[U-Boot-Users] console kernel parameter problem
Hi all, I'm working with a board with a MPC8548 processor. I built the uboot (version 1.3.0), the DTS file (myboard.dtb) and a kernel 2.6.21 . When I try to boot the kernel via NFS I have some exception mode when parsing the kernel parameters. Specifically I obtained an error during the parsing of "console" parameter. My host computer is connected to the board via console using a standard 8250 port.
I append the log in this post.
Has anyone any suggestion?
Thanks in advance for the reply.
root=/dev/nfs rw nfsroot=192.168.0.90:/home/ftpuser/workspace/rootfs ip=192.168.0.11:192.168.0.90:192.168.0.90:255.255.255.0:MYBOARD:eth2:off console=ttyS1,115200
=> => => run nfsboot Enet starting in 1000BT/FD Speed: 1000, full duplex Using eTSEC2 device TFTP from server 192.168.0.90; our IP address is 192.168.0.11 Filename 'uImage'. Load address: 0x1000000 Loading: * Enet starting in 1000BT/FD Speed: 1000, full duplex Using eTSEC2 device TFTP from server 192.168.0.90; our IP address is 192.168.0.11 Filename 'myboard.dtb'. Load address: 0x3000000 Loading: * ## Booting image at 01000000 ... Image Name: Linux-2.6.21.7 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1509390 Bytes = 1.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Booting using the fdt at 0x3000000 Loading Device Tree to 007fc000, end 007fd313 ... OK Parsing ARGS: root=/dev/nfs rw nfsroot=192.168.0.90:/home/ftpuser/workspace/rootfs ip=192.168.0.11:192.168.0.90:192.168.0.90:255.255.255.0:MYBOARD:eth2:off console=ttyS1,115200 early options: Parameter `root' Unknown argument: calling c02dc5f0 return parse_one 0 early options: Parameter `root' early options: Parameter `rw' Unknown argument: calling c02dc5f0 return parse_one 0 early options: Parameter `rw' early options: Parameter `nfsroot' Unknown argument: calling c02dc5f0 return parse_one 0 early options: Parameter `nfsroot' early options: Parameter `ip' Unknown argument: calling c02dc5f0 return parse_one 0 early options: Parameter `ip' early options: Parameter `console' Unknown argument: calling c02dc5f0 return parse_one 0 early options: Parameter `console' Using MYBOARD machine description Memory CAM mapping: CAM0=256Mb, CAM1=256Mb, CAM2=256Mb residual: 256Mb Linux version 2.6.21.7 (gcc version 4.1.2 ) #2 PREEMPT Thu Mar 13 16:30:01 GMT 2008 setup_arch: bootmem setup_arch()
arch: exit Zone PFN ranges: DMA 0 -> 196608 Normal 196608 -> 196608 HighMem 196608 -> 262144 early_node_map[1] active PFN ranges 0: 0 -> 262144 Built 1 zonelists. Total pages: 260096 Kernel command line: root=/dev/nfs rw nfsroot=192.168.0.90:/home/ftpuser/workspace/rootfs ip=192.168.0.11:192.168.0.90:192.168.0.90:255.255.255.0:MYBOARD:eth2:off console=ttyS1,115200 Parsing ARGS: root=/dev/nfs rw nfsroot=192.168.0.90:/home/ftpuser/workspace/rootfs ip=192.168.0.11:192.168.0.90:192.168.0.90:255.255.255.0:MYBOARD:eth2:off console=ttyS1,115200 Booting kernel: Parameter `root' Unknown argument: calling c02dc318 return parse_one 0 Booting kernel: Parameter `root=/dev/nfs' Booting kernel: Parameter `rw' Unknown argument: calling c02dc318 return parse_one 0 Booting kernel: Parameter `rw' Booting kernel: Parameter `nfsroot' Unknown argument: calling c02dc318 return parse_one 0 Booting kernel: Parameter `nfsroot=192.168.0.90:/home/ftpuser/workspace/rootfs' Booting kernel: Parameter `ip' Unknown argument: calling c02dc318 return parse_one 0 Booting kernel: Parameter `ip=192.168.0.11:192.168.0.90:192.168.0.90:255.255.255.0:MYBOARD:eth2:off' Booting kernel: Parameter `console' Unknown argument: calling c02dc318 Oops: Exception in kernel mode, sig: 4 [#1] PREEMPT Modules linked in: NIP: C02E7B30 LR: C02E7C28 CTR: 00000000 REGS: c031be80 TRAP: 0700 Not tainted (2.6.21.7) MSR: 00021000 <ME> CR: 24084022 XER: 00000000 TASK = c02fe5b8[0] 'swapper' THREAD: c031a000 GPR00: 00000000 C031BF30 C02FE5B8 C0332184 C031BF58 C035595A C031BF5E C0300000 GPR08: 0000000A C0332184 00000001 C0332184 00000000 60000000 3FFFC400 03000000 GPR16: 00000001 00000000 007FFF00 00000000 00000000 007FFEB0 00000000 C02D6000 GPR24: 00000044 00021000 00000000 C035595A 00000001 C031BF58 C0332184 00000000 NIP [C02E7B30] add_preferred_console+0xac/0xd8 LR [C02E7C28] console_setup+0xcc/0xe4 Call Trace: [C031BF30] [C03017C0] 0xc03017c0 (unreliable) [C031BF50] [C02E7C28] console_setup+0xcc/0xe4 [C031BF70] [C02DC400] unknown_bootoption+0xe8/0x260 [C031BF90] [C003DDC8] parse_args+0x1f8/0x310 [C031BFC0] [C02DC7F4] start_kernel+0x16c/0x2b4 [C031BFF0] [C0000388] skpinv+0x2b8/0x2f4 Instruction dump: 48000048 3d20c030 38600000 93e9ff98 48000038 3d20c030 93e9ff98 3d20c033 39292184 57eb2036 7d6b4a14 38000000 <7d3d44aa> 7d2b45aa 38600000 938b0008 Kernel panic - not syncing: Attempted to kill the idle task! Rebooting in 180 seconds..
Fabio Ubaldi
