[U-Boot] [PATCH] drivers/crypto/fsl : Allocate output ring with size aligned to CACHELNE SIZE
The output ring needs to be invalidated before enqueuing the job to SEC. While allocation of space to output ring, it should be taken care that the size is cacheline size aligned inorder to prevent invalidating valid data.
The patch also correct the method of aligning end of structs while flushing caches
Since start = align(start_of_struct), it is incorrect to assign end = align(start + struct_size). It should instead be, end = align(start_of_struct + struct_size).
Signed-off-by: Saksham Jain saksham@nxp.com Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com --- drivers/crypto/fsl/jr.c | 28 ++++++++++++++++------------ drivers/crypto/fsl/jr.h | 2 ++ 2 files changed, 18 insertions(+), 12 deletions(-)
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index b553e3c..4566ec3 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -95,14 +95,16 @@ static int jr_init(void) JR_SIZE * sizeof(dma_addr_t)); if (!jr.input_ring) return -1; + + jr.op_size = roundup(JR_SIZE * sizeof(struct op_ring), + ARCH_DMA_MINALIGN); jr.output_ring = - (struct op_ring *)memalign(ARCH_DMA_MINALIGN, - JR_SIZE * sizeof(struct op_ring)); + (struct op_ring *)memalign(ARCH_DMA_MINALIGN, jr.op_size); if (!jr.output_ring) return -1;
memset(jr.input_ring, 0, JR_SIZE * sizeof(dma_addr_t)); - memset(jr.output_ring, 0, JR_SIZE * sizeof(struct op_ring)); + memset(jr.output_ring, 0, jr.op_size);
start_jr0();
@@ -190,8 +192,8 @@ static int jr_enqueue(uint32_t *desc_addr,
unsigned long start = (unsigned long)&jr.info[head] & ~(ARCH_DMA_MINALIGN - 1); - unsigned long end = ALIGN(start + sizeof(struct jr_info), - ARCH_DMA_MINALIGN); + unsigned long end = ALIGN((unsigned long)&jr.info[head] + + sizeof(struct jr_info), ARCH_DMA_MINALIGN); flush_dcache_range(start, end);
#ifdef CONFIG_PHYS_64BIT @@ -216,11 +218,19 @@ static int jr_enqueue(uint32_t *desc_addr, #endif /* ifdef CONFIG_PHYS_64BIT */
start = (unsigned long)&jr.input_ring[head] & ~(ARCH_DMA_MINALIGN - 1); - end = ALIGN(start + sizeof(phys_addr_t), ARCH_DMA_MINALIGN); + end = ALIGN((unsigned long)&jr.input_ring[head] + + sizeof(dma_addr_t), ARCH_DMA_MINALIGN); flush_dcache_range(start, end);
jr.head = (head + 1) & (jr.size - 1);
+ /* Invalidate output ring */ + start = (unsigned long)jr.output_ring & + ~(ARCH_DMA_MINALIGN - 1); + end = ALIGN((unsigned long)jr.output_ring + jr.op_size, + ARCH_DMA_MINALIGN); + invalidate_dcache_range(start, end); + sec_out32(®s->irja, 1);
return 0; @@ -241,12 +251,6 @@ static int jr_dequeue(void) #endif
while (sec_in32(®s->orsf) && CIRC_CNT(jr.head, jr.tail, jr.size)) { - unsigned long start = (unsigned long)jr.output_ring & - ~(ARCH_DMA_MINALIGN - 1); - unsigned long end = ALIGN(start + - sizeof(struct op_ring)*JR_SIZE, - ARCH_DMA_MINALIGN); - invalidate_dcache_range(start, end);
found = 0;
diff --git a/drivers/crypto/fsl/jr.h b/drivers/crypto/fsl/jr.h index 5899696..545d964 100644 --- a/drivers/crypto/fsl/jr.h +++ b/drivers/crypto/fsl/jr.h @@ -72,6 +72,8 @@ struct jobring { int write_idx; /* Size of the rings. */ int size; + /* Op ring size aligned to cache line size */ + int op_size; /* The ip and output rings have to be accessed by SEC. So the * pointers will ahve to point to the housekeeping region provided * by SEC
Ok to push
________________________________________ From: Ruchika Gupta ruchika.gupta@nxp.com Sent: Friday, January 22, 2016 4:42 AM To: u-boot@lists.denx.de; york sun; Ulises Cardenas Cc: Ruchika Gupta; Saksham Jain; Ruchika Gupta Subject: [PATCH] drivers/crypto/fsl : Allocate output ring with size aligned to CACHELNE SIZE
start_jr0();
found = 0;
diff --git a/drivers/crypto/fsl/jr.h b/drivers/crypto/fsl/jr.h index 5899696..545d964 100644 --- a/drivers/crypto/fsl/jr.h +++ b/drivers/crypto/fsl/jr.h @@ -72,6 +72,8 @@ struct jobring { int write_idx; /* Size of the rings. */ int size; + /* Op ring size aligned to cache line size */ + int op_size; /* The ip and output rings have to be accessed by SEC. So the * pointers will ahve to point to the housekeeping region provided * by SEC -- 1.8.1.4
Applied to fsl-qoriq master. Awaiting upstream.
York
Ruchika Gupta
Ulises Cardenas
york sun
