX_SETUP (0) - -/* 0: DRQ asserted 1: DRQ automatically(default) */ -#define EMAC_RX_DRQ_MODE (0x1 << 1) -/* 0: CPU 1: DMA(default) */ -#define EMAC_RX_TM (0x1 << 2) -/* 0: Normal(default) 1: Pass all Frames */ -#define EMAC_RX_PA (0x1 << 4) -/* 0: Normal(default) 1: Pass Control Frames */ -#define EMAC_RX_PCF (0x1 << 5) -/* 0: Normal(default) 1: Pass Frames with CRC Error */ -#define EMAC_RX_PCRCE (0x1 << 6) -/* 0: Normal(default) 1: Pass Frames with Length Error */ -#define EMAC_RX_PLE (0x1 << 7) -/* 0: Normal 1: Pass Frames length out of range(default) */ -#define EMAC_RX_POR (0x1 << 8) -/* 0: Not accept 1: Accept unicast Packets(default) */ -#define EMAC_RX_UCAD (0x1 << 16) -/* 0: Normal(default) 1: DA Filtering */ -#define EMAC_RX_DAF (0x1 << 17) -/* 0: Not accept 1: Accept multicast Packets(default) */ -#define EMAC_RX_MCO (0x1 << 20) -/* 0: Disable(default) 1: Enable Hash filter */ -#define EMAC_RX_MHF (0x1 << 21) -/* 0: Not accept 1: Accept Broadcast Packets(default) */ -#define EMAC_RX_BCO (0x1 << 22) -/* 0: Disable(default) 1: Enable SA Filtering */ -#define EMAC_RX_SAF (0x1 << 24) -/* 0: Normal(default) 1: Inverse Filtering */ -#define EMAC_RX_SAIF (0x1 << 25) - -#define EMAC_RX_SETUP (EMAC_RX_POR | EMAC_RX_UCAD | EMAC_RX_DAF | \ - EMAC_RX_MCO | EMAC_RX_BCO) - -/* 0: Disable 1: Enable Receive Flow Control(default) */ -#define EMAC_MAC_CTL0_RFC (0x1 << 2) -/* 0: Disable 1: Enable Transmit Flow Control(default) */ -#define EMAC_MAC_CTL0_TFC (0x1 << 3) - -#define EMAC_MAC_CTL0_SETUP (EMAC_MAC_CTL0_RFC | EMAC_MAC_CTL0_TFC) - -/* 0: Disable 1: Enable MAC Frame Length Checking(default) */ -#define EMAC_MAC_CTL1_FLC (0x1 << 1) -/* 0: Disable(default) 1: Enable Huge Frame */ -#define EMAC_MAC_CTL1_HF (0x1 << 2) -/* 0: Disable(default) 1: Enable MAC Delayed CRC */ -#define EMAC_MAC_CTL1_DCRC (0x1 << 3) -/* 0: Disable 1: Enable MAC CRC(default) */ -#define EMAC_MAC_CTL1_CRC (0x1 << 4) -/* 0: Disable 1: Enable MAC PAD Short frames(default) */ -#define EMAC_MAC_CTL1_PC (0x1 << 5) -/* 0: Disable(default) 1: Enable MAC PAD Short frames and append CRC */ -#define EMAC_MAC_CTL1_VC (0x1 << 6) -/* 0: Disable(default) 1: Enable MAC auto detect Short frames */ -#define EMAC_MAC_CTL1_ADP (0x1 << 7) -/* 0: Disable(default) 1: Enable */ -#define EMAC_MAC_CTL1_PRE (0x1 << 8) -/* 0: Disable(default) 1: Enable */ -#define EMAC_MAC_CTL1_LPE (0x1 << 9) -/* 0: Disable(default) 1: Enable no back off */ -#define EMAC_MAC_CTL1_NB (0x1 << 12) -/* 0: Disable(default) 1: Enable */ -#define EMAC_MAC_CTL1_BNB (0x1 << 13) -/* 0: Disable(default) 1: Enable */ -#define EMAC_MAC_CTL1_ED (0x1 << 14) - -#define EMAC_MAC_CTL1_SETUP (EMAC_MAC_CTL1_FLC | EMAC_MAC_CTL1_CRC | \ - EMAC_MAC_CTL1_PC) - -#define EMAC_MAC_IPGT 0x15 - -#define EMAC_MAC_NBTB_IPG1 0xC -#define EMAC_MAC_NBTB_IPG2 0x12 - -#define EMAC_MAC_CW 0x37 -#define EMAC_MAC_RM 0xF - -#define EMAC_MAC_MFL 0x0600 - -/* Receive status */ -#define EMAC_CRCERR (1 << 4) -#define EMAC_LENERR (3 << 