[U-Boot] [PATCH] board: Add support for iMX8QXP AI_ML board
This commit adds initial board support for iMX8QXP AI_ML board from Einfochips. This board is one of the 96Boards Consumer Edition and AI boards of the 96Boards family based on i.MX8QXP SoC from NXP/Freescale.
This initial supports contains following peripherals which are tested and known to work:
1. Debug serial via UART2 2. SD card 3. Ethernet
More information about this board can be found in arrow website: https://www.arrow.com/en/products/imx8-ai-ml/arrow-development-tools
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8/Kconfig | 6 ++ board/einfochips/imx8qxp_ai_ml/Kconfig | 21 ++++ board/einfochips/imx8qxp_ai_ml/MAINTAINERS | 6 ++ board/einfochips/imx8qxp_ai_ml/Makefile | 8 ++ board/einfochips/imx8qxp_ai_ml/README | 49 ++++++++++ .../einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c | 78 +++++++++++++++ board/einfochips/imx8qxp_ai_ml/imximage.cfg | 24 +++++ board/einfochips/imx8qxp_ai_ml/spl.c | 39 ++++++++ configs/imx8qxp_ai_ml_defconfig | 83 ++++++++++++++++ include/configs/imx8qxp_ai_ml.h | 95 +++++++++++++++++++ 10 files changed, 409 insertions(+) create mode 100644 board/einfochips/imx8qxp_ai_ml/Kconfig create mode 100644 board/einfochips/imx8qxp_ai_ml/MAINTAINERS create mode 100644 board/einfochips/imx8qxp_ai_ml/Makefile create mode 100644 board/einfochips/imx8qxp_ai_ml/README create mode 100644 board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c create mode 100644 board/einfochips/imx8qxp_ai_ml/imximage.cfg create mode 100644 board/einfochips/imx8qxp_ai_ml/spl.c create mode 100644 configs/imx8qxp_ai_ml_defconfig create mode 100644 include/configs/imx8qxp_ai_ml.h
diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index cdb78afacf..25fe4e2be0 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -55,6 +55,11 @@ config TARGET_COLIBRI_IMX8X select BOARD_LATE_INIT select IMX8QXP
+config TARGET_IMX8QXP_AI_ML + bool "Support i.MX8QXP AI_ML board" + select BOARD_EARLY_INIT_F + select IMX8QXP + config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board" select BOARD_LATE_INIT @@ -73,6 +78,7 @@ config TARGET_IMX8QXP_MEK
endchoice
+source "board/einfochips/imx8qxp_ai_ml/Kconfig" source "board/freescale/imx8qm_mek/Kconfig" source "board/freescale/imx8qxp_mek/Kconfig" source "board/advantech/imx8qm_rom7720_a1/Kconfig" diff --git a/board/einfochips/imx8qxp_ai_ml/Kconfig b/board/einfochips/imx8qxp_ai_ml/Kconfig new file mode 100644 index 0000000000..b6806b8859 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/Kconfig @@ -0,0 +1,21 @@ +if TARGET_IMX8QXP_AI_ML + +config SYS_BOARD + default "imx8qxp_ai_ml" + +config SYS_VENDOR + default "einfochips" + +config SYS_CONFIG_NAME + default "imx8qxp_ai_ml" + +config SYS_MALLOC_LEN + default 0x2400000 + +config ENV_SIZE + default 0x1000 + +config ENV_OFFSET + default 0x400000 + +endif diff --git a/board/einfochips/imx8qxp_ai_ml/MAINTAINERS b/board/einfochips/imx8qxp_ai_ml/MAINTAINERS new file mode 100644 index 0000000000..add0bd9431 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8QXP AI_ML BOARD +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/einfochips/imx8qxp_ai_ml/ +F: include/configs/imx8qxp_ai_ml.h +F: configs/imx8qxp_ai_ml_defconfig diff --git a/board/einfochips/imx8qxp_ai_ml/Makefile b/board/einfochips/imx8qxp_ai_ml/Makefile new file mode 100644 index 0000000000..e08774dc6e --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/Makefile @@ -0,0 +1,8 @@ +# +# Copyright 2019 Linaro Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8qxp_ai_ml.