[U-Boot] [RFC PATCH 1/6] fpga: spartan2: Avoid CamelCase
No functional changes.
board/esd/pmc440/fpga.c | 2 +- board/matrix_vision/mvsmr/fpga.c | 2 +- drivers/fpga/spartan2.c | 40 ++++++++++++++++++++-------------------- drivers/fpga/xilinx.c | 14 +++++++------- include/spartan2.h | 32 ++++++++++++++++---------------- include/xilinx.h | 2 +- 6 files changed, 46 insertions(+), 46 deletions(-)
diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index b7b62dd..cef2050 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -47,7 +47,7 @@ Xilinx_Spartan3_Slave_Serial_fns pmc440_fpga_fns = { }; #endif
-Xilinx_Spartan2_Slave_Serial_fns ngcc_fpga_fns = { +xilinx_spartan2_slave_serial_fns ngcc_fpga_fns = { ngcc_fpga_pre_config_fn, ngcc_fpga_pgm_fn, ngcc_fpga_clk_fn, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index 88035a9..639bc7c 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -27,7 +27,7 @@ Xilinx_Spartan3_Slave_Serial_fns fpga_fns = { };
Xilinx_desc spartan3 = { - Xilinx_Spartan2, + xilinx_spartan2, slave_serial, XILINX_XC3S200_SIZE, (void *) &fpga_fns, diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 6eab1b5..bd31709 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -31,29 +31,29 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan2_sp_info(Xilinx_desc *desc ); */ +static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_sp_info(Xilinx_desc *desc ); */
-static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan2_ss_info(Xilinx_desc *desc ); */ +static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_ss_info(Xilinx_desc *desc ); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int Spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Spartan2_ss_load (desc, buf, bsize); + ret_val = spartan2_ss_load(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Spartan2_sp_load (desc, buf, bsize); + ret_val = spartan2_sp_load(desc, buf, bsize); break;
default: @@ -64,19 +64,19 @@ int Spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Spartan2_ss_dump (desc, buf, bsize); + ret_val = spartan2_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Spartan2_sp_dump (desc, buf, bsize); + ret_val = spartan2_sp_dump(desc, buf, bsize); break;
default: @@ -87,7 +87,7 @@ int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan2_info( Xilinx_desc *desc ) +int spartan2_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -96,10 +96,10 @@ int Spartan2_info( Xilinx_desc *desc ) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -248,10 +248,10 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -296,10 +296,10 @@ static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan2_Slave_Serial_fns *fn = desc->iface_fns; + xilinx_spartan2_slave_serial_fns *fn = desc->iface_fns; int i; unsigned char val;
@@ -439,7 +439,7 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 2e0db53..47bbf39 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -149,11 +149,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Loader...\n", __FUNCTION__); - ret_val = Spartan2_load (desc, buf, bsize); + ret_val = spartan2_load(desc, buf, bsize); #else printf ("%s: No support for Spartan-II devices.\n", __FUNCTION__); @@ -206,11 +206,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) printf ("%s: Invalid device descriptor\n", __FUNCTION__); } else switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Reader...\n", __FUNCTION__); - ret_val = Spartan2_dump (desc, buf, bsize); + ret_val = spartan2_dump(desc, buf, bsize); #else printf ("%s: No support for Spartan-II devices.\n", __FUNCTION__); @@ -262,7 +262,7 @@ int xilinx_info (Xilinx_desc * desc) if (xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("Family: \t"); switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: printf ("Spartan-II\n"); break; case Xilinx_Spartan3: @@ -316,9 +316,9 @@ int xilinx_info (Xilinx_desc * desc) if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); switch (desc->family) { - case Xilinx_Spartan2: + case xilinx_spartan2: #if defined(CONFIG_FPGA_SPARTAN2) - Spartan2_info (desc); + spartan2_info(desc); #else /* just in case */ printf ("%s: No support for Spartan-II devices.\n", diff --git a/include/spartan2.h b/include/spartan2.h index 087a27d..a9fc68a 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-extern int Spartan2_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Spartan2_info(Xilinx_desc *desc); +int spartan2_load(Xilinx_desc *desc, const void *image, size_t size); +int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int spartan2_info(Xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { @@ -29,7 +29,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Spartan2_Slave_Parallel_fns; +} xilinx_spartan2_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -40,7 +40,7 @@ typedef struct { Xilinx_done_fn done; Xilinx_wr_fn wr; Xilinx_post_fn post; -} Xilinx_Spartan2_Slave_Serial_fns; +} xilinx_spartan2_slave_serial_fns;
/* Device Image Sizes *********************************************************************/ @@ -63,36 +63,36 @@ typedef struct { *********************************************************************/ /* Spartan-II devices */ #define XILINX_XC2S15_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie }
#define XILINX_XC2S30_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie }
#define XILINX_XC2S50_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie }
#define XILINX_XC2S100_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie }
#define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie }
#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie }
#define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie }
#define XILINX_XC2S100E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie }
#define XILINX_XC2S150E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie }
#define XILINX_XC2S200E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie }
#define XILINX_XC2S300E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie }
#endif /* _SPARTAN2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 00a585e..9d870b2 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -26,7 +26,7 @@ typedef enum { /* typedef Xilinx_iface */
typedef enum { /* typedef Xilinx_Family */ min_xilinx_type, /* low range check value */ - Xilinx_Spartan2, /* Spartan-II Family */ + xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ Xilinx_Virtex2, /* Virtex2 Family */ Xilinx_Spartan3, /* Spartan-III Family */ -- 1.8.2.3
board/armadeus/apf27/fpga.c | 4 ++-- board/astro/mcf5373l/fpga.c | 4 ++-- board/balloon3/balloon3.c | 2 +- board/esd/pmc440/fpga.c | 4 ++-- board/matrix_vision/mvsmr/fpga.c | 2 +- board/spear/x600/fpga.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 2 +- drivers/fpga/spartan3.c | 40 ++++++++++++++++++------------------ drivers/fpga/xilinx.c | 14 ++++++------- include/spartan3.h | 38 +++++++++++++++++----------------- include/xilinx.h | 2 +- 11 files changed, 57 insertions(+), 57 deletions(-)
diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c index 0c08c06..56fde20 100644 --- a/board/armadeus/apf27/fpga.c +++ b/board/armadeus/apf27/fpga.c @@ -26,7 +26,7 @@ * Spartan2 code is used to download our Spartan 3 :) code is compatible. * Just take care about the file size */ -Xilinx_Spartan3_Slave_Parallel_fns fpga_fns = { +xilinx_spartan3_slave_parallel_fns fpga_fns = { fpga_pre_fn, fpga_pgm_fn, fpga_init_fn, @@ -43,7 +43,7 @@ Xilinx_Spartan3_Slave_Parallel_fns fpga_fns = { };
Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Spartan3, + {xilinx_spartan3, slave_parallel, 1196128l/8, (void *)&fpga_fns, diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index c679ad7..152ff1f 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -363,7 +363,7 @@ int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) * relocated at runtime. * FIXME: relocation not yet working for coldfire, see below! */ -Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { +xilinx_spartan3_slave_serial_fns xilinx_fns = { xilinx_pre_config_fn, xilinx_pgm_fn, xilinx_clk_fn, @@ -375,7 +375,7 @@ Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { };
Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Spartan3, + {xilinx_spartan3, slave_serial, XILINX_XC3S4000_SIZE, (void *)&xilinx_fns, diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index 04e0574..4aa6605 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -191,7 +191,7 @@ int fpga_cs_fn(int assert_clk, int flush, int cookie) return assert_clk; }
-Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { +xilinx_spartan3_slave_parallel_fns balloon3_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index cef2050..18a1b63 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR; #define USE_SP_CODE
#ifdef USE_SP_CODE -Xilinx_Spartan3_Slave_Parallel_fns pmc440_fpga_fns = { +xilinx_spartan3_slave_parallel_fns pmc440_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, @@ -36,7 +36,7 @@ Xilinx_Spartan3_Slave_Parallel_fns pmc440_fpga_fns = { fpga_post_config_fn, }; #else -Xilinx_Spartan3_Slave_Serial_fns pmc440_fpga_fns = { +xilinx_spartan3_slave_serial_fns pmc440_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index 639bc7c..b207455 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -16,7 +16,7 @@ #include "fpga.h" #include "mvsmr.h"
-Xilinx_Spartan3_Slave_Serial_fns fpga_fns = { +xilinx_spartan3_slave_serial_fns fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/spear/x600/fpga.c b/board/spear/x600/fpga.c index c06c994..c26eba4 100644 --- a/board/spear/x600/fpga.c +++ b/board/spear/x600/fpga.c @@ -163,7 +163,7 @@ static int fpga_wr_fn(int assert_write, int flush, int cookie) return assert_write; }
-static Xilinx_Spartan3_Slave_Serial_fns x600_fpga_fns = { +static xilinx_spartan3_slave_serial_fns x600_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index c32d554..a361764 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -190,7 +190,7 @@ int fpga_clk_fn(int assert_clk, int flush, int cookie) return assert_clk; }
-Xilinx_Spartan3_Slave_Serial_fns mt_ventoux_fpga_fns = { +xilinx_spartan3_slave_serial_fns mt_ventoux_fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_clk_fn, diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 3edc5c2..e40abbf 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -35,29 +35,29 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan3_sp_info(Xilinx_desc *desc ); */ +static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_sp_info(Xilinx_desc *desc ); */
-static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int Spartan3_ss_info(Xilinx_desc *desc); */ +static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_ss_info(Xilinx_desc *desc); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int Spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Spartan3_ss_load (desc, buf, bsize); + ret_val = spartan3_ss_load(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Spartan3_sp_load (desc, buf, bsize); + ret_val = spartan3_sp_load(desc, buf, bsize); break;
default: @@ -68,19 +68,19 @@ int Spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Spartan3_ss_dump (desc, buf, bsize); + ret_val = spartan3_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Spartan3_sp_dump (desc, buf, bsize); + ret_val = spartan3_sp_dump(desc, buf, bsize); break;
default: @@ -91,7 +91,7 @@ int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Spartan3_info( Xilinx_desc *desc ) +int spartan3_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -100,10 +100,10 @@ int Spartan3_info( Xilinx_desc *desc ) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -254,10 +254,10 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Parallel_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -302,10 +302,10 @@ static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ - Xilinx_Spartan3_Slave_Serial_fns *fn = desc->iface_fns; + xilinx_spartan3_slave_serial_fns *fn = desc->iface_fns; int i; unsigned char val;
@@ -457,7 +457,7 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 47bbf39..7d93d64 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -159,11 +159,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Loader...\n", __FUNCTION__); - ret_val = Spartan3_load (desc, buf, bsize); + ret_val = spartan3_load(desc, buf, bsize); #else printf ("%s: No support for Spartan-III devices.\n", __FUNCTION__); @@ -216,11 +216,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Reader...\n", __FUNCTION__); - ret_val = Spartan3_dump (desc, buf, bsize); + ret_val = spartan3_dump(desc, buf, bsize); #else printf ("%s: No support for Spartan-III devices.\n", __FUNCTION__); @@ -265,7 +265,7 @@ int xilinx_info (Xilinx_desc * desc) case xilinx_spartan2: printf ("Spartan-II\n"); break; - case Xilinx_Spartan3: + case xilinx_spartan3: printf ("Spartan-III\n"); break; case Xilinx_Virtex2: @@ -325,9 +325,9 @@ int xilinx_info (Xilinx_desc * desc) __FUNCTION__); #endif break; - case Xilinx_Spartan3: + case xilinx_spartan3: #if defined(CONFIG_FPGA_SPARTAN3) - Spartan3_info (desc); + spartan3_info(desc); #else /* just in case */ printf ("%s: No support for Spartan-III devices.\n", diff --git a/include/spartan3.h b/include/spartan3.h index 72e7c0d..93ca8a4 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-extern int Spartan3_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Spartan3_info(Xilinx_desc *desc); +int spartan3_load(Xilinx_desc *desc, const void *image, size_t size); +int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int spartan3_info(Xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { @@ -29,7 +29,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Spartan3_Slave_Parallel_fns; +} xilinx_spartan3_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -42,7 +42,7 @@ typedef struct { Xilinx_post_fn post; Xilinx_bwr_fn bwr; /* block write function */ Xilinx_abort_fn abort; -} Xilinx_Spartan3_Slave_Serial_fns; +} xilinx_spartan3_slave_serial_fns;
/* Device Image Sizes *********************************************************************/ @@ -73,46 +73,46 @@ typedef struct { *********************************************************************/ /* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie }
#define XILINX_XC3S200_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie }
#define XILINX_XC3S400_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie }
#define XILINX_XC3S1000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie }
#define XILINX_XC3S1500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie }
#define XILINX_XC3S2000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie }
#define XILINX_XC3S4000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie }
#define XILINX_XC3S5000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie }
/* Spartan-3E devices */ #define XILINX_XC3S100E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie }
#define XILINX_XC3S250E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie }
#define XILINX_XC3S500E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie }
#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie }
#define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie }
#define XILINX_XC6SLX4_DESC(iface, fn_table, cookie) \ -{ Xilinx_Spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie }
#endif /* _SPARTAN3_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 9d870b2..365c0c3 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -29,7 +29,7 @@ typedef enum { /* typedef Xilinx_Family */ xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ Xilinx_Virtex2, /* Virtex2 Family */ - Xilinx_Spartan3, /* Spartan-III Family */ + xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ } Xilinx_Family; /* end, typedef Xilinx_Family */ -- 1.8.2.3
board/gen860t/fpga.c | 4 ++-- drivers/fpga/virtex2.c | 34 +++++++++++++++++----------------- drivers/fpga/xilinx.c | 14 +++++++------- include/virtex2.h | 34 +++++++++++++++++----------------- include/xilinx.h | 2 +- 5 files changed, 44 insertions(+), 44 deletions(-)
diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index b7984dd..48a4222 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -40,7 +40,7 @@ DECLARE_GLOBAL_DATA_PTR; /* Note that these are pointers to code that is in Flash. They will be * relocated at runtime. */ -Xilinx_Virtex2_Slave_SelectMap_fns fpga_fns = { +xilinx_virtex2_slave_selectmap_fns fpga_fns = { fpga_pre_config_fn, fpga_pgm_fn, fpga_init_fn, @@ -57,7 +57,7 @@ Xilinx_Virtex2_Slave_SelectMap_fns fpga_fns = { };
Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { - {Xilinx_Virtex2, + {xilinx_virtex2, slave_selectmap, XILINX_XC2V3000_SIZE, (void *) &fpga_fns, diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index b5a895d..1cd9046 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -84,25 +84,25 @@ #define CONFIG_SYS_FPGA_WAIT_CONFIG CONFIG_SYS_HZ/5 /* 200 ms */ #endif
-static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize);
-static int Virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int Virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize);
-int Virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Load\n", __FUNCTION__); - ret_val = Virtex2_ss_load (desc, buf, bsize); + ret_val = virtex2_ss_load(desc, buf, bsize); break;
case slave_selectmap: PRINTF ("%s: Launching Slave Parallel Load\n", __FUNCTION__); - ret_val = Virtex2_ssm_load (desc, buf, bsize); + ret_val = virtex2_ssm_load(desc, buf, bsize); break;
default: @@ -112,19 +112,19 @@ int Virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
switch (desc->iface) { case slave_serial: PRINTF ("%s: Launching Slave Serial Dump\n", __FUNCTION__); - ret_val = Virtex2_ss_dump (desc, buf, bsize); + ret_val = virtex2_ss_dump(desc, buf, bsize); break;
case slave_parallel: PRINTF ("%s: Launching Slave Parallel Dump\n", __FUNCTION__); - ret_val = Virtex2_ssm_dump (desc, buf, bsize); + ret_val = virtex2_ssm_dump(desc, buf, bsize); break;
default: @@ -134,7 +134,7 @@ int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int Virtex2_info (Xilinx_desc * desc) +int virtex2_info(Xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,10 +153,10 @@ int Virtex2_info (Xilinx_desc * desc) * INIT_B and DONE lines. If both are high, configuration has * succeeded. Congratulations! */ -static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; - Xilinx_Virtex2_Slave_SelectMap_fns *fn = desc->iface_fns; + xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns;
PRINTF ("%s:%d: Start with interface functions @ 0x%p\n", __FUNCTION__, __LINE__, fn); @@ -352,10 +352,10 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Read the FPGA configuration data */ -static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; - Xilinx_Virtex2_Slave_SelectMap_fns *fn = desc->iface_fns; + xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns;
if (fn) { unsigned char *data = (unsigned char *) buf; @@ -404,13 +404,13 @@ static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int Virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Loading is unsupported\n", __FUNCTION__); return FPGA_FAIL; }
-static int Virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Dumping is unsupported\n", __FUNCTION__); return FPGA_FAIL; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 7d93d64..6953535 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -169,11 +169,11 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined(CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Loader...\n", __FUNCTION__); - ret_val = Virtex2_load (desc, buf, bsize); + ret_val = virtex2_load(desc, buf, bsize); #else printf ("%s: No support for Virtex-II devices.\n", __FUNCTION__); @@ -226,11 +226,11 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined( CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Reader...\n", __FUNCTION__); - ret_val = Virtex2_dump (desc, buf, bsize); + ret_val = virtex2_dump(desc, buf, bsize); #else printf ("%s: No support for Virtex-II devices.\n", __FUNCTION__); @@ -268,7 +268,7 @@ int xilinx_info (Xilinx_desc * desc) case xilinx_spartan3: printf ("Spartan-III\n"); break; - case Xilinx_Virtex2: + case xilinx_virtex2: printf ("Virtex-II\n"); break; case xilinx_zynq: @@ -334,9 +334,9 @@ int xilinx_info (Xilinx_desc * desc) __FUNCTION__); #endif break; - case Xilinx_Virtex2: + case xilinx_virtex2: #if defined(CONFIG_FPGA_VIRTEX2) - Virtex2_info (desc); + virtex2_info(desc); #else /* just in case */ printf ("%s: No support for Virtex-II devices.\n", diff --git a/include/virtex2.h b/include/virtex2.h index 2e9a4f5..1e6624c 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,9 @@
#include <xilinx.h>
-extern int Virtex2_load(Xilinx_desc *desc, const void *image, size_t size); -extern int Virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int Virtex2_info(Xilinx_desc *desc); +int virtex2_load(Xilinx_desc *desc, const void *image, size_t size); +int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +int virtex2_info(Xilinx_desc *desc);
/* * Slave SelectMap Implementation function table. @@ -32,7 +32,7 @@ typedef struct { Xilinx_busy_fn busy; Xilinx_abort_fn abort; Xilinx_post_fn post; -} Xilinx_Virtex2_Slave_SelectMap_fns; +} xilinx_virtex2_slave_selectmap_fns;
/* Slave Serial Implementation function table */ typedef struct { @@ -40,7 +40,7 @@ typedef struct { Xilinx_clk_fn clk; Xilinx_rdata_fn rdata; Xilinx_wdata_fn wdata; -} Xilinx_Virtex2_Slave_Serial_fns; +} xilinx_virtex2_slave_serial_fns;
/* Device Image Sizes (in bytes) *********************************************************************/ @@ -60,39 +60,39 @@ typedef struct { /* Descriptor Macros *********************************************************************/ #define XILINX_XC2V40_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie }
#define XILINX_XC2V80_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie }
#define XILINX_XC2V250_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie }
#define XILINX_XC2V500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie }
#define XILINX_XC2V1000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie }
#define XILINX_XC2V1500_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie }
#define XILINX_XC2V2000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie }
#define XILINX_XC2V3000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie }
#define XILINX_XC2V4000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie }
#define XILINX_XC2V6000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie }
#define XILINX_XC2V8000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie }
#define XILINX_XC2V10000_DESC(iface, fn_table, cookie) \ -{ Xilinx_Virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie }
#endif /* _VIRTEX2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 365c0c3..fa89fb6 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -28,7 +28,7 @@ typedef enum { /* typedef Xilinx_Family */ min_xilinx_type, /* low range check value */ xilinx_spartan2, /* Spartan-II Family */ Xilinx_VirtexE, /* Virtex-E Family */ - Xilinx_Virtex2, /* Virtex2 Family */ + xilinx_virtex2, /* Virtex2 Family */ xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ -- 1.8.2.3
board/armadeus/apf27/fpga.c | 2 +- board/astro/mcf5373l/fpga.c | 2 +- board/balloon3/balloon3.c | 2 +- board/esd/pmc440/fpga.c | 2 +- board/gen860t/fpga.c | 2 +- board/matrix_vision/mvsmr/fpga.c | 2 +- board/spear/x600/fpga.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 2 +- board/xilinx/zynq/board.c | 14 +++++++------- drivers/fpga/spartan2.c | 26 +++++++++++++------------- drivers/fpga/spartan3.c | 26 +++++++++++++------------- drivers/fpga/virtex2.c | 22 +++++++++++----------- drivers/fpga/xilinx.c | 14 +++++++------- drivers/fpga/zynqpl.c | 6 +++--- include/spartan2.h | 6 +++--- include/spartan3.h | 6 +++--- include/virtex2.h | 6 +++--- include/xilinx.h | 10 +++++----- include/zynqpl.h | 6 +++--- 19 files changed, 79 insertions(+), 79 deletions(-)
diff --git a/board/armadeus/apf27/fpga.c b/board/armadeus/apf27/fpga.c index 56fde20..7d6e1e4 100644 --- a/board/armadeus/apf27/fpga.c +++ b/board/armadeus/apf27/fpga.c @@ -42,7 +42,7 @@ xilinx_spartan3_slave_parallel_fns fpga_fns = { fpga_post_fn, };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { {xilinx_spartan3, slave_parallel, 1196128l/8, diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c index 152ff1f..9dc82c5 100644 --- a/board/astro/mcf5373l/fpga.c +++ b/board/astro/mcf5373l/fpga.c @@ -374,7 +374,7 @@ xilinx_spartan3_slave_serial_fns xilinx_fns = { xilinx_fastwr_fn };
-Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { {xilinx_spartan3, slave_serial, XILINX_XC3S4000_SIZE, diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index 4aa6605..aa108ca 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -207,7 +207,7 @@ xilinx_spartan3_slave_parallel_fns balloon3_fpga_fns = { fpga_post_config_fn, };
-Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, +xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, (void *)&balloon3_fpga_fns, 0);
/* Initialize the FPGA */ diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index 18a1b63..f876da8 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -57,7 +57,7 @@ xilinx_spartan2_slave_serial_fns ngcc_fpga_fns = { ngcc_fpga_post_config_fn };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { XILINX_XC3S1200E_DESC( #ifdef USE_SP_CODE slave_parallel, diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index 48a4222..dd0ef70 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -56,7 +56,7 @@ xilinx_virtex2_slave_selectmap_fns fpga_fns = { fpga_post_config_fn };
-Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +xilinx_desc fpga[CONFIG_FPGA_COUNT] = { {xilinx_virtex2, slave_selectmap, XILINX_XC2V3000_SIZE, diff --git a/board/matrix_vision/mvsmr/fpga.c b/board/matrix_vision/mvsmr/fpga.c index b207455..5189925 100644 --- a/board/matrix_vision/mvsmr/fpga.c +++ b/board/matrix_vision/mvsmr/fpga.c @@ -26,7 +26,7 @@ xilinx_spartan3_slave_serial_fns fpga_fns = { 0 };
-Xilinx_desc spartan3 = { +xilinx_desc spartan3 = { xilinx_spartan2, slave_serial, XILINX_XC3S200_SIZE, diff --git a/board/spear/x600/fpga.c b/board/spear/x600/fpga.c index c26eba4..b256222 100644 --- a/board/spear/x600/fpga.c +++ b/board/spear/x600/fpga.c @@ -173,7 +173,7 @@ static xilinx_spartan3_slave_serial_fns x600_fpga_fns = { fpga_post_config_fn, };
-static Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { +static xilinx_desc fpga[CONFIG_FPGA_COUNT] = { XILINX_XC3S1200E_DESC(slave_serial, &x600_fpga_fns, 0) };
diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index a361764..b4a0a72 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -200,7 +200,7 @@ xilinx_spartan3_slave_serial_fns mt_ventoux_fpga_fns = { fpga_post_config_fn, };
-Xilinx_desc fpga = XILINX_XC6SLX4_DESC(slave_serial, +xilinx_desc fpga = XILINX_XC6SLX4_DESC(slave_serial, (void *)&mt_ventoux_fpga_fns, 0);
/* Initialize the FPGA */ diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 485a5e4..c8cc2bc 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -14,15 +14,15 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_FPGA -Xilinx_desc fpga; +xilinx_desc fpga;
/* It can be done differently */ -Xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); -Xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); -Xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); -Xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); -Xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); -Xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); +xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); +xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); +xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); +xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); +xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); +xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); #endif
int board_init(void) diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index bd31709..0796729 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -31,17 +31,17 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan2_sp_info(Xilinx_desc *desc ); */ +static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_sp_info(xilinx_desc *desc ); */
-static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan2_ss_info(Xilinx_desc *desc ); */ +static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan2_ss_info(xilinx_desc *desc ); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -64,7 +64,7 @@ int spartan2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -87,7 +87,7 @@ int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_info(Xilinx_desc *desc) +int spartan2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -96,7 +96,7 @@ int spartan2_info(Xilinx_desc *desc) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns; @@ -248,7 +248,7 @@ static int spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_parallel_fns *fn = desc->iface_fns; @@ -296,7 +296,7 @@ static int spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan2_slave_serial_fns *fn = desc->iface_fns; @@ -439,7 +439,7 @@ static int spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index e40abbf..1304b4c 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -35,17 +35,17 @@ #define CONFIG_SYS_FPGA_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ #endif
-static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan3_sp_info(Xilinx_desc *desc ); */ +static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_sp_info(xilinx_desc *desc ); */
-static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -/* static int spartan3_ss_info(Xilinx_desc *desc); */ +static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize); +/* static int spartan3_ss_info(xilinx_desc *desc); */