5) - -#define DMA_CPU_TRRESHOLD 2000 - -struct wemac_eth_dev { - u32 speed; - u32 duplex; - u32 phy_configured; - int link_printed; -}; - -struct wemac_rxhdr { - s16 rx_len; - u16 rx_status; -}; - -static void wemac_inblk_32bit(void *reg, void *data, int count) -{ - int cnt = (count + 3) >> 2; - - if (cnt) { - u32 *buf = data; - - do { - u32 x = readl(reg); - *buf++ = x; - } while (--cnt); - } -} - -static void wemac_outblk_32bit(void *reg, void *data, int count) -{ - int cnt = (count + 3) >> 2; - - if (cnt) { - const u32 *buf = data; - - do { - writel(*buf++, reg); - } while (--cnt); - } -} - -/* - * Read a word from phyxcer - */ -static int wemac_phy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) -{ - struct eth_device *dev = eth_get_dev_by_name(devname); - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - - /* issue the phy address and reg */ - writel(addr << 8 | reg, ®s->mac_madr); - - /* pull up the phy io line */ - writel(0x1, ®s->mac_mcmd); - - /* Wait read complete */ - mdelay(1); - - /* push down the phy io line */ - writel(0x0, ®s->mac_mcmd); - - /* and write data */ - *value = readl(®s->mac_mrdd); - - return 0; -} - -/* - * Write a word to phyxcer - */ -static int wemac_phy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) -{ - struct eth_device *dev = eth_get_dev_by_name(devname); - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - - /* issue the phy address and reg */ - writel(addr << 8 | reg, ®s->mac_madr); - - /* pull up the phy io line */ - writel(0x1, ®s->mac_mcmd); - - /* Wait write complete */ - mdelay(1); - - /* push down the phy io line */ - writel(0x0, ®s->mac_mcmd); - - /* and write data */ - writel(value, ®s->mac_mwtd); - - return 0; -} - -static void emac_setup(struct eth_device *dev) -{ - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - u32 reg_val; - u16 phy_val; - u32 duplex_flag; - - /* Set up TX */ - writel(EMAC_TX_SETUP, ®s->tx_mode); - - /* Set up RX */ - writel(EMAC_RX_SETUP, ®s->rx_ctl); - - /* Set MAC */ - /* Set MAC CTL0 */ - writel(EMAC_MAC_CTL0_SETUP, ®s->mac_ctl0); - - /* Set MAC CTL1 */ - wemac_phy_read(dev->name, 1, 0, &phy_val); - debug("PHY SETUP, reg 0 value: %x\n", phy_val); - duplex_flag = !!(phy_val & (1 << 8)); - - reg_val = 0; - if (duplex_flag) - reg_val = (0x1 << 0); - writel(EMAC_MAC_CTL1_SETUP | reg_val, ®s->mac_ctl1); - - /* Set up IPGT */ - writel(EMAC_MAC_IPGT, ®s->mac_ipgt); - - /* Set up IPGR */ - writel(EMAC_MAC_NBTB_IPG2 | (EMAC_MAC_NBTB_IPG1 << 8), ®s->mac_ipgr); - - /* Set up Collison window */ - writel(EMAC_MAC_RM | (EMAC_MAC_CW << 8), ®s->mac_clrt); - - /* Set up Max Frame Length */ - writel(EMAC_MAC_MFL, ®s->mac_maxf); -} - -static void wemac_reset(struct eth_device *dev) -{ - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - - debug("resetting device\n"); - - /* RESET device */ - writel(0, ®s->ctl); - udelay(200); - - writel(1, ®s->ctl); - udelay(200); -} - -static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd) -{ - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - struct wemac_eth_dev *priv = dev->priv; - u16 phy_reg; - - /* Init EMAC */ - - /* Flush RX FIFO */ - setbits_le32(®s->rx_ctl, 0x8); - udelay(1); - - /* Init MAC */ - - /* Soft reset MAC */ - clrbits_le32(®s->mac_ctl0, 1 << 15); - - /* Set MII clock */ - clrsetbits_le32(®s->mac_mcfg, 0xf << 2, 0xd << 2); - - /* Clear RX counter */ - writel(0x0, ®s->rx_fbc); - udelay(1); - - /* Set up EMAC */ - emac_setup(dev); - - writel(dev->enetaddr[0] << 16 | dev->enetaddr[1] << 8 | - dev->enetaddr[2], ®s->mac_a1); - writel(dev->enetaddr[3] << 16 | dev->enetaddr[4] << 8 | - dev->enetaddr[5], ®s->mac_a0); - - mdelay(1); - - wemac_reset(dev); - - /* PHY POWER UP */ - wemac_phy_read(dev->name, 1, 0, &phy_reg); - wemac_phy_write(dev->name, 1, 0, phy_reg & (~(1 << 11))); - mdelay(1); - - wemac_phy_read(dev->name, 1, 0, &phy_reg); - - priv->speed = miiphy_speed(dev->name, 0); - priv->duplex = miiphy_duplex(dev->name, 0); - - /* Print link status only once */ - if (!priv->link_printed) { - printf("ENET Speed is %d Mbps - %s duplex connection\n", - priv->speed, (priv->duplex == HALF) ? "HALF" : "FULL"); - priv->link_printed = 1; - } - - /* Set EMAC SPEED depend on PHY */ - clrsetbits_le32(®s->mac_supp, 1 << 8, - ((phy_reg & (1 << 13)) >> 13) << 8); - - /* Set duplex depend on phy */ - clrsetbits_le32(®s->mac_ctl1, 1 << 0, - ((phy_reg & (1 << 8)) >> 8) << 0); - - /* Enable RX/TX */ - setbits_le32(®s->ctl, 0x7); - - return 0; -} - -static void sunxi_wemac_eth_halt(struct eth_device *dev) -{ - /* Nothing to do here */ -} - -static int sunxi_wemac_eth_recv(struct eth_device *dev) -{ - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - struct wemac_rxhdr rxhdr; - u32 rxcount; - u32 reg_val; - int rx_len; - int rx_status; - int good_packet; - - /* Check packet ready or not */ - - /* - * Race warning: The first packet might arrive with - * the interrupts disabled, but the second will fix - */ - rxcount = readl(®s->rx_fbc); - if (!rxcount) { - /* Had one stuck? */ - rxcount = readl(®s->rx_fbc); - if (!rxcount) - return 0; - } - - reg_val = readl(®s->rx_io_data); - if (reg_val != 0x0143414d) { - /* Disable RX */ - clrbits_le32(®s->ctl, 1 << 2); - - /* Flush RX FIFO */ - setbits_le32(®s->rx_ctl, 1 << 3); - while (readl(®s->rx_ctl) & (1 << 3)) - ; - - /* Enable RX */ - setbits_le32(®s->ctl, 1 << 2); - - return 0; - } - - /* - * A packet ready now - * Get status/length - */ - good_packet = 1; - - wemac_inblk_32bit(®s->rx_io_data, &rxhdr, sizeof(rxhdr)); - - rx_len = rxhdr.rx_len; - rx_status = rxhdr.rx_status; - - /* Packet Status check */ - if (rx_len < 0x40) { - good_packet = 0; - debug("RX: Bad Packet (runt)\n"); - } - - /* rx_status is identical to RSR register. */ - if (0 & rx_status & (EMAC_CRCERR | EMAC_LENERR)) { - good_packet = 0; - if (rx_status & EMAC_CRCERR) - printf("crc error\n"); - if (rx_status & EMAC_LENERR) - printf("length error\n"); - } - - /* Move data from WEMAC */ - if (good_packet) { - if (rx_len > DMA_CPU_TRRESHOLD) { - printf("Received packet is too big (len=%d)\n", rx_len); - } else { - wemac_inblk_32bit((void *)®s->rx_io_data, - NetRxPackets[0], rx_len); - - /* Pass to upper layer */ - NetReceive(NetRxPackets[0], rx_len); - return rx_len; - } - } - - return 0; -} - -static int sunxi_wemac_eth_send(struct eth_device *dev, void *packet, int len) -{ - struct wemac_regs *regs = (struct wemac_regs *)dev->iobase; - - /* Select channel 0 */ - writel(0, ®s->tx_ins); - - /* Write packet */ - wemac_outblk_32bit((void *)®s->tx_io_data, packet, len); - - /* Set TX len */ - writel(len, ®s->tx_pl0); - - /* Start translate from fifo to phy */ - setbits_le32(®s->tx_ctl0, 1); - - return 0; -} - -int sunxi_wemac_initialize(void) -{ - struct sunxi_ccm_reg *const ccm = - (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - struct sunxi_sramc_regs *sram = - (struct sunxi_sramc_regs *)SUNXI_SRAMC_BASE; - struct eth_device *dev; - struct wemac_eth_dev *priv; - int pin; - - dev = malloc(sizeof(*dev)); - if (dev == NULL) - return -ENOMEM; - - priv = (struct wemac_eth_dev *)malloc(sizeof(struct wemac_eth_dev)); - if (!priv) { - free(dev); - return -ENOMEM; - } - - memset(dev, 0, sizeof(*dev)); - memset(priv, 0, sizeof(struct wemac_eth_dev)); - - /* Map SRAM to EMAC */ - setbits_le32(&sram->ctrl1, 0x5 << 2); - - /* Configure pin mux settings for MII Ethernet */ - for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(17); pin++) - sunxi_gpio_set_cfgpin(pin, 2); - - /* Set up clock gating */ - setbits_le32(&ccm->ahb_gate0, 1 << AHB_GATE_OFFSET_EMAC); - - dev->iobase = SUNXI_EMAC_BASE; - dev->priv = priv; - dev->init = sunxi_wemac_eth_init; - dev->halt = sunxi_wemac_eth_halt; - dev->send = sunxi_wemac_eth_send; - dev->recv = sunxi_wemac_eth_recv; - strcpy(dev->name, "wemac"); - - eth_register(dev); - - miiphy_register(dev->name, wemac_phy_read, wemac_phy_write); - - return 0; -} diff --git a/include/netdev.h b/include/netdev.h index 63481ec..e45dd7a 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -78,8 +78,8 @@ int sh_eth_initialize(bd_t *bis); int skge_initialize(bd_t *bis); int smc91111_initialize(u8 dev_num, int base_addr); int smc911x_initialize(u8 dev_num, int base_addr); +int sunxi_emac_initialize(bd_t *bis); int sunxi_gmac_initialize(bd_t *bis); -int sunxi_wemac_initialize(bd_t *bis); int tsi108_eth_initialize(bd_t *bis); int uec_standard_init(bd_t *bis); int uli526x_initialize(bd_t *bis);
git format-patch/send-email -M makes this a lot easier to look at. I've reviewed git show -M b6d2111e9a43c927cc83609625107c5b2a518163 from your branch instead (pasted below for everyone's reference).
Acked-by: Ian Campbell ijc@hellion.org.uk
Two general comments which I think are out of scope for this change:
First, I can't see what is using linux/err.h.
Second, there's an awful lot of magic numbers in this driver, but I don't see any reason to block this patch on that just because you are fixing the formatting.