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/einfochips/imx8qxp_ai_ml/README b/board/einfochips/imx8qxp_ai_ml/README new file mode 100644 index 0000000000..488920580f --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/README @@ -0,0 +1,49 @@ +U-Boot for the Einfochips i.MX8QXP AI_ML board + +Quick Start +=========== + +- Get and Build the ARM Trusted firmware +- Get scfw_tcm.bin and ahab-container.img +- Build U-Boot +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +====================================== + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ git checkout origin/imx_4.9.88_imx8qxp_beta2 -b imx_4.9.88_imx8qxp_beta2 +$ make PLAT=imx8qxp bl31 + +Get scfw_tcm.bin and ahab-container.img +======================================= + +$ wget https://raw.githubusercontent.com/96boards-ai-ml/binaries/master/mx8qx-aiml-... +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.1.bin +$ chmod +x firmware-imx-8.1.bin +$ ./firmware-imx-8.1.bin + +Copy the following binaries to U-Boot folder: + +$ cp imx-atf/build/imx8qxp/release/bl31.bin . +$ cp firmware-imx-8.1/firmware/seco/mx8qx-ahab-container.img . + +Build U-Boot +============ + +$ make imx8qxp_ai_ml_defconfig +$ make u-boot-dtb.imx + +Flash the binary into the SD card +================================= + +Burn the u-boot-dtb.imx binary to SD card offset 32KB: + +$ sudo dd if=u-boot-dtb.imx of=/dev/sd[x] bs=1024 seek=32 + +Boot +==== + +Set Boot switch SW2: 1100. diff --git a/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c b/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c new file mode 100644 index 0000000000..465fea65f8 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/imx8qxp_ai_ml.c @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + */ + +#include <common.h> +#include <errno.h> +#include <linux/libfdt.h> +#include <fsl_esdhc.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + sc_pm_clock_rate_t rate = SC_80MHZ; + int ret; + + /* Set UART2 clock root to 80 MHz */ + ret = sc_pm_setup_uart(SC_R_UART_2, rate); + if (ret) + return ret; + + return 0; +} + +#if IS_ENABLED(CONFIG_FEC_MXC) +#include <miiphy.h> + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +int checkboard(void) +{ + puts("Board: iMX8QXP AI_ML\n"); + + build_info(); + print_bootinfo(); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +/* Board specific reset that is system reset */ + +void reset_cpu(ulong addr) +{ + /* TODO */ +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif diff --git a/board/einfochips/imx8qxp_ai_ml/imximage.cfg b/board/einfochips/imx8qxp_ai_ml/imximage.cfg new file mode 100644 index 0000000000..4fc5ade313 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/imximage.cfg @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + * + * Refer doc/README.imx8image for more details about how-to configure + * and create imx8image boot image + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM SD 0x400 +/* SoC type IMX8QX */ +SOC_TYPE IMX8QX +/* Append seco container image */ +APPEND mx8qx-ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qx-aiml-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/einfochips/imx8qxp_ai_ml/spl.c b/board/einfochips/imx8qxp_ai_ml/spl.c new file mode 100644 index 0000000000..2e6e0741e5 --- /dev/null +++ b/board/einfochips/imx8qxp_ai_ml/spl.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + * + */ + +#include <common.h> +#include <dm.h> +#include <spl.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> +#include <dm/lists.h> + +DECLARE_GLOBAL_DATA_PTR; + +void spl_board_init(void) +{ + arch_cpu_init(); + + timer_init(); + + preloader_console_init(); + + puts("Normal Boot\n"); +} + +void board_init_f(ulong dummy) +{ + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8qxp_ai_ml_defconfig b/configs/imx8qxp_ai_ml_defconfig new file mode 100644 index 0000000000..e20a0c783e --- /dev/null +++ b/configs/imx8qxp_ai_ml_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_TARGET_IMX8QXP_AI_ML=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=4 +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/einfochips/imx8qxp_ai_ml/imximage.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_LOG=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_FAT_WRITE=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-ai_ml" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPL_TINY_MEMSET=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/imx8qxp_ai_ml.h b/include/configs/imx8qxp_ai_ml.h new file mode 100644 index 0000000000..bdac710103 --- /dev/null +++ b/include/configs/imx8qxp_ai_ml.h @@ -0,0 +1,95 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + * Copyright 2019 Linaro Ltd. + */ + +#ifndef __IMX8QXP_AI_ML_H +#define __IMX8QXP_AI_ML_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN (SZ_1K * SZ_1K) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x250 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 0 + +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x013E000 +#define CONFIG_SPL_BSS_START_ADDR 0x00128000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_4K /* 4 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x00120000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x3000 /* 12 KB */ +#define CONFIG_SERIAL_LPUART_BASE 0x5a080000 +#define CONFIG_MALLOC_F_ADDR 0x00120000 + +#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#define CONFIG_OF_SEPARATE +#endif + +#define CONFIG_REMAKE_ELF + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_BOARD_SETUP + +#define CONFIG_FSL_USDHC + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttyLP2 earlycon\0" \ + "fdt_addr_r=0x83000000\0" \ + "kernel_addr_r=0x81000000\0" \ + "ramdisk_addr_r=0x94400000\0" \ + "scriptaddr=0x89000000\0" \ + "fdtfile=imx8qxp-ai_ml.dtb\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "image=Image\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp" \ + "\0" \ + "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \ + "imx8qxp-ai_ml/${fdt_file}; booti ${loadaddr} - ${fdt_addr}\0" \ + BOOTENV + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +/* USDHC2 is the SD card interface */ +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE SZ_2G /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */ + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +/* Networking */ +#define CONFIG_FEC_XCV_TYPE RGMII +#define FEC_QUIRK_ENET_MAC + +#endif /* __IMX8QXP_AI_ML_H */
- Debug serial via UART2
- SD card
- Ethernet
Looks like this patch has fallen through the cracks! Let me know if I have to resend it (again).
Thanks, Mani
- bool "Support i.MX8QXP AI_ML board"
- select BOARD_EARLY_INIT_F
- select IMX8QXP
endchoice
+config SYS_BOARD
- default "imx8qxp_ai_ml"
+config SYS_VENDOR
- default "einfochips"
- default 0x2400000
+config ENV_SIZE
- default 0x1000
+config ENV_OFFSET
- default 0x400000
+Boot +====
- Copyright 2018 NXP
- Copyright 2019 Linaro Ltd.
- sc_pm_clock_rate_t rate = SC_80MHZ;
- int ret;
- /* Set UART2 clock root to 80 MHz */
- ret = sc_pm_setup_uart(SC_R_UART_2, rate);
- if (ret)
return ret;
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100);
- if (phydev->drv->config)
+} +#endif
- puts("Board: iMX8QXP AI_ML\n");
- build_info();
- print_bootinfo();
- /* TODO */
- Refer doc/README.imx8image for more details about how-to configure
- and create imx8image boot image
- arch_cpu_init();
- timer_init();
- preloader_console_init();
- puts("Normal Boot\n");
- /* Clear global data */
- memset((void *)gd, 0, sizeof(gd_t));
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- board_init_r(NULL, 0);
- func(MMC, mmc, 1) \
- func(DHCP, dhcp, na)
- "console=ttyLP2 earlycon\0" \
- "fdt_addr_r=0x83000000\0" \
- "kernel_addr_r=0x81000000\0" \
- "ramdisk_addr_r=0x94400000\0" \
- "scriptaddr=0x89000000\0" \
- "fdtfile=imx8qxp-ai_ml.dtb\0" \
- "fdt_high=0xffffffffffffffff\0" \
- "image=Image\0" \
- "initrd_addr=0x83800000\0" \
- "initrd_high=0xffffffffffffffff\0" \
- "netargs=setenv bootargs console=${console},${baudrate} " \
"\0" \
- "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \
- BOOTENV
2.17.1
Hi Manivannan,
On Fri, Jul 10, 2020 at 11:00 AM Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
- SD card
- Ethernet
Sorry for the delay. Your patch looks great:
Reviewed-by: Fabio Estevam festevam@gmail.com
Hi Mani,
- SD card
- Ethernet
Your board cannot be built clean - can you rebase and repost ? Thanks !
You can check the reason here:
https://travis-ci.org/github/sbabic/u-boot-imx/jobs/712217118
Best regards, Stefano
Thanks, Mani
- select IMX8QXP
- config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board" select BOARD_LATE_INIT
endchoice
+config SYS_BOARD
+config SYS_VENDOR
- default 0x2400000
+config ENV_SIZE
- default 0x1000
+config ENV_OFFSET
- default 0x400000
+Boot +====
- int ret;
- if (ret)
return ret;
+} +#endif
- build_info();
- print_bootinfo();
- /* TODO */
- arch_cpu_init();
- timer_init();
- "image=Image\0" \
"\0" \
- BOOTENV
2.17.1
Fabio Estevam
Stefano Babic