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -68,7 +68,7 @@ int spartan3_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -91,7 +91,7 @@ int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_info(Xilinx_desc *desc) +int spartan3_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -100,7 +100,7 @@ int spartan3_info(Xilinx_desc *desc) /* ------------------------------------------------------------------------- */ /* Spartan-II Slave Parallel Generic Implementation */
-static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns; @@ -254,7 +254,7 @@ static int spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_sp_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_parallel_fns *fn = desc->iface_fns; @@ -302,7 +302,7 @@ static int spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
-static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume the worst */ xilinx_spartan3_slave_serial_fns *fn = desc->iface_fns; @@ -457,7 +457,7 @@ static int spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int spartan3_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { /* Readback is only available through the Slave Parallel and */ /* boundary-scan interfaces. */ diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index 1cd9046..a582bf2 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -84,13 +84,13 @@ #define CONFIG_SYS_FPGA_WAIT_CONFIG CONFIG_SYS_HZ/5 /* 200 ms */ #endif
-static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize); -static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); +static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -112,7 +112,7 @@ int virtex2_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -134,7 +134,7 @@ int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_info(Xilinx_desc *desc) +int virtex2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,7 +153,7 @@ int virtex2_info(Xilinx_desc *desc) * INIT_B and DONE lines. If both are high, configuration has * succeeded. Congratulations! */ -static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns; @@ -352,7 +352,7 @@ static int virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Read the FPGA configuration data */ -static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; xilinx_virtex2_slave_selectmap_fns *fn = desc->iface_fns; @@ -404,13 +404,13 @@ static int virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-static int virtex2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Loading is unsupported\n", __FUNCTION__); return FPGA_FAIL; }
-static int virtex2_ss_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) { printf ("%s: Slave Serial Dumping is unsupported\n", __FUNCTION__); return FPGA_FAIL; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 6953535..b0e9cb3 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -31,7 +31,7 @@ #endif
/* Local Static Functions */ -static int xilinx_validate (Xilinx_desc * desc, char *fn); +static int xilinx_validate(xilinx_desc *desc, char *fn);
@@ -43,7 +43,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) unsigned char *dataptr; unsigned int i; const fpga_desc *desc; - Xilinx_desc *xdesc; + xilinx_desc *xdesc;
dataptr = (unsigned char *)fpgadata; /* Find out fpga_description */ @@ -94,7 +94,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) return FPGA_FAIL; } } else { - printf("%s: Please fill correct device ID to Xilinx_desc\n", + printf("%s: Please fill correct device ID to xilinx_desc\n", __func__); } printf(" part number = "%s"\n", buffer); @@ -141,7 +141,7 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size) return fpga_load(devnum, dataptr, swapsize); }
-int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume a failure */
@@ -198,7 +198,7 @@ int xilinx_load(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL; /* assume a failure */
@@ -255,7 +255,7 @@ int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int xilinx_info (Xilinx_desc * desc) +int xilinx_info(xilinx_desc *desc) { int ret_val = FPGA_FAIL;
@@ -369,7 +369,7 @@ int xilinx_info (Xilinx_desc * desc)
-static int xilinx_validate (Xilinx_desc * desc, char *fn) +static int xilinx_validate(xilinx_desc *desc, char *fn) { int ret_val = false;
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index 923a158..b4d0e22 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -36,7 +36,7 @@ #define CONFIG_SYS_FPGA_PROG_TIME (CONFIG_SYS_HZ * 4) /* 4 s */ #endif
-int zynq_info(Xilinx_desc *desc) +int zynq_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -153,7 +153,7 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) }
-int zynq_load(Xilinx_desc *desc, const void *buf, size_t bsize) +int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) { unsigned long ts; /* Timestamp */ u32 partialbit = 0; @@ -358,7 +358,7 @@ int zynq_load(Xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_SUCCESS; }
-int zynq_dump(Xilinx_desc *desc, const void *buf, size_t bsize) +int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) { return FPGA_FAIL; } diff --git a/include/spartan2.h b/include/spartan2.h index a9fc68a..33b25e6 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-int spartan2_load(Xilinx_desc *desc, const void *image, size_t size); -int spartan2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int spartan2_info(Xilinx_desc *desc); +int spartan2_load(xilinx_desc *desc, const void *image, size_t size); +int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int spartan2_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { diff --git a/include/spartan3.h b/include/spartan3.h index 93ca8a4..e06b99b 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,9 +10,9 @@
#include <xilinx.h>
-int spartan3_load(Xilinx_desc *desc, const void *image, size_t size); -int spartan3_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int spartan3_info(Xilinx_desc *desc); +int spartan3_load(xilinx_desc *desc, const void *image, size_t size); +int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int spartan3_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { diff --git a/include/virtex2.h b/include/virtex2.h index 1e6624c..dd47965 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,9 @@
#include <xilinx.h>
-int virtex2_load(Xilinx_desc *desc, const void *image, size_t size); -int virtex2_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -int virtex2_info(Xilinx_desc *desc); +int virtex2_load(xilinx_desc *desc, const void *image, size_t size); +int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int virtex2_info(xilinx_desc *desc);
/* * Slave SelectMap Implementation function table. diff --git a/include/xilinx.h b/include/xilinx.h index fa89fb6..5900c83 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -34,20 +34,20 @@ typedef enum { /* typedef Xilinx_Family */ max_xilinx_type /* insert all new types before this */ } Xilinx_Family; /* end, typedef Xilinx_Family */
-typedef struct { /* typedef Xilinx_desc */ +typedef struct { /* typedef xilinx_desc */ Xilinx_Family family; /* part type */ Xilinx_iface iface; /* interface type */ size_t size; /* bytes of data part can accept */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ char *name; /* device name in bitstream */ -} Xilinx_desc; /* end, typedef Xilinx_desc */ +} xilinx_desc; /* end, typedef xilinx_desc */