Ian.
commit b6d2111e9a43c927cc83609625107c5b2a518163 Author: Stefan Roese sr@denx.de Date: Mon Nov 5 13:12:49 2012 +0100
net: Rename and cleanup sunxi (Allwinner) emac driver There have been 3 versions of the sunxi_emac support patch during its development. Somehow version 2 ended up in upstream u-boot where as the u-boot-sunxi git repo got version 3. This bumps the version in upstream u-boot to version 3 of the patch: - Initialize MII clock earlier so mii access to allow independent use - Name change from WEMAC to EMAC to match mainline kernel & chip manual - Cosmetic code cleanup Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 6005f7e..da2b5f8 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_E1000) += e1000.o obj-$(CONFIG_E1000_SPI) += e1000_spi.o obj-$(CONFIG_EEPRO100) += eepro100.o +obj-$(CONFIG_SUNXI_EMAC) += sunxi_emac.o obj-$(CONFIG_ENC28J60) += enc28j60.o obj-$(CONFIG_EP93XX) += ep93xx_eth.o obj-$(CONFIG_ETHOC) += ethoc.o @@ -51,7 +52,6 @@ obj-$(CONFIG_RTL8169) += rtl8169.o obj-$(CONFIG_SH_ETHER) += sh_eth.o obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o -obj-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o diff --git a/drivers/net/sunxi_wemac.c b/drivers/net/sunxi_emac.c similarity index 78% rename from drivers/net/sunxi_wemac.c rename to drivers/net/sunxi_emac.c index 699a381..5a06d68 100644 --- a/drivers/net/sunxi_wemac.c +++ b/drivers/net/sunxi_emac.c @@ -1,5 +1,5 @@ /*
- sunxi_wemac.c -- Allwinner A10 ethernet driver
- sunxi_emac.c -- Allwinner A10 ethernet driver
- (C) Copyright 2012, Stefan Roese sr@denx.de
@@ -7,16 +7,16 @@ */
#include <common.h> +#include <linux/err.h> #include <malloc.h> -#include <net.h> #include <miiphy.h> -#include <linux/err.h> +#include <net.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h>
/* EMAC register */ -struct wemac_regs { +struct emac_regs { u32 ctl; /* 0x00 */ u32 tx_mode; /* 0x04 */ u32 tx_flow; /* 0x08 */ @@ -27,7 +27,7 @@ struct wemac_regs { u32 tx_pl1; /* 0x1c */ u32 tx_sta; /* 0x20 */ u32 tx_io_data; /* 0x24 */
- u32 tx_io_data1;/* 0x28 */ u32 tx_tsvl0; /* 0x2c */ u32 tx_tsvh0; /* 0x30 */ u32 tx_tsvl1; /* 0x34 */
@@ -141,33 +141,33 @@ struct sunxi_sramc_regs {
-#define EMAC_MAC_NBTB_IPG1 0xC +#define EMAC_MAC_NBTB_IPG1 0xc #define EMAC_MAC_NBTB_IPG2 0x12
#define EMAC_MAC_CW 0x37 -#define EMAC_MAC_RM 0xF +#define EMAC_MAC_RM 0xf
/* Receive status */ -#define EMAC_CRCERR (1 << 4) -#define EMAC_LENERR (3 << 5) +#define EMAC_CRCERR (0x1 << 4) +#define EMAC_LENERR (0x3 << 5)
-struct wemac_eth_dev { +struct emac_eth_dev { u32 speed; u32 duplex; u32 phy_configured; int link_printed; };
-struct wemac_rxhdr { +struct emac_rxhdr { s16 rx_len; u16 rx_status; };
-static void wemac_inblk_32bit(void *reg, void *data, int count) +static void emac_inblk_32bit(void *reg, void *data, int count) { int cnt = (count + 3) >> 2;
@@ -181,7 +181,7 @@ static void wemac_inblk_32bit(void *reg, void *data, int count) } }
-static void wemac_outblk_32bit(void *reg, void *data, int count) +static void emac_outblk_32bit(void *reg, void *data, int count) { int cnt = (count + 3) >> 2;
@@ -194,14 +194,12 @@ static void wemac_outblk_32bit(void *reg, void *data, int count) } }
- Read a word from phyxcer
-static int wemac_phy_read(const char *devname, unsigned char addr, +/* Read a word from phyxcer */ +static int emac_phy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value) { struct eth_device *dev = eth_get_dev_by_name(devname);
