[U-Boot-Users] Mantica@Spea.Net - Email found in subject - [ColdFire] RE: [uClinux-dev] Reset problem
Hi Dan,
Thanks, the solution was connect the reset line to the reset input from our flash chip. Now it seems all works ok!
Daniel Alomar i Claramonte Research & Development Electronic Dept. SERRA SOLDADURA, S.A. WEB Site: http://www.serrasold.com Knowledge Site: http://serratron.serrasold.com
-----Mensaje original----- De: Dan Searle [mailto:dan@adelix.com] Enviado el: viernes, 13 de mayo de 2005 13:28 Para: Daniel Alomar CC: u-boot-users@lists.sourceforge.net; uclinux-dev@uclinux.org; coldfire@lists.wildrice.com Asunto: Re: [uClinux-dev] Reset problem
Are you using a flash to boot from? I had a similar problem with an ADI Coyote based board. Turns out that if the flash chip is in "Write enable" mode when the reboot occurs, the CPU can't read the bootloader from it and the board hangs. I added a reset handler in the MTD mapping driver (ixp4xx.ko in my case), which forced the flash chip in to read mode before the reset is attempted.
Regards, Dan...
Friday, May 13, 2005, 12:22:47 PM, you wrote:
Hi folks,
We have a 5282 in our prototype board based in an Avnet board, with the lastest u-Clinux dist. and U-Boot, and we have an annoying behaviour. The 80% times we push the reset button, uClinux don't boot, and we have to plug off the power and plug on to boot correctly. We have checked the reset out signal from the micro, and it's ok.
Daniel Alomar i Claramonte R D Electronics Dept. SERRA SOLDADURA, S.A.
Dan Searle Adelix Ltd dan.searle@adelix.com web: www.adelix.com tel: 0845 230 9590 / fax: 0845 230 9591 / support: 0845 230 9592 snail: The Old Post Office, Bristol Rd, Hambrook, Bristol BS16 1RY. UK.
Any views expressed in this email communication are those of the individual sender, except where the sender specifically states them to be the views of a member of Adelix Ltd. Adelix Ltd. does not represent, warrant or guarantee that the integrity of this communication has been maintained nor that the communication is free of errors or interference.
-------------------------------------------------------------------- To Subscribe send a message to: ColdFire-On@Lists.Wildrice.com To Unsubscribe send a message to: ColdFire-Off@Lists.Wildrice.com For further information, visit: http://www.WildRice.com/ColdFire/
Daniel Alomar