/* Generic Xilinx Functions *********************************************************************/ -extern int xilinx_load(Xilinx_desc *desc, const void *image, size_t size); -extern int xilinx_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int xilinx_info(Xilinx_desc *desc); +int xilinx_load(xilinx_desc *desc, const void *image, size_t size); +int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int xilinx_info(xilinx_desc *desc);
/* Board specific implementation specific function types *********************************************************************/ diff --git a/include/zynqpl.h b/include/zynqpl.h index c81446e..fdee691 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -12,9 +12,9 @@
#include <xilinx.h>
-extern int zynq_load(Xilinx_desc *desc, const void *image, size_t size); -extern int zynq_dump(Xilinx_desc *desc, const void *buf, size_t bsize); -extern int zynq_info(Xilinx_desc *desc); +int zynq_load(xilinx_desc *desc, const void *image, size_t size); +int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize); +int zynq_info(xilinx_desc *desc);
#define XILINX_ZYNQ_7010 0x2 #define XILINX_ZYNQ_7015 0x1b -- 1.8.2.3
include/spartan2.h | 40 ++++++++++++++++++++-------------------- include/spartan3.h | 44 ++++++++++++++++++++++---------------------- include/virtex2.h | 34 +++++++++++++++++----------------- include/xilinx.h | 42 +++++++++++++++++++++--------------------- 4 files changed, 80 insertions(+), 80 deletions(-)
diff --git a/include/spartan2.h b/include/spartan2.h index 33b25e6..25db6e7 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -16,30 +16,30 @@ int spartan2_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_spartan2_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_init_fn init; - Xilinx_done_fn done; - Xilinx_wr_fn wr; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_init_fn init; + xilinx_done_fn done; + xilinx_wr_fn wr; + xilinx_post_fn post; } xilinx_spartan2_slave_serial_fns;
/* Device Image Sizes diff --git a/include/spartan3.h b/include/spartan3.h index e06b99b..56698ac 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -16,32 +16,32 @@ int spartan3_info(xilinx_desc *desc);
/* Slave Parallel Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_spartan3_slave_parallel_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_init_fn init; - Xilinx_done_fn done; - Xilinx_wr_fn wr; - Xilinx_post_fn post; - Xilinx_bwr_fn bwr; /* block write function */ - Xilinx_abort_fn abort; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_init_fn init; + xilinx_done_fn done; + xilinx_wr_fn wr; + xilinx_post_fn post; + xilinx_bwr_fn bwr; /* block write function */ + xilinx_abort_fn abort; } xilinx_spartan3_slave_serial_fns;
/* Device Image Sizes diff --git a/include/virtex2.h b/include/virtex2.h index dd47965..d39286c 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -19,27 +19,27 @@ int virtex2_info(xilinx_desc *desc); * Slave SelectMap Implementation function table. */ typedef struct { - Xilinx_pre_fn pre; - Xilinx_pgm_fn pgm; - Xilinx_init_fn init; - Xilinx_err_fn err; - Xilinx_done_fn done; - Xilinx_clk_fn clk; - Xilinx_cs_fn cs; - Xilinx_wr_fn wr; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; - Xilinx_busy_fn busy; - Xilinx_abort_fn abort; - Xilinx_post_fn post; + xilinx_pre_fn pre; + xilinx_pgm_fn pgm; + xilinx_init_fn init; + xilinx_err_fn err; + xilinx_done_fn done; + xilinx_clk_fn clk; + xilinx_cs_fn cs; + xilinx_wr_fn wr; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; + xilinx_busy_fn busy; + xilinx_abort_fn abort; + xilinx_post_fn post; } xilinx_virtex2_slave_selectmap_fns;
/* Slave Serial Implementation function table */ typedef struct { - Xilinx_pgm_fn pgm; - Xilinx_clk_fn clk; - Xilinx_rdata_fn rdata; - Xilinx_wdata_fn wdata; + xilinx_pgm_fn pgm; + xilinx_clk_fn clk; + xilinx_rdata_fn rdata; + xilinx_wdata_fn wdata; } xilinx_virtex2_slave_serial_fns;
/* Device Image Sizes (in bytes) diff --git a/include/xilinx.h b/include/xilinx.h index 5900c83..533ba57 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -12,7 +12,7 @@
/* Xilinx types *********************************************************************/ -typedef enum { /* typedef Xilinx_iface */ +typedef enum { /* typedef xilinx_iface */ min_xilinx_iface_type, /* low range check value */ slave_serial, /* serial data and external clock */ master_serial, /* serial data w/ internal clock (not used) */ @@ -22,21 +22,21 @@ typedef enum { /* typedef Xilinx_iface */ slave_selectmap, /* slave SelectMap (virtex2) */ devcfg, /* devcfg interface (zynq) */ max_xilinx_iface_type /* insert all new types before this */ -} Xilinx_iface; /* end, typedef Xilinx_iface */ +} xilinx_iface; /* end, typedef xilinx_iface */
-typedef enum { /* typedef Xilinx_Family */ +typedef enum { /* typedef xilinx_family */ min_xilinx_type, /* low range check value */ xilinx_spartan2, /* Spartan-II Family */ - Xilinx_VirtexE, /* Virtex-E Family */ + xilinx_virtexE, /* Virtex-E Family */ xilinx_virtex2, /* Virtex2 Family */ xilinx_spartan3, /* Spartan-III Family */ xilinx_zynq, /* Zynq Family */ max_xilinx_type /* insert all new types before this */ -} Xilinx_Family; /* end, typedef Xilinx_Family */ +} xilinx_family; /* end, typedef xilinx_Family */
typedef struct { /* typedef xilinx_desc */ - Xilinx_Family family; /* part type */ - Xilinx_iface iface; /* interface type */ + xilinx_family family; /* part type */ + xilinx_iface iface; /* interface type */ size_t size; /* bytes of data part can accept */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ @@ -51,19 +51,19 @@ int xilinx_info(xilinx_desc *desc);
/* Board specific implementation specific function types *********************************************************************/ -typedef int (*Xilinx_pgm_fn)( int assert_pgm, int flush, int cookie ); -typedef int (*Xilinx_init_fn)( int cookie ); -typedef int (*Xilinx_err_fn)( int cookie ); -typedef int (*Xilinx_done_fn)( int cookie ); -typedef int (*Xilinx_clk_fn)( int assert_clk, int flush, int cookie ); -typedef int (*Xilinx_cs_fn)( int assert_cs, int flush, int cookie ); -typedef int (*Xilinx_wr_fn)( int assert_write, int flush, int cookie ); -typedef int (*Xilinx_rdata_fn)( unsigned char *data, int cookie ); -typedef int (*Xilinx_wdata_fn)( unsigned char data, int flush, int cookie ); -typedef int (*Xilinx_busy_fn)( int cookie ); -typedef int (*Xilinx_abort_fn)( int cookie ); -typedef int (*Xilinx_pre_fn)( int cookie ); -typedef int (*Xilinx_post_fn)( int cookie ); -typedef int (*Xilinx_bwr_fn)( void *buf, size_t len, int flush, int cookie ); +typedef int (*xilinx_pgm_fn)(int assert_pgm, int flush, int cookie); +typedef int (*xilinx_init_fn)(int cookie); +typedef int (*xilinx_err_fn)(int cookie); +typedef int (*xilinx_done_fn)(int cookie); +typedef int (*xilinx_clk_fn)(int assert_clk, int flush, int cookie); +typedef int (*xilinx_cs_fn)(int assert_cs, int flush, int cookie); +typedef int (*xilinx_wr_fn)(int assert_write, int flush, int cookie); +typedef int (*xilinx_rdata_fn)(unsigned char *data, int cookie); +typedef int (*xilinx_wdata_fn)(unsigned char data, int flush, int cookie); +typedef int (*xilinx_busy_fn)(int cookie); +typedef int (*xilinx_abort_fn)(int cookie); +typedef int (*xilinx_pre_fn)(int cookie); +typedef int (*xilinx_post_fn)(int cookie); +typedef int (*xilinx_bwr_fn)(void *buf, size_t len, int flush, int cookie);
#endif /* _XILINX_H_ */ -- 1.8.2.3
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test.