/* issue the phy address and reg */ writel(addr << 8 | reg, ®s->mac_madr);
@@ -221,14 +219,12 @@ static int wemac_phy_read(const char *devname, unsigned char addr, return 0; }
- Write a word to phyxcer
-static int wemac_phy_write(const char *devname, unsigned char addr, +/* Write a word to phyxcer */ +static int emac_phy_write(const char *devname, unsigned char addr, unsigned char reg, unsigned short value) { struct eth_device *dev = eth_get_dev_by_name(devname);
@@ -250,7 +246,7 @@ static int wemac_phy_write(const char *devname, unsigned char addr,
static void emac_setup(struct eth_device *dev) {
- struct emac_regs *regs = (struct emac_regs *)dev->iobase; u32 reg_val; u16 phy_val; u32 duplex_flag;
@@ -266,7 +262,7 @@ static void emac_setup(struct eth_device *dev) writel(EMAC_MAC_CTL0_SETUP, ®s->mac_ctl0);
/* Set MAC CTL1 */
- emac_phy_read(dev->name, 1, 0, &phy_val); debug("PHY SETUP, reg 0 value: %x\n", phy_val); duplex_flag = !!(phy_val & (1 << 8));
@@ -288,9 +284,9 @@ static void emac_setup(struct eth_device *dev) writel(EMAC_MAC_MFL, ®s->mac_maxf); }
-static void wemac_reset(struct eth_device *dev) +static void emac_reset(struct eth_device *dev) {
@@ -302,10 +298,10 @@ static void wemac_reset(struct eth_device *dev) udelay(200); }
-static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd) +static int sunxi_emac_eth_init(struct eth_device *dev, bd_t *bd) {
struct emac_eth_dev *priv = dev->priv; u16 phy_reg;
/* Init EMAC */
@@ -317,10 +313,7 @@ static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd) /* Init MAC */
/* Clear RX counter */ writel(0x0, ®s->rx_fbc);
@@ -336,14 +329,14 @@ static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd)
mdelay(1);
- wemac_reset(dev);
emac_reset(dev);
/* PHY POWER UP */
- emac_phy_read(dev->name, 1, 0, &phy_reg);
- emac_phy_write(dev->name, 1, 0, phy_reg & (~(0x1 << 11))); mdelay(1);
priv->speed = miiphy_speed(dev->name, 0); priv->duplex = miiphy_duplex(dev->name, 0);
@@ -357,11 +350,11 @@ static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd)
/* Set EMAC SPEED depend on PHY */ clrsetbits_le32(®s->mac_supp, 1 << 8,
/* Set duplex depend on phy */ clrsetbits_le32(®s->mac_ctl1, 1 << 0,
/* Enable RX/TX */ setbits_le32(®s->ctl, 0x7);
@@ -369,15 +362,15 @@ static int sunxi_wemac_eth_init(struct eth_device *dev, bd_t *bd) return 0; }
-static void sunxi_wemac_eth_halt(struct eth_device *dev) +static void sunxi_emac_eth_halt(struct eth_device *dev) { /* Nothing to do here */ }
-static int sunxi_wemac_eth_recv(struct eth_device *dev) +static int sunxi_emac_eth_recv(struct eth_device *dev) {
- struct emac_rxhdr rxhdr; u32 rxcount; u32 reg_val; int rx_len;
@@ -386,8 +379,7 @@ static int sunxi_wemac_eth_recv(struct eth_device *dev)
- /* Race warning: The first packet might arrive with
*/ rxcount = readl(®s->rx_fbc);
- the interrupts disabled, but the second will fix
@@ -401,26 +393,25 @@ static int sunxi_wemac_eth_recv(struct eth_device *dev) reg_val = readl(®s->rx_io_data); if (reg_val != 0x0143414d) { /* Disable RX */
/* Flush RX FIFO */
while (readl(®s->rx_ctl) & (0x1 << 3)) ;
/* Enable RX */
return 0; }
- /* A packet ready now
*/ good_packet = 1;
- Get status/length
rx_len = rxhdr.rx_len; rx_status = rxhdr.rx_status;
