[U-Boot] [PATCH] mmc: fsl_esdhc: fix calculation of timeout for data transactions
Calculation of the timeout value should be based on actual clock value, written to controller registers. Since mmc->tran_speed is either the maximum allowed speed, or the preliminary value, that is be not yet set to registers, the actual timeout, taken by the controller, based on its clock settings, may be much longer than expected, based on mmc->tran_speed value. In particular it happens at early initialization stage, when typical value of mmc->tran_speed is 20MHz or 26MHz, while actual clock setting, configured in the controller, is 400kHz. It's more correct to use mmc->clock value for timeout calculation instead.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/fsl_esdhc.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 7b146a3..f4d3132 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -221,16 +221,16 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) * 2)Timeout period should be minimum 0.250sec as per SD Card spec * So, Number of SD Clock cycles for 0.25sec should be minimum * (SD Clock/sec * 0.25 sec) SD Clock cycles - * = (mmc->tran_speed * 1/4) SD Clock cycles + * = (mmc->clock * 1/4) SD Clock cycles * As 1) >= 2) - * => (2^(timeout+13)) >= mmc->tran_speed * 1/4 + * => (2^(timeout+13)) >= mmc->clock * 1/4 * Taking log2 both the sides - * => timeout + 13 >= log2(mmc->tran_speed/4) + * => timeout + 13 >= log2(mmc->clock/4) * Rounding up to next power of 2 - * => timeout + 13 = log2(mmc->tran_speed/4) + 1 - * => timeout + 13 = fls(mmc->tran_speed/4) + * => timeout + 13 = log2(mmc->clock/4) + 1 + * => timeout + 13 = fls(mmc->clock/4) */ - timeout = fls(mmc->tran_speed/4); + timeout = fls(mmc->clock/4); timeout -= 13;
if (timeout > 14)
Hi Andrew,
- As 1) >= 2)
- Taking log2 both the sides
- Rounding up to next power of 2
*/* => timeout + 13 = fls(mmc->clock/4)
if (timeout > 14)
-- 1.7.10.4
Thanks
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Andrew Gabbasov
Pantelis Antoniou