drivers/fpga/spartan2.c | 12 +++- drivers/fpga/spartan3.c | 12 +++- drivers/fpga/virtex2.c | 12 +++- drivers/fpga/xilinx.c | 159 +++--------------------------------------------- drivers/fpga/zynqpl.c | 13 ++-- include/spartan2.h | 28 ++++----- include/spartan3.h | 36 +++++------ include/virtex2.h | 28 ++++----- include/xilinx.h | 7 +++ include/zynqpl.h | 16 +++-- 10 files changed, 101 insertions(+), 222 deletions(-)
diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 0796729..42c966f 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -41,7 +41,7 @@ static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -64,7 +64,7 @@ int spartan2_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -87,7 +87,7 @@ int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan2_info(xilinx_desc *desc) +static int spartan2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -447,3 +447,9 @@ static int spartan2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); return FPGA_FAIL; } + +struct xilinx_fpga_op spartan2 = { + .load = spartan2_load, + .dump = spartan2_dump, + .info = spartan2_info, +}; diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 1304b4c..5c9412c 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -45,7 +45,7 @@ static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
/* ------------------------------------------------------------------------- */ /* Spartan-II Generic Implementation */ -int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -68,7 +68,7 @@ int spartan3_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -91,7 +91,7 @@ int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int spartan3_info(xilinx_desc *desc) +static int spartan3_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -465,3 +465,9 @@ static int spartan3_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) __FUNCTION__); return FPGA_FAIL; } + +struct xilinx_fpga_op spartan3_op = { + .load = spartan3_load, + .dump = spartan3_dump, + .info = spartan3_info, +}; diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index a582bf2..e092147 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -90,7 +90,7 @@ static int virtex2_ssm_dump(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_load(xilinx_desc *desc, const void *buf, size_t bsize); static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize);
-int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -112,7 +112,7 @@ int virtex2_load(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) { int ret_val = FPGA_FAIL;
@@ -134,7 +134,7 @@ int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize) return ret_val; }
-int virtex2_info(xilinx_desc *desc) +static int virtex2_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -417,3 +417,9 @@ static int virtex2_ss_dump(xilinx_desc *desc, const void *buf, size_t bsize) }
/* vim: set ts=4 tw=78: */ + +struct xilinx_fpga_op virtex2_op = { + .load = virtex2_load, + .dump = virtex2_dump, + .info = virtex2_info, +}; diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index b0e9cb3..8837f5c 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -19,17 +19,6 @@ #include <spartan3.h> #include <zynqpl.h>
-#if 0 -#define FPGA_DEBUG -#endif - -/* Define FPGA_DEBUG to get debug printf's */ -#ifdef FPGA_DEBUG -#define PRINTF(fmt,args...) printf (fmt ,##args) -#else -#define PRINTF(fmt,args...) -#endif - /* Local Static Functions */ static int xilinx_validate(xilinx_desc *desc, char *fn);
@@ -143,116 +132,22 @@ int fpga_loadbitstream(int devnum, char *fpgadata, size_t size)
int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize) { - int ret_val = FPGA_FAIL; /* assume a failure */ - if (!xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("%s: Invalid device descriptor\n", __FUNCTION__); - } else - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - PRINTF ("%s: Launching the Spartan-II Loader...\n", - __FUNCTION__); - ret_val = spartan2_load(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - PRINTF ("%s: Launching the Spartan-III Loader...\n", - __FUNCTION__); - ret_val = spartan3_load(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined(CONFIG_FPGA_VIRTEX2) - PRINTF ("%s: Launching the Virtex-II Loader...\n", - __FUNCTION__); - ret_val = virtex2_load(desc, buf, bsize); -#else - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - PRINTF("%s: Launching the Zynq PL Loader...\n", - __func__); - ret_val = zynq_load(desc, buf, bsize); -#else - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - break; - - default: - printf ("%s: Unsupported family type, %d\n", - __FUNCTION__, desc->family); - } + return FPGA_FAIL; + }
- return ret_val; + return desc->operations->load(desc, buf, bsize); }
int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize) { - int ret_val = FPGA_FAIL; /* assume a failure */ - if (!xilinx_validate (desc, (char *)__FUNCTION__)) { printf ("%s: Invalid device descriptor\n", __FUNCTION__); - } else - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - PRINTF ("%s: Launching the Spartan-II Reader...\n", - __FUNCTION__); - ret_val = spartan2_dump(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - PRINTF ("%s: Launching the Spartan-III Reader...\n", - __FUNCTION__); - ret_val = spartan3_dump(desc, buf, bsize); -#else - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined( CONFIG_FPGA_VIRTEX2) - PRINTF ("%s: Launching the Virtex-II Reader...\n", - __FUNCTION__); - ret_val = virtex2_dump(desc, buf, bsize); -#else - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - PRINTF("%s: Launching the Zynq PL Reader...\n", - __func__); - ret_val = zynq_dump(desc, buf, bsize); -#else - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - break; - - default: - printf ("%s: Unsupported family type, %d\n", - __FUNCTION__, desc->family); - } + return FPGA_FAIL; + }
- return ret_val; + return desc->operations->dump(desc, buf, bsize); }
int xilinx_info(xilinx_desc *desc) @@ -315,47 +210,7 @@ int xilinx_info(xilinx_desc *desc)
if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); - switch (desc->family) { - case xilinx_spartan2: -#if defined(CONFIG_FPGA_SPARTAN2) - spartan2_info(desc); -#else - /* just in case */ - printf ("%s: No support for Spartan-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_spartan3: -#if defined(CONFIG_FPGA_SPARTAN3) - spartan3_info(desc); -#else - /* just in case */ - printf ("%s: No support for Spartan-III devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_virtex2: -#if defined(CONFIG_FPGA_VIRTEX2) - virtex2_info(desc); -#else - /* just in case */ - printf ("%s: No support for Virtex-II devices.\n", - __FUNCTION__); -#endif - break; - case xilinx_zynq: -#if defined(CONFIG_FPGA_ZYNQPL) - zynq_info(desc); -#else - /* just in case */ - printf("%s: No support for Zynq devices.\n", - __func__); -#endif - /* Add new family types here */ - default: - /* we don't need a message here - we give one up above */ - ; - } + desc->operations->info(desc); } else printf ("No Device Function Table.\n");
diff --git a/drivers/fpga/zynqpl.c b/drivers/fpga/zynqpl.c index b4d0e22..dcd3495 100644 --- a/drivers/fpga/zynqpl.c +++ b/drivers/fpga/zynqpl.c @@ -36,7 +36,7 @@ #define CONFIG_SYS_FPGA_PROG_TIME (CONFIG_SYS_HZ * 4) /* 4 s */ #endif
-int zynq_info(xilinx_desc *desc) +static int zynq_info(xilinx_desc *desc) { return FPGA_SUCCESS; } @@ -152,8 +152,7 @@ static void *check_data(u8 *buf, size_t bsize, u32 *swap) return 0; }
- -int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) { unsigned long ts; /* Timestamp */ u32 partialbit = 0; @@ -358,7 +357,13 @@ int zynq_load(xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_SUCCESS; }