@@ -440,13 +431,13 @@ static int sunxi_wemac_eth_recv(struct eth_device *dev) printf("length error\n"); }
- /* Move data from EMAC */ if (good_packet) { if (rx_len > DMA_CPU_TRRESHOLD) { printf("Received packet is too big (len=%d)\n", rx_len); } else {
NetRxPackets[0], rx_len); /* Pass to upper layer */ NetReceive(NetRxPackets[0], rx_len);
@@ -457,15 +448,15 @@ static int sunxi_wemac_eth_recv(struct eth_device *dev) return 0; }
-static int sunxi_wemac_eth_send(struct eth_device *dev, void *packet, int len) +static int sunxi_emac_eth_send(struct eth_device *dev, void *packet, int len) {
/* Select channel 0 */ writel(0, ®s->tx_ins);
/* Write packet */
/* Set TX len */ writel(len, ®s->tx_pl0);
@@ -476,50 +467,55 @@ static int sunxi_wemac_eth_send(struct eth_device *dev, void *packet, int len) return 0; }
-int sunxi_wemac_initialize(void) +int sunxi_emac_initialize(void) { struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; struct sunxi_sramc_regs *sram = (struct sunxi_sramc_regs *)SUNXI_SRAMC_BASE;
struct eth_device *dev;(struct emac_regs *)SUNXI_EMAC_BASE;
struct emac_eth_dev *priv; int pin;
dev = malloc(sizeof(*dev)); if (dev == NULL) return -ENOMEM;
priv = (struct emac_eth_dev *)malloc(sizeof(struct emac_eth_dev)); if (!priv) { free(dev); return -ENOMEM; }
/* Map SRAM to EMAC */ setbits_le32(&sram->ctrl1, 0x5 << 2);
/* Configure pin mux settings for MII Ethernet */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(17); pin++)
- setbits_le32(&ccm->ahb_gate0, 0x1 << AHB_GATE_OFFSET_EMAC);
- dev->iobase = (int)regs; dev->priv = priv;
eth_register(dev);
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 8 ++++++++ boards.cfg | 2 +- include/configs/sunxi-common.h | 5 +++++ 3 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 7d86409..024c8c1 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -123,6 +123,14 @@ int cpu_eth_init(bd_t *bis) { int rc;
+#ifdef CONFIG_SUNXI_EMAC + rc = sunxi_emac_initialize(bis); + if (rc < 0) { + printf("sunxi: failed to initialize emac\n"); + return rc; + } +#endif + #ifdef CONFIG_SUNXI_GMAC rc = sunxi_gmac_initialize(bis); if (rc < 0) { diff --git a/boards.cfg b/boards.cfg index f4f870a..a50fa01 100644 --- a/boards.cfg +++ b/boards.cfg @@ -381,7 +381,7 @@ Active arm armv7 s5pc1xx samsung goni Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - Active arm armv7 sunxi - sunxi A13-OLinuXinoM sun5i:A13_OLINUXINOM,SPL,CONS_INDEX=2 Hans de Goede hdegoede@redhat.com -Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL,AXP209_POWER Hans de Goede hdegoede@redhat.com +Active arm armv7 sunxi - sunxi Cubieboard sun4i:CUBIEBOARD,SPL,AXP209_POWER,SUNXI_EMAC Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL,AXP209_POWER,SUNXI_GMAC,RGMII Hans de Goede hdegoede@redhat.com Active arm armv7 sunxi - sunxi r7-tv-dongle sun5i:R7DONGLE,SPL,AXP152_POWER Hans de Goede hdegoede@redhat.com diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b76227e..a9d104a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -179,6 +179,11 @@ #define CONFIG_CONS_INDEX 1 /* UART0 */ #endif
+/* Ethernet support */ +#ifdef CONFIG_SUNXI_EMAC +#define CONFIG_MII /* MII PHY management */ +#endif + #ifdef CONFIG_SUNXI_GMAC #define CONFIG_DESIGNWARE_ETH /* GMAC can use designware driver */ #define CONFIG_DW_AUTONEG
ITYM s/sun4i/cubieboard/ in the subject?
The patch itself looks good to me.