-int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) +static int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize) { return FPGA_FAIL; } + +struct xilinx_fpga_op zynq_op = { + .load = zynq_load, + .dump = zynq_dump, + .info = zynq_info, +}; diff --git a/include/spartan2.h b/include/spartan2.h index 25db6e7..2aca954 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -10,10 +10,6 @@
#include <xilinx.h>
-int spartan2_load(xilinx_desc *desc, const void *image, size_t size); -int spartan2_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int spartan2_info(xilinx_desc *desc); - /* Slave Parallel Implementation function table */ typedef struct { xilinx_pre_fn pre; @@ -42,6 +38,8 @@ typedef struct { xilinx_post_fn post; } xilinx_spartan2_slave_serial_fns;
+extern struct xilinx_fpga_op spartan2_op; + /* Device Image Sizes *********************************************************************/ /* Spartan-II (2.5V) */ @@ -63,36 +61,36 @@ typedef struct { *********************************************************************/ /* Spartan-II devices */ #define XILINX_XC2S15_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S30_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S100_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S150E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S200E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie, &spartan2_op }
#define XILINX_XC2S300E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie } +{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie, &spartan2_op }
#endif /* _SPARTAN2_H_ */ diff --git a/include/spartan3.h b/include/spartan3.h index 56698ac..d6d67a6 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -10,10 +10,6 @@
#include <xilinx.h>
-int spartan3_load(xilinx_desc *desc, const void *image, size_t size); -int spartan3_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int spartan3_info(xilinx_desc *desc); - /* Slave Parallel Implementation function table */ typedef struct { xilinx_pre_fn pre; @@ -44,6 +40,8 @@ typedef struct { xilinx_abort_fn abort; } xilinx_spartan3_slave_serial_fns;
+extern struct xilinx_fpga_op spartan3_op; + /* Device Image Sizes *********************************************************************/ /* Spartan-III (1.2V) */ @@ -73,46 +71,48 @@ typedef struct { *********************************************************************/ /* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S400_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1500_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S2000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S4000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S5000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie, &spartan3_op }
/* Spartan-3E devices */ #define XILINX_XC3S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S250E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S500E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie, &spartan3_op }
#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie, \ + &spartan3_op }
#define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie, \ + &spartan3_op }
#define XILINX_XC6SLX4_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie } +{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie, &spartan3_op }
#endif /* _SPARTAN3_H_ */ diff --git a/include/virtex2.h b/include/virtex2.h index d39286c..7b7825f 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,9 +11,7 @@
#include <xilinx.h>
-int virtex2_load(xilinx_desc *desc, const void *image, size_t size); -int virtex2_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int virtex2_info(xilinx_desc *desc); +extern struct xilinx_fpga_op virtex2_op;
/* * Slave SelectMap Implementation function table. @@ -60,39 +58,39 @@ typedef struct { /* Descriptor Macros *********************************************************************/ #define XILINX_XC2V40_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V80_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V250_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V1000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V1500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V2000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V3000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V4000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V6000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V8000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie, &virtex2_op }
#define XILINX_XC2V10000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie } +{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie, &virtex2_op }
#endif /* _VIRTEX2_H_ */ diff --git a/include/xilinx.h b/include/xilinx.h index 533ba57..f06b214 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -41,8 +41,15 @@ typedef struct { /* typedef xilinx_desc */ void *iface_fns; /* interface function table */ int cookie; /* implementation specific cookie */ char *name; /* device name in bitstream */ + struct xilinx_fpga_op *operations; /* operations */ } xilinx_desc; /* end, typedef xilinx_desc */
+struct xilinx_fpga_op { + int (*load)(xilinx_desc *, const void *, size_t); + int (*dump)(xilinx_desc *, const void *, size_t); + int (*info)(xilinx_desc *); +}; + /* Generic Xilinx Functions *********************************************************************/ int xilinx_load(xilinx_desc *desc, const void *image, size_t size); diff --git a/include/zynqpl.h b/include/zynqpl.h index fdee691..b53d92e 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -12,9 +12,7 @@
#include <xilinx.h>
-int zynq_load(xilinx_desc *desc, const void *image, size_t size); -int zynq_dump(xilinx_desc *desc, const void *buf, size_t bsize); -int zynq_info(xilinx_desc *desc); +extern struct xilinx_fpga_op zynq_op;
#define XILINX_ZYNQ_7010 0x2 #define XILINX_ZYNQ_7015 0x1b @@ -33,21 +31,21 @@ int zynq_info(xilinx_desc *desc);
/* Descriptor Macros */ #define XILINX_XC7Z010_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, "7z010" } +{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, "7z010", &zynq_op }
#define XILINX_XC7Z015_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, "7z015" } +{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, "7z015", &zynq_op }
#define XILINX_XC7Z020_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, "7z020" } +{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, "7z020", &zynq_op }
#define XILINX_XC7Z030_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, "7z030" } +{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, "7z030", &zynq_op }
#define XILINX_XC7Z045_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, "7z045" } +{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, "7z045", &zynq_op }
#define XILINX_XC7Z100_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, "7z100" } +{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, "7z100", &zynq_op }
#endif /* _ZYNQPL_H_ */ -- 1.8.2.3
I like the concept. Did you go through the u-boot.map files on spartan/etc to make sure we aren't discarding things now? That'd be the follow up on compile testing the series.
Good that you like the concept - this was my intention for this RFC. I will check it that's not a problem. Enough time to finish this for the next release.
The next patch I want to do in fpga is to synchronize load/loadbitstream commands. The reason is that we need to add one more load which is currently called loadfs which takes bitstream from filesystem and load it with small chunks which are passed to programmable IP. The whole reason is that system is working with limited amount of memory that's why can't be done in 2 steps that fatload is called and move bitstream to memory and then fpga load setup one DMA to program it.
Thanks, Michal
Michal Simek
Michal Simek