Many A20 boards (ie Cubieboard2, A20-OLinuXino_MICRO) use an 100 Mbit MII phy together with the GMAC nic found in the A20 SoC, add support for this (this will get used when we add these boards in a later patch).
Signed-off-by: Chen-Yu Tsai wens@csie.org Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/gmac.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/board/sunxi/gmac.c b/board/sunxi/gmac.c index e48328d..e7ff952 100644 --- a/board/sunxi/gmac.c +++ b/board/sunxi/gmac.c @@ -16,17 +16,28 @@ int sunxi_gmac_initialize(bd_t *bis) setbits_le32(&ccm->ahb_gate1, 0x1 << AHB_GATE_OFFSET_GMAC);
/* Set MII clock */ +#ifdef CONFIG_RGMII setbits_le32(&ccm->gmac_clk_cfg, CCM_GMAC_CTRL_TX_CLK_SRC_INT_RGMII | CCM_GMAC_CTRL_GPIT_RGMII); +#else + setbits_le32(&ccm->gmac_clk_cfg, CCM_GMAC_CTRL_TX_CLK_SRC_MII | + CCM_GMAC_CTRL_GPIT_MII); +#endif
/* Configure pin mux settings for GMAC */ for (pin = SUNXI_GPA(0); pin <= SUNXI_GPA(16); pin++) { +#ifdef CONFIG_RGMII /* skip unused pins in RGMII mode */ if (pin == SUNXI_GPA(9) || pin == SUNXI_GPA(14)) continue; +#endif sunxi_gpio_set_cfgpin(pin, SUN7I_GPA0_GMAC); sunxi_gpio_set_drv(pin, 3); }
+#ifdef CONFIG_RGMII return designware_initialize(SUNXI_GMAC_BASE, PHY_INTERFACE_MODE_RGMII); +#else + return designware_initialize(SUNXI_GMAC_BASE, PHY_INTERFACE_MODE_MII); +#endif }
FYI I've got a cubieboard2 patch in the works which will use this (I've got a very similar patch locally, I shall rebase onto this).
Ian.
Cool, once this patch-set is in I plan to add some more boards myself too.
About rebasing, you can find my latest work here: https://github.com/jwrdegoede/u-boot-sunxi/tree/sun4i-upstreaming-v1
This is u-boot master with u-boot-arm master merged in and then my patches on top.
Note I've added myself as board-maintainer for the cubietruck since you did not add yourself, feel free to submit a patch to make you the maintainer instead if you want :)
Regards,
Hans
Which patch was that? I noticed a bunch of boards.cfg which weren't described in the commit logs.
Is co-maintainership allowed?
Ian.
NM I spotted it in the axp209 pmic patch.
BTW for the other "Add sun?i" patches etc it would be nice to mention which boards are being added in the commit message, likewise when adding new features mentioning "and enable for X, Y and Z" would be good to.
Ian.
In the "sunxi: Add axp209 pmic support" patch, where the commit logs says:
While changing the boards.cfg lines for the Cubietruck, add myself as board maintainer for the Cubietruck.
Looking at other boards, yes. It seems the format for co-maintainership would be putting something like this in the last column:
Hans de Goede hdegoede@redhat.com:Ian Campbell ijc@hellion.org.uk
Regards,
Hans
p.s.
Any chance you could review the rest of this series ?
Yes, I found it later. It was all the other boards.cfg changes which weren't mentioned in their respective logs ;-)
Let's do that then, at least for the boards which we both have/want to support (for me that is cubieboard2 and cubietruck for the moment).
p.s.
Yep, I just did the easy bits which fitted into the time I had available yesterday. I'll try and make time for the more involved bits soon.
Ian.
Right, so for v2 of this series you want me to add a line to the log like this ? :
And enable AXP209 support on boards which have this pmic.
Works for me, shall I adjust things in v2 of my series to add you at the same time I add myself for the cubietruck ?
Also please add me as co-maintainer in the cubieboard2 patch you're working on.
p.s.
Thanks!
Regards,
Hans
"And enable AXP209 support on X, Y and Z".
Please.
Ack.
Ian
Hans de Goede
Ian Campbell
Siarhei Siamashka
